[GRASS-SVN] r64396 - in grass/trunk/db/drivers: dbf mysql ogr postgres sqlite
svn_grass at osgeo.org
Mon Feb 2 05:34:53 PST 2015
Author: mmetz
Date: 2015-02-02 05:34:52 -0800 (Mon, 02 Feb 2015)
New Revision: 64396
grass/trunk/db/drivers/dbf/db.c
grass/trunk/db/drivers/dbf/describe.c
grass/trunk/db/drivers/dbf/table.c
grass/trunk/db/drivers/mysql/parse.c
grass/trunk/db/drivers/mysql/replace.c
grass/trunk/db/drivers/ogr/execute.c
grass/trunk/db/drivers/postgres/parse.c
grass/trunk/db/drivers/sqlite/db.c
db drivers: chop tokens
Modified: grass/trunk/db/drivers/dbf/db.c
--- grass/trunk/db/drivers/dbf/db.c 2015-02-02 13:22:01 UTC (rev 64395)
+++ grass/trunk/db/drivers/dbf/db.c 2015-02-02 13:34:52 UTC (rev 64396)
@@ -65,6 +65,7 @@
db.name[0] = '\0'; /* re-init */
for (n = 0; n < no_tokens; n++) {
+ G_chop(tokens[n]);
G_debug(3, "tokens[%d] = %s", n, tokens[n]);
if (tokens[n][0] == '$') {
G_strchg(tokens[n], '$', ' ');
Modified: grass/trunk/db/drivers/dbf/describe.c
--- grass/trunk/db/drivers/dbf/describe.c 2015-02-02 13:22:01 UTC (rev 64395)
+++ grass/trunk/db/drivers/dbf/describe.c 2015-02-02 13:34:52 UTC (rev 64396)
@@ -65,6 +65,9 @@
else
col = i;
+ precision = 0;
+ scale = 0;
dcol = &(db.tables[tab].cols[col]);
column = db_get_table_column(*table, i);
Modified: grass/trunk/db/drivers/dbf/table.c
--- grass/trunk/db/drivers/dbf/table.c 2015-02-02 13:22:01 UTC (rev 64395)
+++ grass/trunk/db/drivers/dbf/table.c 2015-02-02 13:34:52 UTC (rev 64396)
@@ -259,6 +259,9 @@
case DBF_DOUBLE:
dbftype = FTDouble;
break;
+ default:
+ G_warning("invalid/unsupported DBFFieldType");
+ break;
width = db.tables[t].cols[i].width;
Modified: grass/trunk/db/drivers/mysql/parse.c
--- grass/trunk/db/drivers/mysql/parse.c 2015-02-02 13:22:01 UTC (rev 64395)
+++ grass/trunk/db/drivers/mysql/parse.c 2015-02-02 13:34:52 UTC (rev 64396)
@@ -49,6 +49,7 @@
tokens = G_tokenize(str, delm);
i = 0;
while (tokens[i]) {
+ G_chop(tokens[i]);
G_debug(3, "token %d : %s", i, tokens[i]);
if (strncmp(tokens[i], "host", 4) == 0) {
conn->host = G_store(tokens[i] + 5);
Modified: grass/trunk/db/drivers/mysql/replace.c
--- grass/trunk/db/drivers/mysql/replace.c 2015-02-02 13:22:01 UTC (rev 64395)
+++ grass/trunk/db/drivers/mysql/replace.c 2015-02-02 13:34:52 UTC (rev 64396)
@@ -42,6 +42,7 @@
tmp[0] = '\0';
for (n = 0; n < no_tokens - 1; n++) {
if (n > 0)
strcat(tmp, "/");
Modified: grass/trunk/db/drivers/ogr/execute.c
--- grass/trunk/db/drivers/ogr/execute.c 2015-02-02 13:22:01 UTC (rev 64395)
+++ grass/trunk/db/drivers/ogr/execute.c 2015-02-02 13:34:52 UTC (rev 64396)
@@ -181,6 +181,7 @@
*cols = (column_info *)G_malloc(sizeof(column_info) * (*ncols));
for (n = 0; n < (*ncols); n++) {
+ G_chop(token[n]);
itoken = G_tokenize(token[n], "=");
if (G_number_of_tokens(itoken) != 2)
return FALSE;
Modified: grass/trunk/db/drivers/postgres/parse.c
--- grass/trunk/db/drivers/postgres/parse.c 2015-02-02 13:22:01 UTC (rev 64395)
+++ grass/trunk/db/drivers/postgres/parse.c 2015-02-02 13:34:52 UTC (rev 64396)
@@ -44,6 +44,7 @@
i = 0;
while (tokens[i]) {
pgconn->host = G_store(tokens[i] + 5);
Modified: grass/trunk/db/drivers/sqlite/db.c
--- grass/trunk/db/drivers/sqlite/db.c 2015-02-02 13:22:01 UTC (rev 64395)
+++ grass/trunk/db/drivers/sqlite/db.c 2015-02-02 13:34:52 UTC (rev 64396)
@@ -60,6 +60,7 @@
name2[0] = '\0';
if (n > 0)
strcat(name2, "/");
