[GRASS-SVN] r64546 - grass/branches/releasebranch_7_0/scripts/v.what.vect
Tue Feb 10 20:41:19 PST 2015
Author: annakrat
Date: 2015-02-10 20:41:18 -0800 (Tue, 10 Feb 2015)
New Revision: 64546
   grass/branches/releasebranch_7_0/scripts/v.what.vect/v.what.vect.py
v.what.vect: fix after renaming v.distance options (merge from trunk, r64545)
Modified: grass/branches/releasebranch_7_0/scripts/v.what.vect/v.what.vect.py
--- grass/branches/releasebranch_7_0/scripts/v.what.vect/v.what.vect.py	2015-02-11 04:40:09 UTC (rev 64545)
+++ grass/branches/releasebranch_7_0/scripts/v.what.vect/v.what.vect.py	2015-02-11 04:41:18 UTC (rev 64546)
@@ -62,13 +62,13 @@
     try:
         grass.run_command('v.distance',
                           from_=options['map'],
-                          to=options['qmap'],
+                          to=options['query_map'],
                           column=options['column'],
-                          to_column=options['qcolumn'],
+                          to_column=options['query_column'],
                           upload='to_attr',
                           dmax=options['dmax'],
                           from_layer=options['layer'],
-                          to_layer=options['qlayer'])
+                          to_layer=options['query_layer'])
     except CalledModuleError:
         return 1
     else:
