[GRASS-SVN] r64683 - in grass/trunk/lib/python/gunittest: . testsuite
svn_grass at osgeo.org
Wed Feb 18 20:32:40 PST 2015
Author: wenzeslaus
Date: 2015-02-18 20:32:40 -0800 (Wed, 18 Feb 2015)
New Revision: 64683
grass/trunk/lib/python/gunittest/case.py
grass/trunk/lib/python/gunittest/testsuite/test_assertions.py
gunittest: improve the implementation of newline tests using os.linesep
* use the same also in assertLooksLike function
* fix message handling in assertMultiLineEqual function
* update tests accordingly
* tell user MD5 sums when testing against a MD5 sum
Modified: grass/trunk/lib/python/gunittest/case.py
--- grass/trunk/lib/python/gunittest/case.py 2015-02-18 22:21:18 UTC (rev 64682)
+++ grass/trunk/lib/python/gunittest/case.py 2015-02-19 04:32:40 UTC (rev 64683)
@@ -142,30 +142,43 @@
will be included in the error message. This method is used by default
when comparing strings with assertEqual().
- This method replaces ``\r\n`` by ``\n`` in both parameters. This is
+ This method replaces platform dependent newline characters
+ by ``\n`` (LF) in both parameters. This is
different from the same method implemented in Python ``unittest``
- package which preserves the original line endings. This removes the
- burden of getting the line endings right on each platfrom. You can
- just use ``\n`` everywhere. However, note that ``\r`` is not supported.
+ package which preserves the original newline characters.
+ This function removes the burden of getting the newline characters
+ right on each platfrom. You can just use ``\n`` everywhere and this
+ function will ensure that it does not matter if for example,
+ a module generates (as expected) ``\r\n`` (CRLF) newline characters
+ on MS Windows.
.. warning::
- If you need to test the actual line endings, use the standard
+ If you need to test the actual newline characters, use the standard
string comparison and functions such as ``find()``.
+ if os.linesep != '\n':
+ if os.linesep in first:
+ first = first.replace(os.linesep, '\n')
+ if os.linesep in second:
+ second = second.replace(os.linesep, '\n')
return super(TestCase, self).assertMultiLineEqual(
- first=first.replace('\r\n', '\n'),
- second=second.replace('\r\n', '\n'),
- msg=None)
+ first=first, second=second, msg=msg)
def assertLooksLike(self, actual, reference, msg=None):
- """Test that ``actual`` text is the same as ``referece`` with ellipses.
+ r"""Test that ``actual`` text is the same as ``referece`` with ellipses.
+ If ``actual`` contains platform dependent newline characters,
+ these will replaced by ``\n`` which is expected to be in the test data.
See :func:`check_text_ellipsis` for details of behavior.
self.assertTrue(isinstance(actual, basestring), (
'actual argument is not a string'))
self.assertTrue(isinstance(reference, basestring), (
'reference argument is not a string'))
+ if os.linesep != '\n' and os.linesep in actual:
+ actual = actual.replace(os.linesep, '\n')
if not check_text_ellipsis(actual=actual, reference=reference):
# TODO: add support for multiline (first line general, others with details)
standardMsg = '"%s" does not correspond with "%s"' % (actual,
@@ -558,8 +571,12 @@
hasher.hexdigest()
self.assertFileExists(filename, msg=msg)
- if not file_md5(filename) == md5:
- standardMsg = 'File %s does not have the right MD5 sum' % filename
+ actual = file_md5(filename)
+ if not actual == md5:
+ standardMsg = ('File <{name}> does not have the right MD5 sum.\n'
+ 'Expected is <{expected}>,'
+ ' actual is <{actual}>'.format(
+ name=filename, expected=md5, actual=actual))
self.fail(self._formatMessage(msg, standardMsg))
def assertFilesEqualMd5(self, filename, reference, msg=None):
Modified: grass/trunk/lib/python/gunittest/testsuite/test_assertions.py
--- grass/trunk/lib/python/gunittest/testsuite/test_assertions.py 2015-02-18 22:21:18 UTC (rev 64682)
+++ grass/trunk/lib/python/gunittest/testsuite/test_assertions.py 2015-02-19 04:32:40 UTC (rev 64683)
@@ -16,6 +16,10 @@
class TestTextAssertions(grass.gunittest.TestCase):
# pylint: disable=R0904
+ std_newline = "aaa\nbbb\n"
+ platfrom_newline = "aaa{nl}bbb{nl}".format(nl=os.linesep)
def test_assertLooksLike(self):
self.assertLooksLike("Generated map is <elevation>",
"Generated map is <...>")
@@ -30,6 +34,10 @@
self.assertLooksLike("a=123\nb=456\nc=789",
"a=...\nb=...\nc=...")
+ def test_assertLooksLike_multiline_platform_dependent(self):
+ self.assertLooksLike("a=123\nb=456\nc=789",
+ "a=...{nl}b=...{nl}c=...".format(nl=os.linesep))
def test_assertLooksLike_numbers(self):
self.assertLooksLike("abc = 125521",
"abc = 125...")
@@ -44,16 +52,16 @@
"abc = 689.159589",
"abc = 689....")
- def do_all_combidnations(self, first, second):
- self.assertMultiLineEqual(first, first)
- self.assertMultiLineEqual(first, second)
- self.assertMultiLineEqual(second, first)
- self.assertMultiLineEqual(second, second)
+ def do_all_combidnations(self, first, second, function):
+ function(first, first)
+ function(first, second)
+ function(second, first)
+ function(second, second)
def test_assertMultiLineEqual(self):
- unix_end = "aaa\nbbb\n"
- mswindows_end = "aaa\r\nbbb\r\n"
- self.do_all_combidnations(unix_end, mswindows_end)
+ r"""Test different combinations of ``\n`` and os.linesep"""
+ self.do_all_combidnations(self.std_newline, self.platfrom_newline,
+ function=self.assertMultiLineEqual)
def test_assertMultiLineEqual_raises(self):
"""Test mixed line endings"""
@@ -63,11 +71,12 @@
"aaa\nbbb\n")
def test_assertEqual(self):
- """Test for strings (uses overwritten assertMultiLineEqual())"""
+ """Test for of newlines for strings (uses overwritten assertMultiLineEqual())"""
+ function=self.assertEqual)
+ def test_assertEqual_raises(self):
+ """Test mixed line endings"""
self.assertRaises(self.failureException,
self.assertEqual,
"aaa\n\rbbb\r",
