[GRASS-SVN] r64445 - grass/trunk/vector/v.build
svn_grass at osgeo.org
Tue Feb 3 13:15:38 PST 2015
Author: neteler
Date: 2015-02-03 13:15:37 -0800 (Tue, 03 Feb 2015)
New Revision: 64445
grass/trunk/vector/v.build/v.build.html
v.build manual: point to progman for topology dump
Modified: grass/trunk/vector/v.build/v.build.html
--- grass/trunk/vector/v.build/v.build.html 2015-02-03 21:04:34 UTC (rev 64444)
+++ grass/trunk/vector/v.build/v.build.html 2015-02-03 21:15:37 UTC (rev 64445)
@@ -58,11 +58,13 @@
Note that the vector map <i>urbanarea</i> must be located in the
current mapset.
-<h3>Dump topology or indeces</h3>
+<h3>Dump topology or indices</h3>
Dump options print topology, spatial, category or feature index to
standard output. Such information can be printed also for vector maps
-from other mapsets.
+from other mapsets. A description of the vector topology is available in
+the <a href="http://grass.osgeo.org/programming7/vlibTopology.html">GRASS GIS 7 Programmer's Manual</a>,
+section "Vector library topology management".
<div class="code"><pre>
v.build map=urbanarea option=dump
