[GRASS-SVN] r67437 - in grass-addons/grass7/imagery: . i.eb.deltat
svn_grass at osgeo.org
Wed Dec 30 09:57:43 PST 2015
Author: ychemin
Date: 2015-12-30 09:57:43 -0800 (Wed, 30 Dec 2015)
New Revision: 67437
Added:
grass-addons/grass7/imagery/i.eb.deltat/
grass-addons/grass7/imagery/i.eb.deltat/i.eb.deltat.html
Removed:
grass-addons/grass7/imagery/i.eb.deltat/description.html
grass-addons/grass7/imagery/Makefile
grass-addons/grass7/imagery/i.eb.deltat/Makefile
grass-addons/grass7/imagery/i.eb.deltat/main.c
upgraded i.eb.deltat to grass v7
Modified: grass-addons/grass7/imagery/Makefile
--- grass-addons/grass7/imagery/Makefile 2015-12-30 17:49:54 UTC (rev 67436)
+++ grass-addons/grass7/imagery/Makefile 2015-12-30 17:57:43 UTC (rev 67437)
@@ -3,6 +3,7 @@
# i.fusion.brovey deprecated
SUBDIRS = \
+ i.alti \
i.destripe \
i.eb.hsebal95 \
i.eb.z0m \
Modified: grass-addons/grass7/imagery/i.eb.deltat/Makefile
--- grass-addons/grass6/imagery/gipe/i.eb.deltat/Makefile 2015-12-30 15:21:39 UTC (rev 67434)
+++ grass-addons/grass7/imagery/i.eb.deltat/Makefile 2015-12-30 17:57:43 UTC (rev 67437)
@@ -2,13 +2,9 @@
PGM = i.eb.deltat
-LIBES = $(GISLIB)
-DEPENDENCIES = $(GISDEP)
+LIBES = $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
-ifneq ($(USE_LARGEFILES),)
- EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
-endif
default: cmd
Deleted: grass-addons/grass7/imagery/i.eb.deltat/description.html
--- grass-addons/grass6/imagery/gipe/i.eb.deltat/description.html 2015-12-30 15:21:39 UTC (rev 67434)
+++ grass-addons/grass7/imagery/i.eb.deltat/description.html 2015-12-30 17:57:43 UTC (rev 67437)
@@ -1,23 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>i.eb.deltat</em> calculates the difference of temperature between two heights. Generally considered between surface skin temperature and air temperature ~2m above the skin (soil/canopy/etc). This approximation is found in Pawan (2004) and is used for initialization of the sensible heat flux iterations in SEBAL (Bastiaanssen, 1995).
-<h2>NOTES</h2>
-This is found in Pawan (2004). This is the case of a Landsat satellite image of Oct 8, 2003, located in Portugal. He also mentions a strange equation for MODIS of January 13, 2003. delta T = -3440.37 +12.18404 * LST. Of course the intercept looks like the LST band is still in storage format (*10000).
-Additionally, it is worth menitoning that Pawan only created this map once, and used it all the time. This is certainly because he created the relationship from some field data and found it reliable enough not to modify this parameter anymore, leading to a simplified iteration process of SEBAL, changing only the rah parameter through the iterations of H,L,psi,rah.
-<h2>TODO</h2>
-<h2>SEE ALSO</h2>
-<em>
-<a href="i.eb.h0.html">i.eb.h0</a><br>
-</em>
-<h2>AUTHORS</h2>
-Yann Chemin, Asian Institute of Technology, Thailand<br>
-<p>
-<i>Last changed: $Date$</i>
Copied: grass-addons/grass7/imagery/i.eb.deltat/i.eb.deltat.html (from rev 67434, grass-addons/grass6/imagery/gipe/i.eb.deltat/description.html)
--- grass-addons/grass7/imagery/i.eb.deltat/i.eb.deltat.html (rev 0)
+++ grass-addons/grass7/imagery/i.eb.deltat/i.eb.deltat.html 2015-12-30 17:57:43 UTC (rev 67437)
@@ -0,0 +1,23 @@
+<h2>DESCRIPTION</h2>
+<em>i.eb.deltat</em> calculates the difference of temperature between two heights. Generally considered between surface skin temperature and air temperature ~2m above the skin (soil/canopy/etc). This approximation is found in Pawan (2004) and is used for initialization of the sensible heat flux iterations in SEBAL (Bastiaanssen, 1995).
+<h2>NOTES</h2>
+This is found in Pawan (2004). This is the case of a Landsat satellite image of Oct 8, 2003, located in Portugal. He also mentions a strange equation for MODIS of January 13, 2003. delta T = -3440.37 +12.18404 * LST. Of course the intercept looks like the LST band is still in storage format (*10000).
+Additionally, it is worth menitoning that Pawan only created this map once, and used it all the time. This is certainly because he created the relationship from some field data and found it reliable enough not to modify this parameter anymore, leading to a simplified iteration process of SEBAL, changing only the rah parameter through the iterations of H,L,psi,rah.
+<h2>TODO</h2>
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.eb.h0.html">i.eb.h0</a><br>
+</em>
+<h2>AUTHORS</h2>
+Yann Chemin, Asian Institute of Technology, Thailand<br>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass-addons/grass7/imagery/i.eb.deltat/main.c
--- grass-addons/grass6/imagery/gipe/i.eb.deltat/main.c 2015-12-30 15:21:39 UTC (rev 67434)
+++ grass-addons/grass7/imagery/i.eb.deltat/main.c 2015-12-30 17:57:43 UTC (rev 67437)
@@ -7,7 +7,7 @@
* as seen in Pawan (2004)
* This is a SEBAL initialization parameter for sensible heat.
- * COPYRIGHT: (C) 2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 2006-2016 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -20,65 +20,48 @@
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
+#include <grass/raster.h>
#include <grass/glocale.h>
double delta_t(double tempk);
int main(int argc, char *argv[])
struct Cell_head cellhd; /*region+header info */
char *mapset; /* mapset name */
int nrows, ncols;
int row, col;
int wim = 0;
struct GModule *module;
struct Option *input1, *output1;
struct Flag *flag1, *flag2;
struct History history; /*metadata */
- /* FMEO Declarations**************** */
char *name; /*input raster name */
char *result1; /*output raster name */
- /*File Descriptors */
+ /*File Descriptors */
int infd_tempk;
int outfd1;
char *tempk;
char *delta;
int i = 0, j = 0;
void *inrast_tempk;
DCELL * outrast1;
RASTER_MAP_TYPE data_type_output = DCELL_TYPE;
RASTER_MAP_TYPE data_type_tempk;
- G_gisinit(argv[0]);
+ G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("delta T, energy balance, SEBAL");
+ G_add_keyword(_("imagery"));
+ G_add_keyword(_("energy balance"));
+ G_add_keyword(_("SEBAL"));
+ G_add_keyword(_("SEBS"));
+ G_add_keyword(_("delta T"));
module->description =
_("difference of temperature between two heights as seen in Pawan (2004), this is part of sensible heat flux calculations, as in SEBAL (Bastiaanssen, 1995). A 'w' flag allows for a very generic approximation.");
- /* Define the different options */
- input1 = G_define_standard_option(G_OPT_R_INPUT);
+ /* Define the different options */
+ input1 = G_define_standard_option(G_OPT_R_INPUT);
input1->key = _("tempk");
input1->description =
_("Name of the surface skin temperature map [Kelvin]");
@@ -91,53 +74,43 @@
flag2->key = 'w';
flag2->description = _("Wim's generic table");
- if (G_parser(argc, argv))
+ if (G_parser(argc, argv))
exit(EXIT_FAILURE);
tempk = input1->answer;
result1 = output1->answer;
wim = flag2->answer;
- mapset = G_find_cell2(tempk, "");
- if (mapset == NULL) {
- G_fatal_error(_("cell file [%s] not found"), tempk);
- data_type_tempk = G_raster_map_type(tempk, mapset);
- if ((infd_tempk = G_open_cell_old(tempk, mapset)) < 0)
+ data_type_tempk = Rast_map_type(tempk, mapset);
+ if ((infd_tempk = Rast_open_old(tempk, mapset)) < 0)
G_fatal_error(_("Cannot open cell file [%s]"), tempk);
- if (G_get_cellhd(tempk, mapset, &cellhd) < 0)
- G_fatal_error(_("Cannot read file header of [%s])"), tempk);
- inrast_tempk = G_allocate_raster_buf(data_type_tempk);
+ Rast_get_cellhd(tempk, mapset, &cellhd);
+ inrast_tempk = Rast_allocate_buf(data_type_tempk);
- G_debug(3, "number of rows %d", cellhd.rows);
- nrows = G_window_rows();
- ncols = G_window_cols();
- outrast1 = G_allocate_raster_buf(data_type_output);
+ G_debug(3, "number of rows %d", cellhd.rows);
+ nrows = Rast_window_rows();
+ ncols = Rast_window_cols();
+ outrast1 = Rast_allocate_buf(data_type_output);
- /* Create New raster files */
- if ((outfd1 = G_open_raster_new(result1, data_type_output)) < 0)
- G_fatal_error(_("Could not open <%s>"), result1);
+ /* Create New raster files */
+ outfd1 = Rast_open_new(result1, data_type_output);
- /* Process pixels */
+ /* Process pixels */
for (row = 0; row < nrows; row++)
- DCELL d;
- DCELL d_tempk;
- G_percent(row, nrows, 2);
+ DCELL d;
+ DCELL d_tempk;
+ G_percent(row, nrows, 2);
/* read soil input maps */
- if (G_get_raster_row
- (infd_tempk, inrast_tempk, row, data_type_tempk) < 0)
- G_fatal_error(_("Could not read from <%s>"), tempk);
+ Rast_get_row
+ (infd_tempk, inrast_tempk, row, data_type_tempk);
/*process the data */
for (col = 0; col < ncols; col++)
switch (data_type_tempk) {
case CELL_TYPE:
d_tempk = (double)((CELL *) inrast_tempk)[col];
@@ -149,15 +122,13 @@
d_tempk = ((DCELL *) inrast_tempk)[col];
break;
- if (G_is_d_null_value(&d_tempk)) {
- G_set_d_null_value(&outrast1[col], 1);
+ if (Rast_is_d_null_value(&d_tempk)) {
+ Rast_set_d_null_value(&outrast1[col], 1);
else {
- /* calculate delta T */
- if (wim) {
+ /* calculate delta T */
+ if (wim) {
d = 0.3225 * d_tempk - 91.743;
if (d < 1) {
d = 1.0;
@@ -170,21 +141,20 @@
d = delta_t(d_tempk);
if (abs(d) > 50.0) {
outrast1[col] = d;
- if (G_put_raster_row(outfd1, outrast1, data_type_output) < 0)
- G_fatal_error(_("Cannot write to output raster file"));
- G_free(inrast_tempk);
- G_close_cell(infd_tempk);
- G_free(outrast1);
- G_close_cell(outfd1);
- G_short_history(result1, "raster", &history);
- G_command_history(&history);
- G_write_history(result1, &history);
+ Rast_put_row(outfd1, outrast1, data_type_output);
+ free(inrast_tempk);
+ Rast_close(infd_tempk);
+ free(outrast1);
+ Rast_close(outfd1);
+ Rast_short_history(result1, "raster", &history);
+ Rast_command_history(&history);
+ Rast_write_history(result1, &history);
exit(EXIT_SUCCESS);
