[GRASS-SVN] r64432 - grass/trunk/scripts/d.frame
svn_grass at osgeo.org
Tue Feb 3 08:55:49 PST 2015
Author: martinl
Date: 2015-02-03 08:55:49 -0800 (Tue, 03 Feb 2015)
New Revision: 64432
grass/trunk/scripts/d.frame/d.frame.html
grass/trunk/scripts/d.frame/d.frame.py
d.frame: update to the new monitor architecture
Modified: grass/trunk/scripts/d.frame/d.frame.html
--- grass/trunk/scripts/d.frame/d.frame.html 2015-02-03 16:54:14 UTC (rev 64431)
+++ grass/trunk/scripts/d.frame/d.frame.html 2015-02-03 16:55:49 UTC (rev 64432)
@@ -77,7 +77,7 @@
</em>
<p>
- <a href="variables.html#rendering">GRASS environment variables for
+ <a href="variables.html#list-of-selected-grass-environment-variables-for-rendering">GRASS environment variables for
rendering</a> (GRASS_RENDER_FRAME)
<h2>AUTHOR</h2>
Modified: grass/trunk/scripts/d.frame/d.frame.py
--- grass/trunk/scripts/d.frame/d.frame.py 2015-02-03 16:54:14 UTC (rev 64431)
+++ grass/trunk/scripts/d.frame/d.frame.py 2015-02-03 16:55:49 UTC (rev 64432)
@@ -6,7 +6,7 @@
# AUTHOR(S): Martin Landa <landa.martin gmail.com>
# Based on d.frame from GRASS 6
# PURPOSE: Manages display frames on the user's graphics monitor
-# COPYRIGHT: (C) 2014 by Martin Landa, and the GRASS Development Team
+# COPYRIGHT: (C) 2014-2015 by Martin Landa, and the GRASS Development Team
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
@@ -68,13 +68,14 @@
import os
import sys
-from grass.script.core import parser, read_command, fatal, debug, run_command, gisenv, warning
+from grass.script.core import parser, read_command, fatal, debug, run_command, gisenv, warning, parse_command
# check if monitor is running
def check_monitor():
return read_command('d.mon', flags='p', quiet=True).strip()
# read monitor file and return list of lines
+# TODO: replace by d.info (see #2577)
def read_monitor_file(monitor, ftype='env'):
mfile = check_monitor_file(monitor, ftype)
try:
@@ -92,8 +93,7 @@
# check if monitor file exists
def check_monitor_file(monitor, ftype='env'):
- var = 'MONITOR_%s_%sFILE' % (monitor.upper(), ftype.upper())
- mfile = gisenv().get(var, None)
+ mfile = parse_command('d.info', flags='s').get(ftype, None)
if mfile is None or not os.path.isfile(mfile):
fatal(_("Unable to get monitor info (no %s found)") % var)
