[GRASS-SVN] r64557 - grass/trunk/vector/v.generalize
Wed Feb 11 05:31:52 PST 2015
Author: neteler
Date: 2015-02-11 05:31:52 -0800 (Wed, 11 Feb 2015)
New Revision: 64557
   grass/trunk/vector/v.generalize/v.generalize.html
v.generalize manual: fix broken URLs
Modified: grass/trunk/vector/v.generalize/v.generalize.html
--- grass/trunk/vector/v.generalize/v.generalize.html	2015-02-11 12:57:47 UTC (rev 64556)
+++ grass/trunk/vector/v.generalize/v.generalize.html	2015-02-11 13:31:52 UTC (rev 64557)
@@ -51,7 +51,7 @@
 <li> <i>Douglas-Peucker</i> - "Quicksort" of line simplification, the
      most widely used algorithm. Input parameters: <b>input</b>,
      <b>threshold</b>. For more information, see: <br>
-     <a href="http://geometryalgorithms.com/Archive/algorithm_0205/algorithm_0205.htm">http://geometryalgorithms.com/Archive/algorithm_0205/algorithm_0205.htm</a>.</li>
+     <a href="http://geomalgorithms.com/a16-_decimate-1.html">http://geomalgorithms.com/a16-_decimate-1.html</a>.</li>
 <li> <i>Douglas-Peucker Reduction Algorithm</i> is essentially the same
      algorithm as the algorithm above, the difference being that it takes
      an additional <b>reduction</b> parameter which denotes the percentage
@@ -61,7 +61,7 @@
 <li> <i>Lang</i> - Another standard algorithm. Input parameters:
      <b>input</b>, <b>threshold</b>, <b>look_ahead</b>.
      For an excellent description, see:  <br>
-     <a href="http://www.sli.unimelb.edu.au/gisweb/LGmodule/LGLangVisualisation.htm">http://www.sli.unimelb.edu.au/gisweb/LGmodule/LGLangVisualisation.htm</a>.</li>
+     <a href="https://web.archive.org/web/20090823022009/http://www.sli.unimelb.edu.au/gisweb/LGmodule/LGLangVisualisation.htm">http://www.sli.unimelb.edu.au/gisweb/LGmodule/LGLangVisualisation.htm</a>.</li>
 <li> <i>Vertex Reduction</i> - Simplest among the algorithms. Input
      parameters: <b>input</b>, <b>threshold</b>.
      Given a line, this algorithm removes the points of this line which
@@ -69,11 +69,11 @@
      p1 and p2 are two consecutive points, and the distance between p2
      and p1 is less than <b>threshold</b>, it removes p2 and repeats the
      same process on the remaining points.</li>
-<li> <i>Reuman-Witkam</i> - Input parameters: <b>input</b>,
+<li> <i>Reumann-Witkam</i> - Input parameters: <b>input</b>,
      <b>threshold</b>.
      This algorithm quite reasonably preserves the global characteristics
-     of the lines. For more information, see:  <br>
-     <a href="http://www.ifp.uni-stuttgart.de/lehre/vorlesungen/GIS1/Lernmodule/Lg/LG_de_6.html">http://www.ifp.uni-stuttgart.de/lehre/vorlesungen/GIS1/Lernmodule/Lg/LG_de_6.html</a> (german).</li>
+     of the lines. For more information, see for example:<br>
+     <a href="http://psimpl.sourceforge.net/reumann-witkam.html">http://psimpl.sourceforge.net/reumann-witkam.html</a>.</li>
 </ul>
 <i>Douglas-Peucker</i> and <i>Douglas-Peucker Reduction Algorithm</i>
