[GRASS-SVN] r64721 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Sun Feb 22 01:39:17 PST 2015
Author: martinl
Date: 2015-02-22 01:39:17 -0800 (Sun, 22 Feb 2015)
New Revision: 64721
grass/trunk/scripts/g.extension/g.extension.py
g.extension: message cosmetics (addons metadata)
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2015-02-22 09:11:30 UTC (rev 64720)
+++ grass/trunk/scripts/g.extension/g.extension.py 2015-02-22 09:39:17 UTC (rev 64721)
@@ -198,7 +198,7 @@
if force:
write_xml_modules(fXML)
else:
- grass.warning(_("No metadata file available"))
+ grass.warning(_("No addons metadata file available"))
return []
# read XML file
@@ -257,7 +257,7 @@
for mnode in tnode.findall('task'):
mlist.append(mnode.get('name'))
except HTTPError:
- grass.fatal(_("Unable to fetch metadata file"))
+ grass.fatal(_("Unable to fetch addons metadata file"))
return tdict
@@ -276,7 +276,7 @@
tlist.append(mnode.get('name'))
break
except HTTPError:
return tlist
@@ -335,9 +335,9 @@
pattern = re.compile(r'(<li><a href=".+">)(.+)(</a></li>)', re.IGNORECASE)
if flags['c']:
- grass.warning(_("Flag 'c' ignored, metadata file not available"))
+ grass.warning(_("Flag 'c' ignored, addons metadata file not available"))
if flags['g']:
- grass.warning(_("Flag 'g' ignored, metadata file not available"))
+ grass.warning(_("Flag 'g' ignored, addons metadata file not available"))
prefix = ['d', 'db', 'g', 'i', 'm', 'ps',
'p', 'r', 'r3', 's', 'v']
@@ -488,7 +488,7 @@
if ret != 0:
grass.warning(_('Installation failed, sorry. Please check above error messages.'))
else:
- grass.message(_("Updating metadata file..."))
+ grass.message(_("Updating addons metadata file..."))
blist = install_extension_xml(url, mlist)
for module in blist:
update_manual_page(module)
@@ -524,13 +524,13 @@
'modules' : mlist,
except HTTPError:
- grass.error(_("Unable to read metadata file from the remote server"))
+ grass.error(_("Unable to read addons metadata file from the remote server"))
if not data:
- grass.warning(_("No metadata available"))
+ grass.warning(_("No addons metadata available"))
return
if name not in data:
- grass.warning(_("No metadata available for <%s>") % name)
+ grass.warning(_("No addons metadata available for <%s>") % name)
return
fXML = os.path.join(options['prefix'], 'toolboxes.xml')
@@ -587,7 +587,7 @@
try:
tree = etree.fromstring(f.read())
except:
- grass.warning(_("Unable to parse '%s'. Metadata file not updated.") % url)
+ grass.warning(_("Unable to parse '%s'. Addons metadata file not updated.") % url)
return bList
for mnode in tree.findall('task'):
@@ -620,10 +620,10 @@
except:
if not data:
return []
fXML = os.path.join(options['prefix'], 'modules.xml')
@@ -645,7 +645,7 @@
break
- grass.warning(_("No metadata found for <%s>") % name)
+ grass.warning(_("No addons metadata found for <%s>") % name)
continue
ndata = data[name]
@@ -814,7 +814,7 @@
remove_modules(mlist, force)
if force:
remove_extension_xml(mlist)
grass.message(_("Extension <%s> successfully uninstalled.") % options['extension'])
else:
