[GRASS-SVN] r67451 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Thu Dec 31 02:31:02 PST 2015
Author: mlennert
Date: 2015-12-31 02:31:02 -0800 (Thu, 31 Dec 2015)
New Revision: 67451
grass/trunk/vector/v.out.ogr/export_areas.c
grass/trunk/vector/v.out.ogr/export_lines.c
v.out.ogr: Forcing use of OGR_G_AddPoint_2D when map is not 3D (attempt to fix #2300 "")
Modified: grass/trunk/vector/v.out.ogr/export_areas.c
--- grass/trunk/vector/v.out.ogr/export_areas.c 2015-12-31 10:28:06 UTC (rev 67450)
+++ grass/trunk/vector/v.out.ogr/export_areas.c 2015-12-31 10:31:02 UTC (rev 67451)
@@ -298,8 +298,12 @@
/* Area */
for (j = 0; j < Points->n_points; j++) {
- OGR_G_AddPoint(ring, Points->x[j], Points->y[j],
- Points->z[j]);
+ if (Vect_is_3d(In))
+ OGR_G_AddPoint(ring, Points->x[j], Points->y[j],
+ Points->z[j]);
+ else
+ OGR_G_AddPoint_2D(ring, Points->x[j], Points->y[j]);
OGR_G_AddGeometryDirectly(Ogr_geometry, ring);
@@ -311,8 +315,12 @@
ring = OGR_G_CreateGeometry(wkbLinearRing);
- Points->z[j]);
+ if(Vect_is_3d(In))
+ Points->z[j]);
+ else
Modified: grass/trunk/vector/v.out.ogr/export_lines.c
--- grass/trunk/vector/v.out.ogr/export_lines.c 2015-12-31 10:28:06 UTC (rev 67450)
+++ grass/trunk/vector/v.out.ogr/export_lines.c 2015-12-31 10:31:02 UTC (rev 67451)
@@ -94,13 +94,17 @@
Ogr_geometry = OGR_G_CreateGeometry(get_wkbtype(type, otype));
if (OGR_G_GetGeometryType(Ogr_geometry) == wkbPoint) {
/* GV_POINTS -> wkbPoint */
- OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
- Points->z[0]);
+ OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
+ Points->z[0]);
+ else OGR_G_AddPoint_2D(Ogr_geometry, Points->x[0], Points->y[0]);
else { /* GV_LINES -> wkbLinestring */
- OGR_G_AddPoint(Ogr_geometry, Points->x[j], Points->y[j],
- Points->z[j]);
+ OGR_G_AddPoint(Ogr_geometry, Points->x[j], Points->y[j],
+ Points->z[j]);
+ else OGR_G_AddPoint_2D(Ogr_geometry, Points->x[j], Points->y[j]);
