[GRASS-SVN] r64476 - grass/trunk/vector/v.in.ogr
    svn_grass at osgeo.org
    Thu Feb  5 14:43:15 PST 2015
Author: mmetz
Date: 2015-02-05 14:43:15 -0800 (Thu, 05 Feb 2015)
New Revision: 64476
   grass/trunk/vector/v.in.ogr/geom.c
   grass/trunk/vector/v.in.ogr/main.c
v.in.ogr: improve cleaning suggestions
Modified: grass/trunk/vector/v.in.ogr/geom.c
--- grass/trunk/vector/v.in.ogr/geom.c	2015-02-05 21:32:58 UTC (rev 64475)
+++ grass/trunk/vector/v.in.ogr/geom.c	2015-02-05 22:43:15 UTC (rev 64476)
@@ -305,7 +305,6 @@
 	    return 0;
-	n_polygons++;
 	nr = OGR_G_GetGeometryCount(hGeom);
 	Vect_reset_line(Points);
@@ -327,6 +326,8 @@
 	    return 0;
+	n_polygons++;
 	if (type & GV_LINE)
 	    otype = GV_LINE;
 	else
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2015-02-05 21:32:58 UTC (rev 64475)
+++ grass/trunk/vector/v.in.ogr/main.c	2015-02-05 22:43:15 UTC (rev 64476)
@@ -1576,19 +1576,45 @@
 	    max_snap = pow(10, max_snap);
 	    G_important_message("%s", separator);
-	    G_warning(_("Errors were encountered during the import"));
-	    G_important_message(_("Estimated range of snapping threshold: [%g, %g]"), min_snap, max_snap);
+	    if (n_overlaps) {
+		G_important_message(_("Some input polygons are overlapping each other."));
+		G_important_message(_("If overlapping is not desired, the data need to be cleaned."));
-	    if (snap < min_snap) {
-		G_important_message(_("Try to import again, snapping with at least %g: 'snap=%g'"), min_snap, min_snap);
+		if (snap < max_snap) {
+		    G_important_message(_("The input could be cleaned by snapping vertices to each other."));
+		    G_important_message(_("Estimated range of snapping threshold: [%g, %g]"), min_snap, max_snap);
+		if (snap < min_snap) {
+		    G_important_message(_("Try to import again, snapping with at least %g: 'snap=%g'"), min_snap, min_snap);
+		else if (snap < max_snap) {
+		    min_snap = snap * 10;
+		    G_important_message(_("Try to import again, snapping with %g: 'snap=%g'"), min_snap, min_snap);
+		else
+		    /* assume manual cleaning is required */
+		    G_important_message(_("Manual cleaning may be needed."));
-	    else if (snap < max_snap) {
-		min_snap = snap * 10;
-		G_important_message(_("Try to import again, snapping with %g: 'snap=%g'"), min_snap, min_snap);
+	    else {
+		if (ncentr < n_polygons) {
+		    G_important_message(_("%d input polygons got lost during import."), n_polygons - ncentr);
+		if (ncentr > n_polygons) {
+		    G_important_message(_("%d additional areas where created during import."), ncentr - n_polygons);
+		if (snap > 0) {
+		    G_important_message(_("The snapping threshold %g might be too large."), snap);
+		else {
-	    else
-		/* assume manual cleaning is required */
-		G_important_message(_("Manual cleaning may be needed"));
