[GRASS-SVN] r64631 - in grass/trunk: general/g.filename general/g.findetc general/g.region imagery/i.gensigset scripts/v.out.gps
svn_grass at osgeo.org
Sat Feb 14 13:07:18 PST 2015
Author: neteler
Date: 2015-02-14 13:07:18 -0800 (Sat, 14 Feb 2015)
New Revision: 64631
grass/trunk/general/g.filename/g.filename.html
grass/trunk/general/g.findetc/g.findetc.html
grass/trunk/general/g.region/g.region.html
grass/trunk/imagery/i.gensigset/i.gensigset.html
grass/trunk/scripts/v.out.gps/v.out.gps.html
manual: fix broken links
Modified: grass/trunk/general/g.filename/g.filename.html
--- grass/trunk/general/g.filename/g.filename.html 2015-02-14 17:39:54 UTC (rev 64630)
+++ grass/trunk/general/g.filename/g.filename.html 2015-02-14 21:07:18 UTC (rev 64631)
@@ -77,7 +77,6 @@
<h2>SEE ALSO</h2>
<em>
-<a href="g.ask.html">g.ask</a>,
<a href="g.findfile.html">g.findfile</a>,
<a href="g.gisenv.html">g.gisenv</a>
</em>
Modified: grass/trunk/general/g.findetc/g.findetc.html
--- grass/trunk/general/g.findetc/g.findetc.html 2015-02-14 17:39:54 UTC (rev 64630)
+++ grass/trunk/general/g.findetc/g.findetc.html 2015-02-14 21:07:18 UTC (rev 64631)
@@ -13,7 +13,6 @@
<h2>SEE ALSO</h2>
<em>
<a href="g.filename.html">g.filename</a>,
<a href="g.gisenv.html">g.gisenv</a>,
Modified: grass/trunk/general/g.region/g.region.html
--- grass/trunk/general/g.region/g.region.html 2015-02-14 17:39:54 UTC (rev 64630)
+++ grass/trunk/general/g.region/g.region.html 2015-02-14 21:07:18 UTC (rev 64631)
@@ -450,8 +450,8 @@
<em>
<a href="g.access.html">g.access</a>,
<a href="g.mapsets.html">g.mapsets</a>,
-<a href="g.proj.html">g.proj</a>,
-<a href="g.setproj.html">g.setproj</a><br>
+<a href="g.proj.html">g.proj</a>
+<br>
Environment variables: <a href="variables.html#internal">GRASS_REGION and WIND_OVERRIDE</a>
</em>
Modified: grass/trunk/imagery/i.gensigset/i.gensigset.html
--- grass/trunk/imagery/i.gensigset/i.gensigset.html 2015-02-14 17:39:54 UTC (rev 64630)
+++ grass/trunk/imagery/i.gensigset/i.gensigset.html 2015-02-14 21:07:18 UTC (rev 64631)
@@ -42,7 +42,7 @@
and
<em><a href="v.to.rast.html">v.to.rast</a></em>,
or some other import/developement process (e.g.,
-<em><a href="v.in.transects.html">v.in.transects</a>)</em>
+<em><a href="v.transects.html">v.transects</a>)</em>
to define the areas representative of the classes in the image.
<p>
Modified: grass/trunk/scripts/v.out.gps/v.out.gps.html
--- grass/trunk/scripts/v.out.gps/v.out.gps.html 2015-02-14 17:39:54 UTC (rev 64630)
+++ grass/trunk/scripts/v.out.gps/v.out.gps.html 2015-02-14 21:07:18 UTC (rev 64631)
@@ -78,17 +78,13 @@
<h2>SEE ALSO</h2>
<em>
-<a href="m.proj.html">m.proj</a><br>
-<a href="v.in.ascii.html">v.in.ascii</a><br>
-<a href="v.out.ascii.html">v.out.ascii</a><br>
-<a href="v.in.garmin.html">v.in.garmin</a><br>
-<a href="v.in.gpsbabel.html">v.in.gpsbabel</a><br>
-<a href="v.db.renamecolumn.html">v.db.renamecolumn</a><br>
+<a href="m.proj.html">m.proj</a>,
+<a href="v.in.ascii.html">v.in.ascii</a>,
+<a href="v.out.ascii.html">v.out.ascii</a>,
+<a href="v.db.renamecolumn.html">v.db.renamecolumn</a>,
<a href="v.extract.html">v.extract</a>
</em>
-<br>
-<br>
+<p>
<a href="http://www.gpsbabel.org">GpsBabel.org</a><br>
The <a href="http://www.gdal.org/ogr/drv_gpx.html">GDAL/OGR GPX format page</a><br>
cs2cs from <a href="http://proj.osgeo.org">PROJ.4</a><br>
