[GRASS-SVN] r67350 - grass/trunk/vector/v.in.lidar/testsuite
Wed Dec 23 13:35:31 PST 2015
Author: wenzeslaus
Date: 2015-12-23 13:35:31 -0800 (Wed, 23 Dec 2015)
New Revision: 67350
Added:
   grass/trunk/vector/v.in.lidar/testsuite/mask_test.py
v.in.lidar: test for vector mask
Added: grass/trunk/vector/v.in.lidar/testsuite/mask_test.py
--- grass/trunk/vector/v.in.lidar/testsuite/mask_test.py	                        (rev 0)
+++ grass/trunk/vector/v.in.lidar/testsuite/mask_test.py	2015-12-23 21:35:31 UTC (rev 67350)
@@ -0,0 +1,154 @@
+Name:      decimation_test
+Purpose:   v.in.lidar decimation test
+Author:    Vaclav Petras
+Copyright: (C) 2015 by Vaclav Petras and the GRASS Development Team
+Licence:   This program is free software under the GNU General Public
+           License (>=v2). Read the file COPYING that comes with GRASS
+           for details.
+POINTS = """\
+17.46938776,18.67346939,1
+20.93877551,17.44897959,2
+18.89795918,14.18367347,3
+15.91836735,10.67346939,4
+21.26530612,11.04081633,5
+22.24489796,13.89795918,6
+23.79591837,17.12244898,7
+17.2244898,16.34693878,8
+17.14285714,14.10204082,9
+19.87755102,11.81632653,10
+18.48979592,11.48979592,11
+21.26530612,15.73469388,12
+21.18367347,19.32653061,13
+23.91836735,18.83673469,14
+23.51020408,13.65306122,15
+23.55102041,11.32653061,16
+18.41009273,14.51618034,17
+22.13996161,17.2278263,18
+21.41013052,11.05432488,19
+AREAS = """\
+ORGANIZATION:
+DIGIT DATE:
+DIGIT NAME:   vpetras
+MAP NAME:
+MAP DATE:     Tue Dec 22 17:22:54 2015
+MAP SCALE:    1
+OTHER INFO:
+ZONE:         0
+MAP THRESH:   0.000000
+VERTI:
+B  6
+ 16.89795918  17.28571429
+ 19.75510204  15.12244898
+ 21.34693878  12.87755102
+ 17.3877551   12.67346939
+ 16           15.24489796
+C  1 1
+ 18.41009273  14.51618034
+ 1     17
+B  6
+ 20.20408163  19.57142857
+ 21.14285714  14.63265306
+ 23.75510204  15.08163265
+ 24.36734694  17.57142857
+ 22.20408163  19.73469388
+C  1 1
+ 22.13996161  17.2278263
+ 1     18
+B  5
+ 20.89795918  11.57142857
+ 22.40816327  11.04081633
+ 21.02040816  10.51020408
+ 20.57142857  11.24489796
+C  1 1
+ 21.41013052  11.05432488
+ 1     19
+import os
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+class VectorMaskTest(TestCase):
+    """Test case for watershed module
+    This tests expects v.random and v.out.lidar to work properly.
+    # Setup variables to be used for outputs
+    points = 'vinlidar_points'
+    areas = 'vinlidar_areas'
+    las_file = 'vinlidar_mask_points.las'
+    imported_points = 'vinlidar_imported_points'
+    @classmethod
+    def setUpClass(cls):
+        """Ensures expected computational region and generated data"""
+        cls.use_temp_region()
+        cls.runModule('g.region', n=20, s=10, e=25, w=15, res=1)
+        cls.runModule('v.in.ascii', input='-', output=cls.points,
+                      separator='comma', format='point', stdin_=POINTS)
+        cls.runModule('v.in.ascii', input='-', output=cls.areas,
+                      format='standard', stdin_=AREAS)
+        cls.runModule('v.out.lidar', input=cls.points,
+            output=cls.las_file)
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the temporary region and generated data"""
+        cls.runModule('g.remove', flags='f', type='vector',
+            name=(cls.points, cls.areas))
+        if os.path.isfile(cls.las_file):
+            os.remove(cls.las_file)
+        cls.del_temp_region()
+    def tearDown(self):
+        """Remove the outputs created by the import
+        This is executed after each test run.
+        self.runModule('g.remove', flags='f', type='vector',
+            name=self.imported_points)
+    def test_no_mask(self):
+        """Test to see if the standard outputs are created"""
+        self.assertModule('v.in.lidar', input=self.las_file,
+            output=self.imported_points, flags='bt')
+        self.assertVectorExists(self.imported_points)
+        self.assertVectorFitsTopoInfo(
+            vector=self.imported_points,
+            reference=dict(points=19))
+    def test_mask(self):
+            output=self.imported_points, flags='bt',
+            mask=self.areas)
+            reference=dict(points=11))
+    def test_inverted_mask(self):
+            output=self.imported_points, flags='bti',
+            mask=self.areas)
+            reference=dict(points=8))
+if __name__ == '__main__':
+    test()
Property changes on: grass/trunk/vector/v.in.lidar/testsuite/mask_test.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
