[GRASS-SVN] r64627 - in grass/trunk/gui/wxpython: core mapwin
Sat Feb 14 09:19:27 PST 2015
Author: martinl
Date: 2015-02-14 09:19:27 -0800 (Sat, 14 Feb 2015)
New Revision: 64627
   grass/trunk/gui/wxpython/core/render.py
   grass/trunk/gui/wxpython/mapwin/buffered.py
wxGUI: debug message showing rendering speed fixed and moved to Map.Render()
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py	2015-02-14 14:35:04 UTC (rev 64626)
+++ grass/trunk/gui/wxpython/core/render.py	2015-02-14 17:19:27 UTC (rev 64627)
@@ -34,6 +34,7 @@
 import copy
 import tempfile
 import types
+import time
 import wx
@@ -947,7 +948,8 @@
             env['GRASS_RENDER_IMMEDIATE'] = 'png'
         else:
             env['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+        start = time.time()
         maps, masks, opacities = self.GetMapsMasksAndOpacities(force, windres, env)
         # ugly hack for MSYS
@@ -967,7 +969,7 @@
         # run g.pngcomp to get composite image
         bgcolor = ':'.join(map(str, UserSettings.Get(group = 'display', key = 'bgcolor',
                                                      subkey = 'color')))
+        startComp = time.time()
         if maps:
             ret, msg = RunCommand('g.pnmcomp',
                                   getErrorMsg = True,
@@ -986,8 +988,10 @@
                 wx.EndBusyCursor()
                 return None
-        Debug.msg (3, "Map.Render() force=%s file=%s" % (force, self.mapfile))
+        stop = time.time()
+        Debug.msg (1, "Map.Render() force=%s -> time=%f (comp: %f)" % \
+                   (force, stop - start, stop - startComp))
         wx.EndBusyCursor()
         if not maps:
             return None
Modified: grass/trunk/gui/wxpython/mapwin/buffered.py
--- grass/trunk/gui/wxpython/mapwin/buffered.py	2015-02-14 14:35:04 UTC (rev 64626)
+++ grass/trunk/gui/wxpython/mapwin/buffered.py	2015-02-14 17:19:27 UTC (rev 64627)
@@ -808,7 +808,6 @@
         :func:`UpdateMap` for arguments description.
-        start = time.clock()
         self.resize = False
         # was if self.Map.cmdfile and ...
@@ -913,12 +912,10 @@
         if len(self.polycoords) > 0:
             self.DrawLines(self.pdcTmp)
-        stop = time.clock()
-        Debug.msg (1, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
-                   (render, renderVector, (stop-start)))
+        Debug.msg (1, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s" % \
+                   (render, renderVector))
         return True
     def DrawCompRegionExtent(self):
