[GRASS-SVN] r64585 - grass/trunk
svn_grass at osgeo.org
Thu Feb 12 09:31:55 PST 2015
Author: neteler
Date: 2015-02-12 09:31:55 -0800 (Thu, 12 Feb 2015)
New Revision: 64585
grass/trunk/CHANGES
Update CHANGES file content to a GRASS GIS 7 summary
Modified: grass/trunk/CHANGES
--- grass/trunk/CHANGES 2015-02-12 14:27:21 UTC (rev 64584)
+++ grass/trunk/CHANGES 2015-02-12 17:31:55 UTC (rev 64585)
@@ -1,58 +1,21 @@
-CHANGES IN GRASS 6 compared to GRASS 5
+CHANGES IN GRASS GIS 7 compared to GRASS GIS 6
- * New Vector Engine (geometry):
- o Support for 2D/3D vectors (see screenshot) (CAD drawings,
- TINs), visualization supported in NVIZ
- o multiformat - also virtual map supported from external
- data sources (SHAPE-file, PostGIS) without the need of data
- conversion (through OGR library with 'v.external');
- Export/Import to PostGIS;
- o spatial index build on the fly - 'v.build' (was:
- v.support) significantly accelerated;
- o category index to accelerate attribute queries;
+The graphical user interface based on wxPython (introduced in GRASS GIS
+6.4) has been enriched with many new features in order to make complex
+GIS operations available as simple as possible. The old Tcl/Tk based
+GUI has been dropped. Relevant new features are available in the core
+system, among the most important the new Python interface to the C
+library. This new feature permits Python developers to create new
+modules in a simple way while at the same time creating powerful and
+fast modules. Furthermore, the vector library was particularly improved
+to make it faster and more efficient with support of huge files. This
+required a easy to manage topology format update including a new
+spatial index. Finally, there are a series of new modules to analyse
+raster and vector data; some of the already existing modules were
+improved and made faster (some even 1000 x faster).
- * Database Management Interface (attributes):
- o Attribute storage in DBMS for compatibility with industry
- standards (SQL based interface for PostgreSQL, mySQL, ODBC, dBase)
- o multiattribute - attributes saved in dBase files (default)
- or saved in external DBMS
- o multilayer - features in one vector may represent one or
- several layers and may be linked to one or many external
- tables
- o forms library implemented for user friendly query dialogs
- o Linear reference systems supported (LRS, yet to integrate)
+In total, more than 10,000 changes have been implemented so far with
+respect to GRASS GIS 6.4.
- * Applications/Misc:
- o SQL queries/selects/extractions supported by vector modules
- o interactive attributes updating is supported through the
- forms library (d.what.vect lets you modify directly the
- attached attributes)
- o Vector network analysis: Shortest path, Traveling salesman
- (round trip), Allocation of sources (subnetworks), Minimum
- Steiner trees (starlike connections), and isodistances (from
- centers) (e.g. shortest path, see screenshot) - based on
- DGLIB (Directed Graph Library), costs may be assigned both
- to nodes and arcs (and also different in both directions of
- a vector line)
- o new v.digit with GUI (screenshot)
- o import and export of any OGR supported vector format
- (Shapefile, TIGER, MapInfo and GML2, PostGIS and DGN)
- o GUI generated on runtime and display manager (screenshots)
- o i18n: support for multiple languages (messages partially
- indicated and translated)
- o multiple GRASS sessions: a user can start more than one session at the time
- * Interoperability
- o Raster and vector data interoperability is granted through
- the GDAL/OGR libraries which implement interfaces to OGC
- standards and common GIS data formats
- * Volume visualization
- o NVIZ now supports volume (voxel) visualization
- o VTK export
- * Large File Support for raster maps (Experimental!)
- o GRASS 6.0 experimentally supports reading and writing
- large files (> 2GB, LFS support)
- * Programmer's manual integrated into source code (doxygen)
+For details, please refer to this Web page:
+http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
