[GRASS-SVN] r67336 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Wed Dec 23 03:14:36 PST 2015
Author: mlennert
Date: 2015-12-23 03:14:36 -0800 (Wed, 23 Dec 2015)
New Revision: 67336
grass/trunk/gui/wxpython/lmgr/layertree.py
add attribute export to vector layer context menu
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2015-12-23 01:47:48 UTC (rev 67335)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2015-12-23 11:14:36 UTC (rev 67336)
@@ -406,7 +406,7 @@
'region', 'export', 'attr', 'edit', 'save_ws',
'bgmap', 'topo', 'meta', 'null', 'zoom1',
'color', 'colori', 'hist', 'univar', 'prof', 'properties', 'sql', 'copy',
- 'report', 'export-pg', 'pack'):
+ 'report', 'export-pg', 'export-attr', 'pack'):
self.popupID[key] = wx.NewId()
# get current mapset
@@ -490,6 +490,13 @@
if 'v.out.postgis' not in globalvar.grassCmd:
self.popupMenu.Enable(self.popupID['export-pg'], False)
+ self.popupMenu.Append(self.popupID['export-attr'], text = _("Export attribute table"))
+ self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['v.db.select',
+ 'map=%s' % mapLayer.GetName()]),
+ id = self.popupID['export-attr'])
+ if 'v.db.select' not in globalvar.grassCmd:
+ self.popupMenu.Enable(self.popupID['export-attr'], False)
item = wx.MenuItem(self.popupMenu, id = self.popupID['pack'], text = _("Create pack"))
self.popupMenu.AppendItem(item)
self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['v.pack',
