[GRASS-SVN] r64542 - grass/trunk/raster/r.ros
svn_grass at osgeo.org
Tue Feb 10 17:51:58 PST 2015
Author: annakrat
Date: 2015-02-10 17:51:58 -0800 (Tue, 10 Feb 2015)
New Revision: 64542
grass/trunk/raster/r.ros/main.c
r.ros: fix label, remove unused variable
Modified: grass/trunk/raster/r.ros/main.c
--- grass/trunk/raster/r.ros/main.c 2015-02-11 01:46:45 UTC (rev 64541)
+++ grass/trunk/raster/r.ros/main.c 2015-02-11 01:51:58 UTC (rev 64542)
@@ -202,7 +202,6 @@
} parm;
/* please, remove before GRASS 7 released */
- struct Flag *flag_s;
struct GModule *module;
/* initialize access to database and create temporary files */
@@ -273,9 +272,9 @@
parm.vel = G_define_standard_option(G_OPT_R_INPUT);
parm.vel->key = "velocity";
parm.vel->required = NO;
+ parm.vel->label =
+ _("Raster map containing midflame wind velocities (ft/min)");
parm.vel->description =
- _("Raster map containing midflame wind velocitys (ft/min)");
- parm.vel->description =
_("Name of an existing raster map layer in the user's "
"current mapset search path containing wind velocities at half of the average "
"flame height (feet/minute).");
@@ -351,7 +350,7 @@
parm.spotdist->label =
_("Output raster map containing maximal spotting distance (m)");
parm.spotdist->description =
- _("The maximal potential spotting distance raster will be also generated"
+ _("The maximal potential spotting distance"
" (requires elevation raster map to be provided).");
/* Parse command line */
