[GRASS-SVN] r64641 - grass/trunk/temporal/t.connect/testsuite
Sun Feb 15 18:42:06 PST 2015
Author: wenzeslaus
Date: 2015-02-15 18:42:06 -0800 (Sun, 15 Feb 2015)
New Revision: 64641
   grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
   grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
   grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
t.connect: delete created mapsets in tear down step in tests
 * only the given (current) mapset is deleted with automatic runs
 * TODO: the names should be more unique or a custom gisdbase should be used
 * whitespace and unused variable cleanup using pep8, autopep8, pyflakes and pylint
 * before: automatic tests were failing because location already contained the mapsets, so set up step was failing
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py	2015-02-15 23:03:24 UTC (rev 64640)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py	2015-02-16 02:42:06 UTC (rev 64641)
@@ -8,156 +8,168 @@
 :authors: Soeren Gebbert
-import grass.pygrass.modules as pymod
-import subprocess
 from grass.gunittest.case import TestCase
 from grass.gunittest.gmodules import SimpleModule
+from grass.gunittest.utils import silent_rmtree
 import os
 import grass.temporal as tgis
-mapset_count = 0
 class TestRasterExtraction(TestCase):
+    mapsets_to_remove = []
     @classmethod
     def setUpClass(cls):
         os.putenv("GRASS_OVERWRITE", "1")
-        for i in range(1, 5):
-            cls.runModule("g.mapset", flags="c", mapset="test%i"%i)
-            cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,  t=50,  res=10,  res3=10)
+        for i in range(1, 5):
+            mapset_name = "test%i" % i
+            cls.runModule("g.mapset", flags="c", mapset=mapset_name)
+            cls.mapsets_to_remove.append(mapset_name)
+            cls.runModule("g.region", s=0, n=80,
+                          w=0, e=120, b=0, t=50, res=10, res3=10)
             cls.runModule("t.info", flags="s")
             cls.runModule("r.mapcalc", expression="a1 = 100")
             cls.runModule("r.mapcalc", expression="a2 = 200")
             cls.runModule("r.mapcalc", expression="a3 = 300")
-            cls.runModule("t.create",  type="strds",  temporaltype="absolute",
-                                         output="A",  title="A test",  description="A test")
-            cls.runModule("t.register",  flags="i",  type="raster",  input="A",
-                                         maps="a1,a2,a3",
-                                         start="2001-01-01", increment="%i months"%i)
+            cls.runModule("t.create", type="strds", temporaltype="absolute",
+                          output="A", title="A test", description="A test")
+            cls.runModule("t.register", flags="i", type="raster", input="A",
+                          maps="a1,a2,a3",
+                          start="2001-01-01", increment="%i months" % i)
         # Here we reuse two mapset to share a temporal databse between mapsets
         tgis.init()
         ciface = tgis.get_tgis_c_library_interface()
         cls.runModule("g.mapset", flags="c", mapset="test5")
         driver = ciface.get_driver_name("test1")
         database = ciface.get_database_name("test1")
-        cls.runModule("t.connect",  driver=driver,  database=database)
+        cls.runModule("t.connect", driver=driver, database=database)
         cls.runModule("g.mapset", flags="c", mapset="test6")
         driver = ciface.get_driver_name("test2")
         database = ciface.get_database_name("test2")
-        for i in range(5, 7):
-            cls.runModule("g.mapset", mapset="test%i"%i)
+        for i in range(5, 7):
+            cls.runModule("g.mapset", mapset=mapset_name)
-                                         maps="a1,a2,a3",
-    def test_tlist(self):
+                          maps="a1,a2,a3",
+    @classmethod
+    def tearDownClass(cls):
+        gisenv = SimpleModule('g.gisenv', get='GISDBASE')
+        cls.runModule(gisenv, expecting_stdout=True)
+        gisdbase = gisenv.outputs.stdout.strip()
+        gisenv = SimpleModule('g.gisenv', get='LOCATION_NAME')
+        location = gisenv.outputs.stdout.strip()
+        for mapset_name in cls.mapsets_to_remove:
+            mapset_path = os.path.join(gisdbase, location, mapset_name)
+            silent_rmtree(mapset_path)
+    def test_tlist(self):
         self.runModule("g.mapset", mapset="test1")
         list_string = """A|test1|2001-01-01 00:00:00|2001-04-01 00:00:00|3
                                 A|test2|2001-01-01 00:00:00|2001-07-01 00:00:00|3
                                 A|test3|2001-01-01 00:00:00|2001-10-01 00:00:00|3
                                 A|test4|2001-01-01 00:00:00|2002-01-01 00:00:00|3
                                 A|test5|2001-01-01 00:00:00|2002-04-01 00:00:00|3
                                 A|test6|2001-01-01 00:00:00|2002-07-01 00:00:00|3"""
-        entries = list_string.split("\n")
-        t_list = SimpleModule("t.list", quiet=True,
-                                            columns=["name","mapset,start_time","end_time","number_of_maps"],
-                                            type="strds",  where='name = "A"')
+        t_list = SimpleModule(
+            "t.list", quiet=True,
+            columns=["name", "mapset,start_time", "end_time", "number_of_maps"],
+            type="strds", where='name = "A"')
         self.assertModule(t_list)
         out = t_list.outputs["stdout"].value
-        for a,  b in zip(list_string.split("\n"),  out.split("\n")):
+        for a, b in zip(list_string.split("\n"), out.split("\n")):
             self.assertEqual(a.strip(), b.strip())
-    def test_trast_list(self):
+    def test_trast_list(self):
         list_string = """a1|test1|2001-01-01 00:00:00|2001-02-01 00:00:00
                                 a2|test1|2001-02-01 00:00:00|2001-03-01 00:00:00
                                 a3|test1|2001-03-01 00:00:00|2001-04-01 00:00:00"""
-        trast_list = SimpleModule("t.rast.list", quiet=True, flags="s",  input="A at test1")
+        trast_list = SimpleModule(
+            "t.rast.list", quiet=True, flags="s", input="A at test1")
         self.assertModule(trast_list)
         out = trast_list.outputs["stdout"].value
         list_string = """a1|test2|2001-01-01 00:00:00|2001-03-01 00:00:00
                                 a2|test2|2001-03-01 00:00:00|2001-05-01 00:00:00
                                 a3|test2|2001-05-01 00:00:00|2001-07-01 00:00:00"""
-        trast_list = SimpleModule("t.rast.list", quiet=True, flags="s",  input="A at test2")
+            "t.rast.list", quiet=True, flags="s", input="A at test2")
         list_string = """a1|test3|2001-01-01 00:00:00|2001-04-01 00:00:00
                                 a2|test3|2001-04-01 00:00:00|2001-07-01 00:00:00
                                 a3|test3|2001-07-01 00:00:00|2001-10-01 00:00:00"""
-        trast_list = SimpleModule("t.rast.list", quiet=True, flags="s",  input="A at test3")
+            "t.rast.list", quiet=True, flags="s", input="A at test3")
         list_string = """a1|test4|2001-01-01 00:00:00|2001-05-01 00:00:00
                                 a2|test4|2001-05-01 00:00:00|2001-09-01 00:00:00
                                 a3|test4|2001-09-01 00:00:00|2002-01-01 00:00:00"""
-        trast_list = SimpleModule("t.rast.list", quiet=True, flags="s",  input="A at test4")
+            "t.rast.list", quiet=True, flags="s", input="A at test4")
         list_string = """a1|test5|2001-01-01 00:00:00|2001-06-01 00:00:00
                                 a2|test5|2001-06-01 00:00:00|2001-11-01 00:00:00
                                 a3|test5|2001-11-01 00:00:00|2002-04-01 00:00:00"""
-        trast_list = SimpleModule("t.rast.list", quiet=True, flags="s",  input="A at test5")
+            "t.rast.list", quiet=True, flags="s", input="A at test5")
-    def test_strds_info(self):
+    def test_strds_info(self):
         self.runModule("g.mapset", mapset="test4")
-        tinfo_string="""id=A at test1
+        tinfo_string = """id=A at test1
                                     name=A
                                     mapset=test1
                                     start_time=2001-01-01 00:00:00
@@ -165,10 +177,11 @@
                                     granularity=1 month"""
         info = SimpleModule("t.info", flags="g", input="A at test1")
-        self.assertModuleKeyValue(module=info, reference=tinfo_string, precision=2, sep="=")
+        self.assertModuleKeyValue(
+            module=info, reference=tinfo_string, precision=2, sep="=")
         self.runModule("g.mapset", mapset="test3")
-        tinfo_string="""id=A at test2
+        tinfo_string = """id=A at test2
                                     name=A
                                     mapset=test2
@@ -176,10 +189,11 @@
                                     granularity=2 months"""
         info = SimpleModule("t.info", flags="g", input="A at test2")
         self.runModule("g.mapset", mapset="test2")
-        tinfo_string="""id=A at test3
+        tinfo_string = """id=A at test3
                                     name=A
                                     mapset=test3
@@ -187,10 +201,11 @@
                                     granularity=3 months"""
         info = SimpleModule("t.info", flags="g", input="A at test3")
-        tinfo_string="""id=A at test4
+        tinfo_string = """id=A at test4
                                     name=A
                                     mapset=test4
@@ -198,9 +213,10 @@
                                     granularity=4 months"""
         info = SimpleModule("t.info", flags="g", input="A at test4")
-        tinfo_string="""id=A at test5
+        tinfo_string = """id=A at test5
                                     name=A
                                     mapset=test5
@@ -208,59 +224,70 @@
                                     granularity=5 months"""
         info = SimpleModule("t.info", flags="g", input="A at test5")
-    def test_raster_info(self):
+    def test_raster_info(self):
-        tinfo_string="""id=a1 at test1
+        tinfo_string = """id=a1 at test1
                                 name=a1
                                 mapset=test1
                                 temporal_type=absolute
                                 end_time=2001-02-01 00:00:00 """
-        info = SimpleModule("t.info", flags="g", type="raster",  input="a1 at test1")
+        info = SimpleModule(
+            "t.info", flags="g", type="raster", input="a1 at test1")
-        tinfo_string="""id=a1 at test2
+        tinfo_string = """id=a1 at test2
                                 name=a1
                                 mapset=test2
                                 end_time=2001-03-01 00:00:00 """
-        info = SimpleModule("t.info", flags="g", type="raster",  input="a1 at test2")
+            "t.info", flags="g", type="raster", input="a1 at test2")
-        tinfo_string="""id=a1 at test3
+        tinfo_string = """id=a1 at test3
                                 name=a1
                                 mapset=test3
                                 end_time=2001-04-01 00:00:00 """
-        info = SimpleModule("t.info", flags="g", type="raster",  input="a1 at test3")
+            "t.info", flags="g", type="raster", input="a1 at test3")
-        tinfo_string="""id=a1 at test4
+        tinfo_string = """id=a1 at test4
                                 name=a1
                                 mapset=test4
                                 end_time=2001-05-01 00:00:00 """
-        info = SimpleModule("t.info", flags="g", type="raster",  input="a1 at test4")
+            "t.info", flags="g", type="raster", input="a1 at test4")
-        tinfo_string="""id=a1 at test5
+        tinfo_string = """id=a1 at test5
                                 name=a1
                                 mapset=test5
                                 end_time=2001-06-01 00:00:00 """
-        info = SimpleModule("t.info", flags="g", type="raster",  input="a1 at test5")
+            "t.info", flags="g", type="raster", input="a1 at test5")
 if __name__ == '__main__':
     from grass.gunittest.main import test
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py	2015-02-15 23:03:24 UTC (rev 64640)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py	2015-02-16 02:42:06 UTC (rev 64641)
@@ -8,65 +8,82 @@
 import os
 class testRaster3dExtraction(TestCase):
     @classmethod
-       os.putenv("GRASS_OVERWRITE", "1")
-            cls.runModule("g.mapset", flags="c", mapset="test3d%i"%i)
+        os.putenv("GRASS_OVERWRITE", "1")
+            mapset_name = "test3d%i" % i
             # Use always the current mapset as temporal database
             cls.runModule("r3.mapcalc", expression="a1 = 100")
             cls.runModule("r3.mapcalc", expression="a2 = 200")
             cls.runModule("r3.mapcalc", expression="a3 = 300")
-            cls.runModule("t.create",  type="str3ds",  temporaltype="absolute",
-                                         output="A",  title="A test3d",  description="A test3d")
-            cls.runModule("t.register",  flags="i",  type="raster_3d",  input="A",
-                                         maps="a1,a2,a3",
+            cls.runModule("t.create", type="str3ds", temporaltype="absolute",
+                          output="A", title="A test3d", description="A test3d")
+            cls.runModule(
+                "t.register", flags="i", type="raster_3d", input="A",
+                maps="a1,a2,a3",
+    @classmethod
         self.runModule("g.mapset", mapset="test3d1")
         list_string = """A|test3d1|2001-01-01 00:00:00|2001-04-01 00:00:00|3
                                 A|test3d2|2001-01-01 00:00:00|2001-07-01 00:00:00|3
                                 A|test3d3|2001-01-01 00:00:00|2001-10-01 00:00:00|3
                                 A|test3d4|2001-01-01 00:00:00|2002-01-01 00:00:00|3"""
-                                            type="str3ds",  where='name = "A"')
+            type="str3ds", where='name = "A"')
         list_string = """a1|test3d1|2001-01-01 00:00:00|2001-02-01 00:00:00
                                 a2|test3d1|2001-02-01 00:00:00|2001-03-01 00:00:00
                                 a3|test3d1|2001-03-01 00:00:00|2001-04-01 00:00:00"""
-        trast_list = SimpleModule("t.rast3d.list", quiet=True, flags="s",  input="A at test3d1")
+            "t.rast3d.list", quiet=True, flags="s", input="A at test3d1")
         list_string = """a1|test3d2|2001-01-01 00:00:00|2001-03-01 00:00:00
@@ -75,12 +92,13 @@
-        trast_list = SimpleModule("t.rast3d.list", quiet=True, flags="s",  input="A at test3d2")
+            "t.rast3d.list", quiet=True, flags="s", input="A at test3d2")
         list_string = """a1|test3d3|2001-01-01 00:00:00|2001-04-01 00:00:00
@@ -89,114 +107,130 @@
-        trast_list = SimpleModule("t.rast3d.list", quiet=True, flags="s",  input="A at test3d3")
+            "t.rast3d.list", quiet=True, flags="s", input="A at test3d3")
         list_string = """a1|test3d4|2001-01-01 00:00:00|2001-05-01 00:00:00
                                 a2|test3d4|2001-05-01 00:00:00|2001-09-01 00:00:00
                                 a3|test3d4|2001-09-01 00:00:00|2002-01-01 00:00:00"""
-        trast_list = SimpleModule("t.rast3d.list", quiet=True, flags="s",  input="A at test3d4")
+            "t.rast3d.list", quiet=True, flags="s", input="A at test3d4")
         self.runModule("g.mapset", mapset="test3d4")
-        tinfo_string="""id=A at test3d1
+        tinfo_string = """id=A at test3d1
                                     name=A
                                     mapset=test3d1
-        info = SimpleModule("t.info", flags="g", type="str3ds",  input="A at test3d1")
+            "t.info", flags="g", type="str3ds", input="A at test3d1")
         self.runModule("g.mapset", mapset="test3d3")
-        tinfo_string="""id=A at test3d2
+        tinfo_string = """id=A at test3d2
                                     name=A
                                     mapset=test3d2
                                     end_time=2001-07-01 00:00:00
-        info = SimpleModule("t.info", flags="g", type="str3ds", input="A at test3d2")
+            "t.info", flags="g", type="str3ds", input="A at test3d2")
         self.runModule("g.mapset", mapset="test3d2")
-        tinfo_string="""id=A at test3d3
+        tinfo_string = """id=A at test3d3
                                     name=A
                                     mapset=test3d3
                                     end_time=2001-10-01 00:00:00
-        info = SimpleModule("t.info", flags="g", type="str3ds", input="A at test3d3")
+            "t.info", flags="g", type="str3ds", input="A at test3d3")
-        tinfo_string="""id=A at test3d4
+        tinfo_string = """id=A at test3d4
                                     name=A
                                     mapset=test3d4
                                     end_time=2002-01-01 00:00:00
-        info = SimpleModule("t.info", flags="g", type="str3ds", input="A at test3d4")
+            "t.info", flags="g", type="str3ds", input="A at test3d4")
-        tinfo_string="""id=a1 at test3d1
+        tinfo_string = """id=a1 at test3d1
                                 name=a1
                                 mapset=test3d1
-        info = SimpleModule("t.info", flags="g", type="raster_3d",  input="a1 at test3d1")
+            "t.info", flags="g", type="raster_3d", input="a1 at test3d1")
-        tinfo_string="""id=a1 at test3d2
+        tinfo_string = """id=a1 at test3d2
                                 name=a1
                                 mapset=test3d2
-        info = SimpleModule("t.info", flags="g", type="raster_3d",  input="a1 at test3d2")
+            "t.info", flags="g", type="raster_3d", input="a1 at test3d2")
-        tinfo_string="""id=a1 at test3d3
+        tinfo_string = """id=a1 at test3d3
                                 name=a1
                                 mapset=test3d3
-        info = SimpleModule("t.info", flags="g", type="raster_3d",  input="a1 at test3d3")
+            "t.info", flags="g", type="raster_3d", input="a1 at test3d3")
-        tinfo_string="""id=a1 at test3d4
+        tinfo_string = """id=a1 at test3d4
                                 name=a1
                                 mapset=test3d4
-        info = SimpleModule("t.info", flags="g", type="raster_3d",  input="a1 at test3d4")
+            "t.info", flags="g", type="raster_3d", input="a1 at test3d4")
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py	2015-02-15 23:03:24 UTC (rev 64640)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py	2015-02-16 02:42:06 UTC (rev 64641)
@@ -8,205 +8,232 @@
-import subprocess
 import os
-mapset_count = 0
     @classmethod
-            cls.runModule("g.mapset", flags="c", mapset="testvect%i"%i)
+            mapset_name = "testvect%i" % i
-            cls.runModule("v.random", output="a1",  npoints=20)
-            cls.runModule("v.random", output="a2",  npoints=20)
-            cls.runModule("v.random", output="a3",  npoints=20)
-            cls.runModule("t.create",  type="stvds",  temporaltype="absolute",
-                                         output="A",  title="A testvect",  description="A testvect")
-            cls.runModule("t.register",  flags="i",  type="vector",  input="A",
-                                         maps="a1,a2,a3",
+            cls.runModule("v.random", output="a1", npoints=20)
+            cls.runModule("v.random", output="a2", npoints=20)
+            cls.runModule("v.random", output="a3", npoints=20)
+            cls.runModule("t.create", type="stvds", temporaltype="absolute",
+                          output="A", title="A testvect", description="A testvect")
+            cls.runModule("t.register", flags="i", type="vector", input="A",
+                          maps="a1,a2,a3",
+    @classmethod
         self.runModule("g.mapset", mapset="testvect1")
         list_string = """A|testvect1|2001-01-01 00:00:00|2001-04-01 00:00:00|3
                                 A|testvect2|2001-01-01 00:00:00|2001-07-01 00:00:00|3
                                 A|testvect3|2001-01-01 00:00:00|2001-10-01 00:00:00|3
                                 A|testvect4|2001-01-01 00:00:00|2002-01-01 00:00:00|3"""
-                                           type="stvds",  where='name = "A"')
+            type="stvds", where='name = "A"')
-    def test_tvect_list(self):
+    def test_tvect_list(self):
         list_string = """a1|testvect1|2001-01-01 00:00:00|2001-02-01 00:00:00
                                 a2|testvect1|2001-02-01 00:00:00|2001-03-01 00:00:00
                                 a3|testvect1|2001-03-01 00:00:00|2001-04-01 00:00:00"""
-        trast_list = SimpleModule("t.vect.list", quiet=True, flags="s",
-                                  columns=["name","mapset","start_time","end_time"] ,
+        trast_list = SimpleModule("t.vect.list", quiet=True, flags="s",
+                                  columns=[
+                                      "name", "mapset", "start_time", "end_time"],
                                   input="A at testvect1")
         list_string = """a1|testvect2|2001-01-01 00:00:00|2001-03-01 00:00:00
                                 a2|testvect2|2001-03-01 00:00:00|2001-05-01 00:00:00
                                 a3|testvect2|2001-05-01 00:00:00|2001-07-01 00:00:00"""
-                                  input="A at testvect2")
+            "t.vect.list", quiet=True, flags="s",
+            columns=["name", "mapset", "start_time", "end_time"],
+            input="A at testvect2")
         list_string = """a1|testvect3|2001-01-01 00:00:00|2001-04-01 00:00:00
                                 a2|testvect3|2001-04-01 00:00:00|2001-07-01 00:00:00
                                 a3|testvect3|2001-07-01 00:00:00|2001-10-01 00:00:00"""
+                                  columns=[
                                   input="A at testvect3")
         list_string = """a1|testvect4|2001-01-01 00:00:00|2001-05-01 00:00:00
                                 a2|testvect4|2001-05-01 00:00:00|2001-09-01 00:00:00
                                 a3|testvect4|2001-09-01 00:00:00|2002-01-01 00:00:00"""
-                                  input="A at testvect4")
+            input="A at testvect4")
-    def test_stvds_info(self):
+    def test_stvds_info(self):
         self.runModule("g.mapset", mapset="testvect4")
-        tinfo_string="""id=A at testvect1
+        tinfo_string = """id=A at testvect1
                                     name=A
                                     mapset=testvect1
-        info = SimpleModule("t.info", flags="g", type="stvds", input="A at testvect1")
+            "t.info", flags="g", type="stvds", input="A at testvect1")
         self.runModule("g.mapset", mapset="testvect3")
-        tinfo_string="""id=A at testvect2
+        tinfo_string = """id=A at testvect2
                                     name=A
                                     mapset=testvect2
-        info = SimpleModule("t.info", flags="g", type="stvds",  input="A at testvect2")
+            "t.info", flags="g", type="stvds", input="A at testvect2")
         self.runModule("g.mapset", mapset="testvect2")
-        tinfo_string="""id=A at testvect3
+        tinfo_string = """id=A at testvect3
                                     name=A
                                     mapset=testvect3
-        info = SimpleModule("t.info", flags="g", type="stvds", input="A at testvect3")
+            "t.info", flags="g", type="stvds", input="A at testvect3")
-        tinfo_string="""id=A at testvect4
+        tinfo_string = """id=A at testvect4
                                     name=A
                                     mapset=testvect4
-        info = SimpleModule("t.info", flags="g", type="stvds", input="A at testvect4")
+            "t.info", flags="g", type="stvds", input="A at testvect4")
-    def testv_vector_info(self):
+    def testv_vector_info(self):
-        tinfo_string="""id=a1 at testvect1
+        tinfo_string = """id=a1 at testvect1
                                 name=a1
                                 mapset=testvect1
-        info = SimpleModule("t.info", flags="g", type="vector",  input="a1 at testvect1")
+            "t.info", flags="g", type="vector", input="a1 at testvect1")
-        tinfo_string="""id=a1 at testvect2
+        tinfo_string = """id=a1 at testvect2
                                 name=a1
                                 mapset=testvect2
-        info = SimpleModule("t.info", flags="g", type="vector",  input="a1 at testvect2")
+            "t.info", flags="g", type="vector", input="a1 at testvect2")
-        tinfo_string="""id=a1 at testvect3
+        tinfo_string = """id=a1 at testvect3
                                 name=a1
                                 mapset=testvect3
-        info = SimpleModule("t.info", flags="g", type="vector",  input="a1 at testvect3")
+            "t.info", flags="g", type="vector", input="a1 at testvect3")
-        tinfo_string="""id=a1 at testvect4
+        tinfo_string = """id=a1 at testvect4
                                 name=a1
                                 mapset=testvect4
-        info = SimpleModule("t.info", flags="g", type="vector",  input="a1 at testvect4")
+            "t.info", flags="g", type="vector", input="a1 at testvect4")
