[GRASS-SVN] r63911 - in grass/trunk: display/d.thematic.area include include/defs lib/arraystats vector/v.class
Thu Jan 1 11:45:15 PST 2015
Author: martinl
Date: 2015-01-01 11:45:14 -0800 (Thu, 01 Jan 2015)
New Revision: 63911
   grass/trunk/display/d.thematic.area/main.c
   grass/trunk/include/arraystats.h
   grass/trunk/include/defs/arraystats.h
   grass/trunk/lib/arraystats/class.c
   grass/trunk/vector/v.class/main.c
arraystatslib: add AS_option_to_algorithm()
Modified: grass/trunk/display/d.thematic.area/main.c
--- grass/trunk/display/d.thematic.area/main.c	2015-01-01 19:26:41 UTC (rev 63910)
+++ grass/trunk/display/d.thematic.area/main.c	2015-01-01 19:45:14 UTC (rev 63911)
@@ -325,9 +325,9 @@
 	    /* Get classbreaks for given algorithm and number of classbreaks.
 	     * class_info takes any info coming from the classification algorithms */
-	    class_info =
-		AS_class_apply_algorithm(algo_opt->answer, data, nrec, &nbreaks,
-                                         breakpoints);
+	    class_info = AS_class_apply_algorithm(AS_option_to_algorithm(algo_opt),
+                                                  data, nrec, &nbreaks,
+                                                  breakpoints);
 	else {
Modified: grass/trunk/include/arraystats.h
--- grass/trunk/include/arraystats.h	2015-01-01 19:26:41 UTC (rev 63910)
+++ grass/trunk/include/arraystats.h	2015-01-01 19:45:14 UTC (rev 63911)
@@ -22,6 +22,12 @@
     double stdev;
+#define CLASS_INTERVAL 1
+#define CLASS_STDEV    2
+#define CLASS_QUANT    3
+#define CLASS_EQUIPROB 4
+#define CLASS_DISCONT  5
 #include <grass/defs/arraystats.h>
 #endif
Modified: grass/trunk/include/defs/arraystats.h
--- grass/trunk/include/defs/arraystats.h	2015-01-01 19:26:41 UTC (rev 63910)
+++ grass/trunk/include/defs/arraystats.h	2015-01-01 19:45:14 UTC (rev 63911)
@@ -6,7 +6,8 @@
 void AS_basic_stats(double *, int, struct GASTATS *);
 /* class.c */
-double AS_class_apply_algorithm(char *, double *, int, int *, double *);
+int AS_option_to_algorithm(const struct Option *);
+double AS_class_apply_algorithm(int, double *, int, int *, double *);
 int AS_class_interval(double *, int, int, double *);
 int AS_class_quant(double *, int, int, double *);
 double AS_class_discont(double *, int, int, double *);
Modified: grass/trunk/lib/arraystats/class.c
--- grass/trunk/lib/arraystats/class.c	2015-01-01 19:26:41 UTC (rev 63910)
+++ grass/trunk/lib/arraystats/class.c	2015-01-01 19:45:14 UTC (rev 63911)
@@ -3,27 +3,50 @@
 #include <grass/glocale.h>
 #include <grass/arraystats.h>
-double AS_class_apply_algorithm(char *algo, double *data, int nrec, int *nbreaks,
+int AS_option_to_algorithm(const struct Option * option)
+    if (G_strcasecmp(option->answer, "int") == 0)
+        return CLASS_INTERVAL;
+    if (G_strcasecmp(option->answer, "std") == 0)
+        return CLASS_STDEV;
+    if (G_strcasecmp(option->answer, "qua") == 0)
+        return CLASS_QUANT;
+    if (G_strcasecmp(option->answer, "equ") == 0)
+        return CLASS_EQUIPROB;
+    if (G_strcasecmp(option->answer, "dis") == 0)
+        return CLASS_DISCONT;
+    G_fatal_error(_("Unknown algorithm '%s'"), option->answer);
+double AS_class_apply_algorithm(int algo, double *data, int nrec, int *nbreaks,
                                 double *classbreaks)
     double finfo = 0.0;
-    if (G_strcasecmp(algo, "int") == 0)
-	finfo = AS_class_interval(data, nrec, *nbreaks, classbreaks);
-    else if (G_strcasecmp(algo, "std") == 0)
-	finfo = AS_class_stdev(data, nrec, *nbreaks, classbreaks);
-    else if (G_strcasecmp(algo, "qua") == 0)
+    switch (algo) {
+    case CLASS_INTERVAL:
+        finfo = AS_class_interval(data, nrec, *nbreaks, classbreaks);
+        break;
+    case CLASS_STDEV:
+        finfo = AS_class_stdev(data, nrec, *nbreaks, classbreaks);
+        break;
+    case CLASS_QUANT:
         finfo = AS_class_quant(data, nrec, *nbreaks, classbreaks);
-    else if (G_strcasecmp(algo, "equ") == 0)
-	finfo = AS_class_equiprob(data, nrec, nbreaks, classbreaks);
-    else if (G_strcasecmp(algo, "dis") == 0)
-	    /*	finfo = class_discont(data, nrec, *nbreaks, classbreaks); disabled because of bugs */
+        break;
+    case CLASS_EQUIPROB:
+        finfo = AS_class_equiprob(data, nrec, nbreaks, classbreaks);
+        break;
+    case CLASS_DISCONT:
+        /*	finfo = class_discont(data, nrec, *nbreaks, classbreaks); disabled because of bugs */
         G_fatal_error(_("Discont algorithm currently not available because of bugs"));
-    else
-	G_fatal_error(_("%s: Unknown algorithm"), algo);
+        break;
+    default:
+        break;
     if (finfo == 0)
-	G_fatal_error(_("%s: Error in classification algorithm"), algo);
+	G_fatal_error(_("Classification algorithm failed"));
     return finfo;
Modified: grass/trunk/vector/v.class/main.c
--- grass/trunk/vector/v.class/main.c	2015-01-01 19:26:41 UTC (rev 63910)
+++ grass/trunk/vector/v.class/main.c	2015-01-01 19:45:14 UTC (rev 63911)
@@ -164,10 +164,11 @@
      * finfo takes any info coming from the classification algorithms
      * equ algorithm can alter number of class breaks */
     finfo =
+        AS_class_apply_algorithm(AS_option_to_algorithm(algo_opt),
                                  classbreaks);
     if (G_strcasecmp(algo_opt->answer, "dis") == 0 && finfo < 3.84148)
 	G_warning(_("The discontinuities algorithm indicates that some "
 		    "class breaks are not statistically significant at "
