[GRASS-SVN] r64391 - grass/branches/releasebranch_7_0/lib/vector/Vlib
svn_grass at osgeo.org
Mon Feb 2 00:12:40 PST 2015
Author: mmetz
Date: 2015-02-02 00:12:40 -0800 (Mon, 02 Feb 2015)
New Revision: 64391
grass/branches/releasebranch_7_0/lib/vector/Vlib/copy.c
grass/branches/releasebranch_7_0/lib/vector/Vlib/map.c
Vlib: avoid code duplication (backport from trunk)
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/copy.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/copy.c 2015-02-02 08:08:49 UTC (rev 64390)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/copy.c 2015-02-02 08:12:40 UTC (rev 64391)
@@ -577,16 +577,15 @@
int Vect_copy_tables(const struct Map_info *In, struct Map_info *Out,
int field)
- int i, n, ret, type;
- struct field_info *Fi, *Fin;
- dbDriver *driver;
+ int i, n, type;
+ struct field_info *Fi;
n = Vect_get_num_dblinks(In);
G_debug(2, "Vect_copy_tables(): copying %d tables", n);
type = GV_1TABLE;
- if (n > 1)
+ if (field < 1 && n > 1)
type = GV_MTABLE;
for (i = 0; i < n; i++) {
@@ -599,42 +598,13 @@
if (field > 0 && Fi->number != field)
continue;
- Fin = Vect_default_field_info(Out, Fi->number, Fi->name, type);
- G_debug(2, "Copy drv:db:table '%s:%s:%s' to '%s:%s:%s'",
- Fi->driver, Fi->database, Fi->table, Fin->driver,
- Fin->database, Fin->table);
+ if (Vect_copy_table(In, Out, Fi->number, Fi->number, Fi->name,
+ type) != 0) {
- ret =
- Vect_map_add_dblink(Out, Fi->number, Fi->name, Fin->table,
- Fi->key, Fin->database, Fin->driver);
- if (ret == -1) {
- G_warning(_("Unable to add database link for vector map <%s>"),
- Out->name);
- return -1;
- ret = db_copy_table(Fi->driver, Fi->database, Fi->table,
- Fin->driver, Vect_subst_var(Fin->database, Out),
- Fin->table);
- if (ret == DB_FAILED) {
- G_warning(_("Unable to copy table <%s>"), Fin->table);
- return -1;
- driver =
- db_start_driver_open_database(Fin->driver,
- Vect_subst_var(Fin->database, Out));
- if (driver == NULL) {
- G_warning(_("Unable to open database <%s> by driver <%s>"),
- Fin->database, Fin->driver);
- else {
- if (db_create_index2(driver, Fin->table, Fi->key) != DB_OK)
- G_warning(_("Unable to create index for table <%s>, key <%s>"),
- Fin->table, Fin->key);
- db_close_database_shutdown_driver(driver);
+ G_warning(_("Unable to copy table <%s> for layer %d from <%s> to <%s>"),
+ Fi->table, Fi->number, Vect_get_full_name(In), Vect_get_name(Out));
+ return -1;
return 0;
@@ -724,8 +694,9 @@
int ret;
const char *name, *key;
+ dbDriver *driver;
- G_debug(2, "Vect_copy_table(): field_in = %d field_out = %d", field_in,
+ G_debug(2, "Vect_copy_table_by_cats(): field_in = %d field_out = %d", field_in,
field_out);
Fi = Vect_get_field(In, field_in);
@@ -768,5 +739,30 @@
return -1;
+ driver = db_start_driver_open_database(Fin->driver,
+ Vect_subst_var(Fin->database,
+ Out));
+ if (!driver) {
+ G_warning(_("Unable to open database <%s> with driver <%s>"),
+ Fin->database, Fin->driver);
+ return -1;
+ /* do not allow duplicate keys */
+ if (db_create_index2(driver, Fin->table, Fi->key) != DB_OK) {
+ G_warning(_("Unable to create index"));
+ return -1;
+ if (db_grant_on_table(driver, Fin->table, DB_PRIV_SELECT,
+ DB_GROUP | DB_PUBLIC) != DB_OK) {
+ G_warning(_("Unable to grant privileges on table <%s>"),
+ Fin->table);
+ return -1;
+ db_close_database_shutdown_driver(driver);
return 0;
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/map.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/map.c 2015-02-02 08:08:49 UTC (rev 64390)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/map.c 2015-02-02 08:12:40 UTC (rev 64391)
@@ -86,9 +86,8 @@
int Vect_copy(const char *in, const char *mapset, const char *out)
+ int i, ret;
struct Map_info In, Out;
char old_path[GPATH_MAX], new_path[GPATH_MAX], buf[GPATH_MAX];
const char *files[] = { GV_FRMT_ELEMENT, GV_COOR_ELEMENT,
GV_HEAD_ELEMENT, GV_HIST_ELEMENT,
@@ -98,8 +97,6 @@
const char *inmapset;
char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
- dbDriver *driver;
G_debug(2, "Copy vector '%s' in '%s' to '%s'", in, mapset, out);
/* check for [A-Za-z][A-Za-z0-9_]* in name */
if (Vect_legal_filename(out) < 0)
@@ -169,52 +166,11 @@
G_fatal_error(_("Unable to open vector map <%s>"), out);
/* Copy tables */
- n = Vect_get_num_dblinks(&In);
- type = GV_1TABLE;
- if (n > 1)
- type = GV_MTABLE;
- for (i = 0; i < n; i++) {
- Fi = Vect_get_dblink(&In, i);
- if (Fi == NULL) {
- G_warning(_("Database connection not defined for layer %d"),
- In.dblnk->field[i].number);
- Vect_close(&In);
- Vect_close(&Out);
- return -1;
- Fin = Vect_default_field_info(&Out, Fi->number, Fi->name, type);
- G_debug(3, "Copy drv:db:table '%s:%s:%s' to '%s:%s:%s'",
+ if (Vect_copy_tables(&In, &Out, 0) != 0) {
+ Vect_close(&In);
+ Vect_close(&Out);
- Vect_map_add_dblink(&Out, Fi->number, Fi->name, Fin->table, Fi->key,
- Fin->driver, Vect_subst_var(Fin->database, &Out),
- Fin->table);
- Vect_close(&In);
- Vect_close(&Out);
- return -1;
- driver =
- &Out));
- else {
- Fi->table, Fi->key);
+ return 1;
Vect_close(&In);
