[GRASS-SVN] r64423 - grass/trunk/display/d.mon
svn_grass at osgeo.org
Tue Feb 3 05:20:48 PST 2015
Author: martinl
Date: 2015-02-03 05:20:47 -0800 (Tue, 03 Feb 2015)
New Revision: 64423
grass/trunk/display/d.mon/list.c
grass/trunk/display/d.mon/start.c
d.mon: improve list menthod
fix renderer when display command fails
Modified: grass/trunk/display/d.mon/list.c
--- grass/trunk/display/d.mon/list.c 2015-02-03 13:05:09 UTC (rev 64422)
+++ grass/trunk/display/d.mon/list.c 2015-02-03 13:20:47 UTC (rev 64423)
@@ -49,7 +49,7 @@
while ((dp = readdir(dirp)) != NULL) {
*list = G_realloc(*list, (*n + 1) * sizeof(char *));
- if (!dp->d_name || dp->d_name[0] == '.')
+ if (!dp->d_name || dp->d_name[0] == '.' || dp->d_type != DT_DIR)
continue;
(*list)[*n] = dp->d_name;
(*n)++;
Modified: grass/trunk/display/d.mon/start.c
--- grass/trunk/display/d.mon/start.c 2015-02-03 13:05:09 UTC (rev 64422)
+++ grass/trunk/display/d.mon/start.c 2015-02-03 13:20:47 UTC (rev 64423)
@@ -152,7 +152,8 @@
"cmd, dcmd = gtask.cmdstring_to_tuple(sys.argv[1])\n"
"if not cmd or cmd == 'd.mon':\n"
" sys.exit(0)\n\n"
- "mode = 'w' if cmd == 'd.erase' else 'a'\n"
+ "mode = 'w' if cmd == 'd.erase' else 'a'\n\n"
+ "# update cmd file\n"
"fd = open('%s', mode)\n"
"if fd is None:\n"
" grass.fatal(\"Unable to open file '%s'\")\n"
@@ -162,6 +163,7 @@
"else:\n"
" fd.write('')\n"
"fd.close()\n\n"
+ "# read env file\n"
"fd = open('%s', 'r')\n"
"if fd is None:\n"
@@ -170,7 +172,11 @@
" k, v = l.rstrip('\\n').split('=')\n"
" os.environ[k] = v\n"
"fd.close()\n\n"
- "grass.run_command(cmd, **dcmd)\n"
+ "# run display command\n"
+ "try:\n"
+ " grass.run_command(cmd, **dcmd)\n"
+ "except:\n"
+ " pass\n\n"
"sys.exit(0)\n",
cmd_file, cmd_file, env_file, env_file);
write(fd, pycode, strlen(pycode));
