[GRASS-SVN] r64406 - in grass/trunk/gui/wxpython: animation core	gmodeler mapdisp modules psmap vnet web_services
    svn_grass at osgeo.org
    Mon Feb  2 10:30:09 PST 2015
Author: martinl
Date: 2015-02-02 10:30:09 -0800 (Mon, 02 Feb 2015)
New Revision: 64406
   grass/trunk/gui/wxpython/animation/nviztask.py
   grass/trunk/gui/wxpython/animation/provider.py
   grass/trunk/gui/wxpython/core/render.py
   grass/trunk/gui/wxpython/core/utils.py
   grass/trunk/gui/wxpython/core/ws.py
   grass/trunk/gui/wxpython/gmodeler/model.py
   grass/trunk/gui/wxpython/mapdisp/main.py
   grass/trunk/gui/wxpython/modules/colorrules.py
   grass/trunk/gui/wxpython/psmap/instructions.py
   grass/trunk/gui/wxpython/vnet/vnet_core.py
   grass/trunk/gui/wxpython/vnet/vnet_data.py
   grass/trunk/gui/wxpython/web_services/dialogs.py
wxGUI: replace utils cmd list <-> tuple by grass.script.gtask functions
Modified: grass/trunk/gui/wxpython/animation/nviztask.py
--- grass/trunk/gui/wxpython/animation/nviztask.py	2015-02-02 18:25:03 UTC (rev 64405)
+++ grass/trunk/gui/wxpython/animation/nviztask.py	2015-02-02 18:30:09 UTC (rev 64406)
@@ -22,7 +22,7 @@
 from core.workspace import ProcessWorkspaceFile
 from core.gcmd import RunCommand, GException
-from core.utils import GetLayerNameFromCmd, CmdToTuple, _
+from core.utils import GetLayerNameFromCmd, _
 from grass.script import task as gtask
 from core.settings import UserSettings
@@ -284,7 +284,7 @@
         self.task.set_flag('overwrite', True)
         self.task.set_param('output', 'tobechanged')
         cmd = self.task.get_cmd(ignoreErrors=False, ignoreRequired=False, ignoreDefault=True)
-        return CmdToTuple(cmd)
+        return gtask.cmdlist_to_tuple(cmd)
     def GetRegion(self):
         return self.region
Modified: grass/trunk/gui/wxpython/animation/provider.py
--- grass/trunk/gui/wxpython/animation/provider.py	2015-02-02 18:25:03 UTC (rev 64405)
+++ grass/trunk/gui/wxpython/animation/provider.py	2015-02-02 18:30:09 UTC (rev 64406)
@@ -29,11 +29,12 @@
 from core.debug import Debug
-from core.utils import _, CmdToTuple, autoCropImageFromFile
+from core.utils import _, autoCropImageFromFile
 from animation.utils import HashCmd, HashCmds, GetFileFromCmd, GetFileFromCmds
 import grass.script.core as gcore
+from grass.script.task import cmdlist_to_tuple
 from grass.pydispatch.signal import Signal
@@ -269,7 +270,7 @@
                         transparent=True, bgcolor=(0, 0, 0))
         Debug.msg(1, "Render raster legend " + str(filename))
-        cmdTuple = CmdToTuple(cmd)
+        cmdTuple = cmdlist_to_tuple(cmd)
         returncode, stdout, messages = read2_command(cmdTuple[0], **cmdTuple[1])
         if returncode == 0:
@@ -490,7 +491,7 @@
                     transparent=transparency, bgcolor=bgcolor)
     if region:
         os.environ['GRASS_REGION'] = gcore.region_env(**region)
     if returncode != 0:
         gcore.warning("Rendering failed:\n" + messages)
@@ -523,7 +524,7 @@
     os.environ['GRASS_REGION'] = gcore.region_env(region3d=True, **region)
     Debug.msg(1, "Render image to file " + str(filename))
     cmdTuple[1]['output'] = os.path.splitext(filename)[0]
     # set size
     cmdTuple[1]['size'] = '%d,%d' % (imageWidth, imageHeight)
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py	2015-02-02 18:25:03 UTC (rev 64405)
+++ grass/trunk/gui/wxpython/core/render.py	2015-02-02 18:30:09 UTC (rev 64406)
@@ -39,6 +39,7 @@
 from grass.script import core as grass
 from grass.script.utils import try_remove
 from core          import utils
@@ -104,9 +105,9 @@
         if self.type == 'command':
             self.cmd = list()
             for c in cmd:
-                self.cmd.append(utils.CmdToTuple(c))
+                self.cmd.append(cmdlist_to_tuple(c))
         else:
-            self.cmd = utils.CmdToTuple(cmd)
+            self.cmd = cmdlist_to_tuple(cmd)
         self.active  = active
         self.hidden  = hidden
@@ -302,9 +303,9 @@
             self.cmd = []
             for c in cmd:
         else:
         Debug.msg(3, "Layer.SetCmd(): cmd='%s'" % self.GetCmd(string = True))
         # for re-rendering
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py	2015-02-02 18:25:03 UTC (rev 64405)
+++ grass/trunk/gui/wxpython/core/utils.py	2015-02-02 18:30:09 UTC (rev 64406)
@@ -480,59 +480,8 @@
     :return: command string
-    return ' '.join(CmdTupleToList(cmd))
+    return ' '.join(gtask.cmdtuple_to_list(cmd))
-def CmdTupleToList(cmd):
-    """Convert command tuple to list.
-    :param cmd: GRASS command given as tuple
-    :return: command in list
-    cmdList = []
-    if not cmd:
-        return cmdList
-    cmdList.append(cmd[0])
-    if 'flags' in cmd[1]:
-        for flag in cmd[1]['flags']:
-            cmdList.append('-' + flag)
-    for flag in ('help', 'verbose', 'quiet', 'overwrite'):
-        if flag in cmd[1] and cmd[1][flag] is True:
-            cmdList.append('--' + flag)
-    for k, v in cmd[1].iteritems():
-        if k in ('flags', 'help', 'verbose', 'quiet', 'overwrite'):
-            continue
-        cmdList.append('%s=%s' % (k, v))
-    return cmdList
-def CmdToTuple(cmd):
-    """Convert command list to tuple for gcmd.RunCommand()"""
-    if len(cmd) < 1:
-        return None
-    dcmd = {}
-    for item in cmd[1:]:
-        if '=' in item: # params
-            key, value = item.split('=', 1)
-            dcmd[str(key)] = str(value).replace('"', '')
-        elif item[:2] == '--': # long flags
-            flag = item[2:]
-            if flag in ('help', 'verbose', 'quiet', 'overwrite'):
-                dcmd[str(flag)] = True
-        elif len(item) == 2 and item[0] == '-': # -> flags
-            if 'flags' not in dcmd:
-                dcmd['flags'] = ''
-            dcmd['flags'] += item[1]
-        else: # unnamed parameter
-            module = gtask.parse_interface(cmd[0])
-            dcmd[module.define_first()] = item
-    return (cmd[0], dcmd)
 def PathJoin(*args):
     """Check path created by os.path.join"""
     path = os.path.join(*args)
Modified: grass/trunk/gui/wxpython/core/ws.py
--- grass/trunk/gui/wxpython/core/ws.py	2015-02-02 18:25:03 UTC (rev 64405)
+++ grass/trunk/gui/wxpython/core/ws.py	2015-02-02 18:30:09 UTC (rev 64406)
@@ -23,6 +23,7 @@
 from wx.lib.newevent import NewEvent
+from grass.script.task import cmdtuple_to_list
@@ -126,7 +127,7 @@
             self.downloading = True
             self.fetching_cmd = cmd
-            cmdList = utils.CmdTupleToList(cmd)
+            cmdList = cmdtuple_to_list(cmd)
             if Debug.GetLevel() < 3:
                 cmdList.append('--quiet')
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py	2015-02-02 18:25:03 UTC (rev 64405)
+++ grass/trunk/gui/wxpython/gmodeler/model.py	2015-02-02 18:30:09 UTC (rev 64406)
@@ -670,7 +670,7 @@
                 vlist = list()
                 if condText[0] == '`' and condText[-1] == '`':
                     # run command
-                    cmd, dcmd = utils.CmdToTuple(condText[1:-1].split(' '))
+                    cmd, dcmd = gtask.cmdlist_to_tuple(condText[1:-1].split(' '))
                     ret = RunCommand(cmd,
                                      read = True,
                                      **dcmd)
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py	2015-02-02 18:25:03 UTC (rev 64405)
+++ grass/trunk/gui/wxpython/mapdisp/main.py	2015-02-02 18:30:09 UTC (rev 64406)
@@ -44,6 +44,7 @@
 # for standalone app
@@ -248,7 +249,7 @@
     def __getattr__(self, name):
         if name == 'cmd':
-            return utils.CmdTupleToList(self._maplayer.GetCmd())
+            return cmdtuple_to_list(self._maplayer.GetCmd())
         elif hasattr(self._maplayer, name):
             return getattr(self._maplayer, name)
         elif name == 'maplayer':
Modified: grass/trunk/gui/wxpython/modules/colorrules.py
--- grass/trunk/gui/wxpython/modules/colorrules.py	2015-02-02 18:25:03 UTC (rev 64405)
+++ grass/trunk/gui/wxpython/modules/colorrules.py	2015-02-02 18:30:09 UTC (rev 64406)
@@ -33,6 +33,7 @@
 import wx.lib.filebrowsebutton as filebrowse
 import grass.script as grass
 from core             import globalvar
@@ -692,7 +693,7 @@
             if self.properties['sourceColumn'] and self.properties['sourceColumn'] != 'cat':
                 cmd.append('column=%s' % self.properties['sourceColumn'])
-        cmd = utils.CmdToTuple(cmd)
+        cmd = cmdlist_to_tuple(cmd)
         if self.inmap:
             ctable = RunCommand(cmd[0], **cmd[1])
@@ -739,7 +740,7 @@
         if self.mapType == 'vector' and self.properties['sourceColumn'] \
         ret = RunCommand(cmd[0], **cmd[1])
         if ret != 0:
             return False
@@ -1371,7 +1372,7 @@
     def CreateAttrTable(self, dcmd, layer, params, propwin):
         """Create attribute table"""
         if dcmd:
-            cmd = utils.CmdToTuple(dcmd)
+            cmd = cmdlist_to_tuple(dcmd)
             if ret == 0:
                 self.OnSelectionInput(None)
Modified: grass/trunk/gui/wxpython/psmap/instructions.py
--- grass/trunk/gui/wxpython/psmap/instructions.py	2015-02-02 18:25:03 UTC (rev 64405)
+++ grass/trunk/gui/wxpython/psmap/instructions.py	2015-02-02 18:30:09 UTC (rev 64406)
@@ -39,9 +39,10 @@
 import wx
 from core.gcmd          import RunCommand, GError, GMessage, GWarning
-from core.utils         import CmdToTuple, GetCmdString, _
+from core.utils         import GetCmdString, _
 from dbmgr.vinfo        import VectorDBInfo
 from psmap.utils        import *
@@ -439,7 +440,7 @@
         map = MapFrame(wx.NewId())
         self.AddInstruction(map)
         if regionInstruction:
-            cmd = CmdToTuple(regionInstruction.strip('# ').split())
+            cmd = cmdlist_to_tuple(regionInstruction.strip('# ').split())
             # define scaleType
             if len(cmd[1]) <= 3:
Modified: grass/trunk/gui/wxpython/vnet/vnet_core.py
--- grass/trunk/gui/wxpython/vnet/vnet_core.py	2015-02-02 18:25:03 UTC (rev 64405)
+++ grass/trunk/gui/wxpython/vnet/vnet_core.py	2015-02-02 18:30:09 UTC (rev 64406)
@@ -22,6 +22,7 @@
 import os
 import wx
@@ -361,7 +362,7 @@
                                                 cmd=cmd,
                                                 checked=True)
             if cmd_colors:
-                layerStyleVnetColors = utils.CmdToTuple(cmd_colors)
+                layerStyleVnetColors = cmdlist_to_tuple(cmd_colors)
                 RunCommand(layerStyleVnetColors[0],
                         **layerStyleVnetColors[1])
Modified: grass/trunk/gui/wxpython/vnet/vnet_data.py
--- grass/trunk/gui/wxpython/vnet/vnet_data.py	2015-02-02 18:25:03 UTC (rev 64405)
+++ grass/trunk/gui/wxpython/vnet/vnet_data.py	2015-02-02 18:30:09 UTC (rev 64406)
@@ -28,6 +28,7 @@
 import wx
@@ -992,7 +993,7 @@
         if colorsCmd:
             colorsCmd.append('map=%s' % self.fullName)
-            layerStyleVnetColors = utils.CmdToTuple(colorsCmd)
+            layerStyleVnetColors = cmdlist_to_tuple(colorsCmd)
Modified: grass/trunk/gui/wxpython/web_services/dialogs.py
--- grass/trunk/gui/wxpython/web_services/dialogs.py	2015-02-02 18:25:03 UTC (rev 64405)
+++ grass/trunk/gui/wxpython/web_services/dialogs.py	2015-02-02 18:30:09 UTC (rev 64406)
@@ -27,11 +27,12 @@
 from copy      import deepcopy
+from grass.script.task import cmdlist_to_tuple, cmdtuple_to_list
 from core.gcmd        import GMessage, GWarning, GError, RunCommand
-from core.utils       import GetSettingsPath, CmdToTuple, CmdTupleToList, _
+from core.utils       import GetSettingsPath, _
 from core.gconsole    import CmdThread, GStderr, EVT_CMD_DONE, EVT_CMD_OUTPUT
 from gui_core.gselect import Select
@@ -549,7 +550,7 @@
         ws_cap_files = self._getCapFiles()
         # create properties dialog
         cmd_list = ltree.GetLayerInfo(layer,'cmd')
-        cmd = CmdToTuple(cmd_list)
+        cmd = cmdlist_to_tuple(cmd_list)
         prop_win = WSPropertiesDialog(parent = self.parent,
                                       giface = self.giface,
@@ -705,7 +706,7 @@
                                               propwin = self)
         #TODO use just list or tuple
-        cmd = CmdToTuple(lcmd)
+        cmd = cmdlist_to_tuple(lcmd)
         self.revert_cmd = cmd
         self._setRevertCapFiles(self._getCapFiles())
@@ -992,7 +993,7 @@
             region = self._giface.GetMapWindow().GetMap().SetRegion()
             env['GRASS_REGION'] = region
-        cmdList = CmdTupleToList(cmd)
         self.currentPid = self.thread.GetId()
         self.thread.RunCmd(cmdList, env=env, stderr=self.cmdStdErr)
