[GRASS-SVN] r67395 - grass/branches/releasebranch_7_0/scripts/v.unpack
svn_grass at osgeo.org
Sun Dec 27 10:18:39 PST 2015
Author: neteler
Date: 2015-12-27 10:18:39 -0800 (Sun, 27 Dec 2015)
New Revision: 67395
grass/branches/releasebranch_7_0/scripts/v.unpack/v.unpack.py
v.unpack: sync flag description to trunk
Modified: grass/branches/releasebranch_7_0/scripts/v.unpack/v.unpack.py
--- grass/branches/releasebranch_7_0/scripts/v.unpack/v.unpack.py 2015-12-27 18:11:40 UTC (rev 67394)
+++ grass/branches/releasebranch_7_0/scripts/v.unpack/v.unpack.py 2015-12-27 18:18:39 UTC (rev 67395)
@@ -32,8 +32,10 @@
#%end
#%flag
#% key: o
-#% description: Override projection check (use current location's projection)
+#% label: Override projection check (use current location's projection)
+#% description: Assume that the dataset has same projection as the current location
#% guisection: Output settings
+#% guisection: Output settings
#%end
import os
