[GRASS-SVN] r64486 - grass/branches/releasebranch_6_4/lib/vector/Vlib
svn_grass at osgeo.org
Fri Feb 6 12:34:03 PST 2015
Author: mmetz
Date: 2015-02-06 12:34:03 -0800 (Fri, 06 Feb 2015)
New Revision: 64486
grass/branches/releasebranch_6_4/lib/vector/Vlib/build_nat.c
Vlib: fix reattaching centroids and isles
Modified: grass/branches/releasebranch_6_4/lib/vector/Vlib/build_nat.c
--- grass/branches/releasebranch_6_4/lib/vector/Vlib/build_nat.c 2015-02-06 20:33:08 UTC (rev 64485)
+++ grass/branches/releasebranch_6_4/lib/vector/Vlib/build_nat.c 2015-02-06 20:34:03 UTC (rev 64486)
@@ -313,6 +313,10 @@
for (i = 0; i < List->n_values; i++) {
isle = List->value[i];
+ if (plus->Isle[isle]->area > 0) {
+ dig_area_del_isle(plus, plus->Isle[isle]->area, isle);
+ plus->Isle[isle]->area = 0;
Vect_attach_isle(Map, isle);
return 0;
@@ -364,10 +368,6 @@
* to check if original area exist, unregister centroid from previous area.
* To simplify code, this is implemented so that centroid is always firs unregistered
* and if new area is found, it is registered again.
- * This problem can be avoided altogether if properly attached centroids
- * are skipped
- * MM 2009
Vect_select_lines_by_box(Map, box, GV_CENTROID, List);
@@ -378,15 +378,14 @@
centr = List->value[i];
Line = plus->Line[centr];
- /* only attach unregistered and duplicate centroids because
- * 1) all properly attached centroids are properly attached, really! Don't touch.
- * 2) Vect_find_area() below does not always return the correct area
- * 3) it's faster
- if (Line->left > 0)
- continue;
+ /* Unregister centroid */
orig_area = Line->left;
+ if ( orig_area > 0 ) {
+ if ( plus->Area[orig_area] != NULL ) {
+ plus->Area[orig_area]->centroid = 0;
+ Line->left = 0;
sel_area = Vect_find_area(Map, Line->E, Line->N);
G_debug(3, " centroid %d is in area %d", centr, sel_area);
