[GRASS-SVN] r64566 - in grass/branches/releasebranch_7_0/gui/wxpython: mapdisp nviz
Wed Feb 11 08:59:50 PST 2015
Author: annakrat
Date: 2015-02-11 08:59:50 -0800 (Wed, 11 Feb 2015)
New Revision: 64566
   grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py
   grass/branches/releasebranch_7_0/gui/wxpython/nviz/tools.py
wxGUI/nviz: revert r64473 because it causes problems on Mac (merge from trunk, r64565)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py	2015-02-11 16:58:42 UTC (rev 64565)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py	2015-02-11 16:59:50 UTC (rev 64566)
@@ -102,7 +102,6 @@
         # Emitted when starting (switching to) 3D mode.
         # Parameter firstTime specifies if 3D was already actived.
         self.starting3dMode = Signal("MapFrame.starting3dMode")
-        self.starting3dModeSetInitialMaps = Signal("MapFrame.starting3dMode")
         # Emitted when ending (switching from) 3D mode.
         self.ending3dMode = Signal("MapFrame.ending3dMode")
@@ -383,7 +382,6 @@
             self.MapWindow3D.overlayActivated.connect(self._activateOverlay)
             self.MapWindow3D.overlayHidden.connect(self._hideOverlay)
             self.legend.overlayChanged.connect(self.MapWindow3D.UpdateOverlays)
-            self.starting3dModeSetInitialMaps.emit()
         else:
             self._switchMapWindow(self.MapWindow3D)
             os.environ['GRASS_REGION'] = self.Map.SetRegion(windres = True, windres3 = True)
@@ -398,9 +396,6 @@
             self.starting3dMode.emit(firstTime=False)
             self.MapWindow3D.ResetViewHistory()
-            # explicitly load layers so that we can call SetInitialMaps after that
-            self.MapWindow3D.LoadDataLayers()
         self._giface.updateMap.disconnect(self.MapWindow2D.UpdateMap)
         self._giface.updateMap.connect(self.MapWindow3D.UpdateMap)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/nviz/tools.py
--- grass/branches/releasebranch_7_0/gui/wxpython/nviz/tools.py	2015-02-11 16:58:42 UTC (rev 64565)
+++ grass/branches/releasebranch_7_0/gui/wxpython/nviz/tools.py	2015-02-11 16:59:50 UTC (rev 64566)
@@ -114,7 +114,6 @@
         # bindings
         self.Bind(wx.EVT_NOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
         self.Bind(wx.EVT_SIZE, self.OnSize)
-        self.mapDisplay.starting3dModeSetInitialMaps.connect(self.SetInitialMaps)
         self.mapWindow.GetAnimation().animationFinished.connect(self.OnAnimationFinished)
         self.mapWindow.GetAnimation().animationUpdateIndex.connect(self.OnAnimationUpdateIndex)
@@ -125,6 +124,7 @@
         wx.CallAfter(self.SetPage, 'view')
         wx.CallAfter(self.UpdateScrolling, (self.foldpanelData, self.foldpanelAppear,
                                             self.foldpanelAnalysis))
+        wx.CallAfter(self.SetInitialMaps)
     def SetInitialMaps(self):
         """Set initial raster and vector map"""
