[GRASS-SVN] r64469 - in grass/trunk/scripts: d.frame d.redraw d.what.rast d.what.vect
svn_grass at osgeo.org
Wed Feb 4 13:15:25 PST 2015
Author: martinl
Date: 2015-02-04 13:15:25 -0800 (Wed, 04 Feb 2015)
New Revision: 64469
grass/trunk/scripts/d.frame/d.frame.py
grass/trunk/scripts/d.redraw/d.redraw.py
grass/trunk/scripts/d.what.rast/d.what.rast.py
grass/trunk/scripts/d.what.vect/d.what.vect.py
update scrips to use `d.mon -g`
Modified: grass/trunk/scripts/d.frame/d.frame.py
--- grass/trunk/scripts/d.frame/d.frame.py 2015-02-04 21:11:58 UTC (rev 64468)
+++ grass/trunk/scripts/d.frame/d.frame.py 2015-02-04 21:15:25 UTC (rev 64469)
@@ -93,7 +93,7 @@
# check if monitor file exists
def check_monitor_file(monitor, ftype='env'):
- mfile = parse_command('d.info', flags='s').get(ftype, None)
+ mfile = parse_command('d.mon', flags='g').get(ftype, None)
if mfile is None or not os.path.isfile(mfile):
fatal(_("Unable to get monitor info (no %s found)") % var)
Modified: grass/trunk/scripts/d.redraw/d.redraw.py
--- grass/trunk/scripts/d.redraw/d.redraw.py 2015-02-04 21:11:58 UTC (rev 64468)
+++ grass/trunk/scripts/d.redraw/d.redraw.py 2015-02-04 21:15:25 UTC (rev 64469)
@@ -31,7 +31,7 @@
if not mon:
grass.fatal(_("No graphics device selected. Use d.mon to select graphics device."))
- monCmd = grass.parse_command('d.info', flags='s').get('cmd', None)
+ monCmd = grass.parse_command('d.mon', flags='g').get('cmd', None)
if not monCmd or not os.path.isfile(monCmd):
grass.fatal(_("Unable to open file '%s'") % monCmd)
Modified: grass/trunk/scripts/d.what.rast/d.what.rast.py
--- grass/trunk/scripts/d.what.rast/d.what.rast.py 2015-02-04 21:11:58 UTC (rev 64468)
+++ grass/trunk/scripts/d.what.rast/d.what.rast.py 2015-02-04 21:15:25 UTC (rev 64469)
@@ -30,7 +30,7 @@
options, flags = gcore.parser()
gisenv = gcore.gisenv()
if 'MONITOR' in gisenv:
- cmd_file = gcore.parse_command('d.info', flags='s').get('cmd', None)
+ cmd_file = gcore.parse_command('d.mon', flags='g').get('cmd', None)
if not cmd_file:
gcore.fatal(_("Unable to open file '%s'") % cmd_file)
dout_cmd = 'd.what.rast'
Modified: grass/trunk/scripts/d.what.vect/d.what.vect.py
--- grass/trunk/scripts/d.what.vect/d.what.vect.py 2015-02-04 21:11:58 UTC (rev 64468)
+++ grass/trunk/scripts/d.what.vect/d.what.vect.py 2015-02-04 21:15:25 UTC (rev 64469)
@@ -30,7 +30,7 @@
if not cmd_file:
dout_cmd = 'd.what.vect'
