[GRASS-SVN] r64604 - grass/branches/releasebranch_7_0/vector/v.support
svn_grass at osgeo.org
Fri Feb 13 05:37:51 PST 2015
Author: annakrat
Date: 2015-02-13 05:37:51 -0800 (Fri, 13 Feb 2015)
New Revision: 64604
grass/branches/releasebranch_7_0/vector/v.support/main.c
v.support: open vector on level 1, not 2, related to #2588 (merge from trunk, r64603)
Modified: grass/branches/releasebranch_7_0/vector/v.support/main.c
--- grass/branches/releasebranch_7_0/vector/v.support/main.c 2015-02-13 13:35:53 UTC (rev 64603)
+++ grass/branches/releasebranch_7_0/vector/v.support/main.c 2015-02-13 13:37:51 UTC (rev 64604)
@@ -125,7 +125,7 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- Vect_set_open_level(2);
+ Vect_set_open_level(1);
if (Vect_open_old(&Map, map->answer, "") < 1)
G_fatal_error(_("Unable to open vector map <%s>"), map->answer);
