[GRASS-SVN] r64559 - in grass/trunk/temporal: . t.rast.contour t.rast.contour/testsuite
svn_grass at osgeo.org
Wed Feb 11 05:44:22 PST 2015
Author: huhabla
Date: 2015-02-11 05:44:22 -0800 (Wed, 11 Feb 2015)
New Revision: 64559
Added:
grass/trunk/temporal/t.rast.contour/
grass/trunk/temporal/t.rast.contour/Makefile
grass/trunk/temporal/t.rast.contour/t.rast.contour.html
grass/trunk/temporal/t.rast.contour/t.rast.contour.py
grass/trunk/temporal/t.rast.contour/testsuite/
grass/trunk/temporal/t.rast.contour/testsuite/test_convert.py
grass/trunk/temporal/Makefile
temporal modules: New module that creates a stvds with contours from a strds
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile 2015-02-11 13:31:58 UTC (rev 64558)
+++ grass/trunk/temporal/Makefile 2015-02-11 13:44:22 UTC (rev 64559)
@@ -17,6 +17,7 @@
t.rast.aggregate \
t.rast.aggregate.ds \
t.rast.colors \
+ t.rast.contour \
t.rast.to.rast3 \
t.rast.univar \
t.rast.list \
Added: grass/trunk/temporal/t.rast.contour/Makefile
--- grass/trunk/temporal/t.rast.contour/Makefile (rev 0)
+++ grass/trunk/temporal/t.rast.contour/Makefile 2015-02-11 13:44:22 UTC (rev 64559)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.rast.contour
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/t.rast.contour/t.rast.contour.html
--- grass/trunk/temporal/t.rast.contour/t.rast.contour.html (rev 0)
+++ grass/trunk/temporal/t.rast.contour/t.rast.contour.html 2015-02-11 13:44:22 UTC (rev 64559)
@@ -0,0 +1,43 @@
+<h2>DESCRIPTION</h2>
+<em>t.rast.contour</em> is designed to produce a space time vector dataset of
+specified contours from a space time raster dataset. This module works as a front-end to
+<a href="r.contour.html">r.contour</a> and therefore supports all parameter
+of this module. Hence, all raster map layers in a space time raster dataset
+are successively passed to <a href="r.contour.html">r.contour</a> that computes
+the contour lines.
+Please refer to the <a href="r.contour.html">r.contour</a> documentation
+for a detailed description.
+The new generated vector contour map
+layers will be registered in the output space time vector dataset, using
+the same time stamps as their raster map layer origins.
+<p>
+This module supports the parallel processing of <a href="r.contour.html">r.contour</a>
+module instances. The number of parallel processes
+can be set with the <em>nprocs</em> option.
+However, this will only work in conjunction with the <em>-t</em>
+flag, that avoids the creation of attribute tables.
+The parallel creation of attribute tables is not supported.
+<p>
+The <em>where</em> option allows to select subsets of the input space time raster
+dataset.
+<p>
+The flag <em>-n</em> can be used to force the registration of empty
+vector map layers. Empty vector maps may occur in case that empty
+raster map layers should be converted into vector map layers, or in case the
+chosen steps or contour levels are not present in the raster map layers.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.contour.html">r.contour</a>,
+<a href="t.vect.db.select.html">t.rast.db.select</a>,
+<a href="t.info.html">t.info</a>
+</em>
+<h2>AUTHOR</h2>
+Sören Gebbert, Geoinformatikbüro Dassau
+<p><i>Last changed: $Date: 2014-12-03 20:39:26 +0100 (Mi, 03. Dez 2014) $</i>
Added: grass/trunk/temporal/t.rast.contour/t.rast.contour.py
--- grass/trunk/temporal/t.rast.contour/t.rast.contour.py (rev 0)
+++ grass/trunk/temporal/t.rast.contour/t.rast.contour.py 2015-02-11 13:44:22 UTC (rev 64559)
@@ -0,0 +1,265 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.rast.contour
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Produces a space time vector dataset of specified contours from a space time raster dataset.
+# COPYRIGHT: (C) 2015 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Produces a space time vector dataset of specified contours from a space time raster dataset.
+#% keyword: temporal
+#% keyword: contour
+#% keyword: raster
+#% keyword: vector
+#%end
+#%option G_OPT_STRDS_INPUT
+#%end
+#%option G_OPT_STVDS_OUTPUT
+#%end
+#%option G_OPT_T_WHERE
+#%end
+#%option
+#% key: basename
+#% type: string
+#% label: Basename of the new generated output maps
+#% description: A numerical suffix separated by an underscore will be attached to create a unique identifier
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: step
+#% type: double
+#% description: Increment between contour levels
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: levels
+#% type: double
+#% description: List of contour levels
+#% required: no
+#% multiple: yes
+#%end
+#%option
+#% key: minlevel
+#% type: double
+#% description: Minimum contour level
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: maxlevel
+#% type: double
+#% description: Maximum contour level
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: cut
+#% type: integer
+#% description: Minimum number of points for a contour line (0 -> no limit)
+#% required: no
+#% multiple: no
+#% answer: 0
+#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% description: Number of r.contour processes to run in parallel, more than 1 process works only in conjunction with flag -t
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+#%flag
+#% key: n
+#% description: Register empty vector maps
+#%end
+#%flag
+#% key: t
+#% description: Do not create attribute tables
+#%end
+import sys
+import copy
+import grass.script as gscript
+import grass.temporal as tgis
+import grass.pygrass.modules as pymod
+from grass.exceptions import FatalError
+def main(options, flags):
+ # Get the options
+ input = options["input"]
+ output = options["output"]
+ where = options["where"]
+ base = options["basename"]
+ nprocs = int(options["nprocs"])
+ step = options["step"]
+ levels = options["levels"]
+ minlevel = options["minlevel"]
+ maxlevel = options["maxlevel"]
+ cut = options["cut"]
+ register_null = flags["n"]
+ t_flag = flags["t"]
+ # Make sure the temporal database exists
+ tgis.init()
+ # We need a database interface
+ dbif = tgis.SQLDatabaseInterfaceConnection()
+ dbif.connect()
+ overwrite = gscript.overwrite()
+ sp = tgis.open_old_stds(input, "strds", dbif)
+ maps = sp.get_registered_maps_as_objects(where=where, dbif=dbif)
+ if not maps:
+ dbif.close()
+ gscript.warning(_("Space time raster dataset <%s> is empty") % sp.get_id())
+ return
+ # Check the new stvds
+ new_sp = tgis.check_new_stds(output, "stvds", dbif=dbif,
+ overwrite=overwrite)
+ # Setup the flags
+ flags = ""
+ if t_flag is True:
+ flags += "t"
+ # Configure the r.to.vect module
+ contour_module = pymod.Module("r.contour", input="dummy",
+ output="dummy", run_=False,
+ finish_=False, flags=flags,
+ overwrite=overwrite,
+ quiet=True)
+ if step:
+ contour_module.inputs.step = float(step)
+ if minlevel:
+ contour_module.inputs.minlevel = float(minlevel)
+ if maxlevel:
+ contour_module.inputs.maxlevel = float(maxlevel)
+ if levels:
+ contour_module.inputs.levels = levels.split(",")
+ if cut:
+ contour_module.inputs.cut = int(cut)
+ # The module queue for parallel execution, except if attribute tables should
+ # be created. Then force single process use
+ if t_flag is False:
+ if nprocs > 1:
+ nprocs = 1
+ gscript.warning(_("The number of parellel r.contour processes was "\
+ "reduced to 1 because of the table attribute "\
+ "creation"))
+ process_queue = pymod.ParallelModuleQueue(int(nprocs))
+ count = 0
+ num_maps = len(maps)
+ new_maps = []
+ # run r.to.vect all selected maps
+ for map in maps:
+ count += 1
+ map_name = "%s_%i" % (base, count)
+ new_map = tgis.open_new_map_dataset(map_name, None, type="vector",
+ temporal_extent=map.get_temporal_extent(),
+ overwrite=overwrite, dbif=dbif)
+ new_maps.append(new_map)
+ mod = copy.deepcopy(contour_module)
+ mod(input=map.get_id(), output=new_map.get_id())
+ sys.stderr.write(mod.get_bash() + "\n")
+ process_queue.put(mod)
+ if count%10 == 0:
+ gscript.percent(count, num_maps, 1)
+ # Wait for unfinished processes
+ process_queue.wait()
+ # Open the new space time vector dataset
+ ttype, stype, title, descr = sp.get_initial_values()
+ new_sp = tgis.open_new_stds(output, "stvds", ttype, title,
+ descr, stype, dbif, overwrite)
+ # collect empty maps to remove them
+ num_maps = len(new_maps)
+ empty_maps = []
+ # Register the maps in the database
+ count = 0
+ for map in new_maps:
+ count += 1
+ if count%10 == 0:
+ # Do not register empty maps
+ try:
+ if map.load() is not True:
+ continue
+ except FatalError:
+ continue
+ if map.metadata.get_number_of_primitives() == 0:
+ if not register_null:
+ empty_maps.append(map)
+ continue
+ # Insert map in temporal database
+ map.insert(dbif)
+ new_sp.register_map(map, dbif)
+ # Update the spatio-temporal extent and the metadata table entries
+ new_sp.update_from_registered_maps(dbif)
+ gscript.percent(1, 1, 1)
+ # Remove empty maps
+ if len(empty_maps) > 0:
+ names = ""
+ count = 0
+ for map in empty_maps:
+ if count == 0:
+ count += 1
+ names += "%s" % (map.get_name())
+ else:
+ names += ",%s" % (map.get_name())
+ gscript.run_command("g.remove", flags='f', type='vector', name=names,
+ quiet=True)
+ dbif.close()
+if __name__ == "__main__":
+ options, flags = gscript.parser()
+ main(options, flags)
Property changes on: grass/trunk/temporal/t.rast.contour/t.rast.contour.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/temporal/t.rast.contour/testsuite/test_convert.py
--- grass/trunk/temporal/t.rast.contour/testsuite/test_convert.py (rev 0)
+++ grass/trunk/temporal/t.rast.contour/testsuite/test_convert.py 2015-02-11 13:44:22 UTC (rev 64559)
@@ -0,0 +1,221 @@
+"""Test t.rast.contour
+(C) 2015 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+import subprocess
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+class TestRasterContour(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Initiate the temporal GIS and set the region
+ cls.use_temp_region()
+ cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0, t=50, res=10, res3=10)
+ cls.runModule("r.mapcalc", expression="a_1 = row()", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a_2 = col()", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a_3 = row()", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a_4 = col()", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a_5 = null()", overwrite=True)
+ cls.runModule("t.create", type="strds", temporaltype="absolute",
+ output="A", title="A test", description="A test",
+ overwrite=True)
+ cls.runModule("t.register", flags="i", type="raster", input="A",
+ maps="a_1,a_2,a_3,a_4,a_5", start="2001-01-01",
+ increment="3 months", overwrite=True)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region
+ cls.runModule("t.remove", flags="rf", type="strds",
+ inputs="A")
+ cls.del_temp_region()
+ def tearDown(self):
+ """Remove generated data"""
+ self.runModule("t.remove", flags="rf", type="stvds",
+ inputs="result")
+ def test_register_empty_maps(self):
+ self.assertModule("t.rast.contour", input="A", output="result",
+ levels=(1,2,3,4,5,6,7,8), flags="n",
+ basename="test",
+ nprocs=1, overwrite=True, verbose=True)
+ #self.assertModule("t.info", type="stvds", flags="g", input="result")
+ tinfo_string="""start_time=2001-01-01 00:00:00
+ end_time=2002-04-01 00:00:00
+ granularity=3 months
+ map_time=interval
+ number_of_maps=5
+ lines=28
+ primitives=28
+ nodes=56"""
+ info = SimpleModule("t.info", flags="g", type="stvds", input="result")
+ self.assertModuleKeyValue(module=info, reference=tinfo_string, precision=2, sep="=")
+ def test_simple(self):
+ """Do not register empty maps"""
+ basename="test",
+ end_time=2002-01-01 00:00:00
+ map_time=interval
+ number_of_maps=4
+ lines=28
+ primitives=28
+ nodes=56"""
+ def test_where(self):
+ """Use where statement and do not register empty maps"""
+ basename="test",
+ where="start_time > '2001-02-01'",
+ tinfo_string="""start_time=2001-04-01 00:00:00
+ map_time=interval
+ number_of_maps=3
+ lines=21
+ primitives=21
+ nodes=42"""
+ def test_parallel(self):
+ """Run 4 contour processes do not create attribute tables"""
+ basename="test", flags="t",
+ nprocs=4, overwrite=True, verbose=True)
+ map_time=interval
+ number_of_maps=4
+ lines=28
+ primitives=28
+ nodes=56"""
+ def test_parallel_cut(self):
+ levels=(1,2,3,4,5,6,7,8), cut=2,
+ map_time=interval
+ number_of_maps=4
+ lines=28
+ primitives=28
+ nodes=56"""
+ def test_where_step(self):
+ step=1, minlevel=1, maxlevel=8,
+ basename="test",
+ map_time=interval
+ number_of_maps=3
+ lines=21
+ primitives=21
+ nodes=42"""
+class TestRasterContourFails(TestCase):
+ @classmethod
+ cls.runModule("r.mapcalc", expression="a_1 = 100", overwrite=True)
+ overwrite=True)
+ maps="a_1", start="2001-01-01",
+ @classmethod
+ inputs="A")
+ def test_error_handling(self):
+ # No basename
+ self.assertModuleFail("t.rast.contour", input="A", output="result",
+ def test_empty_strds(self):
+ """Test for empty strds"""
+ basename="test",
+ where="start_time > '2010-01-01'",
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
