[GRASS-SVN] r64573 - grass/trunk/gui/wxpython/xml
Wed Feb 11 22:28:00 PST 2015
Author: martinl
Date: 2015-02-11 22:28:00 -0800 (Wed, 11 Feb 2015)
New Revision: 64573
   grass/trunk/gui/wxpython/xml/toolboxes.xml
wxGUI: remove non-existing modules from menu
       (v.convert, v.convert.all, v.in.gps, v.in.gns)
Modified: grass/trunk/gui/wxpython/xml/toolboxes.xml
--- grass/trunk/gui/wxpython/xml/toolboxes.xml	2015-02-12 03:17:54 UTC (rev 64572)
+++ grass/trunk/gui/wxpython/xml/toolboxes.xml	2015-02-12 06:28:00 UTC (rev 64573)
@@ -305,12 +305,6 @@
       <module-item name="v.in.lines">
         <label>ASCII points as a vector lines</label>
       </module-item>
-      <module-item name="v.convert">
-        <label>Historical GRASS vector import</label>
-      </module-item>
-      <module-item name="v.convert.all">
-        <label>Historical GRASS vector import (all maps)</label>
-      </module-item>
       <separator/>
       <wxgui-item name="DXFImport"/>
       <separator/>
@@ -321,15 +315,9 @@
       <module-item name="v.in.e00">
         <label>ESRI e00 import</label>
       </module-item>
-      <module-item name="v.in.gps">
-        <label>GPS data import</label>
-      </module-item>
       <module-item name="v.in.geonames">
         <label>Geonames import</label>
       </module-item>
-      <module-item name="v.in.gns">
-        <label>GEOnet import</label>
-      </module-item>
       <module-item name="v.in.mapgen">
         <label>Matlab array or Mapgen format import</label>
       </module-item>
