[GRASS-SVN] r67455 - grass/trunk/scripts/v.rast.stats
svn_grass at osgeo.org
Thu Dec 31 07:12:58 PST 2015
Author: annakrat
Date: 2015-12-31 07:12:58 -0800 (Thu, 31 Dec 2015)
New Revision: 67455
grass/trunk/scripts/v.rast.stats/v.rast.stats.py
v.rast.stats: remove unnecessary code related to mask
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2015-12-31 12:58:42 UTC (rev 67454)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2015-12-31 15:12:58 UTC (rev 67455)
@@ -72,19 +72,12 @@
if rastertmp:
grass.run_command('g.remove', flags='f', type='raster',
name=rastertmp, quiet=True)
- grass.run_command('g.remove', flags='f', type='raster',
- name='MASK', quiet=True, stderr=nuldev)
- if mask_found:
- grass.message(_("Restoring previous MASK..."))
- grass.run_command('g.rename', raster=(tmpname + "_origmask", 'MASK'),
- quiet=True)
# for f in [tmp, tmpname, sqltmp]:
# grass.try_remove(f)
def main():
- global tmp, sqltmp, tmpname, nuldev, vector, mask_found, rastertmp
- mask_found = False
+ global tmp, sqltmp, tmpname, nuldev, vector, rastertmp
rastertmp = False
#### setup temporary files
tmp = grass.tempfile()
@@ -123,13 +116,6 @@
if not grass.find_file(raster, 'cell')['file']:
grass.fatal(_("Raster map <%s> not found") % raster)
- # check presence of raster MASK, put it aside
- mask_found = bool(grass.find_file('MASK', 'cell', mapset)['file'])
- if mask_found:
- grass.message(_("Raster MASK found, temporarily disabled"))
- grass.run_command('g.rename', raster=('MASK', tmpname + "_origmask"),
- quiet=True)
# save current settings:
grass.use_temp_region()
@@ -137,7 +123,6 @@
# keep boundary settings
grass.run_command('g.region', align=raster)
- # prepare raster MASK
grass.message(_("Preprocessing input data..."))
try:
grass.run_command('v.to.rast', input=vector, layer=layer, output=rastertmp,
@@ -294,9 +279,6 @@
except CalledModuleError:
grass.warning(_("Failed to upload statistics to attribute table of vector map <%s>.") % vector)
exitcode = 1
- finally:
sys.exit(exitcode)
