[GRASS-SVN] r64687 - in grass/trunk: general/g.gui gui/wxpython/core lib/init
svn_grass at osgeo.org
Thu Feb 19 09:49:45 PST 2015
Author: martinl
Date: 2015-02-19 09:49:45 -0800 (Thu, 19 Feb 2015)
New Revision: 64687
grass/trunk/general/g.gui/main.c
grass/trunk/gui/wxpython/core/render.py
grass/trunk/lib/init/grass.py
revert r64686 (wrong commit)
Modified: grass/trunk/general/g.gui/main.c
--- grass/trunk/general/g.gui/main.c 2015-02-19 17:46:41 UTC (rev 64686)
+++ grass/trunk/general/g.gui/main.c 2015-02-19 17:49:45 UTC (rev 64687)
@@ -8,7 +8,7 @@
* PURPOSE: Start GRASS GUI from command line.
- * COPYRIGHT: (C) 2008-2015 by the GRASS Development Team
+ * COPYRIGHT: (C) 2008-2014 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -25,7 +25,7 @@
int main(int argc, char *argv[])
struct Option *type, *rc_file;
- struct Flag *update_ui, *nolaunch;
+ struct Flag *update, *nolaunch;
struct GModule *module;
const char *gui_type_env;
char progname[GPATH_MAX];
@@ -45,16 +45,15 @@
type = G_define_option();
type->key = "ui";
type->type = TYPE_STRING;
- type->description = _("User interface");
+ type->label = _("User interface");
+ type->description = _("Default value: GRASS_GUI if defined otherwise wxpython");
desc = NULL;
G_asprintf(&desc,
- "wxpython;%s;text;%s;gtext;%s;",
- _("wxPython based GUI (wxGUI)"),
- _("command line interface only"),
- _("command line interface with GUI startup screen"));
+ "wxpython;%s;text;%s",
+ _("wxPython based GUI (wxGUI)"),
+ _("command line interface only"));
type->descriptions = desc;
- type->options = "wxpython,text,gtext";
- type->answer = "wxpython";
+ type->options = "wxpython,text";
type->guisection = _("Type");
rc_file = G_define_standard_option(G_OPT_F_INPUT);
@@ -63,10 +62,10 @@
rc_file->key_desc = "name.gxw";
rc_file->description = _("Name of workspace file to load on start-up (valid only for wxGUI)");
- update_ui = G_define_flag();
- update_ui->key = 'd';
- update_ui->description = _("Update default user interface settings");
- update_ui->guisection = _("Default");
+ update = G_define_flag();
+ update->key = 'd';
+ update->description = _("Update default user interface settings");
+ update->guisection = _("Default");
nolaunch = G_define_flag();
nolaunch->key = 'n';
@@ -77,34 +76,58 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ if (type->answer && strcmp(type->answer, "text") == 0 &&
+ !nolaunch->answer)
+ nolaunch->answer = TRUE;
+ if (nolaunch->answer && !update->answer)
+ update->answer = TRUE;
gui_type_env = G_getenv_nofatal("GUI");
- G_debug(1, "GUI: %s", gui_type_env ? gui_type_env : "unset");
- if (update_ui->answer) {
- if (!gui_type_env || strcmp(type->answer, gui_type_env)) {
- G_setenv("GUI", type->answer);
- G_message(_("<%s> is now the default GUI"), type->answer);
+ if (!type->answer) {
+ if (gui_type_env && strcmp(gui_type_env, "text")) {
+ type->answer = G_store(gui_type_env);
+ else {
+ type->answer = "wxpython";
- if(strcmp(type->answer, "wxpython") != 0 || nolaunch->answer)
- if (!update_ui->answer)
- G_warning(_("Nothing to do. For setting up <%s> as default UI use -%c flag."),
- type->answer, update_ui->key);
+ if (((gui_type_env && update->answer) &&
+ strcmp(gui_type_env, type->answer) != 0) || !gui_type_env) {
+ G_setenv("GUI", type->answer);
+ G_message(_("<%s> is now the default GUI"), type->answer);
+ else {
+ if(update->answer)
+ if(gui_type_env) {
+ G_debug(1, "No change: old gui_type_env=[%s], new type->ans=[%s]",
+ gui_type_env, type->answer);
+ if(nolaunch->answer)
exit(EXIT_SUCCESS);
G_message(_("Launching <%s> GUI in the background, please wait..."), type->answer);
- sprintf(progname, "%s/gui/wxpython/wxgui.py", G_gisbase());
- if (rc_file->answer) {
- G_spawn_ex(getenv("GRASS_PYTHON"), getenv("GRASS_PYTHON"), progname,
- "--workspace", rc_file->answer, SF_BACKGROUND, NULL);
+ if (strcmp(type->answer, "wxpython") == 0) {
+ sprintf(progname, "%s/gui/wxpython/wxgui.py", G_gisbase());
+ if (rc_file->answer) {
+ G_spawn_ex(getenv("GRASS_PYTHON"), getenv("GRASS_PYTHON"), progname,
+ "--workspace", rc_file->answer, SF_BACKGROUND, NULL);
+ else {
+ SF_BACKGROUND, NULL);
- else {
- SF_BACKGROUND, NULL);
/* stop the impatient from starting it again
- before the splash screen comes up */
+ before the splash screen comes up */
G_sleep(3);
exit(EXIT_SUCCESS);
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py 2015-02-19 17:46:41 UTC (rev 64686)
+++ grass/trunk/gui/wxpython/core/render.py 2015-02-19 17:49:45 UTC (rev 64687)
@@ -17,7 +17,7 @@
- render::Overlay
- render::Map
-(C) 2006-2015 by the GRASS Development Team
+(C) 2006-2014 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -156,24 +156,29 @@
if self.type == 'command':
read = False
for c in self.cmd:
- self._runCommand(c)
+ ret, msg = self._runCommand(c)
+ if ret != 0:
+ break
if not read:
self.environ["GRASS_RENDER_FILE_READ"] = "TRUE"
self.environ["GRASS_RENDER_FILE_READ"] = "FALSE"
else:
- self._runCommand(self.cmd)
- except GException as e:
- sys.stderr.write(_("Command '%s' failed\n") % self.GetCmd(string = True))
- sys.stderr.write(_("Details: %s\n") % e)
+ ret, msg = self._runCommand(self.cmd)
+ if ret != 0:
+ sys.stderr.write(_("Command '%s' failed\n") % self.GetCmd(string = True))
+ if msg:
+ sys.stderr.write(_("Details: %s\n") % msg)
+ raise GException()
+ except GException:
# clean up after problems
for f in [self.mapfile, self.maskfile]:
if not f:
continue
try_remove(f)
f = None
self.forceRender = False
return self.mapfile
@@ -181,8 +186,19 @@
def _runCommand(self, cmd):
"""Run command to render data
- self.renderMgr.Render(cmd, env=self.environ)
+ if self.type == 'wms':
+ ret = 0
+ msg = ''
+ self.renderMgr.Render(cmd, env=self.environ)
+ else:
+ ret, msg = RunCommand(cmd[0],
+ getErrorMsg = True,
+ quiet = True,
+ env=self.environ,
+ **cmd[1])
+ return ret, msg
def GetCmd(self, string = False):
"""Get GRASS command as list of string.
@@ -259,16 +275,13 @@
if ltype not in utils.command2ltype.values() + ['overlay', 'command']:
raise GException(_("Unsupported map layer type '%s'") % ltype)
- if not self.renderMgr:
- if ltype == 'wms':
- renderMgr = RenderWMSMgr
- else:
- renderMgr = RenderMgr
- self.renderMgr = renderMgr(layer=self,
- mapfile=self.mapfile,
- maskfile=self.maskfile)
+ if ltype == 'wms' and not isinstance(self.renderMgr, RenderWMSMgr):
+ self.renderMgr = RenderWMSMgr(layer=self,
+ mapfile=self.mapfile,
+ maskfile=self.maskfile)
+ elif self.type == 'wms' and ltype != 'wms':
+ self.renderMgr = None
self.type = ltype
def SetName(self, name):
@@ -1389,21 +1402,3 @@
self.updateProgress.emit(range=self.progressInfo['range'],
value=self.progressInfo['progresVal'],
text=stText)
-class RenderMgr(wx.EvtHandler):
- def __init__(self, layer, mapfile, maskfile):
- self.layer = layer
- wx.EvtHandler.__init__(self)
- self.thread = CmdThread(self)
- self.cmdStdErr = GStderr(self)
- self.mapfile = mapfile
- self.maskfile = maskfile
- def Render(self, cmd, env):
- self.thread.RunCmd(cmdList, env=env, stderr=self.cmdStdErr)
- def Abort(self):
- self.updateMap = False
- self.thread.abort(abortall = True)
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-02-19 17:46:41 UTC (rev 64686)
+++ grass/trunk/lib/init/grass.py 2015-02-19 17:49:45 UTC (rev 64687)
@@ -907,11 +907,10 @@
sh = os.path.basename(os.getenv('SHELL'))
except:
sh = 'sh'
- os.environ['SHELL'] = sh
+ os.environ['SHELL'] = "sh"
if windows and sh:
sh = os.path.splitext(sh)[0]
if sh == "ksh":
shellname = "Korn Shell"
elif sh == "csh":
