[GRASS-SVN] r64408 - grass/trunk/lib/init
svn_grass at osgeo.org
Mon Feb 2 18:49:07 PST 2015
Author: wenzeslaus
Date: 2015-02-02 18:49:07 -0800 (Mon, 02 Feb 2015)
New Revision: 64408
grass/trunk/lib/init/grass.py
startup: do not show old-school command line welcome
* user who needs the info such as website URL will not read it in the command line
* do not require first time user to press Enter (or hit RETURN) in command line to make GRASS start
* rename function according to the part which is creating a dummy rc file
* fixes #2572 for 7.x
* see also r57549, r64345, r64405 and r64407
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-02-03 02:08:29 UTC (rev 64407)
+++ grass/trunk/lib/init/grass.py 2015-02-03 02:49:07 UTC (rev 64408)
@@ -501,27 +501,8 @@
os.environ['GRASS_HTML_BROWSER'] = browser
-def grass_intro():
- intro = _(r"""
-WELCOME TO GRASS %s
- 1) Have at your side all available GRASS GIS tutorials
- 2) When working on your location, the following materials
- are extremely useful:
- - A topographic map of your area
- - Current catalog of available computer maps
- 3) Check the GRASS GIS web pages for supporting mailing lists and more:
- http://grass.osgeo.org
-""") % grass_version
- sys.stderr.write(intro)
- sys.stderr.write("\n")
- sys.stderr.write(_("Hit RETURN to continue"))
- sys.stdin.readline()
- # for convenience, define pwd as GISDBASE:
+def create_initial_gisrc():
+ # for convenience, define GISDBASE as pwd:
s = r"""GISDBASE: %s
LOCATION_NAME: <UNKNOWN>
MAPSET: <UNKNOWN>
@@ -1401,7 +1382,7 @@
" - Create manually GISRC file (%s)\n"
" - Launch GRASS with path to "
"the location/mapset as an argument (`grass71 /path/to/location/mapset`)") % gisrcrc)
- grass_intro()
+ create_initial_gisrc()
else:
clean_temp()
