[GRASS-SVN] r67401 - grass/branches/releasebranch_7_0/raster/r.category
svn_grass at osgeo.org
Sun Dec 27 12:55:06 PST 2015
Author: neteler
Date: 2015-12-27 12:55:06 -0800 (Sun, 27 Dec 2015)
New Revision: 67401
grass/branches/releasebranch_7_0/raster/r.category/r.category.html
r.category manual: minor HTML formatting (more needed)
Modified: grass/branches/releasebranch_7_0/raster/r.category/r.category.html
--- grass/branches/releasebranch_7_0/raster/r.category/r.category.html 2015-12-27 20:55:00 UTC (rev 67400)
+++ grass/branches/releasebranch_7_0/raster/r.category/r.category.html 2015-12-27 20:55:06 UTC (rev 67401)
@@ -69,22 +69,26 @@
</pre></div>
<p>In the format line
<ul>
-<li>$1 refers to the value num*5.0+1000 (ie, using the first 2 coefficients)
-<li>$2 refers to the value num*5.0+1005 (ie, using the last 2 coefficients)
+<li><tt>$1</tt> refers to the value <tt>num*5.0+1000</tt> (ie, using the first 2 coefficients)
+<li><tt>$2</tt> refers to the value <tt>num*5.0+1005</tt> (ie, using the last 2 coefficients)
</ul>
- $1.2 will print $1 with 2 decimal places.
-<p>Also, the form $?xxx$yyy$ translates into yyy if the category is 1, xxx
-otherwise. The $yyy$ is optional. Thus
-<p> $1 meter$?s
-<p>will become: 1 meter (for category 1)<br>
- 2 meters (for category 2), etc.
+ <tt>$1.2</tt> will print <tt>$1</tt> with 2 decimal places.
+<p>Also, the form <tt>$?xxx$yyy$</tt> translates into <tt>yyy</tt> if the category is 1, xxx
+otherwise. The <tt>$yyy$</tt> is optional. Thus
+<p> <tt>$1 meter$?s</tt>
+<p>will become: <br>
+ <tt>1 meter</tt> (for category 1)<br>
+ <tt>2 meters</tt> (for category 2), etc.
-<p>format='Elevation: $1.2 to $2.2 feet' ## Format Statement
-coefficients="5.0,1000,5.0,1005" ## Coefficients
+<p>
+<tt>format='Elevation: $1.2 to $2.2 feet' ## Format Statement</tt><br>
+<tt>coefficients="5.0,1000,5.0,1005" ## Coefficients</tt>
<p>The format and coefficients above would be used to generate the
following statement in creation of the format appropriate category
string for category "num":
-<p> sprintf(buff,"Elevation: %.2f to %.2f feet", num*5.0+1000, num*5.0*1005)
+<p>
+<tt>sprintf(buff,"Elevation: %.2f to %.2f feet", num*5.0+1000, num*5.0*1005)</tt>
<p>Note: while both the format and coefficent lines must be present
a blank line for the format string will effectively suppress
@@ -104,6 +108,8 @@
<h2>EXAMPLES</h2>
+Spearfish sample dataset:
<p><dl>
<dt><span class="code"><tt>
r.category map=soils
