[GRASS-SVN] r64389 - grass/branches/releasebranch_7_0/vector/v.extract
svn_grass at osgeo.org
Mon Feb 2 00:02:05 PST 2015
Author: mmetz
Date: 2015-02-02 00:02:05 -0800 (Mon, 02 Feb 2015)
New Revision: 64389
grass/branches/releasebranch_7_0/vector/v.extract/copy_tab.c
v.extract: +index, grant privileges on table (backport from trunk)
Modified: grass/branches/releasebranch_7_0/vector/v.extract/copy_tab.c
--- grass/branches/releasebranch_7_0/vector/v.extract/copy_tab.c 2015-02-02 03:27:58 UTC (rev 64388)
+++ grass/branches/releasebranch_7_0/vector/v.extract/copy_tab.c 2015-02-02 08:02:05 UTC (rev 64389)
@@ -14,6 +14,7 @@
struct field_info *IFi, *OFi;
struct line_cats *Cats;
+ dbDriver *driver;
ntabs = 0;
@@ -38,14 +39,17 @@
for (i = 0; i < Cats->n_cats; i++) {
int f, j;
+ f = -1;
for (j = 0; j < nfields; j++) { /* find field */
if (fields[j] == Cats->field[i]) {
f = j;
break;
- ocats[f][nocats[f]] = Cats->cat[i];
- nocats[f]++;
+ if (f >= 0) {
+ ocats[f][nocats[f]] = Cats->cat[i];
+ nocats[f]++;
@@ -104,6 +108,31 @@
G_warning(_("Unable to copy table <%s>"), IFi->table);
else {
+ driver = db_start_driver_open_database(OFi->driver,
+ Vect_subst_var(OFi->database,
+ Out));
+ if (!driver) {
+ G_warning(_("Unable to open database <%s> with driver <%s>"),
+ OFi->database, OFi->driver);
+ else {
+ /* do not allow duplicate keys */
+ if (db_create_index2(driver, OFi->table, IFi->key) != DB_OK) {
+ G_warning(_("Unable to create index"));
+ if (db_grant_on_table(driver, OFi->table, DB_PRIV_SELECT,
+ DB_GROUP | DB_PUBLIC) != DB_OK) {
+ G_warning(_("Unable to grant privileges on table <%s>"),
+ OFi->table);
+ db_close_database_shutdown_driver(driver);
Vect_map_add_dblink(Out, OFi->number, OFi->name, OFi->table,
IFi->key, OFi->database, OFi->driver);
