[GRASS-SVN] r64600 - grass/branches/releasebranch_7_0/raster/r.ros
svn_grass at osgeo.org
Thu Feb 12 19:10:26 PST 2015
Author: annakrat
Date: 2015-02-12 19:10:26 -0800 (Thu, 12 Feb 2015)
New Revision: 64600
grass/branches/releasebranch_7_0/raster/r.ros/main.c
r.ros: remove unnecessary checks which caused crash when using spotting, fix label, remove unused variable (merge from trunk, r64541, r64542)
Modified: grass/branches/releasebranch_7_0/raster/r.ros/main.c
--- grass/branches/releasebranch_7_0/raster/r.ros/main.c 2015-02-13 03:07:07 UTC (rev 64599)
+++ grass/branches/releasebranch_7_0/raster/r.ros/main.c 2015-02-13 03:10:26 UTC (rev 64600)
@@ -202,7 +202,6 @@
} parm;
/* please, remove before GRASS 7 released */
- struct Flag *flag_s;
struct GModule *module;
/* initialize access to database and create temporary files */
@@ -273,9 +272,9 @@
parm.vel = G_define_standard_option(G_OPT_R_INPUT);
parm.vel->key = "velocity";
parm.vel->required = NO;
+ parm.vel->label =
+ _("Raster map containing midflame wind velocities (ft/min)");
parm.vel->description =
- _("Raster map containing midflame wind velocitys (ft/min)");
- parm.vel->description =
_("Name of an existing raster map layer in the user's "
"current mapset search path containing wind velocities at half of the average "
"flame height (feet/minute).");
@@ -351,7 +350,7 @@
parm.spotdist->label =
_("Output raster map containing maximal spotting distance (m)");
parm.spotdist->description =
- _("The maximal potential spotting distance raster will be also generated"
+ _("The maximal potential spotting distance"
" (requires elevation raster map to be provided).");
/* Parse command line */
@@ -449,27 +448,9 @@
name_max = parm.max->answer;
name_maxdir = parm.maxdir->answer;
- /*check if the output layer names EXIST */
- if (G_check_overwrite(argc, argv) == 0) {
- if (G_find_raster2(name_base, G_mapset()))
- G_fatal_error(_("Raster map <%s> already exists in mapset <%s>"),
- name_base, G_mapset());
- if (G_find_raster2(name_max, G_mapset()))
- name_max, G_mapset());
- if (G_find_raster2(name_maxdir, G_mapset()))
- name_maxdir, G_mapset());
- /*assign a name to output SPOTTING distance layer */
- if (spotting) {
- name_spotdist = parm.spotdist->answer;
- if (G_find_raster2(name_spotdist, G_mapset()))
- name_spotdist, G_mapset());
+ /*assign a name to output SPOTTING distance layer */
+ if (spotting) {
+ name_spotdist = parm.spotdist->answer;
/* Get database window parameters */
