[GRASS-SVN] r64638 - in grass/trunk/general/g.rename: . testsuite
Sat Feb 14 22:09:35 PST 2015
Author: wenzeslaus
Date: 2015-02-14 22:09:35 -0800 (Sat, 14 Feb 2015)
New Revision: 64638
Added:
   grass/trunk/general/g.rename/testsuite/
   grass/trunk/general/g.rename/testsuite/test_overwrite.py
g.rename: test for raster rename with and without overwrite
Commands r.mapcalc 'a1 = 1' && r.mapcalc 'a2 = 2' && g.rename rast=a1,a2; give 'WARNING: <a2> already exists in mapset <practice2>', not an ERROR and process ends with 0 but nothing was renamed.
Added: grass/trunk/general/g.rename/testsuite/test_overwrite.py
--- grass/trunk/general/g.rename/testsuite/test_overwrite.py	                        (rev 0)
+++ grass/trunk/general/g.rename/testsuite/test_overwrite.py	2015-02-15 06:09:35 UTC (rev 64638)
@@ -0,0 +1,119 @@
+"""g.remove tests
+(C) 2013 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:author: Vaclav Petras
+import grass.gunittest
+from grass.gunittest.gmodules import SimpleModule
+from grass.gunittest.gutils import is_map_in_mapset
+from grass.gunittest.checkers import (text_to_keyvalue, keyvalue_equals,
+                                      diff_keyvalue)
+class RasterRenameTestCase(grass.gunittest.TestCase):
+    """Test wrong input of parameters for g.list module"""
+    def setUp(self):
+        """Create maps in a small region.
+        The raster exists must be renewed for every test.
+        self.use_temp_region()
+        self.runModule("g.region", s=0, n=5, w=0, e=5, res=1)
+        self.runModule("r.mapcalc", expression="rename_1 = 1")
+        self.runModule("r.mapcalc", expression="rename_2 = 20")
+        self.runModule("r.mapcalc", expression="rename_3 = 300")
+        self.runModule("r.mapcalc", expression="exists = 50000")
+        self.to_remove = ['rename_1', 'rename_2', 'rename_3', 'exists']
+    def tearDown(self):
+        """Remove temporary region and renamed maps (and also old if needed)"""
+        self.runModule('g.remove', name=self.to_remove, type=['raster'], flags='f')
+        self.del_temp_region()
+    def test_raster(self):
+        """Test that raster rename works"""
+        module = SimpleModule('g.rename', raster=['rename_1', 'renamed_1'])
+        self.assertModule(module)
+        new_names = ['renamed_1']
+        self.to_remove.extend(new_names)
+        for name in new_names:
+            self.assertRasterExists(name)
+    def test_preserve_existing_raster(self):
+        """Test that existing raster is preserved"""
+        # TODO: write the same for other types
+        # TODO: create a general functions to avoid duplication
+        runivar = SimpleModule('r.univar', flags='g', map='exists')
+        self.runModule(runivar, expecting_stdout=True)
+        original_runivar = text_to_keyvalue(runivar.outputs.stdout,
+                                            sep='=', skip_empty=True)
+        module = SimpleModule('g.rename', raster=['rename_3', 'exists'], overwrite=False)
+        self.assertRasterExists('exists', msg="Destination (existing) map (to) should exist")
+        self.assertRasterExists('rename_3', msg="Source map (from) should exist")
+        new_runivar = text_to_keyvalue(runivar.outputs.stdout,
+        if not keyvalue_equals(dict_a=original_runivar, dict_b=new_runivar,
+                               precision=1e-7):
+            unused, missing, mismatch = diff_keyvalue(dict_a=original_runivar,
+                                                      dict_b=new_runivar,
+                                                      precision=1e-7)
+            if mismatch:
+                msg = "Raster map changed. It was probably overwritten.\n"
+                msg += "Difference between r.univar of maps:\n"
+                msg += "mismatch values"
+                msg += " (key, reference, actual): %s\n" % mismatch
+                self.fail(msg)
+    def test_overwrite_existing_raster(self):
+        """Test that existing raster is overriden if desired"""
+        runivar_source = SimpleModule('r.univar', flags='g', map='rename_3')
+        self.runModule(runivar_source, expecting_stdout=True)
+        original_runivar_source = text_to_keyvalue(runivar_source.outputs.stdout,
+        runivar_target = SimpleModule('r.univar', flags='g', map='exists')
+        self.runModule(runivar_target, expecting_stdout=True)
+        original_runivar_target = text_to_keyvalue(runivar_target.outputs.stdout,
+        module = SimpleModule('g.rename', raster=['rename_3', 'exists'], overwrite=True)
+        self.assertRasterExists('exists', msg="Destination (here: existing) map (to) should exist after rename")
+        self.assertFalse(is_map_in_mapset('rename_3', type='raster'),
+                         msg="Source map (from) should not exist after rename")
+        # both these tests are probably redundant but let's test thoroughly
+        if keyvalue_equals(dict_a=original_runivar_target, dict_b=new_runivar,
+                           precision=1e-7):
+            msg = "Raster map did not change. It probably wasn't overwritten."
+            self.fail(msg)
+        if not keyvalue_equals(dict_a=original_runivar_source, dict_b=new_runivar,
+                               precision=1e-7):
+            unused, missing, mismatch = diff_keyvalue(dict_a=original_runivar_source,
+                                                      precision=1e-7)
+            if mismatch:
+                msg = "Destination raster map is not the same as source."
+                msg += " It probably wasn't overwritten.\n"
+                self.fail(msg)
+if __name__ == '__main__':
+    grass.gunittest.test()
