[GRASS-SVN] r67354 - in grass/trunk/vector/v.in.lidar: . testsuite
svn_grass at osgeo.org
Wed Dec 23 19:05:34 PST 2015
Author: wenzeslaus
Date: 2015-12-23 19:05:34 -0800 (Wed, 23 Dec 2015)
New Revision: 67354
grass/trunk/vector/v.in.lidar/main.c
grass/trunk/vector/v.in.lidar/testsuite/basic_test.py
grass/trunk/vector/v.in.lidar/testsuite/filter_test.py
v.in.lidar: change filter order to a faster one
First check coordinates, then return and class
and then do potentially very slow areas check.
This changes the reported counts of filtered points
and splits the 2D spatial checks but for user
all is still AND relation anyway, only the counts
are different.
Place for z may change if there is some expensive
modification of z needed.
Adding tests for zrange option.
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2015-12-24 02:29:05 UTC (rev 67353)
+++ grass/trunk/vector/v.in.lidar/main.c 2015-12-24 03:05:34 UTC (rev 67354)
@@ -643,12 +643,12 @@
continue;
- if (vector_mask_opt->answer) {
- if (!VectorMask_point_in(&vector_mask, x, y)) {
- n_outside_mask++;
- continue;
+ if (use_zrange) {
+ if (z < zrange_min || z > zrange_max) {
+ zrange_filtered++;
+ continue;
int return_n = LASPoint_GetReturnNumber(LAS_point);
int n_returns = LASPoint_GetNumberOfReturns(LAS_point);
if (return_filter_is_out(&return_filter_struct, return_n, n_returns)) {
@@ -660,9 +660,9 @@
n_class_filtered++;
continue;
- if (use_zrange) {
- if (z < zrange_min || z > zrange_max) {
- zrange_filtered++;
+ if (vector_mask_opt->answer) {
+ if (!VectorMask_point_in(&vector_mask, x, y)) {
+ n_outside_mask++;
continue;
Modified: grass/trunk/vector/v.in.lidar/testsuite/basic_test.py
--- grass/trunk/vector/v.in.lidar/testsuite/basic_test.py 2015-12-24 02:29:05 UTC (rev 67353)
+++ grass/trunk/vector/v.in.lidar/testsuite/basic_test.py 2015-12-24 03:05:34 UTC (rev 67354)
@@ -21,9 +21,9 @@
# Setup variables to be used for outputs
- vector_points = 'vinlidar_decimation_original'
- imported_points = 'vinlidar_decimation_imported'
- las_file = 'vinlidar_decimation_points.las'
+ vector_points = 'vinlidar_basic_original'
+ imported_points = 'vinlidar_basic_imported'
+ las_file = 'vinlidar_basic_points.las'
npoints = 300
@classmethod
Modified: grass/trunk/vector/v.in.lidar/testsuite/filter_test.py
--- grass/trunk/vector/v.in.lidar/testsuite/filter_test.py 2015-12-24 02:29:05 UTC (rev 67353)
+++ grass/trunk/vector/v.in.lidar/testsuite/filter_test.py 2015-12-24 03:05:34 UTC (rev 67354)
@@ -23,22 +23,22 @@
22.24489796,13.89795918,123,2,2,3
23.79591837,17.12244898,151,1,2,3
17.2244898,16.34693878,124,2,2,4
-17.14285714,14.10204082,144,1,3,4
+17.14285714,14.10204082,134,1,3,4
19.87755102,11.81632653,146,2,3,4
-18.48979592,11.48979592,140,2,3,4
+18.48979592,11.48979592,140.6,2,3,4
21.26530612,15.73469388,147,3,3,5
21.18367347,19.32653061,138,1,3,5
23.91836735,18.83673469,144,2,3,5
23.51020408,13.65306122,143,3,3,5
23.55102041,11.32653061,123,1,4,5
-18.41009273,14.51618034,140,2,4,5
+18.41009273,14.51618034,140.4,2,4,5
22.13996161,17.2278263,147,3,4,5
-21.41013052,11.05432488,142,4,4,5
+21.41013052,11.05432488,132,4,4,5
-class BasicTest(TestCase):
- """Test case for watershed module
+class FilterTest(TestCase):
+ """Test case for filter and selection options
This tests expects v.random and v.out.lidar to work properly.
@@ -85,7 +85,10 @@
name=self.imported_points)
def test_no_filter(self):
- """Test to see if the standard outputs are created"""
+ """Test to see if the standard outputs are created
+ This shows if the inpute data are as expected.
self.assertModule('v.in.lidar', input=self.las_file,
output=self.imported_points, flags='bt')
self.assertVectorExists(self.imported_points)
@@ -142,7 +145,7 @@
self.class_filter(5, 8)
def return_and_class_filter(self, return_name, class_n, npoints):
- """Mid return filter test"""
+ """Return and class filter combined test code"""
output=self.imported_points, flags='bt',
return_filter=return_name, class_filter=class_n)
@@ -159,6 +162,47 @@
"""Combined test for return and class"""
self.return_and_class_filter('last', 5, 3)
+ def zrange_filter(self, zrange, npoints):
+ """Actual code for zrange option test"""
+ self.assertModule('v.in.lidar', input=self.las_file,
+ output=self.imported_points, flags='bt',
+ zrange=zrange)
+ self.assertVectorExists(self.imported_points)
+ self.assertVectorFitsTopoInfo(
+ vector=self.imported_points,
+ reference=dict(points=npoints))
+ def test_zrange_filter(self):
+ """Test zrange option"""
+ self.zrange_filter((130.1, 139.9), 3)
+ def test_non_int_zrange_filter(self):
+ """Test zrange option with float number
+ One test point has z right under and one other right above the min.
+ self.zrange_filter((140.5, 900), 8)
+ def test_zrange_and_class_filter(self):
+ """zrange and class_filter option combined test"""
+ zrange=(141, 900), class_filter=5)
+ reference=dict(points=4))
+ def test_zrange_and_return_filter(self):
+ zrange=(141, 900), return_filter='last')
+ reference=dict(points=2))
if __name__ == '__main__':
test()
