[GRASS-SVN] r64440 - grass-addons/grass7/raster/r.vif
svn_grass at osgeo.org
Tue Feb 3 12:18:23 PST 2015
Author: pvanbosgeo
Date: 2015-02-03 12:18:23 -0800 (Tue, 03 Feb 2015)
New Revision: 64440
grass-addons/grass7/raster/r.vif/r.vif.py
minor change
Modified: grass-addons/grass7/raster/r.vif/r.vif.py
--- grass-addons/grass7/raster/r.vif/r.vif.py 2015-02-03 20:15:51 UTC (rev 64439)
+++ grass-addons/grass7/raster/r.vif/r.vif.py 2015-02-03 20:18:23 UTC (rev 64440)
@@ -6,7 +6,7 @@
# MODULE: r.vif
# AUTHOR(S): Paulo van Breugel <p.vanbreugel AT gmail.com>
# PURPOSE: Calculate the variance inflaction factor of set of
-# variables. Alternatively, to speed the calculation up,
+# variables. Alternatively, to speed the calculation up,
# this can be done for an user defined number of random
# cells. The user can set a maximum VIF, in wich case the VIF
# will calculated again after removing the variables with the
@@ -14,7 +14,7 @@
# the user defined VIF threshold value.
# TODO Include the option to force the function to retain one or more
# variables
-# Dependency: r.regression.multi
+# Dependency: r.regression.multi
# COPYRIGHT: (C) 2014 Paulo van Breugel
# http://ecodiv.org
@@ -86,7 +86,7 @@
# Check if running in GRASS
if not os.environ.has_key("GISBASE"):
- grass.message( "You must be in GRASS GIS to run this program." )
+ grass.message("You must be in GRASS GIS to run this program.")
sys.exit(1)
# create set to store names of temporary maps to be deleted upon exit
@@ -95,7 +95,7 @@
def cleanup():
for rast in clean_rast:
grass.run_command("g.remove",
- type="rast", name = rast, quiet = True)
+ type="rast", name=rast, quiet=True)
# main function
def main():
@@ -117,7 +117,7 @@
k = k + 1
opft = OPF.split('.')
if len(opft) == 1:
- OPF = opft[0] + "_" + str(k)
+ OPF = opft[0] + "_v" + str(k)
else:
OPF = opft[0] + "_v" + str(k) + "." + opft[1]
if k > 0:
@@ -129,7 +129,8 @@
# Create mask if nsp is set replace existing MASK if exist)
- citiam = grass.find_file('MASK', element = 'cell')
+ citiam = grass.find_file('MASK', element='cell',
+ mapset=grass.gisenv()['MAPSET'])
if NSP != '':
if citiam['fullname'] != '':
tmpf0 = "rvif_mask_" + str(uuid.uuid4())
@@ -164,7 +165,7 @@
vifstat = [i.split('=') for i in vifstat]
vif = 1 / (1 - float(vifstat[1][1]))
sqrtvif = math.sqrt(vif)
- text_file.write(nMAPy + "\t" + str(round(vif,3)) + "\t" + str(round(sqrtvif,3)) + "\n")
+ text_file.write(nMAPy + "\t" + str(round(vif, 3)) + "\t" + str(round(sqrtvif, 3)) + "\n")
rvif[k] = vif
rvifmx = max(rvif)
@@ -186,7 +187,7 @@
if NSP != '':
grass.run_command("r.mask", flags="r", quiet=True)
- grass.mapcalc("MASK = $tmpf0",tmpf0 = tmpf0, quiet=True)
+ grass.mapcalc("MASK = $tmpf0",tmpf0=tmpf0, quiet=True)
grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmpf0)
grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmpf1)
