[GRASS-SVN] r64571 - in grass/trunk/gui/wxpython: . gui_core
svn_grass at osgeo.org
Wed Feb 11 19:12:39 PST 2015
Author: annakrat
Date: 2015-02-11 19:12:39 -0800 (Wed, 11 Feb 2015)
New Revision: 64571
grass/trunk/gui/wxpython/gis_set.py
grass/trunk/gui/wxpython/gui_core/widgets.py
wxGUI/start up: use normal StaticText instead of StaticTextWrap for error message since it causes emitting events continually on wxPython 3
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2015-02-12 02:33:56 UTC (rev 64570)
+++ grass/trunk/gui/wxpython/gis_set.py 2015-02-12 03:12:39 UTC (rev 64571)
@@ -110,18 +110,7 @@
self.mapset_box = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
label=" %s " % _("3. Select GRASS Mapset"))
- # no message at the beginning but a dummy text is needed to do
- # the layout right (the lenght should be similar to maximal message)
- self.lmessage = StaticWrapText(
- parent=self.panel, id=wx.ID_ANY,
- label=("This is a placeholer text to workaround layout issues."
- " Without this (long) text the widgets will not align"
- " when a message is shown."
- " This text is not translatable and users should never"
- " see it because it will be replaced by nothing or a real"
- " message after initial checks. If you are an user"
- " and you see this text, it is probably some minor issue."
- " Please, contact GRASS developers to tell them about it."))
+ self.lmessage = wx.StaticText(parent=self.panel)
# It is not clear if all wx versions supports color, so try-except.
# The color itself may not be correct for all platforms/system settings
# but in http://xoomer.virgilio.it/infinity77/wxPython/Widgets/wx.SystemSettings.html
@@ -199,14 +188,14 @@
# Locations
self.lblocations = GListBox(parent = self.location_panel,
- id=wx.ID_ANY, size=(180, 120),
+ id=wx.ID_ANY, size=(180, 200),
choices = self.listOfLocations)
self.lblocations.SetColumnWidth(0, 180)
# TODO: sort; but keep PERMANENT on top of list
# Mapsets
self.lbmapsets = GListBox(parent = self.mapset_panel,
choices = self.listOfMapsets)
self.lbmapsets.SetColumnWidth(0, 180)
@@ -423,7 +412,7 @@
sizer.Add(item=self.lmessage,
proportion=0,
flag=wx.ALIGN_CENTER_VERTICAL |
- wx.ALIGN_LEFT | wx.ALL | wx.EXPAND, border=8)
+ wx.ALIGN_LEFT | wx.ALL | wx.EXPAND, border=5)
sizer.Add(item=location_mapset_sizer, proportion=1,
flag = wx.RIGHT | wx.LEFT | wx.EXPAND,
border = 1)
@@ -472,6 +461,7 @@
you know that there is everything correct now.
self.lmessage.SetLabel(text)
+ self.lmessage.Wrap(self.GetClientSize()[0])
self.sizer.Layout()
def _showError(self, text):
@@ -485,6 +475,7 @@
self.lmessage.SetLabel(_("Error: {text}").format(text=text))
self.sizer.Layout()
def _hideMessage(self):
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py 2015-02-12 02:33:56 UTC (rev 64570)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py 2015-02-12 03:12:39 UTC (rev 64571)
@@ -466,7 +466,69 @@
dc.DrawRectangle(0, 0, 2 * size[0] / 5, size[1])
dc.DrawRectangle(3 * size[0] / 5, 0, 2 * size[0] / 5, size[1])
+class AutoWrapStaticText(GenStaticText):
+ def __init__(self, parent, label):
+ GenStaticText.__init__(self, parent, -1, label)
+ self._label = label
+ self.init = False
+ self.Bind(wx.EVT_SIZE, self.OnSize)
+ def OnSize(self, event):
+ self.Wrap(event.GetSize()[0])
+ event.Skip()
+ def DoGetBestSize(self):
+ """Overriden method which reports widget's best size."""
+ print 'do get best size'
+# if not self.init:
+# self._updateLabel()
+# self.init = True
+ parent = self.GetParent()
+ newExtent = wx.ClientDC(parent).GetMultiLineTextExtent(self.GetLabel())
+ # when starting, width is very small and height is big which creates very high windows
+ if newExtent[0] < newExtent[1]:
+ return (0, 0)
+ return newExtent[:2]
+ def Wrap(self, width):
+ if width < 0:
+ return
+ dc = wx.ClientDC(self)
+ dc.SetFont(self.GetFont())
+ text = wordwrap(self._label, width, dc)
+ GenStaticText.SetLabel(self, text)
+ def SetLabel(self, label, wrapped=False):
+ if not wrapped:
+ self.Wrap(self.GetSize()[0])
+class StaticWrapText2(wx.PyControl):
+ def __init__(self, parent, id=wx.ID_ANY, label='', pos=wx.DefaultPosition,
+ size=wx.DefaultSize, style=wx.NO_BORDER,
+ validator=wx.DefaultValidator, name='StaticWrapText'):
+ wx.PyControl.__init__(self, parent, id, pos, size, style, validator, name)
+ self.statictext = wx.StaticText(self, wx.ID_ANY, label, style=style)
+ self.wraplabel = label
+ #self.wrap()
+ def wrap(self):
+ self.statictext.SetLabel(self.wraplabel)
+ self.statictext.Wrap(self.GetParent().GetSize().width)#self.statictext.Wrap(self.GetSize().width)
+ self.wrap()
+ #print self.statictext.GetSize()
+ self.SetSize(self.statictext.GetSize())
+ return self.GetSize()
+ def SetLabel(self, label):
+ self.wrap()
class StaticWrapText(GenStaticText):
"""A Static Text widget that wraps its text to fit parents width,
enlarging its height if necessary."""
@@ -492,7 +554,8 @@
self._updateLabel()
- event.Skip()
+ print event.GetSize()
+ #event.Skip()
def _updateLabel(self):
"""Calculates size of wrapped label"""
@@ -500,11 +563,15 @@
newLabel = wordwrap(text=self._initialLabel, width=parent.GetSize()[0],
dc=wx.ClientDC(parent), breakLongWords=True,
margin=self._margin)
+ print parent.GetSize()[0], newLabel
+ print self.Unbind(wx.EVT_SIZE)
GenStaticText.SetLabel(self, newLabel)
self._initialLabel = label
self._updateLabel()
+ print 'setlabel'
class BaseValidator(wx.PyValidator):
