[GRASS-SVN] r64704 - grass/branches/releasebranch_7_0/locale/po
svn_grass at osgeo.org
Fri Feb 20 11:46:01 PST 2015
Author: neteler
Date: 2015-02-20 11:46:01 -0800 (Fri, 20 Feb 2015)
New Revision: 64704
grass/branches/releasebranch_7_0/locale/po/grasslibs_ar.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_cs.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_de.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_el.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_es.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_fr.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_it.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_ja.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_ko.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_lv.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_ml.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_pl.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_pt.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_pt_br.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_ro.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_ru.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_sl.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_th.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_tr.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_vi.po
grass/branches/releasebranch_7_0/locale/po/grasslibs_zh.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po
grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po
grass/branches/releasebranch_7_0/locale/po/grassmods_de.po
grass/branches/releasebranch_7_0/locale/po/grassmods_el.po
grass/branches/releasebranch_7_0/locale/po/grassmods_es.po
grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po
grass/branches/releasebranch_7_0/locale/po/grassmods_it.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po
grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po
grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po
grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po
grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po
grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po
grass/branches/releasebranch_7_0/locale/po/grassmods_th.po
grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po
grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po
grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_cs.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_de.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_el.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_es.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_id.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_it.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ja.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_lv.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ml.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_pl.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt_br.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ro.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ru.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_th.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_tr.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_vi.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_zh.po
i18N: update from template files
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_ar.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_ar.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_ar.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grassmods_ar\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2015-02-16 14:18+0100\n"
+"POT-Creation-Date: 2015-02-20 20:37+0100\n"
"PO-Revision-Date: 2005-03-09 12:50+0100\n"
"Last-Translator: Dr. Alaa Masoud <alaamasoud at hotmail.com>\n"
"Language-Team: Arabic <grass-translations at lists.osgeo.org>\n"
@@ -1194,7 +1194,7 @@
#: ../lib/proj/convert.c:82 ../lib/vector/Vlib/field.c:660
#: ../lib/vector/Vlib/read_ogr.c:56 ../lib/vector/Vlib/read_ogr.c:157
-#: ../lib/vector/Vlib/read_ogr.c:242 ../lib/vector/Vlib/write_sfa.c:299
+#: ../lib/vector/Vlib/read_ogr.c:242 ../lib/vector/Vlib/write_sfa.c:298
#: ../lib/vector/Vlib/build_sfa.c:711 ../lib/vector/Vlib/build_ogr.c:94
#: ../lib/vector/Vlib/build_ogr.c:169 ../lib/vector/Vlib/simple_features.c:310
#: ../lib/vector/Vlib/close.c:284 ../lib/vector/Vlib/open_ogr.c:121
@@ -2096,17 +2096,17 @@
msgid "Building user fontcap..."
msgstr "ÙØªÙ
Ø§ÙØ§Ù Ø¨ÙØ§Ø¡ Ø§ÙØ·Ø¨ÙÙÙØ¬Ù ...\n"
-#: ../lib/init/grass.py:934
+#: ../lib/init/grass.py:941
#, python-format
msgid "Unsupported shell <%(sh)s>: %(env)s"
msgstr ""
-#: ../lib/init/grass.py:939
+#: ../lib/init/grass.py:946
#, fuzzy
msgid "The SHELL variable is not set"
msgstr "GISRC - اÙÙ
ØªØºÙØ± ÙÙ
ÙØØ¯Ø¯ بشÙ٠صØÙØ"
-#: ../lib/init/grass.py:950
+#: ../lib/init/grass.py:957
#, python-format
msgid ""
"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
@@ -2115,105 +2115,105 @@
"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
msgstr ""
-#: ../lib/init/grass.py:955
+#: ../lib/init/grass.py:962
#, python-format
msgid "Change file permission to 'executable' for '%s'"
msgstr ""
-#: ../lib/init/grass.py:957
+#: ../lib/init/grass.py:964
#, python-format
msgid "Executing '%s' ..."
msgstr ""
-#: ../lib/init/grass.py:962
+#: ../lib/init/grass.py:969
#, python-format
msgid "Execution of '%s' finished."
msgstr ""
-#: ../lib/init/grass.py:968
+#: ../lib/init/grass.py:975
#, python-format
msgid "GRASS GUI should be <%s>"
msgstr ""
-#: ../lib/init/grass.py:997
+#: ../lib/init/grass.py:1004
#, python-format
msgid "Welcome to GRASS GIS %s"
msgstr ""
-#: ../lib/init/grass.py:1016
+#: ../lib/init/grass.py:1023
msgid "GRASS GIS homepage:"
msgstr ""
-#: ../lib/init/grass.py:1017
+#: ../lib/init/grass.py:1024
msgid "This version running through:"
msgstr ""
-#: ../lib/init/grass.py:1019
+#: ../lib/init/grass.py:1026
msgid "Help is available with the command:"
msgstr ""
-#: ../lib/init/grass.py:1020
+#: ../lib/init/grass.py:1027
msgid "See the licence terms with:"
msgstr ""
-#: ../lib/init/grass.py:1023
+#: ../lib/init/grass.py:1030
msgid "If required, restart the GUI with:"
msgstr ""
-#: ../lib/init/grass.py:1025
+#: ../lib/init/grass.py:1032
msgid "Start the GUI with:"
msgstr ""
-#: ../lib/init/grass.py:1027
+#: ../lib/init/grass.py:1034
msgid "When ready to quit enter:"
msgstr ""
-#: ../lib/init/grass.py:1117
+#: ../lib/init/grass.py:1124
msgid "2D and 3D raster MASKs present"
msgstr ""
-#: ../lib/init/grass.py:1118
+#: ../lib/init/grass.py:1125
msgid "Raster MASK present"
msgstr ""
-#: ../lib/init/grass.py:1119
+#: ../lib/init/grass.py:1126
msgid "3D raster MASK present"
msgstr ""
-#: ../lib/init/grass.py:1158
+#: ../lib/init/grass.py:1165
#, fuzzy, python-format
msgid "Failed to start shell '%s'"
msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
-#: ../lib/init/grass.py:1163
+#: ../lib/init/grass.py:1170
#, python-format
msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
msgstr ""
-#: ../lib/init/grass.py:1164 ../lib/init/grass.py:1169
+#: ../lib/init/grass.py:1171 ../lib/init/grass.py:1176
msgid "Goodbye from GRASS GIS"
msgstr ""
-#: ../lib/init/grass.py:1167
+#: ../lib/init/grass.py:1174
#, fuzzy
msgid "Done."
msgstr "ÙØ§Ø´ÙØ¡"
-#: ../lib/init/grass.py:1174
+#: ../lib/init/grass.py:1181
#, fuzzy
msgid "Cleaning up temporary files..."
msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
ÙÙ Ù
Ø¤ÙØª"
-#: ../lib/init/grass.py:1218
+#: ../lib/init/grass.py:1225
msgid "Parameter <%s> not supported"
msgstr "ØºÙØ± Ù
ÙØ¬Ùد'%s' اÙÙÙÙØªÙر"
-#: ../lib/init/grass.py:1341
+#: ../lib/init/grass.py:1348
msgid "Flag -e required also flag -c"
msgstr ""
-#: ../lib/init/grass.py:1384
+#: ../lib/init/grass.py:1391
#, python-format
msgid ""
"Unable to start GRASS. You can:\n"
@@ -2223,15 +2223,15 @@
"path/to/location/mapset`)"
msgstr ""
-#: ../lib/init/grass.py:1394
+#: ../lib/init/grass.py:1401
msgid "Creating new GRASS GIS location/mapset..."
msgstr ""
-#: ../lib/init/grass.py:1396
+#: ../lib/init/grass.py:1403
msgid "Starting GRASS GIS..."
msgstr ""
-#: ../lib/init/grass.py:1454
+#: ../lib/init/grass.py:1461
#, python-format
msgid "Launching <%s> GUI in the background, please wait..."
msgstr ""
@@ -6884,19 +6884,19 @@
msgid "Unable to remove directory '%s'"
msgstr " [%s] ØºÙØ± ÙØ§Ø¯Ø± عÙÙ Ø£ÙØ´Ø§Ø¡ Ù
Ù٠عÙÙØ§Ù Ø±Ø¦ÙØ³Ù Ù"
-#: ../lib/vector/Vlib/read_nat.c:144 ../lib/vector/Vlib/write_nat.c:183
-#: ../lib/vector/Vlib/write_nat.c:296 ../lib/vector/Vlib/write_nat.c:398
-#: ../lib/vector/Vlib/write_nat.c:653 ../lib/vector/Vlib/write_pg.c:236
+#: ../lib/vector/Vlib/read_nat.c:144 ../lib/vector/Vlib/write_nat.c:182
+#: ../lib/vector/Vlib/write_nat.c:295 ../lib/vector/Vlib/write_nat.c:397
+#: ../lib/vector/Vlib/write_nat.c:652 ../lib/vector/Vlib/write_pg.c:236
#: ../lib/vector/Vlib/write_pg.c:381 ../lib/vector/Vlib/write_pg.c:396
#: ../lib/vector/Vlib/box.c:213 ../lib/vector/Vlib/read.c:173
-#: ../lib/vector/Vlib/write_sfa.c:159 ../lib/vector/Vlib/write_sfa.c:208
+#: ../lib/vector/Vlib/write_sfa.c:158 ../lib/vector/Vlib/write_sfa.c:207
#: ../lib/vector/Vlib/read_pg.c:331 ../lib/vector/Vlib/read_sfa.c:50
#, fuzzy, c-format
msgid "Attempt to access feature with invalid id (%d)"
msgstr "%s: ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
ÙÙ Ø§ÙØ·Ø¨ÙغراÙÙØ© ÙÙÙØªØ§Ø¨Ø©\n"
-#: ../lib/vector/Vlib/read_nat.c:150 ../lib/vector/Vlib/write_nat.c:302
-#: ../lib/vector/Vlib/write_nat.c:659 ../lib/vector/Vlib/write_pg.c:242
+#: ../lib/vector/Vlib/read_nat.c:150 ../lib/vector/Vlib/write_nat.c:301
+#: ../lib/vector/Vlib/write_nat.c:658 ../lib/vector/Vlib/write_pg.c:242
#: ../lib/vector/Vlib/write_pg.c:402 ../lib/vector/Vlib/write_pg.c:2584
#: ../lib/vector/Vlib/write_pg.c:2681 ../lib/vector/Vlib/read_pg.c:337
#: ../lib/vector/Vlib/read_sfa.c:56
@@ -6932,7 +6932,7 @@
#: ../lib/vector/Vlib/write_pg.c:196 ../lib/vector/Vlib/write_pg.c:294
#: ../lib/vector/Vlib/write_pg.c:354 ../lib/vector/Vlib/write_pg.c:476
#: ../lib/vector/Vlib/area.c:94 ../lib/vector/Vlib/area.c:499
-#: ../lib/vector/Vlib/write_sfa.c:307 ../lib/vector/Vlib/build_sfa.c:718
+#: ../lib/vector/Vlib/write_sfa.c:306 ../lib/vector/Vlib/build_sfa.c:718
#: ../lib/vector/Vlib/simple_features.c:336 ../lib/vector/Vlib/close.c:275
#: ../lib/vector/Vlib/header_finfo.c:47 ../lib/vector/Vlib/header_finfo.c:86
#: ../lib/vector/Vlib/header_finfo.c:123 ../lib/vector/Vlib/header_finfo.c:171
@@ -7132,17 +7132,17 @@
msgid "Output vector map <%s> is used as input"
msgstr "Ù
ستخدÙ
ÙÙ
دخ٠'%s' اÙÙÙÙØªÙر اÙÙ
خرج"
-#: ../lib/vector/Vlib/write_nat.c:404
+#: ../lib/vector/Vlib/write_nat.c:403
#, fuzzy, c-format
msgid "Attempt to access alive feature %d"
msgstr "%s: ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
-#: ../lib/vector/Vlib/write_nat.c:568 ../lib/vector/Vlib/write_nat.c:604
+#: ../lib/vector/Vlib/write_nat.c:567 ../lib/vector/Vlib/write_nat.c:603
#, c-format
msgid "%s: Area %d does not exist"
msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:758
+#: ../lib/vector/Vlib/write_nat.c:757
#, fuzzy, c-format
msgid "Attempt to access dead area %d"
msgstr "%s: ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
@@ -7240,7 +7240,7 @@
msgstr ""
#: ../lib/vector/Vlib/write_pg.c:187 ../lib/vector/Vlib/write_pg.c:255
-#: ../lib/vector/Vlib/write_sfa.c:165 ../lib/vector/Vlib/write_ogr.c:96
+#: ../lib/vector/Vlib/write_sfa.c:164 ../lib/vector/Vlib/write_ogr.c:96
#, fuzzy
msgid "Unable to rewrite feature (incompatible feature types)"
msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØ§Ø¨Ø© Ø§ÙØ®Ø·"
@@ -7273,7 +7273,7 @@
msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
#: ../lib/vector/Vlib/write_pg.c:554 ../lib/vector/Vlib/write_pg.c:1294
-#: ../lib/vector/Vlib/write_sfa.c:350
+#: ../lib/vector/Vlib/write_sfa.c:349
msgid "Boundary is not closed. Skipping."
msgstr ""
@@ -7898,17 +7898,17 @@
msgid "Unable to calculate centroid for area"
msgstr "ÙÙ
ÙÙ
Ù٠تÙÙÙØ± Ø°Ø§ÙØ±Ø© ÙØ§ÙÙØ©\n"
-#: ../lib/vector/Vlib/write_sfa.c:131 ../lib/vector/Vlib/write_sfa.c:174
-#: ../lib/vector/Vlib/write_sfa.c:274 ../lib/vector/Vlib/read_sfa.c:124
+#: ../lib/vector/Vlib/write_sfa.c:131 ../lib/vector/Vlib/write_sfa.c:173
+#: ../lib/vector/Vlib/write_sfa.c:273 ../lib/vector/Vlib/read_sfa.c:124
msgid "GRASS is not compiled with OGR/PostgreSQL support"
msgstr ""
-#: ../lib/vector/Vlib/write_sfa.c:220
+#: ../lib/vector/Vlib/write_sfa.c:219
#, fuzzy
msgid "Attempt to delete dead feature"
msgstr "%s: ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
-#: ../lib/vector/Vlib/write_sfa.c:312
+#: ../lib/vector/Vlib/write_sfa.c:311
#, fuzzy, c-format
msgid "Unsupported vector map format (%d)"
msgstr "Ù
Ø³ÙØ· ØºÙØ± Ù
عرÙÙ"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_cs.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_cs.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_cs.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -14,7 +14,7 @@
msgstr ""
"Project-Id-Version: grasslibs_cs\n"
"PO-Revision-Date: 2010-03-07 15:47+0100\n"
"Last-Translator: \n"
"Language-Team: <cs at li.org>\n"
@@ -1205,7 +1205,7 @@
@@ -2134,17 +2134,17 @@
msgstr "VytváÅenà grafu ..."
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - promÄnná nenà nastavena"
#, python-format
msgid ""
@@ -2153,106 +2153,106 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "NápovÄda pro pÅÃkaz [%s] nenà dostupná\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Nelze spustit ovladaÄ <%s>"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "nic"
#, fuzzy
msgstr "Nelze otevÅÃt doÄasný soubor"
msgstr "Typ prvku OGR %d nenà podporován"
msgstr ""
#, python-format
msgid ""
@@ -2262,15 +2262,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -7030,19 +7030,19 @@
msgstr "Nelze smazat adresáŠ'%s'"
#, fuzzy, c-format
msgstr "Pokus o odstranÄnà mrtvé plochy"
@@ -7079,7 +7079,7 @@
@@ -7279,17 +7279,17 @@
msgstr "Výstupnà mapa <%s> je použita jako vstup."
#, fuzzy, c-format
msgstr "Pokus o oživenà prvku"
#, c-format
msgstr "%s:Plocha %d neexistuje"
#, fuzzy, c-format
@@ -7386,7 +7386,7 @@
msgstr "Chybný smÄr linie ve Vect_net_get_line_cost()"
#, fuzzy
msgstr "Nelze zapsat prvek (záporný offset)"
@@ -7419,7 +7419,7 @@
msgstr "Nelze pÅepsat prvek %d"
msgstr ""
@@ -8044,16 +8044,16 @@
msgstr "Nemohu urÄit centroid pro plochu %d"
msgstr ""
#, fuzzy, c-format
msgstr "Neznámá Location"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_de.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_de.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_de.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -12,7 +12,7 @@
msgstr ""
"Project-Id-Version: grasslibs_de\n"
"PO-Revision-Date: 2014-08-13 11:57+0200\n"
"Last-Translator: Robert Nuske <robert.nuske nw-fva.de>\n"
"Language-Team: German <grass-translations at lists.osgeo.org>\n"
@@ -1204,7 +1204,7 @@
@@ -2124,17 +2124,17 @@
msgstr "Erzeuge Graphen..."
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - Variable nicht gesetzt."
#, python-format
msgid ""
@@ -2143,105 +2143,105 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "Leider keine Hilfe für den Befehl [%s] verfügbar.\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Kann den Treiber <%s> nicht starten."
#, python-format
msgstr ""
msgstr ""
msgid "Done."
msgstr "Erledigt."
#, fuzzy
msgstr "Kann temporäre Datei nicht öffnen."
msgstr "OGR Objekttyp %d wird nicht unterstützt."
msgstr ""
#, python-format
msgid ""
@@ -2251,15 +2251,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -6997,19 +6997,19 @@
msgstr "Kann das Verzeichnis '%s' nicht löschen."
#, fuzzy, c-format
msgstr "Versuche ein totes Objekt zu löschen"
@@ -7046,7 +7046,7 @@
@@ -7249,17 +7249,17 @@
msgstr "Ausgabe-Vektorkarte <%s> als Eingabe verwendet."
#, fuzzy, c-format
msgstr "Versuche lebendes Objekt wiederherzustellen."
#, c-format
msgstr "%s: Fläche %d existiert nicht."
#, fuzzy, c-format
@@ -7358,7 +7358,7 @@
msgstr "Falsche Linienrichtung in Vect_net_get_line_cost()."
#, fuzzy
msgstr "Kann die Linie nicht schreiben (negativer Offset)."
@@ -7391,7 +7391,7 @@
msgstr "Kann Objekt %d nicht schreiben."
msgstr ""
@@ -8017,16 +8017,16 @@
msgstr "Kann keinen Zentroid für die Fläche %d berechnen."
msgstr ""
msgstr "Versuche totes Objekt zu löschen."
#, fuzzy, c-format
msgstr "unbekannt"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_el.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_el.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_el.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_el\n"
"PO-Revision-Date: 2008-10-16 11:25+0300\n"
"Last-Translator: Vasilios Antoniou <antoniou_v at yahoo.gr>\n"
"Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
@@ -1219,7 +1219,7 @@
@@ -2156,17 +2156,17 @@
msgstr "ÎημιοÏ
Ïγία εÏιÏανειÏν"
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - η ÏαÏάμεÏÏÎ¿Ï Î´ÎµÎ½ ÎÏει καθοÏιÏÏεί"
#, python-format
msgid ""
@@ -2175,105 +2175,105 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "Îεν Ï
ÏάÏÏει κείμενο Î²Î¿Î®Î¸ÎµÎ¹Î±Ï Î³Î¹Î± Ïην ενÏολή [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "ÎδÏ
ναμία εκκίνηÏÎ·Ï ÏοÏ
Î¿Î´Î·Î³Î¿Ï <%s>"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "κανÎνα"
msgstr ""
msgstr "Î 3Î ÏάÏÏÎ·Ï raster <%s> δεν βÏÎθηκε"
msgstr ""
#, python-format
msgid ""
@@ -2283,15 +2283,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -7086,19 +7086,19 @@
msgstr "ÎδÏ
ναμία μεÏαÏοÏÎ¬Ï ÎºÎ±ÏαλÏγοÏ
ÏÏ
ÏÏήμαÏÎ¿Ï '%s'"
#, fuzzy, c-format
msgstr "Î ÏοÏÏάθεια διαγÏαÏÎ®Ï Î»Î¬Î¸Î¿Ï ÏÏοιÏείÏν"
@@ -7135,7 +7135,7 @@
@@ -7343,17 +7343,17 @@
"ΠεξαγÏÎ¼ÎµÎ½Î¿Ï Î´Î¹Î±Î½Ï
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> ÏÏηÏιμοÏοιείÏαι για ειÏαγÏγή "
"δεδομÎνÏν."
#, fuzzy, c-format
msgstr "Î ÏοÏÏάθεια αÏοκαÏάÏÏαÏÎ·Ï ÏÏÏÏÏν ÏÏοιÏείÏν"
#, c-format
msgstr "%s: ÎÏιδάνεια %d δεν Ï
ÏάÏÏει"
#, fuzzy, c-format
@@ -7445,7 +7445,7 @@
msgstr ""
#, fuzzy
msgstr "ÎδÏ
ναμία εγγÏαÏή feature (αÏνηÏÎ¹ÎºÏ offset)"
@@ -7478,7 +7478,7 @@
msgstr "ÎδÏ
ναμία εÏανεγγÏαÏÎ®Ï feature %d"
msgstr ""
@@ -8106,16 +8106,16 @@
msgstr "ÎδÏ
ναμία Ï
ÏολογιÏÎ¼Î¿Ï ÎºÎνÏÏÏν ÏολÏ
γÏνοÏ
για Ïην εÏιÏάνεια %d"
msgstr ""
#, fuzzy, c-format
msgstr "ÎγνÏÏÏÎ¿Ï ÏελεÏÏήÏ"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_es.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_es.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_es.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -16,7 +16,7 @@
msgstr ""
"Project-Id-Version: grasslibs_es\n"
"PO-Revision-Date: 2014-12-10 20:31-0600\n"
"Last-Translator: Daniel Torres <nobeeakon at gmail.com>\n"
"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -1271,7 +1271,7 @@
@@ -2207,17 +2207,17 @@
msgstr "Construyendo grafica..."
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - variable no establecida."
#, python-format
msgid ""
@@ -2226,107 +2226,107 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr "Ejecutando '%s'..."
#, python-format
msgstr "La ejecución de '%s' ha terminado."
#, python-format
msgstr "La GUI de GRASS deberÃa ser <%s>"
msgstr "Bienvenido a GRASS %s"
#, fuzzy
msgstr "Página de inicio de GRASS:"
msgstr "Esta versión corriendo a través de:"
#, fuzzy
msgstr "No hay ayuda disponible para el comando [%s].\n"
msgstr "Vea los términos de la licencia con:"
msgstr "Si lo necesita, reinicie la GUI con:"
msgstr "Iniciar GUI con:"
msgstr "En cuanto esté listo para quitar escriba:"
msgstr "MÃSCARAS ráster 2D y 3D presentes"
msgstr "MÃSCARA ráster presente"
msgstr ""
msgstr "No ha sido posible iniciar el controlador <%s>."
#, python-format
msgstr ""
msgstr "Adios de GRASS GIS"
#, fuzzy
msgid "Done."
msgstr "Ninguno."
#, fuzzy
msgstr "No se puede abrir el archivo temporal."
msgstr "No se soportan objetos espaciales del tipo %d OGR"
msgstr ""
#, python-format
msgid ""
@@ -2341,15 +2341,15 @@
" - Lanzar GRASS con la ruta para localización/directorio de mapas (mapset) "
"como un argumento (`grass70 /pruta/a/localización/directorio de mapas`)"
msgstr "Creando nueva localización/directorio de mapas (mapset)..."
msgstr "Iniciando GRASS GIS..."
#, python-format
msgstr ""
@@ -7321,19 +7321,19 @@
msgstr "No se puede eliminar el directorio '%s'."
#, fuzzy, c-format
msgstr "Intento de borrar un razgo u objeto espacial inexistente."
@@ -7371,7 +7371,7 @@
@@ -7586,17 +7586,17 @@
msgstr "El mapa vectorial de salida <%s> es usado como entrada."
#, fuzzy, c-format
msgstr "Ha intentado restaurar una razgo u objeto espacial existente."
#, c-format
msgstr "%s: El área %d no existe."
#, fuzzy, c-format
@@ -7698,7 +7698,7 @@
msgstr "Dirección de la lÃnea incorrecta en Vect_net_get_line_cost()."
#, fuzzy
msgstr "No se puede escribirel razgo (desplazamiento negativo)."
@@ -7731,7 +7731,7 @@
msgstr "No se puede reescribir el el objeto espacial %d."
msgstr ""
@@ -8368,16 +8368,16 @@
msgstr "No ha sido posible calcular el centróide del área %d."
msgstr ""
#, fuzzy, c-format
msgstr "operador desconocido"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_fr.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_fr.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_fr.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -11,7 +11,7 @@
msgstr ""
"Project-Id-Version: grasslibs_fr\n"
"PO-Revision-Date: 2014-06-01 00:12+0100\n"
"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: French <grass-translations at lists.osgeo.org>\n"
@@ -1236,7 +1236,7 @@
@@ -2162,17 +2162,17 @@
msgstr "Construction du graphique ..."
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - variable sans valeur"
#, python-format
msgid ""
@@ -2181,106 +2181,106 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "Aucune aide disponible pour la commande [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Impossible d'ouvrir le fichier statistique <%s>"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "Aucun"
#, fuzzy
msgstr "Impossible d'ouvrir le fichier temporaire"
msgstr "Le type d'objet OGR %d n'est pas géré"
msgstr ""
#, python-format
msgid ""
@@ -2290,15 +2290,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -7122,19 +7122,19 @@
msgstr "Impossible de supprimer le répertoire '%s'"
#, fuzzy, c-format
msgstr "Tentative de supprimer une surface morte"
@@ -7171,7 +7171,7 @@
@@ -7379,17 +7379,17 @@
msgstr "La couche vectorielle de sortie <%s> est utilisée en entrée"
#, fuzzy, c-format
msgstr "Tentative de restauration d'une entité morte"
#, c-format
msgstr "%s: la surface %d n'existe pas"
#, fuzzy, c-format
@@ -7488,7 +7488,7 @@
msgstr "Mauvaise ligne de direction dans Vect_net_get_line_cost()"
#, fuzzy
msgstr "Impossible d'écrire la ligne (décalage négatif)"
@@ -7521,7 +7521,7 @@
msgstr "Impossible d'écrire la ligne matricielle %i"
msgstr ""
@@ -8152,16 +8152,16 @@
msgstr "Impossible de calculer le centroïde de l'entité surfacique %d"
msgstr ""
msgstr "Tentative de suppression d'une entité morte"
#, fuzzy, c-format
msgstr "Erreur inconnue"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_it.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_it.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_it.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -13,7 +13,7 @@
msgstr ""
"Project-Id-Version: grasslibs_it\n"
"PO-Revision-Date: 2013-02-03 12:21+0100\n"
"Last-Translator: Luca Delucchi <lucadeluge at gmail.com>\n"
"Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
@@ -1209,7 +1209,7 @@
@@ -2130,17 +2130,17 @@
msgstr "Creazione topologia...\n"
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - variabile non impostata"
#, python-format
msgid ""
@@ -2149,106 +2149,106 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "Nessun aiuto disponibile per il comando [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Impossibile aprire il file %s in %s"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "nessuno"
#, fuzzy
msgstr "Tipo %d di feature OGR non supportato"
msgstr ""
#, python-format
msgid ""
@@ -2258,15 +2258,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -7020,19 +7020,19 @@
msgstr "Impossibile rimuovere la directory '%s'"
#, fuzzy, c-format
msgstr "Tentativo di cancellare feature inesistente"
@@ -7068,7 +7068,7 @@
@@ -7270,17 +7270,17 @@
msgstr "Vettoriale <%s> di output è utilizzata come input"
#, fuzzy, c-format
msgstr "Tentativo di ripristinare feature esistente"
#, c-format
msgstr "%s: Area %d non esiste"
#, fuzzy, c-format
@@ -7374,7 +7374,7 @@
msgstr "Direzione sbagliata della linea in Vect_net_get_line_cost()"
#, fuzzy
msgstr "Non posso scrivere la linea (scostamento negativo)"
@@ -7407,7 +7407,7 @@
msgstr "Impossibile riscrivere l'elemento %d"
msgstr ""
@@ -8030,16 +8030,16 @@
msgstr "Impossibile calcolare il centroide per l'area %d"
msgstr ""
#, fuzzy, c-format
msgstr "errore sconosciuto"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_ja.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_ja.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_ja.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -12,7 +12,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ja\n"
"PO-Revision-Date: 2012-03-05 12:14+0900\n"
"Last-Translator: Naoki Ueda <nao at locapoint.com>\n"
"Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
@@ -1186,7 +1186,7 @@
@@ -2112,17 +2112,17 @@
msgstr "ã°ã©ãã使ãã¦ãã¾ã..."
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - 夿°ãè¨å®ããã¦ãã¾ãã"
#, python-format
msgid ""
@@ -2131,106 +2131,106 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "ã³ãã³ãã®ãã«ããå©ç¨ã§ãã¾ãã [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "ãã©ã¤ãã¼ <%s> ãã¹ã¿ã¼ãã§ãã¾ãã"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "ç¡ã"
#, fuzzy
msgstr "䏿ãã¡ã¤ã«ãéãã¾ãã"
msgstr "OGRãã£ã¼ãã£ã¿ã¤ã %d ã¯ãµãã¼ãããã¾ãã"
msgstr ""
#, python-format
msgid ""
@@ -2240,15 +2240,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -6960,19 +6960,19 @@
msgstr "ãã£ã¬ã¯ã㪠'%s' ãåé¤ã§ãã¾ãã"
#, fuzzy, c-format
msgstr "ä¸è¦ãªãã£ã¼ãã£ãåé¤ãããã¨ãã¦ãã¾ã"
@@ -7008,7 +7008,7 @@
@@ -7209,17 +7209,17 @@
msgstr "åºåãããã¯ãã«ããã <%s> ã¯å
¥åã¨ãã¦ä½¿ããã¾ã"
#, fuzzy, c-format
msgstr "æå¹ãªãã£ã¼ãã£ã修復ãããã¨ãã¦ãã¾ã"
#, c-format
msgstr "%s: ã¨ãªã¢ %d ã¯åå¨ãã¾ãã"
#, fuzzy, c-format
@@ -7319,7 +7319,7 @@
msgstr "Vect_net_get_line_cost() ã«ãããã©ã¤ã³ã®æ¹åã¯æ£ããããã¾ãã"
#, fuzzy
msgstr "�������: ����� �����������n"
@@ -7352,7 +7352,7 @@
msgstr "ãã£ã¼ãã£ã¼ %d ãæ¸ãè¾¼ãã¾ãã"
msgstr ""
@@ -7972,16 +7972,16 @@
msgstr "é å %d ã®ã»ã³ããã¤ããè¨ç®ã§ãã¾ãã"
msgstr ""
#, fuzzy, c-format
msgstr "䏿ãªãã¯ãã«ã¿ã¤ã"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_ko.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_ko.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_ko.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ko\n"
"PO-Revision-Date: 2013-10-30 22:07-0500\n"
"Last-Translator: Huidae Cho <grass4u at gmail.com>\n"
"Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
@@ -1182,7 +1182,7 @@
@@ -2066,16 +2066,16 @@
msgstr ""
#, python-format
msgstr ""
msgstr ""
#, python-format
msgid ""
@@ -2084,103 +2084,103 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Datum %s í
ì´ë¸íì¼ì ì´ ì ììµëë¤"
#, python-format
msgstr ""
msgstr ""
msgid "Done."
msgstr ""
msgstr ""
#, python-format
msgstr ""
msgstr ""
#, python-format
msgid ""
@@ -2190,15 +2190,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -6759,19 +6759,19 @@
msgstr "Datum %s í
#, fuzzy, c-format
msgstr "ììíì¼ì ì´ ì ììµëë¤"
@@ -6807,7 +6807,7 @@
@@ -7004,17 +7004,17 @@
msgstr ""
#, fuzzy, c-format
#, c-format
msgstr ""
#, fuzzy, c-format
@@ -7108,7 +7108,7 @@
msgstr ""
#, fuzzy
msgstr "ìë MASKíì¼ì ì´ ì ììµëë¤"
@@ -7140,7 +7140,7 @@
msgstr "Datum %s í
msgstr ""
@@ -7755,17 +7755,17 @@
msgstr "Datum %s í
msgstr ""
#, fuzzy
#, fuzzy, c-format
msgstr "ìë ¤ì§ì§ ìì 벡í°íì
ì
ëë¤"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_lv.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_lv.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_lv.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasslibs_lv\n"
"PO-Revision-Date: 2014-09-10 12:12+0300\n"
"Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
"Language-Team: Latvian\n"
@@ -1183,7 +1183,7 @@
@@ -2080,16 +2080,16 @@
msgstr ""
#, python-format
msgstr ""
msgstr ""
#, python-format
msgid ""
@@ -2098,107 +2098,107 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr "Laipni lūdzam GRASS %s"
#, fuzzy
msgstr "GRASS mÄjas lapa:"
msgstr ""
msgstr "Palīdzība ir pieejama ar komandu:"
msgstr "Licences informÄcija ir pieejama:"
msgstr ""
msgstr "GrafiskÄs vides startÄÅ¡ana: "
msgstr "Lai izietu, izpildiet:"
#, fuzzy
msgstr "[Ir rastra MASKa]"
#, fuzzy
#, fuzzy
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr "Uz redzÄÅ¡anos"
msgid "Done."
msgstr "Pabeigts."
msgstr "Satīra pagaidu failus..."
#, python-format
msgstr "Parametrs <%s> nav atbalstīts"
msgstr ""
#, python-format
msgid ""
@@ -2208,15 +2208,15 @@
msgstr ""
msgstr ""
msgstr "StartÄ GRASS GIS..."
#, python-format
msgstr "StartÄ <%s> grafisko vidi fona režīmÄ. LÅ«dzu uzgaidiet..."
@@ -6880,19 +6880,19 @@
msgstr "neispÄjami mainÄ«t direktoriju uz %s"
#, fuzzy, c-format
msgstr "Nevar nolasīt histogrammu priekš [%s no %s]"
@@ -6929,7 +6929,7 @@
@@ -7128,17 +7128,17 @@
msgstr "Izejas karte '%s' tiek lietota kÄ iejas karte"
#, fuzzy, c-format
#, c-format
msgstr ""
#, fuzzy, c-format
@@ -7234,7 +7234,7 @@
"Nebija iespÄjams izveidot jaunu novietojumu. Novietojums <%s> jau eksistÄ."
msgstr ""
@@ -7264,7 +7264,7 @@
msgstr "NeiespÄjami atvÄrt failu %s iekÅ¡ %s"
msgstr "Robeža nav noslÄgta. Izlaižam."
@@ -7872,16 +7872,16 @@
msgstr ""
msgstr ""
msgstr "MÄÄ£inÄjums dzÄst miruÅ¡u objektu"
#, c-format
msgstr "NeatbalstÄ«ts vektoru kartes formÄts (%d)"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_ml.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_ml.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_ml.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ml\n"
"PO-Revision-Date: 2010-08-24 11:31+0530\n"
"Last-Translator: Mohammed Rashad <rashadkm at gmail.com>\n"
"Language-Team: GRASS Malayalam Translation Team <rashadkm at gmail.com>\n"
@@ -1172,7 +1172,7 @@
@@ -2059,16 +2059,16 @@
msgstr "à´à´¤àµà´°à´¯à´³à´µàµ പണിയàµà´¨àµà´¨àµ..."
#, python-format
msgstr ""
msgstr ""
#, python-format
msgid ""
@@ -2077,103 +2077,103 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "à´¡àµà´°à´¯àµà´µàµà´µàµ¼ à´¤àµà´à´àµà´à´¾àµ» സാധിà´àµà´àµà´¨àµà´¨à´¿à´²àµà´² <%s>"
#, python-format
msgstr ""
msgstr ""
msgid "Done."
msgstr ""
msgstr ""
msgstr "റാസàµà´±àµà´±àµàµ¼ മാപàµà´ªàµ <%s> à´à´£àµà´®à´¾à´¨à´¿à´²àµà´²"
msgstr ""
#, python-format
msgid ""
@@ -2183,15 +2183,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -6720,19 +6720,19 @@
msgstr ""
#, fuzzy, c-format
msgstr "à´µàµà´àµà´±àµà´±àµ¼ മാപàµà´ªàµ വായിà´àµà´à´¾àµ» à´ªà´àµà´àµà´¨àµà´¨à´¿à´²àµà´²"
@@ -6768,7 +6768,7 @@
@@ -6966,17 +6966,17 @@
msgstr ""
#, fuzzy, c-format
#, c-format
msgstr ""
#, fuzzy, c-format
msgstr ""
msgstr ""
@@ -7102,7 +7102,7 @@
msgstr ""
@@ -7709,16 +7709,16 @@
msgstr "à´µàµà´àµà´±àµà´±àµ¼ à´
à´à´¯àµà´àµà´à´¾àµ» പറàµà´±àµà´¨àµà´¨à´¿à´²àµà´² <%s>"
msgstr ""
msgstr ""
#, fuzzy, c-format
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_pl.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_pl.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_pl.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_pl\n"
"PO-Revision-Date: 2013-07-16 15:42+0100\n"
"Last-Translator: Milena Nowotarska <do.milenki * gmail.com>\n"
"Language-Team: GRASS Translation Team\n"
@@ -1198,7 +1198,7 @@
@@ -2094,17 +2094,17 @@
msgstr "Tworzenie obszarów..."
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - brak ustawieÅ zmiennych"
#, python-format
msgid ""
@@ -2113,104 +2113,104 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Nie można uruchomiÄ sterownika <%s>"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "brak"
msgstr ""
msgstr "Obiekty OGR typu %d nie sÄ
obsÅugiwane"
msgstr ""
#, python-format
msgid ""
@@ -2220,15 +2220,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -6933,19 +6933,19 @@
msgstr "Nie można usunÄ
Ä katalogu '%s'"
#, fuzzy, c-format
msgstr "Próba usuniÄcia martwego obiektu"
@@ -6982,7 +6982,7 @@
@@ -7183,17 +7183,17 @@
msgstr "WyjÅciowa mapa wektorowa <%s> jest użyta jako dane wejÅciowe"
#, fuzzy, c-format
msgstr "Próba odzyskania istniejÄ
cego obiektu"
#, c-format
msgstr "%s: Obszar %d nie istnieje"
#, fuzzy, c-format
@@ -7292,7 +7292,7 @@
msgstr "BÅÄdny kierunek linii w Vect_net_get_line_cost()"
#, fuzzy
msgstr "Nie można zapisaÄ obiektu (negative offset)"
@@ -7325,7 +7325,7 @@
msgstr "Nie można ponownie zapisaÄ obiektu %d"
msgstr ""
@@ -7952,16 +7952,16 @@
msgstr "Nie można obliczyÄ centroidu obszaru %d"
msgstr ""
#, fuzzy, c-format
msgstr "nieznany operator"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_pt.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_pt.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_pt.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -10,7 +10,7 @@
msgstr ""
"Project-Id-Version: grasslibs_pt\n"
"PO-Revision-Date: 2013-12-22 16:37+0200\n"
"Last-Translator: luisa <gem12lte at student.lu.se>\n"
"Language-Team: gem12lte at student.lu.se\n"
@@ -1217,7 +1217,7 @@
@@ -2148,17 +2148,17 @@
msgstr "Construindo grafo ..."
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - variável não incializada"
#, python-format
msgid ""
@@ -2167,106 +2167,106 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "No há ajuda disponível para o comando [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Impossível abrir arquivo %s"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "nenhum"
#, fuzzy
msgstr "não consegui abrir arquivo temporário"
msgstr "Feição OGR tipo %d não suportada)"
msgstr ""
#, python-format
msgid ""
@@ -2276,15 +2276,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -7048,19 +7048,19 @@
msgstr "Não foi possível remover o diretório '%s'"
#, fuzzy, c-format
msgstr "Tentativa de remover área morta"
@@ -7097,7 +7097,7 @@
@@ -7298,17 +7298,17 @@
msgstr "Mapa vectorial de saída <%s> usado como entrada"
#, fuzzy, c-format
#, c-format
msgstr "%s: Área %d não existe"
#, fuzzy, c-format
@@ -7406,7 +7406,7 @@
msgstr "Direção errada da linha em Vect_net_get_line_cost()"
#, fuzzy
msgstr "não consegui escrever a linha (deslocamento negativo)"
@@ -7439,7 +7439,7 @@
msgstr ""
@@ -8061,16 +8061,16 @@
msgstr "não consegui calcular centróide para área %d"
msgstr ""
msgstr "Tentativa de remover elemento morto"
#, fuzzy, c-format
msgstr "Erro desconhecido"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_pt_br.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_pt_br.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_pt_br.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -10,7 +10,7 @@
msgstr ""
"Project-Id-Version: grasslibs_pt_br\n"
"PO-Revision-Date: 2007-05-20 10:44-0300\n"
"Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail.com>\n"
"Language-Team: Brazilian Portuguese <grass-translations at lists.osgeo.org>\n"
@@ -1207,7 +1207,7 @@
@@ -2122,17 +2122,17 @@
msgstr "Criando topologia ...\n"
#, python-format
msgstr ""
#, fuzzy
#, python-format
msgid ""
@@ -2141,106 +2141,106 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "não foi possível abrir o arquivo %s em %s"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "nenhum"
#, fuzzy
msgstr ""
#, python-format
msgid ""
@@ -2250,15 +2250,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -6958,19 +6958,19 @@
msgstr "Impossível mudar de diretório para %s"
#, fuzzy, c-format
@@ -7007,7 +7007,7 @@
@@ -7205,17 +7205,17 @@
msgstr "Mapa de saída '%s' usado como entrada"
#, fuzzy, c-format
#, c-format
msgstr ""
#, fuzzy, c-format
@@ -7313,7 +7313,7 @@
msgstr ""
#, fuzzy
@@ -7346,7 +7346,7 @@
msgstr ""
@@ -7978,17 +7978,17 @@
msgstr ""
#, fuzzy
#, fuzzy, c-format
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_ro.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_ro.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_ro.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ro\n"
"PO-Revision-Date: 2013-11-21 22:05+0200\n"
"Last-Translator: Mihai Moise\n"
"Language-Team: GRASS Translation Team <grass-translations at lists.osgeo.org>\n"
@@ -1176,7 +1176,7 @@
@@ -2079,16 +2079,16 @@
msgstr ""
#, python-format
msgstr ""
msgstr ""
#, python-format
msgid ""
@@ -2097,103 +2097,103 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgid "Done."
msgstr ""
msgstr ""
msgstr "rasterul 3D <%s> nu a fost gÄsit"
msgstr ""
#, python-format
msgid ""
@@ -2203,15 +2203,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -6805,19 +6805,19 @@
msgstr ""
#, c-format
msgstr ""
@@ -6852,7 +6852,7 @@
@@ -7048,17 +7048,17 @@
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
@@ -7150,7 +7150,7 @@
msgstr ""
msgstr ""
@@ -7182,7 +7182,7 @@
msgstr "Nu s-a putut crea rasterul <%s>"
msgstr ""
@@ -7782,16 +7782,16 @@
msgstr "Nu s-a putut aloca fluxul"
msgstr ""
msgstr ""
#, c-format
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_ru.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_ru.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_ru.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ru\n"
"PO-Revision-Date: 2009-01-27 22:58-0600\n"
"Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
"Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
@@ -1197,7 +1197,7 @@
msgstr "ÐоÑÑÑоение гÑаÑа..."
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - пеÑÐµÐ¼ÐµÐ½Ð½Ð°Ñ Ð½Ðµ ÑÑÑановлена"
#, python-format
msgid ""
@@ -2143,106 +2143,106 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "ÐÐµÑ ÑпÑавки Ð´Ð»Ñ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Ðевозможен запÑÑк дÑайвеÑа <%s>"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "неÑ"
#, fuzzy
msgstr "Ðевозможно оÑкÑÑÑÑ Ð²ÑеменнÑй Ñайл"
msgstr "Ñип даннÑÑ
OGR %d не поддеÑживаеÑÑÑ"
msgstr ""
#, python-format
msgid ""
@@ -2252,15 +2252,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -7029,19 +7029,19 @@
msgstr "Ðевозможно ÑдалиÑÑ Ð¿Ð°Ð¿ÐºÑ '%s'"
#, fuzzy, c-format
msgstr "ÐопÑÑка ÑдалиÑÑ Ñже ÑдаленнÑй обÑекÑ"
@@ -7078,7 +7078,7 @@
msgstr "ÐÑÑ
одной векÑоÑнÑй Ñлой <%s> иÑполÑзÑеÑÑÑ ÐºÐ°Ðº иÑÑ
однÑй"
#, fuzzy, c-format
msgstr "ÐопÑÑка воÑÑÑановиÑÑ Ð½Ð¾ÑмалÑнÑй обÑекÑ"
#, c-format
msgstr "%s: Ðолигон %d не ÑÑÑеÑÑвÑеÑ"
#, fuzzy, c-format
@@ -7385,7 +7385,7 @@
msgstr "ÐепÑавилÑное напÑавление линии в Vect_net_get_line_cost()"
#, fuzzy
msgstr "Ðевозможно запиÑаÑÑ Ð¾Ð±ÑÐµÐºÑ (оÑÑиÑаÑелÑное ÑмеÑение)"
@@ -7418,7 +7418,7 @@
msgstr "Ðевозможно пеÑезапиÑаÑÑ Ð¾Ð±ÑÐµÐºÑ %d"
msgstr ""
@@ -8045,16 +8045,16 @@
msgstr "Ðевозможно ÑаÑÑÑиÑаÑÑ ÑенÑÑоид Ð´Ð»Ñ Ð¿Ð¾Ð»Ð¸Ð³Ð¾Ð½Ð° %d"
msgstr ""
#, fuzzy, c-format
msgstr "неизвеÑÑнÑй опеÑаÑоÑ"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_sl.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_sl.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_sl.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_sl\n"
"PO-Revision-Date: 2005-04-26 09:38+0200\n"
"Last-Translator: Miha Staut <mihastaut at yahoo.co.uk>\n"
"Language-Team: Sloven¹èina <grass-translations at lists.osgeo.org>\n"
msgstr "Gradim topologijo ...\n"
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - spremenljivka ni nastavljena"
#, python-format
msgid ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "Za ukaz [%s] ni na voljo pomoèi\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Nezmo¾en odpreti datoteko %s v %s"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "ga ni"
#, fuzzy
msgstr "Ne morem odpreti temp datoteke"
msgstr "Vneseni vektor '%s' ni bil najden"
msgstr ""
#, python-format
msgid ""
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -6959,19 +6959,19 @@
msgstr "ne morem spremeniti direktorija v %s"
#, fuzzy, c-format
msgstr "Ne morem prebrati histograma za [%s v %s]"
@@ -7207,17 +7207,17 @@
msgstr "Izhodni sloj '%s' je uporabljen kot vhodni"
#, fuzzy, c-format
#, c-format
msgstr ""
#, fuzzy, c-format
@@ -7315,7 +7315,7 @@
msgstr ""
#, fuzzy
msgstr "Ne morem zapisati linije"
@@ -7348,7 +7348,7 @@
msgstr ""
@@ -7979,17 +7979,17 @@
msgstr "Nezmo¾en dodeliti spomin\n"
msgstr ""
#, fuzzy
#, fuzzy, c-format
msgstr "Nepoznan \"location\""
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_th.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_th.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_th.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasslibs_th\n"
"PO-Revision-Date: 2008-01-05 15:19+0700\n"
"Last-Translator: man <mansv68 at yahoo.co.th>\n"
"Language-Team: Thai <grass-translations at lists.osgeo.org>\n"
@@ -2123,17 +2123,17 @@
msgstr "สรà¹à¸²à¸ graph ..."
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - à¹à¸¡à¹à¹à¸à¹à¸à¸³à¸«à¸à¸à¸à¹à¸²à¸à¸±à¸§à¹à¸à¸¥"
#, python-format
msgid ""
@@ -2142,106 +2142,106 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "à¹à¸¡à¹à¸¡à¸µà¸à¸§à¸²à¸¡à¸à¹à¸§à¸¢à¹à¸«à¸¥à¸·à¸à¸ªà¸³à¸«à¸£à¸±à¸à¸à¸³à¸ªà¸±à¹à¸à¸à¸µà¹ [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸£à¸°à¸à¸¸à¸ªà¸ าà¸à¹à¸à¸¥à¹ <%s>"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "none"
#, fuzzy
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸´à¸ temp à¹à¸à¸¥à¹"
msgstr "à¸à¸à¸´à¸à¸à¹à¸à¸¡à¸¹à¸¥ OGR %d à¹à¸¡à¹à¸£à¸à¸à¸£à¸±à¸)"
msgstr ""
#, python-format
msgid ""
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -7004,19 +7004,19 @@
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸¥à¸ directory '%s'"
#, fuzzy, c-format
msgstr "à¸à¸±à¹à¸à¹à¸à¸à¸µà¹à¸à¸°à¸¥à¸à¸à¸·à¹à¸à¸à¸µà¹"
@@ -7053,7 +7053,7 @@
@@ -7253,17 +7253,17 @@
msgstr "à¸à¸·à¹à¸à¸à¸¥à¸¥à¸±à¸à¸à¹à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ <%s> à¸à¹à¸³à¸à¸±à¸à¸à¸·à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¸à¸³à¹à¸à¹à¸²"
#, fuzzy, c-format
#, c-format
msgstr ""
#, fuzzy, c-format
@@ -7362,7 +7362,7 @@
msgstr "à¸à¸´à¸¨à¸à¸²à¸à¸à¸´à¸à¹à¸ Vect_net_get_line_cost()"
#, fuzzy
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸à¸µà¸¢à¸ (à¸à¸³à¹à¸«à¸à¹à¸à¸à¸´à¸à¸¥à¸)"
@@ -7395,7 +7395,7 @@
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸¥à¸à¹à¸à¸¥à¹ '%s'"
msgstr ""
@@ -8027,17 +8027,17 @@
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¸à¸³à¸à¸§à¸à¸à¸¸à¸à¸¨à¸¹à¸à¸¢à¹à¸à¹à¸§à¸à¸à¸à¸à¸£à¸¹à¸à¸à¸´à¸à¹à¸à¹ %d"
msgstr ""
#, fuzzy
#, fuzzy, c-format
msgstr "à¹à¸¡à¹à¸à¸£à¸²à¸à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_tr.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_tr.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_tr.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -9,7 +9,7 @@
msgstr ""
"Project-Id-Version: grasslibs_tr\n"
"PO-Revision-Date: 2010-11-08 15:14+0200\n"
"Last-Translator: Saban Safak <ssafak at cvm.com.tr>\n"
"Language-Team: Türkçe <grass-translations at lists.osgeo.org>\n"
@@ -1177,7 +1177,7 @@
@@ -2083,17 +2083,17 @@
msgstr "Grafik oluÅturuluyor..."
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - deÄiÅken ayarlanmadı"
#, python-format
msgid ""
@@ -2102,106 +2102,106 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "[%s] komutu için yardım yoktur\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "<%s> Sürücüsü baÅlatılamıyor"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "hiçbiri"
#, fuzzy
msgstr "Geçici dosya açılamıyor"
msgstr "%d OGR obje tipi desteklenmiyor"
msgstr ""
#, python-format
msgid ""
@@ -2211,15 +2211,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -6899,19 +6899,19 @@
msgstr "'%s' dizini kaldırılamıyor "
#, fuzzy, c-format
msgstr "%d çizgisi okunamıyor"
@@ -6948,7 +6948,7 @@
@@ -7146,17 +7146,17 @@
msgstr ""
#, fuzzy, c-format
#, fuzzy, c-format
msgstr "%s: Alan %d mevcut deÄil"
#, fuzzy, c-format
@@ -7248,7 +7248,7 @@
msgstr ""
#, fuzzy
msgstr "%i raster satırı yazılamıyor"
@@ -7281,7 +7281,7 @@
msgstr ""
@@ -7899,16 +7899,16 @@
msgstr "%d alanı içinalan merkezi hesaplanamadı"
msgstr ""
msgstr ""
#, fuzzy, c-format
msgstr "bilinmeyen iÅletmen"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_vi.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_vi.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_vi.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_vi\n"
"PO-Revision-Date: 2010-08-27 11:18+0700\n"
"Language-Team: American English <kde-i18n-doc at kde.org>\n"
@@ -1202,7 +1202,7 @@
@@ -2126,17 +2126,17 @@
msgstr "Äang xây dá»±ng biá»u Äá»..."
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - biến không ÄÆ°á»£c thiết láºp"
#, python-format
msgid ""
@@ -2145,106 +2145,106 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "Không có trợ giúp cho lá»nh [%s]\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "Không thá» khá»i Äá»ng trình Äiá»u khiá»n <%s>"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "không có"
#, fuzzy
msgstr "Không thá» má» táºp tin tạm"
msgstr "Kiá»u Äá»i tượng OGR %d không ÄÆ°á»£c há» trợ"
msgstr ""
#, python-format
msgid ""
@@ -2254,15 +2254,15 @@
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -7050,19 +7050,19 @@
msgstr "Không thỠloại bỠthư mục '%s'"
#, fuzzy, c-format
msgstr "Cá» gắng xoá Äá»i tượng chết"
@@ -7099,7 +7099,7 @@
@@ -7299,17 +7299,17 @@
msgstr "Bản Äá» vec-tÆ¡ Äầu ra <%s> ÄÆ°á»£c dùng là m Äầu và o"
#, fuzzy, c-format
msgstr "Cá» gắng phục há»i lại Äá»i tượng sá»ng"
#, c-format
msgstr "%s: Vùng %d không tá»n tại"
#, fuzzy, c-format
@@ -7403,7 +7403,7 @@
msgstr "Hưá»ng cá»§a ÄÆ°á»ng bá» sai trong Vect_net_get_line_cost()"
#, fuzzy
msgstr "Không thá» ghi Äá»i tượng (Äá» dá»ch âm)"
@@ -7436,7 +7436,7 @@
msgstr "Không thá» ghi lại Äá»i tượng %d"
msgstr ""
@@ -8060,16 +8060,16 @@
msgstr "Không thá» tÃnh toán trá»ng tâm cho vùng %d"
msgstr ""
#, fuzzy, c-format
msgstr "toán tá» không hiá»u"
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_zh.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_zh.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_zh.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -9,7 +9,7 @@
msgstr ""
"Project-Id-Version: grasslibs_zh\n"
"PO-Revision-Date: 2014-04-16 12:27+0100\n"
"Last-Translator: YusiJi <jiyusi0001 at gmail.com>\n"
"Language-Team: Simplified Chinese <translations at grass.itc.it>\n"
@@ -2125,17 +2125,17 @@
msgstr "å»ºç«ææ...\n"
#, python-format
msgstr ""
#, fuzzy
msgstr "GISRC - åéæªè®¾ç½®"
#, python-format
msgid ""
@@ -2144,104 +2144,104 @@
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr "æ æ³æå¼æä»¶ %s å¨ %s ä¸"
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgid "Done."
msgstr "æ "
msgstr ""
msgstr "䏿¯æç OGR è¦ç´ ç±»å %d"
msgstr ""
#, python-format
msgid ""
msgstr ""
msgstr ""
msgstr ""
#, python-format
msgstr ""
@@ -7022,19 +7022,19 @@
msgstr "æ æ³å°ç®å½æ¹åå°%s"
#, fuzzy, c-format
msgstr "æ æ³ä¸ºåºå %d 计ç®è´¨å¿"
@@ -7071,7 +7071,7 @@
@@ -7269,17 +7269,17 @@
msgstr "è¾åºå°å¾'%s'被ç¨ä½è¾å
#, fuzzy, c-format
#, c-format
msgstr ""
#, fuzzy, c-format
@@ -7377,7 +7377,7 @@
msgstr ""
#, fuzzy
msgstr "æ æ³åå
¥çº¿ (è´ååç§»)"
@@ -7410,7 +7410,7 @@
msgstr ""
@@ -8041,17 +8041,17 @@
msgstr ""
#, fuzzy
#, fuzzy, c-format
msgstr "æªç¥åºå"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
@@ -1474,11 +1474,11 @@
#: ../locale/scriptstrings/i.spectral_to_translate.c:6
#: ../locale/scriptstrings/i.spectral_to_translate.c:7
#: ../locale/scriptstrings/i.spectral_to_translate.c:8
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:17
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:19
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:21
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:24
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:14
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:16
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:18
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:20
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:23
#: ../locale/scriptstrings/t.register_to_translate.c:5
#: ../locale/scriptstrings/t.register_to_translate.c:6
#: ../locale/scriptstrings/t.register_to_translate.c:8
@@ -3488,8 +3488,8 @@
#: ../raster/r.in.xyz/main.c:299 ../raster/r.in.lidar/main.c:190
#: ../raster/r.in.lidar/main.c:230 ../raster/r.in.lidar/main.c:239
#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:12
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:28
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
msgid "Statistic"
msgstr ""
@@ -3500,17 +3500,17 @@
msgstr "ÙÙØ¹ Ø§ÙØªØ®Ø²ÙÙ ÙÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙØ§ØªØ¬Ø© "
#: ../raster/r.in.xyz/main.c:201
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:16
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
msgid "Column number of x coordinates in input file (first column is 1)"
msgstr ""
#: ../raster/r.in.xyz/main.c:209
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:18
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:17
msgid "Column number of y coordinates in input file"
msgstr ""
#: ../raster/r.in.xyz/main.c:217
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:22
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:21
msgid "Column number of data values in input file"
msgstr ""
@@ -3559,18 +3559,18 @@
msgstr ""
#: ../raster/r.in.xyz/main.c:280 ../raster/r.in.lidar/main.c:220
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:27
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:26
msgid "Percent of map to keep in memory"
msgstr "اÙÙØ³Ø¨Ø© Ù
Ù Ø§ÙØ®Ø±Ùطة ÙÙØÙØ¸ Ø¨Ø§ÙØ°Ø§Ùرة"
#: ../raster/r.in.xyz/main.c:289 ../raster/r.in.lidar/main.c:229
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:28
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:27
#, fuzzy
msgid "pth percentile of the values"
msgstr "طرÙÙØ© ØªÙØ±Ùر Ø§ÙØ¥ÙØØ¯Ø§Ø±"
#: ../raster/r.in.xyz/main.c:298 ../raster/r.in.lidar/main.c:238
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
msgid ""
"Discard <trim> percent of the smallest and <trim> percent of the largest "
"observations"
@@ -19885,32 +19885,27 @@
msgid "ASCII file containing input data"
msgstr "اÙÙ
ÙÙ Ø§ÙØ£Ø³ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù اÙÙ
Ø·ÙÙØ¨ ادخاÙÙ"
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:14
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:19
#, fuzzy
-msgid "Field separator"
-msgstr "اÙÙØ§ØµÙ Ø§ÙØÙÙ٠بÙÙ Ø¨ÙØ§Ùات اÙÙ
خرج"
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:20
-#, fuzzy
msgid "Column number of z coordinates in input file"
msgstr "Ø§ÙØ¥ØØ¯Ø§Ø«Ù Ø§ÙØ´Ù
اÙÙ ÙÙØ®Ø±Ùطة\n"
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:23
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:22
#, fuzzy
msgid "If not given or set to 0, the data points' z-values are used"
msgstr "%-5d ÙØ¦Ø§Øª اÙÙÙØ· ÙØ±Ø§Øª\n"
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:25
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:24
#, fuzzy
msgid "Filter range for value column data (min,max)"
msgstr "min,max :اÙÙ
Ø¯Ù Ø§ÙØµØÙØ"
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:26
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:25
#, fuzzy
msgid "Scaling factor to apply to value column data"
msgstr "استخداÙ
Ø§ØØ¯Ø§Ø«Ùات Ù
Ø±ÙØ² Ø§ÙØ®Ø±Ùطة\n"
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:32
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
#, fuzzy
msgid "Number of parallel processes to launch"
msgstr "عدد ÙÙØ§Ø· Ø§ÙØ¥Ø³ØªÙÙØ§Ø¡"
@@ -33304,7 +33299,7 @@
msgid "More points with category %d found"
msgstr "%-5d تÙ
ØªØ®Ø·Ù ÙØ¦Ø§Øª اÙÙÙØ· اÙÙ
ÙØª\n"
-#: ../vector/v.net/connect.c:77
+#: ../vector/v.net/connect.c:78
#, fuzzy
msgid "Failed to find intersection segment"
msgstr "%s ÙÙ
ÙØªÙ
Ø§ÙØ¹Ø«Ùر عÙÙ Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
@@ -41177,6 +41172,10 @@
msgstr " nv ÙÙÙ\n"
#, fuzzy
+#~ msgid "Field separator"
+#~ msgstr "اÙÙØ§ØµÙ Ø§ÙØÙÙ٠بÙÙ Ø¨ÙØ§Ùات اÙÙ
خرج"
+#, fuzzy
#~ msgid "Raster map <%s> already exists in mapset <%s>"
#~ msgstr "<%s>ÙÙ<%s>ÙÙ
ÙÙ
ÙÙ ÙØªØ اÙÙ
Ù٠اÙÙÙÙØªÙرÙ"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -14,7 +14,7 @@
msgstr ""
"Project-Id-Version: grassmods_cs\n"
"PO-Revision-Date: 2010-03-07 15:38+0100\n"
@@ -1483,11 +1483,11 @@
@@ -3605,8 +3605,8 @@
msgid "Statistic"
msgstr "Statistika"
@@ -3617,19 +3617,19 @@
msgstr "Typ uloženà výsledné rastrové mapy"
msgstr ""
"ÄÃslo sloupce použitého jako souÅadnice x ve vstupnÃm souboru (prvnà sloupec "
"je 1)"
msgstr "ÄÃslo sloupeÄku pro souÅadnice y ve vstupnÃm souboru"
msgstr "ÄÃslo sloupeÄku hodnot bunÄk ve vstupnÃm souboru"
@@ -3681,17 +3681,17 @@
msgstr "Nastavit na z data"
msgstr "Äást mapy v procentech, která má být uchována v pamÄti"
msgstr "pth percentil hodnot"
msgid ""
"observations"
@@ -20176,32 +20176,27 @@
msgstr "ASCII soubor obsahujÃcà vstupnà data (\"-\" pro standardnà vstup)"
#, fuzzy
-msgstr "Výstupnà oddÄlovaÄ sloupců"
-#, fuzzy
#, fuzzy
msgstr "Jestli ne, bude použito zadané jméno vstupnà mapy "
#, fuzzy
msgstr "Rozsah filtru pro z data: (min,max)"
#, fuzzy
msgstr "MÄÅÃtkový faktor pro hodnoty atributů"
#, fuzzy
msgstr "PoÄet tÅid "
@@ -33802,7 +33797,7 @@
msgstr "Žádný bod s kategorià [%d]"
#, fuzzy
msgstr "selhal pÅevod Å¡ÃÅky na celé ÄÃslo"
@@ -41699,6 +41694,10 @@
msgstr "ZjiÅ¡tÄnà bodů mimo region"
#, fuzzy
+#~ msgstr "Výstupnà oddÄlovaÄ sloupců"
+#, fuzzy
#~ msgstr "<%s> již existuje v mapsetu <%s>"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_de.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_de.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_de.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -9,7 +9,7 @@
msgstr ""
"Project-Id-Version: grassmods_de\n"
"PO-Revision-Date: 2014-08-13 11:44+0200\n"
@@ -1475,11 +1475,11 @@
@@ -3650,8 +3650,8 @@
msgid "Statistic"
msgstr "Statistik"
@@ -3662,18 +3662,18 @@
msgstr "Speichertyp der resultierenden Rasterkarte."
msgstr ""
"Spaltenummer der X-Koordinate in der Eingabedatei (erste Spalte ist 1)."
msgstr "Spaltenummer der Y-Koordinate in der Eingabedatei."
msgstr "Spaltenummer der Daten in der Eingabedatei."
@@ -3726,17 +3726,17 @@
msgstr "Skalierungsfaktor für die z-Daten."
msgstr "Prozentteil der Karte, der im Speicher gehalten werden soll."
msgstr "Perzentil der Werte"
msgid ""
"observations"
@@ -20217,31 +20217,27 @@
msgstr "ASCII-Datei mit Eingabedaten (oder \"-\" um von stdin zu lesen)"
-msgstr "Feld-Trennzeichen"
#, fuzzy
#, fuzzy
msgstr "Wenn nicht angegeben wird der Name der Eingabekarte verwendet."
#, fuzzy
msgstr "Filterbereich für z-Daten (min,max)."
#, fuzzy
msgstr "Skalierfaktor für die Werte der Attributspalte"
#, fuzzy
msgstr "Anzahl der zu bestimmenden Klassen"
@@ -33857,7 +33853,7 @@
msgstr "Kein Punkte mit Kategorie [%d]."
#, fuzzy
msgstr "Interpretation von width als Integer ist fehlgeschlagen."
@@ -41822,6 +41818,9 @@
msgid "Outlier detection"
msgstr "Erkennung von AusreiÃern"
+#~ msgstr "Feld-Trennzeichen"
#, fuzzy
#~ msgstr "<%s> existiert bereits im Mapset <%s>."
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_el.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_el.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_el.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -10,7 +10,7 @@
msgstr ""
"Project-Id-Version: grassmods_el\n"
"PO-Revision-Date: 2009-02-19 10:29+0200\n"
"Last-Translator: Vasilios Antoniou <vantoniou at gmail.com>\n"
@@ -1438,11 +1438,11 @@
@@ -3395,8 +3395,8 @@
msgid "Statistic"
msgstr ""
@@ -3407,17 +3407,17 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
@@ -3464,17 +3464,17 @@
msgstr ""
msgstr ""
msgstr ""
msgid ""
"observations"
@@ -19131,30 +19131,25 @@
msgstr "Îνομα ειÏαγÏμενοÏ
ÏάÏÏÎµÏ ÏάÏÏη "
#, fuzzy
-msgstr "ÎιαÏÏÏιÏÏÎ®Ï ÏεδίÏν εξÏδοÏ
-#, fuzzy
msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏοÏ
ÏάÏÏη raster <%s>"
msgstr ""
msgstr ""
#, fuzzy
msgstr "ÎδÏ
ναμία διαβάÏμαÏÎ¿Ï ÎµÏÏοÏ
Ï fp για Ïον ÏαÏÏÎµÏ ÏάÏÏη <%s>"
#, fuzzy
msgstr "ÎÏιθμÏÏ ÏÏν δεδαδικÏν ÏηÏίÏν για ÏοÏ
Ï Î±ÏιθμοÏÏ Ï
ÏοδιαÏÏολήÏ"
@@ -32012,7 +32007,7 @@
msgstr ""
#, fuzzy
msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
ÏεÏιÎÏει SQL ενÏολÎÏ"
@@ -39512,6 +39507,10 @@
msgstr ""
#, fuzzy
+#~ msgstr "ÎιαÏÏÏιÏÏÎ®Ï ÏεδίÏν εξÏδοÏ
+#, fuzzy
#~ msgstr "Î ÏάÏÏÎ·Ï raster <%s> δεν βÏÎθηκε"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_es.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_es.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_es.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -13,7 +13,7 @@
msgstr ""
"Project-Id-Version: grassmods_es\n"
"PO-Revision-Date: 2015-01-23 20:45-0600\n"
@@ -1491,11 +1491,11 @@
@@ -3638,8 +3638,8 @@
msgid "Statistic"
msgstr "EstadÃstico"
@@ -3650,19 +3650,19 @@
msgstr "Tipo de almacenamiento para el mapa ráster resultante"
msgstr ""
"Número de columna de las coordenadas X en el archivo de entrada (la primera "
"columna es 1)"
msgstr "Número de columna de las coordenadas Y en el archivo de entrada"
msgstr "Número de columna de los valores de datos en el archivo de entrada"
@@ -3715,17 +3715,17 @@
msgstr "Escala a aplicar a los datos Z"
msgstr "Porcentaje de mapa a mantener en memoria"
msgstr "pth percentil de los valores"
msgid ""
"observations"
@@ -20316,31 +20316,27 @@
msgstr ""
"Archivo ASCII que contiene los datos de entrada (o \"-\" para leer de stdin)"
-msgstr "Separador de campos"
#, fuzzy
#, fuzzy
msgstr "Si no se da se usa el nombre del mapa de entrada"
#, fuzzy
msgstr "Rango de filtrado para los datos Z (mÃnimo, máximo)"
#, fuzzy
msgstr "Factor de escala para valores de columna de atributos"
#, fuzzy
msgstr "Número de clases a definir"
@@ -33955,7 +33951,7 @@
msgstr "Ningún punto con categorÃa [%d]"
#, fuzzy
msgstr "No se pudo interpretar la anchura como entero"
@@ -41922,6 +41918,9 @@
msgstr "Detección de valores extremos"
+#~ msgstr "Separador de campos"
#~ msgstr "El mapa ráster <%s> ya existe en el directorio de mapas<%s>"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -12,7 +12,7 @@
msgstr ""
"Project-Id-Version: grassmods_fr\n"
"PO-Revision-Date: 2014-01-01 11:35+0100\n"
"Language-Team: Français <grass-translations at lists.osgeo.org>\n"
@@ -1534,11 +1534,11 @@
@@ -3804,8 +3804,8 @@
msgid "Statistic"
msgstr "Statistique"
@@ -3816,7 +3816,7 @@
msgstr "Type de stockage pour la couche raster créée"
#, fuzzy
msgstr ""
@@ -3824,12 +3824,12 @@
"en mode points"
msgstr "Numéro de colonne pour les ordonnées dans le fichier en entrée"
msgstr "Numéro de colonne pour les valeurs dans le fichier en entrée"
@@ -3881,18 +3881,18 @@
msgstr "Ãchelle à appliquer aux données z"
msgstr "Pourcentage de la couche à garder en mémoire"
#, fuzzy
msgstr "Format de sortie pour la pente"
msgid ""
"observations"
@@ -21128,31 +21128,27 @@
msgstr "Fichier ascii contenant les signatures spectrales"
-msgstr "Caractère de séparation de champs"
#, fuzzy
#, fuzzy
msgstr "%-5d catégories du point lues\n"
#, fuzzy
msgstr "Rang des valeurs entières: min,max"
#, fuzzy
msgstr "Facteur d'échelle pour les valeurs de colonnes attributaires"
#, fuzzy
msgstr "Nombre de copies à imprimer"
@@ -35535,7 +35531,7 @@
msgstr "%d points sans catégorie"
#, fuzzy
msgstr "Echec pour interpréter dp comme valeur entière (integer)"
@@ -43897,6 +43893,9 @@
msgstr "Couleur de mise en valeur"
+#~ msgstr "Caractère de séparation de champs"
#, fuzzy
#~ msgstr "ERREUR: <%s> existe déjà dans le jeu de données <%s>\n"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_it.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_it.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_it.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -14,7 +14,7 @@
msgstr ""
"Project-Id-Version: grassmods_it\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2015-02-16 14:18+0100\n"
+"POT-Creation-Date: 2015-02-20 20:37+0100\n"
"PO-Revision-Date: 2013-11-20 18:19+0100\n"
"Last-Translator: az\n"
@@ -1493,11 +1493,11 @@
msgid "Statistic"
msgstr "Statistica"
msgstr "Tipo di dati memorizzati per la mappa raster risultante"
msgstr ""
"Numero della colonna per le coordinate x nel file di input (prima colonna è "
"1)"
msgstr "Numero della colonna per le coordinate y nel file di input"
msgstr "Numero di colonna dei valori dei dati nel file di input"
@@ -3680,17 +3680,17 @@
msgstr "Scala da applicare ai dati z"
msgstr "Percentuale di mappa da tenere in memoria"
msgstr "p-esimo percentile dei valori"
msgid ""
"observations"
@@ -19895,30 +19895,26 @@
msgstr ""
"File ASCII contenente i dati di input (o \"-\" per leggere dallo stdin)"
-msgstr "Separatore di campo"
#, fuzzy
#, fuzzy
msgstr "Lette [%d] categorie di punti"
msgstr ""
#, fuzzy
#, fuzzy
msgstr "Numero di classi da definire"
@@ -33260,7 +33256,7 @@
msgstr "raster <%s> non trovato"
#, fuzzy
msgstr "Interpretazione della larghezza come intero fallita"
@@ -41039,6 +41035,9 @@
msgstr ""
+#~ msgstr "Separatore di campo"
#, fuzzy
#~ msgstr "<%s> esiste già nel mapset <%s>"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -13,7 +13,7 @@
msgstr ""
"Project-Id-Version: grassmods_ja\n"
"PO-Revision-Date: 2012-03-08 17:49+0900\n"
"Last-Translator: taniguchi <taniguti at apptec.co.jp>\n"
@@ -1469,11 +1469,11 @@
@@ -3530,8 +3530,8 @@
msgid "Statistic"
msgstr "çµ±è¨é "
@@ -3542,17 +3542,17 @@
msgstr "ä¿åå½¢å¼ "
msgstr "å
¥åãã¡ã¤ã«ã® x 座æ¨ã®åçªå· (æåã®å㯠1)"
msgstr "å
¥åãã¡ã¤ã«ã® y 座æ¨ã®åçªå·"
msgstr "å
¥åãã¡ã¤ã«ã®ãã¼ã¿å¤ã®åçªå·"
@@ -3603,17 +3603,17 @@
msgstr "z ãã¼ã¿ã«æå®ãã縮尺"
msgstr "ã¡ã¢ãªã«æ®ããããã®å²åï¼ï¼
ï¼ "
msgstr "pth ã®ç¾åçå¤"
msgid ""
"observations"
@@ -19795,32 +19795,27 @@
msgstr "å
¥åãã¼ã¿ãå«ã ASCII ãã¡ã¤ã« ï¼ã¾ã㯠\"-\" ã§æ¨æºå
¥åããï¼"
#, fuzzy
-msgstr "ãã£ã¼ã«ãã»ãã¬ã¼ã¿ã¼ã®åºå"
-#, fuzzy
msgstr "å
#, fuzzy
msgstr "æå®ããªãå ´åï¼æå®ããããããåã使ããã¾ã"
#, fuzzy
msgstr "z ãã¼ã¿ã®ãã£ã«ã¿ã¼ã¬ã³ã¸ (min,max) "
#, fuzzy
msgstr "é«åº¦åã®ã¹ã±ã¼ã«ãã¡ã¯ã¿ã¼å¤"
#, fuzzy
msgstr "å®ç¾©ããã¯ã©ã¹ã®æ°"
@@ -33216,7 +33211,7 @@
msgstr "åºåãã¡ã¤ã«ã®ä¸æ¸ã"
#, fuzzy
msgstr "å¹
ãæ´æ°å¤ã¨ãã¦è§£éã§ãã¾ãã "
@@ -41033,6 +41028,10 @@
msgstr "å¤ã夿¤åº"
#, fuzzy
+#~ msgstr "ãã£ã¼ã«ãã»ãã¬ã¼ã¿ã¼ã®åºå"
+#, fuzzy
#~ msgstr "åºåãããã¡ã¤ã«"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grassmods_ko\n"
"PO-Revision-Date: 2005-08-09 22:53-0500\n"
@@ -1435,11 +1435,11 @@
@@ -3400,8 +3400,8 @@
msgid "Statistic"
msgstr ""
@@ -3412,17 +3412,17 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
@@ -3469,17 +3469,17 @@
msgstr ""
msgstr ""
msgstr ""
msgid ""
"observations"
@@ -19216,30 +19216,25 @@
msgstr "ì¶ë ¥í 격ìì§ë"
#, fuzzy
-msgstr "ì¶ë ¥í 격ìì§ë"
-#, fuzzy
msgstr ""
msgstr ""
#, fuzzy
msgstr ""
@@ -32175,7 +32170,7 @@
msgstr ""
#, fuzzy
@@ -39747,6 +39742,10 @@
msgstr ""
#, fuzzy
+#~ msgstr "ì¶ë ¥í 격ìì§ë"
+#, fuzzy
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grassmods_lv\n"
"PO-Revision-Date: 2014-09-10 12:05+0300\n"
@@ -1462,11 +1462,11 @@
@@ -3467,8 +3467,8 @@
msgid "Statistic"
msgstr ""
@@ -3479,17 +3479,17 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
@@ -3536,18 +3536,18 @@
msgstr ""
msgstr ""
#, fuzzy
msgstr "Izejas karte kurÄ tiks ierakstÄ«ti punkti"
msgid ""
"observations"
@@ -19773,31 +19773,26 @@
msgstr "ASCII fails ar ievades datiem"
#, fuzzy
-msgstr "Izvades lauku atdalÄ«tÄjs"
-#, fuzzy
msgstr "nederīgs reģions: %s"
#, fuzzy
msgstr "%-5d punktu kategorijas nolasītas\n"
msgstr ""
#, fuzzy
msgstr "%d kategorijas ielÄdÄtas no tabulas\n"
#, fuzzy
msgstr "DrukÄjamo kopiju sakits"
@@ -33175,7 +33170,7 @@
msgstr "%-5d mirušo/neizmantoto punktu kategorijas izlaistas\n"
#, fuzzy
msgstr "NevarÄja atrast rastra failu %s"
@@ -41108,6 +41103,10 @@
msgstr "lÄ«nijas krÄsa 2"
#, fuzzy
+#~ msgstr "Izvades lauku atdalÄ«tÄjs"
+#, fuzzy
#~ msgstr "neiespÄjami atvÄrt <%s>"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grassmods_pl\n"
"PO-Revision-Date: 2013-07-16 12:26+0100\n"
"Language-Team: Polish <grass-translations at lists.osgeo.org>\n"
@@ -1481,11 +1481,11 @@
@@ -3485,8 +3485,8 @@
msgid "Statistic"
msgstr "Statystyka"
@@ -3497,19 +3497,19 @@
msgstr "Sposób zapisu wynikowej mapy rastrowej"
msgstr ""
"Numer kolumny pliku wejÅciowego przechowujÄ
cej wspóÅrzÄdne x (pierwsza "
"kolumna ma numer 1)"
msgstr "Numer kolumny pliku wejÅciowego przechowujÄ
cej wspóÅrzÄdne y"
cej dane"
@@ -3559,17 +3559,17 @@
msgstr "WspóÅczynnik skali dla danych z"
msgstr "Procent mapy przechowywanej w pamiÄci"
msgstr "pth percentyl wartoÅci"
msgid ""
"observations"
@@ -19743,31 +19743,27 @@
msgstr "Plik ASCII zawierajÄ
cy dane wejÅciowe (lub \"-\" aby wczytaÄ z stdin)"
-msgstr "Separator pól"
#, fuzzy
cej wspóÅrzÄdne y"
#, fuzzy
msgstr "Wczytano %d kategorii z mapy"
#, fuzzy
msgstr "Zakres filtra dla danych z: (min,max)"
#, fuzzy
#, fuzzy
msgstr "Liczba klas do zdefiniowania"
@@ -33251,7 +33247,7 @@
msgstr "EdytowaÄ plik kategorii dla [%s]? "
#, fuzzy
msgstr "DÅugoÅÄ wiersza musi byÄ liczbÄ
caÅkowitÄ
@@ -41070,6 +41066,9 @@
msgstr "Wykrywanie konturu"
+#~ msgstr "Separator pól"
#, fuzzy
#~ msgstr "BÅÄD: <%s> już istnieje w mapsecie <%s>\n"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -10,7 +10,7 @@
msgstr ""
"Project-Id-Version: grassmods_pt\n"
"PO-Revision-Date: 2007-06-21 21:54-0300\n"
"Last-Translator: Daniel de Castro Victoria <daniel dot victoria at gmail dot "
"com>\n"
@@ -1504,11 +1504,11 @@
@@ -3631,8 +3631,8 @@
msgid "Statistic"
msgstr ""
@@ -3643,7 +3643,7 @@
msgstr "Tipo de armazenamento para o mapa resultante"
#, fuzzy
msgstr ""
@@ -3651,12 +3651,12 @@
"de pontos"
msgstr ""
msgstr ""
@@ -3709,18 +3709,18 @@
msgstr ""
msgstr "Porcentagem do mapa para manter em memória"
#, fuzzy
msgstr "Formato para relatar a declividade"
msgid ""
"observations"
@@ -20417,34 +20417,29 @@
msgstr "Arquivo ASCII contendo assinaturas espectrais"
#, fuzzy
-msgstr "Separador de campo"
-#, fuzzy
msgstr ""
"Número da coluna usada como coordenada x (primeira coluna é 1) para o modo "
"de pontos"
#, fuzzy
msgstr "%-5d categorias de pontos lidas\n"
#, fuzzy
msgstr "Intervalo de inteiro: min,max"
#, fuzzy
msgstr "Fator de escala para os valores da coluna de atributos"
#, fuzzy
msgstr "Número de cópias"
@@ -34301,7 +34296,7 @@
msgstr "%d pontos sem categoria"
#, fuzzy
msgstr "falha interpretando dp como inteiro"
@@ -42350,6 +42345,10 @@
msgstr "Cor da Linha"
#, fuzzy
+#~ msgstr "Separador de campo"
+#, fuzzy
#~ msgstr "em"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -11,7 +11,7 @@
msgstr ""
"Project-Id-Version: grassmods_pt_br\n"
"PO-Revision-Date: 2011-08-03 03:03-0300\n"
"Last-Translator: Fred Ulisses Maranhão <fred.maranhao at gmail.com>\n"
"Language-Team: Brasilian Portuguese <grass-translations at lists.osgeo.org>\n"
@@ -1498,11 +1498,11 @@
@@ -3617,8 +3617,8 @@
msgid "Statistic"
msgstr ""
@@ -3629,7 +3629,7 @@
#, fuzzy
msgstr ""
@@ -3637,12 +3637,12 @@
"de pontos"
msgstr ""
msgstr ""
@@ -3695,18 +3695,18 @@
msgstr ""
#, fuzzy
msgid ""
"observations"
@@ -20323,34 +20323,29 @@
#, fuzzy
-#, fuzzy
msgstr ""
"de pontos"
#, fuzzy
#, fuzzy
#, fuzzy
#, fuzzy
@@ -34224,7 +34219,7 @@
#, fuzzy
msgstr "falha interpretando a largura como inteiro"
@@ -42272,6 +42267,10 @@
#, fuzzy
+#, fuzzy
#~ msgstr "em"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grassmods_ro\n"
"PO-Revision-Date: 2013-07-17 22:14+0200\n"
"Last-Translator: Andreea Marin <andreea.marin09 yahoo.com>\n"
@@ -1400,11 +1400,11 @@
@@ -3327,8 +3327,8 @@
msgid "Statistic"
msgstr "Statistici"
@@ -3339,17 +3339,17 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
@@ -3394,17 +3394,17 @@
msgstr ""
msgstr ""
msgstr ""
msgid ""
"observations"
@@ -18741,27 +18741,23 @@
msgstr ""
-msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
@@ -31190,7 +31186,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grassmods_ru\n"
"PO-Revision-Date: 2009-05-15 00:23-0600\n"
@@ -1478,11 +1478,11 @@
@@ -3613,8 +3613,8 @@
msgid "Statistic"
msgstr "СÑаÑиÑÑика"
@@ -3625,17 +3625,17 @@
msgstr "Тип даннÑÑ
Ð´Ð»Ñ Ð²ÑÑ
одного ÑаÑÑÑового ÑлоÑ"
msgstr "ÐÐ¾Ð¼ÐµÑ ÑÑолбÑа иÑÑ
одного Ñайла Ð´Ð»Ñ ÐºÐ¾Ð¾ÑÐ´Ð¸Ð½Ð°Ñ x (пеÑвÑй ÑÑÐ¾Ð»Ð±ÐµÑ - 1)"
msgstr "ÐÐ¾Ð¼ÐµÑ ÑÑолбÑа ÑодеÑжаÑего кооÑдинаÑÑ y в иÑÑ
одном Ñайле"
msgstr "ÐÐ¾Ð¼ÐµÑ ÑÑолбÑа ÑодеÑжаÑего даннÑе в иÑÑ
одном Ñайле"
@@ -3686,17 +3686,17 @@
msgstr "ÐаÑÑÑаб пÑименÑемÑй Ð´Ð»Ñ Ð´Ð°Ð½Ð½ÑÑ
z"
msgstr "ÐÑоÑÐµÐ½Ñ ÐºÐ°ÑÑÑ ÑоÑ
ÑанÑемÑй в памÑÑи"
msgstr "p-ÑÑй пеÑÑенÑÐ¸Ð»Ñ Ð·Ð½Ð°Ñений"
msgid ""
"observations"
@@ -20178,32 +20178,27 @@
msgstr "ASCII Ñайл ÑодеÑжаÑий иÑÑ
однÑе даннÑе (или \"-\" Ð´Ð»Ñ ÑÑÐµÐ½Ð¸Ñ Ð¸Ð· stdin)"
#, fuzzy
-msgstr "ÐÑÑ
одной ÑазделиÑÐµÐ»Ñ Ð¿Ð¾Ð»ÐµÐ¹"
-#, fuzzy
одном Ñайле"
#, fuzzy
msgstr "ÐÑли Ð¸Ð¼Ñ Ð½Ðµ задано, Ñо иÑполÑзÑеÑÑÑ Ð¸Ð¼Ñ Ð¸ÑÑ
одного ÑлоÑ"
#, fuzzy
msgstr "Ðиапазон ÑилÑÑÑа Ð´Ð»Ñ Ð´Ð°Ð½Ð½ÑÑ
z (минимÑм,макÑимÑм)"
#, fuzzy
msgstr "ФакÑÐ¾Ñ Ð¼Ð°ÑÑÑабиÑÐ¾Ð²Ð°Ð½Ð¸Ñ Ð´Ð»Ñ Ð·Ð½Ð°Ñений аÑÑибÑÑивного полÑ"
#, fuzzy
msgstr "ЧиÑло опÑеделÑемÑÑ
клаÑÑов"
@@ -33869,7 +33864,7 @@
msgstr "ÐÐµÑ ÑоÑек каÑегоÑии [%d]"
#, fuzzy
msgstr "ÐÑибка инÑеÑпÑеÑаÑии ÑиÑÐ¸Ð½Ñ ÐºÐ°Ðº Ñелого ÑиÑла"
@@ -41816,6 +41811,10 @@
msgstr "Ð¦Ð²ÐµÑ Ð¾Ð±Ð²Ð¾Ð´ÐºÐ¸"
#, fuzzy
+#~ msgstr "ÐÑÑ
+#, fuzzy
#~ msgstr "<%s> Ñже ÑÑÑеÑÑвÑÐµÑ Ð² набоÑе Ñлоев <%s>"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grassmods_sl\n"
"PO-Revision-Date: 2005-06-10 11:15+0200\n"
@@ -1485,11 +1485,11 @@
@@ -3512,8 +3512,8 @@
msgid "Statistic"
msgstr ""
@@ -3525,17 +3525,17 @@
msgstr "Tip zapisa izhodnega rastrskega sloja"
msgstr ""
msgstr ""
msgstr ""
@@ -3582,18 +3582,18 @@
msgstr ""
msgstr "Dele¾ sloja, ki ga ohranjati v spominu raèunalnika"
#, fuzzy
msgstr "Enote za naklon"
msgid ""
"observations"
@@ -20088,31 +20088,26 @@
msgstr "Ne najdem vhodne datoteke %s\n"
#, fuzzy
-msgstr "izpi¹i znak razmejitve med polji"
-#, fuzzy
msgstr "Y koordinata oziroma geografska ¹irina"
#, fuzzy
msgstr "%-5d kategorij toèk prebranih\n"
msgstr ""
#, fuzzy
msgstr "Uporabljam koordinate sredi¹èa sloja\n"
#, fuzzy
msgstr "©tevilo toèk najbli¾jih toèk, ki bodo upo¹tevane"
@@ -33574,7 +33569,7 @@
msgstr "%-5d mrtvih kategorij toèk preskoèenih\n"
#, fuzzy
@@ -41462,6 +41457,10 @@
msgstr " nv barva\n"
#, fuzzy
+#~ msgstr "izpi¹i znak razmejitve med polji"
+#, fuzzy
#~ msgstr "Ime izhodnega rastrskega sloja"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_th.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_th.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_th.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grassmods_th\n"
@@ -1471,11 +1471,11 @@
@@ -3553,8 +3553,8 @@
msgid "Statistic"
msgstr ""
@@ -3565,17 +3565,17 @@
msgstr "à¸à¸à¸´à¸à¸à¸µà¹à¸à¸±à¸à¹à¸à¹à¸ สำหรัภà¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภà¸à¸¥à¸¥à¸±à¸à¸à¹"
msgstr "Column ลำà¸à¸±à¸à¸à¸µà¹ à¸à¸à¸ à¸à¹à¸²à¸à¸´à¸à¸±à¸ x à¹à¸ à¹à¸à¸¥à¹à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸² (Column à¹à¸£à¸à¸à¸·à¸ 1)"
msgstr "Column ลำà¸à¸±à¸à¸à¸µà¹ à¸à¸à¸ à¸à¹à¸²à¸à¸´à¸à¸±à¸ y à¹à¸ à¹à¸à¸¥à¹à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸² "
msgstr "Column ลำà¸à¸±à¸à¸à¸µà¹ à¸à¸à¸ à¸à¹à¸à¸¡à¸¹à¸¥ à¹à¸à¸¥à¹à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸² "
msgstr ""
msgstr "à¹à¸à¸à¸£à¹à¹à¸à¹à¸à¸à¹à¸à¸à¸à¹à¸à¸à¸à¸µà¹ à¸à¸µà¹à¸à¸°à¸à¸±à¸à¹à¸à¹à¸à¹à¸à¸«à¸à¹à¸§à¸¢à¸à¸§à¸²à¸¡à¸à¸³"
msgstr "pth à¹à¸à¸à¸£à¹à¹à¸à¹à¸à¸à¹ à¸à¸à¸ à¸à¹à¸²"
msgid ""
"observations"
@@ -19949,32 +19949,27 @@
msgstr "à¹à¸à¸¥à¹ ASCII à¸à¸µà¹à¸¡à¸µà¸à¹à¸à¸¡à¸¹à¸¥à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸² (หรืภ\"-\" à¹à¸à¸·à¹à¸à¸à¹à¸²à¸à¸à¸²à¸ stdin)"
#, fuzzy
-msgstr "à¸à¸±à¸§à¹à¸¢à¸à¸à¸à¸ field à¸à¸¥à¸¥à¸±à¸à¸à¹"
-#, fuzzy
#, fuzzy
msgstr "à¸à¹à¸²à¹à¸¡à¹à¸à¸³à¸«à¸à¸ à¸à¸°à¹à¸à¹à¸à¸·à¹à¸à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¸à¸³à¹à¸à¹à¸²"
#, fuzzy
msgstr "à¸à¹à¸§à¸à¸à¸²à¸£à¸à¸£à¸à¸ สำหรัà¸à¸à¹à¸à¸¡à¸¹à¸¥ z (à¸à¹à¸à¸¢à¸ªà¸¸à¸,มาà¸à¸ªà¸¸à¸)"
#, fuzzy
msgstr "à¸à¸±à¸§à¸à¸¹à¸à¸¡à¸²à¸à¸£à¸²à¸ªà¹à¸§à¸ สำหรัภà¸à¹à¸² à¹à¸ Column รายละà¹à¸à¸µà¸¢à¸"
#, fuzzy
msgstr "à¸à¸³à¸à¸§à¸ à¸à¸¸à¸ à¸à¸µà¹à¸à¸°à¸à¸´à¸¡à¸à¹"
@@ -33460,7 +33455,7 @@
msgstr "à¹à¸¡à¹à¸¡à¸µà¸à¸¸à¸à¸à¸µà¹à¸¡à¸µ หมวà¸à¸«à¸¡à¸¹à¹ [%d]"
#, fuzzy
msgstr "ลà¹à¸¡à¹à¸«à¸¥à¸§à¸à¸µà¹à¸à¸° à¹à¸à¹ dp à¹à¸à¹à¸ integer"
@@ -41317,6 +41312,10 @@
msgstr "สีà¹à¸ªà¹à¸à¸à¸à¸"
#, fuzzy
+#~ msgstr "à¸à¸±à¸§à¹à¸¢à¸à¸à¸à¸ field à¸à¸¥à¸¥à¸±à¸à¸à¹"
+#, fuzzy
#~ msgstr "<%s> มีà¸à¸¢à¸¹à¹à¹à¸¥à¹à¸§à¹à¸à¸à¸¸à¸à¹à¸à¸à¸à¸µà¹ <%s>"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -9,7 +9,7 @@
msgstr ""
"Project-Id-Version: grassmods_tr\n"
"PO-Revision-Date: 2008-11-16 01:15+0200\n"
"Last-Translator: Osman Yalçın YILMAZ <yilmazy at istanbul.edu.tr>\n"
@@ -1456,11 +1456,11 @@
@@ -3445,8 +3445,8 @@
msgid "Statistic"
msgstr ""
@@ -3457,17 +3457,17 @@
msgstr "Sonuç harita depolama türü"
msgstr "Girdi dosyasındaki x koordinatları sütun numarası (ilk sütun 1'dir)"
msgstr "Girdi dosyasındaki y koordinatları sütun numarası "
msgstr "Girdi dosyasındaki veri deÄerleri sütun numarası"
@@ -3516,17 +3516,17 @@
msgstr ""
msgstr "Hafızada tutulacak harita oranı"
msgstr ""
msgid ""
"observations"
@@ -19504,32 +19504,27 @@
msgstr "Girdi vektör haritasının harita takımı"
#, fuzzy
-msgstr "Ãıktı alan ayracı"
-#, fuzzy
#, fuzzy
msgstr "[%d] nokta kategorisi okundu"
#, fuzzy
msgstr "z verisi süzme aralıÄı (en küçük, en büyük)"
#, fuzzy
msgstr "z koordinatı için ölçek faktörü"
#, fuzzy
msgstr "Belirlenecek sınıf sayısı"
@@ -32785,7 +32780,7 @@
msgstr "[%d] kategorisinde hiç nokta yok"
#, fuzzy
msgstr "BaÅlangıç dokularını içeren dosya"
@@ -40486,6 +40481,10 @@
msgstr "Artalan rengi"
#, fuzzy
+#~ msgstr "Ãıktı alan ayracı"
+#, fuzzy
#~ msgstr "<%s> zaten <%s> harita takımında mevcut"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grassmods_vi\n"
"PO-Revision-Date: 2010-08-27 14:37+0700\n"
"Last-Translator: \n"
"Language-Team: Vietnamese <grass-translations at lists.osgeo.org>\n"
@@ -3621,8 +3621,8 @@
msgid "Statistic"
msgstr "Thá»ng kê"
@@ -3633,17 +3633,17 @@
msgstr "Kiá»u lưu trữ cho bản Äá» raster kết quả"
msgstr "Sá» thứ tá»± cá»t chứa tá»a Äá» x trong táºp tin Äầu và o (cá»t Äầu tiên là 1)"
msgstr "Sá» thứ tá»± cá»t chứa tá»a Äá» y trong táºp tin Äầu và o"
msgstr "Sá» thứ tá»± cá»t chứa giá trá» dữ liá»u trong táºp tin Äầu và o"
@@ -3695,17 +3695,17 @@
msgstr "Tá»· lỠáp dụng cho dữ liá»u z"
msgstr "Phần trÄm bản Äá» ÄÆ°á»£c giữ trong bá» nhá»"
msgstr "Sá» phần trÄm pth cá»§a các giá trá»"
msgid ""
"observations"
@@ -20202,32 +20202,27 @@
"Táºp tin ASCII chứa dữ liá»u Äầu và o (hoặc nháºp \"-\" Äá» Äá»c từ Äầu và o tiêu "
"chuẩn)"
#, fuzzy
-msgstr "Dấu phân cách trưá»ng Äầu ra"
-#, fuzzy
#, fuzzy
msgstr "Nếu không ÄÆ°á»£c cung cấp, tên cá»§a bản Äá» Äầu và o ÄÆ°á»£c sá» dụng"
#, fuzzy
msgstr "Miá»n giá trá» lá»c cho dữ liá»u z (min,max)"
#, fuzzy
msgstr "Há» sá» tá»· lá» dùng cho các giá trá» cá»§a cá»t thuá»c tÃnh"
#, fuzzy
msgstr "Sá» lượng lá»p cần Äá»nh nghÄ©a"
@@ -33887,7 +33882,7 @@
msgstr "Không có Äiá»m có phạm trù [%d]"
#, fuzzy
msgstr "Thất bại trong viá»c diá»
n giải width (chiá»u rá»ng) á» dạng sá» nguyên"
@@ -41811,6 +41806,10 @@
msgstr "Phát hiá»n giá trá» ngoại biên"
#, fuzzy
+#~ msgstr "Dấu phân cách trưá»ng Äầu ra"
+#, fuzzy
#~ msgstr "<%s> Äã có trong bá» bản Äá» <%s>"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grassmods_zh\n"
"PO-Revision-Date: 2007-12-13 16:33+0100\n"
"Last-Translator: Zhang Jun <nilarcs at gmail.com>\n"
@@ -1479,11 +1479,11 @@
@@ -3533,8 +3533,8 @@
msgid "Statistic"
msgstr ""
@@ -3545,18 +3545,18 @@
msgstr "转æ¢åçæ
æ ¼å¾çåå¨ç±»å"
#, fuzzy
msgstr "ç¹æ¨¡å¼ä¸ï¼ç¨ä½ x åæ (第ä¸ä¸ªåæ®µæ¯ 1) çåæ®µåºå·"
msgstr ""
msgstr ""
@@ -3605,18 +3605,18 @@
msgstr ""
msgstr "è½½å
¥å
åçå°å¾çç¾åæ¯"
#, fuzzy
msgstr "表达å¡åº¦çæ ¼å¼"
msgid ""
"observations"
@@ -19993,32 +19993,27 @@
msgstr "导å
¥çASCIIæ
æ ¼æä»¶"
#, fuzzy
-msgstr "è¾åºå段åé符"
-#, fuzzy
#, fuzzy
msgstr "读å%-5d个ç¹ç±»å«\n"
#, fuzzy
msgstr "æ´æ°èå´ï¼min,max"
#, fuzzy
msgstr "屿§å段å¼çæ¯ä¾å å"
#, fuzzy
msgstr "æå°ç份æ°"
@@ -33515,7 +33510,7 @@
msgstr "%d ä¸ªç¹æ²¡æç±»å«ï¼å°è¢«å¿½ç¥"
#, fuzzy
msgstr "æ æ³æ¾å°èµ·å§ç¢é %s "
@@ -41408,6 +41403,10 @@
msgstr "ææ¬é¢è²"
#, fuzzy
+#~ msgstr "è¾åºå段åé符"
+#, fuzzy
#~ msgstr "æ æ³å建æ
æ ¼å°å¾ %s"
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_cs.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_cs.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_cs.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -10,7 +10,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_cs\n"
"PO-Revision-Date: 2015-02-08 18:02+0100\n"
"Last-Translator: Jan Trochta <j.trochta at gmail.com>\n"
"Language-Team: <cs at li.org>\n"
@@ -483,7 +483,7 @@
"\n"
"%s"
-#: ../gui/wxpython/gui_core/mapdisp.py:114 ../gui/wxpython/core/render.py:443
+#: ../gui/wxpython/gui_core/mapdisp.py:114 ../gui/wxpython/core/render.py:449
#: ../gui/wxpython/mapdisp/test_mapdisp.py:88
#, python-format
msgid "GRASS module '%s' not found. Unable to start map display window."
@@ -1860,7 +1860,7 @@
#: ../gui/wxpython/gui_core/preferences.py:394
#: ../gui/wxpython/gui_core/preferences.py:589
#: ../gui/wxpython/animation/dialogs.py:845
-#: ../gui/wxpython/mapwin/decorations.py:366
+#: ../gui/wxpython/mapwin/decorations.py:369
msgid "Set font"
msgstr "Nastavit pÃsmo"
@@ -4626,7 +4626,7 @@
msgstr ""
#: ../gui/wxpython/psmap/dialogs.py:291
-#: ../gui/wxpython/mapwin/decorations.py:363
+#: ../gui/wxpython/mapwin/decorations.py:366
#, fuzzy
msgid "Font:"
msgstr "Formát:"
@@ -5962,8 +5962,8 @@
msgid "Execution failed:"
msgstr "Vykonánà pÅÃkazu selhalo:"
-#: ../gui/wxpython/core/gcmd.py:395 ../gui/wxpython/core/render.py:662
-#: ../gui/wxpython/core/render.py:665 ../gui/wxpython/core/render.py:668
+#: ../gui/wxpython/core/gcmd.py:395 ../gui/wxpython/core/render.py:668
+#: ../gui/wxpython/core/render.py:671 ../gui/wxpython/core/render.py:674
msgid "Details:"
msgstr "Detaily:"
@@ -6046,49 +6046,49 @@
msgid "Details: %s\n"
msgstr "Detaily:"
-#: ../gui/wxpython/core/render.py:268
+#: ../gui/wxpython/core/render.py:274
#, python-format
msgid "Unsupported map layer type '%s'"
msgstr "Nepodporovaný typ mapové vrstvy '%s'"
-#: ../gui/wxpython/core/render.py:412
+#: ../gui/wxpython/core/render.py:418
#, fuzzy
msgid "Trying to recover from default region..."
msgstr "ZvÄtÅ¡it podle výchozÃho regionu"
-#: ../gui/wxpython/core/render.py:477
+#: ../gui/wxpython/core/render.py:483
#, python-format
msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
msgstr "Chyba: Nelze otevÅÃt '%(file)s'. Důvod: %(ret)s. wxGUI konÄÃ.\n"
-#: ../gui/wxpython/core/render.py:485
+#: ../gui/wxpython/core/render.py:491
#, fuzzy, python-format
msgid ""
"\n"
"ERROR: Unable to read WIND file: %s\n"
msgstr "Nelze naÄÃst seznam EPSG kódů: %s"
-#: ../gui/wxpython/core/render.py:582
+#: ../gui/wxpython/core/render.py:588
msgid "Invalid map size %d,%d\n"
msgstr "Neplatná hodnota: %s"
-#: ../gui/wxpython/core/render.py:661
+#: ../gui/wxpython/core/render.py:667
msgid "Unable to zoom to raster map <%s>."
msgstr "Nelze nastavit zoom podle rastrové mapy <%s>."
-#: ../gui/wxpython/core/render.py:664
+#: ../gui/wxpython/core/render.py:670
msgid "Unable to zoom to vector map <%s>."
msgstr "Nelze vytvoÅit vektorovou mapu <%s>."
-#: ../gui/wxpython/core/render.py:667
+#: ../gui/wxpython/core/render.py:673
msgid "Unable to zoom to 3d raster map <%s>."
-#: ../gui/wxpython/core/render.py:670
+#: ../gui/wxpython/core/render.py:676
#, fuzzy
msgid ""
"Unable to get current geographic extent. Force quiting wxGUI. Please "
@@ -6097,32 +6097,32 @@
"Nelze zÃskat souÄasný geografický region. wxGUI se ukonÄuje. ProsÃm spusÅ¥te "
"ruÄnÄ g.region pro nápravu problému. "
-#: ../gui/wxpython/core/render.py:981
+#: ../gui/wxpython/core/render.py:987
msgid "ERROR: Rendering failed. Details: %s"
msgstr "Chyba: vykreslovánà selhalo"
-#: ../gui/wxpython/core/render.py:1028 ../gui/wxpython/core/render.py:1123
+#: ../gui/wxpython/core/render.py:1034 ../gui/wxpython/core/render.py:1129
#, python-format
msgid "Unable to render map layer <%s>."
msgstr "Nelze vykreslit mapovou vrstvu <%s>."
-#: ../gui/wxpython/core/render.py:1234 ../gui/wxpython/core/render.py:1273
+#: ../gui/wxpython/core/render.py:1240 ../gui/wxpython/core/render.py:1279
#, python-format
msgid "Unable to render overlay <%s>."
msgstr "Nelze vykreslit pÅekrytà <%s>."
-#: ../gui/wxpython/core/render.py:1370
+#: ../gui/wxpython/core/render.py:1376
#, fuzzy
msgid "Downloading data "
msgstr "NaÄÃtám data..."
-#: ../gui/wxpython/core/render.py:1380
+#: ../gui/wxpython/core/render.py:1386
#, fuzzy
msgid "Rendering & "
msgstr "Vykreslit"
-#: ../gui/wxpython/core/render.py:1382
+#: ../gui/wxpython/core/render.py:1388
#, fuzzy
msgid "Rendering..."
msgstr "Vykreslit"
@@ -12222,7 +12222,7 @@
msgstr "Vyberte soubor"
#: ../gui/wxpython/animation/dialogs.py:863
-#: ../gui/wxpython/mapwin/decorations.py:335
+#: ../gui/wxpython/mapwin/decorations.py:338
#, fuzzy
msgid "Text:"
msgstr "Test"
@@ -13425,24 +13425,24 @@
msgid "Print preview"
msgstr "Náhled tisku"
-#: ../gui/wxpython/mapwin/decorations.py:174
-#: ../gui/wxpython/mapwin/decorations.py:221
+#: ../gui/wxpython/mapwin/decorations.py:177
+#: ../gui/wxpython/mapwin/decorations.py:224
msgid ""
"Please install Python Imaging Library (PIL)\n"
"for better control of legend and other decorations."
msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:326
+#: ../gui/wxpython/mapwin/decorations.py:329
#, fuzzy
msgid "Show text object"
msgstr "Zobr. výpoÄ. region"
-#: ../gui/wxpython/mapwin/decorations.py:351
+#: ../gui/wxpython/mapwin/decorations.py:354
#: ../gui/wxpython/nviz/tools.py:1011
msgid "Rotation:"
msgstr "OtoÄenÃ:"
-#: ../gui/wxpython/mapwin/decorations.py:379
+#: ../gui/wxpython/mapwin/decorations.py:382
msgid ""
"Drag text with mouse in pointer mode to position.\n"
"Double-click to change options"
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_de.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_de.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_de.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -11,7 +11,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_de\n"
"PO-Revision-Date: 2015-01-14 15:50+0100\n"
"Last-Translator: Markus Neteler <neteler at osgeo.org>\n"
"Language-Team: German <grass-translations at lists.osgeo.org>\n"
@@ -482,7 +482,7 @@
"\n"
"%s"
#, python-format
@@ -1816,7 +1816,7 @@
msgid "Set font"
msgstr "Schrift"
@@ -4602,7 +4602,7 @@
"Ecke des Papiers"
msgid "Font:"
msgstr "Schriftart:"
@@ -5822,8 +5822,8 @@
msgstr "Ausführung fehlgeschlagen:"
msgid "Details:"
msgstr "Einzelheiten:"
@@ -5914,23 +5914,23 @@
msgstr "Einzelheiten: %s\n"
#, python-format
msgstr "Nicht unterstützter Kartenebenentyp '%s'"
#, fuzzy
msgstr "Auf die Standardregion zoomen"
#, python-format
msgstr ""
"Fehler: Unable to open '%(file)s'. Begründung: %(ret)s. wxGUI exited.\n"
#, python-format
msgid ""
"\n"
@@ -5939,27 +5939,27 @@
"\n"
"FEHLER: Kann WIND Datei nicht lesen: %s\n"
#, python-format
msgstr "Ungültige KartengröÃe %d, %d\n"
#, python-format
msgstr "Kann nicht auf die Rasterkarte <%s> zoomen."
#, python-format
msgstr "Kann nicht auf die Vektorkarte <%s> zoomen."
msgid ""
"manually run g.region to fix the problem."
@@ -5968,31 +5968,31 @@
"SchlieÃen von wxGUI. Führen Sie bitte g.region manuell aus, um das Problem "
"zu beheben."
#, python-format
msgstr "FEHLER: Rendering fehlgeschlagen. Details: %s"
#, python-format
msgstr "Kann die Kartenebene <%s> nicht rendern."
#, python-format
msgstr "Kann die Ãberlagerung <%s> nicht rendern."
msgstr "Lade Daten herunter"
#, fuzzy
msgstr "Rendern"
msgstr "Rendern..."
@@ -12049,7 +12049,7 @@
msgstr "Wählen Sie eine Datei"
msgid "Text:"
msgstr "Text:"
@@ -13210,23 +13210,23 @@
msgstr "Druckvorschau"
msgid ""
msgstr ""
msgstr "Zeige Textobjekte"
msgid "Rotation:"
msgstr "Rotation:"
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_el.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_el.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_el.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_el\n"
"PO-Revision-Date: 2013-02-07 20:23+0200\n"
"Last-Translator: Nikos Ves <vesnikos at gmail.com>\n"
"Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
@@ -457,7 +457,7 @@
msgid "Loading ctypes libs failed"
msgstr "Î ÏοÏÏÏÏη ÏοÏ
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη <%(name)s> (%(type)s) αÏÎÏÏ
Ïε."
#, python-format
@@ -1769,7 +1769,7 @@
msgid "Set font"
msgstr ""
@@ -4399,7 +4399,7 @@
msgstr ""
msgid "Font:"
msgstr ""
@@ -5589,8 +5589,8 @@
msgstr "H εκÏÎλεÏη αÏÎÏÏ
Ïε:"
msgid "Details:"
msgstr "ÎεÏÏομÎÏιεÏ:"
@@ -5669,78 +5669,78 @@
msgstr "ÎεÏÏομÎÏÎ¹ÎµÏ %s\n"
#, python-format
msgstr ""
msgstr ""
#, python-format
msgstr ""
msgid ""
"\n"
msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î±ÏÏείοÏ
'%s'\n"
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr "Îεν ήÏαν δÏ
ναÏή η δημιοÏ
Ïγεία ÏÏοÏίλ για Ïον raster ÏάÏÏη."
msgid ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, fuzzy
msgstr "ΦÏÏÏÏÏη δεδομÎνÏν..."
msgstr ""
msgstr ""
@@ -11306,7 +11306,7 @@
msgstr "ÎÏιλογή αÏÏείοÏ
msgid "Text:"
msgstr ""
@@ -12447,23 +12447,23 @@
msgstr ""
msgid ""
msgstr ""
msgstr ""
msgid "Rotation:"
msgstr "ΠεÏιÏÏÏοÏή:"
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_es.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_es.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_es.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -10,7 +10,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_es\n"
"PO-Revision-Date: 2014-12-08 20:51-0600\n"
"Last-Translator: Daniel Torres <nobeeakon at gmail.com>\n"
"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -486,7 +486,7 @@
"\n"
"%s"
#, python-format
@@ -1867,7 +1867,7 @@
msgid "Set font"
msgstr "Establecer el tipo de letra."
@@ -4665,7 +4665,7 @@
"del papel"
msgid "Font:"
msgstr "Fuente:"
@@ -5925,8 +5925,8 @@
msgstr "La ejecución ha fallado."
msgid "Details:"
msgstr "Detalles."
@@ -6012,49 +6012,49 @@
msgstr "Detalles."
#, python-format
msgstr "Tipo de capa de mapa no soportada '%s'."
#, fuzzy
msgstr "Acercamiento a la región predeterminada (zoom)."
#, python-format
msgstr "Error: No se puede abrir '%(file)s'. Razón: %(ret)s. wxGUI salió.\n"
msgid ""
"\n"
msgstr "Falló la lectura del archivo %s."
msgstr "Valor no válido: %s"
#, python-format
msgstr "No es posible realizar un zoom al mapa raster <%s>."
#, python-format
msgstr "No se puede realizar un zoom al mapa vectorial <%s>."
#, fuzzy
msgid ""
@@ -6064,32 +6064,32 @@
"abandono de la interfaz wxGUI. Por favor ejecute manualmente g.region para "
"solucionar el problema."
msgstr "ERROR: Falló el renderizado"
#, python-format
msgstr "No se ha podido realizar la presentación de la capa de mapa <%s>."
#, python-format
msgstr "No se ha podido realizar la presentación de la superposicion <%s>."
#, fuzzy
msgstr "Cargando datos."
#, fuzzy
msgstr "Renderizar"
#, fuzzy
msgstr "Renderizar"
@@ -12282,7 +12282,7 @@
msgstr "Escoger archivo"
#, fuzzy
msgid "Text:"
msgstr "Texto"
@@ -13489,24 +13489,24 @@
msgstr "Vista previa de impresión."
msgid ""
msgstr ""
#, fuzzy
msgstr "Mostrar la región de cómputo."
msgid "Rotation:"
msgstr "Rotación:"
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -9,7 +9,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_fr\n"
"PO-Revision-Date: 2015-02-16 08:39+0100\n"
"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: français <grass-translations at lists.osgeo.org>\n"
@@ -68,8 +68,12 @@
msgstr "Mode zoom pour les nuages de points (bouton de souris gauche, molette)"
#: ../gui/wxpython/iscatt/toolbars.py:56
-msgid "Zoom to scatter plot data extend mode (click on scatter plot for zooming to extend)"
-msgstr "Mode de zoom sur l'emprise des données du nuage de points (cliquer sur le nuage de points pour zoomer sur l'emprise)"
+msgid ""
+"Zoom to scatter plot data extend mode (click on scatter plot for zooming to "
+"extend)"
+msgstr ""
+"Mode de zoom sur l'emprise des données du nuage de points (cliquer sur le "
+"nuage de points pour zoomer sur l'emprise)"
#: ../gui/wxpython/iscatt/toolbars.py:58
msgid "Show/hide class manager"
@@ -99,7 +103,8 @@
#: ../gui/wxpython/iscatt/toolbars.py:172
msgid "Add new vertex between last and first points of the boundary"
-msgstr "Ajouter un nouveau sommet entre le dernier et le premier point du contour"
+msgstr ""
+"Ajouter un nouveau sommet entre le dernier et le premier point du contour"
#: ../gui/wxpython/iscatt/toolbars.py:174
msgid "Move vertex"
@@ -119,7 +124,9 @@
#: ../gui/wxpython/iscatt/toolbars.py:180
msgid "Remove polygon (click on scatter plot for removing it's polygon)"
-msgstr "Supprimer le polygone (cliquer sur le nuage de points pour supprimer son polygone)"
+msgstr ""
+"Supprimer le polygone (cliquer sur le nuage de points pour supprimer son "
+"polygone)"
#: ../gui/wxpython/iscatt/toolbars.py:257
msgid "Add class"
@@ -141,33 +148,45 @@
#, python-format
msgid ""
"Interactive Scatter Plot Tool can not be used.\n"
-"Number of cells (rows*cols) <%d> in current regionis higher than maximum limit <%d>.\n"
+"Number of cells (rows*cols) <%d> in current regionis higher than maximum "
+"limit <%d>.\n"
"\n"
"You can reduce number of cells in current region using <g.region> command."
msgstr ""
"L'outil interactif de nuage de points ne peut pas être utilisé.\n"
-"Le nombre de cellules (lignes*colonnes) <%d> de la région courante ets plus grand que la limite maximale <%d>.\n"
+"Le nombre de cellules (lignes*colonnes) <%d> de la région courante ets plus "
+"grand que la limite maximale <%d>.\n"
"\n"
-"Vous pouvez diminuer le nombre de cellules de la région avec la commande <g.region>."
+"Vous pouvez diminuer le nombre de cellules de la région avec la commande <g."
+"region>."
#: ../gui/wxpython/iscatt/controllers.py:228
#, python-format
msgid ""
-"Number of cells (rows*cols) <%d> in current region is higher than recommended threshold <%d>.\n"
-"It is strongly advised to reduce number of cells in current region bellow recommend threshold.\n"
+"Number of cells (rows*cols) <%d> in current region is higher than "
+"recommended threshold <%d>.\n"
+"It is strongly advised to reduce number of cells in current region bellow "
+"recommend threshold.\n"
" It can be done by <g.region> command.\n"
"\n"
"Do you want to continue using Interactive Scatter Plot Tool with this region?"
msgstr ""
-"Le nombre de cellules (lignes*colonnes) <%d> de la région courante est plus grand que le seuil recommandé <%d>.\n"
-"Il est fortement conseillé de réduire le nombre de cellules de la région courante en dessous du seuil recommandé.\n"
+"Le nombre de cellules (lignes*colonnes) <%d> de la région courante est plus "
+"grand que le seuil recommandé <%d>.\n"
+"Il est fortement conseillé de réduire le nombre de cellules de la région "
+"courante en dessous du seuil recommandé.\n"
" Ceci peut être fait par la commande <g.region>.\n"
"\n"
-"Voulez-vous continuer à utiliser l'outil interactif de nuages de points avec cette région ?"
+"Voulez-vous continuer à utiliser l'outil interactif de nuages de points avec "
+"cette région ?"
#: ../gui/wxpython/iscatt/controllers.py:284
-msgid "Scatter plot with same band combination (regardless x y order) is already displayed."
-msgstr "Un nuage de points avec la même combinaison de bandes (indépendament de l'ordre x y) est déjà affiché."
+msgid ""
+"Scatter plot with same band combination (regardless x y order) is already "
+"displayed."
+msgstr ""
+"Un nuage de points avec la même combinaison de bandes (indépendament de "
+"l'ordre x y) est déjà affiché."
#: ../gui/wxpython/iscatt/controllers.py:297
#, python-format
@@ -182,21 +201,27 @@
#, python-format
msgid ""
"Scatter plot cannot be added.\n"
-"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <%d>.\n"
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <"
+"%d>.\n"
msgstr ""
"Le nuage de point ne peut pas être ajouté.\n"
-"La multiplication des plages de bandes <%s:%d * %s:%d = %d> est supérieure à la limite maximale <%d>.\n"
+"La multiplication des plages de bandes <%s:%d * %s:%d = %d> est supérieure à "
+"la limite maximale <%d>.\n"
#: ../gui/wxpython/iscatt/controllers.py:314
#, python-format
msgid ""
-"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended limit <%d>.\n"
-"It is strongly advised to reduce range extend of bands(e. g. using r.rescale) bellow recommended threshold.\n"
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended "
+"limit <%d>.\n"
+"It is strongly advised to reduce range extend of bands(e. g. using r."
+"rescale) bellow recommended threshold.\n"
"\n"
"Do you really want to add this scatter plot?"
msgstr ""
-"La multiplication des étendues de bandes <%s:%d * %s:%d = %d> est supérieure à la limite recommandée <%d>.\n"
-"Il est fortement conseillé de réduire la plage des bandes (ex : en utilisant r.rescale) en dessous du seuil recommandé.\n"
+"La multiplication des étendues de bandes <%s:%d * %s:%d = %d> est supérieure "
+"à la limite recommandée <%d>.\n"
+"Il est fortement conseillé de réduire la plage des bandes (ex : en utilisant "
+"r.rescale) en dessous du seuil recommandé.\n"
"\n"
"Voulez-vous vraiment ajouter ce nuage de poitns ?"
@@ -206,7 +231,8 @@
"\n"
"There is no class yet, do you want to create one?"
msgstr ""
-"Pour sélectionner une zone dans le nuage de points, vous devez d'abord sélectionner une classe.\n"
+"Pour sélectionner une zone dans le nuage de points, vous devez d'abord "
+"sélectionner une classe.\n"
"\n"
"Il n'y a pas encore de classe, voulez-vous en créer une ?"
@@ -304,8 +330,12 @@
msgstr "Les bandes sélectionnées doivent être différentes."
#: ../gui/wxpython/iscatt/dialogs.py:191
-msgid "Scatter plot with same bands combination (regardless x y order) has been already added into the list."
-msgstr "Un nuage de points avec la même combinaison de bandes (indépendament de l'ordre x y) a déjà été ajouté à la liste."
+msgid ""
+"Scatter plot with same bands combination (regardless x y order) has been "
+"already added into the list."
+msgstr ""
+"l'ordre x y) a déjà été ajouté à la liste."
#: ../gui/wxpython/iscatt/dialogs.py:253 ../gui/wxpython/iclass/dialogs.py:710
msgid "Enter name of new vector map:"
@@ -357,8 +387,11 @@
#: ../gui/wxpython/wxplot/dialogs.py:690
#: ../gui/wxpython/wxplot/dialogs.py:1136 ../gui/wxpython/gcp/manager.py:2409
#: ../gui/wxpython/vnet/dialogs.py:1188
-msgid "Apply and save changes to user settings file (default for next sessions)"
-msgstr "Appliquer et enregistrer les modifications des paramètres utilisateur (valeurs par défaut pour la prochaine session)"
+msgid ""
+"Apply and save changes to user settings file (default for next sessions)"
+msgstr ""
+"Appliquer et enregistrer les modifications des paramètres utilisateur "
+"(valeurs par défaut pour la prochaine session)"
#: ../gui/wxpython/iscatt/dialogs.py:361
#: ../gui/wxpython/gui_core/dialogs.py:1678
@@ -456,11 +489,13 @@
msgstr "Ãchec du chargement de la librairie ctypes"
#, python-format
-msgstr "Module GRASS '%s' introuvable. Impossible de démarrer la fenêtre d'affichage des cartes."
+msgstr ""
+"Module GRASS '%s' introuvable. Impossible de démarrer la fenêtre d'affichage "
+"des cartes."
#: ../gui/wxpython/gui_core/gselect.py:59
#, python-format
@@ -648,7 +683,8 @@
#: ../gui/wxpython/gui_core/gselect.py:1796
#: ../gui/wxpython/web_services/dialogs.py:281
msgid "No data source defined, settings are not saved."
-msgstr "Pas de source de données définie, les paramètres ne sont pas enregistrés."
+msgstr ""
+"Pas de source de données définie, les paramètres ne sont pas enregistrés."
#: ../gui/wxpython/gui_core/gselect.py:1930
#: ../gui/wxpython/location_wizard/wizard.py:778
@@ -731,7 +767,9 @@
#: ../gui/wxpython/gui_core/toolbars.py:56
msgid "Zoom to default or saved region, save to named region, ..."
-msgstr "Zoomer sur la région de calculs par défaut ou enregistrée, enregistre vers un nom de région, ..."
+msgstr ""
+"Zoomer sur la région de calculs par défaut ou enregistrée, enregistre vers "
+"un nom de région, ..."
#: ../gui/wxpython/gui_core/toolbars.py:58
msgid "Zoom to selected map layer(s)"
@@ -834,8 +872,12 @@
msgstr "Fermer la boîte de dialogue après exécution"
#: ../gui/wxpython/gui_core/forms.py:586
-msgid "Close dialog when command is successfully finished. Change this settings in Preferences dialog ('Command' tab)."
-msgstr "Fermer la fenêtre de dialogue quand la commande se termine avec succès. Modifier ce paramètre dans les Préférences (onglet 'Commande')."
+msgid ""
+"Close dialog when command is successfully finished. Change this settings in "
+"Preferences dialog ('Command' tab)."
+msgstr ""
+"Fermer la fenêtre de dialogue quand la commande se termine avec succès. "
+"Modifier ce paramètre dans les Préférences (onglet 'Commande')."
#: ../gui/wxpython/gui_core/forms.py:753
#, python-format
@@ -873,7 +915,9 @@
#: ../gui/wxpython/gui_core/forms.py:1301
msgid "Show graphical representation of temporal extent of dataset(s) ."
-msgstr "Afficher une représentation graphique de l'emprise temporelle du jeu de données."
+msgstr ""
+"Afficher une représentation graphique de l'emprise temporelle du jeu de "
+"données."
#: ../gui/wxpython/gui_core/forms.py:1459 ../gui/wxpython/core/utils.py:998
msgid "Select Color"
@@ -918,8 +962,12 @@
msgstr "ou entrer les valeurs manuellement :"
#: ../gui/wxpython/gui_core/forms.py:1561
-msgid "Enter file content directly instead of specifying a file. Temporary file will be automatically created."
-msgstr "Entrez le contenu directement au lieu de spécifier un fichier. Un fichier temporaire sera créé automatiquement."
+msgid ""
+"Enter file content directly instead of specifying a file. Temporary file "
+"will be automatically created."
+msgstr ""
+"Entrez le contenu directement au lieu de spécifier un fichier. Un fichier "
+"temporaire sera créé automatiquement."
#: ../gui/wxpython/gui_core/forms.py:1828
#: ../gui/wxpython/gmodeler/frame.py:132 ../gui/wxpython/modules/vkrige.py:102
@@ -999,7 +1047,9 @@
#: ../gui/wxpython/gui_core/widgets.py:882
msgid "Type to search in all modules. Press Enter for next match."
-msgstr "Taper pour rechercher dans tous les modules. Appuyer sur Entrer pour la prochaine concordance."
+msgstr ""
+"Taper pour rechercher dans tous les modules. Appuyer sur Entrer pour la "
+"prochaine concordance."
#: ../gui/wxpython/gui_core/widgets.py:946
msgid "Searching, please type more characters."
@@ -1055,7 +1105,8 @@
#: ../gui/wxpython/gui_core/query.py:40
msgid "Right click to copy selected values to clipboard."
-msgstr "Clic droit pour copier les valeurs sélectionnées vers le presse-papier."
+msgstr ""
+"Clic droit pour copier les valeurs sélectionnées vers le presse-papier."
#: ../gui/wxpython/gui_core/query.py:44
msgid "Feature"
@@ -1205,8 +1256,12 @@
#: ../gui/wxpython/gui_core/dialogs.py:420
#, python-format
-msgid "Vector map <%s> already exists in the current mapset. Do you want to overwrite it?"
-msgstr "La carte vecteur <%s> existe déjà dans le jeu de cartes courant. Voulez-vous l'écraser ?"
+msgid ""
+"Vector map <%s> already exists in the current mapset. Do you want to "
+"overwrite it?"
+msgstr ""
+"La carte vecteur <%s> existe déjà dans le jeu de cartes courant. Voulez-vous "
+"l'écraser ?"
#: ../gui/wxpython/gui_core/dialogs.py:423
#: ../gui/wxpython/lmgr/layertree.py:834
@@ -1222,8 +1277,13 @@
msgstr "Enregistrer une région :"
#: ../gui/wxpython/gui_core/dialogs.py:544
-msgid "Name cannot begin with '.' and must not contain space, quotes, '/', ''', '@', ',', '=', '*', and all other non-alphanumeric characters."
-msgstr "Un nom ne peut aps commencer par '.' et ne doit pas contenir d'espaces, guillemets, '/', ''', '@', ',', '=', '*', ou tout autre caractère non alpha-numérique."
+msgid ""
+"Name cannot begin with '.' and must not contain space, quotes, '/', ''', "
+"'@', ',', '=', '*', and all other non-alphanumeric characters."
+msgstr ""
+"Un nom ne peut aps commencer par '.' et ne doit pas contenir d'espaces, "
+"guillemets, '/', ''', '@', ',', '=', '*', ou tout autre caractère non alpha-"
+"numérique."
#: ../gui/wxpython/gui_core/dialogs.py:559
msgid "Create or edit imagery groups"
@@ -1239,12 +1299,17 @@
#: ../gui/wxpython/gui_core/dialogs.py:594
msgid "Close dialog, changes are not applied"
-msgstr "Fermer la boîte de dialogue, les modifications ne seront pas appliquées"
+msgstr ""
+"Fermer la boîte de dialogue, les modifications ne seront pas appliquées"
#: ../gui/wxpython/gui_core/dialogs.py:635
#: ../gui/wxpython/gui_core/dialogs.py:1382
-msgid "Put here a regular expression. Characters '.*' stand for anything, character '^' stands for the beginning and '$' for the end."
-msgstr "Mettez ici une expression régulière. Le caratère '.*' correspond à n'importe quoi, le caractère '^' correspond au début et '$' à la fin."
+msgid ""
+"Put here a regular expression. Characters '.*' stand for anything, character "
+"'^' stands for the beginning and '$' for the end."
+msgstr ""
+"Mettez ici une expression régulière. Le caratère '.*' correspond à n'importe "
+"quoi, le caractère '^' correspond au début et '$' à la fin."
#: ../gui/wxpython/gui_core/dialogs.py:642
msgid "Select existing group or enter name of new group:"
@@ -1256,7 +1321,9 @@
#: ../gui/wxpython/gui_core/dialogs.py:662
msgid "Select existing subgroup or enter name of new subgroup:"
-msgstr "Sélectionner un sous-groupe existant ou entrez le nom d'un nouveau sous-groupe :"
+msgstr ""
+"Sélectionner un sous-groupe existant ou entrez le nom d'un nouveau sous-"
+"groupe :"
#: ../gui/wxpython/gui_core/dialogs.py:690
#: ../gui/wxpython/gui_core/dialogs.py:743
@@ -1289,7 +1356,8 @@
#: ../gui/wxpython/gui_core/dialogs.py:1057
#, python-format
msgid "Group <%s> was changed, do you want to apply changes?"
-msgstr "Le groupe <%s> a été modifié, voulez-vous enregistrer les modifications ?"
+msgstr ""
+"Le groupe <%s> a été modifié, voulez-vous enregistrer les modifications ?"
#: ../gui/wxpython/gui_core/dialogs.py:1059
#: ../gui/wxpython/gui_core/dialogs.py:1071
@@ -1299,7 +1367,9 @@
#: ../gui/wxpython/gui_core/dialogs.py:1069
#, python-format
msgid "Subgroup <%s> was changed, do you want to apply changes?"
-msgstr "Le sous-groupe <%s> a été modifié, voulez-vous enregistrer les modifications ?"
+msgstr ""
+"Le sous-groupe <%s> a été modifié, voulez-vous enregistrer les "
+"modifications ?"
#: ../gui/wxpython/gui_core/dialogs.py:1125
msgid "No raster maps selected."
@@ -1473,12 +1543,15 @@
#: ../gui/wxpython/gui_core/dialogs.py:1850
#, python-brace-format
msgid "Add linked layers into layer tree ({mightNotWork})"
-msgstr "Ajouter les couches liées dans l'arborescence des couches ({mightNotWork})"
+msgstr ""
+"Ajouter les couches liées dans l'arborescence des couches ({mightNotWork})"
#: ../gui/wxpython/gui_core/dialogs.py:1853
msgid "Add imported layers into layer tree ({mightNotWork})"
-msgstr "Ajouter les couches importées dans l'arborescence des couches ({mightNotWork})"
+msgstr ""
+"Ajouter les couches importées dans l'arborescence des couches "
+"({mightNotWork})"
#: ../gui/wxpython/gui_core/dialogs.py:1859
msgid "&Link"
@@ -1692,7 +1765,9 @@
#: ../gui/wxpython/gui_core/preferences.py:305
msgid "Automatically copy selected text to clipboard (in Command console)"
-msgstr "Copier automatiquement le texte dans le bloc-notes (dans la console de commande)"
+msgstr ""
+"Copier automatiquement le texte dans le bloc-notes (dans la console de "
+"commande)"
#: ../gui/wxpython/gui_core/preferences.py:320
msgid "Workspace settings"
@@ -1711,8 +1786,13 @@
msgstr "Enregistrer la configuration de fenêtre actuelle comme défaut"
#: ../gui/wxpython/gui_core/preferences.py:353
-msgid "Save current position and size of Layer Manager window and opened Map Display window(s) and use as default for next sessions."
-msgstr "Enregistrer les positions et tailles actuelles de la fenêtre de gestionnaire de couches et de la (des) fenêtre(s) d'affichage de carte ; utiliser par défaut pour les sessions suivantes."
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+"Enregistrer les positions et tailles actuelles de la fenêtre de gestionnaire "
+"de couches et de la (des) fenêtre(s) d'affichage de carte ; utiliser par "
+"défaut pour les sessions suivantes."
#: ../gui/wxpython/gui_core/preferences.py:372
#: ../gui/wxpython/nviz/tools.py:96
@@ -1734,7 +1814,7 @@
msgid "Set font"
msgstr "Définir la police"
@@ -1927,7 +2007,8 @@
#: ../gui/wxpython/gui_core/preferences.py:1089
msgid "Automatically hightlight selected features in map display"
-msgstr "Surligner automatiquement les entités sélectionnées dans la fenêtre de cartes"
+msgstr ""
+"Surligner automatiquement les entités sélectionnées dans la fenêtre de cartes"
#: ../gui/wxpython/gui_core/preferences.py:1109
msgid "Data browser"
@@ -1961,15 +2042,21 @@
#: ../gui/wxpython/gui_core/preferences.py:1207
msgid ""
"\n"
-"Note: This only controls the coordinates displayed in the lower-left of the Map Display\n"
-"window's status bar. It is purely cosmetic and does not affect the working location's\n"
-"projection in any way. You will need to enable the Projection check box in the drop-down\n"
+"Note: This only controls the coordinates displayed in the lower-left of the "
+"Map Display\n"
+"window's status bar. It is purely cosmetic and does not affect the working "
+"location's\n"
+"projection in any way. You will need to enable the Projection check box in "
+"the drop-down\n"
"menu located at the bottom of the Map Display window.\n"
msgstr ""
"\n"
-"Note : Ceci contrôle uniquement les coordonnées affichées dans le coin inférieur gauche\n"
-" de la fenêtre de Carte. L'effet est purement cosméthique et n'affecte pas la projection\n"
-" du secteur d'aucune manière. Vous devrez cocher la case Projection dans le menu déroulant\n"
+"Note : Ceci contrôle uniquement les coordonnées affichées dans le coin "
+"inférieur gauche\n"
+" de la fenêtre de Carte. L'effet est purement cosméthique et n'affecte pas "
+"la projection\n"
+" du secteur d'aucune manière. Vous devrez cocher la case Projection dans le "
+"menu déroulant\n"
" en bas de la fenêtre de carte.\n"
#: ../gui/wxpython/gui_core/preferences.py:1222
@@ -1986,8 +2073,12 @@
msgstr "Fichier EPSG :"
#: ../gui/wxpython/gui_core/preferences.py:1270
-msgid "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string directly."
-msgstr "Charger les codes EPSG (patience), entrer le code EPSG ou insérer la chaîne Proj.4 directement."
+msgid ""
+"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
+"directly."
+msgstr ""
+"Charger les codes EPSG (patience), entrer le code EPSG ou insérer la chaîne "
+"Proj.4 directement."
#: ../gui/wxpython/gui_core/preferences.py:1278
msgid "&Load EPSG codes"
@@ -2023,7 +2114,9 @@
#: ../gui/wxpython/gui_core/preferences.py:1449
msgid "Failed to set default display font. Try different font."
-msgstr "Impossible de définir la police de caractères par défaut. Essayez une police de caractère différente."
+msgstr ""
+"Impossible de définir la police de caractères par défaut. Essayez une police "
+"de caractère différente."
#: ../gui/wxpython/gui_core/preferences.py:1549
msgid "Select font:"
@@ -2097,8 +2190,12 @@
msgstr "Fichier &Log"
#: ../gui/wxpython/gui_core/goutput.py:149
-msgid "Toggle to save list of executed commands into a file; content saved when switching off."
-msgstr "Basculer l'enregistrement de la liste des commandes exécutées dans le fichier; le contenu est enregistré lorsque désactivé."
+msgid ""
+"Toggle to save list of executed commands into a file; content saved when "
+"switching off."
+msgstr ""
+"Basculer l'enregistrement de la liste des commandes exécutées dans le "
+"fichier; le contenu est enregistré lorsque désactivé."
#: ../gui/wxpython/gui_core/goutput.py:374
#: ../gui/wxpython/gui_core/goutput.py:461
@@ -2371,8 +2468,12 @@
#: ../gui/wxpython/dbmgr/base.py:154
#, python-format
-msgid "Attribute table <%s> not found. For creating the table switch to 'Manage layers' tab."
-msgstr "Table d'attributs <%s> non trouvée. Pour créer la table passer à l'onglet 'Gérer les couches'."
+msgid ""
+"Attribute table <%s> not found. For creating the table switch to 'Manage "
+"layers' tab."
+msgstr ""
+"Table d'attributs <%s> non trouvée. Pour créer la table passer à l'onglet "
+"'Gérer les couches'."
#: ../gui/wxpython/dbmgr/base.py:165
#, python-format
@@ -2406,16 +2507,21 @@
# Conserver le sigle GUI me semble plus clair pour l'utilisateur que sa traduction française (IGU) peu voire pas usitée.
#: ../gui/wxpython/dbmgr/base.py:321
msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
-msgstr "Valeur impossible à décoder. Fixer l'encodage dans les préférences du GUI ('Attributs')"
+msgstr ""
+"Valeur impossible à décoder. Fixer l'encodage dans les préférences du GUI "
+"('Attributs')"
#: ../gui/wxpython/dbmgr/base.py:330
#, python-format
msgid ""
-"Error loading attribute data. Record number: %(rec)d. Unable to convert value '%(val)s' in key column (%(key)s) to integer.\n"
+"Error loading attribute data. Record number: %(rec)d. Unable to convert "
+"value '%(val)s' in key column (%(key)s) to integer.\n"
"\n"
"Details: %(detail)s"
msgstr ""
-"Erreur au chargement des données attributaires. Numéro d'enregistrement %(rec)d. Impossible de convertir la valeur '%(val)s' dans la colonne clé (%(key)s) en nombre entier.\n"
+"Erreur au chargement des données attributaires. Numéro d'enregistrement "
+"%(rec)d. Impossible de convertir la valeur '%(val)s' dans la colonne clé "
+"(%(key)s) en nombre entier.\n"
"\n"
"Détails: %(detail)s"
@@ -2496,7 +2602,8 @@
#: ../gui/wxpython/dbmgr/base.py:1026
msgid "Attribute data - right-click to edit/manage records"
-msgstr "Données attributaires - clic droit pour éditer/gérer les enregistrements"
+msgstr ""
+"Données attributaires - clic droit pour éditer/gérer les enregistrements"
#: ../gui/wxpython/dbmgr/base.py:1041 ../gui/wxpython/dbmgr/base.py:2020
#: ../gui/wxpython/dbmgr/base.py:2613 ../gui/wxpython/dbmgr/base.py:2744
@@ -2590,7 +2697,8 @@
#: ../gui/wxpython/dbmgr/base.py:1454
#, python-format
msgid "Record with category number %d already exists in the table."
-msgstr "L'enregistrement portant la catégorie numéro %d existe déjà dans la table."
+msgstr ""
+"L'enregistrement portant la catégorie numéro %d existe déjà dans la table."
#: ../gui/wxpython/dbmgr/base.py:1464
#, python-format
@@ -2608,8 +2716,12 @@
#: ../gui/wxpython/dbmgr/base.py:1539
#, python-format
-msgid "Selected data records (%d) will be permanently deleted from table. Do you want to delete them?"
-msgstr "Les enregistrements sélectionnés (%d) vont être définitivement supprimés de la table. Souhaitez-vous les supprimer ?"
+msgid ""
+"Selected data records (%d) will be permanently deleted from table. Do you "
+"want to delete them?"
+msgstr ""
+"Les enregistrements sélectionnés (%d) vont être définitivement supprimés de "
+"la table. Souhaitez-vous les supprimer ?"
#: ../gui/wxpython/dbmgr/base.py:1542 ../gui/wxpython/dbmgr/base.py:1588
msgid "Delete records"
@@ -2617,8 +2729,12 @@
#: ../gui/wxpython/dbmgr/base.py:1585
#, python-format
-msgid "All data records (%d) will be permanently deleted from table. Do you want to delete them?"
-msgstr "Tous les enregistrements (%d) seront définitivement supprimés de la table. Souhaitez-vous les supprimer ?"
+msgid ""
+"All data records (%d) will be permanently deleted from table. Do you want to "
+"delete them?"
+msgstr ""
+"Tous les enregistrements (%d) seront définitivement supprimés de la table. "
+"Souhaitez-vous les supprimer ?"
#: ../gui/wxpython/dbmgr/base.py:1759
msgid "Nothing to extract."
@@ -2700,13 +2816,21 @@
#: ../gui/wxpython/dbmgr/base.py:2238
#, python-format
-msgid "Unable to rename column <%(column)s> to <%(columnTo)s>. Column already exists in the table <%(table)s>."
-msgstr "Impossible de renommer la colonne <%(column)s> en <%(columnTo)s>. La colonne existe déjà dans la table <%(table)s>."
+msgid ""
+"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
+"exists in the table <%(table)s>."
+msgstr ""
+"Impossible de renommer la colonne <%(column)s> en <%(columnTo)s>. La colonne "
+"existe déjà dans la table <%(table)s>."
#: ../gui/wxpython/dbmgr/base.py:2254
#, python-format
-msgid "Unable to rename column. Column <%(column)s> doesn't exist in the table <%(table)s>."
-msgstr "Impossible de renommer la colonne. La colonnes<%(column)s> n'existe pas dans la table <%(table)s>."
+msgid ""
+"Unable to rename column. Column <%(column)s> doesn't exist in the table <"
+"%(table)s>."
+msgstr ""
+"Impossible de renommer la colonne. La colonnes<%(column)s> n'existe pas dans "
+"la table <%(table)s>."
#: ../gui/wxpython/dbmgr/base.py:2281
msgid "Drop selected column"
@@ -2718,8 +2842,12 @@
#: ../gui/wxpython/dbmgr/base.py:2313
#, python-format
-msgid "Selected %s will PERMANENTLY removed from table. Do you want to drop the column?"
-msgstr "La colonne sélectionnée %s sera DÃFINITIVEMENT supprimée de la table. Souhaitez-vous supprimer cette colonne ?"
+msgid ""
+"Selected %s will PERMANENTLY removed from table. Do you want to drop the "
+"column?"
+msgstr ""
+"La colonne sélectionnée %s sera DÃFINITIVEMENT supprimée de la table. "
+"Souhaitez-vous supprimer cette colonne ?"
#: ../gui/wxpython/dbmgr/base.py:2316 ../gui/wxpython/dbmgr/base.py:2353
msgid "Drop column(s)"
@@ -2734,7 +2862,8 @@
msgstr ""
"Les colonnes sélectionnées\n"
"%s\n"
-"seront DÃFINITIVEMENT supprimées de la table. Souhaitez-vous supprimer ces colonnes ?"
+"seront DÃFINITIVEMENT supprimées de la table. Souhaitez-vous supprimer ces "
+"colonnes ?"
#: ../gui/wxpython/dbmgr/base.py:2438
msgid "List of layers"
@@ -2848,17 +2977,25 @@
#: ../gui/wxpython/dbmgr/base.py:3187
msgid "Unable to create new table. Table name or key column name is missing."
-msgstr "Impossible de créer la nouvelle table. Il manque le nom de la table ou de la colonne clé."
+msgstr ""
+"Impossible de créer la nouvelle table. Il manque le nom de la table ou de la "
+"colonne clé."
#: ../gui/wxpython/dbmgr/base.py:3193
#, python-format
msgid "Unable to create new table. Table <%s> already exists in the database."
-msgstr "Impossible de créer la nouvelle table. La table <%s> existe déjà dans la base."
+msgstr ""
+"Impossible de créer la nouvelle table. La table <%s> existe déjà dans la "
+"base."
#: ../gui/wxpython/dbmgr/base.py:3231
#, python-format
-msgid "Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already exists."
-msgstr "Impossible d'ajouter la nouvelle couche à la carte vecteur <%(vector)s>. La couche %(layer)d existe déjà ."
+msgid ""
+"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
+"exists."
+msgstr ""
+"Impossible d'ajouter la nouvelle couche à la carte vecteur <%(vector)s>. La "
+"couche %(layer)d existe déjà ."
#: ../gui/wxpython/dbmgr/base.py:3395
msgid "Field statistics"
@@ -2878,8 +3015,11 @@
#: ../gui/wxpython/dbmgr/base.py:3500
#, python-format
-msgid "Unable to calculte statistics. Invalid number of lines %d (should be %d)."
-msgstr "Impossible de calculer les statistiques. Nombre de lignes %d invalides (devrait être %d)."
+msgid ""
+"Unable to calculte statistics. Invalid number of lines %d (should be %d)."
+msgstr ""
+"Impossible de calculer les statistiques. Nombre de lignes %d invalides "
+"(devrait être %d)."
#: ../gui/wxpython/dbmgr/base.py:3518
msgid "Unable to calculte standard deviation."
@@ -2900,8 +3040,13 @@
#: ../gui/wxpython/dbmgr/manager.py:85
#, python-format
-msgid "Database connection for vector map <%s> is not defined in DB file. You can define new connection in 'Manage layers' tab."
-msgstr "La connexion à une base de données n'est pas définie dans le fichier DB pour la carte vecteur <%s>. Vous pouvez définir une nouvelle connexion dans l'onglet 'Gérer les couches'."
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file. You can "
+"define new connection in 'Manage layers' tab."
+msgstr ""
+"La connexion à une base de données n'est pas définie dans le fichier DB pour "
+"la carte vecteur <%s>. Vous pouvez définir une nouvelle connexion dans "
+"l'onglet 'Gérer les couches'."
#: ../gui/wxpython/dbmgr/manager.py:90
msgid "Please wait, loading attribute data..."
@@ -2945,7 +3090,8 @@
#: ../gui/wxpython/dbmgr/sqlbuilder.py:115
msgid "Apply SQL statement in Attribute Table Manager"
-msgstr "Appliquer l'expression SQL dans le gestionnaire des tables attributaires"
+msgstr ""
+"Appliquer l'expression SQL dans le gestionnaire des tables attributaires"
#: ../gui/wxpython/dbmgr/sqlbuilder.py:117
msgid "Close the dialog"
@@ -3058,11 +3204,13 @@
msgid ""
"No attribute table found.\n"
"\n"
-"Do you want to create a new attribute table and defined a link to vector map <%s>?"
+"Do you want to create a new attribute table and defined a link to vector map "
+"<%s>?"
msgstr ""
"Pas de table attributaire trouvée.\n"
"\n"
-"Voulez-vous créer une nouvelle table attributaire et la lier au vecteur <%s> ?"
+"Voulez-vous créer une nouvelle table attributaire et la lier au vecteur <"
+"%s> ?"
#: ../gui/wxpython/dbmgr/dialogs.py:77
msgid "Create table?"
@@ -3104,7 +3252,8 @@
#: ../gui/wxpython/dbmgr/dialogs.py:226
#, python-format
msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
-msgstr "Colonne<%(col)s> : La valeur '%(value)s' doit être entrée comme %(type)s."
+msgstr ""
+"Colonne<%(col)s> : La valeur '%(value)s' doit être entrée comme %(type)s."
#: ../gui/wxpython/dbmgr/dialogs.py:436
msgid "Unknown"
@@ -3127,8 +3276,11 @@
#: ../gui/wxpython/dbmgr/vinfo.py:101
-msgid "Failed to query vector map <{map}>. Check database settings and topology."
-msgstr "Ãchec de requête de la carte vecteur <{map}>. Vérifiez les paramètres de la base de données et la topologie."
+msgid ""
+"Failed to query vector map <{map}>. Check database settings and topology."
+msgstr ""
+"Ãchec de requête de la carte vecteur <{map}>. Vérifiez les paramètres de la "
+"base de données et la topologie."
#: ../gui/wxpython/location_wizard/dialogs.py:36
msgid "Set default region extent and resolution"
@@ -3261,8 +3413,13 @@
#: ../gui/wxpython/location_wizard/wizard.py:162
#, python-format
-msgid "Name <%(name)s> is not a valid name for location. Please use only ASCII characters excluding %(chars)s and space."
-msgstr "Le nom <%(name)s> n'est pas un nom valide pour un secteur. Merci de n'utiliser que des caractères ASCII à l'exclusion de %(chars)s et des espaces."
+msgid ""
+"Name <%(name)s> is not a valid name for location. Please use only ASCII "
+"characters excluding %(chars)s and space."
+msgstr ""
+"Le nom <%(name)s> n'est pas un nom valide pour un secteur. Merci de "
+"n'utiliser que des caractères ASCII à l'exclusion de %(chars)s et des "
+"espaces."
#: ../gui/wxpython/location_wizard/wizard.py:165
msgid "Invalid location name"
@@ -3282,8 +3439,12 @@
msgstr "Impossible de créer le secteur"
#: ../gui/wxpython/location_wizard/wizard.py:208
-msgid "Title of the location is limited only to one line and 256 characters. The rest of the text will be ignored."
-msgstr "Le titre du secteur est limité à une ligne et 256 caractères. Le reste du texte sera ignoré."
+msgid ""
+"Title of the location is limited only to one line and 256 characters. The "
+"rest of the text will be ignored."
+msgstr ""
+"Le titre du secteur est limité à une ligne et 256 caractères. Le reste du "
+"texte sera ignoré."
#: ../gui/wxpython/location_wizard/wizard.py:215
msgid "Choose method for creating a new location"
@@ -3524,8 +3685,13 @@
#: ../gui/wxpython/location_wizard/wizard.py:2078
#, python-format
-msgid "Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will need to change the default GIS data directory in the GRASS startup screen."
-msgstr "Le secteur <%(loc)s> va être créé dans le répertoire SIG <%(dir)s>. Il vous faudra changer le répertoire SIG par défaut dans l'écran de démarrage de GRASS."
+msgid ""
+"Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will "
+"need to change the default GIS data directory in the GRASS startup screen."
+msgstr ""
+"Le secteur <%(loc)s> va être créé dans le répertoire SIG <%(dir)s>. Il vous "
+"faudra changer le répertoire SIG par défaut dans l'écran de démarrage de "
+"GRASS."
#: ../gui/wxpython/location_wizard/wizard.py:2083
msgid "New GIS data directory"
@@ -3549,8 +3715,13 @@
#: ../gui/wxpython/rlisetup/functions.py:138
#: ../gui/wxpython/rlisetup/wizard.py:1578
#, python-format
-msgid "The raster map <%s> already exists. Please remove or rename the maps with the prefix '%s' or select the option to overwrite existing maps"
-msgstr "la carte raster <%s> existe déjà . Merci de supprimer ou de renommer les cartes avec le préfix '%s' ou de sélectionner l'option pour écraser les cartes existantes."
+msgid ""
+"The raster map <%s> already exists. Please remove or rename the maps with "
+"the prefix '%s' or select the option to overwrite existing maps"
+msgstr ""
+"la carte raster <%s> existe déjà . Merci de supprimer ou de renommer les "
+"cartes avec le préfix '%s' ou de sélectionner l'option pour écraser les "
+"cartes existantes."
#: ../gui/wxpython/rlisetup/sampling_frame.py:99
#: ../gui/wxpython/mapdisp/frame.py:473 ../gui/wxpython/gcp/mapdisplay.py:248
@@ -3605,7 +3776,9 @@
#: ../gui/wxpython/rlisetup/sampling_frame.py:392
msgid "Draw sampling region by polygon. Right Double click to end drawing"
-msgstr "Dessiner la région d'échantillonage avec un polygone. Double-clic droit pour terminer"
+msgstr ""
+"Dessiner la région d'échantillonage avec un polygone. Double-clic droit pour "
+"terminer"
#: ../gui/wxpython/rlisetup/frame.py:22
msgid "Modify the configuration file"
@@ -3622,7 +3795,8 @@
"Are you sure that you want modify r.li configuration file {name}?\n"
"You could broke the configuration file..."
msgstr ""
-"Ãtes-vous sûr de vouloir modifier le fichier de configuration de r.li {name} ?\n"
+"Ãtes-vous sûr de vouloir modifier le fichier de configuration de r.li "
+"{name} ?\n"
"Vous risquez de casser la configuration ..."
#: ../gui/wxpython/rlisetup/frame.py:88
@@ -3683,8 +3857,12 @@
#: ../gui/wxpython/rlisetup/frame.py:241
#, python-format
-msgid "Set the new name for %s \" \"configuration file"
-msgstr "Définir le nouveau nom pour le fichier de configuration %s \" \""
+msgid ""
+"Set the new name for %s \" "
+"\"configuration file"
+msgstr ""
+"Définir le nouveau nom pour le fichier de configuration %s "
#: ../gui/wxpython/rlisetup/frame.py:243
msgid "Rename configuration file"
@@ -3705,7 +3883,8 @@
#: ../gui/wxpython/rlisetup/wizard.py:130
msgid "r.li.setup wizard canceled. Configuration file not created."
-msgstr "Assistant de r.li interrompu. Le fichier de configuration n'a pas été créé."
+msgstr ""
+"Assistant de r.li interrompu. Le fichier de configuration n'a pas été créé."
#: ../gui/wxpython/rlisetup/wizard.py:429
msgid "Select maps and define name"
@@ -3752,17 +3931,21 @@
#: ../gui/wxpython/rlisetup/wizard.py:588
#, python-format
msgid "Vector %s was not found, please select another vector"
-msgstr "Le vecteur %s n'a pas été trouvé, merci de sélectionner un autre vecteur"
+msgstr ""
+"Le vecteur %s n'a pas été trouvé, merci de sélectionner un autre vecteur"
#: ../gui/wxpython/rlisetup/wizard.py:592
#, python-format
msgid "Vector %s has no areas, please select another vector"
-msgstr "L vecteur %s n'a pas de polygones, merci de sélectionner un autre vecteur"
+msgstr ""
+"L vecteur %s n'a pas de polygones, merci de sélectionner un autre vecteur"
#: ../gui/wxpython/rlisetup/wizard.py:597
#, python-format
msgid "Vector %s has no table connected, please select another vector"
-msgstr "Le vecteur %s n'a pas de table connectée, merci de sélectionner un autre vecteur"
+msgstr ""
+"Le vecteur %s n'a pas de table connectée, merci de sélectionner un autre "
+"vecteur"
#: ../gui/wxpython/rlisetup/wizard.py:639
msgid "Insert sampling frame parameter"
@@ -4156,18 +4339,27 @@
#: ../gui/wxpython/psmap/instructions.py:818
#: ../gui/wxpython/psmap/instructions.py:1700
#, python-format
-msgid "Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
-msgstr "Les caractères en position %s ne sont pas pris en charge par l'encodage ISO-8859-1 (Latin 1) requis pour le module ps.map."
+msgid ""
+"Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding "
+"which is required by module ps.map."
+msgstr ""
+"Les caractères en position %s ne sont pas pris en charge par l'encodage "
+"ISO-8859-1 (Latin 1) requis pour le module ps.map."
#: ../gui/wxpython/psmap/instructions.py:822
#: ../gui/wxpython/psmap/instructions.py:1704
-msgid "Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
-msgstr "Tous les caractères ne sont pas supportés par l'encodage ISO-8859-1 (Latin 1) requis pour le module ps.map."
+msgid ""
+"Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
+"required by module ps.map."
+msgstr ""
+"Tous les caractères ne sont pas supportés par l'encodage ISO-8859-1 (Latin "
+"1) requis pour le module ps.map."
#: ../gui/wxpython/psmap/instructions.py:938
#, python-format
msgid "Failed to read instruction %(inst)s: file %(file)s not found."
-msgstr "Ãchec à la lecture de l'instruction %(inst)s : fichier %(file)s non trouvé."
+msgstr ""
+"Ãchec à la lecture de l'instruction %(inst)s : fichier %(file)s non trouvé."
#: ../gui/wxpython/psmap/toolbars.py:65 ../gui/wxpython/menustrings.py:1972
msgid "Generate text file with mapping instructions"
@@ -4328,7 +4520,7 @@
"supérieure gauche du papier"
msgid "Font:"
msgstr "Police :"
@@ -4619,7 +4811,8 @@
#: ../gui/wxpython/psmap/dialogs.py:1676
msgid "Database connection is not defined in DB file."
-msgstr "La connexion à la base de données n'est pas définie dans le fichier DB."
+msgstr ""
+"La connexion à la base de données n'est pas définie dans le fichier DB."
#: ../gui/wxpython/psmap/dialogs.py:1677
msgid "Select layer:"
@@ -4701,7 +4894,8 @@
#: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
msgid "Type filename or click browse to choose file"
-msgstr "Taper un nom de fichier ou cliquer sur Parcourir pour choisir un fichier"
+msgstr ""
+"Taper un nom de fichier ou cliquer sur Parcourir pour choisir un fichier"
#: ../gui/wxpython/psmap/dialogs.py:1972 ../gui/wxpython/psmap/dialogs.py:2161
msgid "Choose a file"
@@ -4890,7 +5084,8 @@
#: ../gui/wxpython/psmap/dialogs.py:2729
msgid "Leave the edit field empty, to use default values."
-msgstr "Laisser vide le champ d'édition afin d'utiliser les valeurs par défaut."
+msgstr ""
+"Laisser vide le champ d'édition afin d'utiliser les valeurs par défaut."
#: ../gui/wxpython/psmap/dialogs.py:2751
msgid ""
@@ -5187,7 +5382,9 @@
#: ../gui/wxpython/psmap/frame.py:238
msgid "Program ps2pdf is not available. Please install it first to create PDF."
-msgstr "Le programme ps2pdf n'est pas disponible. Merci de l'installer pour permettre la création de fichiers PDF."
+msgstr ""
+"Le programme ps2pdf n'est pas disponible. Merci de l'installer pour "
+"permettre la création de fichiers PDF."
#: ../gui/wxpython/psmap/frame.py:282
msgid "Generating PDF..."
@@ -5222,7 +5419,8 @@
"\n"
" %s"
msgstr ""
-"Le programme ps2pdf n'est pas disponible. Merci de l'installer pour permettre la création de fichiers PDF.\n"
+"permettre la création de fichiers PDF.\n"
"\n"
" %s"
@@ -5240,7 +5438,8 @@
#: ../gui/wxpython/psmap/frame.py:356
msgid "Preview is not available probably due to missing Ghostscript."
-msgstr "L'aperçu n'est pas disponible, probablement parce qu'il manque Ghostscript."
+msgstr ""
+"L'aperçu n'est pas disponible, probablement parce qu'il manque Ghostscript."
#: ../gui/wxpython/psmap/frame.py:358
msgid "Please follow instructions on GRASS Trac Wiki."
@@ -5540,8 +5739,8 @@
msgstr "L'exécution a échoué :"
msgid "Details:"
msgstr "Détails :"
@@ -5565,7 +5764,8 @@
"impossible de lancer la commande :\n"
"%(cmd)s\n"
"\n"
-"Option <%(opt)s> : la lecture depuis l'entrée standard n'est pas prise en charge par wxGUI"
+"Option <%(opt)s> : la lecture depuis l'entrée standard n'est pas prise en "
+"charge par wxGUI"
#: ../gui/wxpython/core/gconsole.py:610
#, python-format
@@ -5578,8 +5778,11 @@
msgstr "%(min)d min %(sec)d sec"
#: ../gui/wxpython/core/gconsole.py:621
-msgid "Please note that the data are left in inconsistent state and may be corrupted"
-msgstr "Veuillez noter que les données sont laissées dans un état inconsitant et peuvent être corrompues"
+msgid ""
+"Please note that the data are left in inconsistent state and may be corrupted"
+msgstr ""
+"Veuillez noter que les données sont laissées dans un état inconsitant et "
+"peuvent être corrompues"
#: ../gui/wxpython/core/gconsole.py:623
msgid "Command aborted"
@@ -5602,7 +5805,8 @@
"\n"
"Number of skipped lines: %(line)d"
msgstr ""
-"Certaines lignes ont été sautées à la lecture des paramètres depuis le fichier <%(file)s>.\n"
+"Certaines lignes ont été sautées à la lecture des paramètres depuis le "
+"fichier <%(file)s>.\n"
"Voir la fenêtre 'Sortie de commande' pour des détails.\n"
"\n"
"Nombre de lignes sautées : %(line)d"
@@ -5627,21 +5831,22 @@
msgstr "Détails : %s\n"
#, python-format
msgstr "Type de couche '%s' non pris en charge"
msgstr "Essai de récupération depuis la région par défaut ..."
#, python-format
-msgstr "Erreur : impossible d'ouvrir '%(file)s'. Raison : %(ret)s. Sortie de wxGUI.\n"
+msgstr ""
+"Erreur : impossible d'ouvrir '%(file)s'. Raison : %(ret)s. Sortie de wxGUI.\n"
#, python-format
msgid ""
"\n"
@@ -5650,55 +5855,59 @@
"\n"
"ERREUR : Impossible de lire le fichier WIND : %s\n"
#, python-format
msgstr "Taille non valide %d,%d\n"
#, python-format
msgstr "Impossible de zoomer sur la carte raster : %s"
#, python-format
msgstr "Impossible de zoomer sur la carte vecteur <%s>."
#, python-format
msgstr "Impossible de zoomer sur la carte raster 3d <%s>."
-msgid "Unable to get current geographic extent. Force quiting wxGUI. Please manually run g.region to fix the problem."
-msgstr "Impossible d'obtenir lâextension géographique courante. Sortie forcée de wxGUI. Merci d'exécuter manuellement g.region pour résoudre ce problème."
+msgid ""
+"Unable to get current geographic extent. Force quiting wxGUI. Please "
+"manually run g.region to fix the problem."
+msgstr ""
+"Impossible d'obtenir lâextension géographique courante. Sortie forcée de "
+"wxGUI. Merci d'exécuter manuellement g.region pour résoudre ce problème."
#, python-format
msgstr "ERREUR : le rendu a échoué. Détails : %s"
#, python-format
msgstr "Impossible de générer l'aperçu de la carte <%s>."
#, python-format
msgstr "Impossible de générer l'aperçu de la superposition <%s>."
msgstr "Téléchargement des données ..."
#, fuzzy
msgstr "Générer (l'affichage)"
#, fuzzy
@@ -5763,7 +5972,9 @@
#: ../gui/wxpython/core/toolboxes.py:129
msgid "Unable to parse user toolboxes XML files. Default files will be loaded."
-msgstr "Impossible d'analyser le fichier XML des barres d'outils utilisateur. Chargement du fichier par défaut."
+msgstr ""
+"Impossible d'analyser le fichier XML des barres d'outils utilisateur. "
+"Chargement du fichier par défaut."
#: ../gui/wxpython/core/toolboxes.py:169
msgid "Unable to create toolboxes directory."
@@ -5778,7 +5989,9 @@
msgstr "Extensions"
#: ../gui/wxpython/core/toolboxes.py:536
-msgid "WARNING: Some addons failed when loading. Please consider to update your addons by running 'g.extension.all -f'.\n"
+msgid ""
+"WARNING: Some addons failed when loading. Please consider to update your "
+"addons by running 'g.extension.all -f'.\n"
msgstr ""
#: ../gui/wxpython/gmodeler/model.py:63
@@ -6155,7 +6368,8 @@
#: ../gui/wxpython/gmodeler/frame.py:256
msgid "Do you want to store current model settings to model file?"
-msgstr "Voulez-vous enregistrer les paramètres du modèle courants dans un fichier ?"
+msgstr ""
+"Voulez-vous enregistrer les paramètres du modèle courants dans un fichier ?"
#: ../gui/wxpython/gmodeler/frame.py:262
msgid "Quit Graphical Modeler"
@@ -6180,8 +6394,12 @@
msgstr "%d cartes supprimées du jeu de cartes courant"
#: ../gui/wxpython/gmodeler/frame.py:353 ../gui/wxpython/gmodeler/frame.py:479
-msgid "Current model is not empty. Do you want to store current settings to model file?"
-msgstr "Le modèle courant n'est pas vide. Voulez-vous enregistrer les paramètres courants dans un fichier ?"
+msgid ""
+"Current model is not empty. Do you want to store current settings to model "
+"file?"
+msgstr ""
+"Le modèle courant n'est pas vide. Voulez-vous enregistrer les paramètres "
+"courants dans un fichier ?"
#: ../gui/wxpython/gmodeler/frame.py:356 ../gui/wxpython/gmodeler/frame.py:482
msgid "Create new model?"
@@ -6204,7 +6422,8 @@
#: ../gui/wxpython/gmodeler/frame.py:419 ../gui/wxpython/gmodeler/frame.py:456
#, python-format
msgid "Model file <%s> already exists. Do you want to overwrite this file?"
-msgstr "Le fichier de modèle <%s> existe déjà . Voulez-vous écraser ce fichier ?"
+msgstr ""
+"Le fichier de modèle <%s> existe déjà . Voulez-vous écraser ce fichier ?"
#: ../gui/wxpython/gmodeler/frame.py:422 ../gui/wxpython/menustrings.py:1922
msgid "Save model"
@@ -6247,7 +6466,9 @@
#: ../gui/wxpython/mapdisp/frame.py:587 ../gui/wxpython/gcp/mapdisplay.py:383
#: ../gui/wxpython/mapswipe/frame.py:524
msgid "Choose a file name to save the image (no need to add extension)"
-msgstr "Choisissez un nom de fichier pour enregistrer l'image (extension non nécessaire)"
+msgstr ""
+"Choisissez un nom de fichier pour enregistrer l'image (extension non "
+"nécessaire)"
#: ../gui/wxpython/gmodeler/frame.py:605 ../gui/wxpython/gmodeler/frame.py:612
#, python-format
@@ -6420,8 +6641,12 @@
msgstr "Enegistrer le fichier"
#: ../gui/wxpython/gmodeler/frame.py:1797
-msgid "Python script is locally modificated. Refresh will discard all changes. Do you really want to continue?"
-msgstr "Le script Python a été modifié manuellement. La mise à jour écrasera toutes les modifications. Voulez-vous vraiment continuer ?"
+msgid ""
+"Python script is locally modificated. Refresh will discard all changes. Do "
+"you really want to continue?"
+msgstr ""
+"Le script Python a été modifié manuellement. La mise à jour écrasera toutes "
+"les modifications. Voulez-vous vraiment continuer ?"
#: ../gui/wxpython/gmodeler/frame.py:1800
msgid "Update"
@@ -6551,8 +6776,12 @@
msgstr "Importation et maillage de points ASCII x,y,z"
#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1015
-msgid "Creates a raster map from an assemblage of many coordinates using univariate statistics."
-msgstr "Créer une carte raster à partir de l'assemblage d'un lot de coordonnées en utilisant des statistiques univariées."
+msgid ""
+"Creates a raster map from an assemblage of many coordinates using univariate "
+"statistics."
+msgstr ""
+"Créer une carte raster à partir de l'assemblage d'un lot de coordonnées en "
+"utilisant des statistiques univariées."
#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1016
msgid "ASCII grid import"
@@ -6584,7 +6813,8 @@
#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1023
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
-msgstr "Importer un fichier carte GRIDATB.FOR (TOPMODEL) vers une carte raster GRASS."
+msgstr ""
+"Importer un fichier carte GRIDATB.FOR (TOPMODEL) vers une carte raster GRASS."
#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1024
msgid "Matlab 2D array import"
@@ -6623,8 +6853,12 @@
msgstr "Importer un Terra ASTER HDF"
#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1033
-msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
-msgstr "Géoréférencer, rectifier et importer une image Terra-ASTER et ses MNT associés avec gdalwarp."
+msgid ""
+"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
+"using gdalwarp."
+msgstr ""
+"Géoréférencer, rectifier et importer une image Terra-ASTER et ses MNT "
+"associés avec gdalwarp."
#: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:77
#: ../gui/wxpython/menustrings.py:1034 ../gui/wxpython/menustrings.py:1056
@@ -6648,7 +6882,8 @@
#: ../gui/wxpython/menustrings.py:59 ../gui/wxpython/menustrings.py:277
#: ../gui/wxpython/menustrings.py:1038 ../gui/wxpython/menustrings.py:1178
msgid "Re-projects a raster map from given location to the current location."
-msgstr "Reprojeter une carte raster depuis un secteur donné vers le secteur courant."
+msgstr ""
+"Reprojeter une carte raster depuis un secteur donné vers le secteur courant."
#: ../gui/wxpython/menustrings.py:61 ../gui/wxpython/menustrings.py:1040
msgid "Common import formats"
@@ -6664,7 +6899,9 @@
#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:1043
msgid "Creates a vector map from an ASCII points file or ASCII vector file."
-msgstr "Créer une carte vecteur depuis un fichier de points ASCII ou un fichier vecteur ASCII."
+msgstr ""
+"Créer une carte vecteur depuis un fichier de points ASCII ou un fichier "
+"vecteur ASCII."
#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:1044
msgid "ASCII points as a vector lines"
@@ -6731,7 +6968,8 @@
#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:557
#: ../gui/wxpython/menustrings.py:1060 ../gui/wxpython/menustrings.py:1458
msgid "Re-projects a vector map from one location to the current location."
-msgstr "Re-projette une carte vecteur depuis un secteur dans le secteur courant."
+msgstr ""
+"Re-projette une carte vecteur depuis un secteur dans le secteur courant."
#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1061
msgid "Import 3D raster data"
@@ -6799,8 +7037,11 @@
msgstr "Export en points ASCII x,y,z"
#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1077
-msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
-msgstr "Exporter une carte raster vers un fichier texte de valeurs x,y,z basées sur le centre des cellules."
+msgid ""
+"Exports a raster map to a text file as x,y,z values based on cell centers."
+msgstr ""
+"Exporter une carte raster vers un fichier texte de valeurs x,y,z basées sur "
+"le centre des cellules."
#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1078
msgid "GRIDATB.FOR export"
@@ -6873,7 +7114,9 @@
#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1095
msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
-msgstr "Exporter une carte raster vers le Langage de Modélisaiton de Réalité Virtuelle (VRML)."
+msgstr ""
+"Exporter une carte raster vers le Langage de Modélisaiton de Réalité "
+"Virtuelle (VRML)."
#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:136
#: ../gui/wxpython/menustrings.py:147 ../gui/wxpython/menustrings.py:1096
@@ -6898,16 +7141,26 @@
msgstr "Exporter une carte vecteur"
#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1102
-msgid "Exports a vector map layer to any of the supported OGR vector formats. By default a vector map layer is exported to Esri Shapefile format."
-msgstr "Exporter une couche vecteur vers n'importe lequel des formats vecteurs supportés par OGR. Par défaut une couche vecteur est exportée vers le format ESRI Shape."
+msgid ""
+"Exports a vector map layer to any of the supported OGR vector formats. By "
+"default a vector map layer is exported to Esri Shapefile format."
+msgstr ""
+"Exporter une couche vecteur vers n'importe lequel des formats vecteurs "
+"supportés par OGR. Par défaut une couche vecteur est exportée vers le format "
+"ESRI Shape."
#: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:1103
msgid "ASCII points or GRASS ASCII vector export"
msgstr "Exporter des points ASCII ou vecteurs ASCII GRASS"
#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1104
-msgid "Exports a vector map to a GRASS ASCII vector representation. By default only features with category are exported. To export all features use 'layer=-1'."
-msgstr "Exporter une carte vecteur vers un vecteur ASCII GRASS. Par défaut seules les entités avec une catégorie sont exportés. Utiliser 'layer=-1' pour exporter toutes les entités."
+msgid ""
+"Exports a vector map to a GRASS ASCII vector representation. By default only "
+"features with category are exported. To export all features use 'layer=-1'."
+msgstr ""
+"Exporter une carte vecteur vers un vecteur ASCII GRASS. Par défaut seules "
+"les entités avec une catégorie sont exportés. Utiliser 'layer=-1' pour "
+"exporter toutes les entités."
#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1105
msgid "DXF export"
@@ -6922,8 +7175,11 @@
msgstr "Exporter vers des formats GPS avec GPSBABEL"
#: ../gui/wxpython/menustrings.py:129 ../gui/wxpython/menustrings.py:1108
-msgid "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
-msgstr "Exporter une carte vecteur vers un récepteur GPS ou un fichier pris en charge par GPSBabel."
+msgid ""
+"Exports a vector map to a GPS receiver or file format supported by GPSBabel."
+msgstr ""
+"Exporter une carte vecteur vers un récepteur GPS ou un fichier pris en "
+"charge par GPSBabel."
#: ../gui/wxpython/menustrings.py:130 ../gui/wxpython/menustrings.py:1109
msgid "PostGIS export"
@@ -7007,11 +7263,14 @@
#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1133
msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
-msgstr "Lier des données prises en charge par GDAL en tant que pseudocarte raster."
+msgstr ""
+"Lier des données prises en charge par GDAL en tant que pseudocarte raster."
#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1135
msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
-msgstr "Crée une nouvelle pseudo carte vecteur comme lien vers une couche prise en charge par OGR."
+msgstr ""
+"Crée une nouvelle pseudo carte vecteur comme lien vers une couche prise en "
+"charge par OGR."
#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1136
msgid "Output format for raster data"
@@ -7038,8 +7297,12 @@
msgstr "Copier"
#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1142
-msgid "Copies available data files in the current mapset search path to the user's current mapset."
-msgstr "Copier les fichiers de données disponibles dans le chemin de recherche du jeu de cartes courant vers le jeu de cartes de l'utilisateur courant."
+msgid ""
+"Copies available data files in the current mapset search path to the user's "
+"current mapset."
+msgstr ""
+"Copier les fichiers de données disponibles dans le chemin de recherche du "
+"jeu de cartes courant vers le jeu de cartes de l'utilisateur courant."
#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:923
#: ../gui/wxpython/menustrings.py:1143 ../gui/wxpython/menustrings.py:1824
@@ -7047,17 +7310,27 @@
msgstr "Liste"
#: ../gui/wxpython/menustrings.py:165 ../gui/wxpython/menustrings.py:1144
-msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
-msgstr "Lister les fichiers de base de données GRASS disponibles du type spécifié par l'utilisateur en utilisant un modèle de recherche."
+msgid ""
+"Lists available GRASS data base files of the user-specified data type "
+"optionally using the search pattern."
+msgstr ""
+"Lister les fichiers de base de données GRASS disponibles du type spécifié "
+"par l'utilisateur en utilisant un modèle de recherche."
#: ../gui/wxpython/menustrings.py:167 ../gui/wxpython/menustrings.py:1146
msgid "Renames data base element files in the user's current mapset."
-msgstr "Renommer les fichiers éléments de la base de données dans le jeu de données courant de l'utilisateur"
+msgstr ""
+"Renommer les fichiers éléments de la base de données dans le jeu de données "
+"courant de l'utilisateur"
#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:1148
#, fuzzy
-msgid "Removes data base element files from the user's current mapset using the search pattern."
-msgstr "Supprimer les fichiers éléments de base de données du jeu de données courant de l'utilisateur"
+msgid ""
+"Removes data base element files from the user's current mapset using the "
+"search pattern."
+msgstr ""
+"Supprimer les fichiers éléments de base de données du jeu de données courant "
+"de l'utilisateur"
#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:300
#: ../gui/wxpython/menustrings.py:594 ../gui/wxpython/menustrings.py:826
@@ -7084,7 +7357,8 @@
#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:304
#: ../gui/wxpython/menustrings.py:1205
msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr "Convertir des tranches de cartes raster 2D en une carte volumique raster 3D. "
+msgstr ""
+"Convertir des tranches de cartes raster 2D en une carte volumique raster 3D. "
#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:305
#: ../gui/wxpython/menustrings.py:1206
@@ -7094,7 +7368,8 @@
#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:306
#: ../gui/wxpython/menustrings.py:1207
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr "Crée un volume 3D à partir de cartes raster 2D d'altitude et de valeurs."
+msgstr ""
+"Crée un volume 3D à partir de cartes raster 2D d'altitude et de valeurs."
#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:595
#: ../gui/wxpython/menustrings.py:1496
@@ -7164,8 +7439,12 @@
msgstr "Rendu d'image 3D"
#: ../gui/wxpython/menustrings.py:192
-msgid "Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
-msgstr "Créer un rendu 3D. Rendu des surfaces (raster), des vecteurs 2D/3D, et des volumes (raster 3D) en 3D."
+msgid ""
+"Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D "
+"vector data, and volumes (3D raster data) in 3D."
+msgstr ""
+"Créer un rendu 3D. Rendu des surfaces (raster), des vecteurs 2D/3D, et des "
+"volumes (raster 3D) en 3D."
#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:995
#: ../gui/wxpython/menustrings.py:1896 ../gui/wxpython/menustrings.py:1901
@@ -7182,8 +7461,13 @@
msgstr "Gisement/distance vers coordonnées"
#: ../gui/wxpython/menustrings.py:196
-msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa. It assumes a cartesian coordinate system"
-msgstr "Un utilitaire simple pour convertir des mesures de gisements et distances vers des coordonnées et vice-versa. Présume un système de coordonnées cartésien"
+msgid ""
+"A simple utility for converting bearing and distance measurements to "
+"coordinates and vice versa. It assumes a cartesian coordinate system"
+msgstr ""
+"Un utilitaire simple pour convertir des mesures de gisements et distances "
+"vers des coordonnées et vice-versa. Présume un système de coordonnées "
+"cartésien"
#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:1912
#: ../gui/wxpython/lmgr/toolbars.py:144
@@ -7250,23 +7534,32 @@
#: ../gui/wxpython/menustrings.py:213
msgid "Set/unset access to other mapsets in current location"
-msgstr "Active/désactive l'accès aux autres jeux de données dans le secteur courant"
+msgstr ""
+"Active/désactive l'accès aux autres jeux de données dans le secteur courant"
#: ../gui/wxpython/menustrings.py:214
msgid "User access"
msgstr "Permissions utilisateur"
#: ../gui/wxpython/menustrings.py:215
-msgid "Controls access to the current mapset for other users on the system. If no option given, prints current status."
-msgstr "Contrôle l'accès au jeu de cartes courant pour les autres utilisateurs du système. Si aucune option n'ets données, affiche l'état actuel."
+msgid ""
+"Controls access to the current mapset for other users on the system. If no "
+"option given, prints current status."
+msgstr ""
+"Contrôle l'accès au jeu de cartes courant pour les autres utilisateurs du "
+"système. Si aucune option n'ets données, affiche l'état actuel."
#: ../gui/wxpython/menustrings.py:216
msgid "Change working environment"
msgstr "Modifier l'environnement de travail"
#: ../gui/wxpython/menustrings.py:217
-msgid "Changes/reports current mapset. Optionally create new mapset or list available mapsets in given location."
-msgstr "Modifie/affiche le jeu de cartes courant. En option, créé un nouveau jeu de cartes ou list les jeux de cartes disponibles dans le secteur choisi."
+msgid ""
+"Changes/reports current mapset. Optionally create new mapset or list "
+"available mapsets in given location."
+msgstr ""
+"Modifie/affiche le jeu de cartes courant. En option, créé un nouveau jeu de "
+"cartes ou list les jeux de cartes disponibles dans le secteur choisi."
#: ../gui/wxpython/menustrings.py:218
msgid "Change location and mapset"
@@ -7294,15 +7587,22 @@
#: ../gui/wxpython/menustrings.py:225
msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr "Affiche et modifie les paramètres de variables GRASS de l'utilisateur courant."
+msgstr ""
+"Affiche et modifie les paramètres de variables GRASS de l'utilisateur "
+"courant."
#: ../gui/wxpython/menustrings.py:226
msgid "Change settings"
msgstr "Modifier les paramètres"
#: ../gui/wxpython/menustrings.py:227
-msgid "Outputs and modifies the user's current GRASS variable settings. Prints all defined GRASS variables if no option is given."
-msgstr "Affiche et modifie les paramètres des variables GRASS de l'utilisateur courant. Affiche toutes les variables GRASS définies si aucune option n'est définie."
+msgid ""
+"Outputs and modifies the user's current GRASS variable settings. Prints all "
+"defined GRASS variables if no option is given."
+msgstr ""
+"Affiche et modifie les paramètres des variables GRASS de l'utilisateur "
+"courant. Affiche toutes les variables GRASS définies si aucune option n'est "
+"définie."
#: ../gui/wxpython/menustrings.py:228
msgid "Create new location"
@@ -7319,7 +7619,9 @@
#: ../gui/wxpython/menustrings.py:231
msgid "Creates new mapset in the current location, changes current mapset."
-msgstr "Crée un nouveau jeux de cartes dans le secteur de travail courant, et change le jeux de cartes courant."
+msgstr ""
+"Crée un nouveau jeux de cartes dans le secteur de travail courant, et change "
+"le jeux de cartes courant."
#: ../gui/wxpython/menustrings.py:232
msgid "Version and copyright"
@@ -7338,16 +7640,26 @@
msgstr "Affiche la projection de la carte"
#: ../gui/wxpython/menustrings.py:236
-msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
-msgstr "Convertit les descriptions de systèmes de coordonnées (c.-à -d. les informations de projection) entre divers formats (dont le format GRASS)."
+msgid ""
+"Converts co-ordinate system descriptions (i.e. projection information) "
+"between various formats (including GRASS format)."
+msgstr ""
+"Convertit les descriptions de systèmes de coordonnées (c.-à -d. les "
+"informations de projection) entre divers formats (dont le format GRASS)."
#: ../gui/wxpython/menustrings.py:237
msgid "Manage projections"
msgstr "Gérer les projections"
#: ../gui/wxpython/menustrings.py:238
-msgid "Prints or modifies GRASS projection information files (in various co-ordinate system descriptions). Can also be used to create new GRASS locations."
-msgstr "Affiche ou modifie les fichiers de projection de GRASS (dans divers systèmes de coordonnées). Peut aussi être utilisé pour créer de nouveaux secteurs GRASS."
+msgid ""
+"Prints or modifies GRASS projection information files (in various co-"
+"ordinate system descriptions). Can also be used to create new GRASS "
+"locations."
+msgstr ""
+"Affiche ou modifie les fichiers de projection de GRASS (dans divers systèmes "
+"de coordonnées). Peut aussi être utilisé pour créer de nouveaux secteurs "
+"GRASS."
#: ../gui/wxpython/menustrings.py:239
msgid "Convert coordinates"
@@ -7356,7 +7668,8 @@
# L'usage en traduction française semble être de conserver les anglicismes frontend et backend
#: ../gui/wxpython/menustrings.py:240
msgid "Converts coordinates from one projection to another (cs2cs frontend)."
-msgstr "Convertir les coordonnées d'une projection à une autre (frontend cs2cs)."
+msgstr ""
+"Convertir les coordonnées d'une projection à une autre (frontend cs2cs)."
#: ../gui/wxpython/menustrings.py:241
msgid "Addons extensions"
@@ -7384,7 +7697,8 @@
#: ../gui/wxpython/menustrings.py:247
msgid "User GUI preferences (display font, commands, digitizer, etc.)"
-msgstr "Préférences utilisateur GUI (police d'affichage, commandes, numériseur, etc.)"
+msgstr ""
+"Préférences utilisateur GUI (police d'affichage, commandes, numériseur, etc.)"
#: ../gui/wxpython/menustrings.py:248 ../gui/wxpython/menustrings.py:1149
msgid "&Raster"
@@ -7424,7 +7738,8 @@
#: ../gui/wxpython/menustrings.py:257 ../gui/wxpython/menustrings.py:1158
msgid "Produces the quantization file for a floating-point map."
-msgstr "Produit le fichier de quantification pour une carte en virgule flottante."
+msgstr ""
+"Produit le fichier de quantification pour une carte en virgule flottante."
#: ../gui/wxpython/menustrings.py:258 ../gui/wxpython/menustrings.py:1159
msgid "Timestamp"
@@ -7432,7 +7747,9 @@
#: ../gui/wxpython/menustrings.py:259 ../gui/wxpython/menustrings.py:1160
#, fuzzy
-msgid "Modifies a timestamp for a raster map. Print/add/remove a timestamp for a raster map."
+msgid ""
+"Modifies a timestamp for a raster map. Print/add/remove a timestamp for a "
+"raster map."
msgstr "Afficher/ajouter/supprimer une date/heure d'une carte raster 3D"
#: ../gui/wxpython/menustrings.py:260 ../gui/wxpython/menustrings.py:1161
@@ -7441,7 +7758,9 @@
#: ../gui/wxpython/menustrings.py:261 ../gui/wxpython/menustrings.py:1162
msgid "Resamples raster map layers to a coarser grid using aggregation."
-msgstr "Ré-échantillonner une carte raster avec un maillage plus grossier en procédant par agrégation."
+msgstr ""
+"Ré-échantillonner une carte raster avec un maillage plus grossier en "
+"procédant par agrégation."
#: ../gui/wxpython/menustrings.py:262 ../gui/wxpython/menustrings.py:1163
msgid "Resample using multiple methods"
@@ -7449,7 +7768,9 @@
#: ../gui/wxpython/menustrings.py:263 ../gui/wxpython/menustrings.py:1164
msgid "Resamples raster map to a finer grid using interpolation."
-msgstr "Ré-échantillonner une carte raster vers un maillage plus fin par interpolation."
+msgstr ""
+"Ré-échantillonner une carte raster vers un maillage plus fin par "
+"interpolation."
#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:1165
msgid "Resample using nearest neighbor"
@@ -7464,16 +7785,25 @@
msgstr "Ré-échantillonner par les splines avec tension"
#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1168
-msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
-msgstr "Ré-interpole et en option calcule une analyse topographique d'une carte raster (éventuellement à une résolution différente) en utilisant les splines régulées avec tension et lissage."
+msgid ""
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
+"Ré-interpole et en option calcule une analyse topographique d'une carte "
+"raster (éventuellement à une résolution différente) en utilisant les splines "
+"régulées avec tension et lissage."
#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1169
msgid "Resample using bspline"
msgstr "Rééchantillonner par les bsplines"
#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1170
-msgid "Performs bilinear or bicubic spline interpolation with Tykhonov regularization."
-msgstr "Interpolation spline bilinéaire ou bicubique avec régularisation de Tykhonov."
+msgid ""
+"Performs bilinear or bicubic spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+"Interpolation spline bilinéaire ou bicubique avec régularisation de Tykhonov."
#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:1171
#, fuzzy
@@ -7494,7 +7824,9 @@
# Pour désigner les support files, je propose la traduction fichiers de maintenance. Guère d'autre idée pour englober à la fois la dimension historique du fichier, méta-infos, lien vers un éventuel autre raster...
#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1174
msgid "Allows creation and/or modification of raster map layer support files."
-msgstr "Permet la création et/ou la modification de fichiers de maintenance de cartes raster."
+msgstr ""
+"Permet la création et/ou la modification de fichiers de maintenance de "
+"cartes raster."
#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:1175
msgid "Update map statistics"
@@ -7509,8 +7841,12 @@
msgstr "Mosaïquer"
#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:1180
-msgid "Produces tilings of the source projection for use in the destination region and projection."
-msgstr "Produit une mosaïque de la projection source pour utilisation dans la région et projection de destination."
+msgid ""
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
+msgstr ""
+"Produit une mosaïque de la projection source pour utilisation dans la région "
+"et projection de destination."
#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:577
#: ../gui/wxpython/menustrings.py:1181 ../gui/wxpython/menustrings.py:1478
@@ -7532,7 +7868,9 @@
#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1185
msgid "Sets color rules based on stddev from a raster map's mean value."
-msgstr "Définir les règles de couleurs basées sur l'écart-type depuis la moyenne des valeurs d'une carte raster."
+msgstr ""
+"Définir les règles de couleurs basées sur l'écart-type depuis la moyenne des "
+"valeurs d'une carte raster."
#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:580
#: ../gui/wxpython/menustrings.py:1186 ../gui/wxpython/menustrings.py:1481
@@ -7558,15 +7896,19 @@
#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:1191
msgid "Blends color components of two raster maps by a given ratio."
-msgstr "Mélange les composantes de couleur de deux cartes raster d'un ratio donné."
+msgstr ""
+"Mélange les composantes de couleur de deux cartes raster d'un ratio donné."
#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:1192
msgid "Create RGB"
msgstr "Créer RVB"
#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:1193
-msgid "Combines red, green and blue raster maps into a single composite raster map."
-msgstr "Combine des cartes raster rouge, vert et bleu en une unique carte raster composite."
+msgid ""
+"Combines red, green and blue raster maps into a single composite raster map."
+msgstr ""
+"Combine des cartes raster rouge, vert et bleu en une unique carte raster "
+"composite."
#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:733
#: ../gui/wxpython/menustrings.py:1194 ../gui/wxpython/menustrings.py:1634
@@ -7574,8 +7916,14 @@
msgstr "RVB vers TSV"
#: ../gui/wxpython/menustrings.py:294 ../gui/wxpython/menustrings.py:1195
-msgid "Generates red, green and blue (RGB) raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
-msgstr "Génère des couches raster rouge, vert et bleu (RVB) en combinant des valeurs de teinte, saturation, valeur (TSV) depuis des cartes raster indiquées par l'utilisateur."
+msgid ""
+"Generates red, green and blue (RGB) raster map layers combining hue, "
+"intensity and saturation (HIS) values from user-specified input raster map "
+"layers."
+msgstr ""
+"Génère des couches raster rouge, vert et bleu (RVB) en combinant des valeurs "
+"de teinte, saturation, valeur (TSV) depuis des cartes raster indiquées par "
+"l'utilisateur."
#: ../gui/wxpython/menustrings.py:295 ../gui/wxpython/menustrings.py:1196
msgid "Query raster maps"
@@ -7587,7 +7935,8 @@
#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:1198
msgid "Queries raster maps on their category values and category labels."
-msgstr "Interroger des cartes raster sur les valeurs et étiquettes de catégories."
+msgstr ""
+"Interroger des cartes raster sur les valeurs et étiquettes de catégories."
#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:1199
msgid "Query colors by value"
@@ -7606,8 +7955,12 @@
msgstr "Zone tampon raster"
#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:1210
-msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
-msgstr "Créer une carte raster qui affiche des zones tampon autour des cellules qui contiennent des valeurs de catégorie non-NULL."
+msgid ""
+"Creates a raster map showing buffer zones surrounding cells that contain non-"
+"NULL category values."
+msgstr ""
+"Créer une carte raster qui affiche des zones tampon autour des cellules qui "
+"contiennent des valeurs de catégorie non-NULL."
#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:1211
msgid "Concentric circles"
@@ -7615,7 +7968,9 @@
#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:1212
msgid "Creates a raster map containing concentric rings around a given point."
-msgstr "Crée une carte raster contenant des cercles concentriques autour d'un point donné."
+msgstr ""
+"Crée une carte raster contenant des cercles concentriques autour d'un point "
+"donné."
#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1213
msgid "Closest points"
@@ -7623,7 +7978,9 @@
#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:1214
msgid "Locates the closest points between objects in two raster maps."
-msgstr "Localise les points de plus grande proximité entre objets de deux cartes raster."
+msgstr ""
+"Localise les points de plus grande proximité entre objets de deux cartes "
+"raster."
#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:1215
msgid "Grow by one cell"
@@ -7632,7 +7989,9 @@
#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:378
#: ../gui/wxpython/menustrings.py:1216 ../gui/wxpython/menustrings.py:1279
msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr "Produit une couche raster où les surfaces contiguës ont été agrandies d'une cellule."
+msgstr ""
+"Produit une couche raster où les surfaces contiguës ont été agrandies d'une "
+"cellule."
#: ../gui/wxpython/menustrings.py:316 ../gui/wxpython/menustrings.py:370
#: ../gui/wxpython/menustrings.py:1217 ../gui/wxpython/menustrings.py:1271
@@ -7642,7 +8001,9 @@
#: ../gui/wxpython/menustrings.py:317 ../gui/wxpython/menustrings.py:371
#: ../gui/wxpython/menustrings.py:1218 ../gui/wxpython/menustrings.py:1272
msgid "Generates a raster map containing distances to nearest raster features."
-msgstr "Générer une carte raster contenant les distances vers les entités raster les plus proches."
+msgstr ""
+"Générer une carte raster contenant les distances vers les entités raster les "
+"plus proches."
#: ../gui/wxpython/menustrings.py:319 ../gui/wxpython/menustrings.py:1220
msgid "Creates a MASK for limiting raster operation."
@@ -7658,16 +8019,29 @@
msgstr "Analyse de voisinage"
#: ../gui/wxpython/menustrings.py:324 ../gui/wxpython/menustrings.py:1225
-msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
-msgstr "Rend la catégorie de chaque cellule une fontion des valeurs de catégorie des cellules voisines, et enregistre la nouvelle valeur dans une carte raster de sortie."
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
+msgstr ""
+"Rend la catégorie de chaque cellule une fontion des valeurs de catégorie des "
+"cellules voisines, et enregistre la nouvelle valeur dans une carte raster de "
+"sortie."
#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:1226
msgid "Neighborhood points"
msgstr "Points voisins"
#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:1227
-msgid "Neighborhood analysis tool for vector point maps. Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
-msgstr "OUtil d'analyse de voisinnage pour des cartes vecteurs de points. Défini la valeur de chaque cellule en fonction des valeurs d'attributs des points ou centroids voisins, et enregistre les nouvelles valeurs de cellule dans une carte raster."
+msgid ""
+"Neighborhood analysis tool for vector point maps. Makes each cell value a "
+"function of the attribute values assigned to the vector points or centroids "
+"around it, and stores new cell values in an output raster map."
+msgstr ""
+"OUtil d'analyse de voisinnage pour des cartes vecteurs de points. Défini la "
+"valeur de chaque cellule en fonction des valeurs d'attributs des points ou "
+"centroids voisins, et enregistre les nouvelles valeurs de cellule dans une "
+"carte raster."
#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1228
msgid "Overlay rasters"
@@ -7678,40 +8052,59 @@
msgstr "Produit en croix"
#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1230
-msgid "Creates a cross product of the category values from multiple raster map layers."
-msgstr "Crée un produit croisé des valeurs de catégories de multiples cartes raster."
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
+msgstr ""
+"Crée un produit croisé des valeurs de catégories de multiples cartes raster."
#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1231
msgid "Patch raster maps"
msgstr "Combiner des cartes raster"
#: ../gui/wxpython/menustrings.py:331 ../gui/wxpython/menustrings.py:1232
-msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr "Crée une carte raster composite en utilisant les valeurs connues d'une (ou plusieurs) carte pour remplir les zones de \"no data\" d'une autre carte."
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+"Crée une carte raster composite en utilisant les valeurs connues d'une (ou "
+"plusieurs) carte pour remplir les zones de \"no data\" d'une autre carte."
#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:1233
msgid "Raster series aggregation"
msgstr "Aggrégation de séries raster"
#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:1234
-msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
-msgstr "Rend la valeur de sortie des cellules une foncton des valeurs des cellules correspondantes dans les cartes raster d'entrée."
+msgid ""
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
+msgstr ""
+"Rend la valeur de sortie des cellules une foncton des valeurs des cellules "
+"correspondantes dans les cartes raster d'entrée."
#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:1235
msgid "Raster series accumulation"
msgstr "Accumulation de séries raster"
#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1236
-msgid "Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers."
-msgstr "Définie la valeur de sortie des cellules comme une foncton d'accumulation des valeurs des cellules correspondantes dans les cartes raster d'entrée."
+msgid ""
+"Makes each output cell value a accumulationfunction of the values assigned "
+"to the corresponding cells in the input raster map layers."
+msgstr ""
+"Définie la valeur de sortie des cellules comme une foncton d'accumulation "
+"des valeurs des cellules correspondantes dans les cartes raster d'entrée."
#: ../gui/wxpython/menustrings.py:336 ../gui/wxpython/menustrings.py:1237
msgid "Statistical overlay"
msgstr "Recouvrement statistique"
#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1238
-msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
-msgstr "Calculer des statistiques par catégories ou orientées objets (statistiques d'accumulation)."
+msgid ""
+"Calculates category or object oriented statistics (accumulator-based "
+"statistics)."
+msgstr ""
+"Calculer des statistiques par catégories ou orientées objets (statistiques "
+"d'accumulation)."
#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1239
#, fuzzy
@@ -7739,24 +8132,53 @@
msgstr "Rayonnement solaire et irradiation"
#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1245
-msgid "Solar irradiance and irradiation model. Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-msgstr "Irradiance solaire et modèle d'irradiation. Calcule las cartes d'irradiation solaire directe (beam), diffuse et réfléchie pour un jour, latitude, conditions de surface et atmosphérique donnés. Les paramètres olaire (ex: heures de lever et de coucher, déclinaison, irradiance extra-terrestre, durée du jour) sont enregistrés dans l'historique du fichier. Alternativement, un fichier local peut être spécifié pour calculer les cartes raster d'angle d'incidence et/ou d'irradiance solaire. La prise en compte de l'effet d'ombrage de la topographie est optionnelle."
+msgid ""
+"Solar irradiance and irradiation model. Computes direct (beam), diffuse and "
+"reflected solar irradiation raster maps for given day, latitude, surface and "
+"atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, "
+"declination, extraterrestrial irradiance, daylight length) are saved in the "
+"map history file. Alternatively, a local time can be specified to compute "
+"solar incidence angle and/or irradiance raster maps. The shadowing effect of "
+"the topography is optionally incorporated."
+msgstr ""
+"Irradiance solaire et modèle d'irradiation. Calcule las cartes d'irradiation "
+"solaire directe (beam), diffuse et réfléchie pour un jour, latitude, "
+"conditions de surface et atmosphérique donnés. Les paramètres olaire (ex: "
+"heures de lever et de coucher, déclinaison, irradiance extra-terrestre, "
+"durée du jour) sont enregistrés dans l'historique du fichier. "
+"Alternativement, un fichier local peut être spécifié pour calculer les "
+"cartes raster d'angle d'incidence et/ou d'irradiance solaire. La prise en "
+"compte de l'effet d'ombrage de la topographie est optionnelle."
#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1246
msgid "Shadows map"
msgstr "Carte des ombres"
#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1247
-msgid "Calculates cast shadow areas from sun position and elevation raster map. Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
-msgstr "Calcule les zones d'ombre depuis la position du soleil et une carte raster d'altitudes. Soit la position exacte du soleil (A) est spécifiée, soit la date/heure (B) pour que r.sunmask calcule tout seul la position du soleil."
+msgid ""
+"Calculates cast shadow areas from sun position and elevation raster map. "
+"Either exact sun position (A) is specified, or date/time to calculate the "
+"sun position (B) by r.sunmask itself."
+msgstr ""
+"Calcule les zones d'ombre depuis la position du soleil et une carte raster "
+"d'altitudes. Soit la position exacte du soleil (A) est spécifiée, soit la "
+"date/heure (B) pour que r.sunmask calcule tout seul la position du soleil."
#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1248
msgid "Sunshine hours and solar angles"
msgstr "Heure et angle solaire"
#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1249
-msgid "Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction."
-msgstr "Calcules l'élévation du soleil, son azimuth, et l'heure solaire. Ãlévation du soleil : l'angle entre la direction du centre géométrique du disque solaire apparent et l'horizon (idéal). Azimuth solaire : l'angle dans le sens horaire à partir du nord."
+msgid ""
+"Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: "
+"the angle between the direction of the geometric center of the sun's "
+"apparent disk and the (idealized) horizon. Solar azimuth: the angle from due "
+"north in clockwise direction."
+msgstr ""
+"Calcules l'élévation du soleil, son azimuth, et l'heure solaire. Ãlévation "
+"du soleil : l'angle entre la direction du centre géométrique du disque "
+"solaire apparent et l'horizon (idéal). Azimuth solaire : l'angle dans le "
+"sens horaire à partir du nord."
#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1250
msgid "Terrain analysis"
@@ -7768,15 +8190,22 @@
#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1252
msgid "Produces a vector map of specified contours from a raster map."
-msgstr "Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
+msgstr ""
+"Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1253
msgid "Cost surface"
msgstr "Surface de coût"
#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1254
-msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
-msgstr "Crée une carte raster montrant le coût cumulé d'un déplacement entre différents points sur une carte raster d'altitude dont les valeurs de catégories représentent un coût."
+msgid ""
+"Creates a raster map showing the cumulative cost of moving between different "
+"geographic locations on an input raster map whose cell category values "
+"represent cost."
+msgstr ""
+"Crée une carte raster montrant le coût cumulé d'un déplacement entre "
+"différents points sur une carte raster d'altitude dont les valeurs de "
+"catégories représentent un coût."
#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1255
msgid "Cumulative movement costs"
@@ -7784,16 +8213,25 @@
#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1256
#, fuzzy
-msgid "Creates a raster map showing the anisotropic cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgid ""
+"Creates a raster map showing the anisotropic cumulative cost of moving "
+"between different geographic locations on an input raster map whose cell "
+"category values represent cost."
+msgstr ""
#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1257
msgid "Least cost route or flow"
msgstr "Plus court chemin ou flux"
#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1258
-msgid "Traces a flow through an elevation model or cost surface on a raster map."
-msgstr "Trace un écoulement à travers un modèle d'altitude ou une surface de coûts sur une carte raster."
+msgid ""
+"Traces a flow through an elevation model or cost surface on a raster map."
+msgstr ""
+"Trace un écoulement à travers un modèle d'altitude ou une surface de coûts "
+"sur une carte raster."
#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1259
msgid "Compute shaded relief"
@@ -7809,23 +8247,35 @@
#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1262
msgid "Drapes a color raster over an shaded relief or aspect map."
-msgstr "Drape un raster de couleur sur le relief ombré ou une carte d'exposition."
+msgstr ""
+"Drape un raster de couleur sur le relief ombré ou une carte d'exposition."
#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1263
msgid "Slope and aspect"
msgstr "Pente et exposition"
#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1264
-msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map. Aspect is calculated counterclockwise from east."
-msgstr "Générer des cartes raster de pente, exposition, courbure et dérivées partielles à partir d'une carte raster d'altitude. L'exposition est calculée dans le sens anti-horaire depuis l'est."
+msgid ""
+"Generates raster maps of slope, aspect, curvatures and partial derivatives "
+"from an elevation raster map. Aspect is calculated counterclockwise from "
+"east."
+msgstr ""
+"Générer des cartes raster de pente, exposition, courbure et dérivées "
+"partielles à partir d'une carte raster d'altitude. L'exposition est calculée "
+"dans le sens anti-horaire depuis l'est."
#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1265
msgid "Terrain parameters"
msgstr "Paramètres de terrain"
#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1266
-msgid "Extracts terrain parameters from a DEM. Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
-msgstr "Extrait les paramètres du terrain depuis un MNA. Utilise une approche multi-échelle en prenant le paramètres quadratiques englobants pour n'import quelle taille de fenêtre (par les moindre carrés)."
+msgid ""
+"Extracts terrain parameters from a DEM. Uses a multi-scale approach by "
+"taking fitting quadratic parameters to any size window (via least squares)."
+msgstr ""
+"Extrait les paramètres du terrain depuis un MNA. Utilise une approche multi-"
+"échelle en prenant le paramètres quadratiques englobants pour n'import "
+"quelle taille de fenêtre (par les moindre carrés)."
#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1267
msgid "Textural features"
@@ -7833,7 +8283,8 @@
#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1268
msgid "Generate images with textural features from a raster map."
-msgstr "Génère des images avec des entités de textures à partir d'une couche raster."
+msgstr ""
+"Génère des images avec des entités de textures à partir d'une couche raster."
#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1269
msgid "Visibility"
@@ -7841,16 +8292,34 @@
#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1270
#, fuzzy
-msgid "Computes the viewshed of a point on an elevation raster map. Default format: NULL (invisible), vertical angle wrt viewpoint (visible)."
-msgstr "Calculer la visibilité d'un point sur une carte raster d'altitudes. Format par défaut : NULL (invisible), angle vertical vers le point de vue (visible)."
+msgid ""
+"Computes the viewshed of a point on an elevation raster map. Default format: "
+"NULL (invisible), vertical angle wrt viewpoint (visible)."
+msgstr ""
+"Calculer la visibilité d'un point sur une carte raster d'altitudes. Format "
+"par défaut : NULL (invisible), angle vertical vers le point de vue (visible)."
#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1273
msgid "Horizon angle"
msgstr "Angle d'horizon"
#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1274
-msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
-msgstr "Calculer la hauteur d'angle de l'horizon depuis un modèle numérique d'altitude. Le module a deux modes opératoiires différents : 1. Calculer l'horizon entier autour d'un simple point dont on a donné les coordonnées en option. La hauteur d'orizon (en radians). 2. Calculer une ou plusieurs cartes raster de la hauteur d'horizon dans une seule direction. Le paramètre d'entrée est l'angle (en degrés), qui est mesuré dans le sens anti-horaire avec est=0, nord=90 etc. La sortie est la hauteur de l'horizon en radians."
+msgid ""
+"Computes horizon angle height from a digital elevation model. The module has "
+"two different modes of operation: 1. Computes the entire horizon around a "
+"single point whose coordinates are given with the 'coord' option. The "
+"horizon height (in radians). 2. Computes one or more raster maps of the "
+"horizon height in a single direction. The input for this is the angle (in "
+"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
+"output is the horizon height in radians."
+msgstr ""
+"Calculer la hauteur d'angle de l'horizon depuis un modèle numérique "
+"d'altitude. Le module a deux modes opératoiires différents : 1. Calculer "
+"l'horizon entier autour d'un simple point dont on a donné les coordonnées en "
+"option. La hauteur d'orizon (en radians). 2. Calculer une ou plusieurs "
+"cartes raster de la hauteur d'horizon dans une seule direction. Le paramètre "
+"d'entrée est l'angle (en degrés), qui est mesuré dans le sens anti-horaire "
+"avec est=0, nord=90 etc. La sortie est la hauteur de l'horizon en radians."
#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1275
msgid "Transform features"
@@ -7861,8 +8330,12 @@
msgstr "Agglomérer"
#: ../gui/wxpython/menustrings.py:376 ../gui/wxpython/menustrings.py:1277
-msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
-msgstr "Reclasser les données dans une couche raster en regroupant les cellules qui forment des zones physiques discrètes."
+msgid ""
+"Recategorizes data in a raster map by grouping cells that form physically "
+"discrete areas into unique categories."
+msgstr ""
+"Reclasser les données dans une couche raster en regroupant les cellules qui "
+"forment des zones physiques discrètes."
#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1278
msgid "Grow"
@@ -7874,7 +8347,9 @@
#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1281
msgid "Thins non-zero cells that denote linear features in a raster map layer."
-msgstr "Réduit les cellules non vides qui définissent une entité linéaire dans une couche raster."
+msgstr ""
+"Réduit les cellules non vides qui définissent une entité linéaire dans une "
+"couche raster."
#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1282
msgid "Hydrologic modeling"
@@ -7885,8 +8360,13 @@
msgstr "Creuser des chenaux d'écoulement"
#: ../gui/wxpython/menustrings.py:383 ../gui/wxpython/menustrings.py:1284
-msgid "Generates stream channels. Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
-msgstr "Générer les chenaux d'écoulement. Prends les données vectorielles d'écoulement, les transforme en raster, et soustrait la profondeur au modèle de terrain en sortie."
+msgid ""
+"Generates stream channels. Takes vector stream data, transforms it to raster "
+"and subtracts depth from the output DEM."
+msgstr ""
+"Générer les chenaux d'écoulement. Prends les données vectorielles "
+"d'écoulement, les transforme en raster, et soustrait la profondeur au modèle "
+"de terrain en sortie."
#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1285
msgid "Fill lake"
@@ -7901,8 +8381,12 @@
msgstr "Carte sans dépressions ni lignes de flux"
#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1288
-msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
-msgstr "Filtrer et générer une couche d'altitude sans dépressions et une couche de direction d'écoulement depuis une couche d'altitude donnée."
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation raster map."
+msgstr ""
+"Filtrer et générer une couche d'altitude sans dépressions et une couche de "
+"direction d'écoulement depuis une couche d'altitude donnée."
#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1289
msgid "Flow accumulation"
@@ -7917,8 +8401,13 @@
msgstr "Lignes de flux"
#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1292
-msgid "Constructs flowlines. Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
-msgstr "Construit les lignes de flux. Calcule les lignes de flux, longueur des chemins, et accumulations (surfaces amont) depuis une carte raster d'altitudes."
+msgid ""
+"Constructs flowlines. Computes flowlines, flowpath lengths, and "
+"flowaccumulation (contributing areas) from a elevation raster map."
+msgstr ""
+"Construit les lignes de flux. Calcule les lignes de flux, longueur des "
+"chemins, et accumulations (surfaces amont) depuis une carte raster "
+"d'altitudes."
#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1293
msgid "Watershed analysis"
@@ -7942,7 +8431,9 @@
#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1298
msgid "Creates watershed basins from a drainage direction map."
-msgstr "Générer les bassins versants à partir d'une carte de direction des écoulements."
+msgstr ""
+"Générer les bassins versants à partir d'une carte de direction des "
+"écoulements."
#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1299
msgid "Extraction of stream networks"
@@ -7965,8 +8456,12 @@
msgstr "Modélisation SIMWE des flux de sédiments"
#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1304
-msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
-msgstr "Simulation de transport de sédiments et d'érosion/sédimentation avec la méthode SIMWE."
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)."
+msgstr ""
+"Simulation de transport de sédiments et d'érosion/sédimentation avec la "
+"méthode SIMWE."
#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1305
msgid "Topographic index map"
@@ -7974,7 +8469,9 @@
#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1306
msgid "Creates a topographic index raster map from an elevation raster map."
-msgstr "Créer une carte d'index topographique à partir d'une carte raster d'altitudes."
+msgstr ""
+"Créer une carte d'index topographique à partir d'une carte raster "
+"d'altitudes."
#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1307
msgid "TOPMODEL simulation"
@@ -8010,16 +8507,24 @@
msgstr "Flux souterrain"
#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1315
-msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
-msgstr "Calcul numérique pour les eaux souterraines transitoires, confinées et non confinées, en deux dimensions."
+msgid ""
+"Numerical calculation program for transient, confined and unconfined "
+"groundwater flow in two dimensions."
+msgstr ""
+"Calcul numérique pour les eaux souterraines transitoires, confinées et non "
+"confinées, en deux dimensions."
#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1316
msgid "Groundwater solute transport"
msgstr "Transport de soluté souterrain"
#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1317
-msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
-msgstr "Calcul numérique pour le transport soluble transitoire, confiné et non confiné, en deux dimensions"
+msgid ""
+"Numerical calculation program for transient, confined and unconfined solute "
+"transport in two dimensions"
+msgstr ""
+"Calcul numérique pour le transport soluble transitoire, confiné et non "
+"confiné, en deux dimensions"
#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1318
msgid "Landscape patch analysis"
@@ -8038,8 +8543,11 @@
msgstr "Densité du bord"
#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1322
-msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr "Calcule l'index de densité de bords d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+"Calcule l'index de densité de bords d'une carte raster, à l'aide d'un "
+"algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1323
msgid "Contrast weighted edge density"
@@ -8047,15 +8555,21 @@
#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1324
msgid "Calculates contrast weighted edge density index on a raster map"
-msgstr "Calculer l'index de densité de bords pondérée par le contraste sur une carte raster"
+msgstr ""
+"Calculer l'index de densité de bords pondérée par le contraste sur une carte "
+"raster"
#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1325
msgid "Patch area mean"
msgstr "Surface moyenne des patch"
#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1326
-msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
-msgstr "Calculer l'index de taille moyenne de patch d'une carte raster, Ã l'aide d'un algorithme des 4 voisins les plus proches."
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
+msgstr ""
+"Calculer l'index de taille moyenne de patch d'une carte raster, Ã l'aide "
+"d'un algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1327
msgid "Patch area range"
@@ -8079,23 +8593,30 @@
#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1332
msgid "Calculates coefficient of variation of patch area on a raster map"
-msgstr "Calculer le coefficient de variation des taille de patch d'une carte raster."
+msgstr ""
+"Calculer le coefficient de variation des taille de patch d'une carte raster."
#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1333
msgid "Patch density"
msgstr "Module de densité"
#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1334
-msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr "Calculer l'index de densité de patch d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+"Calculer l'index de densité de patch d'une carte raster, à l'aide d'un "
#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1335
msgid "Patch number"
msgstr "Module nombre"
#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1336
-msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr "Calculer l'index du nombre de patch d'une carte raster, Ã l'aide d'un algorithme des 4 voisins les plus proches."
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+"Calculer l'index du nombre de patch d'une carte raster, Ã l'aide d'un "
#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1337
msgid "Dominance's diversity"
@@ -8147,16 +8668,28 @@
#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1349
#, fuzzy
-msgid "Generates rate of spread raster maps. Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation."
-msgstr "Génère trois ou quatre couches raster montrant 1) la la vitesse de propagation de base (ROS), 2) la propagation maximale, 3) la direction dela propagation maximale, et en option 4) la distance potentielle maximale de propagation."
+msgid ""
+"Generates rate of spread raster maps. Generates three, or four raster map "
+"layers showing the base (perpendicular) rate of spread (ROS), the maximum "
+"(forward) ROS, the direction of the maximum ROS, and optionally the maximum "
+"potential spotting distance for fire spread simulation."
+msgstr ""
+"Génère trois ou quatre couches raster montrant 1) la la vitesse de "
+"propagation de base (ROS), 2) la propagation maximale, 3) la direction dela "
+"propagation maximale, et en option 4) la distance potentielle maximale de "
+"propagation."
#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1350
msgid "Least-cost spread paths"
msgstr "Propagation par chemins de moindre coût "
#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1351
-msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
-msgstr "Trace de façon récursive le plus court chemin vers les cellules pour lequelles le coût cumulé est déterminé."
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
+msgstr ""
+"Trace de façon récursive le plus court chemin vers les cellules pour "
+"lequelles le coût cumulé est déterminé."
#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1352
msgid "Anisotropic spread simulation"
@@ -8164,8 +8697,16 @@
#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1353
#, fuzzy
-msgid "Simulates elliptically anisotropic spread. Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations."
-msgstr "Simule une propagation elliptique anisotropique sur une fenêtre graphique et génère une couche raster du temps cumulé de propagation, à partir de couches raster contenant des taux (ROS), directions, et origine des propagations."
+msgid ""
+"Simulates elliptically anisotropic spread. Generates a raster map of the "
+"cumulative time of spread, given raster maps containing the rates of spread "
+"(ROS), the ROS directions and the spread origins. It optionally produces "
+"raster maps to contain backlink UTM coordinates for tracing spread paths. "
+"Usable for fire spread simulations."
+msgstr ""
+"Simule une propagation elliptique anisotropique sur une fenêtre graphique et "
+"génère une couche raster du temps cumulé de propagation, à partir de couches "
+"raster contenant des taux (ROS), directions, et origine des propagations."
#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1354
msgid "Change category values and labels"
@@ -8178,8 +8719,12 @@
#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:507
#: ../gui/wxpython/menustrings.py:1356 ../gui/wxpython/menustrings.py:1408
-msgid "Manages category values and labels associated with user-specified raster map layers."
-msgstr "Gérer les valeurs de catégories et les étiquettes associées aux cartes raster spécifiées."
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
+msgstr ""
+"Gérer les valeurs de catégories et les étiquettes associées aux cartes "
+"raster spécifiées."
#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1357
msgid "Interactively edit category values"
@@ -8194,8 +8739,12 @@
msgstr "Reclasser en fonction de la taille"
#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1360
-msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
-msgstr "Reclasser une carte raster pour une taille supérieure ou égale à la taille spécifiée par l'utilisateur (en hectares)."
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)."
+msgstr ""
+"Reclasser une carte raster pour une taille supérieure ou égale à la taille "
+"spécifiée par l'utilisateur (en hectares)."
#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:666
#: ../gui/wxpython/menustrings.py:1361 ../gui/wxpython/menustrings.py:1567
@@ -8203,8 +8752,14 @@
msgstr "Reclasser"
#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1362
-msgid "Reclassify raster map based on category values. Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
-msgstr "Reclasser une carte raster en se basant sur les valeurs de catégories. Créer une nouvelle carte dont les valeurs de catégories sont basées sur une reclassification des catégories d'une carte raster existante."
+msgid ""
+"Reclassify raster map based on category values. Creates a new raster map "
+"whose category values are based upon a reclassification of the categories in "
+"an existing raster map."
+msgstr ""
+"Reclasser une carte raster en se basant sur les valeurs de catégories. Créer "
+"une nouvelle carte dont les valeurs de catégories sont basées sur une "
+"reclassification des catégories d'une carte raster existante."
#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1363
msgid "Recode"
@@ -8227,8 +8782,12 @@
msgstr "Recalculer l'échelle des valeurs par histogramme"
#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1368
-msgid "Rescales histogram equalized the range of category values in a raster map layer."
-msgstr "Rééchelonne l'histogramme sur la plage des valeurs de catégories de la couche raster."
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
+msgstr ""
+"Rééchelonne l'histogramme sur la plage des valeurs de catégories de la "
+"couche raster."
#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1369
msgid "Generate random cells"
@@ -8240,15 +8799,20 @@
#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1371
msgid "Generates random cell values with spatial dependence."
-msgstr "Génère des valeurs de cellules aléatoires avec une dépendance spatiale."
+msgstr ""
+"Génère des valeurs de cellules aléatoires avec une dépendance spatiale."
#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1372
msgid "Random cells and vector points"
msgstr "Cellules aléatoires et points vectoriels"
#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1373
-msgid "Creates a raster map layer and vector point map containing randomly located points."
-msgstr "Créer une carte raster ou une carte vectorielle de points contenant des points dispersés de manière aléatoire."
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"points."
+msgstr ""
+"Créer une carte raster ou une carte vectorielle de points contenant des "
+"points dispersés de manière aléatoire."
#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:1374
msgid "Generate surfaces"
@@ -8267,16 +8831,27 @@
msgstr "Surface avec un noyau de densité gaussienne"
#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1378
-msgid "Generates a raster density map from vector points map. Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
-msgstr "Génère une carte raster de densité à partir de données vecteurs points en utilisant un noyau mouvant et en option génère une carte de densité sur un réseau vectoriel."
+msgid ""
+"Generates a raster density map from vector points map. Density is computed "
+"using a moving kernel. Optionally generates a vector density map on a vector "
+"network."
+msgstr ""
+"Génère une carte raster de densité à partir de données vecteurs points en "
+"utilisant un noyau mouvant et en option génère une carte de densité sur un "
+"réseau vectoriel."
#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1379
msgid "Gaussian deviates surface"
msgstr "Déviance gaussienne de surface"
#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1380
-msgid "Generates a raster map using gaussian random number generator. Mean and standard deviation of gaussian deviates can be expressed by the user."
-msgstr "Générer une carte raster en utilisant un générateur de nombres aléatoire gaussien. La moyenne et l'écart-type de la déviation gaussienne peut être indiqués par l'utilisateur."
+msgid ""
+"Generates a raster map using gaussian random number generator. Mean and "
+"standard deviation of gaussian deviates can be expressed by the user."
+msgstr ""
+"Générer une carte raster en utilisant un générateur de nombres aléatoire "
+"gaussien. La moyenne et l'écart-type de la déviation gaussienne peut être "
+"indiqués par l'utilisateur."
#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1381
#: ../gui/wxpython/nviz/tools.py:4593
@@ -8285,16 +8860,23 @@
# Dip traduit ici pendage, en référence à la terminologie des géologues.
#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1382
-msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
-msgstr "Crée une carte raster plane définie par un pendage (inclinaison), une orientation (azimuth) et un point."
+msgid ""
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
+msgstr ""
+"Crée une carte raster plane définie par un pendage (inclinaison), une "
+"orientation (azimuth) et un point."
#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1383
msgid "Random deviates surface"
msgstr "Déviance aléatoire de surface"
#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1384
-msgid "Produces a raster surface map of uniform random deviates with defined range."
-msgstr "Produit une couche raster de données aléatoires uniformément réparties dans une plage donnée par l'utilisateur."
+msgid ""
+"Produces a raster surface map of uniform random deviates with defined range."
+msgstr ""
+"Produit une couche raster de données aléatoires uniformément réparties dans "
+"une plage donnée par l'utilisateur."
#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1385
msgid "Random surface with spatial dependence"
@@ -8313,24 +8895,36 @@
msgstr "Bilinéaire et bicubique de points vecteur"
#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1389
-msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
-msgstr "Effectue une interpolation spline bicubique ou bilinéaire avec régularisation de Tykhonov."
+msgid ""
+"Performs bicubic or bilinear spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+"Effectue une interpolation spline bicubique ou bilinéaire avec "
+"régularisation de Tykhonov."
#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1390
msgid "IDW from raster points"
msgstr "IDW de points matriciels"
#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1391
-msgid "Provides surface interpolation from raster point data by Inverse Distance Squared Weighting."
-msgstr "Interpolation de surface à partir de points raster par pondération de la distance inverse au carré (IDSW)."
+msgid ""
+"Provides surface interpolation from raster point data by Inverse Distance "
+"Squared Weighting."
+msgstr ""
+"Interpolation de surface à partir de points raster par pondération de la "
+"distance inverse au carré (IDSW)."
#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1392
msgid "IDW from vector points"
msgstr "IDW de points vecteur"
#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1393
-msgid "Provides surface interpolation from vector point data by Inverse Distance Squared Weighting."
-msgstr "Interpolation de surface à partir de points vecteur par pondération de la distance inverse au carré (IDSW)."
+msgid ""
+"Provides surface interpolation from vector point data by Inverse Distance "
+msgstr ""
+"Interpolation de surface à partir de points vecteur par pondération de la "
#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1394
msgid "Raster contours"
@@ -8345,16 +8939,28 @@
msgstr "Splines régulées avec tension"
#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1397
-msgid "Performs surface interpolation from vector points map by splines. Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
-msgstr "Effectue une interpolation de surfaces depuis des points vecteurs avec les splines. Approximation spatiale et analyse topographique depuis des points ou isolines au format vecteur vers un raster en nombre flottants, en utilisant des splines régulées avec tension."
+msgid ""
+"Performs surface interpolation from vector points map by splines. Spatial "
+"approximation and topographic analysis from given point or isoline data in "
+"vector format to floating point raster format using regularized spline with "
+"tension."
+msgstr ""
+"Effectue une interpolation de surfaces depuis des points vecteurs avec les "
+"splines. Approximation spatiale et analyse topographique depuis des points "
+"ou isolines au format vecteur vers un raster en nombre flottants, en "
+"utilisant des splines régulées avec tension."
#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1398
msgid "Raster series interpolation"
msgstr "Interpolation de série raster"
#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1399
-msgid "Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
-msgstr "Interpoler des cartes raster situées (temporel ou spatial) entre des cartes rasters d'entrée à des points d'échantillonages spécifiques."
+msgid ""
+"Interpolates raster maps located (temporal or spatial) in between input "
+"raster maps at specific sampling positions."
+msgstr ""
+"Interpoler des cartes raster situées (temporel ou spatial) entre des cartes "
+"rasters d'entrée à des points d'échantillonages spécifiques."
#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1400
msgid "Ordinary or block kriging"
@@ -8370,7 +8976,8 @@
#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1403
msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr "Remplir les zones sans données de la carte raster par interpolation spline."
+msgstr ""
+"Remplir les zones sans données de la carte raster par interpolation spline."
#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:705
#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:983
@@ -8409,7 +9016,8 @@
#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1414
msgid "Prints terse list of category values found in a raster map layer."
-msgstr "Afficher la liste des valeurs de catégories trouvées dans une carte raster."
+msgstr ""
+"Afficher la liste des valeurs de catégories trouvées dans une carte raster."
#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1415
msgid "Sum area by raster map and category"
@@ -8424,8 +9032,12 @@
msgstr "Statistiques pour des amas de cellules"
#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1418
-msgid "Calculates the volume of data \"clumps\". Optionally produces a GRASS vector points map containing the calculated centroids of these clumps."
-msgstr "Calcul le volume de données en amas. En option, produit une couche de points contenant les centroïdes de ces amas."
+msgid ""
+"Calculates the volume of data \"clumps\". Optionally produces a GRASS vector "
+"points map containing the calculated centroids of these clumps."
+msgstr ""
+"Calcul le volume de données en amas. En option, produit une couche de points "
+"contenant les centroïdes de ces amas."
#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1419
msgid "Total corrected area"
@@ -8441,8 +9053,16 @@
msgstr "Statistiques raster univariées"
#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1422
-msgid "Calculates univariate statistics from the non-null cells of a raster map. Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
-msgstr "Calcule les statistiques univariées pour les cellules non nulles d'une carte raster. Les statistiques incluent le nombe de cellules, les valeurs minimales et maximales, la plage, la moyenne arithmétique, la variance, l'écart-type, le coefficient de variation, et la somme."
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map. "
+"Statistics include number of cells counted, minimum and maximum cell values, "
+"range, arithmetic mean, population variance, standard deviation, coefficient "
+"of variation, and sum."
+msgstr ""
+"Calcule les statistiques univariées pour les cellules non nulles d'une carte "
+"raster. Les statistiques incluent le nombe de cellules, les valeurs "
+"minimales et maximales, la plage, la moyenne arithmétique, la variance, "
+"l'écart-type, le coefficient de variation, et la somme."
#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1423
msgid "Sample transects"
@@ -8450,22 +9070,29 @@
#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1424
msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr "Affiche en sortie les valeurs de carte raster suivant une(des) ligne(s) définie(s) par l'utilisateur."
+msgstr ""
+"Affiche en sortie les valeurs de carte raster suivant une(des) ligne(s) "
+"définie(s) par l'utilisateur."
#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1425
msgid "Sample transects (bearing/distance)"
msgstr "Exemple de transects (parcours/distance)"
#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1426
-msgid "Outputs raster map layer values lying along user defined transect line(s)."
-msgstr "Affiche en sortie les valeurs de carte raster suivant un(des) transect(s) défini(s) par l'utilisateur."
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+"Affiche en sortie les valeurs de carte raster suivant un(des) transect(s) "
+"défini(s) par l'utilisateur."
#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1427
msgid "Covariance/correlation"
msgstr "Covariance/corrélation"
#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1428
-msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map "
+"layer(s)."
msgstr "Sortir la matrice de covariance/corrélation pour des"
#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1429
@@ -8474,7 +9101,8 @@
#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:1430
msgid "Calculates linear regression from two raster maps: y = a + b*x."
-msgstr "Calcule une régression linéaire depuis deux cartes raster : y = a + b*x."
+msgstr ""
+"Calcule une régression linéaire depuis deux cartes raster : y = a + b*x."
#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1431
msgid "Multiple regression"
@@ -8489,8 +9117,11 @@
msgstr "Occurences mutelles de catégories"
#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1434
-msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
-msgstr "Tabuler les occurences mutuelles (coincidence) des catégories de deux rasters"
+msgid ""
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
+msgstr ""
+"Tabuler les occurences mutuelles (coincidence) des catégories de deux rasters"
#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1435
msgid "&Vector"
@@ -8509,8 +9140,12 @@
msgstr "Ãditer une carte vecteur (de façon non interactive)"
#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:1440
-msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
-msgstr "Ãdite une carte vecteur, permet d'ajouter, supprimer et modifier les objets vectoriels sélectionnés."
+msgid ""
+"Edits a vector map, allows adding, deleting and modifying selected vector "
+"features."
+msgstr ""
+"Ãdite une carte vecteur, permet d'ajouter, supprimer et modifier les objets "
+"vectoriels sélectionnés."
#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1441
msgid "Convert object types"
@@ -8533,8 +9168,12 @@
msgstr "Fusionner des contours"
#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1446
-msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
-msgstr "Fusionne des contours entre surfaces adjacentes partageant un attribut ou une catégorie commun(e)."
+msgid ""
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
+msgstr ""
+"Fusionne des contours entre surfaces adjacentes partageant un attribut ou "
+"une catégorie commun(e)."
#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1447
msgid "Create 3D vector over raster"
@@ -8542,15 +9181,22 @@
#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1448
msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
-msgstr "Convertit des entités vecteurs de 2D vers 3D par échantillonage d'une carte raster d'altitudes."
+msgstr ""
+"Convertit des entités vecteurs de 2D vers 3D par échantillonage d'une carte "
+"raster d'altitudes."
#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1449
msgid "Extrude 3D vector map"
msgstr "Extruder une carte vecteur 3D"
#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1450
-msgid "Extrudes flat vector features to 3D vector features with defined height. Optionally the height can be derived from sampling of elevation raster map."
-msgstr "Extruder un vecteur plat vers des entités vectorielles 3D avec une hauteur définie. En Option, la hauteur peut être dérivée de l'échantillonage d'une carte raster d'altitudes."
+msgid ""
+"Extrudes flat vector features to 3D vector features with defined height. "
+"Optionally the height can be derived from sampling of elevation raster map."
+msgstr ""
+"Extruder un vecteur plat vers des entités vectorielles 3D avec une hauteur "
+"définie. En Option, la hauteur peut être dérivée de l'échantillonage d'une "
+"carte raster d'altitudes."
#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1451
msgid "Create labels"
@@ -8565,16 +9211,23 @@
msgstr "Repositionner une carte vecteur"
#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1454
-msgid "Performs an affine transformation (shift, scale and rotate) on vector map."
-msgstr "Effectue la transformation affine (translation, échelle et rotation) d'une carte vecteur."
+msgid ""
+"Performs an affine transformation (shift, scale and rotate) on vector map."
+msgstr ""
+"Effectue la transformation affine (translation, échelle et rotation) d'une "
+"carte vecteur."
#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1455
msgid "Rectify vector map"
msgstr "Rectifier une carte vecteur"
#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1456
-msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
-msgstr "Rectifie un vecteur en calculant une transformation de coordonnées pour chaque objet du vecteur en se basant sur des points de contrôle."
+msgid ""
+"Rectifies a vector by computing a coordinate transformation for each object "
+"in the vector based on the control points."
+msgstr ""
+"Rectifie un vecteur en calculant une transformation de coordonnées pour "
+"chaque objet du vecteur en se basant sur des points de contrôle."
#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1460
msgid "Updates vector map metadata."
@@ -8589,8 +9242,12 @@
msgstr "Créer ou reconstruire la topologie"
#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1463
-msgid "Creates topology for vector map. Optionaly also checks for topological errors."
-msgstr "Créer la topologie pour la carte vecteur. En option, vérifie les erreurs de topologie."
+msgid ""
+"Creates topology for vector map. Optionaly also checks for topological "
+"errors."
+msgstr ""
+"Créer la topologie pour la carte vecteur. En option, vérifie les erreurs de "
+"topologie."
#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1464
msgid "Rebuild topology on all vector maps"
@@ -8598,7 +9255,9 @@
#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1465
msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr "Reconstruire la topologie de toutes les cartes vectorielles dans le jeux de cartes courant."
+msgstr ""
+"Reconstruire la topologie de toutes les cartes vectorielles dans le jeux de "
+"cartes courant."
#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1466
msgid "Build polylines"
@@ -8622,7 +9281,9 @@
#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1471
msgid "Creates points/segments from input vector lines and positions."
-msgstr "Crée des points/segments à partir de lignes vectorielles et positions en entrée."
+msgstr ""
+"Crée des points/segments à partir de lignes vectorielles et positions en "
+"entrée."
#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1472
msgid "Clean vector map"
@@ -8691,16 +9352,23 @@
msgstr "Sélectionner par attributs"
#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:1492
-msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
-msgstr "Sélectionne les entités vectorielles depuis une carte vecteur existante et créé une nouvelle carte vecteur contenant les entités sélectionnées."
+msgid ""
+"Selects vector features from an existing vector map and creates a new vector "
+"map containing only the selected features."
+msgstr ""
+"Sélectionne les entités vectorielles depuis une carte vecteur existante et "
+"créé une nouvelle carte vecteur contenant les entités sélectionnées."
#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:1493
msgid "Select by another map"
msgstr "Sélectionner par une autre carte"
#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:1494
-msgid "Selects features from vector map (A) by features from other vector map (B)."
-msgstr "Sélectionne des entités d'une carte vecteur (A) par des entités d'une autre carte vecteur (B)."
+msgid ""
+"Selects features from vector map (A) by features from other vector map (B)."
+msgstr ""
+"Sélectionne des entités d'une carte vecteur (A) par des entités d'une autre "
+"carte vecteur (B)."
#: ../gui/wxpython/menustrings.py:601 ../gui/wxpython/menustrings.py:1502
msgid "Buffer vectors"
@@ -8736,16 +9404,24 @@
msgstr "Détecter intérieurs"
#: ../gui/wxpython/menustrings.py:609 ../gui/wxpython/menustrings.py:1510
-msgid "Building contour determination and Region Growing algorithm for determining the building inside"
-msgstr "Détermination des contours de bâtiments et algorithme d'agrandissement de la région pour déterminer les bâtiments à l'intérieur"
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
+msgstr ""
+"Détermination des contours de bâtiments et algorithme d'agrandissement de la "
+"région pour déterminer les bâtiments à l'intérieur"
#: ../gui/wxpython/menustrings.py:610 ../gui/wxpython/menustrings.py:1511
msgid "Correct and reclassify objects"
msgstr "Corriger et classifier les objets"
#: ../gui/wxpython/menustrings.py:611 ../gui/wxpython/menustrings.py:1512
-msgid "Corrects the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
-msgstr "Correction de la sortie de v.lidar.growing. Il s'agit du dernier des trois algorithms pour le filtrage LIDAR."
+msgid ""
+"Corrects the v.lidar.growing output. It is the last of the three algorithms "
+"for LIDAR filtering."
+msgstr ""
+"Correction de la sortie de v.lidar.growing. Il s'agit du dernier des trois "
+"algorithms pour le filtrage LIDAR."
#: ../gui/wxpython/menustrings.py:612 ../gui/wxpython/menustrings.py:1513
msgid "Linear referencing"
@@ -8765,31 +9441,45 @@
#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:1517
msgid "Creates stationing from input lines, and linear reference system."
-msgstr "Créer des placement à partir de lignes, et d'un système de référence linéaire"
+msgstr ""
+"Créer des placement à partir de lignes, et d'un système de référence linéaire"
#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:1518
msgid "Create points/segments"
msgstr "Créer points/segments"
#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1519
-msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
-msgstr "Créer des points/segments à partir des lignes en entrée, un système de référence linéaire et des positions lues depuis l'entrée standard ou un fichier."
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
+msgstr ""
+"Créer des points/segments à partir des lignes en entrée, un système de "
+"référence linéaire et des positions lues depuis l'entrée standard ou un "
+"fichier."
#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1520
msgid "Find line id and offset"
msgstr "Trouver l'id de ligne et le décalage"
#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:1521
-msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
-msgstr "Trouvez l'id de ligne et le km réel pour les points donnés de la carte vectorielle en utilisant un système de référence linéaire"
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
+msgstr ""
+"Trouvez l'id de ligne et le km réel pour les points donnés de la carte "
+"vectorielle en utilisant un système de référence linéaire"
#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:1522
msgid "Nearest features"
msgstr "Entités les plus proches"
#: ../gui/wxpython/menustrings.py:622 ../gui/wxpython/menustrings.py:1523
-msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
-msgstr "Trouve l'élément de la carte \"vers\" le plus proche des éléments de la carte \"depuis\"."
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
+msgstr ""
+"Trouve l'élément de la carte \"vers\" le plus proche des éléments de la "
+"carte \"depuis\"."
#: ../gui/wxpython/menustrings.py:623 ../gui/wxpython/menustrings.py:1524
msgid "Network analysis"
@@ -8817,16 +9507,28 @@
msgstr "Allouer des sous-réseaux"
#: ../gui/wxpython/menustrings.py:629 ../gui/wxpython/menustrings.py:1530
-msgid "Allocates subnets for nearest centers (direction from center). center node must be opened (costs >= 0). Costs of center node are used in calculation"
-msgstr "Allouer les sous-réseaux pour le centre le plus proche (direction depuis le centre). Le noeud central doit être ouvert (coût >= 0). Le coût du noeud central est pris en compte dans le calcul."
+msgid ""
+"Allocates subnets for nearest centers (direction from center). center node "
+"must be opened (costs >= 0). Costs of center node are used in calculation"
+msgstr ""
+"Allouer les sous-réseaux pour le centre le plus proche (direction depuis le "
+"centre). Le noeud central doit être ouvert (coût >= 0). Le coût du noeud "
+"central est pris en compte dans le calcul."
#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1531
msgid "Split net"
msgstr "Diviser le réseau"
#: ../gui/wxpython/menustrings.py:631 ../gui/wxpython/menustrings.py:1532
-msgid "Splits net by cost isolines. Splits net to bands between cost isolines (direction from center). Center node must be opened (costs >= 0). Costs of center node are used in calculation."
-msgstr "Couper le réseau selon les isolignes de coût. Coupe le réseau en bandes entre les isolignes de coût (direction depuis le centre). Le noeud central doit être ouvert (coût >= 0). Le coût du noeud central est pris en compte dans le calcul."
+msgid ""
+"Splits net by cost isolines. Splits net to bands between cost isolines "
+"(direction from center). Center node must be opened (costs >= 0). Costs of "
+"center node are used in calculation."
+msgstr ""
+"Couper le réseau selon les isolignes de coût. Coupe le réseau en bandes "
+"entre les isolignes de coût (direction depuis le centre). Le noeud central "
+"doit être ouvert (coût >= 0). Le coût du noeud central est pris en compte "
+"dans le calcul."
#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:1533
msgid "Shortest path"
@@ -8841,8 +9543,16 @@
msgstr "Plus court chemin pour des jeux d'entités"
#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1536
-msgid "Computes shortest distance via the network between the given sets of features. Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table."
-msgstr "Calcule la distance la plus proche à travers le réseau entre les jeux d'entités donnés. Trouve le chemin le plus proche depuis tous les points 'depuis' vers l'entité 'vers' la plus proche et enregistre les informations sur cette relation dans la table d'attributs."
+msgid ""
+"Computes shortest distance via the network between the given sets of "
+"features. Finds the shortest paths from each 'from' point to the nearest "
+"'to' feature and various information about this relation are uploaded to the "
+"attribute table."
+msgstr ""
+"Calcule la distance la plus proche à travers le réseau entre les jeux "
+"d'entités donnés. Trouve le chemin le plus proche depuis tous les points "
+"'depuis' vers l'entité 'vers' la plus proche et enregistre les informations "
+"sur cette relation dans la table d'attributs."
#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1537
msgid "Shortest path using timetables"
@@ -8858,7 +9568,8 @@
#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1540
msgid "Computes the shortest path between all pairs of nodes in the network."
-msgstr "Calcule le plus court chemin entre toutes les paires de nÅuds du réseau."
+msgstr ""
+"Calcule le plus court chemin entre toutes les paires de nÅuds du réseau."
#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1541
msgid "Visibility network"
@@ -8890,7 +9601,8 @@
#: ../gui/wxpython/menustrings.py:647 ../gui/wxpython/menustrings.py:1548
msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr "Calcule la connectivité des sommets entre deux jeux de noeuds d'un réseau."
+msgstr ""
+"Calcule la connectivité des sommets entre deux jeux de noeuds d'un réseau."
#: ../gui/wxpython/menustrings.py:648 ../gui/wxpython/menustrings.py:1549
msgid "Components"
@@ -8905,16 +9617,27 @@
msgstr "Centralité"
#: ../gui/wxpython/menustrings.py:651 ../gui/wxpython/menustrings.py:1552
-msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
-msgstr "Calcule les degré, centralité, intermédiarité, proximité et vecteur propre des mesures de centralité d'un réseau."
+msgid ""
+"Computes degree, centrality, betweeness, closeness and eigenvector "
+"centrality measures in the network."
+msgstr ""
+"Calcule les degré, centralité, intermédiarité, proximité et vecteur propre "
+"des mesures de centralité d'un réseau."
#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1553
msgid "Steiner tree"
msgstr "Arbre de Steiner"
#: ../gui/wxpython/menustrings.py:653 ../gui/wxpython/menustrings.py:1554
-msgid "Creates Steiner tree for the network and given terminals. Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal."
-msgstr "Créer l'arbre de Steiner pour le réseau et les points terminaux donnés. Il est à noter que 'l'arbre de Steiner minimal' est un problème NP complexe et qu'un algorithme heuristique est utilisé par ce module, le résultat peut être sous-optimal."
+msgid ""
+"Creates Steiner tree for the network and given terminals. Note that 'Minimum "
+"Steiner Tree' problem is NP-hard and heuristic algorithm is used in this "
+"module so the result may be sub optimal."
+msgstr ""
+"Créer l'arbre de Steiner pour le réseau et les points terminaux donnés. Il "
+"est à noter que 'l'arbre de Steiner minimal' est un problème NP complexe et "
+"qu'un algorithme heuristique est utilisé par ce module, le résultat peut "
+"être sous-optimal."
#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1555
msgid "Minimum spanning tree"
@@ -8929,8 +9652,15 @@
msgstr "Analyse de type 'représentant commercial'"
#: ../gui/wxpython/menustrings.py:657 ../gui/wxpython/menustrings.py:1558
-msgid "Creates a cycle connecting given nodes (Traveling salesman problem). Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
-msgstr "Créer un cycle connectant les noeuds donnés (problème du représentant commercial). Il est à noter qu'il s'agit d'une problème NP complexe, un algorithme heuristique est utilisé par ce module et le résultat peut être sous optimal."
+msgid ""
+"Creates a cycle connecting given nodes (Traveling salesman problem). Note "
+"that TSP is NP-hard, heuristic algorithm is used by this module and created "
+"cycle may be sub optimal"
+msgstr ""
+"Créer un cycle connectant les noeuds donnés (problème du représentant "
+"commercial). Il est à noter qu'il s'agit d'une problème NP complexe, un "
+"algorithme heuristique est utilisé par ce module et le résultat peut être "
+"sous optimal."
#: ../gui/wxpython/menustrings.py:658 ../gui/wxpython/menustrings.py:659
#: ../gui/wxpython/menustrings.py:1559 ../gui/wxpython/menustrings.py:1560
@@ -8959,19 +9689,31 @@
#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:1566
msgid "Attaches, deletes or reports vector categories to map geometry."
-msgstr "Attacher, supprimer ou rendre compte des catégories de vecteur vers la carte de géométries."
+msgstr ""
+"Attacher, supprimer ou rendre compte des catégories de vecteur vers la carte "
+"de géométries."
#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1568
-msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
-msgstr "Change les valeurs de catégorie pour une carte vecteur existante en fonction des résultats de requêtes SQL ou d'un valeur dans une colonne de table attributaire."
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
+msgstr ""
+"Change les valeurs de catégorie pour une carte vecteur existante en fonction "
+"des résultats de requêtes SQL ou d'un valeur dans une colonne de table "
+"attributaire."
#: ../gui/wxpython/menustrings.py:669 ../gui/wxpython/menustrings.py:1570
msgid "Update area attributes from raster"
msgstr "Mise à jour des attributs surfaciques à partir d'une carte raster"
#: ../gui/wxpython/menustrings.py:670 ../gui/wxpython/menustrings.py:1571
-msgid "Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns."
-msgstr "Calculer les statistiques univariées d'une carte raster basées sur une carte vecteur et ajouter les statistiques dans des nouvelles colonnes attributaires."
+msgid ""
+"Calculates univariate statistics from a raster map based on a vector map and "
+"uploads statistics to new attribute columns."
+msgstr ""
+"Calculer les statistiques univariées d'une carte raster basées sur une carte "
+"vecteur et ajouter les statistiques dans des nouvelles colonnes "
+"attributaires."
#: ../gui/wxpython/menustrings.py:671 ../gui/wxpython/menustrings.py:1572
msgid "Update area attributes from vector"
@@ -8979,7 +9721,9 @@
#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1573
msgid "Count points in areas, calculate statistics from point attributes."
-msgstr "Compter les points dans une surface, calculer les statistiques des attributs des points."
+msgstr ""
+"Compter les points dans une surface, calculer les statistiques des attributs "
+"des points."
#: ../gui/wxpython/menustrings.py:673 ../gui/wxpython/menustrings.py:1574
msgid "Update point attributes from areas"
@@ -8987,7 +9731,9 @@
#: ../gui/wxpython/menustrings.py:674 ../gui/wxpython/menustrings.py:1575
msgid "Uploads vector values at positions of vector points to the table."
-msgstr "Ajouter dans la table les valeurs de vecteur à la position des points du vecteur."
+msgstr ""
+"Ajouter dans la table les valeurs de vecteur à la position des points du "
+"vecteur."
#: ../gui/wxpython/menustrings.py:675 ../gui/wxpython/menustrings.py:1576
msgid "Update database values from vector"
@@ -9003,7 +9749,9 @@
#: ../gui/wxpython/menustrings.py:678 ../gui/wxpython/menustrings.py:1579
msgid "Uploads raster values at positions of vector points to the table."
-msgstr "Ajouter dans la table les valeurs de raster à la position des points du vecteur."
+msgstr ""
+"Ajouter dans la table les valeurs de raster à la position des points du "
+"vecteur."
#: ../gui/wxpython/menustrings.py:679 ../gui/wxpython/menustrings.py:1580
msgid "Sample raster neighborhood around points"
@@ -9011,7 +9759,8 @@
#: ../gui/wxpython/menustrings.py:680 ../gui/wxpython/menustrings.py:1581
msgid "Samples a raster map at vector point locations."
-msgstr "Ãchantillonne une carte raster au droit des points d'une carte vecteur."
+msgstr ""
+"Ãchantillonne une carte raster au droit des points d'une carte vecteur."
#: ../gui/wxpython/menustrings.py:681 ../gui/wxpython/menustrings.py:1582
msgid "Generate area for current region"
@@ -9038,16 +9787,24 @@
msgstr "Triangles de Delaunay"
#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:1588
-msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
-msgstr "Crée une triangulation de Delaunay à partir d'une carte vecteur contenant des points ou centroïdes."
+msgid ""
+"Creates a Delaunay triangulation from an input vector map containing points "
+"or centroids."
+msgstr ""
+"Crée une triangulation de Delaunay à partir d'une carte vecteur contenant "
+"des points ou centroïdes."
#: ../gui/wxpython/menustrings.py:688 ../gui/wxpython/menustrings.py:1589
msgid "Voronoi diagram/Thiessen polygons"
msgstr "Diagramme de Voronoï/polygones de Thiessen"
#: ../gui/wxpython/menustrings.py:689 ../gui/wxpython/menustrings.py:1590
-msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
-msgstr "Crée un diagramme de Voronoï dans la région courante depuis une carte vecteur contenant des points ou centroïdes."
+msgid ""
+"Creates a Voronoi diagram in current region from an input vector map "
+"containing points or centroids."
+msgstr ""
+"Crée un diagramme de Voronoï dans la région courante depuis une carte "
+"vecteur contenant des points ou centroïdes."
#: ../gui/wxpython/menustrings.py:690 ../gui/wxpython/menustrings.py:1591
msgid "Generate grid"
@@ -9066,8 +9823,11 @@
msgstr "Générer à partir d'une base de données"
#: ../gui/wxpython/menustrings.py:694 ../gui/wxpython/menustrings.py:1595
-msgid "Creates new vector (points) map from database table containing coordinates."
-msgstr "Crée une nouvelle carte vecteur (points) à partir d'une table de base de données contenant des coordonnées."
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+"Crée une nouvelle carte vecteur (points) à partir d'une table de base de "
+"données contenant des coordonnées."
#: ../gui/wxpython/menustrings.py:695 ../gui/wxpython/menustrings.py:1596
msgid "Generate points along lines"
@@ -9075,7 +9835,9 @@
#: ../gui/wxpython/menustrings.py:696 ../gui/wxpython/menustrings.py:1597
msgid "Creates points along input lines in new vector map with 2 layers."
-msgstr "Créer des points le long d'une ligne d'entrée dans une nouvelle carte vecteur avec 2 couches."
+msgstr ""
+"Créer des points le long d'une ligne d'entrée dans une nouvelle carte "
+"vecteur avec 2 couches."
#: ../gui/wxpython/menustrings.py:697 ../gui/wxpython/menustrings.py:1598
msgid "Generate random points"
@@ -9120,7 +9882,9 @@
#: ../gui/wxpython/menustrings.py:709 ../gui/wxpython/menustrings.py:1610
msgid "Classifies attribute data, e.g. for thematic mapping"
-msgstr "Classifier les données attributaires, par exemple pour une cartographie thématique"
+msgstr ""
+"Classifier les données attributaires, par exemple pour une cartographie "
+"thématique"
#: ../gui/wxpython/menustrings.py:710 ../gui/wxpython/menustrings.py:1611
msgid "Report topology by category"
@@ -9136,15 +9900,21 @@
msgstr "Statistiques univariées pour des points"
#: ../gui/wxpython/menustrings.py:713 ../gui/wxpython/menustrings.py:1614
-msgid "Calculates univariate statistics of vector map features. Variance and standard deviation is calculated only for points if specified."
-msgstr "Calcule les statistiques univariées pour les entités. La variance et l'écart-type sont calculés uniquement pour les points."
+msgid ""
+"Calculates univariate statistics of vector map features. Variance and "
+"standard deviation is calculated only for points if specified."
+msgstr ""
+"Calcule les statistiques univariées pour les entités. La variance et l'écart-"
+"type sont calculés uniquement pour les points."
#: ../gui/wxpython/menustrings.py:714 ../gui/wxpython/menustrings.py:1615
msgid "Univariate statistics for attribute columns"
msgstr "Statistiques univariées pour les colonnes d'attributs"
#: ../gui/wxpython/menustrings.py:715 ../gui/wxpython/menustrings.py:1616
-msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+msgid ""
+"Calculates univariate statistics on selected table column for a GRASS vector "
+"map."
msgstr "Calcule les statistiques univariées sur la colonne sélectionnée."
#: ../gui/wxpython/menustrings.py:716 ../gui/wxpython/menustrings.py:1617
@@ -9197,7 +9967,9 @@
#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1628
#, fuzzy
msgid "Mosaics several images and extends colormap."
-msgstr "Créer une mosaïque jusqu'à 4 images et étend la table de couleurs; créer une carte *.mosaic"
+msgstr ""
+"Créer une mosaïque jusqu'à 4 images et étend la table de couleurs; créer une "
+"carte *.mosaic"
#: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1629
msgid "Manage image colors"
@@ -9217,20 +9989,32 @@
msgstr "TSV vers RVB"
#: ../gui/wxpython/menustrings.py:732 ../gui/wxpython/menustrings.py:1633
-msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
-msgstr "Transforme une carte raster de l'espace colorimétrique TSV (Teinte-Saturation-Valeur) vers l'espace colorimétrique RVB (Rouge-Vert-Bleu)."
+msgid ""
+"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
+"RGB (Red-Green-Blue) color space."
+msgstr ""
+"Transforme une carte raster de l'espace colorimétrique TSV (Teinte-"
+"Saturation-Valeur) vers l'espace colorimétrique RVB (Rouge-Vert-Bleu)."
#: ../gui/wxpython/menustrings.py:734 ../gui/wxpython/menustrings.py:1635
-msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
-msgstr "Transforme une carte raster de l'espace colorimétrique RVB (Rouge-Vert-Bleu) vers l'espace colorimétrique TSV (Teinte-Saturation-Valeur)."
+msgid ""
+"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
+"Intensity-Saturation) color space."
+msgstr ""
+"Transforme une carte raster de l'espace colorimétrique RVB (Rouge-Vert-Bleu) "
+"vers l'espace colorimétrique TSV (Teinte-Saturation-Valeur)."
#: ../gui/wxpython/menustrings.py:735 ../gui/wxpython/menustrings.py:1636
msgid "Rectify image or raster"
msgstr "Rectifier une image ou une carte raster"
#: ../gui/wxpython/menustrings.py:736 ../gui/wxpython/menustrings.py:1637
-msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
-msgstr "Redresse une image en calculant une transformation de coordonnées pour chaque pixel de l'image basée sur des points de contrôle."
+msgid ""
+"Rectifies an image by computing a coordinate transformation for each pixel "
+"in the image based on the control points."
+msgstr ""
+"Redresse une image en calculant une transformation de coordonnées pour "
+"chaque pixel de l'image basée sur des points de contrôle."
#: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1638
#: ../gui/wxpython/lmgr/layertree.py:609
@@ -9246,8 +10030,11 @@
msgstr "Réponse spectrale"
#: ../gui/wxpython/menustrings.py:740 ../gui/wxpython/menustrings.py:1641
-msgid "Displays spectral response at user specified locations in group or images."
-msgstr "Affiche la réponse spectrale d'une position données pour un groupe ou une image."
+msgid ""
+"Displays spectral response at user specified locations in group or images."
+msgstr ""
+"Affiche la réponse spectrale d'une position données pour un groupe ou une "
+"image."
#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1642
#, fuzzy
@@ -9256,8 +10043,12 @@
#: ../gui/wxpython/menustrings.py:742 ../gui/wxpython/menustrings.py:1643
#, fuzzy
-msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
-msgstr "Transformation de Brovey pour fusionner des canaux multispectraux et panchromatique haute résolution."
+msgid ""
+"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
+"channels"
+msgstr ""
+"Transformation de Brovey pour fusionner des canaux multispectraux et "
+"panchromatique haute résolution."
#: ../gui/wxpython/menustrings.py:743 ../gui/wxpython/menustrings.py:1644
msgid "Classify image"
@@ -9269,8 +10060,13 @@
#: ../gui/wxpython/menustrings.py:745 ../gui/wxpython/menustrings.py:1646
#, fuzzy
-msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm. The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
-msgstr "Générer les signatures spectrales pour l'occupation des sols dans une image, à l'aide d'un algorithme de regroupement."
+msgid ""
+"Generates spectral signatures for land cover types in an image using a "
+"clustering algorithm. The resulting signature file is used as input for i."
+"maxlik, to generate an unsupervised image classification."
+msgstr ""
+"Générer les signatures spectrales pour l'occupation des sols dans une image, "
+"Ã l'aide d'un algorithme de regroupement."
#: ../gui/wxpython/menustrings.py:746 ../gui/wxpython/menustrings.py:1647
msgid "Input for supervised MLC"
@@ -9285,8 +10081,14 @@
msgstr "Classification par le maximum de vraissemblance (MLC)"
#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1650
-msgid "Classifies the cell spectral reflectances in imagery data. Classification is based on the spectral signature information generated by either i.cluster, g.gui.iclass, or i.gensig."
-msgstr "Classifie les réflectances spectrales des cellules de donénes d'imagerie. La classification est basée sur les informations de signatures spectrales générées soit par i.cluster, g.gui.iclass, ou i.gensig."
+msgid ""
+"Classifies the cell spectral reflectances in imagery data. Classification is "
+"based on the spectral signature information generated by either i.cluster, g."
+"gui.iclass, or i.gensig."
+msgstr ""
+"Classifie les réflectances spectrales des cellules de donénes d'imagerie. La "
+"classification est basée sur les informations de signatures spectrales "
+"générées soit par i.cluster, g.gui.iclass, ou i.gensig."
#: ../gui/wxpython/menustrings.py:750 ../gui/wxpython/menustrings.py:1651
#: ../gui/wxpython/menustrings.py:1908
@@ -9297,8 +10099,11 @@
#: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1652
#: ../gui/wxpython/menustrings.py:1909
#, fuzzy
-msgid "Generates spectral signatures by allowing the user to outline training areas."
-msgstr "Générer les signatures spectrales en autorisant l'utilisateur à définir les zones d'entrainement."
+msgid ""
+"Generates spectral signatures by allowing the user to outline training areas."
+msgstr ""
+"Générer les signatures spectrales en autorisant l'utilisateur à définir les "
+"zones d'entrainement."
#: ../gui/wxpython/menustrings.py:752 ../gui/wxpython/menustrings.py:1653
msgid "Input for supervised SMAP"
@@ -9313,8 +10118,12 @@
msgstr "Classification par le maximum séquentiel à postériori (SMAP)"
#: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1656
-msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
-msgstr "Effectue une classification d'image contextuelle, en utilisant l'estimation du maximum séquentiel à postériori (SMAP)."
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
+"Effectue une classification d'image contextuelle, en utilisant l'estimation "
+"du maximum séquentiel à postériori (SMAP)."
#: ../gui/wxpython/menustrings.py:756 ../gui/wxpython/menustrings.py:1657
#, fuzzy
@@ -9335,7 +10144,9 @@
#: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/menustrings.py:1661
msgid "Zero-crossing \"edge detection\" raster function for image processing."
-msgstr "Fonction raster de \"détection des bords\" sans croisement pour l'analyse d'images."
+msgstr ""
+"Fonction raster de \"détection des bords\" sans croisement pour l'analyse "
+"d'images."
#: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1662
msgid "Matrix/convolving filter"
@@ -9392,8 +10203,12 @@
#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1675
#, fuzzy
-msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN."
-msgstr "Calcules les radiance/réflectance/température de luminosité au dessus de l'atmosphère pour les DN Aster."
+msgid ""
+"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
+"from ASTER DN."
+msgstr ""
+"Calcules les radiance/réflectance/température de luminosité au dessus de "
+"l'atmosphère pour les DN Aster."
#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1676
msgid "Landsat DN to radiance/reflectance"
@@ -9401,8 +10216,12 @@
#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1677
#, fuzzy
-msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
-msgstr "Calculer la radiance ou la réflectance \"top-of-atmosphere\" et la température pour les images Landsat MSS/TM/ETM+."
+msgid ""
+"Calculates top-of-atmosphere radiance or reflectance and temperature for "
+"Landsat MSS/TM/ETM+/OLI"
+msgstr ""
+"Calculer la radiance ou la réflectance \"top-of-atmosphere\" et la "
+"température pour les images Landsat MSS/TM/ETM+."
#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1678
msgid "Landsat cloud cover assessment"
@@ -9410,7 +10229,9 @@
#: ../gui/wxpython/menustrings.py:778 ../gui/wxpython/menustrings.py:1679
msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr "Effecture une évaluation automatique de la couverture nuageuse (ACCA) pour Landsat TM/ETM+."
+msgstr ""
+"Effecture une évaluation automatique de la couverture nuageuse (ACCA) pour "
+"Landsat TM/ETM+."
#: ../gui/wxpython/menustrings.py:779 ../gui/wxpython/menustrings.py:1680
msgid "Modis quality control"
@@ -9427,7 +10248,9 @@
#: ../gui/wxpython/menustrings.py:782 ../gui/wxpython/menustrings.py:1683
#, fuzzy
-msgid "Performs atmospheric correction using the 6S algorithm. 6S - Second Simulation of Satellite Signal in the Solar Spectrum."
+msgid ""
+"Performs atmospheric correction using the 6S algorithm. 6S - Second "
+"Simulation of Satellite Signal in the Solar Spectrum."
msgstr "Effectue une correction atmosphérique par l'algorithme 6S."
#: ../gui/wxpython/menustrings.py:783 ../gui/wxpython/menustrings.py:1684
@@ -9449,8 +10272,13 @@
msgstr "Indices des quadrats"
#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1688
-msgid "Calculates different types of vegetation indices. Uses red and nir bands mostly, and some indices require additional bands."
-msgstr "Calcule différents types d'indices de végétation. Utilise principalement les bandes rouge et proche infra-rouge, certains indices nécessitent des bandes supplémentaires."
+msgid ""
+"Calculates different types of vegetation indices. Uses red and nir bands "
+"mostly, and some indices require additional bands."
+msgstr ""
+"Calcule différents types d'indices de végétation. Utilise principalement les "
+"bandes rouge et proche infra-rouge, certains indices nécessitent des bandes "
+"supplémentaires."
#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1689
msgid "Tasseled cap vegetation index"
@@ -9459,7 +10287,8 @@
#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1690
#, fuzzy
msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
-msgstr "Transformation de Tasseled cap (Kauth Thomas) pour les données LANDSAT-TM"
+msgstr ""
+"Transformation de Tasseled cap (Kauth Thomas) pour les données LANDSAT-TM"
#: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1691
msgid "Albedo"
@@ -9477,7 +10306,9 @@
#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1694
msgid "Computes emissivity from NDVI, generic method for sparse land."
-msgstr "Calcule l'émissivité depuis le NDVI, méthode générique pour les terres clairsemées."
+msgstr ""
+"Calcule l'émissivité depuis le NDVI, méthode générique pour les terres "
+"clairsemées."
#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1695
msgid "Biomass growth"
@@ -9485,7 +10316,9 @@
#: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1696
msgid "Computes biomass growth, precursor of crop yield calculation."
-msgstr "Calcule la croissance de la biomasse, un des précurseur du calcul du rendement d'un champ."
+msgstr ""
+"Calcule la croissance de la biomasse, un des précurseur du calcul du "
+"rendement d'un champ."
#: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1697
msgid "Evapotranspiration calculation"
@@ -9524,8 +10357,12 @@
#: ../gui/wxpython/menustrings.py:804 ../gui/wxpython/menustrings.py:1705
#, fuzzy
-msgid "Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil moisture (Makin, Molden and Bastiaanssen, 2001)."
-msgstr "Calcule la fraction évaporée (Bastiaanssen, 1995) et l'humidité racinaire du sol (Makin, Molden and Bastiaanssen, 2001)."
+msgid ""
+"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
+"moisture (Makin, Molden and Bastiaanssen, 2001)."
+msgstr ""
+"Calcule la fraction évaporée (Bastiaanssen, 1995) et l'humidité racinaire du "
+"sol (Makin, Molden and Bastiaanssen, 2001)."
#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1706
msgid "Actual Evapotranspiration"
@@ -9540,7 +10377,9 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1709
-msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
+msgid ""
+"Computes temporal integration of satellite ET actual (ETa) following the "
+"daily ET reference (ETo) from meteorological station(s)."
msgstr ""
#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1710
@@ -9549,8 +10388,12 @@
#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1711
#, fuzzy
-msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
-msgstr "Calcule l'évapotranspiration selon la formule de Hargreaves originale ou modifiée, 2001."
+msgid ""
+"Computes evapotranspiration calculation modified or original Hargreaves "
+"formulation, 2001."
+msgstr ""
+"Calcule l'évapotranspiration selon la formule de Hargreaves originale ou "
+"modifiée, 2001."
#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1712
msgid "Penman-Monteith Evapotranspiration"
@@ -9558,8 +10401,12 @@
#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1713
#, fuzzy
-msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
-msgstr "Calcule le potentiel d'évapotranspiration avec la méthode horaire Penman-Monteith."
+msgid ""
+"Computes potential evapotranspiration calculation with hourly Penman-"
+"Monteith."
+msgstr ""
+"Calcule le potentiel d'évapotranspiration avec la méthode horaire Penman-"
+"Monteith."
#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:1714
msgid "Priestley-Taylor Evapotranspiration"
@@ -9567,16 +10414,23 @@
#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1715
#, fuzzy
-msgid "Computes evapotranspiration calculation Priestley and Taylor formulation, 1972."
-msgstr "Calcule l'évapotranspiration selon la formule de Priestley et Taylor, 1972."
+msgid ""
+"Computes evapotranspiration calculation Priestley and Taylor formulation, "
+"1972."
+msgstr ""
+"Calcule l'évapotranspiration selon la formule de Priestley et Taylor, 1972."
#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1717
msgid "Kappa analysis"
msgstr "Analyse Kappa"
#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1718
-msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
-msgstr "Calcule la matrice de confusion et le paramètre kappa pour l'évaluation de l'exactitude des résultats de classification."
+msgid ""
+"Calculates error matrix and kappa parameter for accuracy assessment of "
+"classification result."
+msgstr ""
+"Calcule la matrice de confusion et le paramètre kappa pour l'évaluation de "
+"l'exactitude des résultats de classification."
#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:1719
msgid "OIF for LandSat TM"
@@ -9585,7 +10439,9 @@
#: ../gui/wxpython/menustrings.py:819 ../gui/wxpython/menustrings.py:1720
#, fuzzy
msgid "Calculates Optimum-Index-Factor table for spectral bands"
-msgstr "Calcule la table de facteur d'index optimal pour les bandes 1-5 et 7 de Landsat TM."
+msgstr ""
+"Calcule la table de facteur d'index optimal pour les bandes 1-5 et 7 de "
+"Landsat TM."
#: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/menustrings.py:1721
#, fuzzy
@@ -9658,21 +10514,33 @@
#: ../gui/wxpython/menustrings.py:838 ../gui/wxpython/menustrings.py:1739
#, fuzzy
-msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
-msgstr "Créer une section de coupe 2D depuis une carte raster 3D et une carte d'altitude 2D"
+msgid ""
+"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
+"map"
+msgstr ""
+"Créer une section de coupe 2D depuis une carte raster 3D et une carte "
+"d'altitude 2D"
#: ../gui/wxpython/menustrings.py:840 ../gui/wxpython/menustrings.py:1741
#, fuzzy
-msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
-msgstr "Calcul numérique pour les eaux souterraines transitoires, confinées et non confinées, en deux dimensions."
+msgid ""
+"Numerical calculation program for transient, confined groundwater flow in "
+"three dimensions."
+msgstr ""
+"Calcul numérique pour les eaux souterraines transitoires, confinées et non "
+"confinées, en deux dimensions."
#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1742
msgid "Interpolate 3D raster from points"
msgstr "Interpoler un raster 3D depuis des points"
#: ../gui/wxpython/menustrings.py:842 ../gui/wxpython/menustrings.py:1743
-msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
-msgstr "Interpoler des données points vers une carte raster 3D, en utilisant l'algorithme des splines régulées avec tension (RST)."
+msgid ""
+"Interpolates point data to a 3D raster map using regularized spline with "
+"tension (RST) algorithm."
+msgstr ""
+"Interpoler des données points vers une carte raster 3D, en utilisant "
+"l'algorithme des splines régulées avec tension (RST)."
#: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1744
msgid "Reports and Statistics"
@@ -9699,8 +10567,16 @@
msgstr "Statistiques univariées pour les raster 3D"
#: ../gui/wxpython/menustrings.py:849 ../gui/wxpython/menustrings.py:1750
-msgid "Calculates univariate statistics from the non-null cells of a 3D raster map. Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
-msgstr "Calcule les statistiques univariées pour les cellules non nulles d'une carte raster 3D. Les statiqtiques incluent le nombre de cellules, les valeurs minimales et maximales, la plage, la moyenne arithmétique, la variance, l'écart type, le coefficient de variation, et la somme."
+msgid ""
+"Calculates univariate statistics from the non-null cells of a 3D raster map. "
+msgstr ""
+"raster 3D. Les statiqtiques incluent le nombre de cellules, les valeurs "
+"l'écart type, le coefficient de variation, et la somme."
#: ../gui/wxpython/menustrings.py:850 ../gui/wxpython/menustrings.py:1751
msgid "&Database"
@@ -9716,7 +10592,8 @@
#: ../gui/wxpython/menustrings.py:853 ../gui/wxpython/menustrings.py:1754
msgid "Lists all databases for a given driver and location."
-msgstr "Lister toutes les bases de données pour un pilote et un secteur donnés."
+msgstr ""
+"Lister toutes les bases de données pour un pilote et un secteur donnés."
#: ../gui/wxpython/menustrings.py:854 ../gui/wxpython/menustrings.py:1755
msgid "List drivers"
@@ -9760,7 +10637,8 @@
#: ../gui/wxpython/menustrings.py:864 ../gui/wxpython/menustrings.py:1765
msgid "Prints/sets general DB connection for current mapset."
-msgstr "Afficher/définir la connecion DB générale pour le jeu de cartes courant."
+msgstr ""
+"Afficher/définir la connecion DB générale pour le jeu de cartes courant."
#: ../gui/wxpython/menustrings.py:865 ../gui/wxpython/menustrings.py:1766
msgid "Login"
@@ -9799,8 +10677,13 @@
msgstr "Copier la table"
#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:1775
-msgid "Copy a table. Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
-msgstr "Copier une table. Soit 'depuis_table' (en option avec 'where') peut être utilisé ou l'option 'select', mais pas 'depuis_table' et 'select' en même temps."
+msgid ""
+"Copy a table. Either 'from_table' (optionally with 'where') can be used or "
+"'select' option, but not 'from_table' and 'select' at the same time."
+msgstr ""
+"Copier une table. Soit 'depuis_table' (en option avec 'where') peut être "
+"utilisé ou l'option 'select', mais pas 'depuis_table' et 'select' en même "
+"temps."
#: ../gui/wxpython/menustrings.py:875 ../gui/wxpython/menustrings.py:895
#: ../gui/wxpython/menustrings.py:1776 ../gui/wxpython/menustrings.py:1796
@@ -9817,7 +10700,9 @@
#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:1779
msgid "Test database driver, database must exist and set by db.connect."
-msgstr "Tester un pilote de base de données ; la base doit exister et être connectée via db.connect"
+msgstr ""
+"Tester un pilote de base de données ; la base doit exister et être connectée "
+"via db.connect"
#: ../gui/wxpython/menustrings.py:880 ../gui/wxpython/menustrings.py:1781
msgid "Query any table"
@@ -9825,7 +10710,8 @@
#: ../gui/wxpython/menustrings.py:881 ../gui/wxpython/menustrings.py:1782
msgid "Selects data from attribute table. Performs SQL query statement(s)."
-msgstr "Sélectionne des données d'une table attributaire. Exécute des requêtes SQL."
+msgstr ""
+"Sélectionne des données d'une table attributaire. Exécute des requêtes SQL."
#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1785
msgid "SQL statement"
@@ -9833,7 +10719,9 @@
#: ../gui/wxpython/menustrings.py:885 ../gui/wxpython/menustrings.py:1786
msgid "Executes any SQL statement. For SELECT statements use 'db.select'."
-msgstr "Exécute n'importe qu'elle requête SQL. Pour une requête SELECT utiliser 'db.select'."
+msgstr ""
+"Exécute n'importe qu'elle requête SQL. Pour une requête SELECT utiliser 'db."
+"select'."
#: ../gui/wxpython/menustrings.py:886 ../gui/wxpython/menustrings.py:1787
msgid "Vector database connections"
@@ -9844,8 +10732,12 @@
msgstr "Nouvelle table"
#: ../gui/wxpython/menustrings.py:888 ../gui/wxpython/menustrings.py:1789
-msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
-msgstr "Créée et connecte une table attributaire à une couche donnée d'une carte vecteur existante."
+msgid ""
+"Creates and connects a new attribute table to a given layer of an existing "
+"vector map."
+msgstr ""
+"Créée et connecte une table attributaire à une couche donnée d'une carte "
+"vecteur existante."
#: ../gui/wxpython/menustrings.py:889 ../gui/wxpython/menustrings.py:1790
msgid "Remove table"
@@ -9868,16 +10760,26 @@
msgstr "Ajouter des colonnes"
#: ../gui/wxpython/menustrings.py:894 ../gui/wxpython/menustrings.py:1795
-msgid "Adds one or more columns to the attribute table connected to a given vector map."
-msgstr "Ajoute une ou des colonnes à la table attributaire connectée à une carte vecteur donnée."
+msgid ""
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
+msgstr ""
+"Ajoute une ou des colonnes à la table attributaire connectée à une carte "
+"vecteur donnée."
#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1797
-msgid "Drops a column from the attribute table connected to a given vector map."
-msgstr "Supprime une colonne d'une table attributaire connectée à une carte vecteur donnée."
+msgid ""
+"Drops a column from the attribute table connected to a given vector map."
+msgstr ""
+"Supprime une colonne d'une table attributaire connectée à une carte vecteur "
+"donnée."
#: ../gui/wxpython/menustrings.py:898 ../gui/wxpython/menustrings.py:1799
-msgid "Renames a column in the attribute table connected to a given vector map."
-msgstr "Renomme une colonne dans une table attributaire connectée à une carte vecteur donnée."
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+"Renomme une colonne dans une table attributaire connectée à une carte "
+"vecteur donnée."
#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1800
msgid "Change values"
@@ -9885,7 +10787,9 @@
#: ../gui/wxpython/menustrings.py:900 ../gui/wxpython/menustrings.py:1801
msgid "Updates a column in the attribute table connected to a vector map."
-msgstr "Met à jour une colonne dans la table attributaire connectée à une carte vecteur."
+msgstr ""
+"Met à jour une colonne dans la table attributaire connectée à une carte "
+"vecteur."
#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1802
msgid "Drop row"
@@ -9893,15 +10797,20 @@
#: ../gui/wxpython/menustrings.py:902 ../gui/wxpython/menustrings.py:1803
msgid "Removes a vector feature from a vector map through attribute selection."
-msgstr "Supprime une entité d'une carte vecteur par sélection de ses attributs."
+msgstr ""
+"Supprime une entité d'une carte vecteur par sélection de ses attributs."
#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1804
msgid "Reconnect vectors to database"
msgstr "Reconnecter des cartes vecteur à une base de données"
#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:1805
-msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
-msgstr "Reconnecter les tables attributaires pour toutes les cartes vecteur du jeu de données actuel vers une nouvelle base de données."
+msgid ""
+"Reconnects attribute tables for all vector maps from the current mapset to a "
+"new database."
+msgstr ""
+"Reconnecter les tables attributaires pour toutes les cartes vecteur du jeu "
+"de données actuel vers une nouvelle base de données."
#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:1806
msgid "Set vector map - database connection"
@@ -9909,7 +10818,9 @@
#: ../gui/wxpython/menustrings.py:906 ../gui/wxpython/menustrings.py:1807
msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr "Afficher/définir les connexions base de données pour la table d'attributs de la carte vecteur."
+msgstr ""
+"Afficher/définir les connexions base de données pour la table d'attributs de "
+"la carte vecteur."
#: ../gui/wxpython/menustrings.py:907 ../gui/wxpython/menustrings.py:1808
msgid "&Temporal"
@@ -9929,7 +10840,8 @@
#: ../gui/wxpython/menustrings.py:914 ../gui/wxpython/menustrings.py:1815
msgid "Removes space time datasets from temporal database."
-msgstr "Supprimer des jeux de données temporels de la base de donénes temporelle."
+msgstr ""
+"Supprimer des jeux de données temporels de la base de donénes temporelle."
#: ../gui/wxpython/menustrings.py:915 ../gui/wxpython/menustrings.py:1816
msgid "Update metadata"
@@ -9945,7 +10857,9 @@
#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1819
msgid "Merges several space time datasets into a single space time dataset."
-msgstr "Fusionner plusieurs jeux de données temporels vers un seul jeu de données temporel."
+msgstr ""
+"Fusionner plusieurs jeux de données temporels vers un seul jeu de données "
+"temporel."
#: ../gui/wxpython/menustrings.py:919 ../gui/wxpython/menustrings.py:1820
msgid "Temporally shift"
@@ -9977,14 +10891,18 @@
#: ../gui/wxpython/menustrings.py:927 ../gui/wxpython/menustrings.py:1828
msgid "Registers raster, vector and raster3d maps in a space time datasets."
-msgstr "Enregistrer des cartes raster, vecteur et raster3D dans un jeu de données temporel."
+msgstr ""
+"Enregistrer des cartes raster, vecteur et raster3D dans un jeu de données "
+"temporel."
#: ../gui/wxpython/menustrings.py:928 ../gui/wxpython/menustrings.py:1829
msgid "Unregister maps from datasets"
msgstr ""
#: ../gui/wxpython/menustrings.py:929 ../gui/wxpython/menustrings.py:1830
-msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
+msgid ""
+"Unregisters raster, vector and raster3d maps from the temporal database or a "
+"specific space time dataset."
msgstr ""
#: ../gui/wxpython/menustrings.py:930 ../gui/wxpython/menustrings.py:1831
@@ -10029,7 +10947,8 @@
#: ../gui/wxpython/menustrings.py:940 ../gui/wxpython/menustrings.py:1841
#, fuzzy
-msgid "Imports a space time vector dataset from a GRASS GIS specific archive file."
+msgid ""
+"Imports a space time vector dataset from a GRASS GIS specific archive file."
msgstr "Importer des données vectorielles"
#: ../gui/wxpython/menustrings.py:941 ../gui/wxpython/menustrings.py:1842
@@ -10104,7 +11023,8 @@
msgstr "Interroger la carte vecteur depuis la table d'attributs"
#: ../gui/wxpython/menustrings.py:958 ../gui/wxpython/menustrings.py:1859
-msgid "Prints attributes of vector maps registered in a space time vector dataset."
+msgid ""
+"Prints attributes of vector maps registered in a space time vector dataset."
msgstr ""
#: ../gui/wxpython/menustrings.py:959 ../gui/wxpython/menustrings.py:1860
@@ -10114,7 +11034,9 @@
#: ../gui/wxpython/menustrings.py:960 ../gui/wxpython/menustrings.py:1861
#, fuzzy
-msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
+msgid ""
+"Creates/modifies the color table associated with each raster map of the "
+"space time raster dataset."
msgstr "Crée/modifie la table de couleur associée à une carte raster."
#: ../gui/wxpython/menustrings.py:961 ../gui/wxpython/menustrings.py:1862
@@ -10123,7 +11045,9 @@
#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1863
#, fuzzy
-msgid "Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets."
+msgid ""
+"Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
+"space time raster datasets."
msgstr "Importer une carte raster"
#: ../gui/wxpython/menustrings.py:963 ../gui/wxpython/menustrings.py:1864
@@ -10132,7 +11056,9 @@
#: ../gui/wxpython/menustrings.py:964 ../gui/wxpython/menustrings.py:1865
#, fuzzy
-msgid "Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets."
+msgid ""
+"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
+"datasets."
#: ../gui/wxpython/menustrings.py:965 ../gui/wxpython/menustrings.py:1866
@@ -10142,7 +11068,8 @@
#: ../gui/wxpython/menustrings.py:966 ../gui/wxpython/menustrings.py:1867
#, fuzzy
-msgid "Replaces gaps in a space time raster dataset with interpolated raster maps."
+msgid ""
+"Replaces gaps in a space time raster dataset with interpolated raster maps."
msgstr "Convertir une carte vecteur en carte raster."
#: ../gui/wxpython/menustrings.py:967 ../gui/wxpython/menustrings.py:1868
@@ -10156,8 +11083,11 @@
msgstr "Analyse de voisinage"
#: ../gui/wxpython/menustrings.py:969 ../gui/wxpython/menustrings.py:1870
-msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
-msgstr "Effectuer une analyse de voisinage pour chaque carte d'un jeu de données temporel."
+msgid ""
+"Performs a neighborhood analysis for each map in a space time raster dataset."
+msgstr ""
+"Effectuer une analyse de voisinage pour chaque carte d'un jeu de données "
+"temporel."
#: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1871
#, fuzzy
@@ -10166,8 +11096,12 @@
#: ../gui/wxpython/menustrings.py:971 ../gui/wxpython/menustrings.py:1872
#, fuzzy
-msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
-msgstr "Effectue différents algorithmes d'aggrégation depuis r.series ou a sous-jeu de cartes raster dans un jeu de données raster temporels."
+msgid ""
+"Performs different aggregation algorithms from r.series on all or a subset "
+"of raster maps in a space time raster dataset."
+msgstr ""
+"Effectue différents algorithmes d'aggrégation depuis r.series ou a sous-jeu "
+"de cartes raster dans un jeu de données raster temporels."
#: ../gui/wxpython/menustrings.py:972 ../gui/wxpython/menustrings.py:1873
#, fuzzy
@@ -10176,7 +11110,9 @@
#: ../gui/wxpython/menustrings.py:973 ../gui/wxpython/menustrings.py:1874
#, fuzzy
-msgid "Aggregates temporally the maps of a space time raster dataset by a user defined granularity."
+msgid ""
+"Aggregates temporally the maps of a space time raster dataset by a user "
+"defined granularity."
#: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1875
@@ -10186,8 +11122,12 @@
#: ../gui/wxpython/menustrings.py:975 ../gui/wxpython/menustrings.py:1876
#, fuzzy
-msgid "Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset."
-msgstr "Aggrégation de données d'un jeu de données raster temporel en utilisant le temps d'intervale d'un second jeu de données temporel."
+msgid ""
+"Aggregates data of an existing space time raster dataset using the time "
+"intervals of a second space time dataset."
+msgstr ""
+"Aggrégation de données d'un jeu de données raster temporel en utilisant le "
+"temps d'intervale d'un second jeu de données temporel."
#: ../gui/wxpython/menustrings.py:976 ../gui/wxpython/menustrings.py:1877
#, fuzzy
@@ -10201,26 +11141,39 @@
#: ../gui/wxpython/menustrings.py:978 ../gui/wxpython/menustrings.py:1879
#, fuzzy
-msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
-msgstr "Ãchantillone un jeu de données temporel d'entrée avec un échantillon de jeu de données temporel et affiche le résultat dans la sortie standard."
+msgid ""
+"Samples the input space time dataset(s) with a sample space time dataset and "
+"print the result to stdout."
+msgstr ""
+"Ãchantillone un jeu de données temporel d'entrée avec un échantillon de jeu "
+"de données temporel et affiche le résultat dans la sortie standard."
#: ../gui/wxpython/menustrings.py:979 ../gui/wxpython/menustrings.py:1880
#, fuzzy
msgid "Query raster dataset by vector points dataset"
+msgstr ""
#: ../gui/wxpython/menustrings.py:980 ../gui/wxpython/menustrings.py:1881
#, fuzzy
-msgid "Stores raster map values at spatial and temporal positions of vector points as vector attributes."
+msgid ""
+"Stores raster map values at spatial and temporal positions of vector points "
+"as vector attributes."
+msgstr ""
+"vecteur."
#: ../gui/wxpython/menustrings.py:981 ../gui/wxpython/menustrings.py:1882
msgid "Observe specific locations in raster dataset"
msgstr "Observer un secteur spécifique dans le jeu de données raster"
#: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1883
-msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
-msgstr "Observer un jeu de données spécifique dans un jeu de données raster temporel sur une période de temps en utilisant un vecteur de points."
+msgid ""
+"Observes specific locations in a space time raster dataset over a period of "
+"time using vector points."
+msgstr ""
+"Observer un jeu de données spécifique dans un jeu de données raster temporel "
+"sur une période de temps en utilisant un vecteur de points."
#: ../gui/wxpython/menustrings.py:984 ../gui/wxpython/menustrings.py:1885
#, fuzzy
@@ -10239,8 +11192,12 @@
#: ../gui/wxpython/menustrings.py:987 ../gui/wxpython/menustrings.py:1888
#, fuzzy
-msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
-msgstr "Calculer les statistiques univariées pour les cellules non nulles de la carte raster."
+msgid ""
+"Calculates univariate statistics from the non-null cells for each registered "
+"raster map of a space time raster dataset."
+msgstr ""
+"Calculer les statistiques univariées pour les cellules non nulles de la "
+"carte raster."
#: ../gui/wxpython/menustrings.py:988 ../gui/wxpython/menustrings.py:1889
#, fuzzy
@@ -10249,7 +11206,9 @@
#: ../gui/wxpython/menustrings.py:989 ../gui/wxpython/menustrings.py:1890
#, fuzzy
-msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
+msgid ""
+"Calculates univariate statistics of attributes for each registered vector "
+"map of a space time vector dataset"
#: ../gui/wxpython/menustrings.py:990 ../gui/wxpython/menustrings.py:1891
@@ -10259,8 +11218,12 @@
#: ../gui/wxpython/menustrings.py:991 ../gui/wxpython/menustrings.py:1892
#, fuzzy
-msgid "Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset."
+msgid ""
+"3D raster map of a space time 3D raster dataset."
+msgstr ""
+"carte raster."
#: ../gui/wxpython/menustrings.py:992 ../gui/wxpython/menustrings.py:1893
#, fuzzy
@@ -10575,8 +11538,12 @@
#: ../gui/wxpython/animation/controller.py:245
#: ../gui/wxpython/animation/dialogs.py:725
-msgid "More animations are using one window. Please select different window for each animation."
-msgstr "Plusieurs animations utilisent la même fenêtre. Merci de sélectionner une fenêtre différente pour chaque animation."
+msgid ""
+"More animations are using one window. Please select different window for "
+"each animation."
+msgstr ""
+"Plusieurs animations utilisent la même fenêtre. Merci de sélectionner une "
+"fenêtre différente pour chaque animation."
#: ../gui/wxpython/animation/controller.py:404
#, fuzzy
@@ -10669,7 +11636,8 @@
#: ../gui/wxpython/animation/toolbars.py:50
msgid "Add space-time dataset or series of map layers for animation"
-msgstr "Ajouter un jeu de données temporel ou une série de cartes pour l'animation"
+msgstr ""
+"Ajouter un jeu de données temporel ou une série de cartes pour l'animation"
#: ../gui/wxpython/animation/nviztask.py:42 ../gui/wxpython/lmgr/frame.py:1224
#, python-format
@@ -10839,7 +11807,8 @@
"For 3D animation, please select only one space-time dataset\n"
"or one series of map layers."
msgstr ""
-"Pour une animation 3D, merci de ne sélectionner qu'unn seul jeu de données temporel\n"
+"Pour une animation 3D, merci de ne sélectionner qu'unn seul jeu de données "
+"temporel\n"
"ou une série de cartes."
#: ../gui/wxpython/animation/dialogs.py:369
@@ -10859,7 +11828,8 @@
#: ../gui/wxpython/animation/dialogs.py:394
msgid "Choose workspace file to import 3D view parameters"
-msgstr "Choisir le fichier d'espace de travail pour l'import des paramètres de vue 3D"
+msgstr ""
+"Choisir le fichier d'espace de travail pour l'import des paramètres de vue 3D"
#: ../gui/wxpython/animation/dialogs.py:401
#, fuzzy
@@ -10888,7 +11858,8 @@
#: ../gui/wxpython/animation/dialogs.py:439
msgid "N-S/E-W distances in map units used to gradually reduce region."
-msgstr "Distances N-S/E-O en unité de carte pour réduire graduellement la région."
+msgstr ""
+"Distances N-S/E-O en unité de carte pour réduire graduellement la région."
#: ../gui/wxpython/animation/dialogs.py:446
msgid "N-S:"
@@ -10900,7 +11871,8 @@
#: ../gui/wxpython/animation/dialogs.py:541
msgid "Only one series or space-time dataset is accepted for 3D mode."
-msgstr "Seulement une série ou jeu de données temporel est accepté dans le mode 3D."
+msgstr ""
+"Seulement une série ou jeu de données temporel est accepté dans le mode 3D."
#: ../gui/wxpython/animation/dialogs.py:549
#, fuzzy
@@ -10967,14 +11939,16 @@
msgstr "Choisir un fichier"
#: ../gui/wxpython/animation/dialogs.py:863
-#: ../gui/wxpython/mapwin/decorations.py:335
+#: ../gui/wxpython/mapwin/decorations.py:338
#, fuzzy
msgid "Text:"
msgstr "Texte"
#: ../gui/wxpython/animation/dialogs.py:876
msgid "Placement as percentage of screen coordinates (X: 0, Y: 0 is top left):"
-msgstr "Positionnement en pourcentage des coordonnées de l'écran (X : 0, Y : 0 est en haut à gauche) :"
+msgstr ""
+"Positionnement en pourcentage des coordonnées de l'écran (X : 0, Y : 0 est "
+"en haut à gauche) :"
#: ../gui/wxpython/animation/dialogs.py:899
#, fuzzy
@@ -11040,7 +12014,8 @@
"Please install it first and make sure\n"
"it's in the PATH variable."
msgstr ""
-"Le programme 'ffmpeg' n'a pas été trouvé.Merci de l'installer et de vérifier\n"
+"Le programme 'ffmpeg' n'a pas été trouvé.Merci de l'installer et de "
+"vérifier\n"
"qu'il ets dans le PATH."
#: ../gui/wxpython/animation/dialogs.py:988
@@ -11058,8 +12033,12 @@
msgstr "Options de création :"
#: ../gui/wxpython/animation/dialogs.py:996
-msgid "Consider adding '-sameq' or '-qscale 1' if not satisfied with video quality. Options depend on ffmpeg version."
-msgstr "Ajouter '-sameq' ou '-qscale 1' si vous n'êtes pas satisfaits de la qualité de la vidéo. Les options dépendent de la version de ffmpeg."
+msgid ""
+"Consider adding '-sameq' or '-qscale 1' if not satisfied with video quality. "
+"Options depend on ffmpeg version."
+msgstr ""
+"Ajouter '-sameq' ou '-qscale 1' si vous n'êtes pas satisfaits de la qualité "
+"de la vidéo. Les options dépendent de la version de ffmpeg."
#: ../gui/wxpython/animation/dialogs.py:1018
#, python-format
@@ -11163,8 +12142,12 @@
#: ../gui/wxpython/animation/dialogs.py:1535
#, fuzzy
-msgid "Click and then press key up or down to preview different date and time formats. Type custom format string."
-msgstr "Cliquez et appuyer sur les touches haut et bas pour voir différents formats de date et heure."
+msgid ""
+"Click and then press key up or down to preview different date and time "
+"formats. Type custom format string."
+msgstr ""
+"Cliquez et appuyer sur les touches haut et bas pour voir différents formats "
+"de date et heure."
#: ../gui/wxpython/animation/dialogs.py:1544
msgid "Learn more about formatting options"
@@ -11177,8 +12160,13 @@
#: ../gui/wxpython/animation/dialogs.py:1554
#, fuzzy
-msgid "When animating instant-based data which have irregular timestamps you can display 'no data frame' (checked option) or keep last frame."
-msgstr "Lorsque l'animation contient des données avec un pas de temps irrégulier, vous pouvez afficher 'pas d'image' (option cochée) ou garder la dernière image."
+msgid ""
+"When animating instant-based data which have irregular timestamps you can "
+"display 'no data frame' (checked option) or keep last frame."
+msgstr ""
+"Lorsque l'animation contient des données avec un pas de temps irrégulier, "
+"vous pouvez afficher 'pas d'image' (option cochée) ou garder la dernière "
+"image."
#: ../gui/wxpython/animation/dialogs.py:1576
#, fuzzy
@@ -11201,17 +12189,28 @@
msgstr "Carte vectorielle <%s> non trouvée"
#: ../gui/wxpython/animation/temporal_manager.py:105
-msgid "It is not allowed to display data with different temporal types (absolute and relative)."
-msgstr "Il n'est pas permis d'afficher des données avec des types temporels différents (absolu et reatif)."
+msgid ""
+"It is not allowed to display data with different temporal types (absolute "
+"and relative)."
+msgstr ""
+"Il n'est pas permis d'afficher des données avec des types temporels "
+"différents (absolu et reatif)."
#: ../gui/wxpython/animation/temporal_manager.py:119
#, python-format
msgid "It is not allowed to display data with different units (%s)."
-msgstr "Il n'est pas permis d'afficher des donénes avec des unités différentes (%s)."
+msgstr ""
+"Il n'est pas permis d'afficher des donénes avec des unités différentes (%s)."
#: ../gui/wxpython/animation/temporal_manager.py:130
-msgid "You are going to display data with different temporal types of maps (interval and point). It is recommended to use data of one temporal type to avoid confusion."
-msgstr "Vous êtes sur le point d'afficher des données avec des types de cartes temporelles différents (intervalle et ponctuel). Il est recommandé d'utiliser un seul tye temporel pour éviter la confusion."
+msgid ""
+"You are going to display data with different temporal types of maps "
+"(interval and point). It is recommended to use data of one temporal type to "
+"avoid confusion."
+msgstr ""
+"Vous êtes sur le point d'afficher des données avec des types de cartes "
+"temporelles différents (intervalle et ponctuel). Il est recommandé "
+"d'utiliser un seul tye temporel pour éviter la confusion."
#: ../gui/wxpython/animation/temporal_manager.py:228
#: ../gui/wxpython/animation/utils.py:69 ../gui/wxpython/animation/utils.py:75
@@ -11274,24 +12273,39 @@
msgstr "Le nombre de cartes des jeux de données temporels doiit être le même."
#: ../gui/wxpython/animation/utils.py:182
-msgid "The temporal type (absolute/relative) of space-time datasets has to be the same."
-msgstr "Le type temporel (absolut/relatif) des jeux de données temporels doit être le même."
+msgid ""
+"The temporal type (absolute/relative) of space-time datasets has to be the "
+"same."
+msgstr ""
+"Le type temporel (absolut/relatif) des jeux de données temporels doit être "
+"le même."
#: ../gui/wxpython/animation/utils.py:186
-msgid "The map type (point/interval) of space-time datasets has to be the same."
-msgstr "Le type de carte (ponctuel/intervalle) des jeux de donénes temporels doit être le même."
+msgid ""
+"The map type (point/interval) of space-time datasets has to be the same."
+msgstr ""
+"Le type de carte (ponctuel/intervalle) des jeux de donénes temporels doit "
+"être le même."
#: ../gui/wxpython/animation/utils.py:190
-msgid "The temporal extents of maps in space-time datasets have to be the same."
-msgstr "L'étendue temporelle des cartes des jeux de données temporels doit être la même."
+msgid ""
+"The temporal extents of maps in space-time datasets have to be the same."
+msgstr ""
+"L'étendue temporelle des cartes des jeux de données temporels doit être la "
+"même."
#: ../gui/wxpython/animation/utils.py:198
msgid "The number of maps to animate has to be the same for each map series."
-msgstr "Le nombre de cartes à animer doit être le même pour chaque série de cartes."
+msgstr ""
+"Le nombre de cartes à animer doit être le même pour chaque série de cartes."
#: ../gui/wxpython/animation/utils.py:202
-msgid "The number of maps to animate has to be the same as the number of maps in temporal dataset."
-msgstr "Le nombre de cartes à animer doit être le même que le nombre de cartes dans le jeu de données temporel."
+msgid ""
+"The number of maps to animate has to be the same as the number of maps in "
+"temporal dataset."
+msgstr ""
+"Le nombre de cartes à animer doit être le même que le nombre de cartes dans "
+"le jeu de données temporel."
#: ../gui/wxpython/modules/mcalc_builder.py:53
msgid "GRASS GIS Raster Map Calculator"
@@ -11713,7 +12727,9 @@
#: ../gui/wxpython/modules/colorrules.py:409
msgid "Type filename or click to choose file and load color table"
-msgstr "Entrer un nom de fichier ou cliquer sur Parcourir pour charger une table de couleur"
+msgstr ""
+"Entrer un nom de fichier ou cliquer sur Parcourir pour charger une table de "
+"couleur"
#: ../gui/wxpython/modules/colorrules.py:415
msgid "Choose file to save color table"
@@ -11721,7 +12737,9 @@
#: ../gui/wxpython/modules/colorrules.py:416
msgid "Type filename or click to choose file and save color table"
-msgstr "Entrer un nom de fichier ou cliquer sur Parcourir pour enregistrer une table de couleur"
+msgstr ""
+"Entrer un nom de fichier ou cliquer sur Parcourir pour enregistrer une table "
+"de couleur"
#: ../gui/wxpython/modules/colorrules.py:424
#, fuzzy
@@ -11752,7 +12770,9 @@
#: ../gui/wxpython/modules/colorrules.py:527
msgid "Show preview of map (current Map Display extent is used)."
-msgstr "Affiche un aperçu de la carte (l'étendue de la fenêtre de cartes actuelle sera utilisée)."
+msgstr ""
+"Affiche un aperçu de la carte (l'étendue de la fenêtre de cartes actuelle "
+"sera utilisée)."
#: ../gui/wxpython/modules/colorrules.py:560
#: ../gui/wxpython/modules/colorrules.py:1717
@@ -11766,7 +12786,8 @@
#: ../gui/wxpython/modules/colorrules.py:720
#, python-format
msgid "Invalid rule value '%s'. Unable to apply color table."
-msgstr "Valeur '%s' de règle non valide. Impossible d'appliquer la table de couleur."
+msgstr ""
+"Valeur '%s' de règle non valide. Impossible d'appliquer la table de couleur."
#: ../gui/wxpython/modules/colorrules.py:798
msgid "Create new color table for raster map"
@@ -11783,7 +12804,9 @@
#: ../gui/wxpython/modules/colorrules.py:881
#, python-format
msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
-msgstr "Saisir les valeurs de catégorie ou le pourcentage (%(range)s = %(min)d-%(max)d)"
+msgstr ""
+"Saisir les valeurs de catégorie ou le pourcentage (%(range)s = %(min)d-"
+"%(max)d)"
#: ../gui/wxpython/modules/colorrules.py:969
msgid "Create new color rules for vector map"
@@ -11850,8 +12873,13 @@
#: ../gui/wxpython/modules/colorrules.py:1140
#, python-format
-msgid "Database connection for vector map <%s> is not defined in DB file. Do you want to create and connect new attribute table?"
-msgstr "La connexion à une base de données pour la carte vecteur <%s> n'est pas définie dans le fichier DB. Voulez-vous créer et connecter une nouvelle table d'attributs ?"
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file. Do you "
+"want to create and connect new attribute table?"
+msgstr ""
+"La connexion à une base de données pour la carte vecteur <%s> n'est pas "
+"définie dans le fichier DB. Voulez-vous créer et connecter une nouvelle "
+"table d'attributs ?"
#: ../gui/wxpython/modules/colorrules.py:1143
msgid "No database connection defined"
@@ -11859,8 +12887,12 @@
#: ../gui/wxpython/modules/colorrules.py:1215
#, python-format
-msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute table cannot be edited."
-msgstr "La carte sélectionnée <%(map)s> n'est pas dans le jeux de cartes courant <%(mapset)s>. La table d'attributs ne peut pas être modifiée."
+msgid ""
+"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
+"table cannot be edited."
+msgstr ""
+"La carte sélectionnée <%(map)s> n'est pas dans le jeux de cartes courant <"
+"%(mapset)s>. La table d'attributs ne peut pas être modifiée."
#: ../gui/wxpython/modules/colorrules.py:1368
#, python-format
@@ -11873,8 +12905,13 @@
#: ../gui/wxpython/modules/colorrules.py:1461
#, python-format
-msgid "Number of loaded records reached %d, displaying all the records will be time-consuming and may lead to computer freezing, do you still want to continue?"
-msgstr "Le nombre d'enregistrements est de %d, afficher tous les enregistrements serait très long et peut provoquer un gel de l'ordinateur. Voulez-vous continuer ?"
+msgid ""
+"Number of loaded records reached %d, displaying all the records will be time-"
+"consuming and may lead to computer freezing, do you still want to continue?"
+msgstr ""
+"Le nombre d'enregistrements est de %d, afficher tous les enregistrements "
+"serait très long et peut provoquer un gel de l'ordinateur. Voulez-vous "
+"continuer ?"
#: ../gui/wxpython/modules/colorrules.py:1465
msgid "Too many records"
@@ -11921,7 +12958,9 @@
#: ../gui/wxpython/modules/extensions.py:96
msgid "Fetch list of available modules from GRASS Addons SVN repository"
-msgstr "Récupérer la liste des modules disponibles depuis le dépôt svn des GRASS AddOns"
+msgstr ""
+"Récupérer la liste des modules disponibles depuis le dépôt svn des GRASS "
+"AddOns"
#: ../gui/wxpython/modules/extensions.py:100
msgid "&Install"
@@ -11941,7 +12980,9 @@
#: ../gui/wxpython/modules/extensions.py:191
msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
-msgstr "Récupération de la liste des modules à partir du svn GRASS AddOns (soyez patient)..."
+msgstr ""
+"Récupération de la liste des modules à partir du svn GRASS AddOns (soyez "
+"patient)..."
#: ../gui/wxpython/modules/extensions.py:213
#, fuzzy
@@ -12108,8 +13149,8 @@
msgid "Print preview"
msgstr "Aperçu avant impression"
-#: ../gui/wxpython/mapwin/decorations.py:174
-#: ../gui/wxpython/mapwin/decorations.py:221
+#: ../gui/wxpython/mapwin/decorations.py:177
+#: ../gui/wxpython/mapwin/decorations.py:224
#, fuzzy
msgid ""
"Please install Python Imaging Library (PIL)\n"
@@ -12118,16 +13159,16 @@
"Merci d'installer la librairie Pyhton Imaging Library (PIL)\n"
"pour un meilleur contrôle de la légende et des décorations."
-#: ../gui/wxpython/mapwin/decorations.py:326
+#: ../gui/wxpython/mapwin/decorations.py:329
msgid "Show text object"
msgstr "Montrer l'objet texte"
-#: ../gui/wxpython/mapwin/decorations.py:351
+#: ../gui/wxpython/mapwin/decorations.py:354
#: ../gui/wxpython/nviz/tools.py:1011
msgid "Rotation:"
msgstr "Rotation :"
-#: ../gui/wxpython/mapwin/decorations.py:379
+#: ../gui/wxpython/mapwin/decorations.py:382
msgid ""
"Drag text with mouse in pointer mode to position.\n"
"Double-click to change options"
@@ -12232,8 +13273,12 @@
#: ../gui/wxpython/mapwin/analysis.py:233
#: ../gui/wxpython/mapwin/analysis.py:342
#, python-format
-msgid "Click and drag with left mouse button to measure.%sDouble click with left button to clear."
-msgstr "Cliquer et glisser avec le bouton gauche de la souris pour mesurer. %s Double-cliquer avec le bouton gauche pour annuler."
+msgid ""
+"Click and drag with left mouse button to measure.%sDouble click with left "
+"button to clear."
+msgstr ""
+"Cliquer et glisser avec le bouton gauche de la souris pour mesurer. %s "
+"Double-cliquer avec le bouton gauche pour annuler."
#: ../gui/wxpython/mapwin/analysis.py:239
msgid "Measuring distance"
@@ -12391,8 +13436,11 @@
msgstr "Mode survol"
#: ../gui/wxpython/mapdisp/toolbars.py:62
-msgid "Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
-msgstr "Déplacer avec la souris, appuyer sur Ctrl pour les différents modes, ou Maj pour accélérer"
+msgid ""
+"Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
+msgstr ""
+"Déplacer avec la souris, appuyer sur Ctrl pour les différents modes, ou Maj "
+"pour accélérer"
#: ../gui/wxpython/mapdisp/toolbars.py:64
msgid "Click mouse to zoom"
@@ -12421,8 +13469,15 @@
msgstr "La numérisation de vector n'est pas disponible"
#: ../gui/wxpython/mapdisp/toolbars.py:109
-msgid "Note that the wxGUI's vector digitizer is currently disabled (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"v.digit\" from the Develop Vector menu."
-msgstr "Notez que le module de digitalisation de wxGUI est actuellement indisponible (en espérant que cela soit prochainement résolu). Merci de garder un Åil sur les mises à jour de GRASS. En attendant, vous pouvez utiliser le module \"v.digit\", accessible depuis le menu Vecteur."
+msgid ""
+"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
+"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
+"In the meantime you can use \"v.digit\" from the Develop Vector menu."
+msgstr ""
+"Notez que le module de digitalisation de wxGUI est actuellement indisponible "
+"(en espérant que cela soit prochainement résolu). Merci de garder un Åil sur "
+"les mises à jour de GRASS. En attendant, vous pouvez utiliser le module \"v."
+"digit\", accessible depuis le menu Vecteur."
#: ../gui/wxpython/mapdisp/gprint.py:150
msgid ""
@@ -12469,32 +13524,54 @@
msgstr "Afficher les limites de calculs"
#: ../gui/wxpython/mapdisp/statusbar.py:443
-msgid "Show/hide computational region extent (set with g.region). Display region drawn as a blue box inside the computational region, computational region inside a display region as a red box)."
-msgstr "Afficher/cacher les limites de la région de calcul (définie avec g.region). Région de l'affichage dessinée comme rectangle bleu à l'intérieur de la région de calcul, région de calcul comme rectangle rouge à l'intérieur de la région de l'affichage."
+msgid ""
+"Show/hide computational region extent (set with g.region). Display region "
+"drawn as a blue box inside the computational region, computational region "
+"inside a display region as a red box)."
+msgstr ""
+"Afficher/cacher les limites de la région de calcul (définie avec g.region). "
+"Région de l'affichage dessinée comme rectangle bleu à l'intérieur de la "
+"région de calcul, région de calcul comme rectangle rouge à l'intérieur de la "
+"région de l'affichage."
#: ../gui/wxpython/mapdisp/statusbar.py:492
msgid "Display mode"
msgstr "Mode d'affichage"
#: ../gui/wxpython/mapdisp/statusbar.py:499
-msgid "Align region extent based on display size from center point. Default value for new map displays can be set up in 'User GUI settings' dialog."
-msgstr "Aligner l'emprise de la région sur la taille de l'affichage depuis le point central. La valeur par défaut pour les nouveaux affichages peut être définie dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
+msgid ""
+"Align region extent based on display size from center point. Default value "
+"for new map displays can be set up in 'User GUI settings' dialog."
+msgstr ""
+"Aligner l'emprise de la région sur la taille de l'affichage depuis le point "
+"central. La valeur par défaut pour les nouveaux affichages peut être définie "
+"dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
#: ../gui/wxpython/mapdisp/statusbar.py:532
msgid "Display resolution"
msgstr "Résolution de l'affichage"
#: ../gui/wxpython/mapdisp/statusbar.py:538
-msgid "Constrain display resolution to computational region settings. Default value for new map displays can be set up in 'User GUI settings' dialog."
-msgstr "Contraindre la résolution d'affichage aux paramètres de la région calculée. La valeur par défaut pour les nouveaux affichages de cartes peut être définie dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
+msgid ""
+"Constrain display resolution to computational region settings. Default value "
+msgstr ""
+"Contraindre la résolution d'affichage aux paramètres de la région calculée. "
+"La valeur par défaut pour les nouveaux affichages de cartes peut être "
+"définie dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
#: ../gui/wxpython/mapdisp/statusbar.py:575
msgid "Map scale"
msgstr "Ãchelle de la carte"
#: ../gui/wxpython/mapdisp/statusbar.py:589
-msgid "As everyone's monitors and resolutions are set differently these values are not true map scales, but should get you into the right neighborhood."
-msgstr "Ãtant donné que tous les moniteurs et les résolutions sont réglés différemment, ces valeurs ne sont pas des échelles réelles mais restent proches de la réalité."
+msgid ""
+"As everyone's monitors and resolutions are set differently these values are "
+"not true map scales, but should get you into the right neighborhood."
+msgstr ""
+"Ãtant donné que tous les moniteurs et les résolutions sont réglés "
+"différemment, ces valeurs ne sont pas des échelles réelles mais restent "
+"proches de la réalité."
#: ../gui/wxpython/mapdisp/statusbar.py:642
msgid "Go to"
@@ -12518,8 +13595,13 @@
msgstr "Utiliser une projection définie"
#: ../gui/wxpython/mapdisp/statusbar.py:787
-msgid "Reproject coordinates displayed in the statusbar. Projection can be defined in GUI preferences dialog (tab 'Projection')"
-msgstr "Re-projeter les coordonnées affichées dans la barre d'état. La projection peut être définie dans les préférences de l'interface utilisateur (onglet 'Affichage de la carte')"
+msgid ""
+"Reproject coordinates displayed in the statusbar. Projection can be defined "
+"in GUI preferences dialog (tab 'Projection')"
+msgstr ""
+"Re-projeter les coordonnées affichées dans la barre d'état. La projection "
+"peut être définie dans les préférences de l'interface utilisateur (onglet "
+"'Affichage de la carte')"
#: ../gui/wxpython/mapdisp/statusbar.py:812
msgid "MASK"
@@ -12548,8 +13630,11 @@
#: ../gui/wxpython/mapdisp/frame.py:254
#, python-format
-msgid "GRASS GIS %(version)s Map Display: %(id)s - Location: %(loc)s@%(mapset)s"
-msgstr "SIG GRASS %(version)s - Fenêtre de cartes : %(id)s - Secteur : %(loc)s@%(mapset)s"
+msgid ""
+"GRASS GIS %(version)s Map Display: %(id)s - Location: %(loc)s@%(mapset)s"
+msgstr ""
+"SIG GRASS %(version)s - Fenêtre de cartes : %(id)s - Secteur : %(loc)s@"
+"%(mapset)s"
#: ../gui/wxpython/mapdisp/frame.py:272 ../gui/wxpython/lmgr/layertree.py:909
#, python-format
@@ -12616,12 +13701,17 @@
#: ../gui/wxpython/mapdisp/frame.py:823 ../gui/wxpython/mapswipe/frame.py:630
msgid "No raster or vector map layer selected for querying."
-msgstr "Pas de carte rater ou couche de carte vecteur sélectionnée pour interrogation."
+msgstr ""
+"Pas de carte rater ou couche de carte vecteur sélectionnée pour "
+"interrogation."
#: ../gui/wxpython/mapdisp/frame.py:878
#, python-brace-format
-msgid "Failed to query vector map(s) <{maps}>. Check database settings and topology."
-msgstr "L'interrogation de la carte vecteur <{maps}> a échoué. Vérifier les paramètres de base de données et de topologie."
+msgid ""
+"Failed to query vector map(s) <{maps}>. Check database settings and topology."
+msgstr ""
+"L'interrogation de la carte vecteur <{maps}> a échoué. Vérifier les "
+"paramètres de base de données et de topologie."
#: ../gui/wxpython/mapdisp/frame.py:1354 ../gui/wxpython/gcp/mapdisplay.py:463
msgid "Zoom to default region"
@@ -12671,7 +13761,8 @@
#: ../gui/wxpython/nviz/tools.py:247
msgid "Adjusts the distance and angular perspective of the image viewpoint"
-msgstr "Ajuster la distance et l'angle de perspective de l'image au point de vue"
+msgstr ""
+"Ajuster la distance et l'angle de perspective de l'image au point de vue"
#: ../gui/wxpython/nviz/tools.py:252 ../gui/wxpython/nviz/preferences.py:69
msgid "Perspective:"
@@ -12686,8 +13777,12 @@
msgstr "Inclinaison :"
#: ../gui/wxpython/nviz/tools.py:271
-msgid "Adjusts the viewing height above the surface (angle of view automatically adjusts to maintain the same center of view)"
-msgstr "Ajuster la hauteur de vue (l'angle de vue s'ajuste automatiquement pour garder le même centre de la vue)"
+msgid ""
+"Adjusts the viewing height above the surface (angle of view automatically "
+"adjusts to maintain the same center of view)"
+msgstr ""
+"Ajuster la hauteur de vue (l'angle de vue s'ajuste automatiquement pour "
+"garder le même centre de la vue)"
#: ../gui/wxpython/nviz/tools.py:276
msgid "Adjusts the relative height of features above the plane of the surface"
@@ -12706,8 +13801,12 @@
msgstr "curseur"
#: ../gui/wxpython/nviz/tools.py:309
-msgid "Allows you to select a point on the surface that becomes the new center of view. Click on the button and then on the surface."
-msgstr "Permet de sélectionner un point sur la surface qui deviendra le nouveau centre de la vue. Cliquer sur le bouton puis sur la surface."
+msgid ""
+"Allows you to select a point on the surface that becomes the new center of "
+"view. Click on the button and then on the surface."
+msgstr ""
+"Permet de sélectionner un point sur la surface qui deviendra le nouveau "
+"centre de la vue. Cliquer sur le bouton puis sur la surface."
#: ../gui/wxpython/nviz/tools.py:315
msgid "center"
@@ -12722,8 +13821,12 @@
msgstr "nord"
#: ../gui/wxpython/nviz/tools.py:325
-msgid "Sets the viewer directly over the scene's center position. This top view orients approximately north south."
-msgstr "Définir la vue directement au dessus du centre de la scène. Cette vue du haut est orientée approximativement nord-sud."
+msgid ""
+"Sets the viewer directly over the scene's center position. This top view "
+"orients approximately north south."
+msgstr ""
+"Définir la vue directement au dessus du centre de la scène. Cette vue du "
+"haut est orientée approximativement nord-sud."
#: ../gui/wxpython/nviz/tools.py:329
msgid "reset"
@@ -12738,8 +13841,13 @@
msgstr "Apparence de l'image"
#: ../gui/wxpython/nviz/tools.py:392
-msgid "Press 'Record' button and start changing the view. It is recommended to use fly-through mode (Map Display toolbar) to achieve smooth motion."
-msgstr "Appuyez sur le bouton 'Enregistrer' et commencez à changer la vue. Il est recommandé d'utiliser le mode survol (barre d'outils d'affichage) pour obtenir un déplacement fluide."
+msgid ""
+"Press 'Record' button and start changing the view. It is recommended to use "
+"fly-through mode (Map Display toolbar) to achieve smooth motion."
+msgstr ""
+"Appuyez sur le bouton 'Enregistrer' et commencez à changer la vue. Il est "
+"recommandé d'utiliser le mode survol (barre d'outils d'affichage) pour "
+"obtenir un déplacement fluide."
#: ../gui/wxpython/nviz/tools.py:403
msgid "Record"
@@ -12770,8 +13878,11 @@
msgstr "Choisir un répertoire pour les images"
#: ../gui/wxpython/nviz/tools.py:490
-msgid "Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
-msgstr "Les noms de fichiers générés ressembleront à ceci : prefix_1.ppm, prefix_2.ppm, ..."
+msgid ""
+"Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
+msgstr ""
+"Les noms de fichiers générés ressembleront à ceci : prefix_1.ppm, prefix_2."
+"ppm, ..."
#: ../gui/wxpython/nviz/tools.py:546 ../gui/wxpython/nviz/tools.py:1862
#: ../gui/wxpython/nviz/preferences.py:361
@@ -12958,8 +14069,12 @@
msgstr "Effectue une rotation sur l'axe horizontal du plan de coupe"
#: ../gui/wxpython/nviz/tools.py:1045
-msgid "Sets the Z coordinate of the current cutting plane (only meaningful when tilt is not 0)"
-msgstr "Définit la coordonnée Z du plan de coupe actuel (n'a de sens que si l'inclinaison n'est pas à 0)"
+msgid ""
+"Sets the Z coordinate of the current cutting plane (only meaningful when "
+"tilt is not 0)"
+msgstr ""
+"Définit la coordonnée Z du plan de coupe actuel (n'a de sens que si "
+"l'inclinaison n'est pas à 0)"
#: ../gui/wxpython/nviz/tools.py:1114
msgid "Fine resolution:"
@@ -13150,7 +14265,9 @@
#: ../gui/wxpython/nviz/tools.py:2090
msgid "Do you want to record new animation without saving the previous one?"
-msgstr "Voulez-vous enregistrer une nouvelle animation sans enregistrer la précédente ?"
+msgstr ""
+"Voulez-vous enregistrer une nouvelle animation sans enregistrer la "
+"précédente ?"
#: ../gui/wxpython/nviz/tools.py:2093
msgid "Animation already axists"
@@ -13324,8 +14441,12 @@
msgstr "Ajuster la distance et la direction au point de vue"
#: ../gui/wxpython/nviz/tools.py:5175
-msgid "Adjusts the light direction. Click and drag the puck to change the light direction."
-msgstr "Ajuster la direction de la lumière. Cliquez et déplacez le point pour changer l'origine de la lumière."
+msgid ""
+"Adjusts the light direction. Click and drag the puck to change the light "
+"direction."
+msgstr ""
+"Ajuster la direction de la lumière. Cliquez et déplacez le point pour "
+"changer l'origine de la lumière."
#: ../gui/wxpython/nviz/preferences.py:32
msgid "3D view default settings"
@@ -13333,7 +14454,8 @@
#: ../gui/wxpython/nviz/preferences.py:49
msgid "Revert settings to default, changes are not applied"
-msgstr "Revenir aux paramètres par défaut, les changements ne seront pas appliqués"
+msgstr ""
+"Revenir aux paramètres par défaut, les changements ne seront pas appliqués"
#: ../gui/wxpython/nviz/preferences.py:72
#: ../gui/wxpython/nviz/preferences.py:135
@@ -13398,13 +14520,22 @@
msgstr "Paramètres de vue 3D enregistrés dans le fichier <%s>."
#: ../gui/wxpython/nviz/mapwindow.py:224
-msgid "Opening 3D view was not successful. Please try to change the value of depth buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
-msgstr "Le lancement de la vue 3D a échoué. Essayez de modifier la taille du tampon d'affichage dans Paramètres > Préférences > onglet Fenêtre de carte > Paramètres d'affichage avancés puis redémarrer l'interface."
+msgid ""
+"Opening 3D view was not successful. Please try to change the value of depth "
+"buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
+msgstr ""
+"Le lancement de la vue 3D a échoué. Essayez de modifier la taille du tampon "
+"d'affichage dans Paramètres > Préférences > onglet Fenêtre de carte > "
+"Paramètres d'affichage avancés puis redémarrer l'interface."
#: ../gui/wxpython/nviz/mapwindow.py:559
#, python-format
-msgid "Image is too large, your OpenGL implementation supports maximum texture size %d px."
-msgstr "L'image est trop grande, votre installation OpenGL supporte une taille de texture d'un maximum de %d pixels."
+msgid ""
+"Image is too large, your OpenGL implementation supports maximum texture size "
+"%d px."
+msgstr ""
+"L'image est trop grande, votre installation OpenGL supporte une taille de "
+"texture d'un maximum de %d pixels."
# Easting et Northing sont ici traduits resp. Abscisse et Ordonnée, désignant plutôt des valeurs numériques que des directions cardinales.
#: ../gui/wxpython/nviz/mapwindow.py:1057
@@ -13522,8 +14653,16 @@
"%s"
#: ../gui/wxpython/nviz/wxnviz.py:32 ../gui/wxpython/wxplot/profile.py:34
-msgid "This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries."
-msgstr "Ce module requiert le module NumPy, qui n'a pas pu être importé. Il n'est probablement pas installé (ne fait pas partie de la distribution standard Python). Voir le site Numeric Python (http://numpy.scipy.org) pour télécharger les binaires ou le code source."
+msgid ""
+"This module requires the NumPy module, which could not be imported. It "
+"probably is not installed (it's not part of the standard Python "
+"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
+"information on downloading source or binaries."
+msgstr ""
+"Ce module requiert le module NumPy, qui n'a pas pu être importé. Il n'est "
+"probablement pas installé (ne fait pas partie de la distribution standard "
+"Python). Voir le site Numeric Python (http://numpy.scipy.org) pour "
+"télécharger les binaires ou le code source."
#: ../gui/wxpython/nviz/wxnviz.py:482 ../gui/wxpython/nviz/wxnviz.py:494
#, python-format
@@ -13615,7 +14754,8 @@
#: ../gui/wxpython/wxplot/profile.py:342
msgid "Choose prefix for file(s) where to save profile values..."
-msgstr "Choisir le préfixe des fichiers où enregistrer les valeurs du profil ..."
+msgstr ""
+"Choisir le préfixe des fichiers où enregistrer les valeurs du profil ..."
#: ../gui/wxpython/wxplot/profile.py:344
msgid "Comma separated value (*.csv)|*.csv"
@@ -13743,7 +14883,9 @@
#: ../gui/wxpython/wxplot/dialogs.py:687
#: ../gui/wxpython/wxplot/dialogs.py:1135
msgid "Apply changes for the current session and close dialog"
-msgstr "Appliquer les changements pour la session courante et fermer la boite de dialogue"
+msgstr ""
+"Appliquer les changements pour la session courante et fermer la boite de "
+"dialogue"
#: ../gui/wxpython/wxplot/dialogs.py:743
#, python-format
@@ -13796,8 +14938,11 @@
msgstr "Ãchelle"
#: ../gui/wxpython/wxplot/dialogs.py:1033
-msgid "Automatic axis scaling, custom max and min, or scale matches data range (min)"
-msgstr "Ãchelle de l'axe automatique, min et max personnalisés, ou échelle correspondant à la plage de données (min)"
+msgid ""
+"Automatic axis scaling, custom max and min, or scale matches data range (min)"
+msgstr ""
+"Ãchelle de l'axe automatique, min et max personnalisés, ou échelle "
+"correspondant à la plage de données (min)"
#: ../gui/wxpython/wxplot/dialogs.py:1038
msgid "Custom min"
@@ -14019,7 +15164,8 @@
#: ../gui/wxpython/lmgr/layertree.py:463
msgid "Set computational region from selected map(s)"
-msgstr "Définir la région calculée à partir de la(des) carte(s) sélectionnée(s)"
+msgstr ""
+"Définir la région calculée à partir de la(des) carte(s) sélectionnée(s)"
#: ../gui/wxpython/lmgr/layertree.py:477
#, fuzzy
@@ -14068,7 +15214,9 @@
#: ../gui/wxpython/lmgr/layertree.py:580
msgid "Set computational region from selected map(s) (ignore NULLs)"
-msgstr "Définir la région de calcul à partir de la(des) carte(s) sélectionnée(s) (ignore les NULLs)"
+msgstr ""
+"Définir la région de calcul à partir de la(des) carte(s) sélectionnée(s) "
+"(ignore les NULLs)"
#: ../gui/wxpython/lmgr/layertree.py:619
#, fuzzy
@@ -14090,8 +15238,13 @@
#: ../gui/wxpython/lmgr/layertree.py:787
#, fuzzy, python-format
-msgid "Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII characters excluding %(chars)s and space."
-msgstr "Le nom <%(name)s> n'est pas un nom valide pour un secteur. Merci de n'utiliser que des caractères ASCII à l'exclusion de %(chars)s et des espaces."
+msgid ""
+"Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII "
+"characters excluding %(chars)s and space."
+msgstr ""
+"Le nom <%(name)s> n'est pas un nom valide pour un secteur. Merci de "
+"n'utiliser que des caractères ASCII à l'exclusion de %(chars)s et des "
+"espaces."
#: ../gui/wxpython/lmgr/layertree.py:790 ../gui/wxpython/gis_set.py:1023
msgid "Invalid name"
@@ -14114,8 +15267,10 @@
#: ../gui/wxpython/lmgr/layertree.py:831
#, python-format
-msgid "%s <%s> already exists in the current mapset. Do you want to overwrite it?"
-msgstr "%s <%s> existe déjà dans le jeu de cartes courant. Voulez-vous l'écraser ?"
+msgid ""
+"%s <%s> already exists in the current mapset. Do you want to overwrite it?"
+msgstr ""
+"%s <%s> existe déjà dans le jeu de cartes courant. Voulez-vous l'écraser ?"
#: ../gui/wxpython/lmgr/layertree.py:841
@@ -14129,7 +15284,9 @@
#: ../gui/wxpython/lmgr/layertree.py:865
msgid "Unable to display histogram of raster map. No map name defined."
-msgstr "Impossible d'afficher l'histogramme de carte raster. Pas de nom de carte définit."
+msgstr ""
+"Impossible d'afficher l'histogramme de carte raster. Pas de nom de carte "
+"définit."
#: ../gui/wxpython/lmgr/layertree.py:1071
msgid "Layer group:"
@@ -14153,12 +15310,18 @@
msgstr "opacité :"
#: ../gui/wxpython/lmgr/menudata.py:42
-msgid "Unable to parse user toolboxes XML files. Default main menu will be loaded."
-msgstr "Impossible d'analyser le fichier XML des outils utilisateur. Chargement du menu principal par défaut."
+msgid ""
+"Unable to parse user toolboxes XML files. Default main menu will be loaded."
+msgstr ""
+"Impossible d'analyser le fichier XML des outils utilisateur. Chargement du "
+"menu principal par défaut."
#: ../gui/wxpython/lmgr/menudata.py:64
-msgid "Unable to parse user toolboxes XML files. Default module tree will be loaded."
-msgstr "Impossible d'analyser le fichier XML des outils utilisateur. Chargement de l'arbre des modules par défaut."
+msgid ""
+"Unable to parse user toolboxes XML files. Default module tree will be loaded."
+msgstr ""
+"Impossible d'analyser le fichier XML des outils utilisateur. Chargement de "
+"l'arbre des modules par défaut."
#: ../gui/wxpython/lmgr/toolbars.py:46
msgid "Start new map display"
@@ -14211,7 +15374,8 @@
#: ../gui/wxpython/lmgr/toolbars.py:95
msgid "Remove selected map layer(s) from layer tree"
-msgstr "Supprimer la(les) carte(s) sélectionnée(s) de l'arborescence des couches"
+msgstr ""
+"Supprimer la(les) carte(s) sélectionnée(s) de l'arborescence des couches"
#: ../gui/wxpython/lmgr/toolbars.py:136
msgid "Import/link raster or vector data"
@@ -14370,7 +15534,9 @@
#: ../gui/wxpython/lmgr/frame.py:423 ../gui/wxpython/gis_set.py:539
msgid "Do you want to set the default region extents and resolution now?"
-msgstr "Voulez-vous définir les limites et la résolution la région par défaut maintenant ?"
+msgstr ""
+"Voulez-vous définir les limites et la résolution la région par défaut "
+"maintenant ?"
#: ../gui/wxpython/lmgr/frame.py:425 ../gui/wxpython/gis_set.py:538
#, python-format
@@ -14396,8 +15562,12 @@
#: ../gui/wxpython/lmgr/frame.py:646
#, python-format
-msgid "Command '%s' not yet implemented in the WxGUI. Try adding it as a command layer instead."
-msgstr "La commande '%s' n'est pas encore implantée dans wxGUI. Essayez plutôt de l'ajouter en tant que couche de commande."
+msgid ""
+"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
+"layer instead."
+msgstr ""
+"La commande '%s' n'est pas encore implantée dans wxGUI. Essayez plutôt de "
+"l'ajouter en tant que couche de commande."
#: ../gui/wxpython/lmgr/frame.py:807 ../gui/wxpython/lmgr/frame.py:1732
msgid "Selected map layer is not vector."
@@ -14405,7 +15575,9 @@
#: ../gui/wxpython/lmgr/frame.py:812
msgid "Editing is allowed only for vector maps from the current mapset."
-msgstr "L'édition n'est permise que pour des cartes vectorielles du jeux de cartes actuel."
+msgstr ""
+"L'édition n'est permise que pour des cartes vectorielles du jeux de cartes "
+"actuel."
#: ../gui/wxpython/lmgr/frame.py:836
msgid "Choose script file to run"
@@ -14416,8 +15588,14 @@
msgstr "Script Python (*.py)|*.py|Bash script (*.sh)|*.sh"
#: ../gui/wxpython/lmgr/frame.py:850
-msgid "Due to the limitations of your operating system, the script path cannot contain certain non-ascii characters. Please rename the script or move it to a different location."
-msgstr "à cause de limitations de votre système, the chemin du script ne peut pas contenir certains caractères non-ascii. Merci de renommer le script ou de le déplacer dans un endroit différent."
+msgid ""
+"Due to the limitations of your operating system, the script path cannot "
+"contain certain non-ascii characters. Please rename the script or move it to "
+"a different location."
+msgstr ""
+"à cause de limitations de votre système, the chemin du script ne peut pas "
+"contenir certains caractères non-ascii. Merci de renommer le script ou de le "
+"déplacer dans un endroit différent."
#: ../gui/wxpython/lmgr/frame.py:857
#, python-format
@@ -14426,8 +15604,12 @@
#: ../gui/wxpython/lmgr/frame.py:864
#, python-format
-msgid "Script <%s> is not executable. Do you want to set the permissions that allows you to run this script (note that you must be the owner of the file)?"
-msgstr "Le script <%s> n'est pas exécutable. Voulez-vous définir les permissions d'exécution du script (vous devez être l'utilisateur propriétaire) ?"
+msgid ""
+"Script <%s> is not executable. Do you want to set the permissions that "
+"allows you to run this script (note that you must be the owner of the file)?"
+msgstr ""
+"Le script <%s> n'est pas exécutable. Voulez-vous définir les permissions "
+"d'exécution du script (vous devez être l'utilisateur propriétaire) ?"
#: ../gui/wxpython/lmgr/frame.py:869
msgid "Set permission?"
@@ -14439,8 +15621,12 @@
#: ../gui/wxpython/lmgr/frame.py:889
#, python-format
-msgid "Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this directory to GRASS_ADDON_PATH?"
-msgstr "Le dossier '%s' n'est pas définit dans GRASS_ADDON_PATH. Voulez-vous ajouter ce dossier à GRASS_ADDON_PATH ?"
+msgid ""
+"Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
+"directory to GRASS_ADDON_PATH?"
+msgstr ""
+"Le dossier '%s' n'est pas définit dans GRASS_ADDON_PATH. Voulez-vous ajouter "
+"ce dossier à GRASS_ADDON_PATH ?"
#: ../gui/wxpython/lmgr/frame.py:892
msgid "Update Addons path?"
@@ -14492,8 +15678,12 @@
msgstr "Sans paramètre, ouvre une boiite de dialogue."
#: ../gui/wxpython/lmgr/frame.py:1000
-msgid "If ~ (tilde) is present as the first directory on the path, it is replaced by user's home directory."
-msgstr "Si ~ (tilde) est présent comme premier dossier du chemin, il sera remplacé par le dossier utilisateur."
+msgid ""
+"If ~ (tilde) is present as the first directory on the path, it is replaced "
+"by user's home directory."
+msgstr ""
+"Si ~ (tilde) est présent comme premier dossier du chemin, il sera remplacé "
+"par le dossier utilisateur."
#: ../gui/wxpython/lmgr/frame.py:1014
msgid "More than one parameter provided."
@@ -14526,8 +15716,12 @@
msgstr "Plateforme"
#: ../gui/wxpython/lmgr/frame.py:1160
-msgid "Current workspace is not empty. Do you want to store current settings to workspace file?"
-msgstr "L'espace de travail n'est pas vide. Voulez-vous enregistrer les paramètres actuels dans un fichier ?"
+msgid ""
+"Current workspace is not empty. Do you want to store current settings to "
+"workspace file?"
+msgstr ""
+"L'espace de travail n'est pas vide. Voulez-vous enregistrer les paramètres "
+"actuels dans un fichier ?"
#: ../gui/wxpython/lmgr/frame.py:1163
msgid "Create new workspace?"
@@ -14560,7 +15754,8 @@
#: ../gui/wxpython/lmgr/frame.py:1401 ../gui/wxpython/lmgr/frame.py:1417
#, python-format
msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
-msgstr "Le fichier d'environnement <%s> existe déjà . Voulez-vous écraser ce fichier ?"
+msgstr ""
+"Le fichier d'environnement <%s> existe déjà . Voulez-vous écraser ce fichier ?"
#: ../gui/wxpython/lmgr/frame.py:1441
msgid "Writing current settings to workspace file failed."
@@ -14600,8 +15795,12 @@
msgstr "Type de couche <%s> non pris en charge"
#: ../gui/wxpython/lmgr/frame.py:2052
-msgid "Note that cell values can only be displayed for regions of less than 10,000 cells."
-msgstr "A noter que les valeurs des cellules ne peuvent être affichées que pour les régions de moins de 10 000 cellules."
+msgid ""
+"Note that cell values can only be displayed for regions of less than 10,000 "
+"cells."
+msgstr ""
+"A noter que les valeurs des cellules ne peuvent être affichées que pour les "
+"régions de moins de 10 000 cellules."
#: ../gui/wxpython/lmgr/frame.py:2134
#, python-format
@@ -14616,7 +15815,9 @@
#: ../gui/wxpython/lmgr/frame.py:2137
msgid "Do you want to remove selected map layer(s) from layer tree?"
-msgstr "Voulez-vous retirer la(les) carte(s) sélectionnée(s) de l'arborescence des couches ?"
+msgstr ""
+"Voulez-vous retirer la(les) carte(s) sélectionnée(s) de l'arborescence des "
+"couches ?"
#: ../gui/wxpython/lmgr/frame.py:2141
msgid "Remove map layer"
@@ -14631,16 +15832,26 @@
msgstr "Aucune ccouche sélectionnée. Opération annulée."
#: ../gui/wxpython/lmgr/frame.py:2247
-msgid "Display resolution is currently not constrained to computational settings. It's suggested to constrain map to region geometry. Do you want to constrain the resolution?"
-msgstr "La résolution de l'affichage n'est actuellement pas contrainte aux limite de la région de calculs. Il est suggéré de contraindre les cartes aux limites de la région. Voulez-vous contraindre la résolution ?"
+msgid ""
+"Display resolution is currently not constrained to computational settings. "
+"It's suggested to constrain map to region geometry. Do you want to constrain "
+"the resolution?"
+msgstr ""
+"La résolution de l'affichage n'est actuellement pas contrainte aux limite de "
+"la région de calculs. Il est suggéré de contraindre les cartes aux limites "
+"de la région. Voulez-vous contraindre la résolution ?"
#: ../gui/wxpython/lmgr/frame.py:2256
msgid "Constrain map to region geometry?"
msgstr "Restreindre la carte aux limites de la région ?"
#: ../gui/wxpython/timeline/frame.py:38
-msgid "The Timeline Tool needs the \"matplotlib\" (python-matplotlib) package to be installed."
-msgstr "L'outil temporel nécessite que le paquet \"matplotlib\" (python-matplotlib) soit installé."
+msgid ""
+"The Timeline Tool needs the \"matplotlib\" (python-matplotlib) package to be "
+"installed."
+msgstr ""
+"L'outil temporel nécessite que le paquet \"matplotlib\" (python-matplotlib) "
+"soit installé."
#: ../gui/wxpython/timeline/frame.py:70
#, fuzzy
@@ -14667,12 +15878,18 @@
#: ../gui/wxpython/timeline/frame.py:174
-msgid "Datasets have different temporal type (absolute x relative), which is not allowed."
-msgstr "Les jeux de données ont des types temporels (absolut x relatif) différents, ce qui n'ets pas permis. "
+msgid ""
+"Datasets have different temporal type (absolute x relative), which is not "
+"allowed."
+msgstr ""
+"Les jeux de données ont des types temporels (absolut x relatif) différents, "
+"ce qui n'ets pas permis. "
#: ../gui/wxpython/timeline/frame.py:189
msgid "Datasets have different time unit which is not allowed."
-msgstr "Les jeux de données ont des unités de temps différentes, ce qui n'est pas permis."
+msgstr ""
+"Les jeux de données ont des unités de temps différentes, ce qui n'est pas "
+"permis."
#: ../gui/wxpython/timeline/frame.py:264
#, python-format
@@ -14819,11 +16036,15 @@
#: ../gui/wxpython/gcp/manager.py:399
msgid "You must select a valid location before selecting a mapset"
-msgstr "Vous devez sélectionner un secteur valide avant de sélectionner un jeu de cartes"
+msgstr ""
+"Vous devez sélectionner un secteur valide avant de sélectionner un jeu de "
+"cartes"
#: ../gui/wxpython/gcp/manager.py:412
msgid "You must select a valid location and mapset in order to continue"
-msgstr "Vous devez sélectionner un secteur et un jeu de cartes valides pour pouvoir continuer"
+msgstr ""
+"Vous devez sélectionner un secteur et un jeu de cartes valides pour pouvoir "
+"continuer"
#: ../gui/wxpython/gcp/manager.py:431
msgid "Select image/map group to georectify"
@@ -14851,7 +16072,9 @@
#: ../gui/wxpython/gcp/manager.py:537
msgid "You must select a valid image/map group in order to continue"
-msgstr "Vous devez sélectionner un groupe d'images ou de cartes valides pour pouvoir continuer"
+msgstr ""
+"Vous devez sélectionner un groupe d'images ou de cartes valides pour pouvoir "
+"continuer"
#: ../gui/wxpython/gcp/manager.py:544
msgid "You must enter an map name extension in order to continue"
@@ -14859,7 +16082,8 @@
#: ../gui/wxpython/gcp/manager.py:610
msgid "Select maps to display for ground control point (GCP) creation"
-msgstr "Sélectionner les cartes à afficher pour la création des points de contrôle"
+msgstr ""
+"Sélectionner les cartes à afficher pour la création des points de contrôle"
#: ../gui/wxpython/gcp/manager.py:618 ../gui/wxpython/gcp/manager.py:2602
msgid "Select source map to display:"
@@ -14946,12 +16170,14 @@
#: ../gui/wxpython/gcp/manager.py:1382
msgid ""
-"Insufficient points defined and active (checked) for selected rectification method (order: %d).\n"
+"Insufficient points defined and active (checked) for selected rectification "
+"method (order: %d).\n"
"3+ points needed for 1st order,\n"
"6+ points for 2nd order, and\n"
"10+ points for 3rd order."
msgstr ""
-"Pas assez de points définis et activés pour la méthode de rectification choisie.\n"
+"Pas assez de points définis et activés pour la méthode de rectification "
+"choisie.\n"
"3 points ou + nécessaires pour le 1er ordre,\n"
"7 points ou + nécessaires pour le 2ème ordre, et\n"
"10 points ou + nécessaires pour le 3ème ordre."
@@ -15157,7 +16383,9 @@
#: ../gui/wxpython/gcp/manager.py:2850
#, python-format
msgid "GCP Manager settings saved to file '%s'."
-msgstr "Paramètres du gestionnaire de points de contrôle enregistrés dans le fichier '%s'."
+msgstr ""
+"Paramètres du gestionnaire de points de contrôle enregistrés dans le fichier "
+"'%s'."
#: ../gui/wxpython/gcp/statusbar.py:36
msgid "Go to GCP No."
@@ -15201,12 +16429,18 @@
msgstr ""
"La fonction de nuage de points est désactivée.\n"
"\n"
-"Raison : impossible d'importer les paquets nécessaires pour le nuage de pooints.\n"
+"Raison : impossible d'importer les paquets nécessaires pour le nuage de "
+"pooints.\n"
"%s"
#: ../gui/wxpython/iclass/digit.py:57
-msgid "You are trying to create a training area outside the computational region. Please, use g.region to set the appropriate region first."
-msgstr "Vous êtes en train de créer une zone d'entrainement en dehors de la région de calcul. Merci de commencer par utiliser g.region pour définir la région appropriée."
+msgid ""
+"You are trying to create a training area outside the computational region. "
+"Please, use g.region to set the appropriate region first."
+msgstr ""
+"Vous êtes en train de créer une zone d'entrainement en dehors de la région "
+"de calcul. Merci de commencer par utiliser g.region pour définir la région "
+"appropriée."
#: ../gui/wxpython/iclass/digit.py:66
msgid ""
@@ -15214,7 +16448,8 @@
"\n"
"There is no class yet, do you want to create one?"
msgstr ""
-"Pour créer unne zone d'entrainement, vous devez commencer apr sélectionner une classe.\n"
+"Pour créer unne zone d'entrainement, vous devez commencer apr sélectionner "
+"une classe.\n"
"\n"
"Il n'y a pas encore de classes, voulez-vous en créer une ?"
@@ -15257,7 +16492,9 @@
#: ../gui/wxpython/iclass/toolbars.py:39
#, fuzzy
msgid "Run analysis, update histogram and coincidence plots"
-msgstr "Lancement de l'analyse, mise à jour de l'histogramme et des points de concordance"
+msgstr ""
+"Lancement de l'analyse, mise à jour de l'histogramme et des points de "
+"concordance"
#: ../gui/wxpython/iclass/toolbars.py:41
msgid "Save signature file for i.maxlik"
@@ -15470,7 +16707,9 @@
#: ../gui/wxpython/iclass/frame.py:554
#, python-format
msgid "Vector map <%s> contains points or lines, these features are ignored."
-msgstr "La carte vecteur <%s> contient des points ou des lignes, ces entités seront ignorés."
+msgstr ""
+"La carte vecteur <%s> contient des points ou des lignes, ces entités seront "
+"ignorés."
#: ../gui/wxpython/iclass/frame.py:579
@@ -15495,7 +16734,8 @@
#: ../gui/wxpython/iclass/frame.py:698
#, python-format
msgid "%d training areas (%d classes) exported to vector map <%s>."
-msgstr "%d zones d'entrainement (%d classes) exportées vers la carte vecteur <%s>."
+msgstr ""
+"%d zones d'entrainement (%d classes) exportées vers la carte vecteur <%s>."
#: ../gui/wxpython/iclass/frame.py:897
#, fuzzy
@@ -15522,8 +16762,12 @@
msgstr "Pas de couche sélectionnée"
#: ../gui/wxpython/iclass/frame.py:994
-msgid "Due to recent changes in classes, signatures can be outdated and should be recalculated. Do you still want to continue?"
-msgstr "Suite à un changement récent dans les classes, les signatures peuvent être obsolètes et doivent être recalculées. Voulez-vous continuer ?"
+msgid ""
+"Due to recent changes in classes, signatures can be outdated and should be "
+"recalculated. Do you still want to continue?"
+msgstr ""
+"Suite à un changement récent dans les classes, les signatures peuvent être "
+"obsolètes et doivent être recalculées. Voulez-vous continuer ?"
#: ../gui/wxpython/iclass/frame.py:997
msgid "Outdated signatures"
@@ -15543,7 +16787,9 @@
#: ../gui/wxpython/iclass/frame.py:1070
-msgid "Group <%(group)s> does not have enough files (it has %(files)d files). Operation canceled."
+msgid ""
+"Group <%(group)s> does not have enough files (it has %(files)d files). "
+"Operation canceled."
msgstr "Ãchec de lecture de l'objet d'id %d. Opération annulée."
#: ../gui/wxpython/iclass/frame.py:1079
@@ -15553,7 +16799,9 @@
#: ../gui/wxpython/iclass/frame.py:1094
msgid "Vector features are outside raster layers. Operation canceled."
-msgstr "Les entités vectorielles sont en dehors de la couche raster. Opération annulée."
+msgstr ""
+"Les entités vectorielles sont en dehors de la couche raster. Opération "
+"annulée."
#: ../gui/wxpython/iclass/statistics.py:29
#, fuzzy
@@ -15580,12 +16828,21 @@
msgstr "La base de donnée GRASS contient les secteurs."
#: ../gui/wxpython/gis_set.py:133
-msgid "All data in one Location is in the same coordinate reference system (projection). One Location can be one project. Location contains Mapsets."
-msgstr "Toutes les données dans le même Secteur partagent le même système de coordonnées (projection). Un Secteur peut être un projet. Le Secteur contient des Jeux de données."
+msgid ""
+"All data in one Location is in the same coordinate reference system "
+"(projection). One Location can be one project. Location contains Mapsets."
+msgstr ""
+"Toutes les données dans le même Secteur partagent le même système de "
+"coordonnées (projection). Un Secteur peut être un projet. Le Secteur "
+"contient des Jeux de données."
#: ../gui/wxpython/gis_set.py:141
-msgid "Mapset contains GIS data related to one project, task within one project, subregion or user."
-msgstr "Les Jeux de données contiennent les données SIG relatives au projet, tâche dans un projet, sous-région ou utilisateur."
+msgid ""
+"Mapset contains GIS data related to one project, task within one project, "
+"subregion or user."
+msgstr ""
+"Les Jeux de données contiennent les données SIG relatives au projet, tâche "
+"dans un projet, sous-région ou utilisateur."
#: ../gui/wxpython/gis_set.py:156
msgid "Start &GRASS session"
@@ -15612,8 +16869,12 @@
#: ../gui/wxpython/gis_set.py:169
#, fuzzy
-msgid "Create a new location using location wizard. After location is created successfully, GRASS session is started."
-msgstr "Lancement de l'assistant. Une fois qu'un secteur est créé, la session GRASS sera lancée."
+msgid ""
+"Create a new location using location wizard. After location is created "
+"successfully, GRASS session is started."
+msgstr ""
+"Lancement de l'assistant. Une fois qu'un secteur est créé, la session GRASS "
+"sera lancée."
#: ../gui/wxpython/gis_set.py:173
msgid "Ren&ame"
@@ -15636,9 +16897,8 @@
msgstr "Renommer le jeu de cartes sélectionné"
#: ../gui/wxpython/gis_set.py:182
-#, fuzzy
msgid "&Delete"
-msgstr "Supprimer"
+msgstr "&Effacer"
#: ../gui/wxpython/gis_set.py:183 ../gui/wxpython/gis_set.py:683
msgid "Delete selected mapset"
@@ -15655,12 +16915,14 @@
#: ../gui/wxpython/gis_set.py:252 ../gui/wxpython/gis_set.py:728
msgid "Unable to set GRASS database. Check your locale settings."
-msgstr "Impossible de définir la base de données GRASS. Vérifiez vos paramètres de langue."
+msgstr ""
+"Impossible de définir la base de données GRASS. Vérifiez vos paramètres de "
+"langue."
#: ../gui/wxpython/gis_set.py:270
-#, fuzzy, python-format
+#, python-format
msgid "ERROR: Location <%s> not found\n"
-msgstr "ERREUR : Secteur <%s> non trouvé"
+msgstr "ERREUR : Secteur <%s> non trouvé\n"
#: ../gui/wxpython/gis_set.py:287
@@ -15680,7 +16942,9 @@
#: ../gui/wxpython/gis_set.py:509
msgid "Do you want to import <%(name)s> to the newly created location?"
-msgstr "Voulez-vous importer la source de données <%(name)s> pour créer le secteur ? la région par défaut sera alignée sur la carte importée."
+msgstr ""
+"Voulez-vous importer la source de données <%(name)s> pour créer le secteur ? "
+"la région par défaut sera alignée sur la carte importée."
#: ../gui/wxpython/gis_set.py:513
#, fuzzy
@@ -15700,8 +16964,12 @@
#: ../gui/wxpython/gis_set.py:582
-msgid "Data file <%(name)s> imported successfully. The location's default region was set from this imported map."
+msgid ""
+"Data file <%(name)s> imported successfully. The location's default region "
+"was set from this imported map."
+msgstr ""
#: ../gui/wxpython/gis_set.py:595
msgid ""
@@ -15709,7 +16977,8 @@
"\n"
"This mapset cannot be renamed."
msgstr ""
-"Le jeu de cartes <PERMANENT> est requis pour qu'un secteur GRASS soit valide.\n"
+"Le jeu de cartes <PERMANENT> est requis pour qu'un secteur GRASS soit "
+"valide.\n"
"\n"
"Ce jeu de cartes ne peut être renommé."
@@ -15774,20 +17043,24 @@
"\n"
"This mapset cannot be deleted."
msgstr ""
+"valide.\n"
"\n"
"Ce jeu de cartes ne peut être supprimé."
#: ../gui/wxpython/gis_set.py:678
#, python-format
msgid ""
-"Do you want to continue with deleting mapset <%(mapset)s> from location <%(location)s>?\n"
+"Do you want to continue with deleting mapset <%(mapset)s> from location <"
+"%(location)s>?\n"
"\n"
"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
msgstr ""
-"Voulez-vous vraiment supprimer le jeu de cartes <%(mapset)s> du secteur <%(location)s>?\n"
+"Voulez-vous vraiment supprimer le jeu de cartes <%(mapset)s> du secteur <"
+"%(location)s>?\n"
"\n"
-"TOUTES LES CARTES incluses dans ce jeu de cartes seront DÃFINITIVEMENT SUPPRIMÃES !"
+"TOUTES LES CARTES incluses dans ce jeu de cartes seront DÃFINITIVEMENT "
+"SUPPRIMÃES !"
#: ../gui/wxpython/gis_set.py:692
msgid "Unable to delete mapset"
@@ -15810,8 +17083,12 @@
#: ../gui/wxpython/gis_set.py:739
#, python-format
-msgid "No GRASS Location found in '%s'. Create a new Location or choose different GRASS database directory."
-msgstr "Pas de Secteur GRASS trouvé dans '%s'. Créez un nouveau Secteur ou choisissez un autre dossier de base de données GRASS."
+msgid ""
+"No GRASS Location found in '%s'. Create a new Location or choose different "
+"GRASS database directory."
+msgstr ""
+"Pas de Secteur GRASS trouvé dans '%s'. Créez un nouveau Secteur ou "
+"choisissez un autre dossier de base de données GRASS."
#: ../gui/wxpython/gis_set.py:857
@@ -15826,11 +17103,13 @@
#: ../gui/wxpython/gis_set.py:903
#, python-format
msgid ""
-"Mapset <%s> is reserved for direct read access to OGR layers. Please consider to use another name for your mapset.\n"
+"Mapset <%s> is reserved for direct read access to OGR layers. Please "
+"consider to use another name for your mapset.\n"
"\n"
"Are you really sure that you want to create this mapset?"
msgstr ""
-"Le jeu de cartes <%s> est réservé pour un accès en lecture directe des couches OGR. Merci d'utiliser un autre nom pour votre jeu de cartes.\n"
+"Le jeu de cartes <%s> est réservé pour un accès en lecture directe des "
+"couches OGR. Merci d'utiliser un autre nom pour votre jeu de cartes.\n"
"\n"
"Ãtes-vous sûr de vouloir créer ce jeu de cartes ?"
@@ -15852,14 +17131,16 @@
"\n"
"Concurrent use not allowed.\n"
"\n"
-"Do you want to try to remove .gislock (note that you need permission for this operation) and continue?"
+"Do you want to try to remove .gislock (note that you need permission for "
+"this operation) and continue?"
msgstr ""
"GRASS s'exécute déjà dans le jeu de cartes <%(mapset)s> sélectionné\n"
"(fichier %(lock)s détecté).\n"
"\n"
"L'accès concurrent n'est pas autorisé.\n"
"\n"
-"Souhaitez-vous essayer de supprimer .gislock (notez qu'il vous faut disposer de droits pour cette opération) et continuer ?"
+"Souhaitez-vous essayer de supprimer .gislock (notez qu'il vous faut disposer "
+"de droits pour cette opération) et continuer ?"
#: ../gui/wxpython/gis_set.py:949 ../gui/wxpython/gis_set.py:961
msgid "Lock file found"
@@ -15869,11 +17150,13 @@
msgid ""
"ARE YOU REALLY SURE?\n"
"\n"
-"If you really are running another GRASS session doing this could corrupt your data. Have another look in the processor manager just to be sure..."
+"If you really are running another GRASS session doing this could corrupt "
+"your data. Have another look in the processor manager just to be sure..."
msgstr ""
"ÃTES-VOUS VRAIMENT SÃR ?\n"
"\n"
-"Si vous avez une autre session GRASS en cours, vous risquez de corrompre vos données. Vérifiez dans votre gestionnaire de tâches pour en être sûr ..."
+"Si vous avez une autre session GRASS en cours, vous risquez de corrompre vos "
+"données. Vérifiez dans votre gestionnaire de tâches pour en être sûr ..."
#: ../gui/wxpython/gis_set.py:972
#, python-format
@@ -15888,13 +17171,24 @@
#: ../gui/wxpython/gis_set.py:1020
#, python-format
-msgid "Name <%(name)s> is not a valid name for location or mapset. Please use only ASCII characters excluding %(chars)s and space."
-msgstr "le nom <%(name)s> n'ets pas un nom valide pour un secteur ou un jeu de cartes. Merci de n'utiliser que des caractères ASCII sans %(chars)s ni espaces."
+msgid ""
+"Name <%(name)s> is not a valid name for location or mapset. Please use only "
+"ASCII characters excluding %(chars)s and space."
+msgstr ""
+"le nom <%(name)s> n'ets pas un nom valide pour un secteur ou un jeu de "
+"cartes. Merci de n'utiliser que des caractères ASCII sans %(chars)s ni "
+"espaces."
#: ../gui/wxpython/gis_set.py:1091
#, fuzzy
-msgid "GRASS needs a directory (GRASS database) in which to store its data. Create one now if you have not already done so. A popular choice is \"grassdata\", located in your home directory. Press Browse button to select the directory."
-msgstr "GRASS nécéssite un dossier dans lequel enregistrer ses données. Créez en un si vous ne l'avez pas déjà fait. Un choix populaire est « grassdata », dans votre dossier personnel."
+msgid ""
+"GRASS needs a directory (GRASS database) in which to store its data. Create "
+"one now if you have not already done so. A popular choice is \"grassdata\", "
+"located in your home directory. Press Browse button to select the directory."
+msgstr ""
+"GRASS nécéssite un dossier dans lequel enregistrer ses données. Créez en un "
+"si vous ne l'avez pas déjà fait. Un choix populaire est « grassdata », dans "
+"votre dossier personnel."
#: ../gui/wxpython/mapswipe/toolbars.py:27
msgid "Quit Map Swipe"
@@ -15993,7 +17287,8 @@
#: ../gui/wxpython/icons/icon.py:34
#, python-format
msgid "Unknown iconset '%s', using default 'grass'...\n"
-msgstr "Jeu d'icônes '%s' inconnu, utilisation du jeu par defaut 'grass\" ...\n"
+msgstr ""
+"Jeu d'icônes '%s' inconnu, utilisation du jeu par defaut 'grass\" ...\n"
#: ../gui/wxpython/icons/icon.py:51
@@ -16022,7 +17317,9 @@
#: ../gui/wxpython/vdigit/toolbars.py:130
#: ../gui/wxpython/vdigit/toolbars.py:154
msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
-msgstr "Gauche : nouveau point ; Ctrl+gauche : annuler le dernier point ; Droite : fermer la ligne"
+msgstr ""
+"Gauche : nouveau point ; Ctrl+gauche : annuler le dernier point ; Droite : "
+"fermer la ligne"
#: ../gui/wxpython/vdigit/toolbars.py:129
msgid "Digitize new boundary"
@@ -16035,7 +17332,9 @@
#: ../gui/wxpython/vdigit/toolbars.py:135
#, fuzzy
msgid "Digitize new area (boundary without category)"
-msgstr "Numériser une nouvelle surface (composée d'un contour sans catégorie et d'un centroïde avec catégorie)"
+msgstr ""
+"Numériser une nouvelle surface (composée d'un contour sans catégorie et d'un "
+"centroïde avec catégorie)"
#: ../gui/wxpython/vdigit/toolbars.py:138
#, fuzzy
@@ -16050,7 +17349,8 @@
#: ../gui/wxpython/vdigit/toolbars.py:163
#: ../gui/wxpython/vdigit/toolbars.py:172
msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
-msgstr "Gauche : Sélectionner ; Ctrl+Gauche : Dé-sélectionner : Droite : Confirmer"
+msgstr ""
+"Gauche : Sélectionner ; Ctrl+Gauche : Dé-sélectionner : Droite : Confirmer"
# à défaut de mieux, je traduis snap ou snapping par magnétisme, magnétiser. Ouvert à d'autres suggestions...
#: ../gui/wxpython/vdigit/toolbars.py:141
@@ -16204,9 +17504,14 @@
#: ../gui/wxpython/vdigit/toolbars.py:848
msgid ""
-"Topology for vector map <%s> is not available. Topology is required by digitizer.\n"
-"Do you want to rebuild topology (takes some time) and open the vector map for editing?"
-msgstr "La topologie pour la carte vecteur <%s> n'est pas disponible. La topologie est requise pour la digitalisation. Voulez-vous reconstruire la topologie (peut prendre du temps) et ouvrir la carte vecteur pour édition ?"
+"Topology for vector map <%s> is not available. Topology is required by "
+"digitizer.\n"
+"Do you want to rebuild topology (takes some time) and open the vector map "
+"for editing?"
+msgstr ""
+"La topologie pour la carte vecteur <%s> n'est pas disponible. La topologie "
+"est requise pour la digitalisation. Voulez-vous reconstruire la topologie "
+"(peut prendre du temps) et ouvrir la carte vecteur pour édition ?"
#: ../gui/wxpython/vdigit/toolbars.py:852
#, fuzzy
@@ -16220,8 +17525,11 @@
#: ../gui/wxpython/vdigit/toolbars.py:904
#, python-format
-msgid "Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
-msgstr "Type d'entité '%(type)s' non prise en charge. Impossible de modifier la couche OGR <%(layer)s>."
+msgid ""
+"Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
+msgstr ""
+"Type d'entité '%(type)s' non prise en charge. Impossible de modifier la "
+"couche OGR <%(layer)s>."
#: ../gui/wxpython/vdigit/toolbars.py:916
#, fuzzy
@@ -16240,7 +17548,9 @@
#: ../gui/wxpython/vdigit/toolbars.py:974
#, python-format
msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
-msgstr "Merci de patienter, fermeture et reconstruction de la topologie de la carte vecteur <%s>..."
+msgstr ""
+"Merci de patienter, fermeture et reconstruction de la topologie de la carte "
+"vecteur <%s>..."
#: ../gui/wxpython/vdigit/toolbars.py:988
#, python-format
@@ -16264,7 +17574,9 @@
#: ../gui/wxpython/vdigit/g.gui.vdigit.py:97
-msgid "Vector map <%s> not found in current mapset. New vector map can be created by providing '-c' flag."
+msgid ""
+"Vector map <%s> not found in current mapset. New vector map can be created "
+"by providing '-c' flag."
msgstr "Carte vectorielle <%s> non trouvée"
#: ../gui/wxpython/vdigit/g.gui.vdigit.py:100
@@ -16344,7 +17656,9 @@
#: ../gui/wxpython/vdigit/preferences.py:60
msgid "Close dialog and save changes to user settings file"
-msgstr "Fermer la boîte de dialogue et enregistrer les modifications dans le fichier de paramètres utilisateur"
+msgstr ""
+"Fermer la boîte de dialogue et enregistrer les modifications dans le fichier "
+"de paramètres utilisateur"
#: ../gui/wxpython/vdigit/preferences.py:154
msgid "Snapping"
@@ -16387,8 +17701,11 @@
msgstr "Ne sélectionner que les entités contenues dans la boîte de sélection"
#: ../gui/wxpython/vdigit/preferences.py:226
-msgid "By default are selected all features overlapping selection bounding box "
-msgstr "Par défaut sont sélectionnées toutes les entités chevauchent la boîte de sélection"
+msgid ""
+"By default are selected all features overlapping selection bounding box "
+msgstr ""
+"Par défaut sont sélectionnées toutes les entités chevauchent la boîte de "
+"sélection"
#: ../gui/wxpython/vdigit/preferences.py:229
msgid "Check for duplicates"
@@ -16509,8 +17826,12 @@
msgstr "périmètre"
#: ../gui/wxpython/vdigit/preferences.py:505
-msgid "Note: These settings are stored in the workspace not in the vector digitizer preferences."
-msgstr "Note : ces paramètres sont stockés dans l'espace de travail, et non dans les préférences du module de numérisation."
+msgid ""
+"Note: These settings are stored in the workspace not in the vector digitizer "
+"preferences."
+msgstr ""
+"Note : ces paramètres sont stockés dans l'espace de travail, et non dans les "
+"préférences du module de numérisation."
#: ../gui/wxpython/vdigit/preferences.py:534
msgid "Digitize new line segment"
@@ -16579,7 +17900,9 @@
#: ../gui/wxpython/vdigit/preferences.py:620
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
-msgstr "Le seuil de magnétisme vaut %(value).1f %(units)s (fondé sur la résolution calculée)"
+msgstr ""
+"Le seuil de magnétisme vaut %(value).1f %(units)s (fondé sur la résolution "
+"calculée)"
#: ../gui/wxpython/vdigit/preferences.py:676
#, python-format
@@ -16597,7 +17920,9 @@
#: ../gui/wxpython/vdigit/mapwindow.py:543
msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
-msgstr "Pas d'action. Choisissez l'outil approprié depuis la barre d'outil de numérisation."
+msgstr ""
+"Pas d'action. Choisissez l'outil approprié depuis la barre d'outil de "
+"numérisation."
#: ../gui/wxpython/vdigit/mapwindow.py:1041
msgid "Z bulk-labeling dialog"
@@ -16605,8 +17930,14 @@
#: ../gui/wxpython/vdigit/wxdisplay.py:948
#, python-format
-msgid "Topology for vector map <%s> is not available. Topology is required by digitizer. Do you want to rebuild topology (takes some time) and open the vector map for editing?"
+msgid ""
+"digitizer. Do you want to rebuild topology (takes some time) and open the "
+"vector map for editing?"
+msgstr ""
#: ../gui/wxpython/vdigit/wxdisplay.py:952
msgid "Topology missing"
@@ -16649,12 +17980,16 @@
#: ../gui/wxpython/vdigit/wxdigit.py:94
#, python-format
msgid "Unable to start database driver <%s>. Operation canceled."
-msgstr "Impossible de démarrer le pilote de base de données <%s>. Opération annulée."
+msgstr ""
+"Impossible de démarrer le pilote de base de données <%s>. Opération annulée."
#: ../gui/wxpython/vdigit/wxdigit.py:102
#, python-format
-msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
-msgstr "Impossible d'ouvrir la base de données <%(db)s> avec le pilote <%(driver)s> . Opération annulée."
+msgid ""
+"Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
+msgstr ""
+"Impossible d'ouvrir la base de données <%(db)s> avec le pilote <"
+"%(driver)s> . Opération annulée."
#: ../gui/wxpython/vdigit/wxdigit.py:110
#, python-format
@@ -16747,10 +18082,12 @@
#: ../gui/wxpython/vnet/vnet_core.py:211
#, python-format
msgid ""
-"Temporary map '%s' with result was changed outside vector network analysis tool.\n"
+"Temporary map '%s' with result was changed outside vector network analysis "
+"tool.\n"
"Showed result may not correspond original analysis result."
msgstr ""
-"La carte temporaire '%s' avec les résultats a été modifiée en dehors de l'outil d'analyse de réseau vectoriel.\n"
+"La carte temporaire '%s' avec les résultats a été modifiée en dehors de "
+"l'outil d'analyse de réseau vectoriel.\n"
"Les résultats affichés peuvent ne pas correspondre aux résultats d'origine."
#: ../gui/wxpython/vnet/vnet_core.py:216
@@ -16794,10 +18131,12 @@
#: ../gui/wxpython/vnet/vnet_core.py:895
#, python-format
msgid ""
-"Input map '%s' for analysis was changed outside vector network analysis tool.\n"
+"Input map '%s' for analysis was changed outside vector network analysis "
+"tool.\n"
"Topology column may not correspond to changed situation."
msgstr ""
-"La carte d'entrée '%s' pour l'analyse a été modifiée en dehors de l'outil d'analyse de réseau vectoriel.\n"
+"La carte d'entrée '%s' pour l'analyse a été modifiée en dehors de l'outil "
+"d'analyse de réseau vectoriel.\n"
"La colonne de topologie peut ne pas correspondre à la situation modifiée."
#: ../gui/wxpython/vnet/vnet_core.py:900
@@ -16832,7 +18171,8 @@
"Temporary map '%s' was changed outside vector analysis tool.\n"
"Do you really want to activate snapping and overwrite it? "
msgstr ""
-"La carte temporaire '%s' a été modifiée en dehors de l'outil d'analyse vectorielle.\n"
+"La carte temporaire '%s' a été modifiée en dehors de l'outil d'analyse "
+"vectorielle.\n"
"Voulez-vous vraiment activer le magnétisme et l'écraser ?"
#: ../gui/wxpython/vnet/vnet_core.py:1045
@@ -17017,8 +18357,12 @@
#: ../gui/wxpython/vnet/vnet_data.py:184
#, python-format
-msgid "Chosen column '%s' does not exist in attribute table of layer '%s' of vector map '%s'.\n"
-msgstr "La colonne choisie '%s' n'existe pas dans la table d'attributs de la couche '%s' de la carte vectorielle '%s'.\n"
+msgid ""
+"Chosen column '%s' does not exist in attribute table of layer '%s' of vector "
+"map '%s'.\n"
+msgstr ""
+"La colonne choisie '%s' n'existe pas dans la table d'attributs de la couche "
+"'%s' de la carte vectorielle '%s'.\n"
#: ../gui/wxpython/vnet/vnet_data.py:238
msgid "type"
@@ -17201,7 +18545,8 @@
"%s web service was not found in fetched capabilities file from <%s>:\n"
"%s\n"
msgstr ""
-"Le service web %s n'a pas été trouvé dans le fichier de capacités récupérer depuis <%s> :\n"
+"Le service web %s n'a pas été trouvé dans le fichier de capacités récupérer "
+"depuis <%s> :\n"
"%s\n"
#: ../gui/wxpython/web_services/widgets.py:768
@@ -17242,7 +18587,8 @@
"User defined server with same name as default server <%s> already exists.\n"
"Keeping user defined server"
msgstr ""
-"Un serveur défini par l'utilisateur existe déjà avec le même nom que le serveur par défaut <%s>.\n"
+"Un serveur défini par l'utilisateur existe déjà avec le même nom que le "
+"serveur par défaut <%s>.\n"
"On garde le serveur défini par l'utilisateur."
#: ../gui/wxpython/web_services/dialogs.py:90
@@ -17306,7 +18652,8 @@
#: ../gui/wxpython/web_services/dialogs.py:488
msgid "Add selected web service layers as map layer into layer tree"
-msgstr "Ajouter les couches web service sélectionnées dans l'arborescence des couches"
+msgstr ""
+"Ajouter les couches web service sélectionnées dans l'arborescence des couches"
#: ../gui/wxpython/web_services/dialogs.py:581
msgid "Web service layer properties"
@@ -17336,7 +18683,9 @@
#: ../gui/wxpython/web_services/dialogs.py:807
msgid "Extent and resolution are based on Map Display geometry."
-msgstr "L'étendue et la résolution sont basés sur la géométrie de l'écran d'affichage."
+msgstr ""
+"L'étendue et la résolution sont basés sur la géométrie de l'écran "
+"d'affichage."
#: ../gui/wxpython/web_services/dialogs.py:809
#, fuzzy
@@ -17395,10 +18744,15 @@
#~ msgstr "Importer une carte vecteur d'une ancienne version de GRASS"
#~ msgid "Historical GRASS vector import (all maps)"
-#~ msgstr "Import de cartes vecteurs ancienne version de GRASS (toutes les cartes)"
+#~ msgstr ""
+#~ "Import de cartes vecteurs ancienne version de GRASS (toutes les cartes)"
-#~ msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
-#~ msgstr "Convertir toutes les cartes vectorielles en ancien format GRASS du jeux de cartes courant vers le nouveau format."
+#~ msgid ""
+#~ "Converts all older versions of GRASS vector maps in current mapset to "
+#~ "current format."
+#~ msgstr ""
+#~ "Convertir toutes les cartes vectorielles en ancien format GRASS du jeux "
+#~ "de cartes courant vers le nouveau format."
#~ msgid "GPS data import"
#~ msgstr "Importer des données GPS"
@@ -17407,7 +18761,8 @@
#~ msgstr "Importer depuis GEOnet"
#~ msgid "IDW from raster points (alternate method for sparse points)"
-#~ msgstr "IDW depuis des points raster (méthode alternative pour points clairsemés)"
+#~ msgstr ""
+#~ "IDW depuis des points raster (méthode alternative pour points clairsemés)"
#~ msgid "Create optimally placed labels"
#~ msgstr "Créer des étiquettes placées de manière optimale"
@@ -17432,7 +18787,8 @@
#~ msgstr "Créer un nouveau jeu de cartes"
#, fuzzy
-#~ msgid "Selected map <%s> has been disabled for rendering. Operation canceled."
+#~ msgid ""
+#~ "Selected map <%s> has been disabled for rendering. Operation canceled."
#~ msgstr "La carte vecteur n'est pas 3D. Opération annulée."
#, fuzzy
@@ -17466,8 +18822,11 @@
#~ msgstr "1:"
#, fuzzy
-#~ msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
-#~ msgstr "Créer une carte raster à partir d'un assemblage d'un lot de coordonnées en utilisant des statistiques univariées."
+#~ msgid ""
+#~ "Creates a raster map from LAS LiDAR points using univariate statistics."
+#~ msgstr ""
+#~ "Créer une carte raster à partir d'un assemblage d'un lot de coordonnées "
+#~ "en utilisant des statistiques univariées."
#, fuzzy
#~ msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
@@ -17603,8 +18962,12 @@
#~ msgstr "Calcule l'indice de forme sur une carte raster"
#, fuzzy
-#~ msgid "Raster map <%s> already exists in the current mapset. Do you want to overwrite it?"
-#~ msgstr "La carte vecteur <%s> existe déjà dans le jeu de cartes courant. Voulez-vous l'écraser ?"
+#~ msgid ""
+#~ "Raster map <%s> already exists in the current mapset. Do you want to "
+#~ "overwrite it?"
+#~ msgstr ""
+#~ "La carte vecteur <%s> existe déjà dans le jeu de cartes courant. Voulez-"
+#~ "vous l'écraser ?"
#, fuzzy
#~ msgid "GRASS GIS Temporal Plot Tool"
@@ -17708,5 +19071,9 @@
#~ msgstr "Afficher la carte"
#, fuzzy
-#~ msgid "Do you want to import <%(name)s> to the newly created location? The location's default region will be set from this imported map."
-#~ msgstr "Voulez-vous importer la source de données <%(name)s> pour créer le secteur ? la région par défaut sera alignée sur la carte importée."
+#~ msgid ""
+#~ "Do you want to import <%(name)s> to the newly created location? The "
+#~ "location's default region will be set from this imported map."
+#~ msgstr ""
+#~ "Voulez-vous importer la source de données <%(name)s> pour créer le "
+#~ "secteur ? la région par défaut sera alignée sur la carte importée."
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_id.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_id.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_id.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_id\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2015-02-16 14:18+0100\n"
+"POT-Creation-Date: 2015-02-20 20:37+0100\n"
"PO-Revision-Date: 2009-04-10 21:13+0700\n"
"Last-Translator: Firman Hadi <jalmiburung at gmail.com>\n"
"Language-Team: deutsch <grass-translations at lists.osgeo.org>\n"
@@ -484,7 +484,7 @@
"\n"
"'%s'"
-#: ../gui/wxpython/gui_core/mapdisp.py:114 ../gui/wxpython/core/render.py:443
+#: ../gui/wxpython/gui_core/mapdisp.py:114 ../gui/wxpython/core/render.py:449
#: ../gui/wxpython/mapdisp/test_mapdisp.py:88
#, python-format
msgid "GRASS module '%s' not found. Unable to start map display window."
@@ -1909,7 +1909,7 @@
#: ../gui/wxpython/gui_core/preferences.py:394
#: ../gui/wxpython/gui_core/preferences.py:589
#: ../gui/wxpython/animation/dialogs.py:845
-#: ../gui/wxpython/mapwin/decorations.py:366
+#: ../gui/wxpython/mapwin/decorations.py:369
msgid "Set font"
msgstr "Tentukan jenis huruf"
@@ -4730,7 +4730,7 @@
msgstr ""
#: ../gui/wxpython/psmap/dialogs.py:291
-#: ../gui/wxpython/mapwin/decorations.py:363
+#: ../gui/wxpython/mapwin/decorations.py:366
#, fuzzy
msgid "Font:"
msgstr "Tema ikon:"
@@ -6076,8 +6076,8 @@
msgid "Execution failed:"
msgstr "Eksekusi gagal:"
-#: ../gui/wxpython/core/gcmd.py:395 ../gui/wxpython/core/render.py:662
-#: ../gui/wxpython/core/render.py:665 ../gui/wxpython/core/render.py:668
+#: ../gui/wxpython/core/gcmd.py:395 ../gui/wxpython/core/render.py:668
+#: ../gui/wxpython/core/render.py:671 ../gui/wxpython/core/render.py:674
msgid "Details:"
msgstr "Deil:"
@@ -6165,80 +6165,80 @@
msgid "Details: %s\n"
msgstr "Deil:"
-#: ../gui/wxpython/core/render.py:268
+#: ../gui/wxpython/core/render.py:274
msgid "Unsupported map layer type '%s'"
msgstr "Tidak dapat melakukan render layer peta <%s>."
-#: ../gui/wxpython/core/render.py:412
+#: ../gui/wxpython/core/render.py:418
#, fuzzy
msgid "Trying to recover from default region..."
msgstr "Perbesaran sesuai dengan region standar"
-#: ../gui/wxpython/core/render.py:477
+#: ../gui/wxpython/core/render.py:483
#, python-format
msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
msgstr ""
-#: ../gui/wxpython/core/render.py:485
+#: ../gui/wxpython/core/render.py:491
msgid ""
"\n"
"ERROR: Unable to read WIND file: %s\n"
msgstr "Tidak dapat membaca daftar: %s"
-#: ../gui/wxpython/core/render.py:582
+#: ../gui/wxpython/core/render.py:588
msgid "Invalid map size %d,%d\n"
msgstr "Nilai tidak valid: %s"
-#: ../gui/wxpython/core/render.py:661
+#: ../gui/wxpython/core/render.py:667
msgid "Unable to zoom to raster map <%s>."
msgstr "Tidak dapat memperbesar ke peta raster <%s>"
-#: ../gui/wxpython/core/render.py:664
+#: ../gui/wxpython/core/render.py:670
msgid "Unable to zoom to vector map <%s>."
msgstr "Tidak bisa membuat sebuah peta vektor baru <%s>."
-#: ../gui/wxpython/core/render.py:667
+#: ../gui/wxpython/core/render.py:673
msgid "Unable to zoom to 3d raster map <%s>."
-#: ../gui/wxpython/core/render.py:670
+#: ../gui/wxpython/core/render.py:676
msgid ""
"Unable to get current geographic extent. Force quiting wxGUI. Please "
"manually run g.region to fix the problem."
msgstr ""
-#: ../gui/wxpython/core/render.py:981
+#: ../gui/wxpython/core/render.py:987
#, python-format
msgid "ERROR: Rendering failed. Details: %s"
msgstr ""
-#: ../gui/wxpython/core/render.py:1028 ../gui/wxpython/core/render.py:1123
+#: ../gui/wxpython/core/render.py:1034 ../gui/wxpython/core/render.py:1129
#, python-format
msgid "Unable to render map layer <%s>."
-#: ../gui/wxpython/core/render.py:1234 ../gui/wxpython/core/render.py:1273
+#: ../gui/wxpython/core/render.py:1240 ../gui/wxpython/core/render.py:1279
#, python-format
msgid "Unable to render overlay <%s>."
msgstr "Tidak dapat merender overlay <%s>."
-#: ../gui/wxpython/core/render.py:1370
+#: ../gui/wxpython/core/render.py:1376
#, fuzzy
msgid "Downloading data "
msgstr "Menampilkan data..."
-#: ../gui/wxpython/core/render.py:1380
+#: ../gui/wxpython/core/render.py:1386
#, fuzzy
msgid "Rendering & "
msgstr "Render"
-#: ../gui/wxpython/core/render.py:1382
+#: ../gui/wxpython/core/render.py:1388
#, fuzzy
msgid "Rendering..."
msgstr "Render"
@@ -12433,7 +12433,7 @@
msgstr "Pilih berkas workspace"
#: ../gui/wxpython/animation/dialogs.py:863
-#: ../gui/wxpython/mapwin/decorations.py:335
+#: ../gui/wxpython/mapwin/decorations.py:338
#, fuzzy
msgid "Text:"
msgstr "Tes"
@@ -13678,24 +13678,24 @@
msgid "Print preview"
msgstr "Tampilan cetak"
-#: ../gui/wxpython/mapwin/decorations.py:174
-#: ../gui/wxpython/mapwin/decorations.py:221
+#: ../gui/wxpython/mapwin/decorations.py:177
+#: ../gui/wxpython/mapwin/decorations.py:224
msgid ""
"Please install Python Imaging Library (PIL)\n"
"for better control of legend and other decorations."
msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:326
+#: ../gui/wxpython/mapwin/decorations.py:329
#, fuzzy
msgid "Show text object"
msgstr "Tampilkan batas luar komputasi"
-#: ../gui/wxpython/mapwin/decorations.py:351
+#: ../gui/wxpython/mapwin/decorations.py:354
#: ../gui/wxpython/nviz/tools.py:1011
msgid "Rotation:"
msgstr "Rotasi:"
-#: ../gui/wxpython/mapwin/decorations.py:379
+#: ../gui/wxpython/mapwin/decorations.py:382
msgid ""
"Drag text with mouse in pointer mode to position.\n"
"Double-click to change options"
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_it.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_it.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_it.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_it\n"
"PO-Revision-Date: 2015-01-14 14:10+0100\n"
"Last-Translator: Luca Delucchi <lucadeluge at gmail.com>\n"
"Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
@@ -444,7 +444,7 @@
msgid "Loading ctypes libs failed"
msgstr "Caricamento librerie ctypes fallito"
#, python-format
@@ -1743,7 +1743,7 @@
msgid "Set font"
msgstr "Imposta font"
@@ -4407,7 +4407,7 @@
"del foglio"
msgid "Font:"
msgstr "Font:"
@@ -5618,8 +5618,8 @@
msgstr "Esecuzione fallita:"
msgid "Details:"
msgstr "Dettagli:"
@@ -5708,23 +5708,23 @@
msgstr "Dettagli: %s\n"
#, python-format
msgstr "Layer '%s' non supportato"
msgstr ""
#, python-format
msgstr ""
"Errore: Impossibile aprire '%(file)s'. Motivazione: %(ret)s. Usciti da "
"wxGUI.\n"
#, python-format
msgid ""
"\n"
@@ -5733,27 +5733,27 @@
"\n"
"ERRORE: Impossibile leggere il file WIND: %s\n"
#, python-format
msgstr "Dimensione mappa non valida: %d,%d\n"
#, python-format
msgstr "Impossibile zoomare al raster <%s>."
#, python-format
msgstr "Impossibile zoomare al vettoriale <%s>."
#, python-format
msgstr "Impossibile fare zoom al raster 3d <%s>."
msgid ""
@@ -5761,30 +5761,30 @@
"Impossibile ottenere l'estensione geografica attuale. Uscita forzata da "
"wxGUI. Per favore eseguire manualmente g.region per risolvere il problema"
#, python-format
msgstr "ERRORE: Rendering fallito. Dettagli: %s"
#, python-format
msgstr "Impossibile visualizzare layer <%s>."
#, python-format
msgstr "Impossibile visualizzare <%s> sovrapposto"
msgstr "Scaricamento dati"
msgstr "Visualizzazione &"
msgstr "Visualizzazione..."
@@ -11478,7 +11478,7 @@
msgstr "Scegli un file d'immagine"
msgid "Text:"
msgstr "Testo:"
@@ -12606,23 +12606,23 @@
msgstr "Anteprima di stampa"
msgid ""
msgstr ""
msgstr "Mostra oggetto testuale"
msgid "Rotation:"
msgstr "Rotazione:"
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ja.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ja.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ja.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -11,7 +11,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_ja\n"
"PO-Revision-Date: 2012-03-08 17:45+0900\n"
"Last-Translator: taniguchi <taniguti at apptec.co.jp>\n"
"Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
@@ -484,7 +484,7 @@
"\n"
"%s"
#, python-format
@@ -1854,7 +1854,7 @@
msgid "Set font"
msgstr "ãã©ã³ãè¨å®"
@@ -4624,7 +4624,7 @@
"ç¨ç´ã®ç«¯"
msgid "Font:"
msgstr "ãã©ã³ãï¼"
@@ -5860,8 +5860,8 @@
msgstr "å®è¡å¤±æï¼"
msgid "Details:"
msgstr "詳細ï¼"
@@ -5948,49 +5948,49 @@
msgstr "詳細ï¼"
#, python-format
msgstr "æªãµãã¼ãã¬ã¤ã¤ã¼ã¿ã¤ã '%s'"
#, fuzzy
msgstr "ããã©ã«ãé åã§ãºã¼ã "
#, python-format
msgstr "ã¨ã©ã¼: ãªã¼ãã³ã§ãã¾ãã '%(file)s'. çç±: %(ret)s. wxGUI çµäº.\n"
msgid ""
"\n"
msgstr " EPGSã³ã¼ããèªãã¾ãã: %s"
msgstr "ééã£ãå¤ï¼ %s "
#, python-format
msgstr "ã©ã¹ã¿ã¼ããã <%s> ããºã¼ã åºæ¥ã¾ãã"
#, python-format
msgstr "ãã¯ãã«ããããä½ãã¾ãã <%s>"
msgid ""
@@ -5998,32 +5998,32 @@
"ç¾å¨ã®å°ççç¯å²ãåå¾ãããã¨ãã§ãã¾ãããwxGUIãå¼·å¶çµäºãã¾ããæåã§g."
"regionãå®è¡ãåé¡ã解決ãã¦ãã ãã"
#, python-format
msgstr ""
#, python-format
msgstr "ãããã¬ã¤ã¤ã¼ <%s> ãã¬ã³ããªã³ã°åºæ¥ã¾ãã"
#, python-format
msgstr "<%s> ãã¬ã³ãã¼ãªã¼ãã¼ã¬ã¤ã§ãã¾ãã"
#, fuzzy
msgstr "ãã¼ã¿ ãã¼ãä¸... "
#, fuzzy
msgstr "ã¬ã³ããªã³ã° "
#, fuzzy
@@ -11915,7 +11915,7 @@
msgstr "DXFãã¡ã¤ã«é¸æï¼"
#, fuzzy
msgid "Text:"
msgstr "ããã¹ã "
@@ -13108,23 +13108,23 @@
msgstr "å°å·ãã¬ãã¥ã¼ "
msgid ""
msgstr ""
msgstr "ç·¨éç¯å²è¡¨ç¤º"
msgid "Rotation:"
msgstr "å転ï¼"
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_ko\n"
"PO-Revision-Date: 2014-05-03 16:44-0400\n"
"Last-Translator: Huidae Cho <grass4u at gmail.com>\n"
"Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
@@ -435,7 +435,7 @@
msgstr ""
#, python-format
@@ -1716,7 +1716,7 @@
msgid "Set font"
msgstr ""
@@ -4276,7 +4276,7 @@
msgstr ""
msgid "Font:"
msgstr ""
@@ -5462,8 +5462,8 @@
msgstr ""
msgid "Details:"
msgstr ""
@@ -5542,77 +5542,77 @@
msgstr ""
#, python-format
msgstr ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgid ""
"\n"
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgid ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
msgstr ""
msgstr ""
@@ -11010,7 +11010,7 @@
msgstr ""
msgid "Text:"
msgstr ""
@@ -12115,23 +12115,23 @@
msgstr ""
msgid ""
msgstr ""
msgstr ""
msgid "Rotation:"
msgstr ""
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_lv.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_lv.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_lv.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_lv\n"
"PO-Revision-Date: 2014-09-14 19:30+0300\n"
"Last-Translator: MÄris NartiÅ¡s <mn at sungis.lv>\n"
"Language-Team: Latvian <lata-l10n at googlegroups.com>\n"
@@ -457,7 +457,7 @@
msgstr ""
#, python-format
@@ -1772,7 +1772,7 @@
msgid "Set font"
msgstr "Iestatīt fontu"
@@ -4410,7 +4410,7 @@
msgstr ""
msgid "Font:"
msgstr "Fonts:"
@@ -5604,8 +5604,8 @@
msgstr ""
msgid "Details:"
msgstr ""
@@ -5684,79 +5684,79 @@
msgstr ""
#, python-format
msgstr ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgid ""
"\n"
msgstr ""
msgstr "NederÄ«ga vÄtÄ«ba: %s"
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr "Nav iespÄjams izveidot jaunu karÅ¡u kopu: %s"
msgid ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, fuzzy
msgstr "Datu ielÄde..."
#, fuzzy
msgstr "ZÄ«mÄt"
#, fuzzy
msgstr "ZÄ«mÄt"
@@ -11249,7 +11249,7 @@
msgstr "AizvÄrt modeļa failu"
#, fuzzy
msgid "Text:"
msgstr "Teksts"
@@ -12389,23 +12389,23 @@
msgstr ""
msgid ""
msgstr ""
msgstr "RÄdÄ«t teksta objektu"
msgid "Rotation:"
msgstr ""
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ml.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ml.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ml.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_ml\n"
"PO-Revision-Date: \n"
"Last-Translator: Mohammed Rashad <rashadkm at gmail.com>\n"
"Language-Team: Malayalam <grass-translations at lists.osgeo.org>\n"
@@ -470,7 +470,7 @@
msgstr ""
#, python-format
@@ -1839,7 +1839,7 @@
msgid "Set font"
msgstr ""
@@ -4520,7 +4520,7 @@
msgstr ""
#, fuzzy
msgid "Font:"
msgstr "à´
à´à´¯à´¾à´³à´¤àµà´¤à´¿à´¨àµà´±àµà´±àµ à´¸à´àµà´àµà´à´°à´£à´"
@@ -5803,8 +5803,8 @@
msgstr ""
msgid "Details:"
msgstr "വിശദ വിവരà´àµà´àµ¾:"
@@ -5883,78 +5883,78 @@
#, python-format
msgstr ""
msgstr ""
#, python-format
msgstr ""
msgid ""
"\n"
msgstr "à´ªàµà´¤à´¿à´¯ മാപàµà´ªàµà´¸àµà´±àµà´±àµ à´à´£àµà´à´¾à´àµà´à´¾àµ» പറàµà´±àµà´¨à´¿à´²àµà´²: %s"
#, python-format
msgstr ""
msgstr "മാപàµà´ªàµà´¸àµà´±àµà´±à´¿à´²àµà´àµà´àµ മാറാൻ à´à´´à´¿à´¯àµà´¨à´¿à´²àµà´² <%s>."
msgid ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
msgstr ""
#, fuzzy
msgstr "മാപàµà´ªàµ à´µàµà´£àµà´àµà´ à´ªàµà´°à´¦àµ¼à´¶à´¿à´ªà´¿à´àµà´àµà´"
msgstr ""
@@ -11629,7 +11629,7 @@
msgstr "ഫയൽ തിരà´àµà´àµà´àµà´àµà´àµà´"
msgid "Text:"
msgstr ""
@@ -12824,23 +12824,23 @@
msgstr ""
msgid ""
msgstr ""
msgstr ""
msgid "Rotation:"
msgstr ""
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_pl.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_pl.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_pl.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_pl\n"
"PO-Revision-Date: 2014-12-22 14:52+0100\n"
"Last-Translator: Milena Nowotarska <do.milenki * gmail.com>\n"
"Language-Team: Polish <grass-translations at lists.osgeo.org>\n"
@@ -474,7 +474,7 @@
"\n"
"'%s'"
#, python-format
@@ -1792,7 +1792,7 @@
msgid "Set font"
msgstr "Ustaw czcionkÄ"
@@ -4521,7 +4521,7 @@
"krawÄdzi papieru"
msgid "Font:"
msgstr "Czcionka:"
@@ -5727,8 +5727,8 @@
msgstr "Wykonanie nie powiodÅo siÄ:"
msgid "Details:"
msgstr "SzczegóÅy:"
@@ -5812,80 +5812,80 @@
msgstr "SzczegóÅy: %s\n"
#, python-format
msgstr "NieobsÅugiwany typ warstwy '%s'"
#, fuzzy
msgstr "PowiÄksz do domyÅlnego regionu"
#, python-format
msgstr ""
"BÅÄ
d: Nie można otworzyÄ '%(file)s'. Powód: %(ret)s. wxGUI zostaÅo "
"zamkniÄte.\n"
msgid ""
"\n"
msgstr "Nie można przeczytaÄ pliku %s"
msgstr "NieprawidÅowa wartoÅÄ: %s"
#, python-format
msgstr "Nie można powiÄkszyÄ do mapy rastrowej <%s>."
#, python-format
msgstr "Nie można powiÄkszyÄ do mapy wektorowej <%s>."
msgid ""
msgstr ""
#, python-format
msgstr "BÅÄD: Renderowanie nie powiodÅo siÄ. SzczegóÅy: %s"
#, python-format
msgstr "Nie można wyÅwietliÄ warstwy mapy <%s>."
#, python-format
msgstr "Nie można wyÅwietliÄ nakÅadki <%s>."
msgstr "Wczytywanie danych"
msgstr "Renderowanie &"
msgstr "Renderowanie..."
@@ -11703,7 +11703,7 @@
msgstr "Wybierz plik"
msgid "Text:"
msgstr "Tekst:"
@@ -12850,23 +12850,23 @@
msgstr "PodglÄ
d wydruku"
msgid ""
msgstr ""
msgstr "Pokaż obiekt tekstowy"
msgid "Rotation:"
msgstr "Rotacja:"
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_pt\n"
"PO-Revision-Date: 2009-11-23 14:10-0000\n"
"Last-Translator: \n"
"Language-Team: Português <grass-translations at lists.osgeo.org>\n"
@@ -485,7 +485,7 @@
msgstr "EmbedGivenNulls: tipo errado de dados!"
#, python-format
@@ -1915,7 +1915,7 @@
msgid "Set font"
msgstr "Establecer tipo de letra"
@@ -4724,7 +4724,7 @@
msgstr ""
#, fuzzy
msgid "Font:"
msgstr "Tamanho do Ãcone"
@@ -6067,8 +6067,8 @@
msgstr "Falha na execução:"
msgid "Details:"
msgstr "Detalhes:"
@@ -6155,80 +6155,80 @@
msgstr "Detalhes:"
#, python-format
msgstr "Tipo de camada de mapa não suportado '%s'"
#, fuzzy
msgstr "Zoom à região pré-definida"
#, python-format
msgstr ""
msgid ""
"\n"
msgstr "Não é possÃvel ler os códigos EPSG: %s"
msgstr "Valor não válido: %s"
msgstr "Mapa raster a ser pesquisado"
msgstr "No se puede crear el mapa vectorial <%s>."
msgid ""
msgstr ""
msgstr "ERRO: Falha no rendering"
#, python-format
msgstr ""
#, python-format
msgstr ""
#, fuzzy
msgstr "Carregando dados..."
#, fuzzy
msgstr "Render"
#, fuzzy
msgstr "Render"
@@ -12640,7 +12640,7 @@
msgstr "Seleccionar archivo DXF:"
#, fuzzy
msgid "Text:"
msgstr "Teste"
@@ -13883,25 +13883,25 @@
msgstr "Vista previa de impressão"
msgid ""
msgstr ""
#, fuzzy
msgstr "Mostrar comp. extent"
#, fuzzy
msgid "Rotation:"
msgstr "Rotación:"
#, fuzzy
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt_br.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt_br.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt_br.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -10,7 +10,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_pt_br\n"
"PO-Revision-Date: 2011-08-12 16:32-0300\n"
"Language-Team: Português do Brasil <grass-translations at lists.osgeo.org>\n"
@@ -487,7 +487,7 @@
#, python-format
@@ -1938,7 +1938,7 @@
#, fuzzy
msgid "Set font"
msgstr "Estabelecer tipo de letra"
@@ -4866,7 +4866,7 @@
msgstr ""
#, fuzzy
msgid "Font:"
@@ -6213,8 +6213,8 @@
#, fuzzy
msgid "Details:"
msgstr "Detalhes:"
@@ -6305,80 +6305,80 @@
msgstr "Detalhes:"
#, fuzzy
#, python-format
msgstr ""
msgid ""
"\n"
msgid ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, fuzzy
#, fuzzy
msgstr "Render"
#, fuzzy
msgstr "Render"
@@ -13030,7 +13030,7 @@
#, fuzzy
msgid "Text:"
msgstr "Teste"
@@ -14271,25 +14271,25 @@
msgid ""
msgstr ""
#, fuzzy
#, fuzzy
msgid "Rotation:"
msgstr "Rotación:"
#, fuzzy
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ro.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ro.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ro.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_ro\n"
"PO-Revision-Date: 2013-07-17 21:26+0200\n"
"Last-Translator: Andreea Marin <andreea.marin09 yahoo.com>\n"
"Language-Team: GRASS Translation Team <grass-translations at lists.osgeo.org>\n"
@@ -478,7 +478,7 @@
"\n"
"%s"
#, python-format
@@ -1828,7 +1828,7 @@
msgid "Set font"
msgstr "SeteazÄ font"
@@ -4617,7 +4617,7 @@
"marginea paginii"
msgid "Font:"
msgstr "Font:"
@@ -5840,8 +5840,8 @@
msgstr "ExecuÈie eÈuatÄ:"
msgid "Details:"
msgstr "Detalii:"
@@ -5930,50 +5930,50 @@
msgstr "Detalii: %s\n"
#, python-format
msgstr "Tipul stratutului neacceptat '%s'"
#, fuzzy
msgstr "MÄreÈte la regiunea implicitÄ"
#, python-format
msgstr ""
"Eroare: Nu s-a putut deschide '%(file)s'. Motiv: %(ret)s. wxGUI închisÄ.\n"
msgid ""
"\n"
msgstr "Nu s-a putut citi fiÈierul %s"
msgstr "Valoare invalidÄ: %s"
#, python-format
msgstr "Nu s-a putut da zoom la harta raster<%s>."
#, python-format
msgstr "Nu s-a putut da zoom la harta vectorialÄ<%s>."
msgid ""
@@ -5981,32 +5981,32 @@
"Nu s-a putut obÈine extinderea geograficÄ curentÄ. ForÈaÈi închiderea wxGUI. "
"VÄ rugÄm rulaÈi manual g.region pentru a rezolva problema."
#, python-format
msgstr "EROARE: Redarea a eÈuat. Detalii: %s"
#, python-format
msgstr "Nu s-a putut reda stratul <%s>."
#, python-format
msgstr "Nu s-a putut reda suprapunerea <%s>."
#, fuzzy
msgstr "Ãncarca data..."
#, fuzzy
msgstr "Redare"
#, fuzzy
msgstr "Redare"
@@ -12067,7 +12067,7 @@
msgstr "Alege un fiÈier"
#, fuzzy
msgid "Text:"
msgstr "Text"
@@ -13240,23 +13240,23 @@
msgstr "PrinteazÄ previzualizare"
msgid ""
msgstr ""
msgstr "AfiÈeazÄ obiectul text"
msgid "Rotation:"
msgstr "RotaÈia:"
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ru.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ru.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ru.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_ru\n"
"PO-Revision-Date: 2008-10-10 19:44-0600\n"
"Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
"Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
@@ -479,7 +479,7 @@
"\n"
"%s"
#, python-format
@@ -1891,7 +1891,7 @@
msgid "Set font"
msgstr "УÑÑановиÑе ÑÑиÑÑ"
@@ -4697,7 +4697,7 @@
msgstr ""
#, fuzzy
msgid "Font:"
msgstr "Ð Ð°Ð·Ð¼ÐµÑ Ð¸ÐºÐ¾Ð½ÐºÐ¸:"
@@ -6036,8 +6036,8 @@
msgstr "ÐÑполнение пÑеÑвано Ñ Ð¾Ñибкой:"
msgid "Details:"
msgstr "ÐодÑобноÑÑи:"
@@ -6123,80 +6123,80 @@
#, python-format
msgstr "Тип ÑÐ»Ð¾Ñ '%s' не поддеÑживаеÑÑÑ"
#, fuzzy
msgstr "ÐаÑÑÑабиÑоваÑÑ Ð´Ð¾ Ñегиона по ÑмолÑаниÑ"
#, python-format
msgstr ""
msgid ""
"\n"
msgstr "Ðевозможно пÑоÑиÑаÑÑ ÐºÐ¾Ð´Ñ EPSG: %s"
msgstr "ÐепÑавилÑное знаÑение: %s "
msgstr "Ðевозможно маÑÑÑабиÑоваÑÑ ÑаÑÑÑовÑй Ñлой <%s>."
msgstr "Ðе Ð¼Ð¾Ð³Ñ ÑоздаÑÑ Ð½Ð¾Ð²Ñй векÑоÑнÑй Ñлой <%s>."
msgid ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr "Ðевозможно пеÑеÑиÑоваÑÑ Ñлой <%s>."
#, python-format
msgstr "Ðевозможно пеÑеÑиÑоваÑÑ Ð¾Ð²ÐµÑлей <%s>."
#, fuzzy
msgstr "ÐагÑÑзка даннÑÑ
#, fuzzy
msgstr "ÐÑÑиÑоваÑÑ"
#, fuzzy
msgstr "ÐÑÑиÑоваÑÑ"
@@ -12365,7 +12365,7 @@
msgstr "ÐÑбÑаÑÑ Ñайл DXF:"
#, fuzzy
msgid "Text:"
msgstr "ТеÑÑ"
@@ -13607,24 +13607,24 @@
msgstr "ÐÑедваÑиÑелÑнÑй пÑоÑмоÑÑ"
msgid ""
msgstr ""
#, fuzzy
msgstr "ÐоказаÑÑ ÑаÑÑеÑнÑй оÑ
ваÑ"
msgid "Rotation:"
msgstr "ÐовоÑоÑ:"
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_th.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_th.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_th.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_th\n"
"PO-Revision-Date: 2008-01-05 15:19+0700\n"
"Language-Team: Thai <grass-translations at lists.osgeo.org>\n"
@@ -471,7 +471,7 @@
msgstr ""
#, python-format
@@ -1833,7 +1833,7 @@
msgid "Set font"
msgstr ""
@@ -4527,7 +4527,7 @@
msgstr ""
#, fuzzy
msgid "Font:"
msgstr "à¸à¸¸à¸"
@@ -5829,8 +5829,8 @@
msgstr ""
msgid "Details:"
msgstr ""
@@ -5909,80 +5909,80 @@
msgstr ""
#, python-format
msgstr ""
#, fuzzy
msgstr "ยà¹à¸/à¸à¸¢à¸²à¸¢ à¹à¸à¸à¸µà¹à¸à¸à¸à¹à¸à¸à¸«à¸¥à¸±à¸"
#, python-format
msgstr ""
msgid ""
"\n"
msgstr "à¸à¹à¸à¸à¸à¸±à¸ à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¹à¸ªà¹à¸ 2 à¹à¸à¸à¸à¸µà¹"
#, python-format
msgstr ""
msgid ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, fuzzy
msgstr "à¸à¸³à¸¥à¸±à¸à¸à¹à¸²à¸à¸à¹à¸à¸¡à¸¹à¸¥ ..."
#, fuzzy
msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸£à¸ªà¹à¸à¸à¸£à¹"
msgstr ""
@@ -11876,7 +11876,7 @@
msgstr "à¹à¸à¸´à¸à¸à¸·à¹à¸à¸à¸µà¹à¸à¸³à¸à¸²à¸à¸à¸µà¹à¸¡à¸µà¸à¸¢à¸¹à¹"
#, fuzzy
msgid "Text:"
msgstr "à¸à¸à¸ªà¸à¸"
@@ -13068,23 +13068,23 @@
msgstr ""
msgid ""
msgstr ""
msgstr ""
msgid "Rotation:"
msgstr ""
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_tr.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_tr.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_tr.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_tr\n"
"PO-Revision-Date: 2010-12-01 03:06+0200\n"
"Last-Translator: Fatih <bounfat at gmail.com>\n"
"Language-Team: Türkçe <grass-translations at lists.osgeo.org>\n"
@@ -485,7 +485,7 @@
"\n"
"%s"
#, python-format
@@ -1897,7 +1897,7 @@
msgid "Set font"
msgstr "Yazıtipini ayarla"
@@ -4686,7 +4686,7 @@
msgstr ""
#, fuzzy
msgid "Font:"
msgstr "Format:"
@@ -6022,8 +6022,8 @@
msgstr "ÃalıÅtırmada hata:"
msgid "Details:"
msgstr "Ayrıntılar:"
@@ -6102,80 +6102,80 @@
#, python-format
msgstr ""
#, fuzzy
msgstr "Varsayılan bölgeyi yakınlaÅtır"
#, python-format
msgstr ""
msgid ""
"\n"
msgstr "EPSG Kodları okunamıyor: %s"
msgstr "Geçersiz DeÄer: %s"
msgstr "<%s> raster haritası büyütülemiyor."
msgstr "<%s> vektör haritası oluÅturulamıyor."
msgid ""
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgstr ""
#, fuzzy
msgstr "Veri yükleniyor..."
#, fuzzy
msgstr "Render"
#, fuzzy
msgstr "Render"
@@ -12271,7 +12271,7 @@
msgstr "DXF dosyasını Seç:"
#, fuzzy
msgid "Text:"
msgstr "Sınama"
@@ -13509,23 +13509,23 @@
msgstr "Yazdırma önizleme"
msgid ""
msgstr ""
msgstr ""
msgid "Rotation:"
msgstr "Döndürme:"
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_vi.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_vi.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_vi.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_vi\n"
"PO-Revision-Date: 2010-08-27 16:40+0700\n"
"Language-Team: American English <kde-i18n-doc at kde.org>\n"
@@ -485,7 +485,7 @@
"\n"
"%s"
#, python-format
@@ -1889,7 +1889,7 @@
msgid "Set font"
msgstr "Äặt phông"
@@ -4683,7 +4683,7 @@
msgstr ""
#, fuzzy
msgid "Font:"
msgstr "Äá»nh dạng:"
@@ -6023,8 +6023,8 @@
msgstr "Thá»±c thi lá»nh thất bại:"
msgid "Details:"
msgstr "Chi tiết:"
@@ -6109,49 +6109,49 @@
msgstr "Chi tiết:"
#, python-format
msgstr "Kiá»u lá»p bản Äá» '%s' chưa ÄÆ°á»£c há» trợ"
#, fuzzy
msgstr "Phóng Äến vùng mặc Äá»nh"
#, python-format
msgstr ""
msgid ""
"\n"
msgstr "Không thá» Äá»c táºp tin EPSG: '%s'"
msgstr "Giá trá» không hợp lá»: %s"
msgstr "Không thá» phóng Äến bản Äá» raster <%s>."
msgstr "Không thá» tạo bản Äá» véc tÆ¡ <%s>."
#, fuzzy
msgid ""
@@ -6160,32 +6160,32 @@
"Không thá» lấy phạm vi Äá»a lý hiá»n tại. Buá»c phải thoát wxGUI. Vui lòng chạy "
"thá»§ công lá»nh g.region Äá» khắc phục lá»i nà y."
#, python-format
msgstr ""
#, python-format
msgstr "Không thá» vẽ lá»p bản Äá» <%s>."
#, python-format
msgstr "Không thá» vẽ chá»ng <%s>."
#, fuzzy
msgstr "Äang nạp dữ liá»u..."
#, fuzzy
msgstr "Vẽ"
#, fuzzy
msgstr "Vẽ"
@@ -12428,7 +12428,7 @@
msgstr "Chá»n táºp tin"
#, fuzzy
msgid "Text:"
msgstr "Kiá»m tra"
@@ -13658,24 +13658,24 @@
msgstr "Xem trưá»c khi in"
msgid ""
msgstr ""
#, fuzzy
msgstr "Hiá»n thá» phạm vi tÃnh toán"
msgid "Rotation:"
msgstr "Xoay:"
msgid ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_zh.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_zh.po 2015-02-20 17:09:55 UTC (rev 64703)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_zh.po 2015-02-20 19:46:01 UTC (rev 64704)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasswxpy_zh\n"
"PO-Revision-Date: 2015-01-19 13:23-0600\n"
"Last-Translator: Shulin Yang <shulin.yang.9 at gmail.com>\n"
"Language-Team: Simplified Chinese <grass-translations at lists.osgeo.org>\n"
@@ -498,7 +498,7 @@
msgstr "è£
è½½ctypesåºå¤±è´¥"
#, python-format
msgid "Set font"
msgstr "设置åä½"
@@ -4647,7 +4647,7 @@
"çº¸å¼ è¾¹ç¼"
#, fuzzy
msgid "Font:"
msgstr "OGR æ ¼å¼"
@@ -5997,8 +5997,8 @@
msgstr "æä½å¤±è´¥ï¼"
msgid "Details:"
msgstr "ç»èï¼"
@@ -6077,79 +6077,79 @@
msgstr "读å %s ..."
#, python-format
msgstr "䏿¯æå°å¾å±ç±»å'%s'"
msgstr "æ£å¨å°è¯æ¢å¤é»è®¤åºå..."
#, python-format
msgstr "éè¯¯ï¼æ æ³æå¼'%(file)s'ãåå ï¼%(ret)s. éåºwxGUIã\n"
msgid ""
"\n"
msgstr "æ æ³å建æ
æ ¼å°å¾ %s"
msgstr "æ æçåºåï¼%s"
msgstr "æ æ³å建æ
æ ¼å°å¾ %s"
msgstr "æ æ³æ¾å°ç¢éå°å¾ [%s]"
msgstr "æ æ³å建æ
æ ¼å°å¾ %s"
msgid ""
msgstr "æ æ³è·åå½åå°çèå´ã强å¶éåºwxGUIã请æå¨è¿è¡g.region以解å³è¯¥é®é¢ã"
msgstr "读ådigæä»¶...\n"
#, python-format
msgstr "æ æ³æ¸²æå°å¾å±<%s>ã"
#, python-format
msgstr "æ æ³æ¸²æå±<%s>ã"
#, fuzzy
msgstr "读åå°å¾"
#, fuzzy
msgstr "éæ°æ¸²æå°å¾"
#, fuzzy
msgstr "读åå°å¾"
@@ -11819,7 +11819,7 @@
msgstr "æ·è´è¡¨å¤±è´¥"
#, fuzzy
msgid "Text:"
msgstr "ææ¬"
@@ -13052,24 +13052,24 @@
msgstr "æå°é¢è§"
msgid ""
msgstr ""
#, fuzzy
msgstr "æçè·¯å¾"
msgid "Rotation:"
msgstr "æè½¬ï¼"
msgid ""
