[GRASS-SVN] r64590 - grass-addons/grass7/raster/r.mess
svn_grass at osgeo.org
Thu Feb 12 11:15:48 PST 2015
Author: pvanbosgeo
Date: 2015-02-12 11:15:48 -0800 (Thu, 12 Feb 2015)
New Revision: 64590
grass-addons/grass7/raster/r.mess/r.mess.html
grass-addons/grass7/raster/r.mess/r.mess.py
corrections
Modified: grass-addons/grass7/raster/r.mess/r.mess.html
--- grass-addons/grass7/raster/r.mess/r.mess.html 2015-02-12 19:07:17 UTC (rev 64589)
+++ grass-addons/grass7/raster/r.mess/r.mess.html 2015-02-12 19:15:48 UTC (rev 64590)
@@ -1,7 +1,7 @@
<h2>DESCRIPTION</h2>
<p>The Multivariate Environmental Similarity (MES) surfaces was
-proposed by Elith et al (2010) and originally implemented in the
+proposed by Elith et al (2010) [1] and originally implemented in the
Maxent software. They described the MES approach as: "The
multivariate environmental similarity surface (MESS) calculation
represents how similar a point is to a reference set of points, with
@@ -19,7 +19,8 @@
<ul>
<li>the area where for at least one of the variables has a value that falls outside the range of values found in the reference set</li>
<li>the most dissimilar variable (MoD)</li>
- <li>the sum of the IES layers where IES < 0</li>
+ <li>the sum of the IES layers where IES < 0. This is similar to the
+ NT1 measure as proposed by Mesgaran et al. 2014 [2]</li>
<li>the number of layers with negative values</li>
</ul>
@@ -41,12 +42,16 @@
area you want to compare to (env_new). Make sure the region
(g.region) is set to the reference layer / env_old.
-<h2>REFERENCES</h2>
-<p>Elith, J., Kearney, M., & Phillips, S.
+<h2>REFERENCES</h2>
+<p>[1] Elith, J., Kearney, M., & Phillips, S.
2010. The art of modelling range-shifting species. Methods in
Ecology and Evolution 1:330-342.
+<p>[2] Mesgaran, M.B., Cousens, R.D. & Webber, B.L. (2014) Here be
+dragons: a tool for quantifying novelty due to covariate range and
+correlation change when projecting species distribution models.
+Diversity & Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.
<h2>AUTHOR</h2>
Paulo van Breugel, paulo at ecodiv.org
Modified: grass-addons/grass7/raster/r.mess/r.mess.py
--- grass-addons/grass7/raster/r.mess/r.mess.py 2015-02-12 19:07:17 UTC (rev 64589)
+++ grass-addons/grass7/raster/r.mess/r.mess.py 2015-02-12 19:15:48 UTC (rev 64590)
@@ -115,6 +115,12 @@
#% guisection: Output
#%end
+##%flag
+##% key: b
+##% description: Only compute MESS for areas with novel conditions (faster)
+##% guisection: Output
+##%end
#%flag: IES
#% key: i
#% description: Remove individual environmental similarity layers (IES)
@@ -223,6 +229,7 @@
fli = flags['i']
flr = flags['r']
fll = flags['c']
+ #flb = flags['b']
# digits / precision
digits = int(options['digits'])
