[GRASS-SVN] r67418 - grass-addons/grass7/raster/r.meb
svn_grass at osgeo.org
Tue Dec 29 05:14:44 PST 2015
Author: pvanbosgeo
Date: 2015-12-29 05:14:44 -0800 (Tue, 29 Dec 2015)
New Revision: 67418
grass-addons/grass7/raster/r.meb/r.meb.py
bugfix
Modified: grass-addons/grass7/raster/r.meb/r.meb.py
--- grass-addons/grass7/raster/r.meb/r.meb.py 2015-12-29 13:14:38 UTC (rev 67417)
+++ grass-addons/grass7/raster/r.meb/r.meb.py 2015-12-29 13:14:44 UTC (rev 67418)
@@ -200,32 +200,28 @@
# Median and mad for whole region (within current mask)
tmpf4 = tmpname('reb4')
clean_rast.add(tmpf4)
- d = grass.read_command("r.quantile", quiet=True, input=simlay, percentiles="50")
+ d = grass.read_command("r.quantile", quiet=True, input=simlay,
+ percentiles="50")
d = d.split(":")
d = float(string.replace(d[2], "\n", ""))
grass.mapcalc("$tmpf4 = abs($map - $d)",
map=simlay,
tmpf4=tmpf4,
d=d, quiet=True)
- mad = grass.read_command("r.quantile", quiet=True, input=tmpf4, percentiles="50")
+ mad = grass.read_command("r.quantile", quiet=True, input=tmpf4,
+ percentiles="50")
mad = mad.split(":")
mad = float(string.replace(mad[2], "\n", ""))
- grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmpf4)
+ grass.run_command("g.remove", quiet=True, flags="f", type="raster",
+ name=tmpf4)
# Median and mad for reference layer
tmpf5 = tmpname('reb5')
clean_rast.add(tmpf5)
- grass.run_command("r.null", map=reflay, setnull=0)
- chlay = grass.parse_command("r.info", flags="r", map=reflay)
- if chlay['max'] != '1' or chlay['min'] != '1':
- grass.warning('please note that your layer is not a binary layer. Continuing assuming that all values other than 0 mark the area of interest')
- grass.mapcalc("$tmpf5 = if($reflay != 0, 1, null())",
- tmpf5=tmpf5, reflay=reflay, quiet=True)
- else:
- grass.run_command("g.copy", raster=(reflay,tmpf5), quiet=True)
- grass.mapcalc("$tmpf5 = $tmpf5 * $simlay", tmpf5=tmpf5,
- simlay=simlay, quiet=True, overwrite=True)
- e = grass.read_command("r.quantile", quiet=True, input=tmpf5, percentiles="50")
+ grass.mapcalc("$tmpf5 = if($reflay==1, $simlay, null())", simlay=simlay,
+ tmpf5=tmpf5, reflay=reflay, quiet=True)
+ e = grass.read_command("r.quantile", quiet=True, input=tmpf5,
+ percentiles="50")
e = e.split(":")
e = float(string.replace(e[2], "\n", ""))
EBstat = abs(d - e) / mad
@@ -240,7 +236,6 @@
grass.run_command("g.remove", flags="f", type="raster", name=tmpf5, quiet=True)
return (mad, d, e, EBstat)
def main():
