[GRASS-SVN] r64484 - grass/branches/releasebranch_6_4/vector/v.generalize
Fri Feb 6 12:14:28 PST 2015
Author: mmetz
Date: 2015-02-06 12:14:28 -0800 (Fri, 06 Feb 2015)
New Revision: 64484
   grass/branches/releasebranch_6_4/vector/v.generalize/misc.c
v.generalize: add test for self-intersection
Modified: grass/branches/releasebranch_6_4/vector/v.generalize/misc.c
--- grass/branches/releasebranch_6_4/vector/v.generalize/misc.c	2015-02-06 20:08:21 UTC (rev 64483)
+++ grass/branches/releasebranch_6_4/vector/v.generalize/misc.c	2015-02-06 20:14:28 UTC (rev 64484)
@@ -88,12 +88,10 @@
     int ttype, ntabs = 0;
     struct field_info *IFi, *OFi;
     struct line_cats *Cats;
-    struct line_pnts *Points;
     int **ocats, *nocats, *fields;
     int i;
     /* Collect list of output cats */
-    Points = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
     nfields = Vect_cidx_get_num_fields(In);
     ocats = (int **)G_malloc(nfields * sizeof(int *));
@@ -258,26 +256,49 @@
 int check_topo(struct Map_info *Out, int line, struct line_pnts *APoints,
                struct line_pnts *Points, struct line_cats *Cats)
-    int i, intersect, newline, left_old, right_old,
+    int i, j, intersect, newline, left_old, right_old,
 	left_new, right_new;
     struct bound_box box;
     static struct line_pnts *BPoints = NULL;
     static struct ilist *List = NULL;
+    struct line_pnts **AXLines, **BXLines;
+    int naxlines, nbxlines;
     if (!BPoints)
 	BPoints = Vect_new_line_struct();
     if (!List)
 	List = Vect_new_list();
+    /* Check the modified boundary for self-intersection */
+    AXLines = BXLines = NULL;
+    Vect_line_intersection(Points, Points, &AXLines, &BXLines,
+			   &naxlines, &nbxlines, 0);
+    /* Free */
+    if (naxlines > 0) {
+	for (j = 0; j < naxlines; j++) {
+	    Vect_destroy_line_struct(AXLines[j]);
+    if (AXLines)
+	G_free(AXLines);
+    if (nbxlines > 0) {
+	for (j = 0; j < nbxlines; j++) {
+	    Vect_destroy_line_struct(BXLines[j]);
+    if (BXLines)
+	G_free(BXLines);
+    if (naxlines > 0 || nbxlines > 0)
+	return 0;
     /* Check intersection of the modified boundary with other boundaries */
     Vect_line_box(Points, &box);
     Vect_select_lines_by_box(Out, &box, GV_BOUNDARY, List);
     intersect = 0;
     for (i = 0; i < List->n_values; i++) {
-	int j, bline;
-	struct line_pnts **AXLines, **BXLines;
-	int naxlines, nbxlines;
+	int bline;
 	bline = List->value[i];
 	if (bline == line)
