[GRASS-SVN] r67392 - in grass/branches/releasebranch_7_0/vector: v.kernel v.outlier
Sun Dec 27 10:05:13 PST 2015
Author: neteler
Date: 2015-12-27 10:05:13 -0800 (Sun, 27 Dec 2015)
New Revision: 67392
   grass/branches/releasebranch_7_0/vector/v.kernel/main.c
   grass/branches/releasebranch_7_0/vector/v.outlier/main.c
v.outlier,v.kernel: keyword sync to trunk
Modified: grass/branches/releasebranch_7_0/vector/v.kernel/main.c
--- grass/branches/releasebranch_7_0/vector/v.kernel/main.c	2015-12-27 11:09:23 UTC (rev 67391)
+++ grass/branches/releasebranch_7_0/vector/v.kernel/main.c	2015-12-27 18:05:13 UTC (rev 67392)
@@ -108,6 +108,9 @@
     module = G_define_module();
     G_add_keyword(_("vector"));
     G_add_keyword(_("kernel density"));
+    G_add_keyword(_("point density"));
+    G_add_keyword(_("heatmap"));
+    G_add_keyword(_("hotspot"));
     module->label =
         _("Generates a raster density map from vector points map.");
     module->description = _("Density is computed using a moving kernel. "
Modified: grass/branches/releasebranch_7_0/vector/v.outlier/main.c
--- grass/branches/releasebranch_7_0/vector/v.outlier/main.c	2015-12-27 11:09:23 UTC (rev 67391)
+++ grass/branches/releasebranch_7_0/vector/v.outlier/main.c	2015-12-27 18:05:13 UTC (rev 67392)
@@ -68,6 +68,9 @@
     G_add_keyword(_("statistics"));
+    G_add_keyword(_("extract"));
+    G_add_keyword(_("select"));
+    G_add_keyword(_("filter"));
     module->description = _("Removes outliers from vector point data.");
     spline_step_flag = G_define_flag();
