[GRASS-SVN] r64731 - in grass-addons/grass7/raster: . r.catchment
svn_grass at osgeo.org
Mon Feb 23 13:05:19 PST 2015
Author: isaacullah
Date: 2015-02-23 13:05:19 -0800 (Mon, 23 Feb 2015)
New Revision: 64731
Added:
grass-addons/grass7/raster/r.catchment/
grass-addons/grass7/raster/r.catchment/Makefile
grass-addons/grass7/raster/r.catchment/description.html
grass-addons/grass7/raster/r.catchment/r.catchment
Adding GRASS 7 version of my r.catchment script. All variable names have been updated to the GRASS 7 standard, and all internal python code updated to GRASS 7 styles. Added a proper description.html file and makefile.
Added: grass-addons/grass7/raster/r.catchment/Makefile
--- grass-addons/grass7/raster/r.catchment/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.catchment/Makefile 2015-02-23 21:05:19 UTC (rev 64731)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.catchment
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.catchment/description.html
--- grass-addons/grass7/raster/r.catchment/description.html (rev 0)
+++ grass-addons/grass7/raster/r.catchment/description.html 2015-02-23 21:05:19 UTC (rev 64731)
@@ -0,0 +1,43 @@
+<h2>DESCRIPTION</h2>
+<em>r.catchment</em> is a module that facilitates modeling "catchments" around point locations according to a walking cost function. The module is particularly aimed at "Site Catchment Analysis" for archaeology, but could be potentially useful in any number of appliations where delimiting an area based on walking-costs is desireable. Although defining a catchment based on a threshold in walking-costs (or time) can be undertaken using <em>r.walk</em> or <em>r.cost</em> alone, this addon module allows the user to enter a pre-determined square meterage (option <b>area</b>) for the resultant catchment, which is a different approach. This is useful for applications where the user wants to make a catchment of a particular size (e.g., certain number of square meters needed for farmed fields), and doesn't want to spend time via trial and error experimenting with different cost radii.
+Additionally, this module allows the user to enter a slope threshold (option <b>sigma</b>), which will mask out areas of higher slope. This is useful for delimiting catchments that are of generally flat land (e.g., areas where agriculture are likely).
+<h3>Options and flags:</h3>
+<em>r.catchment</em> requires an input elevation map, <b>elevation</b>, and an input vector points map of starting locations, <b>start_points</b>. <b>area</b> is also requited, which is an integer value for the size of the desired catchment (in the map units of the defined location/region). The final required parameter is <b>map_val</b>, wich is the integer value to write to the areas defined as part of the catchment in the output map, <b>buffer</b>. The optional value, <b>sigma</b> is the slope threshold cut off value. Slopes above <b>sigma</b> will be masked out during the determination of the catchment configuration. There are two native flags for <em>r.catchment</em>. <b>-c</b> allows you to keep the interim cost surface maps made. <b>-l</b> allows you to show a list of the cost values in that cost map, along with the size of the catchments they delineate. All other flags and options are inherited from <em>r.walk</em> (see the<a href="r.walk.html">r.walk</a> help page fo
r more information on these).
+<h2>NOTES</h2>
+The module will attempt to find the cost radius that defines an area close to the value of <b>area</b>, but em will likely slightly overestimate the catchement size. The module will display the actual area of the defined catchment in the Command Output.
+By default, <em>r.catchment</em> will create a <b>friction</b> map of value 0, which, when input into <em>r.walk</em> will yeild a cost surface based on walking times only. The user may optionally create a <b>friction</b> map, however, and, if used, r.walk will consider these costs this as well when determining the cost surface used to determine the catchment.
+The input vector points map can be manually digitized (with <em>v.digit</em>) over topographic or cultural features, or can be created as a series of random points (with <em>r.random</em> or <em>v.random</em>).
+In the case of multiple input points, the routine will attempt to equally divide the area (<b>area</b>) between all input points to determine catchments for each point. The total area of all these catchments will sum (close) to <b>area</b>. If two input points are close, their catchments may overlap. In this case, the routine will "meld" the two, and the melded catchment will still be of an area close to <b>area</b>. If truly overlapping catchments are desired, then the routine should be run independantly for each individual start point.
+<p>
+<h2>EXAMPLES</h2>
+Delimit a catchment of 5,000,000 square meters around a single start point, ignoring areas of slope > 15 degrees:<br>
+<div class="code"><pre>
+r.catchment elevation=DEM10m start_points=site buffer=test_catchment sigma=15 area=5000000 map_val=1
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.walk.html">r.walk</a>, <a href="r.cost.html">r.cost</a>
+</em>
+<h2>AUTHOR</h2>
+Isaac Ullah
+<p>
+Updated for GRASS 7, 23, Feb. 2015.
+<p>
+<i>Last changed: $Date: Mon Feb 23 13:42:13 MST 2015 $</i>
Added: grass-addons/grass7/raster/r.catchment/r.catchment
--- grass-addons/grass7/raster/r.catchment/r.catchment (rev 0)
+++ grass-addons/grass7/raster/r.catchment/r.catchment 2015-02-23 21:05:19 UTC (rev 64731)
@@ -0,0 +1,320 @@
+#!/usr/bin/python
+# MODULE: r.catchment
+# AUTHOR(S): Isaac Ullah, Arizona State University
+# PURPOSE: Creates a raster buffer of specified area around vector points
+# using cost distances. Module requires r.walk.
+# ACKNOWLEDGEMENTS: National Science Foundation Grant #BCS0410269
+# COPYRIGHT: (C) 2015 by Isaac Ullah, Arizona State University
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Creates a raster buffer of specified area around vector points using cost distances using r.walk. NOTE: please run g.region first to make sure region boundaries and resolution match input elevation map.
+#%END
+#%option
+#% key: elevation
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: Input elevation map (DEM)
+#% required : yes
+#%END
+#%option
+#% key: in_cost
+#% type: string
+#% description: Input cost map (This will override the input elevation map, if none specified, one will be created from input elevation map with r.walk)
+#% required : no
+#%END
+#%option
+#% key: start_points
+#% type: string
+#% gisprompt: new,vector,vector
+#% description: Name of input vector site points map
+#% required : yes
+#%END
+#%option
+#% key: friction
+#% type: string
+#% description: Optional map of friction costs. If no map selected, default friction=0 making output reflect time costs only
+#% answer:
+#% required : no
+#%END
+#%option
+#% key: a
+#% type: double
+#% description: Coefficients for walking energy formula parameters a,b,c,d
+#% answer: 0.72
+#% required : no
+#%END
+#%option
+#% key: b
+#% type: double
+#% description:
+#% answer: 6.0
+#% required : no
+#%END
+#%option
+#% key: c
+#% type: double
+#% description:
+#% answer: 1.9998
+#% required : no
+#%END
+#%option
+#% key: d
+#% type: double
+#% description:
+#% answer: -1.9998
+#% required : no
+#%END
+#%option
+#% key: lambda
+#% type: double
+#% description: Lambda value for cost distance calculation (for combining friction costs with walking costs)
+#% answer: 1
+#% required : no
+#%END
+#%option
+#% key: slope_factor
+#% type: double
+#% description: Slope factor determines travel energy cost per height step
+#% answer: -0.2125
+#% required : no
+#%END
+#%option
+#% key: buffer
+#% type: string
+#% description: Output buffer map
+#% required : yes
+#%END
+#%option
+#% key: sigma
+#% type: double
+#% description: Slope threshold for mask
+#% answer:
+#% required : no
+#%END
+#%option
+#% key: area
+#% type: integer
+#% description: Area of buffer (Integer value to nearest 100 square map units)
+#% answer: 5000000
+#% required : yes
+#%END
+#%option
+#% key: map_val
+#% type: integer
+#% description: Integer value for output catchment area (all other areas will be Null)
+#% answer: 1
+#% required : yes
+#%END
+#%flag
+#% key: k
+#% description: -k Use knight's move for calculating cost surface (slower but more accurate)
+#%END
+#%flag
+#% key: c
+#% description: -c Keep cost surface used to calculate buffers
+#%END
+#%flag
+#% key: l
+#% description: -l Show a list of all cost surface values and the area of the catchment that they delimit
+#%END
+import sys
+import os
+import subprocess
+import tempfile
+import random
+grass_install_tree = os.getenv('GISBASE')
+sys.path.append(grass_install_tree + os.sep + 'etc' + os.sep + 'python')
+import grass.script as grass
+# first define a useful custom method
+# m is a grass/bash command that will generate some list of keyed info to stdout where the keys are numeric values, n is the character that separates the key from the data, o is a defined blank dictionary to write results to
+def out2dictnum(m, n, o):
+ p1 = subprocess.Popen('%s' % m, stdout=subprocess.PIPE, shell='bash')
+ p2 = p1.stdout.readlines()
+ for y in p2:
+ y0,y1 = y.split('%s' % n)
+ y0num = float(y0)
+ o[y0num] = y1.strip('\n')
+#main block of code starts here
+def main():
+ pid = os.getpid()
+ #setting up variables for use later on
+ elevation = options["elevation"]
+ start_points = options["start_points"]
+ lmbda = options["lambda"]
+ slope_factor = options["slope_factor"]
+ a = options["a"]
+ b = options["b"]
+ c = options["c"]
+ d = options["d"]
+ sigma = options["sigma"]
+ area = float(options["area"])
+ buffer = options["buffer"]
+ mapval = options["map_val"]
+ w_coefs = a + ',' + b + ',' + c + ',' + d
+ if "MASK" in grass.list_grouped('rast')[grass.gisenv()['MAPSET']] and bool(options["sigma"]) is True:
+ grass.message('There is already a MASK in place, and you have also selected to mask slope values above %s.\n The high slope areas (slope mask) will be temporarily added to current MASKED areas for the calcualtion of the catchment geometry.\n The original MASK will be restored when the module finishes' % sigma)
+ ismask = 2
+ elif "MASK" in grass.list_grouped('rast')[grass.gisenv()['MAPSET']]:
+ grass.message('There is a MASK in place. The areas MASKed out will be ignored while calculating catchment geometry.')
+ ismask = 1
+ else:
+ ismask = 0
+ grass.message("Wanted buffer area=%s\n" % int(area))
+ if bool(options["in_cost"]) is True:
+ grass.message('\n\nUsing input cost surface\n')
+ cost = options["in_cost"]
+ else:
+ grass.message('\n\nstep 1 of 4: Calculating cost surface\n')
+ cost = 'temporary.cost.%s' % pid
+ if bool(options["friction"]) is True:
+ grass.message('Calculating costs using input friction map\n')
+ friction = options["friction"]
+ else:
+ grass.message('Calculating for time costs only')
+ friction = "temporary.friction.%s" % pid
+ grass.mapcalc("${out} = if(isnull(${rast1}), null(), 0)", overwrite = grass.overwrite(), quiet = True, out = friction, rast1 = elevation)
+ if flags["k"] is True:
+ grass.message('Using Knight\'s move\n')
+ #NOTE! because "lambda" is an internal python variable, it is impossible to enter the value for key "lambda" in r.walk. It ends up with a python error.
+ grass.run_command('r.walk', quiet = True, overwrite = grass.overwrite(), flags = 'k', elevation = elevation, friction = friction, output = cost, start_points = start_points, walk_coeff = w_coefs, slope_factor = slope_factor)
+ else:
+ grass.run_command('r.walk', quiet = True, overwrite = grass.overwrite(), elevation = elevation, friction = friction, output = cost, start_points = start_points, percent_memory = '100', walk_coeff = w_coefs, slope_factor = slope_factor)
+ if bool(options["friction"]) is False:
+ grass.run_command('g.remove', quiet = True, flags = 'f', type = 'raster', name = friction)
+ if bool(options["sigma"]) is True:
+ grass.message('\n\nCreating optional slope mask\n')
+ slope = "temporary.slope.%s" % pid
+ grass.run_command('r.slope.aspect', quiet = True, overwrite = grass.overwrite(), elevation = elevation, slope = slope)
+ if ismask == 2:
+ grass.mapcalc("MASK=if(${rast1} <= ${sigma}, 1, if(${tempmask}, 1, null()))", overwrite = grass.overwrite(), quiet = True, sigma = sigma, rast1 = slope, tempmask = tempmask)
+ else:
+ grass.mapcalc("MASK=if(${rast1} <= ${sigma}, 1, null())", overwrite = grass.overwrite(), quiet = True, sigma = sigma, rast1 = slope)
+ else:
+ grass.message('No slope mask created')
+ if flags["l"] is True:
+ grass.message('\n\nCalculating list of possible catchment configurations\n')
+ grass.message("cost value | catchment area")
+ areadict = {}
+ out2dictnum('r.stats -Aani input=' + cost + ' fs=, nv=* nsteps=255', ',', areadict)
+ testarea = 0
+ #start the loop, and list the values
+ for key in sorted(areadict):
+ testarea = testarea + int(float(areadict[key]))
+ grass.message("%s | %s" % (int(key), testarea))
+ if flags["c"] is True:
+ if bool(options["in_cost"]) is False:
+ grass.run_command('g.rename', overwrite = grass.overwrite(), quiet = True, rast = 'temporary.cost.%s,%s_cost_surface' % (pid, buffer))
+ grass.message('Cleaning up...(keeping cost map)')
+ grass.run_command('g.remove', quiet = True, flags = 'f', type = 'raster', name = 'cost.reclass.%s' % pid)
+ else:
+ grass.message('Cleaning up...1')
+ else:
+ grass.message('Cleaning up...2')
+ grass.run_command('g.remove', quiet = True, flags = 'f', type = 'raster', name = 'cost.reclass.%s,temporary.cost.%s' % (pid, pid))
+ else:
+ grass.message('Cleaning up...3')
+ grass.run_command('g.remove', quiet = True, flags = 'f', type = 'raster', name = slope)
+ if ismask == 2:
+ grass.message('Reinstating original MASK...')
+ grass.run_command('g.rename', overwrite = grass.overwrite(), quiet = "True", rast = tempmask +',MASK')
+ elif ismask == 0 and bool(options["sigma"]) is True:
+ grass.run_command('g.remove', quiet = True, flags = 'f', type = 'raster', name = 'MASK')
+ elif ismask == 1:
+ grass.message('Keeping original MASK')
+ grass.message(' DONE!')
+ return
+ else:
+ grass.message('\n\nCalculating buffer\n')
+ areadict = {}
+ tot_area = 0
+ tot_area = tot_area + int(float(areadict[key]))
+ maxcost = key
+ grass.message("Maximum cost distance value %s covers an area of %s square map units\n\nCommencing to find a catchment configuration.....\n\n" % (int(maxcost), tot_area))
+ testarea = 0
+ lastarea = 0
+ lastkey = 0
+ #start the loop, and home in on the target range
+ if testarea >= area:
+ break
+ lastkey = key
+ lastarea = testarea
+ if (testarea - area) <= (area - lastarea):
+ cutoff = key
+ displayarea = testarea
+ else:
+ cutoff = lastkey
+ displayarea = lastarea
+ grass.message("Catchment configuration found! Cost cutoff %s produces a catchment of %s square map units." % (int(cutoff), displayarea))
+ grass.message('\n\nCreating output map\n')
+ temp = tempfile.NamedTemporaryFile()
+ temp.write('0 thru %s = %s\n' % (int(cutoff), mapval))
+ temp.flush()
+ grass.run_command('r.reclass', overwrite = grass.overwrite(), input = cost, output = 'cost.reclass.%s' % pid, rules = temp.name)
+ temp.close()
+ grass.mapcalc("${out}=if(isnull(${cost}), null(), ${cost})", overwrite = grass.overwrite(), quiet = True, cost = "cost.reclass.%s" % pid, out = buffer)
+ grass.message("\nThe output catchment map will be named %s" % buffer)
+ grass.run_command('r.colors', quiet = True, map = buffer, color = 'ryb')
+ grass.run_command('g.rename', overwrite = grass.overwrite(), quiet = True, rast = 'temporary.cost,%s_cost_surface' % (buffer))
+ else:
+ else:
+ else:
+ if ismask == 2:
+ grass.run_command('g.remove', quiet = True, flags = 'f', type = 'raster', name ='MASK')
+ elif ismask == 1:
+ return
+# here is where the code in "main" actually gets executed. This way of programming is neccessary for the way g.parser needs to run in GRASS 7.
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
+ exit(0)
Property changes on: grass-addons/grass7/raster/r.catchment/r.catchment
___________________________________________________________________
Added: svn:executable
