[GRASS-SVN] r64538 - in grass-addons/grass7/vector: . v.ellipse
Tue Feb 10 14:06:23 PST 2015
Author: martinl
Date: 2015-02-10 14:06:23 -0800 (Tue, 10 Feb 2015)
New Revision: 64538
Added:
   grass-addons/grass7/vector/v.ellipse/
   grass-addons/grass7/vector/v.ellipse/Makefile
   grass-addons/grass7/vector/v.ellipse/ellipse.c
   grass-addons/grass7/vector/v.ellipse/main.c
   grass-addons/grass7/vector/v.ellipse/proto.h
   grass-addons/grass7/vector/v.ellipse/read.c
   grass-addons/grass7/vector/v.ellipse/v.ellipse.html
   grass-addons/grass7/vector/v.ellipse/v_ellipse.png
   grass-addons/grass7/vector/v.ellipse/write.c
v.ellipse: Computes the best-fitting ellipse for given vector data
           (author: Tereza Fiedlerova, OSGeoREL, CTU in Prague)
Added: grass-addons/grass7/vector/v.ellipse/Makefile
--- grass-addons/grass7/vector/v.ellipse/Makefile	                        (rev 0)
+++ grass-addons/grass7/vector/v.ellipse/Makefile	2015-02-10 22:06:23 UTC (rev 64538)
@@ -0,0 +1,14 @@
+# fix this relative to include/
+# or use absolute path to the GRASS source code
+MODULE_TOPDIR = ../..
+PGM = v.ellipse
+LIBES = $(VECTORLIB) $(DBMILIB) $(GISLIB) $(MATHLIB) $(GMATHLIB)
+DEPENDENCIES = $(VECTORDEP) $(DBMIDEP) $(GISDEP) $(GMATHDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass-addons/grass7/vector/v.ellipse/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass7/vector/v.ellipse/ellipse.c
--- grass-addons/grass7/vector/v.ellipse/ellipse.c	                        (rev 0)
+++ grass-addons/grass7/vector/v.ellipse/ellipse.c	2015-02-10 22:06:23 UTC (rev 64538)
@@ -0,0 +1,220 @@
+#include <math.h>
+#include <grass/vector.h>
+#include <grass/gmath.h>
+#include <grass/glocale.h>
+#include "proto.h"
+void create_ellipse(struct Parameters *par, struct line_pnts *Ellipse,
+		    struct line_cats *Cats, double stepsize)
+    Vect_reset_line(Ellipse);
+    /* angle */
+    double t = 0;
+    /* number of points */
+    if (stepsize < 0.01)	/* too small step */
+	stepsize = 0.01;
+    int n = 360.0 / stepsize;
+    /* compute n points on ellipse */
+    double *x;
+    double *y;
+    x = (double *)G_malloc((n + 1) * sizeof(double));
+    y = (double *)G_malloc((n + 1) * sizeof(double));
+    int i;
+    for (i = 0; i < n; i++) {
+	x[i] = par->a * cos(t) * cos(par->angle) - par->b * sin(t) * sin(par->angle) + par->xc;	/* parametric equations of an ellipse (non-tilted) */
+	y[i] =
+	    par->a * cos(t) * sin(par->angle) +
+	    par->b * sin(t) * cos(par->angle) + par->yc;
+	Vect_cat_set(Cats, 1, i);
+	t += 2 * M_PI / n;
+    x[n] = x[0];
+    y[n] = y[0];
+    Vect_cat_set(Cats, 1, n);
+    Vect_copy_xyz_to_pnts(Ellipse, x, y, 0, n + 1);
+    G_free(x);
+    G_free(y);
+int fitting_ellipse(struct line_pnts *Points, struct Parameters *pars)
+    /* variables */
+    int i, j, k, n;
+    double meanx, meany;
+    double *x, *y, *nn;
+    double **AA, **NN;
+    int singular;
+    /* LSM for conic representation of an ellipse */
+    /* a*x^2 + b*x*y + c*y^2 + d*x + e*y = f */
+    /* allocate memory */
+    n = Points->n_points;
+    x = G_alloc_vector(n);	/* x-coordinates */
+    y = G_alloc_vector(n);	/* y-coordinates */
+    AA = G_alloc_matrix(n, 5);	/* design matrix [x.^2, y.^2, x.*y, y.^2, x, y] */
+    NN = G_alloc_matrix(5, 5);	/* N = A'*A */
+    nn = G_alloc_vector(5);	/* n = A'*l, vector of unknown
+				 * parameters of conic representation of
+				 * ellipse [a, b, c, d, e] */
+    /* remove bias of the ellipse (to be more accurate for inversion) */
+    /* compute mean */
+    meanx = 0;
+    meany = 0;
+    /* TODO: do this more effective */
+	meanx += Points->x[i] / n;
+	meany += Points->y[i] / n;
+    /* change coordinates */
+	x[i] = Points->x[i] - meanx;
+	y[i] = Points->y[i] - meany;
+    /* compute design matrix */
+	AA[i][0] = x[i] * x[i];
+	AA[i][1] = x[i] * y[i];
+	AA[i][2] = y[i] * y[i];
+	AA[i][3] = x[i];
+	AA[i][4] = y[i];
+    /* compute N=A'*A */
+    /* TODO: use fn - mat_struct *G_matrix_product (mat_struct *mt1, mat_struct *mt2) */
+    for (i = 0; i < 5; i++) {
+	for (j = 0; j < 5; j++) {
+	    NN[i][j] = 0;
+	    if (i > j) {
+		NN[i][j] = NN[j][i];	// matrix is symmetric
+	    else {
+		for (k = 0; k < n; k++) {
+		    NN[i][j] += AA[k][i] * AA[k][j];
+    /* compute n = A'*l (as column sum) */
+	nn[i] = 0;
+	    nn[i] += AA[k][i];
+    /* solve x = N^(-1)*n */
+    singular = G_math_solv(NN, nn, 5);	/* TODO: ensure use of the most effective method from G_math_sol... */
+    /* free memory */
+    G_free_vector(x);
+    G_free_vector(y);
+    G_free_matrix(AA);
+    G_free_matrix(NN);
+    if (singular == -1) {
+	G_free_vector(nn);
+	G_warning(_("Singular matrix failure"));
+	return 0;
+    /* extract parameters of ellipse from conic representation */
+    double a, b, c, d, e, f;
+    double test, tol, cos_phi, sin_phi, x0, y0, sqrta, sqrtb;	/*, sqrta, sqrtb; */
+    tol = 1e-3;
+    /* parameters of conic representation */
+    a = nn[0];
+    b = nn[1];
+    c = nn[2];
+    d = nn[3];
+    e = nn[4];
+    /* f = -1; */
+    /* check if it is an ellipse */
+    test = a * c;
+    if (test == 0) {
+	G_warning(_("Parabola found. Exiting."));
+	return 0;
+    else if (test < 0) {
+	G_warning(_("Hyperbola found. Exiting."));
+	return 0;
+    /* orientation (and its removing for further computing) */
+    if ((abs(b / a) > tol) && (abs(b / c) > tol)) {
+	pars->angle = 0.5 * atan2(b, (c - a));
+	cos_phi = cos(pars->angle);
+	sin_phi = sin(pars->angle);
+	a = a * cos_phi * cos_phi - b * cos_phi * sin_phi +
+	    c * sin_phi * sin_phi;
+	b = 0;
+	c = a * sin_phi * sin_phi - b * cos_phi * sin_phi +
+	    c * cos_phi * cos_phi;
+	d = d * cos_phi - e * sin_phi;
+	e = d * sin_phi + e * cos_phi;
+    else {
+	pars->angle = 0;
+	cos_phi = 1;
+	sin_phi = 0;
+    /* make sure coefficients are positive */
+    if (a < 0) {
+	a *= -1;
+	b *= -1;
+	c *= -1;
+	d *= -1;
+	e *= -1;
+    /* center of non-tilted ellipse */
+    x0 = meanx - d / 2 / a;
+    y0 = meany - e / 2 / c;
+    /* center of tilted ellipse */
+    pars->xc = cos_phi * x0 + sin_phi * y0;
+    pars->yc = cos_phi * y0 - sin_phi * x0;
+    /* semi-axis */
+    f = 1 + d * d / 4 / a + e * e / 4 / c;
+    sqrta = sqrt(f / a);
+    sqrtb = sqrt(f / c);
+    if (sqrta > sqrtb) {
+	pars->a = sqrta;
+	pars->b = sqrtb;
+    else {
+	pars->b = sqrta;
+	pars->a = sqrtb;
+    G_verbose_message("%s: %f*x^2+%f*x*y+%f*y^2+%f*x+%f*y-1=0",
+		      _("conic representation"), a, b, c, d, e);
+    G_verbose_message
+	("parameters of ellipse:\na = %f \nb = %f \nangle = %f \n"
+	 "xc = %f \nyc = %f", pars->a, pars->b, pars->angle, pars->xc,
+	 pars->yc);
+    return 1;
Property changes on: grass-addons/grass7/vector/v.ellipse/ellipse.c
   + text/x-csrc
   + native
Added: grass-addons/grass7/vector/v.ellipse/main.c
--- grass-addons/grass7/vector/v.ellipse/main.c	                        (rev 0)
+++ grass-addons/grass7/vector/v.ellipse/main.c	2015-02-10 22:06:23 UTC (rev 64538)
@@ -0,0 +1,109 @@
+ * MODULE:       v.ellipse
+ * AUTHOR(S):    Tereza Fiedlerova
+ * PURPOSE:      Computes the best-fitting ellipse for
+ *               given vector data
+ * COPYRIGHT:    (C) 2015 by Tereza Fiedlerova, and the GRASS Development Team
+ *               This program is free software under the GNU General
+ *               Public License (>=v2). Read the file COPYING that
+ *               comes with GRASS for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <grass/gis.h>
+#include <grass/dbmi.h>
+#include "proto.h"
+int main(int argc, char *argv[])
+    /* variables */
+    struct Map_info In, Out;
+    static struct line_pnts *Points, *Ellipse;
+    struct line_cats *Cats, *Cats2;
+    struct GModule *module;
+    struct Option *old, *new, *stepopt;
+    struct Parameters *pars;
+    double stepsize;
+    /* initialize GIS environment */
+    G_gisinit(argv[0]);
+    /* initialize module */
+    module = G_define_module();
+    G_add_keyword(_("vector"));
+    G_add_keyword(_("geometry"));
+    G_add_keyword(_("best-fitting ellipse"));
+    module->description =
+	_("Computes the best-fitting ellipse for given vector data.");
+    /* define options */
+    old = G_define_standard_option(G_OPT_V_INPUT);
+    new = G_define_standard_option(G_OPT_V_OUTPUT);
+    stepopt = G_define_option();
+    stepopt->type = TYPE_DOUBLE;
+    stepopt->key = "step";
+    stepopt->description = "Step size in degrees";
+    stepopt->required = NO;
+    stepopt->answer = "4";
+    /* call parser */
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    /* read step size */
+    stepsize = atof(stepopt->answer);	/* conversion to double stepopt->answer */
+    G_debug(1, "step size: %f degrees", stepsize);
+    /* test if input and output are different */
+    Vect_check_input_output_name(old->answer, new->answer, G_FATAL_EXIT);
+    /* open input vector map */
+    Vect_set_open_level(2);
+    if (1 > Vect_open_old(&In, old->answer, ""))
+	G_fatal_error(_("Unable to open vector map <%s> on topological level"),
+		      old->answer);
+    /* open output vector map */
+    if (0 > Vect_open_new(&Out, new->answer, WITHOUT_Z)) {
+	Vect_close(&In);
+	G_fatal_error(_("Unable to create vector map <%s>"), new->answer);
+    Vect_set_error_handler_io(&In, &Out);
+    /* create and initializes structs where to store points, categories */
+    Cats = Vect_new_cats_struct();
+    Cats2 = Vect_new_cats_struct();
+    Points = Vect_new_line_struct();
+    Ellipse = Vect_new_line_struct();
+    pars = (struct Parameters *)G_malloc(sizeof(struct Parameters));
+    int ok;
+    load_points(&In, Points, Cats);
+    ok = fitting_ellipse(Points, pars);
+    G_debug(1, "exit %d", ok);
+    if (ok) {
+	create_ellipse(pars, Ellipse, Cats2, stepsize);
+	write_ellipse(&Out, Ellipse, Cats2);
+    Vect_destroy_line_struct(Points);
+    G_free(pars);
+    exit(EXIT_SUCCESS);
Property changes on: grass-addons/grass7/vector/v.ellipse/main.c
   + text/x-csrc
   + native
Added: grass-addons/grass7/vector/v.ellipse/proto.h
--- grass-addons/grass7/vector/v.ellipse/proto.h	                        (rev 0)
+++ grass-addons/grass7/vector/v.ellipse/proto.h	2015-02-10 22:06:23 UTC (rev 64538)
@@ -0,0 +1,24 @@
+#ifndef __V_ELLIPSE_PROTO__
+#define __V_ELLIPSE_PROTO__
+/* struct with ellipse parameters */
+struct Parameters
+    double a; /* main semi-axis */
+    double b; /* second semi-axis */
+    double xc; /* x of center of ellipse */
+    double yc; /* y of center of ellipse */
+    double angle; /* rotation */
+/* read.c */
+void load_points(struct Map_info *, struct line_pnts *, struct line_cats *);
+/* write.c */
+void write_ellipse(struct Map_info *, struct line_pnts *, struct line_cats *);
+/* ellipse.c */
+void create_ellipse(struct Parameters *, struct line_pnts *, struct line_cats *, double);
+int fitting_ellipse(struct line_pnts *, struct Parameters *);
+#endif
Property changes on: grass-addons/grass7/vector/v.ellipse/proto.h
   + text/x-chdr
   + native
Added: grass-addons/grass7/vector/v.ellipse/read.c
--- grass-addons/grass7/vector/v.ellipse/read.c	                        (rev 0)
+++ grass-addons/grass7/vector/v.ellipse/read.c	2015-02-10 22:06:23 UTC (rev 64538)
@@ -0,0 +1,34 @@
+#include "proto.h"
+void load_points(struct Map_info *In, struct line_pnts *Points,
+		 struct line_cats *Cats)
+    /* variables */
+    struct line_pnts *OPoints;
+    int type, i, cat;
+    OPoints = Vect_new_line_struct();
+    Vect_reset_cats(Cats);
+    /* load points */
+    while ((type = Vect_read_next_line(In, OPoints, Cats)) > 0) {
+	if (type == GV_LINE || type == GV_POINT || type == GV_CENTROID) {
+	    if (Vect_cat_get(Cats, 1, &cat) == 0) {
+		i++;
+	Vect_append_points(Points, OPoints, GV_FORWARD);
+	Vect_reset_line(OPoints);
+    Vect_destroy_line_struct(OPoints);
+    /* close map */
+    Vect_close(In);
Property changes on: grass-addons/grass7/vector/v.ellipse/read.c
   + text/x-csrc
   + native
Added: grass-addons/grass7/vector/v.ellipse/v.ellipse.html
--- grass-addons/grass7/vector/v.ellipse/v.ellipse.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.ellipse/v.ellipse.html	2015-02-10 22:06:23 UTC (rev 64538)
@@ -0,0 +1,45 @@
+<h2>DESCRIPTION</h2>
+<em>v.ellipse</em> computes the best-fitting ellipse for <b>input</b>
+vector map and creates new <b>output</b> vector map with
+ellipse. Input vector data might be 2D points, lines, or areas.
+The parameters of ellipse are printed on output if <b>--verbose</b>
+flag is given.
+<center>
+<img src="v_ellipse.png" border="1"><br>
+<i>Fig: Fitting ellipse created with v.ellipse</i>
+</center>
+<h2>EXAMPLE</h2>
+Example of <em>v.ellipse</em> created around set of points (using data
+<i>points_of_interest</i>, North Carolina sample data set). Ellipse is
+is approximated by linestring with point distance 1 degree
+(<b>step</b>).
+<div class="code"><pre>
+v.ellipse input=points_of_interest output=ellipse step=1
+</pre></div>
+<h2>REFERENCES</h2>
+<ul>
+  <li><a href="https://www.cs.cornell.edu/cv/OtherPdf/Ellipse.pdf">Charles
+  F. Van Loan: Using the Ellipse to Fit and Enclose Data
+  Points.</a></li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.hull.html">v.hull</a>
+</em>
+<h2>AUTHOR</h2>
+Tereza Fiedlerova, OSGeoREL, Czech Technical University in Prague
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/vector/v.ellipse/v.ellipse.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass7/vector/v.ellipse/v_ellipse.png
(Binary files differ)
Property changes on: grass-addons/grass7/vector/v.ellipse/v_ellipse.png
   + image/png
Added: grass-addons/grass7/vector/v.ellipse/write.c
--- grass-addons/grass7/vector/v.ellipse/write.c	                        (rev 0)
+++ grass-addons/grass7/vector/v.ellipse/write.c	2015-02-10 22:06:23 UTC (rev 64538)
@@ -0,0 +1,36 @@
+#include "proto.h"
+void write_ellipse(struct Map_info *Out, struct line_pnts *Ellipse,
+    /* variables */
+    double xc, yc;
+    int i, n;
+    /* write boundary */
+    Vect_write_line(Out, GV_BOUNDARY, Ellipse, Cats);
+    /* write centroid */
+    xc = 0;
+    yc = 0;
+    n = Ellipse->n_points;
+	xc += Ellipse->x[i];
+	yc += Ellipse->y[i];
+    xc /= n;
+    yc /= n;
+    Vect_append_point(Ellipse, xc, yc, 0);
+    Vect_cat_set(Cats, 1, 1);
+    Vect_write_line(Out, GV_CENTROID, Ellipse, Cats);
+    Vect_destroy_line_struct(Ellipse);
+    /* build topology and close map */
+    Vect_build(Out);
+    Vect_close(Out);
Property changes on: grass-addons/grass7/vector/v.ellipse/write.c
   + text/x-csrc
   + native
