[GRASS-SVN] r67459 - grass-addons/tools/addons
Thu Dec 31 09:52:41 PST 2015
Author: martinl
Date: 2015-12-31 09:52:41 -0800 (Thu, 31 Dec 2015)
New Revision: 67459
   grass-addons/tools/addons/build-xml.py
   grass-addons/tools/addons/compile-xml.sh
   grass-addons/tools/addons/compile.sh
   grass-addons/tools/addons/grass-addons-build.sh
addons compilation: fix ARCH build server reference
Modified: grass-addons/tools/addons/build-xml.py
--- grass-addons/tools/addons/build-xml.py	2015-12-31 16:56:46 UTC (rev 67458)
+++ grass-addons/tools/addons/build-xml.py	2015-12-31 17:52:41 UTC (rev 67459)
@@ -8,7 +8,7 @@
 from   datetime import datetime
 ADDON_PATH = os.path.join(os.getenv('HOME'), 'src', 'grass-addons')
-DIST = 'dist.x86_64-unknown-linux-gnu'
+DIST = 'dist.x86_64-pc-linux-gnu'
 def get_list(addons):
     mlist = [d for d in os.listdir(os.path.join(addons)) if os.path.isdir(os.path.join(addons, d))]
Modified: grass-addons/tools/addons/compile-xml.sh
--- grass-addons/tools/addons/compile-xml.sh	2015-12-31 16:56:46 UTC (rev 67458)
+++ grass-addons/tools/addons/compile-xml.sh	2015-12-31 17:52:41 UTC (rev 67459)
@@ -20,8 +20,8 @@
 (cd ..; svn up || (svn cleanup && svn up))
 # compile AddOns for GRASS 7 and GRASS 6.5
-compile ../../grass7 ~/src/grass70_release/dist.x86_64-unknown-linux-gnu /tmp/.grass7/addons
-compile ../../grass6 ~/src/grass64_release/dist.x86_64-unknown-linux-gnu /tmp/.grass6/addons
+compile ../../grass7 ~/src/grass70_release/dist.x86_64-pc-linux-gnu /tmp/.grass7/addons
+compile ../../grass6 ~/src/grass64_release/dist.x86_64-pc-linux-gnu /tmp/.grass6/addons
 # create XML file for AddOns
 build_xml /tmp/.grass7/addons 7
Modified: grass-addons/tools/addons/compile.sh
--- grass-addons/tools/addons/compile.sh	2015-12-31 16:56:46 UTC (rev 67458)
+++ grass-addons/tools/addons/compile.sh	2015-12-31 17:52:41 UTC (rev 67459)
@@ -4,7 +4,7 @@
 if [ -z "$3" ]; then
     echo "usage: $0 svn_path topdir addons_path [separate]"
-    echo "eg. $0 ~/src/grass-addons/grass7/ ~/src/grass_trunk/dist.x86_64-unknown-linux-gnu ~/.grass7/addons"
+    echo "eg. $0 ~/src/grass-addons/grass7/ ~/src/grass_trunk/dist.x86_64-pc-linux-gnu ~/.grass7/addons"
     exit 1
 fi
Modified: grass-addons/tools/addons/grass-addons-build.sh
--- grass-addons/tools/addons/grass-addons-build.sh	2015-12-31 16:56:46 UTC (rev 67458)
+++ grass-addons/tools/addons/grass-addons-build.sh	2015-12-31 17:52:41 UTC (rev 67459)
@@ -9,7 +9,7 @@
 # original author: Martin Landa
 DST=/var/www/grass
-DIST=dist.x86_64-unknown-linux-gnu
+DIST=dist.x86_64-pc-linux-gnu
 SRC=${HOME}/src/
 run=`ps aux | grep "${HOME}/cronjobs/grass-addons.sh c" | wc -l`
