[GRASS-SVN] r64426 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Tue Feb 3 07:20:48 PST 2015
Author: glynn
Date: 2015-02-03 07:20:48 -0800 (Tue, 03 Feb 2015)
New Revision: 64426
grass/trunk/lib/python/script/array.py
numpy.memmap() no longer has _close; use __del__ instead
Modified: grass/trunk/lib/python/script/array.py
--- grass/trunk/lib/python/script/array.py 2015-02-03 15:01:35 UTC (rev 64425)
+++ grass/trunk/lib/python/script/array.py 2015-02-03 15:20:48 UTC (rev 64426)
@@ -150,8 +150,7 @@
self.filename = filename
return self
- def _close(self):
- numpy.memmap._close(self)
+ def __del__(self):
if isinstance(self, array):
try_remove(self.filename)
@@ -273,10 +272,8 @@
return self
- def _close(self):
- if isinstance(self, array):
+ if isinstance(self, array3d):
def read(self, mapname, null=None):
