[GRASS-SVN] r67333 - grass/trunk/vector/v.in.lidar
Tue Dec 22 14:17:52 PST 2015
Author: wenzeslaus
Date: 2015-12-22 14:17:52 -0800 (Tue, 22 Dec 2015)
New Revision: 67333
Added:
   grass/trunk/vector/v.in.lidar/info.c
   grass/trunk/vector/v.in.lidar/info.h
   grass/trunk/vector/v.in.lidar/main.c
v.in.lidar: move print info to a file
Function in sync with r.in.lidar.
Added: grass/trunk/vector/v.in.lidar/info.c
--- grass/trunk/vector/v.in.lidar/info.c	                        (rev 0)
+++ grass/trunk/vector/v.in.lidar/info.c	2015-12-22 22:17:52 UTC (rev 67333)
@@ -0,0 +1,89 @@
+ * v.in.lidar projection-related functions
+ * Copyright 2011-2015 by Markus Metz, and The GRASS Development Team
+ * Authors:
+ *  Markus Metz (v.in.lidar)
+ *  Vaclav Petras (move functions to a file)
+ * This program is free software licensed under the GPL (>=v2).
+ * Read the COPYING file that comes with GRASS for details.
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/gprojects.h>
+#include "info.h"
+void print_lasinfo(LASHeaderH LAS_header, LASSRSH LAS_srs)
+    char *las_srs_proj4 = LASSRS_GetProj4(LAS_srs);
+    int las_point_format = LASHeader_GetDataFormatId(LAS_header);
+    fprintf(stdout, "\nUsing LAS Library Version '%s'\n\n",
+            LAS_GetFullVersion());
+    fprintf(stdout, "LAS File Version:                  %d.%d\n",
+            LASHeader_GetVersionMajor(LAS_header),
+            LASHeader_GetVersionMinor(LAS_header));
+    fprintf(stdout, "System ID:                         '%s'\n",
+            LASHeader_GetSystemId(LAS_header));
+    fprintf(stdout, "Generating Software:               '%s'\n",
+            LASHeader_GetSoftwareId(LAS_header));
+    fprintf(stdout, "File Creation Day/Year:            %d/%d\n",
+            LASHeader_GetCreationDOY(LAS_header),
+            LASHeader_GetCreationYear(LAS_header));
+    fprintf(stdout, "Point Data Format:                 %d\n",
+            las_point_format);
+    fprintf(stdout, "Number of Point Records:           %d\n",
+            LASHeader_GetPointRecordsCount(LAS_header));
+    fprintf(stdout, "Number of Points by Return:        %d %d %d %d %d\n",
+            LASHeader_GetPointRecordsByReturnCount(LAS_header, 0),
+            LASHeader_GetPointRecordsByReturnCount(LAS_header, 1),
+            LASHeader_GetPointRecordsByReturnCount(LAS_header, 2),
+            LASHeader_GetPointRecordsByReturnCount(LAS_header, 3),
+            LASHeader_GetPointRecordsByReturnCount(LAS_header, 4));
+    fprintf(stdout, "Scale Factor X Y Z:                %g %g %g\n",
+            LASHeader_GetScaleX(LAS_header),
+            LASHeader_GetScaleY(LAS_header), LASHeader_GetScaleZ(LAS_header));
+    fprintf(stdout, "Offset X Y Z:                      %g %g %g\n",
+            LASHeader_GetOffsetX(LAS_header),
+            LASHeader_GetOffsetY(LAS_header),
+            LASHeader_GetOffsetZ(LAS_header));
+    fprintf(stdout, "Min X Y Z:                         %g %g %g\n",
+            LASHeader_GetMinX(LAS_header),
+            LASHeader_GetMinY(LAS_header), LASHeader_GetMinZ(LAS_header));
+    fprintf(stdout, "Max X Y Z:                         %g %g %g\n",
+            LASHeader_GetMaxX(LAS_header),
+            LASHeader_GetMaxY(LAS_header), LASHeader_GetMaxZ(LAS_header));
+    if (las_srs_proj4 && strlen(las_srs_proj4) > 0) {
+        fprintf(stdout, "Spatial Reference:\n");
+        fprintf(stdout, "%s\n", las_srs_proj4);
+    else {
+        fprintf(stdout, "Spatial Reference:                 None\n");
+    fprintf(stdout, "\nData Fields:\n");
+    fprintf(stdout,
+            "  'X'\n  'Y'\n  'Z'\n  'Intensity'\n  'Return Number'\n");
+    fprintf(stdout, "  'Number of Returns'\n  'Scan Direction'\n");
+    fprintf(stdout,
+            "  'Flighline Edge'\n  'Classification'\n  'Scan Angle Rank'\n");
+    fprintf(stdout, "  'User Data'\n  'Point Source ID'\n");
+    if (las_point_format == 1 || las_point_format == 3 ||
+        las_point_format == 4 || las_point_format == 5) {
+        fprintf(stdout, "  'GPS Time'\n");
+    if (las_point_format == 2 || las_point_format == 3 ||
+        las_point_format == 5) {
+        fprintf(stdout, "  'Red'\n  'Green'\n  'Blue'\n");
+    fprintf(stdout, "\n");
+    fflush(stdout);
+    return;
Added: grass/trunk/vector/v.in.lidar/info.h
--- grass/trunk/vector/v.in.lidar/info.h	                        (rev 0)
+++ grass/trunk/vector/v.in.lidar/info.h	2015-12-22 22:17:52 UTC (rev 67333)
@@ -0,0 +1,21 @@
+ * MODULE:       v.in.lidar
+ * AUTHOR(S):    Vaclav Petras
+ * PURPOSE:      projection related functions
+ * COPYRIGHT:    (C) 2015 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the COPYING file that comes with GRASS
+ *               for details.
+#include <liblas/capi/liblas.h>
+#ifndef LIDAR_INFO_H
+#define LIDAR_INFO_H
+void print_lasinfo(LASHeaderH LAS_header, LASSRSH LAS_srs);
+#endif /* LIDAR_INFO_H */
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c	2015-12-22 19:29:55 UTC (rev 67332)
+++ grass/trunk/vector/v.in.lidar/main.c	2015-12-22 22:17:52 UTC (rev 67333)
@@ -31,6 +31,7 @@
 #include "projection.h"
 #include "lidar.h"
 #include "attributes.h"
+#include "info.h"
 #ifndef MAX
 #  define MIN(a,b)      ((a<b) ? a : b)
@@ -38,8 +39,6 @@
 #endif
-void print_lasinfo(LASHeaderH LAS_header, LASSRSH LAS_srs);
 int main(int argc, char *argv[])
     int i;
@@ -887,71 +886,3 @@
     exit(EXIT_SUCCESS);
-    char *las_srs_proj4 = LASSRS_GetProj4(LAS_srs);
-    int las_point_format = LASHeader_GetDataFormatId(LAS_header);
-    fprintf(stdout, "\nUsing LAS Library Version '%s'\n\n",
-                    LAS_GetFullVersion());
-    fprintf(stdout, "LAS File Version:                  %d.%d\n",
-                    LASHeader_GetVersionMajor(LAS_header),
-                    LASHeader_GetVersionMinor(LAS_header));
-    fprintf(stdout, "System ID:                         '%s'\n",
-                    LASHeader_GetSystemId(LAS_header));
-    fprintf(stdout, "Generating Software:               '%s'\n",
-                    LASHeader_GetSoftwareId(LAS_header));
-    fprintf(stdout, "File Creation Day/Year:            %d/%d\n",
-                    LASHeader_GetCreationDOY(LAS_header),
-		    LASHeader_GetCreationYear(LAS_header));
-    fprintf(stdout, "Point Data Format:                 %d\n",
-                    las_point_format);
-    fprintf(stdout, "Number of Point Records:           %d\n",
-                    LASHeader_GetPointRecordsCount(LAS_header));
-    fprintf(stdout, "Number of Points by Return:        %d %d %d %d %d\n",
-                    LASHeader_GetPointRecordsByReturnCount(LAS_header, 0),
-                    LASHeader_GetPointRecordsByReturnCount(LAS_header, 1),
-                    LASHeader_GetPointRecordsByReturnCount(LAS_header, 2),
-                    LASHeader_GetPointRecordsByReturnCount(LAS_header, 3),
-                    LASHeader_GetPointRecordsByReturnCount(LAS_header, 4));
-    fprintf(stdout, "Scale Factor X Y Z:                %g %g %g\n",
-                    LASHeader_GetScaleX(LAS_header),
-                    LASHeader_GetScaleY(LAS_header),
-                    LASHeader_GetScaleZ(LAS_header));
-    fprintf(stdout, "Offset X Y Z:                      %g %g %g\n",
-                    LASHeader_GetOffsetX(LAS_header),
-                    LASHeader_GetOffsetY(LAS_header),
-                    LASHeader_GetOffsetZ(LAS_header));
-    fprintf(stdout, "Min X Y Z:                         %g %g %g\n",
-                    LASHeader_GetMinX(LAS_header),
-                    LASHeader_GetMinY(LAS_header),
-                    LASHeader_GetMinZ(LAS_header));
-    fprintf(stdout, "Max X Y Z:                         %g %g %g\n",
-                    LASHeader_GetMaxX(LAS_header),
-                    LASHeader_GetMaxY(LAS_header),
-                    LASHeader_GetMaxZ(LAS_header));
-    if (las_srs_proj4 && strlen(las_srs_proj4) > 0) {
-	fprintf(stdout, "Spatial Reference:\n");
-	fprintf(stdout, "%s\n", las_srs_proj4);
-    else {
-	fprintf(stdout, "Spatial Reference:                 None\n");
-    fprintf(stdout, "\nData Fields:\n");
-    fprintf(stdout, "  'X'\n  'Y'\n  'Z'\n  'Intensity'\n  'Return Number'\n");
-    fprintf(stdout, "  'Number of Returns'\n  'Scan Direction'\n");
-    fprintf(stdout, "  'Flighline Edge'\n  'Classification'\n  'Scan Angle Rank'\n");
-    fprintf(stdout, "  'User Data'\n  'Point Source ID'\n");
-    if (las_point_format == 1 || las_point_format == 3 || las_point_format == 4 || las_point_format == 5) {
-	fprintf(stdout, "  'GPS Time'\n");
-    if (las_point_format == 2 || las_point_format == 3 || las_point_format == 5) {
-	fprintf(stdout, "  'Red'\n  'Green'\n  'Blue'\n");
-    fprintf(stdout, "\n");
-    fflush(stdout);
-    return;
