[GRASS-SVN] r63919 - in grass/branches/releasebranch_7_0: imagery imagery/i.atcorr imagery/i.landsat.toar imagery/i.segment raster/r.contour raster/r.gwflow raster/r.gwflow/testsuite raster/r.in.poly raster/r.in.poly/testsuite raster/r.mapcalc raster/r.mapcalc/testsuite raster/r.profile raster/r.profile/testsuite raster/r.recode raster/r.recode/testsuite raster/r.series.accumulate/test_suite raster/r.series.interp raster/r.slope.aspect raster/r.slope.aspect/testsuite raster/r.slope.aspect/testsuite/data raster/r.sunmask raster/r.viewshed raster/r.viewshed/testsuite raster/r.viewshed/testsuite/data
svn_grass at osgeo.org
Thu Jan 1 14:16:37 PST 2015
Author: neteler
Date: 2015-01-01 14:16:37 -0800 (Thu, 01 Jan 2015)
New Revision: 63919
Added:
grass/branches/releasebranch_7_0/raster/r.gwflow/testsuite/
grass/branches/releasebranch_7_0/raster/r.gwflow/testsuite/validation_7x7_grid.py
grass/branches/releasebranch_7_0/raster/r.gwflow/testsuite/validation_excavation.py
grass/branches/releasebranch_7_0/raster/r.in.poly/testsuite/
grass/branches/releasebranch_7_0/raster/r.in.poly/testsuite/test_rinpoly.py
grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/
grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/const_map_test.sh
grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/test_r3_mapcalc.py
grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/test_r_mapcalc.py
grass/branches/releasebranch_7_0/raster/r.profile/testsuite/
grass/branches/releasebranch_7_0/raster/r.profile/testsuite/test_profile_ncspm.py
grass/branches/releasebranch_7_0/raster/r.recode/testsuite/
grass/branches/releasebranch_7_0/raster/r.recode/testsuite/test_rrecode_ncspm.py
grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/
grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/
grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/fractal_surf.ascii
grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_aspect.grd
grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_aspect.grd.aux.xml
grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_slope.grd
grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_slope.grd.aux.xml
grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/test_r_slope_aspect.py
grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/
grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/data/
grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/data/elevation.ascii
grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/data/lake_viewshed.ascii
grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/test_r_viewshed.py
Removed:
grass/branches/releasebranch_7_0/raster/r.gwflow/valid_calc_7x7.py
grass/branches/releasebranch_7_0/raster/r.gwflow/valid_calc_excavation.py
grass/branches/releasebranch_7_0/imagery/i.atcorr/aerosolmodel.cpp
grass/branches/releasebranch_7_0/imagery/i.landsat.toar/main.c
grass/branches/releasebranch_7_0/imagery/i.segment/write_output.c
grass/branches/releasebranch_7_0/imagery/imageryintro.html
grass/branches/releasebranch_7_0/raster/r.contour/cont.c
grass/branches/releasebranch_7_0/raster/r.series.accumulate/test_suite/test.r.series.accumulate.sh
grass/branches/releasebranch_7_0/raster/r.series.interp/main.c
grass/branches/releasebranch_7_0/raster/r.sunmask/main.c
grass/branches/releasebranch_7_0/raster/r.viewshed/main.cpp
i.* + r.*: minor backports; testsuites backported
Modified: grass/branches/releasebranch_7_0/imagery/i.atcorr/aerosolmodel.cpp
--- grass/branches/releasebranch_7_0/imagery/i.atcorr/aerosolmodel.cpp 2015-01-01 20:56:58 UTC (rev 63918)
+++ grass/branches/releasebranch_7_0/imagery/i.atcorr/aerosolmodel.cpp 2015-01-01 22:16:37 UTC (rev 63919)
@@ -385,7 +385,7 @@
for(int k = 1; k <= mu; k++)
- double co_n = (2 * k + 1) / k / (k + 1);
+ double co_n = (2.0 * k + 1) / k / (k + 1);
RS1 += co_n * (RAn[k] * PIn[k] + RBn[k] * TAUn[k]);
RS2 += co_n * (RAn[k] * TAUn[k] + RBn[k] * PIn[k]);
IS1 += co_n * (IAn[k] * PIn[k] + IBn[k] * TAUn[k]);
Modified: grass/branches/releasebranch_7_0/imagery/i.landsat.toar/main.c
--- grass/branches/releasebranch_7_0/imagery/i.landsat.toar/main.c 2015-01-01 20:56:58 UTC (rev 63918)
+++ grass/branches/releasebranch_7_0/imagery/i.landsat.toar/main.c 2015-01-01 22:16:37 UTC (rev 63919)
@@ -721,6 +721,8 @@
Rast_write_units(band_out, "W/(m^2 sr um)");
else
Rast_write_units(band_out, "unitless");
+ /* set raster timestamp from acq date? (see r.timestamp module) */
Rast_set_window(&orig_cellhd);
Modified: grass/branches/releasebranch_7_0/imagery/i.segment/write_output.c
--- grass/branches/releasebranch_7_0/imagery/i.segment/write_output.c 2015-01-01 20:56:58 UTC (rev 63918)
+++ grass/branches/releasebranch_7_0/imagery/i.segment/write_output.c 2015-01-01 22:16:37 UTC (rev 63919)
@@ -209,6 +209,9 @@
G_free(inbuf);
G_free(in_fd);
+ G_free(fp_range);
+ G_free(min);
+ G_free(max);
/* free memory */
Modified: grass/branches/releasebranch_7_0/imagery/imageryintro.html
--- grass/branches/releasebranch_7_0/imagery/imageryintro.html 2015-01-01 20:56:58 UTC (rev 63918)
+++ grass/branches/releasebranch_7_0/imagery/imageryintro.html 2015-01-01 22:16:37 UTC (rev 63919)
@@ -1,6 +1,6 @@
<!-- meta page description: Image processing in GRASS GIS -->
<!-- meta page index: imagery -->
-<h3>General introduction</h3>
+<h3>Image processing in general</h3>
<b>Digital numbers and physical values (reflection/radiance-at-sensor):</b>
<p>
Modified: grass/branches/releasebranch_7_0/raster/r.contour/cont.c
--- grass/branches/releasebranch_7_0/raster/r.contour/cont.c 2015-01-01 20:56:58 UTC (rev 63918)
+++ grass/branches/releasebranch_7_0/raster/r.contour/cont.c 2015-01-01 22:16:37 UTC (rev 63919)
@@ -346,9 +346,9 @@
if (Rast_raster_cmp(&curr->z[p1], &curr->z[p2], DCELL_TYPE) == 0)
ratio = 1;
else if (Rast_is_d_null_value(&curr->z[p1]))
- ratio = 1 / 2;
+ ratio = 0.5;
else if (Rast_is_d_null_value(&curr->z[p2]))
- ratio = 1 / 2;
+ ratio = 0.5;
else
ratio = (level - curr->z[p1]) / (curr->z[p2] - curr->z[p1]);
Added: grass/branches/releasebranch_7_0/raster/r.gwflow/testsuite/validation_7x7_grid.py
--- grass/branches/releasebranch_7_0/raster/r.gwflow/testsuite/validation_7x7_grid.py (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.gwflow/testsuite/validation_7x7_grid.py 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,89 @@
+"""Test to verify r.gwflow calculation, this calculation is based on
+the example at page 133 of the following book:
+author = "Kinzelbach, W. and Rausch, R.",
+title = "Grundwassermodellierung",
+publisher = "Gebr{\"u}der Borntraeger (Berlin, Stuttgart)",
+year = "1995"
+ at author Soeren Gebbert
+from grass.gunittest.case import TestCase
+class Validation7x7Grid(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Use temporary region settings"""
+ cls.use_temp_region()
+ cls.runModule("g.region", res=100, n=700, s=0, w=0, e=700)
+ @classmethod
+ def tearDownClass(cls):
+ """!Remove the temporary region
+ cls.del_temp_region()
+ def setUp(self):
+ """Create input data for transient groundwater flow computation
+ self.runModule("r.mapcalc", expression="phead=50")
+ self.runModule("r.mapcalc", expression="status=if(col() == 1 || col() == 7 , 2, 1)")
+ self.runModule("r.mapcalc", expression="well=if((row() == 4 && col() == 4), -0.1, 0)")
+ self.runModule("r.mapcalc", expression="hydcond=0.0005")
+ self.runModule("r.mapcalc", expression="recharge=0")
+ self.runModule("r.mapcalc", expression="top_conf=20")
+ self.runModule("r.mapcalc", expression="bottom=0")
+ self.runModule("r.mapcalc", expression="s=0.0001")
+ self.runModule("r.mapcalc", expression="null=0.0")
+ def test_transient(self):
+ #First compute the groundwater flow after 500 seconds to have initial conditions
+ self.assertModule("r.gwflow", flags="f", solver="cholesky", top="top_conf", bottom="bottom", phead="phead",\
+ status="status", hc_x="hydcond", hc_y="hydcond", q="well", s="s",\
+ recharge="recharge", output="gwresult_conf", dtime=500, type="confined", budget="water_budget", overwrite=True)
+ # loop over the timesteps each 500 seconds
+ for i in range(20):
+ self.assertModule("r.gwflow", flags="f", solver="cholesky", top="top_conf", bottom="bottom", phead="gwresult_conf",\
+ # Output of r.univar
+ univar_string="""n=49
+ null_cells=0
+ cells=49
+ min=45.1219899394172
+ max=50
+ range=4.8780100605828
+ mean=49.081632669812
+ mean_of_abs=49.081632669812
+ stddev=0.908558909200636
+ variance=0.825479291487849
+ coeff_var=1.85111794326975
+ sum=2405.00000082079"""
+ # Output of r.info, only a subset of the output is needed
+ info_string="""north=700
+ south=0
+ east=700
+ west=0
+ nsres=100
+ ewres=100
+ rows=7
+ cols=7
+ cells=49
+ datatype=DCELL
+ ncats=0
+ max=50
+ map=gwresult_conf"""
+ self.assertRasterFitsUnivar(raster="gwresult_conf", reference=univar_string, precision=3)
+ self.assertRasterFitsInfo(raster="gwresult_conf", reference=info_string, precision=3)
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
Added: grass/branches/releasebranch_7_0/raster/r.gwflow/testsuite/validation_excavation.py
--- grass/branches/releasebranch_7_0/raster/r.gwflow/testsuite/validation_excavation.py (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.gwflow/testsuite/validation_excavation.py 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,87 @@
+the example at page 167 of the following book:
+year = "1995"
+class ValidationExcavation(TestCase):
+ @classmethod
+ cls.runModule("g.region", flags="p", res=50, n=950, s=0, w=0, e=2000)
+ @classmethod
+ def setUp(self):
+ """Create input data for steady state groundwater flow computation
+ self.runModule("r.mapcalc", expression="phead= if(row() == 19, 5, 3)")
+ self.runModule("r.mapcalc", expression="status=if((col() == 1 && row() == 13) ||\
+ (col() == 1 && row() == 14) ||\
+ (col() == 2 && row() == 13) ||\
+ (col() == 2 && row() == 14) ||\
+ (row() == 19), 2, 1)")
+ self.runModule("r.mapcalc", expression="hydcond=0.001")
+ self.runModule("r.mapcalc", expression="recharge=0.000000006")
+ self.runModule("r.mapcalc", expression="top=20")
+ self.runModule("r.mapcalc", expression="poros=0.1")
+ def test_steady_state(self):
+ #compute a steady state groundwater flow
+ self.assertModule("r.gwflow", flags="f", solver="cholesky", top="top", bottom="bottom", phead="phead", \
+ status="status", hc_x="hydcond", hc_y="hydcond", s="poros", \
+ recharge="recharge", output="gwresult", dtime=864000000000, type="unconfined", budget="water_budget")
+ # Output of r.univar -g
+ univar_string="""n=760
+ null_cells=0
+ cells=760
+ min=3
+ max=5.39762629189687
+ range=2.39762629189687
+ mean=5.02846950820457
+ mean_of_abs=5.02846950820457
+ stddev=0.333565013446849
+ variance=0.111265618195797
+ coeff_var=6.63352960384062
+ sum=3821.63682623547"""
+ # Output of r.info -gre, only a subset of the output is needed
+ info_string="""north=950
+ south=0
+ east=2000
+ west=0
+ nsres=50
+ ewres=50
+ rows=19
+ cols=40
+ cells=760
+ datatype=DCELL
+ ncats=0
+ min=3
+ map=gwresult"""
+ self.assertRasterFitsUnivar(raster="gwresult", reference=univar_string, precision=3)
+ self.assertRasterFitsInfo(raster="gwresult", reference=info_string, precision=3)
+ test()
Deleted: grass/branches/releasebranch_7_0/raster/r.gwflow/valid_calc_7x7.py
--- grass/branches/releasebranch_7_0/raster/r.gwflow/valid_calc_7x7.py 2015-01-01 20:56:58 UTC (rev 63918)
+++ grass/branches/releasebranch_7_0/raster/r.gwflow/valid_calc_7x7.py 2015-01-01 22:16:37 UTC (rev 63919)
@@ -1,43 +0,0 @@
-#!/usr/bin/env python
-# Python script to verify r.gwflow calculation, this calculation is based on
-# the example at page 133 of the following book:
-# author = "Kinzelbach, W. and Rausch, R.",
-# title = "Grundwassermodellierung",
-# publisher = "Gebr{\"u}der Borntraeger (Berlin, Stuttgart)",
-# year = "1995"
-import sys
-import os
-import grass.script as grass
-# Overwrite existing maps
-grass.run_command("g.gisenv", set="OVERWRITE=1")
-grass.message(_("Set the region"))
-# The area is 2000m x 1000m with a cell size of 25m x 25m
-grass.run_command("g.region", res=100, n=700, s=0, w=0, e=700)
-grass.run_command("r.mapcalc", expression="phead=50")
-grass.run_command("r.mapcalc", expression="status=if(col() == 1 || col() == 7 , 2, 1)")
-grass.run_command("r.mapcalc", expression="well=if((row() == 4 && col() == 4), -0.1, 0)")
-grass.run_command("r.mapcalc", expression="hydcond=0.0005")
-grass.run_command("r.mapcalc", expression="recharge=0")
-grass.run_command("r.mapcalc", expression="top_conf=20")
-grass.run_command("r.mapcalc", expression="bottom=0")
-grass.run_command("r.mapcalc", expression="s=0.0001")
-grass.run_command("r.mapcalc", expression="null=0.0")
-#First compute the groundwater flow
-grass.run_command("r.gwflow", "f", solver="cholesky", top="top_conf", bottom="bottom", phead="phead",\
- status="status", hc_x="hydcond", hc_y="hydcond", q="well", s="s",\
- recharge="recharge", output="gwresult_conf", dt=500, type="confined", budget="water_budget")
-count=500
-# loop over the timesteps
-for i in range(20):
- grass.run_command("r.gwflow", "f", solver="cholesky", top="top_conf", bottom="bottom", phead="gwresult_conf",\
- count += 500
Deleted: grass/branches/releasebranch_7_0/raster/r.gwflow/valid_calc_excavation.py
--- grass/branches/releasebranch_7_0/raster/r.gwflow/valid_calc_excavation.py 2015-01-01 20:56:58 UTC (rev 63918)
+++ grass/branches/releasebranch_7_0/raster/r.gwflow/valid_calc_excavation.py 2015-01-01 22:16:37 UTC (rev 63919)
@@ -1,38 +0,0 @@
-# Shellscript to verify r.gwflow calculation, this calculation is based on
-# the example at page 167 of the following book:
-# year = "1995"
-import sys
-import os
-grass.run_command("g.region", res=50, n=950, s=0, w=0, e=2000)
-grass.run_command("r.mapcalc", expression="phead= if(row() == 19, 5, 3)")
-grass.run_command("r.mapcalc", expression="status=if((col() == 1 && row() == 13) ||\
- (col() == 1 && row() == 14) ||\
- (col() == 2 && row() == 13) ||\
- (col() == 2 && row() == 14) ||\
- (row() == 19), 2, 1)")
-grass.run_command("r.mapcalc", expression="hydcond=0.001")
-grass.run_command("r.mapcalc", expression="recharge=0.000000006")
-grass.run_command("r.mapcalc", expression="top=20")
-grass.run_command("r.mapcalc", expression="poros=0.1")
-#compute a steady state groundwater flow
-grass.run_command("r.gwflow", "f", solver="cholesky", top="top", bottom="bottom", phead="phead", \
- status="status", hc_x="hydcond", hc_y="hydcond", s="poros", \
- recharge="recharge", output="gwresult", dt=864000000000, type="unconfined", budget="water_budget")
Added: grass/branches/releasebranch_7_0/raster/r.in.poly/testsuite/test_rinpoly.py
--- grass/branches/releasebranch_7_0/raster/r.in.poly/testsuite/test_rinpoly.py (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.in.poly/testsuite/test_rinpoly.py 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,111 @@
+import os
+import tempfile
+import grass.gunittest
+from grass.script.core import read_command
+input1 = \
+A
+634308.630394 223320.356473
+640640.712946 223092.401501
+641248.592871 217748.123827
+= 10.01 label1
+A
+639576.923077 222256.566604
+639045.028143 216329.737336
+637702.626642 224662.757974
+= -8
+L
+633523.452158 222231.238274
+642565.666041 221218.105066
+641957.786116 222585.834897
+= 3 label2
+class TestRInPoly(grass.gunittest.TestCase):
+ rinpoly = 'test_rinpoly'
+ @classmethod
+ cls.runModule('g.region', raster='elevation')
+ @classmethod
+ def setUp(self):
+ self.tmpFile = tempfile.NamedTemporaryFile(delete=False)
+ def tearDown(self):
+ """Remove rinpoly map after each test method"""
+ self.runModule('g.remove', flags='f', type='raster',
+ name=self.rinpoly)
+ os.unlink(self.tmpFile.name)
+ def testTypeCell(self):
+ """Test type of resulting map"""
+ self.tmpFile.write(input1)
+ self.tmpFile.close()
+ self.assertModule('r.in.poly', input=self.tmpFile.name, output=self.rinpoly, type='CELL')
+ minmax = 'min=-8\nmax=10\ndatatype=CELL'
+ self.assertRasterFitsInfo(raster=self.rinpoly, reference=minmax)
+ def testTypeFCell(self):
+ self.assertModule('r.in.poly', input=self.tmpFile.name, output=self.rinpoly, type='FCELL')
+ minmax = 'min=-8\nmax=10.01\ndatatype=FCELL'
+ self.assertRasterFitsInfo(raster=self.rinpoly, reference=minmax, precision=1e-8)
+ def testTypeDCell(self):
+ self.assertModule('r.in.poly', input=self.tmpFile.name, output=self.rinpoly, type='DCELL')
+ minmax = 'min=-8\nmax=10.01\ndatatype=DCELL'
+ def testTypeCellNull(self):
+ self.assertModule('r.in.poly', input=self.tmpFile.name, output=self.rinpoly, type='CELL',
+ null=-8)
+ minmax = 'min=3\nmax=10\ndatatype=CELL'
+ def testTypeDCellNull(self):
+ self.assertModule('r.in.poly', input=self.tmpFile.name, output=self.rinpoly, type='DCELL',
+ null=-8)
+ minmax = 'min=3\nmax=10.01\ndatatype=DCELL'
+ def testTypeDCellNull2(self):
+ null=0)
+ def testLabels(self):
+ category = read_command('r.category', map=self.rinpoly, values=[-8, 3, 10.01]).strip()
+ self.assertEqual(first="-8\t\n3\tlabel2\n10.01\tlabel1", second=category,
+ msg="Labels do not match")
+ grass.gunittest.test()
Added: grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/const_map_test.sh
--- grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/const_map_test.sh (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/const_map_test.sh 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,177 @@
+#!/bin/sh
+# Markus Neteler
+# Test cases for 2D raster data
+# Tests:
+# - generate 3x3 map, value 1/1.1
+# - calculate statistics
+# - compare with known results
+# TODO
+# - how big EPSILON?
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program."
+ exit 1
+fi
+#### check if we have awk
+if [ ! -x "`which awk`" ] ; then
+ echo "$PROG: awk required, please install first" 1>&2
+ exit 1
+fi
+# setting environment, so that awk works properly in all languages
+unset LC_ALL
+export LC_NUMERIC=C
+eval `g.gisenv`
+: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
+LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
+# some definitions
+PIXEL=3
+# how big EPSILON?
+# epsilon for doubles in IEEE is 2.220446e-16
+EPSILON=22204460000000000
+PID=$$
+TMPNAME="`echo ${PID}_tmp_testmap | sed 's+\.+_+g'`"
+# some functions - keep order here
+cleanup()
+ echo "Removing temporary map"
+ g.remove -f type=raster name=$TMPNAME > /dev/null
+# check if a MASK is already present:
+MASKTMP=mask.$TMPNAME
+USERMASK=usermask_${MASKTMP}
+if test -f $LOCATION/cell/MASK
+then
+ echo "A user raster mask (MASK) is present. Saving it..."
+ g.rename raster=MASK,$USERMASK > /dev/null
+fi
+finalcleanup()
+ echo "Restoring user region"
+ g.region region=$TMPNAME
+ g.remove -f type=region name=$TMPNAME > /dev/null
+ #restore user mask if present:
+ if test -f $LOCATION/cell/$USERMASK ; then
+ echo "Restoring user MASK"
+ g.remove -f type=raster name=MASK > /dev/null
+ g.rename raster=$USERMASK,MASK > /dev/null
+ fi
+check_exit_status()
+ if [ $1 -ne 0 ] ; then
+ echo "An error occurred."
+ cleanup ; finalcleanup
+ exit 1
+ fi
+########## test function goes here
+compare_result()
+ EXPECTED=$1
+ FOUND=$2
+ VALUENAME=$3
+ # test for NAN
+ if [ "$FOUND" = "nan" ] ; then
+ echo "ERROR. $VALUENAME: Expected=$EXPECTED | FOUND=$FOUND"
+ exit 1
+ fi
+ # check for difference + 1
+ DIFF=`echo $EXPECTED $FOUND $EPSILON | awk '{printf "%16f", ($1 - $2) * $3 }'`
+ #make absolute value
+ DIFF=`echo $DIFF | awk '{printf("%f", sqrt($1 * $1))}'`
+ #round to integer
+ DIFF=`echo $DIFF | awk '{printf("%20d", int($1+0.5))}'`
+ # check if difference > 0
+ if [ $DIFF -gt 0 ] ; then
+ exit 1
+ fi
+#check if a MASK is already present:
+then
+ check_exit_status $?
+fi
+echo "Saving current & setting test region."
+g.region save=$TMPNAME
+check_exit_status $?
+g.region s=0 n=$PIXEL w=0 e=$PIXEL res=1 tbres=1
+########### 2D raster INT tests ###########
+VALUE=1
+echo "INT/CELL test."
+r.mapcalc "$TMPNAME = 1"
+echo "Univariate statistics of INT/CELL test."
+eval `r.univar -g $TMPNAME`
+compare_result 9 $n n
+compare_result $VALUE $min min
+compare_result $VALUE $max max
+compare_result 0 $range range
+compare_result $VALUE $mean mean
+compare_result 0 $stddev stddev
+compare_result 0 $variance variance
+compare_result 0 $coeff_var coeff_var
+compare_result 9 $sum sum
+cleanup
+echo "INT/CELL univariate statistics test successful"
+echo "##################################"
+########### 2D raster FCELL tests ###########
+VALUE=1.1
+echo "FLOAT/FCELL test."
+r.mapcalc "$TMPNAME = $VALUE"
+echo "Univariate statistics of FLOAT/FCELL test."
+compare_result 9.9 $sum sum
+cleanup
+echo "FLOAT/FCELL univariate statistics test successful"
+# if we arrive here...
+finalcleanup
+echo "All tests successful. Congrats."
+exit 0
Property changes on: grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/const_map_test.sh
___________________________________________________________________
Added: svn:executable
Added: grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/test_r3_mapcalc.py
--- grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/test_r3_mapcalc.py (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/test_r3_mapcalc.py 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,56 @@
+# TODO: add more expressions
+# TODO: add tests with prepared data
+class TestBasicOperations(grass.gunittest.TestCase):
+ # TODO: replace by unified handing of maps
+ to_remove = []
+ @classmethod
+ n=85, s=5, e=85, w=5,
+ b=0, t=2000,
+ res=1e-07)
+ @classmethod
+ if cls.to_remove:
+ cls.runModule('g.remove', flags='f', type='raster_3d',
+ name=','.join(cls.to_remove), verbose=True)
+ def test_difference_of_the_same_map_double(self):
+ """Test zero difference of map with itself"""
+ self.runModule('r3.mapcalc', flags='s',
+ expression='a = rand(1.0, 200)')
+ self.to_remove.append('a')
+ self.assertModule('r3.mapcalc',
+ expression='diff_a_a = a - a')
+ self.to_remove.append('diff_a_a')
+ self.assertRaster3dMinMax('diff_a_a', refmin=0, refmax=0)
+ def test_difference_of_the_same_map_float(self):
+ expression='af = rand(float(1), 200)')
+ self.to_remove.append('af')
+ expression='diff_af_af = af - af')
+ self.to_remove.append('diff_af_af')
+ self.assertRaster3dMinMax('diff_af_af', refmin=0, refmax=0)
+ def test_difference_of_the_same_expression(self):
+ """Test zero difference of two same expressions"""
+ expression='diff_e_e = 3 * x() * y() * z() - 3 * x() * y() * z()')
+ self.to_remove.append('diff_e_e')
+ self.assertRaster3dMinMax('diff_e_e', refmin=0, refmax=0)
Added: grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/test_r_mapcalc.py
--- grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/test_r_mapcalc.py (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.mapcalc/testsuite/test_r_mapcalc.py 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,223 @@
+from grass.gunittest.gmodules import SimpleModule
+cell_seed_500 = """\
+north: 20
+south: 10
+east: 25
+west: 15
+rows: 10
+cols: 10
+2 12 183 135 117 176 138 117 182 40
+157 70 195 1 30 125 122 74 108 104
+163 146 82 164 67 63 60 3 147 193
+151 173 144 173 128 77 141 6 144 193
+180 56 14 121 124 107 46 107 90 60
+177 57 12 104 178 13 167 104 163 187
+55 133 27 114 195 60 78 35 49 11
+55 138 25 105 32 58 47 18 139 32
+24 74 36 71 131 124 87 161 160 154
+136 45 48 146 9 182 69 12 35 19
+dcell_seed_600 = """\
+north: 20
+south: 10
+east: 25
+west: 15
+rows: 10
+cols: 10
+130.790433856418332 101.3319248101491041 33.5781271447787759 37.4064724824657944 98.2794723130458152 73.9118866262841863 185.9530433718733775 74.5210037729812882 166.1178416001017695 90.9915650902159996
+109.2478664232956334 25.6499350759712215 150.9024447059825036 125.7544119036241312 66.7235333366722614 167.9375729129454271 123.1009291055983965 12.0922254083554606 59.389026967287819 113.2843489528100349
+40.0044184023145277 135.8273774212801186 71.6737798852435049 191.6223505280372876 4.1546013811569615 143.3082794522489962 177.043829294835632 115.0300571162354402 141.8985452774071234 127.8949967123638061
+93.2842559637482793 9.7471880052423856 118.1216452002055632 158.1474162140586088 67.2957262519499437 3.6524546350146849 147.0965842667525862 37.060628529871579 47.3408278816968959 66.2219633495724054
+175.5638637866295539 67.1399023507611901 162.2058392782793703 198.1586789345953719 36.474049475167746 49.2589028048889617 112.1169663235969836 22.0227597984432535 95.9169228571662131 86.7470895014531322
+93.5401613888204935 193.7821104138942587 193.8286564351004699 3.2623643889134684 94.6955247357847725 25.7099391122614307 155.592251526775442 25.3392337002970294 48.3979699868663005 99.6836079482556272
+104.16296861365457 190.7865884377180805 6.2841805474238619 49.3731395705159528 100.1903962703459285 116.927654961282343 19.8626348109264264 40.9693022766258466 81.6500759554420057 169.2220572316770131
+118.8112518721558217 55.8955021401724039 112.9150308215961331 62.6399760484719081 85.400498505854145 191.0144187084912062 124.2128169358724534 167.9341741649760706 170.6149695243870781 158.3034517206661462
+130.0453795775294736 64.1996403829061535 62.9317494959142465 175.1909990236256931 122.9624852869890361 79.9546265736285733 9.6594013716963367 114.0611338072915544 11.9371167643030809 186.9121199748369122
+3.2891990250261536 30.9245408751958379 46.4021422454598991 104.2378950097200203 47.424093232347019 73.4801303522840499 22.4778583078695213 132.870185207462697 48.1666164169167388 100.5504714442693057
+fcell_seed_700 = """\
+north: 20
+south: 10
+east: 25
+west: 15
+rows: 10
+cols: 10
+146.756378 192.682159 2.644822 147.270462 62.178818 192.668198 94.320778 107.710426 98.319664 114.444504
+12.995321 18.026272 151.590958 5.249451 197.266708 103.663635 115.424088 28.01062 78.555168 62.912098
+164.053619 154.652039 98.536011 44.601639 85.322289 168.383957 44.93845 128.62262 89.910591 107.242188
+111.182487 63.080284 177.791473 47.439354 42.451859 72.396568 170.597778 170.622742 141.88858 105.126854
+120.76828 148.581085 42.124866 56.432236 164.652176 98.094009 60.741329 66.286987 187.847427 160.120056
+50.530689 179.090652 138.114014 138.629211 193.147903 172.861481 133.72728 108.720459 103.508438 28.81559
+39.653179 101.948265 35.744762 25.570076 78.767021 154.600616 144.907684 82.370148 116.378654 18.218494
+35.587288 66.534409 65.744408 186.476959 137.081116 151.379272 48.261463 8.323328 130.432739 53.346546
+152.67189 15.512391 146.049072 185.276245 34.417141 127.522453 124.54998 52.08218 167.141342 87.771118
+69.0522 43.57811 63.15279 68.677063 74.202805 97.429077 167.123199 19.892767 120.593437 190.960815
+class TestRandFunction(grass.gunittest.TestCase):
+ to_remove = []
+ @classmethod
+ cls.runModule('g.region', n=20, s=10, e=25, w=15, res=1)
+ @classmethod
+ if cls.to_remove:
+ cls.runModule('g.remove', flags='f', type='raster',
+ name=','.join(cls.to_remove))
+ def rinfo_contains_number(self, raster, number):
+ """Test that r.info standard output for raster contains a given number
+ To be used in test methods for testing presence of a given number.
+ rinfo = SimpleModule('r.info', map=raster)
+ self.runModule(rinfo)
+ self.assertIn(str(number), rinfo.outputs.stdout)
+ def test_seed_not_required(self):
+ """Test that seed is not required when rand() is not used"""
+ self.assertModule('r.mapcalc', expression='nonrand_cell = 200')
+ self.to_remove.append('nonrand_cell')
+ def test_seed_required(self):
+ """Test that seed is required when rand() is used
+ This test can, and probably should, generate an error message.
+ self.assertModuleFail('r.mapcalc', expression='rand_x = rand(1, 200)')
+ # TODO: assert map not exists but it would be handy here
+ # TODO: test that error message was generated
+ def test_seed_cell(self):
+ """Test given seed with CELL against reference map"""
+ seed = 500
+ self.runModule('r.in.ascii', input='-', stdin=cell_seed_500,
+ output='rand_cell_ref')
+ self.to_remove.append('rand_cell_ref')
+ self.assertModule('r.mapcalc', seed=seed,
+ expression='rand_cell = rand(1, 200)')
+ self.to_remove.append('rand_cell')
+ # this assert is using r.mapcalc but we are testing different
+ # functionality than used by assert
+ self.assertRastersNoDifference(actual='rand_cell',
+ reference='rand_cell_ref',
+ precision=0)
+ self.rinfo_contains_number('rand_cell', seed)
+ def test_seed_dcell(self):
+ """Test given seed with DCELL against reference map"""
+ seed = 600
+ self.runModule('r.in.ascii', input='-', stdin=dcell_seed_600,
+ output='rand_dcell_ref')
+ self.to_remove.append('rand_dcell_ref')
+ expression='rand_dcell = rand(1.0, 200.0)')
+ self.to_remove.append('rand_dcell')
+ self.assertRastersNoDifference(actual='rand_dcell',
+ reference='rand_dcell_ref',
+ precision=0.00000000000001)
+ self.rinfo_contains_number('rand_dcell', seed)
+ def test_seed_fcell(self):
+ """Test given seed with FCELL against reference map"""
+ seed = 700
+ self.runModule('r.in.ascii', input='-', stdin=fcell_seed_700,
+ output='rand_fcell_ref')
+ self.to_remove.append('rand_fcell_ref')
+ expression='rand_fcell = rand(float(1), 200)')
+ self.to_remove.append('rand_fcell')
+ self.assertRastersNoDifference(actual='rand_fcell',
+ reference='rand_fcell_ref',
+ precision=0.000001)
+ self.rinfo_contains_number('rand_fcell', seed)
+ def test_auto_seed(self):
+ """Test that two runs with -s does not give same maps"""
+ self.assertModule('r.mapcalc', flags='s',
+ expression='rand_auto_1 = rand(1., 2)')
+ self.to_remove.append('rand_auto_1')
+ expression='rand_auto_2 = rand(1., 2)')
+ self.to_remove.append('rand_auto_2')
+ self.assertRastersDifference(
+ 'rand_auto_1', 'rand_auto_2',
+ statistics=dict(min=-1, max=1, mean=0),
+ precision=0.5) # low precision, we have few cells
+ to_remove = []
+ @classmethod
+ @classmethod
+ if cls.to_remove:
+ self.runModule('r.mapcalc', flags='s',
+ self.assertRasterMinMax('diff_a_a', refmin=0, refmax=0)
+ self.assertRasterMinMax('diff_af_af', refmin=0, refmax=0)
+ def test_difference_of_the_same_map_int(self):
+ expression='ai = rand(1, 200)')
+ self.to_remove.append('ai')
+ expression='diff_ai_ai = ai - ai')
+ self.to_remove.append('diff_ai_ai')
+ self.assertRasterMinMax('diff_ai_ai', refmin=0, refmax=0)
+ expression='diff_e_e = 3 * x() * y() - 3 * x() * y()')
+ self.assertRasterMinMax('diff_e_e', refmin=0, refmax=0)
Added: grass/branches/releasebranch_7_0/raster/r.profile/testsuite/test_profile_ncspm.py
--- grass/branches/releasebranch_7_0/raster/r.profile/testsuite/test_profile_ncspm.py (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.profile/testsuite/test_profile_ncspm.py 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,190 @@
+from grass.gunittest import TestCase, test
+import grass.script.core as gcore
+# not used yet
+LOCATION = 'nc_spm'
+output1 = """
+ 0.000000 88.370453
+ 10.000000 88.397057
+ 20.000000 89.526253
+ 30.000000 89.677551
+ 40.000000 91.297195
+ 50.000000 91.297195
+ 60.000000 92.330658
+ 70.000000 93.069199
+ 80.000000 94.768280
+ 90.000000 95.524551
+ 100.000000 96.770805
+ 110.000000 96.770805
+ 120.000000 97.418869
+output2 = """
+637656.000000 224222.000000 0.000000 88.370453
+637664.540486 224227.201932 10.000000 88.397057
+637673.080972 224232.403865 20.000000 89.526253
+637681.621458 224237.605797 30.000000 89.677551
+637690.161944 224242.807729 40.000000 91.297195
+637698.702430 224248.009662 50.000000 91.297195
+637707.242916 224253.211594 60.000000 92.330658
+637715.783402 224258.413526 70.000000 93.069199
+637724.323887 224263.615459 80.000000 94.768280
+637732.864373 224268.817391 90.000000 95.524551
+637741.404859 224274.019323 100.000000 96.770805
+637749.945345 224279.221256 110.000000 96.770805
+637758.485831 224284.423188 120.000000 97.418869
+output3 = """
+ 0.000000 91.071831
+ 10.000000 91.431198
+ 20.000000 91.746628
+ 30.000000 91.746628
+ 40.000000 91.748047
+ 50.000000 91.872192
+ 60.000000 91.730049
+ 70.000000 91.690292
+ 80.000000 91.341331
+ 86.533231 91.341331
+ 96.533231 91.639000
+ 106.533231 nodata
+ 116.533231 nodata
+ 126.533231 nodata
+ 136.533231 nodata
+ 146.533231 nodata
+ 156.533231 nodata
+ 166.533231 nodata
+ 176.533231 nodata
+ 186.533231 nodata
+ 196.533231 nodata
+ 206.533231 nodata
+ 216.533231 nodata
+output4 = """
+ 25.000000 89.526253
+ 75.000000 94.768280
+ 125.000000 97.646629
+output5 = """
+635747.000000 222664.000000 0.000000 117.672462
+635738.870095 222669.822770 10.000000 116.417213
+635730.740190 222675.645539 20.000000 115.639481
+635722.610285 222681.468309 30.000000 112.835342
+635714.480381 222687.291079 40.000000 111.324890
+635706.350476 222693.113848 50.000000 108.612282
+635698.220571 222698.936618 60.000000 106.313347
+635690.090666 222704.759388 70.000000 104.915665
+635681.960761 222710.582158 80.000000 102.878601
+635673.830856 222716.404927 90.000000 102.935074
+635673.000000 222717.000000 91.021975 102.935074
+635665.017450 222710.976803 101.021975 102.932213
+635657.034900 222704.953607 111.021975 102.931152
+635649.052351 222698.930410 121.021975 102.932213
+635641.069801 222692.907213 131.021975 102.932213
+635633.087251 222686.884017 141.021975 102.931648
+635625.104701 222680.860820 151.021975 102.936768
+635617.122151 222674.837623 161.021975 102.903358
+635609.139601 222668.814427 171.021975 105.447823
+635601.157052 222662.791230 181.021975 105.447823
+635593.174502 222656.768033 191.021975 108.423523
+635585.191952 222650.744836 201.021975 109.192360
+635577.209402 222644.721640 211.021975 112.042763
+635569.226852 222638.698443 221.021975 114.321136
+635563.000000 222634.000000 228.822556 114.321136
+635569.507914 222626.407434 238.822556 115.357292
+635576.015827 222618.814868 248.822556 114.609100
+635582.523741 222611.222302 258.822556 111.636292
+635589.031655 222603.629736 268.822556 112.355431
+635595.539569 222596.037170 278.822556 110.162842
+635602.047482 222588.444604 288.822556 109.172668
+635608.555396 222580.852038 298.822556 109.172668
+635615.063310 222573.259472 308.822556 108.030540
+635621.571224 222565.666906 318.822556 105.670113
+635628.079137 222558.074340 328.822556 105.770287
+635634.587051 222550.481774 338.822556 105.169937
+635641.000000 222543.000000 348.676634 105.416862
+635647.589446 222550.521915 358.676634 105.011185
+635654.178892 222558.043830 368.676634 104.854263
+635660.768338 222565.565744 378.676634 104.573921
+635667.357784 222573.087659 388.676634 103.413361
+635673.947230 222580.609574 398.676634 105.485588
+635680.536676 222588.131489 408.676634 109.791016
+635687.126122 222595.653403 418.676634 109.701485
+635693.715568 222603.175318 428.676634 112.104370
+635700.305014 222610.697233 438.676634 113.684036
+635706.894460 222618.219148 448.676634 113.684036
+635713.483906 222625.741062 458.676634 114.252579
+635720.073352 222633.262977 468.676634 114.115379
+635726.662798 222640.784892 478.676634 114.123955
+635733.252244 222648.306807 488.676634 115.766998
+635739.841690 222655.828721 498.676634 116.547440
+635746.431136 222663.350636 508.676634 117.672462
+class TestProfileNCSPM(TestCase):
+ @classmethod
+ gcore.use_temp_region()
+ gcore.run_command('g.region', raster='elevation')
+ @classmethod
+ gcore.del_temp_region()
+ def test_profile_default(self):
+ rprofile = SimpleModule('r.profile', input='elevation',
+ coordinates=[637656, 224222, 637766, 224289])
+ self.assertModule(rprofile)
+ self.assertMultiLineEqual(rprofile.outputs.stdout.strip(), output1.strip())
+ self.assertIn('128.798292 [meters]', rprofile.outputs.stderr) # distance
+ self.assertIn('10 [meters]', rprofile.outputs.stderr) # resolution
+ def test_profile_m(self):
+ rprofile = SimpleModule('r.profile', input='elevation', units='meters',
+ def test_profile_resolution(self):
+ rprofile = SimpleModule('r.profile', input='elevation', resolution=25,
+ self.assertMultiLineEqual(rprofile.outputs.stdout.strip(), output4.strip())
+ self.assertIn('25 [meters]', rprofile.outputs.stderr) # resolution
+ def test_profile_ne(self):
+ rprofile = SimpleModule('r.profile', input='elevation', flags='g',
+ self.assertMultiLineEqual(rprofile.outputs.stdout.strip(), output2.strip())
+ def test_profile_region(self):
+ rprofile = SimpleModule('r.profile', input='elevation', null_value='nodata',
+ coordinates=[644914, 224579, 644986,
+ 224627, 645091, 224549])
+ self.assertMultiLineEqual(rprofile.outputs.stdout.strip(), output3.strip())
+ self.assertIn("WARNING: Endpoint coordinates are outside of current region settings",
+ rprofile.outputs.stderr)
+ def test_profile_directions(self):
+ coordinates=[635747, 222664, 635673, 222717, 635563,
+ 222634, 635641, 222543, 635747, 222664])
+ self.assertMultiLineEqual(rprofile.outputs.stdout.strip(), output5.strip())
+ test()
Added: grass/branches/releasebranch_7_0/raster/r.recode/testsuite/test_rrecode_ncspm.py
--- grass/branches/releasebranch_7_0/raster/r.recode/testsuite/test_rrecode_ncspm.py (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.recode/testsuite/test_rrecode_ncspm.py 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,95 @@
+# -*- coding: utf-8 -*-
+rules1 = """
+55:65:1
+65:75:2
+75:85:3
+85:95:4
+95:105:5
+105:115:6
+115:125:7
+125:135:8
+135:145:9
+145:155:10
+155:165:11
+rules2 = """
+55.6:156:-0.5:0.5
+rules3 = """
+0:1:0:255
+rules4 = """
+0:5:1
+6:10:2
+11:*:3
+class TestNCMaps(TestCase):
+ @classmethod
+ cls.runModule('g.region', raster='elevation at PERMANENT')
+ cls.runModule('r.mapcalc', expression="random01 = rand(0, 1.)", seed=1, overwrite=True)
+ @classmethod
+ cls.runModule('g.remove', type='raster', name=['random01', 'recoded'], flags='f')
+ def test_formats_elevation(self):
+ recode = SimpleModule('r.recode', input='elevation at PERMANENT', output='recoded',
+ rules='-', overwrite=True)
+ recode.inputs.stdin = rules1
+ self.assertModule(recode)
+ info = 'min=1\nmax=11\ndatatype=CELL'
+ self.assertRasterFitsInfo(raster='recoded', reference=info)
+ recode.flags['d'].value = True
+ info = 'min=1\nmax=11\ndatatype=DCELL'
+ recode.flags['d'].value = False
+ recode.inputs.stdin = rules2
+ info = 'min=-0.5\nmax=0.5\ndatatype=FCELL'
+ self.assertRasterFitsInfo(raster='recoded', reference=info, precision=1e-3)
+ info = 'min=-0.5\nmax=0.5\ndatatype=DCELL'
+ def test_formats_random(self):
+ recode = SimpleModule('r.recode', input='random01', output='recoded',
+ recode.inputs.stdin = rules3
+ category = read_command('r.category', map='recoded')
+ n_cats = len(category.strip().split('\n'))
+ if n_cats <= 2:
+ self.fail(msg="Number of categories is <= 2 "
+ "which suggests input map values were read as integers.")
+ def test_formats_landcover(self):
+ recode = SimpleModule('r.recode', input='landuse96_28m at PERMANENT',
+ output='recoded', rules='-', overwrite=True)
+ recode.inputs.stdin = rules4
+ info = 'min=1\nmax=3\ndatatype=CELL'
+ test()
Modified: grass/branches/releasebranch_7_0/raster/r.series.accumulate/test_suite/test.r.series.accumulate.sh
--- grass/branches/releasebranch_7_0/raster/r.series.accumulate/test_suite/test.r.series.accumulate.sh 2015-01-01 20:56:58 UTC (rev 63918)
+++ grass/branches/releasebranch_7_0/raster/r.series.accumulate/test_suite/test.r.series.accumulate.sh 2015-01-01 22:16:37 UTC (rev 63919)
@@ -51,7 +51,7 @@
output=test_accu_9 range=6,9 method=mean --verbose
# Test for correct results
-for map in `g.list type=rast pattern=test_accu_*` ; do
+for map in `g.list type=raster pattern=test_accu_*` ; do
r.out.ascii input=${map} output=${map}.ref precision=2
done
Modified: grass/branches/releasebranch_7_0/raster/r.series.interp/main.c
--- grass/branches/releasebranch_7_0/raster/r.series.interp/main.c 2015-01-01 20:56:58 UTC (rev 63918)
+++ grass/branches/releasebranch_7_0/raster/r.series.interp/main.c 2015-01-01 22:16:37 UTC (rev 63919)
@@ -64,8 +64,9 @@
G_add_keyword(_("raster"));
G_add_keyword(_("series"));
G_add_keyword(_("interpolation"));
+ /* TODO: re-phrase the description */
module->description =
- _("Interpolate raster maps located (temporal or spatial) "
+ _("Interpolates raster maps located (temporal or spatial) "
"in between input raster maps at specific sampling positions.");
parm.input = G_define_standard_option(G_OPT_R_INPUTS);
Added: grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/fractal_surf.ascii
--- grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/fractal_surf.ascii (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/fractal_surf.ascii 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,16 @@
+north: 20
+south: 10
+east: 25
+west: 15
+rows: 10
+cols: 10
+18042.0449657581812062 25383.8864299957058392 14054.8876733628094371 9718.6028777712708688 6811.412182415643656 2930.9162473829337614 -2117.0534472693707357 -3110.9860095434078175 4306.5996776199253873 987.4507122526649709
+10168.7073320247400261 9977.3079539500449755 5446.1555224152061783 4481.6517453232163462 1848.8039189165833704 -1700.797216407640235 -1544.4356998912949166 5619.2167452912372028 166.5044979636321045 2281.682802785037893
+3177.1414551946154461 -1491.910636019688809 -522.2980383497083494 -7733.1639587946547181 -9407.8445629291018122 -5840.1778570036331075 736.7154505421329986 6800.3416513099646181 -931.3345534823686194 -5463.0700545775525825
+10109.0777441430691397 913.7987579666439615 -2463.2252033934960309 -14508.6051479571506206 -20888.966440910462552 -14497.8998969001877413 -10522.8316460882324463 -816.1074612102775063 3359.0009318826023446 1090.6260443768023833
+8603.3056905043868028 4831.7340326208714032 -3556.3140177522709564 -8175.5341846188184718 -18357.2730383907437499 -18661.3149188292372855 -14409.728317302373398 -7102.8287566742747003 1779.425264984356545 3837.2560983032271906
+3627.8840285699184278 -133.8571474710850566 -3452.0622719314178539 -8000.7487283949603807 -16672.8438014870589541 -18038.9599507521306805 -17202.0380336391281162 -8919.2834336959240318 -5346.6450827091866813 -1954.214336749309723
+873.3209737757239282 -3346.9982385845969475 -11470.5463756023364112 -13199.9832339778495225 -14721.2637378373001411 -16224.3487699516826979 -19522.6366976581812196 -13069.7222692795330659 -9759.9528482313853601 -9054.4029620675919432
+292.2682278056205973 -3794.3364980614819615 -11426.0054321001316566 -16664.9545810654999514 -23409.7229947478008398 -27173.6223750138269679 -21000.9338307948601141 -8467.5305864940492029 -3463.9662640234532773 -4937.8907319630416168
+-5159.7969122775912183 -5883.0143716484344623 -4182.0455386342391648 -9149.4519877815255313 -28860.9848558809571841 -24850.2964268596515467 -18894.4634812169642828 -7910.7308709206999993 -2709.5147474691702882 1055.4081442089825487
+-1721.3017714211916882 -3815.394704173491391 721.3503318535069866 -4283.5534905015056211 -19226.051844524248736 -18363.9268685237584577 -12999.7725237885060778 -12001.7549241148735746 -4098.3666298110829302 5166.4987688895371321
Added: grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_aspect.grd
--- grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_aspect.grd (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_aspect.grd 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,25 @@
+DSAA
+10 10
+15.5 24.5
+10.5 19.5
+1.3795901536942 359.78637695312
+1.70141E+38 1.70141E+38 1.70141E+38 1.70141E+38 1.70141E+38 1.70141E+38 1.70141E+38 1.70141E+38 1.70141E+38 1.70141E+38
+1.70141E+38 54.044281005859 61.536731719971 26.817855834961 27.830316543579 133.78686523438 160.15232849121 179.70936584473 172.18589782715 1.70141E+38
+1.70141E+38 353.74163818359 22.493587493896 1.3795901536942 320.41970825195 252.02178955078 182.20143127441 163.56805419922 124.30812072754 1.70141E+38
+1.70141E+38 336.80844116211 325.04400634766 314.70040893555 310.37930297852 285.00897216797 205.49880981445 181.18598937988 176.19082641602 1.70141E+38
+1.70141E+38 320.38543701172 323.04837036133 342.1510925293 7.9401998519897 60.624557495117 202.65769958496 209.92497253418 235.44174194336 1.70141E+38
+1.70141E+38 347.72735595703 4.0403199195862 14.852857589722 20.189586639404 208.29371643066 208.56834411621 208.52819824219 222.8828125 1.70141E+38
+1.70141E+38 20.142166137695 359.78637695312 347.99960327148 285.37921142578 235.00204467773 227.87588500977 223.58207702637 161.80085754395 1.70141E+38
+1.70141E+38 313.41848754883 307.28234863281 300.10757446289 271.76864624023 244.55999755859 218.78259277344 236.69653320312 357.2619934082 1.70141E+38
+1.70141E+38 281.6360168457 294.11804199219 289.54504394531 286.39514160156 280.21655273438 162.12962341309 115.12343597412 334.69934082031 1.70141E+38
Added: grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_aspect.grd.aux.xml
--- grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_aspect.grd.aux.xml (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_aspect.grd.aux.xml 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,5 @@
+<PAMDataset>
+ <PAMRasterBand band="1">
+ <NoDataValue>-9.99900000000000E+03</NoDataValue>
+ </PAMRasterBand>
+</PAMDataset>
Added: grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_slope.grd
--- grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_slope.grd (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_slope.grd 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,25 @@
+DSAA
+10 10
+15.5 24.5
+10.5 19.5
+89.825134277344 89.994964599609
+1.70141E+38 89.963233947754 89.98900604248 89.994964599609 89.99275970459 89.988899230957 89.992683410645 89.992202758789 89.988243103027 1.70141E+38
+1.70141E+38 89.986907958984 89.989105224609 89.991172790527 89.991111755371 89.985824584961 89.992034912109 89.992797851562 89.987106323242 1.70141E+38
+1.70141E+38 89.990310668945 89.990707397461 89.98983001709 89.988838195801 89.98462677002 89.98787689209 89.990631103516 89.975311279297 1.70141E+38
+1.70141E+38 89.990867614746 89.990509033203 89.990196228027 89.986480712891 89.882415771484 89.987167358398 89.992004394531 89.990997314453 1.70141E+38
+1.70141E+38 89.989814758301 89.99072265625 89.992767333984 89.986122131348 89.977241516113 89.991233825684 89.993072509766 89.989074707031 1.70141E+38
+1.70141E+38 89.989501953125 89.990852355957 89.99259185791 89.985816955566 89.992454528809 89.994033813477 89.992149353027 89.825134277344 1.70141E+38
+1.70141E+38 89.987243652344 89.991683959961 89.99422454834 89.994071960449 89.992774963379 89.992279052734 89.979469299316 89.982360839844 1.70141E+38
+1.70141E+38 89.994606018066 89.99430847168 89.993423461914 89.992500305176 89.985404968262 89.979461669922 89.976203918457 89.972076416016 1.70141E+38
Added: grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_slope.grd.aux.xml
--- grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_slope.grd.aux.xml (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/data/gdal_slope.grd.aux.xml 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,5 @@
+<PAMDataset>
+ </PAMRasterBand>
+</PAMDataset>
Added: grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/test_r_slope_aspect.py
--- grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/test_r_slope_aspect.py (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.slope.aspect/testsuite/test_r_slope_aspect.py 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,163 @@
+from grass.gunittest.gmodules import call_module
+SMALL_MAP = """\
+north: 15
+south: 10
+east: 25
+west: 20
+rows: 5
+cols: 5
+100.0 150.0 150.0 100.0 100.0
+100.0 150.0 150.0 150.0 150.0
+class TestSlopeAspect(grass.gunittest.TestCase):
+ def test_limits(self):
+ slope = 'limits_slope'
+ aspect = 'limits_aspect'
+ self.assertModule('r.slope.aspect', elevation='elevation',
+ slope=slope, aspect=aspect)
+ self.assertRasterMinMax(map=slope, refmin=0, refmax=90,
+ msg="Slope in degrees must be between 0 and 90")
+ self.assertRasterMinMax(map=aspect, refmin=0, refmax=360,
+ msg="Aspect in degrees must be between 0 and 360")
+ def test_limits_precent(self):
+ slope = 'limits_percent_slope'
+ aspect = 'limits_percent_aspect'
+ slope=slope, aspect=aspect, format='percent')
+ self.assertRasterMinMax(map=slope, refmin=0, refmax=100,
+ msg="Slope in percent must be between 0 and 100")
+class TestSlopeAspectAgainstReference(grass.gunittest.TestCase):
+ Data created using::
+ g.region n=20 s=10 e=25 w=15 res=1
+ r.surf.fractal output=fractal_surf
+ r.out.ascii input=fractal_surf output=data/fractal_surf.ascii
+ gdaldem slope .../fractal_surf.ascii .../gdal_slope.grd -of GSAG
+ gdaldem aspect .../fractal_surf.ascii .../gdal_aspect.grd -of GSAG -trigonometric
+ GDAL version 1.11.0 was used. Note: GDAL-slope/aspect implementation is originally based on
+ GRASS GIS 4.1.
+ # precision for comparisons
+ precision = 0.0001
+ @classmethod
+ call_module('g.region', n=20, s=10, e=25, w=15, res=1)
+ cls.elevation = 'fractal_surf'
+ cls.runModule('r.in.ascii', input='data/fractal_surf.ascii',
+ output=cls.elevation)
+ @classmethod
+ cls.runModule('g.remove', flags='f', type='raster', name=cls.elevation)
+ def test_slope(self):
+ ref_slope = 'reference_slope'
+ slope = 'fractal_slope'
+ # TODO: using gdal instead of ascii because of cannot seek error
+ self.runModule('r.in.gdal', flags='o',
+ input='data/gdal_slope.grd', output=ref_slope)
+ self.assertModule('r.slope.aspect', elevation=self.elevation,
+ slope=slope)
+ # check we have expected values
+ # check against reference data
+ self.assertRastersNoDifference(actual=slope, reference=ref_slope,
+ precision=self.precision)
+ def test_aspect(self):
+ ref_aspect = 'reference_aspect'
+ aspect = 'fractal_aspect'
+ input='data/gdal_aspect.grd', output=ref_aspect)
+ aspect=aspect)
+ self.assertRastersNoDifference(actual=aspect, reference=ref_aspect,
+class TestSlopeAspectAgainstItself(grass.gunittest.TestCase):
+ precision = 0.0000001
+ @classmethod
+ call_module('g.region', raster='elevation')
+ @classmethod
+ def test_slope_aspect_together(self):
+ """Slope and aspect computed separately and together should be the same
+ elevation = 'elevation'
+ t_aspect = 'sa_together_aspect'
+ t_slope = 'sa_together_slope'
+ s_aspect = 'sa_separately_aspect'
+ s_slope = 'sa_separately_slope'
+ self.assertModule('r.slope.aspect', elevation=elevation,
+ aspect=s_aspect)
+ slope=s_slope)
+ slope=t_slope, aspect=t_aspect)
+ self.assertRastersNoDifference(actual=t_aspect, reference=s_aspect,
+ self.assertRastersNoDifference(actual=t_slope, reference=s_slope,
+# TODO: implement this class
+class TestExtremes(grass.gunittest.TestCase):
+ def setUp(self):
+ self.use_temp_region()
+ self.del_temp_region()
+ def test_small(self):
+ elevation = 'small_elevation'
+ slope = 'small_slope'
+ aspect = 'small_aspect'
+ self.runModule('r.in.ascii', input='-', output=elevation,
+ stdin_=SMALL_MAP)
+ call_module('g.region', raster=elevation)
Modified: grass/branches/releasebranch_7_0/raster/r.sunmask/main.c
--- grass/branches/releasebranch_7_0/raster/r.sunmask/main.c 2015-01-01 20:56:58 UTC (rev 63918)
+++ grass/branches/releasebranch_7_0/raster/r.sunmask/main.c 2015-01-01 22:16:37 UTC (rev 63919)
@@ -361,7 +361,7 @@
fprintf(stdout, "sunangleabovehorizon=%f\n",
pdat->elevref);
- if (sretr / 60 <= 24.0) {
+ if (sretr / 60 <= 24) {
fprintf(stdout, "sunrise=%02d:%02d:%02d\n",
sretr / 60, sretr % 60, sretr_sec);
fprintf(stdout, "sunset=%02d:%02d:%02d\n", ssetr / 60,
@@ -382,7 +382,7 @@
fprintf(stdout, "Solar position: sun azimuth: %f, sun angle above horz. (refraction corrected): %f\n",
pdat->azim, pdat->elevref);
fprintf(stdout, "Sunrise time (without refraction): %02d:%02d:%02d\n",
fprintf(stdout, "Sunset time (without refraction): %02d:%02d:%02d\n",
@@ -409,7 +409,7 @@
if (use_solpos) {
G_debug(3, "current_time:%f sunrise:%f", current_time, sunrise);
if ((current_time < sunrise)) {
G_message(_("Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"),
pdat->hour, pdat->minute, pdat->second, sretr / 60,
@@ -420,7 +420,7 @@
G_warning(_("Nothing to calculate. Please verify settings."));
if ((current_time > sunset)) {
G_message(_("Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"),
pdat->hour, pdat->minute, pdat->second, ssetr / 60,
ssetr % 60, ssetr_sec);
Modified: grass/branches/releasebranch_7_0/raster/r.viewshed/main.cpp
--- grass/branches/releasebranch_7_0/raster/r.viewshed/main.cpp 2015-01-01 20:56:58 UTC (rev 63918)
+++ grass/branches/releasebranch_7_0/raster/r.viewshed/main.cpp 2015-01-01 22:16:37 UTC (rev 63919)
@@ -175,9 +175,12 @@
the algorithm will work correctly in theory. But this
requires some changes. To do. */
if (!(vp.row < hd->nrows && vp.col < hd->ncols)) {
- G_warning(_("Viewpoint outside grid"));
- G_warning(_("viewpont: (row=%d, col=%d)"), vp.row, vp.col);
- G_fatal_error(_("grid: (rows=%d, cols=%d)"), hd->nrows, hd->ncols);
+ /* unfortunately, we don't know the point coordinates now */
+ G_warning(_("Region extent: north=%d, south=%d, east=%d, west=%d"),
+ hd->window.north, hd->window.south, hd->window.east, hd->window.west);
+ G_warning(_("Region extent: rows=%d, cols=%d"), hd->nrows, hd->ncols);
+ G_warning(_("Viewpoint: row=%d, col=%d"), vp.row, vp.col);
+ G_fatal_error(_("Viewpoint outside of computational region"));
Added: grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/data/elevation.ascii
--- grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/data/elevation.ascii (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/data/elevation.ascii 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,153 @@
+north: 216990
+south: 215520
+east: 635950
+west: 633730
+rows: 147
+cols: 222
+86.3976590000000044 86.1764979999999952 86.0875929999999983 86.1971659999999957 86.2519379999999956 86.3007810000000006 86.3118589999999983 86.2783050000000031 86.3217700000000008 86.522437999999994 86.5938569999999999 86.5658949999999976 86.5471650000000068 86.4565580000000011 86.2814869999999985 86.4916529999999995 86.7166600000000045 86.6938250000000039 86.7711869999999976 86.6989820000000009 86.6916729999999944 86.7107390000000038 86.4141919999999999 86.1532899999999984 86.3693700000000035 86.550690000000003 86.4518360000000001 86.3601989999999944 86.3061450000000008 86.3756029999999981 86.495757999999995 86.5198900000000037 86.5632779999999968 86.5034789999999987 86.3967130000000054 86.2177279999999939 86.115074000000007 86.2844620000000049 86.5488430000000051 86.8983000000000061 87.1628489999999942 87.3140340000000066 87.5153430000000014 87.6569819999999993 87.8337939999999975 88.0348970000000008 88.2133330000000058 88.3279950000000014 88.5737000000000023 88.7753369999
999933 88.9606930000000062 88.9893040000000042 89.2606119999999947 89.8244169999999968 90.238669999999999 90.560173000000006 90.8671420000000012 91.2391279999999938 91.6175920000000019 91.9346390000000042 92.3135220000000061 92.8038480000000021 93.3375549999999947 93.5097959999999944 93.1337589999999977 92.526764 92.1170120000000026 91.7656400000000048 91.5638200000000069 91.6339260000000024 91.8270420000000058 92.0749890000000022 92.1333620000000053 92.3123779999999954 92.6876680000000022 92.9232250000000022 93.1338810000000024 93.0112529999999964 92.4417270000000002 91.4098589999999973 90.2126540000000006 89.3405840000000069 88.6997989999999987 88.3662410000000023 88.2839050000000043 88.6342700000000008 88.9261089999999967 89.5049669999999935 91.2466739999999987 92.8962939999999975 94.0739209999999986 94.9737850000000066 95.7912520000000001 96.6330719999999985 97.3222049999999967 97.7246549999999985 97.7147290000000055 97.4048080000000027 97.0168910000000011 96.56104299999
9998 96.3670730000000049 96.9709629999999976 98.0917660000000069 99.1139679999999998 99.9332119999999975 100.6184769999999986 101.1919019999999989 101.6780930000000041 102.1527940000000001 102.6132049999999936 103.0236739999999998 103.731262000000001 104.4255979999999937 104.8694150000000036 105.5154040000000037 106.1340639999999951 106.7223890000000068 107.3705290000000048 107.5499190000000027 107.4301530000000042 107.4717030000000051 107.3660579999999953 106.8108670000000018 105.8672789999999964 105.0763469999999984 104.2709579999999931 103.1723559999999935 101.8394320000000022 100.0818179999999984 98.8236619999999988 97.6664200000000022 95.6534039999999948 94.0971830000000011 93.5352550000000065 93.0430829999999958 92.4594040000000064 92.1540600000000012 92.2411730000000034 92.0971069999999941 92.2589569999999952 93.8825680000000062 96.3276440000000065 98.7629550000000052 100.5333789999999965 101.3050379999999961 101.8044280000000015 102.567504999999997 103.23947099999999
47 103.8178020000000004 104.4052120000000059 104.7089079999999939 104.7317890000000062 104.8499529999999993 105.0377500000000026 105.2757490000000047 105.511841000000004 105.9054720000000032 106.4363560000000035 107.0315630000000056 107.7188869999999952 108.0679020000000037 108.2394259999999946 108.6033860000000004 108.8748020000000025 108.9211810000000042 109.2105870000000039 109.6775590000000022 110.2174610000000001 110.6649170000000026 111.1362919999999974 111.7776949999999943 112.2945629999999966 112.6019670000000019 112.970123000000001 113.4608609999999942 113.9214020000000005 114.2313769999999948 114.3821559999999948 114.4796070000000014 114.5495990000000006 114.5396499999999946 114.5162890000000004 114.214691000000002 113.524360999999999 112.6714249999999993 111.8754200000000054 111.3320539999999994 111.4245609999999971 111.8159559999999999 112.2903979999999962 111.9351199999999977 110.5507199999999983 110.2499389999999977 111.1726680000000016 112.3814390000000003 113
.5463029999999947 114.3576350000000019 115.0843430000000041 115.8255769999999956 116.1901859999999971 116.1779400000000066 115.9818190000000016 115.5429079999999971 115.0178829999999977 114.3795549999999963 113.5097430000000003 112.5391390000000058 111.4704820000000041 110.5842360000000042 109.8993229999999954 108.1279140000000041 107.1071699999999964 107.7804179999999974 109.5256810000000058 111.1799319999999938 112.3817520000000059 113.3964079999999939 114.1542280000000034 114.6205669999999941 114.7597430000000003 114.4905320000000017 114.0406949999999995
+86.2743380000000002 86.2845690000000047 86.1922069999999962 86.1707380000000001 86.2651520000000005 86.3236919999999941 86.298491999999996 86.3130259999999936 86.4271470000000051 86.5125349999999997 86.5381550000000033 86.4880519999999962 86.4294280000000015 86.4205780000000061 86.3311080000000004 86.4580760000000055 86.5997700000000066 86.493347 86.6483609999999942 86.7119900000000001 86.5583270000000056 86.6208649999999949 86.5804980000000057 86.3866040000000055 86.405060000000006 86.4546129999999948 86.361510999999993 86.3118740000000031 86.2540889999999933 86.3786620000000056 86.582611 86.5116199999999935 86.5631259999999969 86.5141370000000052 86.3105699999999985 86.1434249999999935 86.1447450000000003 86.3657910000000015 86.7053989999999999 86.9474720000000048 87.0757519999999943 87.1593479999999943 87.3014370000000071 87.4351649999999978 87.6467059999999947 87.7762149999999934 87.9290469999999971 88.0447690000000023 88.1118550000000056 88.219420999999997 88.4855040000
000059 88.7075729999999965 89.0697250000000054 89.5942840000000018 89.9538040000000052 90.2632370000000037 90.5999759999999981 90.9758829999999961 91.3786929999999984 91.7403950000000066 92.0892790000000048 92.5440289999999948 92.9674150000000026 93.0339660000000066 92.6637879999999967 92.0056000000000012 91.4572370000000063 91.2074810000000014 91.2023700000000019 91.3124239999999929 91.4855119999999999 91.6859129999999993 91.7024380000000008 91.6883320000000026 91.954741999999996 92.2511059999999929 92.3832400000000007 92.1608509999999939 91.6477890000000031 90.7911909999999978 89.812775000000002 88.9113849999999957 88.4955439999999953 88.3604200000000048 88.7877040000000051 88.7797699999999992 88.6997300000000024 89.8436659999999989 91.4406280000000038 92.8423839999999956 93.8826289999999943 94.8145219999999966 95.4832530000000048 96.1569060000000064 96.7479320000000058 97.076233000000002 96.9984129999999993 96.7886510000000015 96.6735149999999948 96.3620910000000066 96.23
52450000000061 96.9289859999999948 98.1527710000000013 99.2164539999999988 100.0575330000000065 100.7875439999999969 101.4270170000000064 101.9692380000000043 102.4515690000000063 102.8872910000000047 103.149162000000004 103.6567380000000043 104.4009700000000009 104.8881609999999966 105.5081019999999938 106.0723339999999979 106.5420680000000004 107.109650000000002 107.295226999999997 107.3899080000000055 107.5460819999999984 107.2657619999999952 106.6260300000000001 105.9936519999999973 105.3704529999999977 104.4780200000000008 103.4098429999999951 102.1972659999999991 100.3008800000000065 98.4268040000000042 97.339500000000001 95.4128340000000037 93.4506990000000002 92.6317750000000046 92.3257370000000037 92.1227949999999964 91.9625929999999983 92.0662159999999972 91.9602809999999948 92.0719380000000029 94.1992719999999935 97.1464840000000009 99.1736980000000017 100.4664539999999988 101.2618480000000005 101.9088899999999995 102.4812770000000057 102.9321290000000033 103.4180
070000000029 103.8246690000000001 103.9265290000000022 103.9158860000000004 104.0144420000000025 104.2315439999999995 104.6398999999999972 104.9463350000000048 105.3038410000000056 105.8369830000000036 106.4627839999999992 107.2774579999999958 107.5513760000000048 107.6188889999999958 107.9934460000000058 108.2603150000000056 108.4030529999999999 108.6936649999999958 109.1607060000000047 109.9009860000000032 110.516998000000001 110.9639739999999932 111.5122070000000036 111.9835360000000009 112.4995499999999993 113.0575939999999946 113.5117419999999981 113.8246230000000025 114.0654449999999969 114.2256770000000046 114.150550999999993 113.9856800000000021 113.9378970000000066 113.8922649999999948 113.5947340000000025 112.8975980000000021 112.0854640000000018 111.2173609999999968 110.5182649999999995 110.5962679999999949 111.1609949999999998 111.5587539999999933 110.7594380000000029 109.5853039999999936 109.7974549999999994 110.9060360000000003 112.2660829999999947 113.46357000
00000043 114.226585 114.891814999999994 115.5519709999999947 115.9642410000000012 115.9011079999999936 115.5486980000000017 114.987922999999995 114.3739170000000058 113.6806179999999955 112.8734280000000041 111.8786010000000033 110.8400500000000051 110.1328809999999976 109.5116119999999995 107.5795590000000033 106.8561859999999939 108.3822329999999994 110.071472 111.272270000000006 112.2086110000000048 113.1101910000000004 113.8704910000000012 114.3152539999999959 114.4187929999999938 114.0934979999999968 113.5252839999999992
+86.1737899999999968 86.1819380000000024 86.144676000000004 86.1511310000000066 86.2765880000000038 86.4177629999999937 86.4715960000000052 86.4723280000000045 86.4368670000000066 86.5469360000000023 86.5521700000000038 86.4848180000000042 86.4669339999999949 86.3978809999999982 86.3533099999999934 86.4316560000000038 86.536011000000002 86.4405979999999943 86.4842220000000026 86.7106859999999955 86.6004180000000048 86.4097519999999975 86.4581529999999958 86.6010059999999982 86.6118929999999949 86.5058060000000069 86.405822999999998 86.2958449999999999 86.3116610000000009 86.4799730000000011 86.5706019999999938 86.418091000000004 86.4708629999999943 86.4941249999999968 86.2605740000000054 86.0965419999999995 86.0986180000000019 86.2984849999999994 86.6178510000000017 86.838745000000003 86.9659269999999935 86.9889830000000046 87.0467299999999966 87.1769409999999993 87.4042280000000034 87.5800930000000051 87.7713700000000046 87.8174740000000043 87.7506180000000029 87.87816599999
99931 88.1517259999999965 88.3377839999999992 88.6285780000000045 89.0969699999999989 89.5058819999999997 89.9072570000000013 90.3400189999999981 90.764686999999995 91.1966780000000057 91.5852200000000067 91.9226610000000051 92.336662000000004 92.6318660000000023 92.5428770000000043 92.050933999999998 91.3221510000000052 90.8574219999999997 90.7781219999999962 90.9370959999999968 91.0921859999999981 91.2619169999999968 91.3738479999999953 91.3171389999999974 91.3315659999999951 91.5270770000000056 91.6868670000000066 91.6367259999999959 91.339698999999996 90.9078290000000067 90.2022249999999985 89.283141999999998 88.6495359999999977 88.647437999999994 88.401488999999998 88.4494779999999992 88.4938810000000018 88.8507079999999974 90.0032120000000049 91.3028029999999973 92.5854340000000064 93.5850980000000021 94.4265060000000034 95.0223540000000071 95.609382999999994 96.098044999999999 96.2008359999999954 96.2317120000000017 96.2253269999999929 96.1755909999999972 96.085517999
9999933 96.1359939999999966 96.9327470000000062 98.2926029999999997 99.4399719999999974 100.3302690000000013 101.0290679999999952 101.6490629999999982 102.1768950000000018 102.6947100000000006 103.0898059999999958 103.2664950000000061 103.5622860000000003 104.2752150000000029 104.876213000000007 105.4461900000000014 105.9725799999999936 106.3880000000000052 106.7932359999999932 107.0293810000000008 107.3030009999999947 107.3277049999999946 106.8940960000000047 106.317504999999997 105.9296800000000047 105.2644269999999977 104.3786089999999973 103.4305569999999932 102.1665569999999974 100.3242950000000064 98.3400649999999956 97.0572590000000019 95.5225829999999974 93.2410809999999941 91.9598849999999999 91.9606399999999979 91.9667740000000009 91.8035349999999966 91.7796709999999933 91.723236 92.0732500000000016 94.3643950000000018 97.2936629999999951 99.0272980000000018 100.0882569999999987 100.7613369999999975 101.351768000000007 101.9972460000000041 102.4334259999999972 102.
7556919999999963 102.8637920000000037 102.7719040000000064 102.7694630000000018 102.9898910000000001 103.3849560000000025 103.9614030000000042 104.3842389999999938 104.6585850000000022 105.0986249999999984 105.6556470000000019 106.3938600000000037 106.7195739999999944 106.9381029999999981 107.346076999999994 107.6028589999999951 108.0127719999999982 108.5112529999999964 108.9127199999999931 109.5289460000000048 110.3164670000000029 110.9969410000000067 111.4812550000000044 112.0139850000000052 112.691794999999999 113.1412349999999947 113.436126999999999 113.7117080000000016 113.9212720000000019 113.9707789999999932 113.5973589999999973 113.2387920000000037 113.2504119999999972 113.1984250000000003 112.8601460000000003 112.1264270000000067 111.3324580000000026 110.4968800000000044 109.8139110000000045 109.8896330000000034 110.4984050000000053 110.784790000000001 109.7298049999999989 108.7784809999999993 109.3157350000000037 110.7109219999999965 112.1767499999999984 113.333466
0000000014 114.1637649999999979 114.797118999999995 115.2794650000000019 115.6317599999999999 115.5341640000000041 115.0098880000000037 114.3856119999999947 113.689826999999994 112.9715419999999995 112.1635670000000005 111.0136799999999937 109.7561720000000065 109.2124019999999973 108.8991010000000017 107.6262969999999939 107.4894790000000029 109.1041340000000019 110.344703999999993 111.169990999999996 111.8582920000000058 112.5835270000000037 113.3296129999999948 113.8052899999999994 113.8852839999999986 113.5766069999999957 112.9673540000000003
+86.2339779999999934 86.1084819999999951 86.0754009999999994 86.2309800000000024 86.2347110000000043 86.3998339999999985 86.6169589999999943 86.6209029999999984 86.4771420000000006 86.4941479999999956 86.4905239999999935 86.4027940000000001 86.4905320000000017 86.4044420000000031 86.3102039999999988 86.3877030000000019 86.4733729999999952 86.4150159999999943 86.4916529999999995 86.7073139999999967 86.7362059999999957 86.4894029999999958 86.3759610000000038 86.4944610000000011 86.5440899999999971 86.4617690000000039 86.3989640000000065 86.3852920000000069 86.4885179999999991 86.5819170000000042 86.5126190000000008 86.4102400000000017 86.4768679999999961 86.5220949999999931 86.319153 86.0420230000000004 86.0255200000000002 86.1819689999999952 86.3800959999999947 86.6777880000000067 86.8592150000000061 86.8704610000000059 86.8925930000000051 87.0529789999999934 87.2551270000000017 87.4429090000000002 87.5586469999999935 87.511146999999994 87.5032120000000049 87.6450119999999941
87.8126139999999964 87.9405059999999992 88.1207200000000057 88.5632319999999993 89.0797349999999994 89.5365299999999991 90.1057210000000026 90.6485289999999964 91.0881270000000001 91.4302440000000018 91.7837520000000069 92.1968080000000043 92.4002689999999944 92.1304549999999978 91.398216000000005 90.6560360000000003 90.4233020000000067 90.5050810000000041 90.7235260000000068 90.8812479999999994 91.0111770000000035 91.0429230000000018 90.9937670000000054 91.0652620000000042 91.2706830000000053 91.309227000000007 91.0374910000000028 90.7668000000000035 90.2732620000000026 89.5875020000000006 88.875007999999994 88.5444179999999932 88.3598329999999947 88.0843349999999958 87.8477550000000065 88.1735840000000053 89.0145190000000071 89.9203640000000064 91.1329039999999964 92.3602139999999991 93.2717899999999958 93.9668350000000032 94.4816589999999934 94.9437640000000016 95.2750779999999935 95.1948929999999933 95.4002229999999969 95.6855390000000057 95.6276859999999971 95.816153999
9999974 96.2157210000000021 97.1683809999999966 98.5273739999999947 99.7505490000000066 100.669312000000005 101.3034590000000037 101.8270339999999976 102.3381880000000024 102.8529889999999938 103.1946109999999948 103.353950999999995 103.5705800000000067 104.1533969999999982 104.7642290000000003 105.3183060000000069 105.8085329999999971 106.2197570000000013 106.4635770000000008 106.6694870000000037 106.9058689999999956 106.8250050000000044 106.4903340000000043 105.974457000000001 105.4371720000000039 104.7280039999999985 104.0502089999999953 103.2541889999999967 101.865074000000007 100.1765670000000057 98.7162699999999944 97.0998539999999934 95.6019820000000067 93.6045680000000004 91.8794709999999952 91.7934879999999964 91.941986 91.6395490000000024 91.4874499999999955 91.9322970000000055 93.0230870000000039 95.1744079999999997 97.527709999999999 98.8353730000000041 99.5035709999999938 99.8214040000000011 100.2406770000000051 101.2127380000000016 101.6895449999999954 101.7650
299999999959 101.6728590000000025 101.558014 101.6997599999999977 102.1182330000000036 102.739295999999996 103.4260940000000062 103.9645840000000021 104.1621860000000055 104.408173000000005 104.9389879999999948 105.5578309999999931 106.0695269999999937 106.5380710000000022 106.9011380000000031 107.232056 107.7996600000000029 108.3800659999999993 108.7978059999999942 109.4095839999999953 110.2569119999999998 111.0547329999999988 111.6243740000000031 112.303520000000006 112.8488849999999957 113.0847629999999953 113.3736719999999991 113.583564999999993 113.5376969999999943 113.4138109999999955 113.0175629999999956 112.60154 112.4903639999999996 112.4246519999999947 112.1214449999999943 111.342528999999999 110.4199749999999938 109.6327210000000036 109.1019440000000031 109.2166600000000045 109.8864970000000056 110.0970690000000047 108.9362110000000001 108.1796190000000024 109.0434649999999976 110.7419129999999967 112.1349110000000024 113.2350009999999969 114.0877299999999934 114.
6936649999999958 115.072661999999994 115.2017900000000026 114.8789979999999957 114.2642359999999968 113.5955809999999957 112.8189160000000015 112.0401690000000059 111.1157989999999955 109.8321909999999946 108.1137540000000001 107.323646999999994 107.9171070000000014 107.9044650000000019 107.9845810000000057 109.1861499999999978 110.1022030000000029 110.7948300000000046 111.4222639999999984 112.0242920000000026 112.6025470000000013 113.1319199999999938 113.2889019999999931 112.9514159999999947 112.3256449999999944
+86.3518600000000021 86.1870880000000028 86.0715789999999998 86.2259899999999959 86.0560380000000009 86.2280650000000009 86.520813000000004 86.6297529999999938 86.5741579999999971 86.4260940000000062 86.3902659999999969 86.3839870000000047 86.4508289999999988 86.4310530000000057 86.3721919999999983 86.4185329999999965 86.4505840000000063 86.4249109999999945 86.5148159999999962 86.6224979999999931 86.676604999999995 86.7144619999999975 86.691315000000003 86.5609129999999993 86.5023960000000045 86.4121700000000033 86.3057790000000011 86.3949810000000014 86.5955430000000064 86.5192870000000056 86.3078689999999966 86.2866209999999967 86.3439249999999987 86.4216540000000037 86.3722839999999934 86.1347200000000015 86.0553510000000017 86.1463930000000033 86.1973950000000002 86.3955990000000043 86.6289369999999934 86.7591550000000069 86.8317949999999996 86.9906919999999957 87.1720729999999975 87.3634720000000016 87.3467030000000051 87.2806700000000006 87.3406750000000045 87.409164000
0000041 87.5090710000000058 87.6144639999999981 87.6682739999999967 87.9325330000000065 88.469688000000005 89.0886610000000019 89.8242489999999947 90.5566939999999931 90.9937819999999959 91.1726299999999981 91.484809999999996 91.9461289999999991 92.1341089999999951 91.7100300000000033 90.7957310000000035 90.197417999999999 90.1363910000000033 90.2905350000000055 90.5115810000000067 90.6460110000000014 90.752562999999995 90.7688519999999954 90.7406689999999969 90.8005519999999962 91.1307749999999999 91.216583 90.6524430000000052 90.329741999999996 89.6741640000000046 88.859618999999995 88.7247160000000008 88.4647599999999983 87.7279130000000009 87.6201480000000004 87.7774430000000052 88.3276670000000053 88.9861910000000051 89.8769530000000003 90.9536130000000043 91.8694459999999964 92.6081389999999942 93.4731450000000024 93.9821620000000024 94.0906599999999997 94.2005079999999992 94.2284700000000015 94.5751949999999937 95.1888430000000056 95.5065160000000049 95.87187199999999
62 96.5107500000000016 97.6324460000000016 98.9634020000000021 100.089256000000006 100.9400329999999997 101.5381160000000023 102.0318220000000053 102.5705870000000033 102.9804529999999971 103.2198559999999929 103.3614960000000025 103.5932080000000042 104.0648960000000045 104.5849079999999987 105.1150669999999963 105.5932159999999982 105.9203870000000052 106.186126999999999 106.3662869999999998 106.3807139999999976 106.2698290000000014 106.0104599999999948 105.4513699999999972 104.7046430000000043 104.0214840000000009 103.4672010000000029 102.7351230000000015 101.5215529999999973 100.1056899999999956 98.8791889999999967 97.298064999999994 95.4426420000000064 93.7823180000000036 92.2249149999999958 91.5706250000000068 91.6459349999999944 91.4684599999999932 91.4344640000000055 92.6082459999999941 94.3146289999999965 95.9553829999999977 97.5358350000000058 98.5514139999999941 99.0370640000000009 99.2789760000000001 99.5573810000000066 100.2993239999999986 100.6457979999999992 1
00.5415729999999996 100.5030289999999979 100.6830980000000011 101.1227800000000059 101.7188720000000046 102.3822710000000029 103.1342769999999973 103.8197020000000066 104.0488200000000063 104.321280999999999 104.8914340000000038 105.4891429999999986 105.9857329999999962 106.469261000000003 106.8566969999999969 107.3817520000000059 107.8899920000000066 108.3875579999999985 109.027275000000003 109.8809969999999936 110.6005710000000022 111.2133029999999962 111.9162450000000035 112.5741419999999948 112.8665309999999948 113.0687259999999981 113.3142849999999981 113.2814560000000057 113.0731119999999947 112.8401719999999955 112.4691930000000042 112.0321579999999955 111.7107469999999978 111.6115800000000036 111.4453890000000058 110.6550900000000013 109.6033400000000029 108.7015150000000006 108.2998809999999992 108.5865710000000064 109.1868060000000042 109.0385210000000029 107.9368970000000019 107.7967830000000049 109.1361540000000048 110.8273319999999984 112.0993729999999999 113.11
41659999999973 113.8412780000000026 114.4111019999999996 114.7605060000000066 114.7449569999999994 114.2454299999999989 113.5421910000000025 112.7485049999999944 111.8665309999999948 110.936546000000007 109.8106609999999961 108.3932800000000043 106.4494320000000016 105.4122239999999948 106.771759000000003 107.7557139999999976 107.7713779999999986 108.7494509999999934 109.4802250000000043 110.0696489999999983 110.8134689999999978 111.4700389999999999 111.9870990000000006 112.3882140000000049 112.5565189999999944 112.2505490000000066 111.6269609999999943
+86.4126820000000038 86.2769779999999997 86.1436539999999979 86.1764450000000011 86.0928420000000045 86.1704479999999933 86.4118650000000059 86.5625229999999988 86.5488430000000051 86.4712600000000009 86.4248120000000029 86.4681850000000054 86.5049290000000042 86.4864039999999932 86.5065919999999977 86.4475479999999976 86.3055339999999944 86.2971569999999986 86.3979340000000064 86.4905930000000041 86.4843369999999965 86.5339890000000054 86.6664279999999962 86.7193829999999934 86.7614820000000009 86.6573719999999952 86.4146580000000029 86.2899699999999967 86.3942490000000021 86.2968220000000059 86.2711639999999989 86.4823460000000068 86.3207239999999985 86.2599409999999978 86.4245449999999948 86.4051900000000046 86.1930389999999989 86.1414180000000016 86.1472629999999953 86.1447979999999944 86.3646159999999981 86.6450040000000001 86.814155999999997 86.9583360000000027 87.098228000000006 87.216431 87.129920999999996 87.0768130000000014 87.1630250000000046 87.2330319999999944 87
.2659989999999937 87.2060929999999956 87.1752780000000058 87.3586580000000055 87.7581250000000068 88.3825070000000039 89.236976999999996 90.1592789999999979 90.6847149999999971 90.8273930000000007 91.0598070000000064 91.5268709999999999 91.6704710000000063 91.082642000000007 90.1816100000000063 89.823830000000001 89.879493999999994 90.0754620000000017 90.2748569999999972 90.357048000000006 90.462097 90.4435650000000066 90.4032749999999936 90.538856999999993 91.0565409999999957 91.2171100000000052 90.3858340000000027 89.8522420000000039 89.128112999999999 88.1467360000000042 88.2786710000000028 88.2314530000000019 87.5431669999999968 87.4349979999999931 87.6856310000000008 88.424980000000005 89.1189729999999969 89.9382860000000051 90.7583470000000005 91.5180969999999974 92.0622939999999943 92.9651180000000039 93.4393230000000017 93.3982699999999966 93.6817549999999954 94.2635879999999986 94.7725449999999938 95.2115859999999969 95.7238849999999957 96.2486799999999931 97.011489
9999999949 98.1290359999999993 99.3965149999999937 100.417823999999996 101.1696089999999941 101.7648619999999937 102.2678599999999989 102.8024599999999964 103.0731509999999957 103.1884689999999978 103.2985149999999948 103.5214310000000069 103.939423000000005 104.4279099999999971 104.8956830000000053 105.3130419999999958 105.5943680000000029 105.9457239999999985 106.0742719999999935 105.9626769999999993 105.8190840000000037 105.471069 104.6875760000000071 103.8538669999999939 103.0983509999999939 102.4864350000000002 101.8191989999999976 101.0050739999999934 99.8693920000000048 98.5274119999999982 97.0849000000000046 94.9595640000000003 93.1059190000000001 92.3750529999999941 91.6956789999999984 91.1910100000000057 91.1533050000000031 91.6686329999999998 93.1127850000000024 94.5971219999999988 95.8514480000000049 97.1011429999999933 98.2012629999999973 98.8989179999999948 99.1356810000000053 99.2678379999999976 99.5046839999999975 99.5185699999999969 99.4706500000000062 99.80
5655999999999 100.3645479999999992 101.0442280000000039 101.7559590000000043 102.4535750000000007 103.2282710000000066 103.9640959999999978 104.2739030000000042 104.7789839999999941 105.4029239999999987 105.9858090000000033 106.4200670000000031 106.8143160000000051 107.2389529999999951 107.7300340000000034 108.1674650000000071 108.771332000000001 109.6296770000000009 110.4226989999999944 110.948127999999997 111.4486239999999952 112.1104129999999941 112.6776890000000009 112.9215549999999979 113.0879589999999979 113.0663069999999948 112.8901749999999993 112.7652970000000039 112.4064410000000009 111.8982699999999966 111.468781000000007 110.9734270000000009 110.7409360000000049 110.6808010000000024 110.0114059999999938 108.984382999999994 107.9013750000000016 107.4867629999999963 107.765900000000002 107.9266199999999998 107.4112630000000053 106.9231029999999976 107.6933439999999962 109.2517399999999981 110.7282260000000065 111.9893490000000043 112.9415359999999993 113.5516970000
000043 114.0756530000000026 114.3979190000000017 114.2606049999999982 113.6424410000000051 112.7855909999999966 111.8909069999999986 110.8435970000000026 109.643921000000006 108.2066879999999998 106.8194809999999961 105.3507610000000057 104.5330890000000039 105.7898100000000028 107.316986 107.3112560000000002 107.8831250000000068 108.5243909999999943 109.057495000000003 109.9210280000000068 110.7911220000000014 111.4611969999999985 111.7171940000000063 111.7931590000000028 111.5464709999999968 110.9190600000000018
+86.4783479999999969 86.4350809999999967 86.2708439999999968 86.2481230000000068 86.2622070000000036 86.2166820000000058 86.2570110000000057 86.3879390000000029 86.4049990000000037 86.4114759999999933 86.3835219999999993 86.468238999999997 86.5377579999999966 86.4811779999999999 86.4121860000000055 86.3191599999999966 86.1553650000000033 86.1757199999999983 86.2660750000000007 86.3609469999999959 86.3677670000000006 86.2905350000000055 86.2645190000000071 86.4083710000000025 86.589934999999997 86.6190189999999944 86.545653999999999 86.3424150000000026 86.234375 86.3091809999999953 86.5721970000000027 86.8220670000000041 86.5503920000000022 86.2246549999999985 86.3898470000000032 86.571479999999994 86.3546599999999955 86.1522369999999995 86.1163789999999949 86.0965810000000005 86.2042160000000024 86.4833600000000047 86.697936999999996 86.8477780000000052 86.9663089999999954 87.022712999999996 86.978935000000007 86.9344410000000067 86.9605179999999933 87.0523610000000048 87.054
4280000000015 86.933205000000001 86.8924480000000017 87.0514069999999975 87.3113330000000047 87.7008129999999966 88.4508589999999941 89.332367000000005 89.9120640000000009 90.2153930000000059 90.5030670000000015 90.8981019999999944 90.9804610000000054 90.3835530000000063 89.6845930000000067 89.5387499999999932 89.639167999999998 89.8280489999999929 89.9839939999999956 90.0696259999999995 90.1716689999999943 90.1176379999999995 90.1532669999999996 90.4703899999999948 90.9939729999999969 90.9207459999999941 90.0049589999999995 89.3958820000000003 88.5947879999999941 87.7911220000000014 87.8836210000000051 87.7970959999999963 87.4685970000000026 87.3689650000000029 87.8578190000000063 88.588050999999993 89.2878570000000025 90.0330349999999981 90.6765749999999997 91.4373169999999931 91.9081879999999956 92.5152590000000004 92.939826999999994 93.2335209999999961 93.9360279999999932 94.8562320000000057 95.4625400000000042 95.719420999999997 96.1278230000000065 96.7281420000000054 9
7.5190809999999999 98.4808809999999966 99.7412869999999998 100.694587999999996 101.3543010000000066 101.9558640000000054 102.4606090000000052 102.9075550000000021 103.0628810000000044 103.1182170000000013 103.2185900000000061 103.375 103.7394409999999993 104.1993259999999992 104.6658400000000029 105.0273590000000041 105.2479019999999963 105.5906910000000067 105.6439440000000047 105.5328829999999982 105.3400960000000026 104.8530959999999936 103.866981999999993 102.8996730000000071 101.9525299999999959 101.2183610000000016 100.7843170000000015 100.192420999999996 99.1611330000000066 97.9587630000000047 96.3037410000000023 93.8699649999999934 92.1101529999999968 92.1861650000000026 92.0556720000000013 91.3938220000000001 91.4604109999999935 92.3259510000000034 93.4482189999999946 94.2803569999999951 95.2979279999999989 96.4508510000000001 97.5553670000000039 98.4199600000000032 98.5840610000000055 98.5798869999999994 98.7033389999999997 98.5796200000000056 98.8049769999999938 9
9.5496059999999972 100.298088000000007 101.1253590000000031 101.9909669999999977 102.8059389999999951 103.6864010000000036 104.3564829999999972 104.7280269999999973 105.3018189999999947 105.9145129999999995 106.4709239999999966 106.9561690000000027 107.4118959999999987 107.7980579999999975 108.1141199999999998 108.7111050000000034 109.4369429999999994 110.1113890000000026 110.6136319999999955 111.1247180000000014 111.5484390000000019 112.1116260000000011 112.7232060000000047 113.001380999999995 112.9607699999999966 112.7437440000000066 112.5350420000000042 112.2778320000000036 111.8434450000000027 111.3830030000000022 110.9820940000000036 110.3504790000000071 109.8261569999999949 109.6553880000000021 109.2485960000000063 108.4150850000000048 107.4299550000000067 106.9030230000000046 106.8315889999999939 106.5903399999999976 106.070258999999993 106.2989879999999943 107.6168210000000016 109.0691680000000048 110.446044999999998 111.751189999999994 112.7536699999999996 113.39632
4000000007 113.8783650000000023 114.1644900000000007 113.8540569999999974 113.0273509999999959 112.0458220000000011 110.7944870000000037 109.2601169999999939 107.936278999999999 106.5317000000000007 105.5356519999999989 104.682343000000003 104.2536089999999973 105.0855710000000016 106.6873169999999931 106.978943000000001 106.8262179999999972 107.3564760000000007 107.9781720000000007 108.8761219999999952 109.8576280000000054 110.5645520000000062 110.8630140000000068 110.9335860000000054 110.8224409999999978 110.2696530000000052
+86.568207000000001 86.6094889999999964 86.4047549999999944 86.3396450000000044 86.3109209999999933 86.2713470000000058 86.1305009999999953 86.1141970000000043 86.2617719999999935 86.3647310000000061 86.3549730000000011 86.3571620000000024 86.3884280000000047 86.3578260000000029 86.2356489999999951 86.2227550000000065 86.2179409999999962 86.1960679999999968 86.2226179999999971 86.3262249999999938 86.3469159999999931 86.3055949999999967 86.2502520000000032 86.2749629999999996 86.3149800000000056 86.3961869999999976 86.5148769999999985 86.4834440000000058 86.426361 86.5700149999999979 86.7212449999999961 86.7569119999999998 86.6663360000000011 86.3501969999999943 86.2561259999999947 86.5692899999999952 86.4917760000000015 86.1882319999999993 86.0551150000000007 86.0610120000000052 86.1513669999999934 86.3301850000000002 86.559227000000007 86.6518630000000059 86.7541499999999957 86.8933329999999984 86.8919910000000044 86.813202000000004 86.7885890000000018 86.8308559999999972 86
.7720110000000062 86.7305369999999982 86.7775419999999968 86.8887560000000008 87.0341870000000029 87.219727000000006 87.7065429999999964 88.3278119999999944 88.8768230000000017 89.3110889999999955 89.7290880000000044 90.0835419999999942 90.1252369999999985 89.7799299999999931 89.3951870000000071 89.3706590000000034 89.4376220000000046 89.5407560000000018 89.6558529999999934 89.7941509999999994 89.8817140000000023 89.8819430000000068 90.0638430000000056 90.4732819999999975 90.8204499999999939 90.3936230000000052 89.4156650000000042 88.8990710000000064 88.3045730000000049 87.8759160000000037 87.6873319999999978 87.4985960000000063 87.3438189999999963 87.4575580000000059 88.0059590000000043 88.6007000000000033 89.2714390000000009 90.0304490000000044 90.7385940000000062 91.2514340000000033 91.6311110000000042 92.0179140000000046 92.511382999999995 93.1911620000000056 94.2796479999999946 95.1263119999999986 95.6390229999999946 96.1470790000000051 96.7040860000000038 97.2508389999
999991 97.8339610000000022 98.7185290000000037 100.0200580000000059 100.8835679999999968 101.473938000000004 102.0757899999999978 102.5681079999999952 102.8979640000000018 103.0088959999999929 103.0582729999999998 103.1396940000000058 103.2412869999999998 103.499572999999998 103.9035640000000029 104.3793330000000026 104.7509000000000015 104.9676970000000011 105.2404250000000019 105.2483289999999982 105.0363849999999957 104.6812589999999972 104.032898000000003 103.0420610000000039 101.9778369999999938 100.8602450000000061 99.894835999999998 99.5597530000000006 99.1184080000000023 98.1581189999999992 97.1060329999999965 95.2449260000000066 92.8658910000000049 91.491264000000001 91.5153269999999992 92.0621950000000027 92.1583559999999977 92.2363280000000003 92.8311309999999992 93.5248950000000008 94.0349350000000044 94.6974560000000025 95.5630040000000065 96.3625949999999989 97.1106570000000033 97.5052490000000063 97.5993650000000059 97.8753509999999949 98.0714420000000047 98.5
380099999999999 99.3519359999999949 100.1326600000000013 101.0640719999999959 102.1035609999999991 103.0751800000000031 104.1621399999999937 104.7780149999999963 105.1721270000000032 105.6770400000000052 106.2727430000000055 106.8846280000000064 107.3904189999999943 107.9214860000000016 108.3288799999999981 108.6958920000000006 109.3442150000000055 109.930176000000003 110.3592000000000013 110.7323229999999938 111.1582640000000026 111.5663530000000065 112.1508939999999939 112.7929149999999936 112.9690630000000056 112.7644499999999965 112.5076449999999966 112.0837169999999929 111.5840299999999985 111.1869509999999934 110.7894969999999972 110.3684839999999951 109.7533719999999988 108.9402919999999995 108.4404219999999981 108.137244999999993 107.5656589999999966 106.8771210000000025 106.3547439999999966 106.0873179999999962 105.8103179999999952 105.4942400000000049 106.0237429999999961 107.3476720000000029 108.736701999999994 110.1298139999999961 111.4540480000000002 112.5719069
999999959 113.2836300000000023 113.7191930000000042 113.9356920000000031 113.5421520000000015 112.4835970000000032 111.2569349999999986 109.3616180000000071 107.5003430000000009 106.4052429999999987 105.3936309999999992 104.6828540000000061 103.8542860000000019 103.7960659999999962 104.5309680000000014 105.8198009999999982 106.7279280000000057 106.2518160000000051 106.3914259999999956 107.1207959999999986 107.9932100000000048 108.8152390000000054 109.3887710000000055 109.7434539999999998 109.9380950000000041 110.119536999999994 109.6470790000000051
+86.4910809999999941 86.6162570000000045 86.543334999999999 86.4023509999999959 86.2936859999999939 86.2286380000000037 86.2083740000000063 86.261382999999995 86.3451459999999997 86.3987199999999973 86.4322590000000019 86.3124389999999977 86.3035349999999966 86.2416309999999982 86.2270129999999995 86.2940899999999971 86.3246079999999978 86.2916110000000032 86.225646999999995 86.3145980000000037 86.4606169999999992 86.4604949999999945 86.4759600000000006 86.5268250000000023 86.4040219999999977 86.3603669999999966 86.4186480000000046 86.4918980000000062 86.5871350000000035 86.5869450000000001 86.5603789999999975 86.565796000000006 86.5839770000000044 86.5536960000000022 86.361534000000006 86.3966139999999996 86.5074230000000028 86.2680359999999951 86.0619509999999934 85.9916690000000017 86.1101000000000028 86.2692490000000021 86.4614490000000018 86.4783330000000063 86.5191800000000057 86.7065730000000059 86.7361829999999969 86.6705170000000038 86.6260529999999989 86.61316700000
00042 86.5381320000000045 86.5446010000000001 86.6487580000000008 86.7110669999999999 86.7167429999999939 86.8581089999999989 87.1763380000000012 87.5270840000000021 87.9854349999999954 88.4265369999999962 88.8283839999999998 89.1754530000000045 89.277434999999997 89.2243579999999952 89.1617360000000048 89.2405009999999947 89.2499619999999965 89.281257999999994 89.3812329999999946 89.4988249999999965 89.5864490000000018 89.664787000000004 89.9346079999999972 90.3223420000000061 90.4472119999999933 89.7204590000000053 88.7865749999999991 88.3890459999999933 88.128272999999993 88.141295999999997 87.6369930000000039 87.2854229999999944 87.3228450000000009 87.6491780000000063 88.0265809999999931 88.525108000000003 89.1930009999999953 89.7966380000000015 90.5216450000000066 90.9743500000000012 91.2649080000000055 91.5467680000000001 92.2211910000000046 93.4383009999999956 94.8042679999999933 95.5152970000000039 95.9170610000000039 96.4981989999999996 97.0689469999999943 97.488060
0000000044 97.9910129999999953 98.9471209999999957 100.2131959999999964 100.9577259999999939 101.5707469999999972 102.1276170000000008 102.5046839999999975 102.8442840000000018 102.9262999999999977 102.8791580000000039 102.9436800000000005 103.0417709999999971 103.2464370000000002 103.7090910000000008 104.1343459999999936 104.5717700000000008 104.9143519999999938 104.9838790000000017 104.8702009999999945 104.549469000000002 104.039116000000007 103.2246860000000055 102.2287220000000048 101.2501680000000022 100.117125999999999 98.886382999999995 98.2124100000000055 97.7917560000000066 97.0311580000000049 95.8645779999999945 94.1497959999999949 92.3990629999999982 91.2366870000000034 90.8471760000000046 91.5838470000000058 92.4366229999999973 92.6178210000000064 92.8141020000000054 93.2683940000000007 93.6764069999999975 94.1278230000000065 94.7558060000000069 95.3103179999999952 95.917548999999994 96.6116710000000012 97.0747219999999942 97.5773010000000056 98.1673049999999989
98.7162859999999966 99.4300539999999984 100.2019880000000001 101.0688629999999932 102.157188000000005 103.3281709999999975 104.4481049999999982 105.0379099999999966 105.3700099999999935 105.8428190000000058 106.6174160000000057 107.276329000000004 107.7548369999999949 108.2210539999999952 108.7140430000000038 109.259681999999998 109.7360610000000065 110.1243130000000008 110.5307159999999982 110.9084780000000023 111.2350689999999958 111.683684999999997 112.2144849999999963 112.7839280000000031 112.8859939999999966 112.6672740000000061 112.2837219999999974 111.6575160000000011 110.988617000000005 110.4195399999999978 109.8635029999999944 109.4345090000000056 109.0082780000000042 108.1963269999999966 107.3926539999999932 106.8270030000000048 106.2538600000000031 105.6515959999999978 105.318634000000003 105.1930389999999989 105.0626830000000069 105.124724999999998 105.813873000000001 107.0401459999999929 108.4737630000000053 109.8928599999999989 111.2441790000000026 112.41114000
00000032 113.1270980000000037 113.5431820000000016 113.6746059999999972 113.1984410000000025 112.0165180000000049 110.449584999999999 108.380195999999998 106.7828290000000067 105.850127999999998 104.8762360000000058 104.0181809999999984 103.0308840000000004 103.1568829999999934 103.9028629999999964 104.7439499999999981 106.1671369999999968 106.2887120000000039 105.9567720000000008 106.5848309999999941 107.4581150000000065 108.1524509999999992 108.6360020000000048 108.9480290000000053 109.1984860000000026 109.5065460000000002 108.9673460000000063
+86.3201519999999931 86.4899599999999964 86.6047740000000061 86.4284669999999977 86.3201289999999943 86.2562709999999981 86.3330540000000042 86.4800340000000034 86.4876560000000012 86.4717789999999979 86.5360340000000008 86.397246999999993 86.2531280000000038 86.295685000000006 86.4559710000000052 86.4589689999999962 86.4211200000000019 86.4356769999999983 86.3089219999999955 86.184394999999995 86.2315219999999982 86.4119029999999952 86.4866030000000023 86.6022640000000052 86.5003360000000043 86.3469620000000049 86.3021470000000051 86.3940120000000036 86.5138929999999959 86.4411470000000008 86.4039460000000048 86.3952100000000058 86.4071270000000027 86.623383000000004 86.616271999999995 86.2815549999999973 86.466148000000004 86.374297999999996 86.100594000000001 86.0046920000000057 86.0017550000000028 86.1330800000000067 86.2802659999999975 86.2736210000000057 86.2551040000000029 86.3532260000000065 86.4882810000000006 86.5361400000000032 86.4628600000000063 86.40834800000000
37 86.4025419999999968 86.416175999999993 86.4850390000000004 86.4680180000000007 86.4551770000000062 86.6743770000000069 86.9085309999999964 87.1102520000000027 87.4626389999999958 87.813477000000006 88.0980220000000003 88.4156949999999995 88.7052149999999955 88.8515170000000012 88.9400789999999972 89.0803149999999988 89.0460970000000032 89.031952000000004 89.1248700000000014 89.2253419999999977 89.3365479999999934 89.4858930000000043 89.7711639999999989 90.025108000000003 89.872649999999993 89.059905999999998 88.3459550000000036 88.0932080000000042 87.8074720000000042 88.054466000000005 87.8270190000000071 87.0616150000000033 87.3555300000000017 87.7584609999999969 88.0219189999999969 88.529869000000005 89.1496580000000023 89.6101989999999944 90.1344220000000007 90.5629430000000042 90.9855040000000059 91.5485610000000065 92.6671750000000003 94.1763310000000047 95.302550999999994 95.8175430000000006 96.2393260000000055 96.7361449999999934 97.1808319999999952 97.628685000000
0044 98.2052079999999989 99.1804580000000016 100.3216479999999962 100.9575040000000001 101.6717909999999989 102.2167589999999961 102.4237750000000062 102.6778410000000008 102.7137069999999994 102.6075739999999996 102.6323849999999993 102.7367550000000023 103.009917999999999 103.5034639999999939 103.8136520000000047 104.2083889999999968 104.6583329999999989 104.7346339999999998 104.4905009999999947 104.1115949999999941 103.6805190000000039 102.8487700000000018 101.6956330000000008 100.6803819999999945 99.6868900000000053 98.364570999999998 97.2139130000000051 96.4871669999999995 95.8246610000000061 94.5443949999999944 93.1402130000000028 91.8770140000000026 90.9227290000000039 90.6700060000000008 91.0271000000000043 92.1153340000000043 92.815605000000005 93.0197069999999968 93.2826539999999937 93.6600569999999948 94.122437000000005 94.6460270000000037 95.2484970000000004 95.9489290000000068 96.7963940000000065 97.579741999999996 98.1137619999999941 98.6320570000000032 99.2582
859999999982 100.0564880000000016 100.8111040000000003 101.5282140000000055 102.6400450000000006 103.8506849999999986 104.7537229999999937 105.2369079999999997 105.5496830000000017 106.1411899999999946 106.991187999999994 107.5912399999999991 108.0373079999999959 108.4283219999999943 108.9532549999999986 109.5268939999999986 110.024628000000007 110.358856000000003 110.6729660000000024 111.0725560000000058 111.4750669999999957 111.823639 112.178520000000006 112.6748050000000063 112.8095550000000031 112.4955290000000048 112.0783839999999998 111.5036620000000056 110.569580000000002 109.6556089999999983 108.8898319999999984 108.3260649999999998 107.9801410000000033 107.3998030000000057 106.5334849999999989 105.6410139999999984 104.8186259999999947 104.2286380000000037 104.0945660000000004 104.0792009999999976 104.0724720000000048 104.6530529999999999 105.6219789999999961 106.9193800000000039 108.4031679999999938 109.8597720000000066 111.1791230000000041 112.3021159999999981 113.
0341339999999946 113.3891069999999957 113.4786380000000037 112.8463899999999995 111.5313419999999951 109.9915850000000006 108.2359009999999984 106.6905210000000039 105.5989529999999945 104.4587860000000035 103.4914019999999937 102.5661390000000068 102.3857880000000051 102.9607539999999943 103.7198489999999964 105.327171000000007 106.3919680000000056 106.0102689999999939 106.3595200000000034 107.2223209999999938 107.9581759999999946 108.4181590000000028 108.644867000000005 108.8006290000000007 108.9489360000000033 108.308448999999996
+86.3615800000000036 86.3992310000000003 86.5193409999999972 86.4538040000000052 86.3320850000000064 86.4145809999999983 86.4319689999999952 86.2854540000000014 86.3211139999999943 86.4797360000000026 86.5119320000000016 86.3408280000000019 86.1512989999999945 86.3483350000000058 86.5914690000000036 86.5345839999999953 86.4678880000000021 86.4544369999999986 86.3951569999999975 86.1593859999999978 86.0182949999999948 86.2413250000000033 86.3172679999999986 86.3624499999999955 86.3309859999999958 86.2737120000000033 86.2425000000000068 86.2724610000000069 86.3230669999999947 86.3622280000000018 86.3495180000000033 86.2972639999999984 86.3055729999999954 86.5139309999999995 86.6590419999999995 86.3095019999999948 86.3520970000000005 86.4473109999999991 86.2624279999999999 86.1363220000000069 86.009925999999993 86.0348890000000068 86.1386870000000044 86.189423000000005 86.237480000000005 86.2165300000000059 86.2360079999999982 86.2634280000000047 86.2798229999999933 86.247237999
9999958 86.2187270000000012 86.321228000000005 86.3165819999999968 86.2968369999999965 86.3708110000000033 86.5407490000000053 86.6811519999999973 86.8582760000000036 87.1827090000000027 87.4386219999999952 87.6656569999999959 87.9573970000000003 88.3154679999999956 88.5614620000000059 88.6388699999999972 88.7633589999999941 88.7695080000000019 88.7855610000000013 88.8453449999999947 88.9084699999999941 89.0130539999999968 89.2591550000000069 89.5613780000000048 89.609893999999997 89.2958449999999999 88.6728360000000038 88.0743709999999993 87.8401340000000062 87.7111359999999962 87.7619629999999944 87.4626849999999934 87.0680619999999976 87.3881229999999931 87.7560200000000066 88.0352100000000064 88.4441149999999965 89.030974999999998 89.5127030000000019 89.872840999999994 90.3894200000000012 91.2067339999999973 92.2813869999999952 93.7716290000000043 95.0628509999999949 95.7258530000000007 96.0966339999999946 96.4529419999999931 96.889435000000006 97.3109050000000053 97.829
0559999999942 98.4313889999999958 99.3340380000000067 100.3408199999999937 100.7943949999999944 101.3380659999999978 102.0225829999999974 102.3860700000000037 102.4707640000000026 102.4551850000000002 102.3666230000000041 102.3358460000000036 102.4751049999999992 102.8358000000000061 103.2545779999999951 103.3980030000000028 103.638023000000004 104.1853870000000057 104.4521940000000058 104.1763380000000012 103.7576899999999966 103.3519129999999961 102.5128330000000005 101.3117369999999937 100.2456130000000059 99.315796000000006 98.1065219999999982 96.7865139999999968 95.5354159999999979 94.582374999999999 93.4155429999999996 92.2304919999999981 91.1411740000000066 90.4672549999999944 90.564635999999993 91.0814510000000013 92.0284960000000041 92.9442059999999941 93.5098799999999954 93.8128049999999973 94.2298049999999989 94.7575070000000039 95.3925700000000063 96.283851999999996 97.2368550000000056 98.075523000000004 98.7854229999999944 99.1774290000000036 99.3961410000000001
100.0671999999999997 100.8992310000000003 101.6980060000000066 102.4578170000000057 103.5735020000000048 104.5708920000000006 105.1019739999999985 105.446747000000002 105.9185410000000047 106.5767290000000003 107.2101519999999937 107.773499000000001 108.3207170000000019 108.774872000000002 109.1631930000000068 109.7109300000000047 110.2895280000000042 110.5622099999999932 110.8806000000000012 111.2638400000000019 111.5838999999999999 111.8627319999999941 112.1263660000000044 112.5630419999999958 112.6859740000000016 112.2495040000000017 111.9518199999999979 111.5719299999999947 110.6018830000000008 109.5464549999999946 108.5156779999999941 107.4821319999999929 106.7605360000000019 106.1242139999999949 105.3019709999999947 104.4779889999999938 103.8062900000000042 103.3023680000000013 103.1288530000000065 103.1483309999999989 103.4080510000000004 104.4213259999999934 105.670417999999998 107.0248339999999985 108.5150909999999982 109.9421839999999975 111.2070389999999946 112.3
153839999999946 113.0128559999999993 113.180603000000005 113.083800999999994 112.4147719999999993 111.0651929999999936 109.752167 108.2017900000000026 106.5847090000000037 105.2331310000000002 103.9687880000000035 103.2302399999999949 102.3694760000000059 101.6378559999999993 102.1883389999999991 103.4358139999999935 104.7987140000000039 106.2253189999999989 106.2616730000000018 106.4463959999999929 107.220130999999995 107.904114000000007 108.285308999999998 108.4405139999999932 108.5344699999999989 108.4974749999999943 107.7361599999999981
+86.3778839999999946 86.3303070000000048 86.4093019999999967 86.3929059999999964 86.2564469999999943 86.3542790000000053 86.445098999999999 86.2820969999999932 86.184394999999995 86.3874440000000021 86.4768909999999948 86.3440319999999986 86.2318879999999979 86.3179860000000048 86.4761890000000051 86.5167919999999953 86.456657000000007 86.4116669999999942 86.4566350000000057 86.4142989999999998 86.2437209999999936 86.2550430000000006 86.3171159999999986 86.2326510000000042 86.2304460000000006 86.2347639999999984 86.2288669999999939 86.2313610000000068 86.2271729999999934 86.2739179999999948 86.3521120000000053 86.4252780000000058 86.3517379999999974 86.3637240000000048 86.5666279999999944 86.4333110000000033 86.2553630000000027 86.3749470000000059 86.3509829999999994 86.2399220000000071 86.1605909999999966 86.1731869999999986 86.2406849999999991 86.2834009999999978 86.4487299999999976 86.3956759999999946 86.2176280000000048 86.1302259999999933 86.1893539999999945 86.209038000
0000067 86.1812970000000007 86.2927020000000056 86.294739000000007 86.2487409999999954 86.2865680000000026 86.4028019999999941 86.4905009999999947 86.6666029999999949 86.9344480000000033 87.1494979999999941 87.3954999999999984 87.6571730000000002 87.9295580000000001 88.2291259999999937 88.3686139999999938 88.3919910000000044 88.4546660000000031 88.5438919999999996 88.5145569999999964 88.5316090000000031 88.6289600000000064 88.8923649999999981 89.1997379999999964 89.1899259999999998 88.9319459999999964 88.4149929999999955 87.7638469999999984 87.4000319999999959 87.5380169999999964 87.5113599999999963 87.1992869999999982 87.3299710000000005 87.5337449999999961 87.7751540000000006 88.0489500000000049 88.3856049999999982 88.9477310000000045 89.3722460000000041 89.8559190000000001 90.7846370000000036 91.9848400000000055 93.3228529999999949 94.7068859999999972 95.720130999999995 96.1675259999999952 96.3454590000000053 96.5902940000000001 97.0181120000000021 97.4676819999999964 97.
911445999999998 98.4290539999999936 99.2758939999999939 100.2064670000000035 100.5951539999999937 100.8491970000000038 101.506134000000003 102.1884689999999978 102.3400730000000038 102.2566379999999953 102.1156459999999981 102.1311259999999947 102.2926180000000045 102.6260759999999976 102.8739089999999976 102.9595570000000038 103.3363039999999984 103.8722839999999934 104.0967409999999944 103.9130099999999999 103.4551850000000002 102.8982089999999943 101.9589310000000069 100.872596999999999 99.8496700000000033 98.7914049999999975 97.7106169999999992 96.5574799999999982 95.2381129999999985 93.8799669999999935 92.6074069999999949 91.5024109999999951 90.5931929999999994 90.2643429999999967 90.7282100000000042 91.5797270000000054 92.3701779999999957 93.1382830000000013 93.9155499999999961 94.5112529999999964 95.0578689999999966 95.7288889999999952 96.5471339999999998 97.6360930000000025 98.7344439999999963 99.5614400000000046 100.1581800000000015 100.518897999999993 100.727042999
9999948 101.3604509999999976 102.0324099999999987 102.790222 103.6269910000000039 104.5418010000000066 105.2239000000000004 105.4068220000000053 105.7569349999999986 106.3682859999999977 106.9308240000000012 107.407227000000006 108.0455319999999944 108.6537320000000051 109.0488359999999943 109.4369279999999947 109.9869609999999938 110.3941879999999998 110.679230000000004 111.0276790000000062 111.2467419999999976 111.4392780000000016 111.7312160000000034 112.0200650000000024 112.4357530000000054 112.5737079999999963 112.1597289999999987 111.8790359999999993 111.589256000000006 110.852753000000007 109.8337479999999999 108.7198329999999942 107.3897089999999963 106.1155619999999971 105.0044479999999965 104.0903469999999942 103.4561839999999933 102.9042359999999974 102.4294969999999978 102.3208850000000041 102.5656510000000026 103.2960740000000044 104.5962829999999997 105.9304889999999943 107.1885379999999941 108.6303249999999991 110.0333250000000049 111.3491060000000061 112.4335
329999999971 112.9320299999999975 112.8798220000000043 112.4743650000000059 111.8178410000000014 110.6718520000000012 109.3821640000000031 108.003296000000006 106.7480620000000044 105.3062209999999936 103.6844559999999973 103.0956950000000063 102.3460620000000034 101.3293840000000046 102.2404099999999971 103.7886199999999945 104.6767200000000031 105.9143140000000045 106.399162000000004 106.5261229999999983 107.2202379999999948 107.7561950000000053 108.0183940000000007 108.1353529999999949 108.3053210000000064 108.1533969999999982 107.0963820000000055
+86.4456559999999996 86.5027309999999972 86.5026929999999936 86.3562239999999974 86.2279589999999985 86.2240139999999968 86.4482650000000064 86.433525000000003 86.3027040000000056 86.3990170000000006 86.4860460000000018 86.4331360000000046 86.3755340000000018 86.3302079999999989 86.3531270000000006 86.4212950000000006 86.435364000000007 86.4471439999999944 86.5660170000000022 86.6639710000000036 86.464256000000006 86.3412399999999991 86.3786769999999962 86.315764999999999 86.234893999999997 86.1961440000000039 86.2335130000000021 86.2283249999999981 86.2254259999999988 86.2316280000000006 86.2990039999999965 86.5144580000000047 86.5055540000000036 86.3840260000000058 86.4709849999999989 86.5518880000000053 86.3254620000000017 86.2704159999999973 86.3807749999999999 86.3028029999999973 86.2480319999999949 86.3215409999999963 86.3409879999999958 86.2999420000000015 86.4951169999999934 86.442939999999993 86.3159940000000034 86.282623000000001 86.2963490000000064 86.2999109999999
945 86.2672270000000054 86.2796709999999933 86.3043590000000052 86.2519149999999968 86.1923979999999972 86.2747650000000021 86.3841400000000021 86.5418619999999947 86.7372210000000052 86.9312819999999959 87.1990430000000032 87.4713899999999995 87.6807019999999966 87.9141999999999939 88.0975269999999995 88.1335140000000052 88.1418840000000046 88.271324000000007 88.285728000000006 88.2686539999999979 88.3321300000000065 88.5273899999999969 88.8098750000000052 88.8688810000000018 88.5934220000000039 88.0568770000000001 87.4680180000000007 87.1721270000000032 87.369101999999998 87.2532350000000037 87.2676320000000061 87.3708500000000043 87.5792540000000059 87.782866999999996 88.0183559999999972 88.3473890000000068 88.8202670000000012 89.3424530000000061 90.1939699999999931 91.4030079999999998 92.7249070000000017 94.0226899999999972 95.1514970000000062 96.0950619999999986 96.5142290000000003 96.6443859999999972 96.7893140000000045 97.1320500000000067 97.5720749999999981 97.937340
0000000061 98.2999190000000027 99.0102080000000058 99.8576510000000042 100.3852689999999939 100.8463820000000055 101.4387820000000033 101.8878169999999983 102.0533369999999991 102.0475390000000004 101.9686739999999929 101.9919359999999955 102.1456989999999934 102.3451459999999997 102.320526000000001 102.5551829999999995 103.1767650000000032 103.5996250000000032 103.7229310000000027 103.5648730000000057 103.090485000000001 102.5094150000000042 101.5684739999999948 100.5163189999999958 99.4165270000000021 98.1720660000000009 96.9907680000000028 95.8430249999999972 94.7760310000000032 93.5067290000000071 92.0053939999999955 91.0287320000000051 90.4387739999999951 90.3097920000000016 90.9569850000000031 91.8985749999999939 92.7397380000000027 93.5214540000000056 94.3566359999999946 95.1138839999999988 95.7444150000000036 96.6971970000000027 97.7446439999999939 98.7680890000000034 99.7561189999999982 100.6536409999999933 101.3767169999999993 101.7664869999999979 102.0613859999999
988 102.7817759999999936 103.4886549999999943 104.128532000000007 104.7927169999999961 105.3414460000000048 105.6241990000000044 105.7832949999999954 106.1912990000000008 106.6947169999999971 107.1285170000000022 107.6978679999999997 108.3827969999999965 108.839020000000005 109.1945189999999997 109.7397310000000061 110.1402590000000004 110.4159010000000052 110.6856379999999973 110.8937839999999966 111.0359270000000009 111.220673000000005 111.5013890000000032 111.7710110000000014 112.2247540000000043 112.4791950000000043 112.0917510000000021 111.776732999999993 111.4788439999999952 110.9091339999999946 110.0204619999999949 109.0352630000000005 107.9077149999999961 106.4605329999999981 104.9697419999999966 103.9677049999999952 103.078368999999995 101.7658310000000057 101.4107889999999941 101.9279400000000066 102.5228579999999994 103.4183879999999931 104.8550639999999987 106.2052079999999989 107.4066470000000066 108.8348849999999999 110.2418519999999944 111.5349120000000056 112
.5810620000000029 112.8199230000000028 112.549744000000004 112.0948939999999965 111.327415000000002 110.2015229999999946 108.9596559999999954 107.7964099999999945 106.7587199999999967 105.3162990000000008 103.229179000000002 102.4927059999999983 101.9631200000000035 101.1824260000000066 102.4233020000000067 103.8716660000000047 104.5271070000000009 105.4533919999999938 106.2836690000000033 106.3680729999999954 106.8848569999999967 107.315369000000004 107.5318829999999934 107.7378769999999975 107.9952090000000027 107.5667190000000062 106.477485999999999
+86.5975040000000007 86.7105260000000015 86.550933999999998 86.3440480000000008 86.311561999999995 86.2373659999999944 86.4019849999999963 86.3739929999999987 86.3868559999999945 86.4508969999999977 86.4410929999999951 86.4196850000000012 86.3807529999999986 86.3333970000000051 86.3190380000000062 86.338829000000004 86.4174579999999963 86.446990999999997 86.5115129999999937 86.5915219999999977 86.504294999999999 86.3862230000000011 86.3853909999999985 86.4130399999999952 86.4175029999999964 86.2716450000000066 86.2045289999999937 86.2295459999999991 86.2286220000000014 86.2253570000000025 86.238624999999999 86.3522109999999969 86.4594419999999957 86.4119950000000046 86.4166560000000032 86.6011120000000005 86.4638439999999946 86.2497330000000062 86.3822559999999982 86.315796000000006 86.226624000000001 86.3332900000000052 86.3858800000000002 86.38279 86.5132830000000013 86.4507679999999965 86.3530810000000031 86.4439699999999931 86.4110029999999938 86.2847440000000034 86.24630
70000000016 86.2354430000000036 86.241028 86.2306980000000038 86.2112350000000021 86.2518539999999945 86.3092579999999998 86.4641040000000061 86.6512220000000042 86.8144450000000063 87.0367889999999989 87.3377610000000004 87.5186159999999944 87.5884779999999949 87.7115019999999959 87.9258959999999945 87.9057690000000065 88.0073170000000005 88.1530379999999951 88.1475980000000021 88.1402439999999956 88.2693560000000019 88.5338289999999972 88.5997310000000056 88.2558140000000009 87.6883930000000049 87.2723849999999999 87.0756379999999979 87.1094439999999963 87.0635149999999953 87.175926000000004 87.1959149999999994 87.416435000000007 87.6611099999999936 87.8556750000000051 88.2097239999999942 88.6712799999999959 89.4034269999999935 90.469703999999993 91.7795409999999947 93.2261890000000051 94.4689639999999997 95.519835999999998 96.3040850000000006 96.710907000000006 96.9980010000000021 97.1407169999999951 97.3026349999999951 97.5813830000000024 97.8541029999999949 98.176726999
9999996 98.7684399999999982 99.4456330000000008 100.0562740000000019 100.7685850000000016 101.3952259999999939 101.636298999999994 101.707451000000006 101.874565000000004 102.0452959999999933 101.9791110000000032 101.9946209999999951 101.9954989999999952 101.9225310000000064 102.3462300000000056 102.9082870000000014 103.2931059999999945 103.4291230000000041 103.1922840000000008 102.7464370000000002 102.2234499999999997 101.3612439999999992 100.2567370000000011 98.9848329999999947 97.592369000000005 96.2547840000000008 94.984131000000005 93.8029789999999934 92.5705410000000057 91.4124599999999958 90.7111050000000034 90.3543619999999947 90.5298159999999967 91.1364669999999961 91.9610749999999939 93.0423360000000059 93.9626010000000065 94.8533549999999934 95.8693770000000001 96.3288730000000015 97.1334839999999957 98.5718770000000006 99.667625000000001 100.5257720000000035 101.3943100000000044 102.1931299999999965 102.6853179999999952 103.0505979999999937 103.7997819999999933 1
04.6535719999999969 105.3081279999999964 105.7644810000000035 105.9800110000000046 106.0257639999999952 106.2404939999999982 106.5477910000000037 106.9043120000000044 107.4223400000000055 108.0646210000000025 108.5129239999999982 108.9906540000000064 109.3957439999999934 109.7326130000000006 110.0797649999999948 110.3714899999999943 110.4615710000000064 110.6199419999999947 110.8222659999999991 110.9961930000000052 111.261841000000004 111.5307770000000005 111.9684369999999944 112.3174060000000054 111.9741209999999967 111.6990969999999948 111.4070049999999981 110.7958529999999939 110.106071 109.2903440000000046 108.3255390000000062 106.9514470000000017 105.5751340000000056 104.6747060000000005 103.5474849999999947 101.5898669999999981 100.9357909999999947 101.7586749999999967 102.5186389999999932 103.3644330000000053 104.9018630000000059 106.4325099999999935 107.7511369999999999 109.1395339999999976 110.513221999999999 111.705994000000004 112.5835340000000002 112.603072999999
9949 112.2221069999999941 111.7833020000000062 110.9159999999999968 109.6824340000000007 108.5387649999999979 107.5151209999999935 106.2550580000000053 104.2360989999999958 101.8935469999999981 101.1547620000000052 100.9833830000000034 100.9207229999999953 102.123115999999996 103.371887000000001 103.9717409999999944 104.6224210000000028 105.9407269999999954 106.3522569999999945 106.308959999999999 106.6071089999999941 106.9052120000000059 107.3016659999999973 107.3553919999999948 106.5315400000000068 106.3614649999999955
+86.6722409999999996 86.637352000000007 86.348267000000007 86.2638929999999959 86.4276200000000046 86.3374629999999996 86.3256449999999944 86.3096850000000018 86.3900529999999947 86.4384989999999931 86.4010700000000043 86.3787920000000042 86.3387910000000005 86.3226319999999987 86.319121999999993 86.3267589999999956 86.4282610000000062 86.468047999999996 86.4608989999999977 86.4697649999999953 86.3759079999999955 86.3295669999999973 86.391998000000001 86.456908999999996 86.6178740000000005 86.4868160000000046 86.2560500000000019 86.2277600000000035 86.2329409999999967 86.2434769999999986 86.2346339999999998 86.2366099999999989 86.2809599999999932 86.2865680000000026 86.3642430000000019 86.5801539999999932 86.4698029999999989 86.2627030000000019 86.4359970000000004 86.3208159999999936 86.208556999999999 86.3193590000000057 86.4456409999999948 86.507874000000001 86.5833820000000003 86.5603940000000023 86.438713000000007 86.4483869999999968 86.3531799999999947 86.217338999999995
5 86.2039340000000038 86.2020799999999952 86.2016140000000064 86.195250999999999 86.2390290000000022 86.3280560000000037 86.2874759999999981 86.3795319999999975 86.5659480000000059 86.7382580000000019 86.9782560000000018 87.2548599999999936 87.3907549999999986 87.3661579999999987 87.3694919999999939 87.5825959999999952 87.6281510000000026 87.7167210000000068 87.8437040000000025 87.8524630000000002 87.8874660000000034 88.0330430000000064 88.2844309999999979 88.3009639999999933 88.0136490000000009 87.514686999999995 87.1415180000000049 86.852997000000002 86.7068100000000044 86.9142460000000057 87.0711289999999991 87.1404040000000037 87.2432100000000048 87.536713000000006 87.7560119999999984 88.0746309999999966 88.6610340000000008 89.5593410000000034 90.705260999999993 92.0942840000000018 93.5230710000000016 94.8699189999999959 95.9134219999999971 96.3834229999999934 96.6968540000000019 97.0708999999999946 97.397712999999996 97.5222550000000012 97.6089249999999993 97.7684560000
000005 98.0520779999999945 98.542145000000005 99.1224590000000063 99.6624599999999958 100.3118819999999971 100.9910739999999976 101.4054110000000009 101.5553969999999993 101.7383190000000042 101.992644999999996 101.9179919999999981 101.8006440000000055 101.5805509999999998 101.6498490000000032 102.1677320000000009 102.6224289999999968 102.9457400000000007 103.0923310000000015 102.8544459999999958 102.4438930000000028 101.9333419999999961 101.083991999999995 99.9160770000000014 98.5004959999999983 97.077147999999994 95.7101059999999961 94.3214260000000024 92.8248140000000035 91.5004579999999947 90.8116459999999961 90.3765109999999936 90.2724460000000022 90.6772689999999955 91.3852540000000033 92.234131000000005 93.2701870000000071 94.126648000000003 95.166167999999999 96.6547470000000004 97.1329570000000047 97.3535920000000061 98.6090549999999979 100.0192109999999985 100.9791560000000032 101.8043140000000051 102.5921550000000053 103.2920909999999992 103.8367999999999967 104.5
978620000000063 105.3916930000000036 105.8604660000000024 106.1806339999999977 106.3719179999999938 106.5811000000000064 106.8062589999999972 106.9798360000000059 107.3223650000000049 107.8864669999999961 108.3050769999999972 108.6656949999999995 109.1261669999999953 109.366219000000001 109.5834270000000004 109.929466000000005 110.1170350000000013 110.1487580000000008 110.3273930000000007 110.5760499999999951 110.7735980000000069 111.0458150000000046 111.3382799999999975 111.7390290000000022 112.1010359999999935 111.884949000000006 111.6227650000000011 111.2287450000000035 110.6172940000000011 110.017241999999996 109.3194730000000021 108.3576970000000017 107.093474999999998 106.0249479999999949 105.1964949999999988 104.0276719999999955 102.0957489999999979 100.8057790000000011 101.3254390000000029 102.0851059999999961 103.0227200000000067 104.7160640000000029 106.5611339999999956 108.0798110000000065 109.3654329999999959 110.6400220000000019 111.7768860000000046 112.35025799
99999966 112.2425839999999937 111.8605500000000035 111.2851330000000019 110.3814540000000051 109.2371519999999947 108.0947189999999978 106.9914320000000032 105.2111660000000057 102.3578109999999981 100.4282149999999945 100.2945019999999943 100.6491469999999993 100.9756930000000068 101.7078249999999997 102.5574799999999982 103.0479969999999952 103.596862999999999 105.2266309999999976 106.4338230000000038 105.942939999999993 105.8456189999999992 106.1959760000000017 106.5483020000000067 106.2253879999999953 105.7821200000000061 107.0062559999999934
+86.6753309999999999 86.5250699999999995 86.3675309999999996 86.3804779999999965 86.5293499999999938 86.4982449999999972 86.4453510000000023 86.3873059999999953 86.3264850000000052 86.3574679999999972 86.3735729999999933 86.3462370000000021 86.3208079999999995 86.319823999999997 86.3202670000000012 86.3216630000000009 86.4114840000000015 86.5632399999999933 86.5697710000000029 86.4590149999999937 86.3802950000000038 86.3559190000000001 86.325721999999999 86.446037000000004 86.6393810000000002 86.5640719999999959 86.2740940000000052 86.2032549999999986 86.2287979999999976 86.2527309999999972 86.231071 86.218757999999994 86.2278979999999962 86.2066120000000069 86.2469710000000021 86.4299620000000033 86.4949869999999947 86.320106999999993 86.4721600000000024 86.3651729999999986 86.2157899999999984 86.2791289999999975 86.3622060000000005 86.4688569999999999 86.5372389999999996 86.5626450000000034 86.5571060000000045 86.4481509999999957 86.2613070000000022 86.1968920000000054 86.1
972499999999968 86.1975779999999929 86.1975170000000048 86.1935500000000019 86.2120510000000024 86.3092500000000058 86.2811889999999977 86.3175200000000018 86.5002980000000008 86.6582570000000061 86.9070590000000038 87.1354220000000055 87.2128979999999956 87.189903000000001 87.1548920000000038 87.2120670000000047 87.276329000000004 87.384490999999997 87.4605260000000015 87.4647140000000007 87.6086580000000055 87.7998889999999932 87.9422150000000045 87.9642180000000025 87.7604520000000008 87.3531720000000007 86.923096000000001 86.6421969999999959 86.6622919999999937 86.843040000000002 86.8886640000000057 87.0423660000000012 87.191047999999995 87.5409700000000015 87.8050989999999985 88.1002730000000014 88.82029 89.7983629999999948 91.031761000000003 92.4312900000000042 93.6860279999999932 94.9955669999999941 95.989799000000005 96.4283219999999943 96.705726999999996 97.0369110000000035 97.3761829999999975 97.5146940000000058 97.6435010000000005 97.7636870000000044 97.9577029999
999951 98.3592909999999989 98.9394070000000028 99.4612809999999996 100.0927120000000059 100.846076999999994 101.3273159999999962 101.5164110000000051 101.6585919999999987 101.6468430000000041 101.6646039999999971 101.4783860000000004 101.1299439999999947 101.342560000000006 101.8172449999999998 102.2715450000000033 102.5265119999999968 102.6144330000000053 102.3814009999999968 102.024437000000006 101.5295559999999995 100.6397709999999961 99.3995359999999977 97.9031520000000057 96.4447020000000066 95.029792999999998 93.5217970000000065 91.7504880000000043 90.5113979999999998 90.2517930000000064 90.1846010000000007 90.357048000000006 90.7960429999999974 91.5212939999999975 92.5554049999999933 93.3689729999999969 94.0321660000000037 95.3023450000000025 96.8683089999999964 97.5570909999999998 97.8220519999999993 98.453552000000002 99.8211900000000014 101.0550690000000031 101.9200129999999973 102.8295439999999985 103.641052000000002 104.3108220000000017 105.2045899999999961 105.8
501129999999932 106.1301500000000004 106.5186460000000039 106.8428420000000045 106.9930190000000039 107.1550979999999953 107.4279559999999947 107.8066249999999968 108.093506000000005 108.3770980000000037 108.8168950000000024 109.0434719999999942 109.1588670000000008 109.3931050000000056 109.6117480000000057 109.691986 109.7781599999999997 109.9684680000000014 110.2215190000000007 110.4598309999999941 110.8343809999999934 111.152434999999997 111.4909360000000049 111.8790439999999933 111.7188340000000011 111.4835659999999962 111.0876769999999993 110.5176770000000062 109.9099499999999949 109.1616520000000037 108.2281569999999959 107.1435170000000028 106.2493520000000018 105.3311000000000064 104.0591280000000012 102.2603450000000009 100.6221079999999972 100.6507260000000059 101.3556370000000015 102.4756930000000068 104.3825530000000015 106.5145109999999988 108.1875229999999988 109.4416429999999991 110.6038439999999952 111.6340330000000023 111.9890749999999997 111.770781999999997
111.3611369999999994 110.7095110000000062 109.7858279999999951 108.7811509999999942 107.5551150000000007 105.9553680000000071 103.7030259999999942 100.8144149999999968 99.7893600000000021 100.6357730000000004 101.309235000000001 101.538062999999994 101.8030779999999993 102.2016909999999967 102.8147739999999999 103.5476149999999933 104.5250089999999972 106.2162479999999931 106.1229479999999938 105.2451709999999991 105.321472 105.5069730000000021 105.3178249999999991 106.1891099999999994 108.306601999999998
+86.6946559999999948 86.5933909999999969 86.6184839999999951 86.629051000000004 86.649597 86.638298000000006 86.6224590000000063 86.474449000000007 86.2741549999999933 86.3363109999999949 86.3696819999999974 86.3202440000000024 86.3193660000000023 86.3203809999999976 86.3203960000000023 86.3160550000000057 86.3514789999999977 86.5190350000000024 86.6196670000000069 86.481812000000005 86.4746319999999997 86.4517900000000026 86.3442150000000055 86.4695210000000003 86.6024319999999932 86.5237429999999961 86.2768709999999999 86.2337420000000066 86.2219470000000001 86.2169800000000066 86.2064359999999965 86.1791759999999982 86.2163160000000062 86.2088619999999963 86.1849289999999968 86.3621830000000017 86.6475910000000056 86.427063000000004 86.3760529999999989 86.459068000000002 86.3065030000000064 86.2459340000000054 86.2440110000000004 86.413848999999999 86.5229570000000052 86.5590289999999953 86.6306529999999952 86.5031199999999956 86.2401349999999951 86.1973650000000049 86.198
4020000000015 86.1984939999999966 86.1985020000000048 86.1981119999999947 86.1991270000000043 86.2110440000000011 86.2596360000000004 86.3304980000000057 86.4744639999999976 86.6094209999999975 86.7559200000000033 86.9084009999999978 86.8813549999999992 86.8959810000000061 86.968238999999997 86.9307019999999966 86.9823379999999986 87.1274870000000021 87.2148439999999994 87.2558520000000044 87.3308329999999984 87.5264360000000039 87.6321030000000007 87.6401209999999935 87.469971000000001 87.0609209999999933 86.8168639999999954 86.6289369999999934 86.6119539999999972 86.7728120000000018 86.7685170000000028 86.9223790000000065 87.256812999999994 87.5812679999999943 87.7859190000000069 88.1364290000000068 88.9622420000000034 90.0714949999999988 91.3096769999999935 92.5357970000000023 93.7599330000000037 94.8960720000000038 95.589966000000004 96.1051479999999998 96.5119629999999944 96.8037489999999963 96.9590299999999985 97.0379099999999966 97.278137000000001 97.5424730000000011
97.9080280000000016 98.4253769999999975 99.1201779999999957 99.7863159999999993 100.431601999999998 101.0147709999999961 101.4219740000000058 101.6101840000000038 101.6335980000000063 101.4647290000000055 101.2771149999999949 100.9052049999999952 100.7055440000000033 100.9686049999999966 101.3524630000000002 101.834937999999994 102.1127319999999941 102.1337889999999931 101.839698999999996 101.436790000000002 100.929481999999993 100.0618060000000042 98.7735289999999964 97.1880040000000065 95.6601940000000042 94.1272660000000059 92.494300999999993 90.9170680000000004 90.1317439999999976 90.1321949999999958 90.1692500000000052 90.4692000000000007 91.0485989999999958 91.8611910000000051 93.1275100000000009 93.9176479999999998 94.219261000000003 95.1335140000000052 96.4571689999999933 97.3007580000000019 97.962883000000005 98.5792919999999953 99.5855870000000039 100.8016740000000055 101.8977359999999948 102.9979399999999998 103.8638150000000024 104.5738599999999963 105.6116180000
000071 106.2723160000000036 106.5665439999999933 106.9908980000000014 107.2658459999999963 107.2693409999999972 107.2943879999999979 107.5843430000000041 107.9172669999999954 108.1728360000000038 108.4334719999999948 108.7051160000000039 108.839775000000003 108.8965149999999937 109.0013200000000069 109.1695789999999988 109.298491999999996 109.4471889999999945 109.6313549999999992 109.8670500000000061 110.1112899999999968 110.5105819999999994 110.920685000000006 111.2831269999999932 111.689391999999998 111.572417999999999 111.3552470000000056 111.0112000000000023 110.4301150000000007 109.8024900000000059 109.0238190000000031 108.1310880000000054 107.1890259999999984 106.459075999999996 105.5247650000000021 104.2270970000000005 102.4685290000000037 100.6201480000000004 100.0161209999999983 100.5472720000000066 101.8412859999999966 103.9545140000000032 106.218718999999993 107.9056700000000006 109.1859589999999969 110.3908839999999998 111.3503189999999989 111.5110629999999929 11
1.0638579999999962 110.597999999999999 110.0236280000000022 109.1719279999999941 108.155304000000001 106.9371189999999956 104.833800999999994 102.1445310000000006 99.9022219999999948 99.8319780000000065 101.110328999999993 101.7924880000000059 102.3989640000000065 102.9712520000000069 103.3172529999999938 104.3993150000000014 105.3971789999999942 105.4805980000000005 106.4179989999999947 106.699821 105.271324000000007 104.9649200000000064 105.1934969999999936 105.5360869999999949 107.3107909999999947 109.4404069999999933
+86.7682039999999972 86.8090899999999976 86.837372000000002 86.8154449999999969 86.7920459999999991 86.7055129999999963 86.6541440000000023 86.4955980000000011 86.3757930000000016 86.4098890000000068 86.3585280000000068 86.3035959999999989 86.3119659999999982 86.3201750000000061 86.3204190000000011 86.3190539999999942 86.3158260000000013 86.376221000000001 86.4993520000000018 86.4993670000000066 86.4945299999999975 86.4874729999999943 86.4730529999999931 86.5076980000000049 86.5207670000000064 86.471855000000005 86.4320220000000035 86.4039760000000001 86.3619609999999938 86.2871020000000044 86.2060699999999969 86.1724090000000018 86.2340769999999992 86.227294999999998 86.1760940000000062 86.3746869999999944 86.6493300000000062 86.4616929999999968 86.2681809999999984 86.5235519999999951 86.5602109999999954 86.3752589999999998 86.2502819999999986 86.3270420000000058 86.4752960000000002 86.527717999999993 86.5090940000000046 86.4658969999999982 86.2730480000000028 86.16116300000
00019 86.1972499999999968 86.1988369999999975 86.1984939999999966 86.1986160000000012 86.1984410000000025 86.1930310000000048 86.2877119999999991 86.3993150000000014 86.4534150000000068 86.5191800000000057 86.5901949999999943 86.6905139999999932 86.6321640000000031 86.6467289999999934 86.7172699999999992 86.6567229999999995 86.7259980000000041 86.936829000000003 87.054633999999993 87.1187740000000019 87.055854999999994 87.1079029999999932 87.3001940000000047 87.3573300000000046 87.1650089999999977 86.8401410000000027 86.9042429999999939 86.607208 86.3663939999999997 86.6501540000000006 86.7591550000000069 86.9648669999999981 87.4177860000000067 87.6010279999999995 87.675147999999993 88.1360320000000002 88.9619670000000013 90.2487950000000012 91.6081089999999989 92.5577159999999992 93.6225589999999954 94.5645289999999932 95.101592999999994 95.5184249999999935 95.890656000000007 96.173530999999997 96.2762149999999934 96.3607640000000032 96.5594860000000068 96.9663089999999954
97.6018909999999948 98.3754880000000043 99.2831879999999956 100.0648800000000023 100.7129750000000001 101.2038119999999992 101.5291440000000023 101.7120589999999964 101.5557170000000013 101.3994830000000036 100.8265459999999933 100.2485279999999932 100.3087309999999945 100.5492399999999975 100.870757999999995 101.3356930000000062 101.6112519999999932 101.5545879999999954 101.2160420000000016 100.7144930000000045 100.1959760000000017 99.3835600000000028 98.0610279999999932 96.4489290000000068 94.8959499999999991 93.3200530000000015 91.7013170000000031 90.528931 90.2556919999999963 90.2055660000000046 90.1601940000000042 90.6256479999999982 91.4306789999999978 92.6308360000000022 94.1471099999999979 95.0654449999999969 95.1796800000000047 95.4341129999999964 96.4591829999999959 97.1896129999999943 97.8329159999999973 98.753296000000006 99.706389999999999 100.6943210000000022 101.851592999999994 103.0118870000000015 103.9661640000000062 104.7915650000000056 105.8534389999999945
106.5599979999999931 106.8607329999999962 107.1727910000000037 107.3149339999999938 107.3573070000000058 107.466583 107.6779250000000019 107.9665449999999964 108.2214280000000031 108.3647840000000002 108.4570389999999946 108.4560170000000028 108.457451000000006 108.5692059999999941 108.7714840000000009 108.9959180000000032 109.1605220000000003 109.3401570000000049 109.5738220000000069 109.852478000000005 110.2247540000000043 110.6711959999999948 111.118858000000003 111.5264430000000004 111.4441379999999953 111.1398089999999996 110.7494130000000041 110.2216339999999946 109.648658999999995 108.9408949999999976 108.0998459999999994 107.1914600000000064 106.4816739999999982 105.6365049999999997 104.4378200000000021 102.6360169999999954 100.6998669999999976 99.7261579999999981 99.9544530000000009 101.3140029999999996 103.4348140000000029 105.6145549999999957 107.2661899999999946 108.5891419999999954 109.8955310000000054 110.740241999999995 110.6923830000000066 110.19241300000000
19 109.7512439999999998 109.2095949999999931 108.3601759999999956 107.2362289999999945 106.1577529999999996 104.0549390000000045 101.0329820000000041 99.3278959999999955 100.1403959999999955 101.5165860000000038 102.4575119999999941 103.6283339999999953 104.9013819999999981 105.8602520000000027 107.0200880000000012 107.8505549999999999 108.0867159999999956 107.8206250000000068 107.4012220000000042 106.2373730000000052 105.5479050000000001 105.8592529999999954 106.6938860000000062 108.3551559999999938 109.9778670000000034
+87.1070100000000025 86.9255069999999961 87.0053939999999955 87.0114750000000043 86.9946060000000045 86.8283919999999938 86.5597530000000006 86.4741439999999955 86.5544510000000002 86.4633790000000033 86.3699490000000054 86.3959579999999931 86.3458940000000013 86.3215869999999938 86.3204570000000047 86.3225560000000058 86.3215639999999951 86.2921070000000014 86.3038860000000057 86.3712230000000005 86.3920970000000068 86.4478529999999949 86.5334320000000048 86.463286999999994 86.372596999999999 86.3712230000000005 86.4502410000000054 86.5024870000000021 86.5013050000000021 86.3673249999999939 86.208588000000006 86.2158280000000019 86.2557599999999951 86.283173000000005 86.2830280000000016 86.3835749999999933 86.5173029999999983 86.522246999999993 86.2973709999999983 86.3571400000000011 86.6649929999999955 86.6136089999999967 86.407439999999994 86.2716980000000007 86.3345719999999943 86.3869629999999944 86.2991710000000012 86.3838039999999978 86.4423519999999996 86.313605999999
9929 86.1869200000000006 86.1952210000000036 86.1991880000000066 86.1984939999999966 86.1984559999999931 86.1988070000000022 86.3001100000000037 86.4709469999999953 86.4789659999999998 86.3575440000000043 86.4407879999999977 86.5954590000000053 86.5696259999999995 86.5554889999999943 86.5545960000000036 86.5551530000000042 86.6012570000000039 86.718757999999994 86.8568269999999956 86.9303510000000017 86.9106599999999929 86.8452680000000043 86.8825760000000002 86.9976580000000013 86.838310000000007 86.7158280000000019 86.7670590000000033 86.3665469999999971 86.1458509999999933 86.4776310000000024 86.6956629999999961 86.9078059999999937 87.3744509999999934 87.6991730000000018 87.8182529999999986 88.2528839999999946 88.9771960000000064 90.2503889999999984 91.6593929999999943 92.5361330000000066 93.1501619999999946 93.8187559999999934 94.427338000000006 94.8057629999999989 95.0899959999999993 95.3243030000000005 95.3481900000000024 95.451469000000003 95.7953870000000052 96.31883
20000000004 97.033134000000004 97.9499820000000057 99.0583500000000043 99.9605559999999969 100.5498050000000063 101.1048200000000037 101.5323640000000012 101.655060000000006 101.454102000000006 101.1989360000000033 100.4356920000000031 99.7872310000000056 99.7922590000000014 100.037903 100.3898319999999984 100.7627640000000042 100.9914930000000055 100.8615879999999976 100.4880830000000032 99.9868620000000021 99.4816969999999969 98.6450880000000012 97.3492660000000001 95.8543010000000066 94.2641299999999944 92.6459660000000014 91.2008440000000036 90.3544619999999981 90.2399599999999964 90.1768110000000007 90.1774599999999964 90.6690669999999983 91.8443149999999946 93.5617450000000019 95.053009000000003 96.0801320000000061 96.580475000000007 96.8206330000000008 97.3694610000000011 97.6365810000000067 98.0125960000000021 98.9538569999999993 99.9636079999999936 100.9792860000000019 101.8824309999999969 102.9103240000000028 103.9769289999999984 104.9496379999999931 106.0045089999
999988 106.6406709999999975 106.971344000000002 107.2014539999999982 107.1807170000000013 107.2546389999999974 107.4967879999999951 107.8270569999999964 108.0728759999999937 108.1109699999999947 108.1071400000000011 108.0627369999999985 108.0041889999999967 108.0558240000000012 108.1854479999999938 108.3134079999999955 108.5506670000000042 108.794739000000007 109.0437239999999974 109.3268659999999954 109.6355669999999947 110.1104579999999942 110.5698699999999945 110.9392780000000016 111.3403169999999989 111.2396470000000051 110.7855529999999931 110.3789060000000006 109.9271240000000063 109.3713070000000016 108.7185589999999991 107.958556999999999 107.0560229999999962 106.2747729999999962 105.495948999999996 104.4605179999999933 102.6523439999999994 100.7059560000000005 99.594268999999997 99.524437000000006 100.8571850000000012 102.8709029999999984 104.8323900000000037 106.485352000000006 107.9346919999999983 109.2047649999999948 109.7994920000000008 109.5858000000000061 109.
1638870000000026 108.856102000000007 108.2857889999999941 107.2976529999999968 106.0681229999999999 104.875945999999999 103.0370860000000022 100.3126299999999986 99.054665 100.5698469999999958 102.1973799999999954 103.5185010000000005 104.9707949999999954 106.4098280000000045 107.8932570000000055 108.8386459999999971 109.4782260000000065 110.1512299999999982 109.7079319999999996 108.398407000000006 107.5120390000000015 106.6407090000000011 106.517241999999996 107.4913480000000021 108.9322509999999937 110.3378680000000003
+88.3786010000000033 87.6066129999999958 87.2269969999999972 87.2634050000000059 87.2386929999999978 87.0251920000000041 86.597290000000001 86.5187990000000013 86.5814969999999988 86.4403149999999982 86.4195789999999988 86.4619979999999941 86.3733979999999946 86.3226470000000035 86.3212970000000013 86.3183290000000056 86.3059460000000058 86.2566910000000036 86.2220760000000013 86.2408980000000014 86.2518460000000005 86.3457949999999954 86.575774999999993 86.487244000000004 86.2862400000000065 86.2844999999999942 86.3312530000000038 86.4281009999999981 86.4761510000000015 86.4059830000000062 86.2730329999999981 86.231078999999994 86.2302470000000056 86.3033219999999943 86.4362560000000002 86.4000929999999983 86.4071119999999979 86.617133999999993 86.5089870000000047 86.2270050000000055 86.3914639999999991 86.5390239999999977 86.5126719999999949 86.3757399999999933 86.3607099999999974 86.4453579999999988 86.3716579999999965 86.3135070000000013 86.447226999999998 86.486687000000
0034 86.300139999999999 86.1919400000000024 86.1977920000000069 86.1984250000000003 86.1984939999999966 86.1984020000000015 86.2477339999999941 86.4072110000000038 86.4876629999999977 86.3433069999999958 86.3030700000000053 86.4352650000000011 86.4584349999999944 86.4488070000000022 86.4752199999999931 86.5422439999999966 86.5685349999999971 86.5652539999999959 86.6875760000000071 86.7592999999999961 86.8162540000000007 86.792381000000006 86.6499790000000019 86.6743160000000046 86.5512389999999954 86.5559460000000058 86.4738389999999981 86.1881560000000064 86.1681289999999933 86.4120180000000033 86.5747910000000047 86.7425460000000044 87.2235720000000043 87.7540819999999968 87.9739000000000004 88.2156829999999985 88.9337770000000063 90.1491850000000028 91.2927470000000056 92.1662520000000001 92.6198499999999996 93.0059049999999985 93.5623020000000025 93.9851299999999981 94.210915 94.2846069999999941 94.1875610000000023 94.3339459999999974 94.8952409999999986 95.5818330000000
032 96.4003450000000015 97.3589020000000005 98.6385499999999951 99.7863239999999934 100.3616030000000023 100.8193049999999999 101.3701930000000004 101.5372540000000043 101.3529050000000069 101.000427000000002 100.2207109999999943 99.4702300000000008 99.2815169999999938 99.483704000000003 99.8670500000000061 100.1841129999999964 100.3776929999999936 100.1828309999999931 99.6525500000000051 99.140349999999998 98.641602000000006 97.8194270000000046 96.6129459999999938 95.247673000000006 93.6132740000000041 91.8637159999999966 90.7027889999999957 90.2623439999999988 90.2010190000000023 90.161925999999994 90.1519470000000069 90.6076740000000029 92.2111129999999974 94.3389209999999991 95.667381000000006 96.6932829999999939 97.6013109999999955 98.0163649999999933 98.2200320000000033 98.3746569999999991 98.6684649999999976 99.3459629999999976 100.4002909999999957 101.5260009999999937 102.2551500000000004 103.005898000000002 103.9984280000000041 104.9867859999999951 106.1271969999999
953 106.8586810000000042 107.0197979999999944 106.9686659999999989 107.0102080000000058 107.3514019999999931 107.697936999999996 107.9466630000000009 107.9975890000000049 107.8169249999999977 107.6347049999999967 107.6339040000000011 107.6791149999999959 107.6465380000000067 107.6194919999999939 107.6784360000000049 108.0171509999999984 108.4184419999999989 108.697174000000004 109.113617000000005 109.5131229999999931 110.0201720000000023 110.5318599999999947 110.8574980000000068 111.1445159999999959 111.0706100000000021 110.5642780000000016 110.0789869999999979 109.5704800000000034 109.0127410000000054 108.3663410000000056 107.6592100000000016 106.8977890000000031 106.1608200000000011 105.3249359999999939 104.2811430000000001 102.5715409999999963 100.6103360000000038 99.2964779999999934 99.1124339999999933 100.3889920000000018 102.2906490000000019 104.0931850000000054 105.7389830000000046 107.2489170000000058 108.2945179999999965 108.6726000000000028 108.4178770000000043 107
.9652329999999978 107.6566619999999972 107.076469000000003 106.049201999999994 104.7583850000000041 103.2678070000000048 101.5306089999999983 99.6073379999999986 99.153137000000001 100.881134000000003 102.7229389999999967 104.2689969999999988 105.7286150000000049 107.1571579999999955 108.5689540000000051 109.5117869999999982 110.2832640000000026 111.0269930000000045 111.1352920000000069 109.5326079999999962 108.2850569999999948 107.7064589999999953 107.0073699999999945 107.6033780000000064 109.0281679999999938 110.4725880000000018
+89.9338379999999944 89.0306929999999994 87.6916499999999957 87.5166779999999989 87.4222259999999949 87.2187040000000025 86.8340069999999997 86.6243359999999996 86.4930109999999956 86.338745000000003 86.3919450000000069 86.411438000000004 86.3300399999999968 86.3184969999999936 86.3175659999999993 86.2978899999999953 86.2707439999999934 86.249992000000006 86.2286450000000002 86.2216949999999969 86.2118760000000037 86.2645720000000011 86.4685439999999943 86.4762949999999933 86.3918299999999988 86.3630519999999962 86.3207239999999985 86.3288799999999981 86.4129489999999976 86.4830469999999991 86.3329319999999996 86.2005920000000003 86.2168730000000068 86.2483979999999946 86.4097749999999962 86.4203720000000004 86.3345259999999968 86.4769359999999949 86.603424000000004 86.4391020000000054 86.3440020000000032 86.307311999999996 86.3517230000000069 86.3451539999999937 86.3491060000000061 86.467772999999994 86.5026550000000043 86.3898769999999985 86.3332369999999969 86.381911999999
9998 86.4325099999999935 86.2638929999999959 86.1807400000000001 86.1988139999999987 86.1984939999999966 86.1984860000000026 86.2022249999999985 86.254761000000002 86.3444899999999933 86.3417210000000068 86.2910540000000026 86.2268300000000067 86.2099149999999952 86.2661970000000053 86.3241419999999948 86.4358059999999995 86.4986719999999991 86.5089870000000047 86.6132280000000065 86.7150879999999944 86.7415390000000031 86.7073970000000003 86.6204070000000002 86.5097350000000063 86.3825609999999955 86.3363269999999972 86.4262619999999941 86.3398899999999969 86.3459320000000048 86.4712600000000009 86.513023000000004 86.6072850000000045 87.029876999999999 87.5579759999999965 87.851532000000006 88.0820769999999982 88.9019700000000057 89.948875000000001 90.8256679999999932 91.6424710000000005 92.060181 92.3094020000000057 92.7765050000000002 93.1399380000000008 93.326508000000004 93.2908709999999957 93.1365200000000044 93.3297270000000054 93.9707719999999966 94.6654429999999962
95.5820769999999982 96.6910019999999975 98.090217999999993 99.5040659999999946 100.2450410000000005 100.6516110000000026 101.1830520000000035 101.3955839999999995 101.2497330000000062 100.9415659999999946 100.202697999999998 99.1990890000000007 98.7796940000000063 98.9450300000000027 99.3853909999999985 99.7029569999999978 99.7449189999999959 99.415062000000006 98.8259960000000035 98.2102509999999995 97.5160060000000044 96.7363509999999991 95.7302169999999961 94.4054490000000044 92.7352980000000002 91.0260470000000055 90.3220670000000041 90.2225040000000007 90.1702420000000018 90.1387179999999972 90.1698910000000069 90.8262179999999972 92.7236330000000066 95.0257419999999939 96.2352750000000015 97.2098540000000071 98.1055219999999935 98.5040740000000028 98.7655639999999977 99.0785139999999984 99.4982530000000054 100.1151430000000033 101.1093369999999965 102.1143569999999983 102.9314190000000053 103.5158080000000069 104.1442030000000045 105.1746059999999972 106.29853799999999
35 106.809203999999994 106.704582000000002 106.6569369999999992 106.9071270000000027 107.3706889999999987 107.6991419999999948 107.7250140000000016 107.6275100000000009 107.3747330000000062 107.2354739999999964 107.2404789999999934 107.1763990000000035 107.0457920000000058 106.9696349999999967 107.0869979999999941 107.5051799999999957 108.0338289999999972 108.3487319999999983 108.8480069999999955 109.4697570000000013 109.9663699999999977 110.4497300000000024 110.8100589999999954 110.9960329999999971 110.9196239999999989 110.4075239999999951 109.7872160000000008 109.1607130000000012 108.6361160000000012 107.9385450000000048 107.2753220000000027 106.7623899999999963 106.0732270000000028 105.1014399999999966 103.9789279999999962 102.4094089999999966 100.3753200000000021 98.9662550000000039 98.786445999999998 99.9538730000000015 101.6858600000000052 103.442504999999997 105.0930560000000042 106.4942020000000014 107.3015900000000045 107.4302140000000065 107.1170809999999989 106.80
03010000000046 106.3842769999999973 105.6250380000000035 104.4710239999999999 103.1067350000000005 101.6372829999999965 100.1039729999999963 98.8603590000000025 99.1526640000000015 100.9845200000000034 103.1235049999999944 104.8477859999999993 106.2035979999999995 107.5931549999999959 108.8734050000000053 109.9167329999999936 110.7198559999999929 111.521324000000007 112.0155330000000049 110.6668930000000017 108.8469010000000026 108.4265209999999939 107.8338849999999951 108.0418930000000017 109.1091919999999931 110.4640050000000002
+90.3618620000000021 89.714539000000002 88.2207339999999931 87.808441000000002 87.583564999999993 87.4191440000000028 87.0476380000000063 86.6727910000000037 86.398926000000003 86.3218990000000019 86.4590000000000032 86.4757919999999984 86.369995000000003 86.3265229999999946 86.3051300000000055 86.2863689999999934 86.2648470000000032 86.2473679999999945 86.2307739999999967 86.2289659999999998 86.2276690000000059 86.2337109999999996 86.2627719999999982 86.3117069999999984 86.443199000000007 86.5174870000000027 86.423798000000005 86.4017939999999953 86.4743500000000012 86.5051349999999957 86.3210909999999956 86.1819310000000058 86.2139130000000051 86.2200239999999951 86.2821119999999979 86.3961560000000048 86.3300930000000051 86.300926000000004 86.5224759999999975 86.5891720000000049 86.5308529999999934 86.3455349999999981 86.2743990000000025 86.317963000000006 86.3140340000000066 86.2745589999999964 86.3283389999999997 86.4586489999999941 86.455687999999995 86.3071290000000033
86.3547970000000049 86.2789149999999978 86.1746830000000017 86.1993939999999981 86.1985020000000048 86.1985020000000048 86.1958999999999946 86.1958620000000053 86.1967769999999973 86.2179639999999949 86.3048780000000022 86.190369000000004 86.1367110000000054 86.2458799999999997 86.217804000000001 86.3126139999999964 86.3878019999999935 86.4485860000000059 86.6288380000000018 86.7590330000000023 86.6493990000000025 86.5645899999999955 86.5832369999999969 86.4143600000000021 86.2886730000000028 86.1497420000000034 86.3273389999999949 86.4307330000000036 86.4269029999999958 86.5235519999999951 86.528923000000006 86.5125500000000045 86.7975540000000052 87.309203999999994 87.6613239999999934 88.0136719999999997 88.8552320000000009 89.7079700000000031 90.4795069999999981 91.2145309999999938 91.4543299999999988 91.6662599999999941 92.0532910000000015 92.1901699999999948 92.144165000000001 92.1291499999999957 92.1158599999999979 92.321235999999999 92.8738709999999941 93.54389999999
99936 94.6359410000000025 96.0167849999999987 97.4870449999999948 98.9770740000000018 99.9993740000000031 100.5860749999999939 101.0605699999999985 101.2024609999999996 101.1503979999999956 100.9263150000000024 100.1275329999999997 98.9032969999999949 98.1739350000000002 98.2638469999999984 98.8856889999999993 99.2263260000000002 99.0780409999999989 98.7062070000000062 98.111969000000002 97.3287119999999959 96.3841709999999949 95.5588529999999992 94.6665729999999996 93.287200999999996 91.5784230000000008 90.3751369999999952 90.1581269999999932 90.1737370000000027 90.1535719999999969 90.0870589999999964 90.3992230000000063 91.2875140000000016 93.2624279999999999 95.647437999999994 96.8416059999999987 97.6739809999999977 98.4295120000000026 98.9792790000000053 99.4615249999999946 99.8347090000000037 100.2759020000000021 101.0117570000000029 101.872840999999994 102.7063830000000024 103.5699769999999944 104.1828689999999966 104.5805660000000046 105.4449840000000052 106.227905000
0000069 106.3604809999999929 106.3676990000000018 106.5653920000000028 106.7684399999999982 106.9425959999999947 107.1596980000000059 107.224884000000003 107.1236569999999944 107.0099029999999942 106.8681409999999943 106.6474230000000034 106.473076000000006 106.4132079999999974 106.4599299999999999 106.6404799999999966 107.0153349999999932 107.5823209999999932 108.0964579999999984 108.6378169999999983 109.3633650000000017 109.9046709999999933 110.3559570000000036 110.7401349999999951 110.9328229999999991 110.8037340000000057 110.2583769999999959 109.5079649999999987 108.7336269999999985 108.118110999999999 107.380424000000005 106.8395160000000033 106.4646450000000044 105.8802639999999968 104.8964770000000044 103.694153 102.1665420000000069 100.0531620000000004 98.6921389999999974 98.6232380000000006 99.6647190000000052 101.1875610000000023 102.92971 104.5238039999999984 105.600639000000001 106.2165760000000034 106.1682050000000004 105.7702029999999951 105.5929569999999984 10
5.0043490000000048 104.1211550000000017 102.8466719999999981 101.3277360000000016 100.2004699999999957 98.9784389999999945 98.4214020000000005 99.5095369999999946 101.6872099999999932 103.8464199999999948 105.4682459999999935 106.7952499999999958 108.019408999999996 109.2455900000000071 110.3832550000000055 111.2218089999999933 112.0180589999999938 112.4934460000000058 111.6826020000000028 109.695801000000003 109.017273000000003 108.7642749999999978 108.7612529999999964 109.4152830000000023 110.6109540000000067
+90.1860120000000052 89.5705489999999998 88.3838269999999966 88.034514999999999 87.7997739999999993 87.5496370000000042 87.1173169999999999 86.6654819999999972 86.3195719999999937 86.3888550000000066 86.5936580000000049 86.5532460000000015 86.4395520000000062 86.3363800000000055 86.3041309999999982 86.2847210000000047 86.2585679999999968 86.2325819999999936 86.2290339999999986 86.2289659999999998 86.2294009999999957 86.2267070000000047 86.2090840000000043 86.2042309999999929 86.2851409999999959 86.4709780000000023 86.5565339999999992 86.621651 86.6401520000000005 86.5253979999999956 86.3512120000000039 86.2856450000000024 86.2511829999999975 86.2304079999999971 86.2264789999999977 86.2916950000000043 86.3383330000000058 86.350594000000001 86.4367139999999949 86.4105069999999955 86.4224009999999936 86.400574000000006 86.3954619999999949 86.4084849999999989 86.3075709999999958 86.2362059999999957 86.2403869999999984 86.3370740000000012 86.5557170000000013 86.5086670000000026 86
.3194660000000056 86.2266999999999939 86.1879959999999983 86.1968150000000009 86.1985779999999977 86.1984939999999966 86.1985779999999977 86.1979829999999936 86.1830829999999963 86.1811289999999985 86.2267300000000034 86.2221530000000058 86.2567290000000071 86.3527449999999988 86.2905200000000008 86.2988280000000003 86.3486560000000054 86.4237820000000028 86.6082150000000013 86.7078699999999998 86.5679020000000037 86.5138850000000019 86.5583570000000009 86.3770679999999942 86.2382130000000018 86.2081680000000006 86.276061999999996 86.3550419999999974 86.352019999999996 86.4322889999999973 86.4512480000000068 86.4475779999999929 86.7642589999999956 87.2082599999999957 87.5074460000000016 87.8409960000000041 88.5489960000000025 89.4350199999999944 90.2347029999999961 90.7999949999999956 90.9366909999999962 91.0597379999999958 91.2703779999999938 91.1721119999999985 90.8941190000000034 90.9215389999999957 91.1812520000000006 91.5010759999999976 91.9086609999999951 92.6225890000
000049 93.9187849999999997 95.4607620000000026 96.8558649999999943 98.2499849999999952 99.6747280000000018 100.582618999999994 100.9748079999999959 101.1115719999999953 101.1557159999999982 100.9342419999999976 100.2001110000000068 98.8337020000000024 97.5594020000000057 97.4774089999999944 98.2889859999999942 98.716423000000006 98.6251830000000069 98.3187410000000028 97.5522160000000014 96.4218520000000012 95.3859410000000025 94.5232539999999943 93.3269499999999965 91.6864549999999952 90.4837420000000066 90.1257779999999968 90.1509700000000009 90.1566389999999984 90.1284179999999964 90.3312229999999943 91.127837999999997 92.0450210000000055 93.7310099999999977 95.9630130000000037 97.250243999999995 98.0765229999999946 98.8297349999999994 99.5055470000000071 100.1896509999999978 100.7404099999999971 101.120002999999997 101.7834780000000023 102.6391140000000064 103.4385529999999989 104.2028880000000015 104.7719570000000004 105.1549679999999967 105.5737529999999964 105.8826140
000000038 106.0062870000000004 106.2709119999999956 106.4945139999999952 106.5105590000000007 106.3156199999999956 106.287116999999995 106.5828779999999938 106.6125490000000013 106.4466479999999962 106.2125089999999972 105.9822769999999963 105.9220430000000022 105.9256969999999995 106.0044330000000059 106.1598359999999985 106.5297850000000039 107.1081310000000002 107.7699360000000013 108.4229809999999929 109.173759000000004 109.7936480000000046 110.2676089999999931 110.6312559999999934 110.7958299999999952 110.6846079999999972 110.1208419999999961 109.2587199999999967 108.4676740000000024 107.7798920000000038 106.9588389999999976 106.3980710000000016 105.9439469999999943 105.4268569999999983 104.7102969999999971 103.6027069999999952 101.9444270000000046 99.8519670000000019 98.4687650000000048 98.390113999999997 99.4163669999999939 100.8467330000000004 102.4928819999999945 103.834502999999998 104.5645980000000037 104.8962779999999952 104.8532100000000042 104.5240249999999946
104.2140880000000038 103.471100000000007 102.4531099999999952 101.0893250000000023 99.6991040000000055 98.8598479999999995 98.2058490000000006 98.7194140000000004 100.6557540000000017 102.8862459999999999 104.7170789999999982 106.1106719999999939 107.2991410000000059 108.4419170000000037 109.6554869999999937 110.822929000000002 111.764411999999993 112.5034789999999987 112.7083659999999981 111.9916840000000064 110.4378590000000031 109.566749999999999 109.3161850000000044 109.3033369999999991 109.8853000000000009 110.9786380000000037
+90.4356920000000031 89.796882999999994 88.5764159999999947 88.1064760000000007 87.824860000000001 87.5418470000000042 87.0915449999999964 86.6396409999999975 86.3651499999999999 86.3997729999999962 86.5196380000000005 86.4811710000000033 86.3950499999999977 86.3299640000000039 86.3002400000000023 86.2625730000000033 86.2342529999999954 86.2269289999999984 86.2287979999999976 86.2289659999999998 86.2289659999999998 86.2288970000000035 86.2319490000000002 86.2167280000000034 86.2028959999999955 86.2865450000000038 86.533653000000001 86.6909409999999951 86.6862950000000012 86.5706710000000044 86.4428180000000026 86.376616999999996 86.2518309999999957 86.2066959999999938 86.2264019999999931 86.224213000000006 86.2845839999999953 86.3946080000000052 86.348228000000006 86.2203370000000007 86.2298279999999977 86.2642290000000003 86.3103870000000057 86.2344360000000023 86.1659159999999957 86.3957139999999981 86.5071640000000031 86.2600400000000036 86.3720699999999937 86.587333999999
9985 86.4201740000000029 86.3125840000000011 86.2453309999999931 86.193641999999997 86.1984709999999978 86.1984939999999966 86.1984939999999966 86.1982730000000004 86.2002789999999948 86.2003940000000028 86.1884000000000015 86.2224960000000067 86.3082809999999938 86.3898010000000056 86.4187550000000044 86.4162520000000001 86.3799819999999983 86.4344559999999973 86.5566939999999931 86.6023330000000016 86.5816420000000022 86.5880810000000025 86.5874940000000066 86.4555739999999986 86.3207320000000067 86.4130250000000046 86.4521029999999939 86.4339449999999943 86.3764110000000045 86.3709029999999984 86.3580699999999979 86.413146999999995 86.7078089999999975 87.0390469999999965 87.3228299999999962 87.5314330000000069 88.1684269999999941 89.180412000000004 90.0383829999999961 90.4596099999999979 90.5072710000000029 90.5100099999999941 90.4541399999999953 90.2654419999999931 90.1173100000000034 90.1950230000000062 90.495948999999996 90.9416499999999957 91.3773039999999952 92.17167
70000000025 93.5560839999999985 95.0590669999999989 96.5706789999999984 98.0815280000000058 99.5451809999999995 100.4717179999999956 100.8034130000000062 101.1213759999999979 101.2528310000000005 100.9844130000000035 100.4758829999999961 99.3666840000000064 97.4092250000000064 96.610084999999998 97.5509639999999933 98.267760999999993 98.2644269999999977 97.8562929999999938 96.743858000000003 95.3204879999999974 94.2428589999999957 93.2632370000000037 91.7176060000000035 90.3630140000000068 90.0611499999999978 90.1284639999999939 90.1487050000000067 90.114104999999995 90.2546229999999952 91.1564560000000057 92.3873750000000058 93.2015459999999933 94.2388760000000048 96.065101999999996 97.6075359999999961 98.4973679999999945 99.2351230000000015 99.9647520000000043 100.7654950000000014 101.4841610000000003 102.0030139999999932 102.5604320000000058 103.3563919999999996 104.0814900000000023 104.6864779999999939 105.1715930000000014 105.4052659999999975 105.4854200000000048 105.60
41029999999949 106.0258790000000033 106.3179549999999978 106.1903920000000028 105.8983460000000036 105.6621860000000055 105.4804989999999947 105.639244000000005 105.7967450000000014 105.5189900000000023 105.2775039999999933 105.2551119999999969 105.2653880000000015 105.2575149999999979 105.2982250000000022 105.5735169999999954 106.1452409999999986 106.8477939999999933 107.5941310000000044 108.2728199999999958 109.0129550000000052 109.6202239999999932 110.0665359999999993 110.3917160000000024 110.5058750000000032 110.4150240000000025 109.9019009999999952 109.0729599999999948 108.3419650000000019 107.6383819999999929 106.7129290000000026 106.0277480000000025 105.4828109999999981 104.9423519999999996 104.4238820000000061 103.4922030000000035 101.844459999999998 99.8010940000000062 98.3776320000000055 97.9793010000000066 98.8139039999999937 100.3270260000000036 101.8722759999999994 102.8639529999999951 103.3778839999999946 103.4971769999999935 103.4187009999999987 103.1825560000
000053 102.6466219999999936 101.8473890000000068 100.6956480000000056 99.1819529999999929 98.2377929999999964 97.9359050000000053 98.2610020000000048 99.8764039999999937 101.9035259999999994 103.6653210000000058 105.3456039999999945 106.7276609999999977 107.7141879999999929 108.7941670000000016 110.080444 111.2690809999999999 112.274872000000002 112.9515909999999934 112.9797130000000038 112.3523859999999956 111.3222889999999978 110.1743239999999986 109.7006229999999931 109.7816930000000042 110.4841689999999943 111.5196080000000052
+90.6521450000000044 90.5508119999999934 89.8356480000000062 88.8955990000000043 87.9173200000000037 87.4044339999999949 87.0132289999999955 86.6303939999999955 86.4324340000000007 86.3996120000000047 86.4132769999999937 86.414085 86.3679049999999933 86.3145829999999989 86.2682039999999972 86.2378460000000047 86.2250140000000016 86.2288439999999952 86.2289810000000045 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2285920000000061 86.2311859999999939 86.2307210000000026 86.2141490000000061 86.3380580000000037 86.4917449999999945 86.4942700000000002 86.5268939999999986 86.566032000000007 86.4160229999999956 86.2521440000000013 86.2079159999999973 86.2058329999999984 86.2285310000000038 86.2352520000000027 86.3159559999999999 86.3433529999999934 86.2790600000000012 86.2587740000000025 86.225403 86.2004320000000064 86.109893999999997 86.1968839999999972 86.5039440000000042 86.5926819999999964 86.272437999999994 86.2389830000000046 86.4054869999999937 86.406211999
9999965 86.4290539999999936 86.3505099999999999 86.1699600000000032 86.1786270000000059 86.1983489999999932 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1982650000000064 86.1989750000000043 86.2329479999999933 86.3056950000000001 86.3789830000000052 86.4630360000000024 86.5089260000000024 86.4245679999999936 86.3919750000000022 86.4861599999999981 86.6226649999999978 86.685883000000004 86.6117550000000023 86.5162509999999969 86.4953459999999978 86.4800950000000057 86.5108180000000004 86.5163119999999992 86.5037769999999995 86.4809340000000049 86.4755099999999999 86.3992690000000039 86.4431689999999975 86.6244659999999982 86.7628169999999983 87.0600359999999966 87.3270949999999999 88.0198440000000062 89.0265880000000038 89.8159639999999939 90.1015620000000013 90.071312000000006 89.9908290000000051 89.7677690000000013 89.686561999999995 89.6206509999999952 89.6764370000000071 89.9932709999999929 90.3929600000000022 90.9115369999999956 91.8644330000000053 93.3
39020000000005 94.7749859999999984 96.4110790000000009 98.1386870000000044 99.397514000000001 100.1801990000000018 100.5896220000000056 101.1048739999999952 101.2788769999999943 100.9790119999999973 100.5954129999999935 100.0482180000000056 97.9298480000000069 95.9575269999999989 96.3939900000000023 97.4022899999999936 97.5910719999999969 96.8204570000000047 95.4236449999999934 93.9501719999999949 92.7480999999999938 91.7365800000000036 90.6490170000000006 90.1247180000000014 90.1268230000000017 90.1400150000000053 90.1178359999999969 90.0666729999999944 90.7245249999999999 92.2475429999999932 93.5965039999999959 94.4716489999999993 95.2949600000000032 96.7638400000000019 98.094452000000004 98.8648680000000013 99.6039049999999975 100.3932879999999983 101.2295759999999945 101.9978490000000022 102.6076970000000017 103.1804889999999943 103.8985289999999964 104.5212709999999987 104.9670789999999982 105.1987529999999964 105.1692280000000039 105.2043610000000058 105.59580200000000
62 106.1928410000000014 106.1451490000000035 105.6841050000000024 105.2219850000000037 104.8943179999999984 104.6930919999999929 104.5843119999999971 104.5361560000000054 104.3539729999999963 104.2432790000000011 104.2604749999999996 104.3303910000000059 104.4698790000000059 104.8045199999999966 105.3645779999999945 106.1233900000000006 106.9767910000000057 107.638701999999995 108.2225880000000018 108.8654630000000054 109.3504489999999976 109.710716000000005 109.9583509999999933 110.0581209999999999 110.0035629999999998 109.6451950000000011 108.9719920000000002 108.2775120000000015 107.4813769999999948 106.5552899999999994 105.7704700000000031 104.991028 104.4384919999999966 104.0426410000000033 103.2630539999999968 101.9011079999999936 99.9418720000000036 98.4009479999999996 97.6927259999999933 98.1491170000000039 99.5982970000000023 100.861976999999996 101.6180729999999954 102.0423660000000012 102.1041950000000043 101.857483000000002 101.4110179999999986 100.76825700000000
55 100.1022339999999957 99.0666580000000039 97.7702940000000069 97.6058879999999931 98.2794880000000006 99.3328170000000057 101.0422290000000061 102.6634289999999936 104.2772899999999936 105.9153289999999998 107.1993939999999981 108.1739270000000062 109.2751920000000041 110.530028999999999 111.7201539999999937 112.7009350000000012 113.2987059999999957 113.3781890000000061 112.9403149999999982 112.2233279999999951 110.9270860000000027 110.1334609999999969 110.227485999999999 111.1143260000000055 112.1087950000000006
+90.6345290000000006 91.5147709999999961 91.7929689999999994 90.5946500000000015 88.5816269999999975 87.2779390000000035 86.8612059999999957 86.6126170000000002 86.3522490000000005 86.3815840000000037 86.4381099999999947 86.4337009999999992 86.4359819999999957 86.3458179999999942 86.2627789999999948 86.2239689999999968 86.2276540000000011 86.2291179999999997 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.228935000000007 86.2272719999999993 86.2212449999999961 86.2677379999999943 86.2548599999999936 86.4058529999999934 86.6415939999999978 86.5736849999999976 86.4390259999999984 86.3741530000000068 86.2701260000000048 86.198798999999994 86.1893079999999969 86.2773820000000029 86.4835889999999949 86.4483720000000062 86.2980799999999988 86.3172990000000055 86.3426440000000071 86.3318179999999984 86.4611210000000057 86.4752730000000014 86.3168560000000014 86.2448499999999996 86.3148730000000057 86.33933299
99999963 86.3436810000000037 86.4098510000000033 86.4824980000000068 86.4204859999999968 86.256896999999995 86.1991349999999983 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1970290000000006 86.2066499999999962 86.2544479999999965 86.320258999999993 86.3899839999999983 86.4540410000000037 86.4896849999999944 86.4638900000000064 86.3928829999999977 86.4042210000000068 86.5986249999999984 86.7899929999999955 86.7628559999999993 86.5650859999999938 86.4554600000000022 86.5014649999999961 86.5006180000000029 86.4784850000000063 86.483161999999993 86.489570999999998 86.5275419999999968 86.446280999999999 86.4546660000000031 86.5461269999999985 86.4832609999999988 86.7862779999999958 87.2193369999999959 87.7816310000000044 88.7309039999999953 89.4397430000000071 89.5311509999999942 89.5477599999999967 89.478675999999993 89.2135389999999973 89.2821040000000039 89.2342220000000026 89.2755279999999942 89.6279750000000064 89.9804309999999958 90.5668560000000014 91.675
7429999999971 93.2387540000000001 94.7980579999999975 96.2332839999999976 97.7372510000000005 99.1233900000000006 99.9823229999999938 100.5163880000000063 101.0505679999999984 101.2321170000000023 100.9673460000000063 100.4099729999999937 99.9971469999999982 98.3218459999999936 95.7254939999999976 95.0749969999999962 95.8921590000000066 96.454314999999994 95.488190000000003 93.9327320000000014 92.4027860000000061 91.1611630000000019 90.6194919999999939 90.4066389999999984 90.2813569999999999 90.1620329999999939 90.1563869999999952 90.1459959999999967 90.1820139999999952 91.5057749999999999 93.2785030000000006 94.4739229999999992 95.4485020000000048 96.4220279999999974 97.6868060000000042 98.4957279999999997 99.1847920000000016 99.9908750000000026 100.7365190000000013 101.5825119999999941 102.4004819999999967 102.963074000000006 103.5726389999999952 104.3426060000000035 104.8317870000000056 104.8594510000000071 104.7903589999999951 104.8224869999999953 105.2174219999999991 10
5.8616559999999964 106.0298080000000027 105.6720049999999986 105.245750000000001 104.7031779999999941 104.1060939999999988 103.849648000000002 103.6612319999999983 103.3496090000000009 103.1423259999999971 103.3069689999999952 103.4769900000000007 103.7648010000000056 104.277985000000001 104.925407000000007 105.6301799999999957 106.4648130000000066 107.2160800000000052 107.7267609999999962 108.2549290000000042 108.7798540000000003 109.1436230000000052 109.3693310000000025 109.4853739999999931 109.5291519999999963 109.4269709999999947 109.117408999999995 108.6969600000000042 108.1628039999999942 107.403846999999999 106.6022799999999933 105.7770610000000033 104.686286999999993 103.9096909999999951 103.4567569999999961 102.8784710000000047 101.845130999999995 100.0877530000000064 98.5629729999999995 97.5921709999999933 97.7141419999999954 98.8577729999999946 99.6277390000000054 100.1656880000000029 100.6256869999999992 100.6546859999999981 100.3611219999999946 99.58513600000000
57 98.843474999999998 98.5330199999999934 97.7676089999999931 97.036247000000003 97.8256379999999979 99.1750260000000026 100.348511000000002 101.5402830000000023 102.9842380000000048 104.8710779999999971 106.5033870000000036 107.6035310000000038 108.6154400000000066 109.7026749999999993 110.9235460000000018 112.1521000000000043 112.9887389999999954 113.510468000000003 113.6818470000000048 113.2437970000000007 112.5976869999999934 111.6505889999999965 110.6702959999999933 110.6462250000000012 111.6270289999999932 112.7195360000000051
+91.0737689999999986 92.1524280000000005 92.8343050000000005 91.7582469999999972 89.2648089999999996 87.3219529999999935 86.6632539999999949 86.5171050000000008 86.3129880000000043 86.3670730000000049 86.4927289999999971 86.5297699999999992 86.5135649999999998 86.4698410000000024 86.3706970000000069 86.2354809999999929 86.2193829999999934 86.227294999999998 86.2289810000000045 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.229186999999996 86.2237169999999935 86.2095110000000062 86.1926500000000004 86.277869999999993 86.5481800000000021 86.7176970000000011 86.6351779999999962 86.5646210000000025 86.4404750000000064 86.2791059999999987 86.2232740000000035 86.2640379999999993 86.5015340000000066 86.4641270000000048 86.2294310000000053 86.4144969999999972 86.5780330000000049 86.5447539999999975 86.5866469999999993 86.460875999999999 86.1884840000000025 86.2061389999999932 86.3228229999999996 86.4145510000
00003 86.3888850000000019 86.3480529999999931 86.5421520000000015 86.7608720000000062 86.3649599999999964 86.2001499999999936 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1968459999999936 86.2072450000000003 86.2648389999999949 86.3389970000000062 86.4125750000000039 86.4375840000000011 86.4485700000000037 86.4747619999999984 86.4563830000000024 86.4151839999999964 86.4531939999999963 86.7033389999999997 86.9342800000000011 86.7506939999999958 86.4610749999999939 86.4388430000000056 86.4682690000000065 86.4645610000000033 86.4647669999999948 86.4597629999999953 86.468231000000003 86.4404909999999944 86.3927460000000025 86.3356780000000015 86.3471679999999964 86.6466290000000043 87.0716170000000034 87.412193000000002 88.1318360000000069 88.8107830000000007 88.8860169999999954 88.875243999999995 88.8063429999999983 88.6650010000000037 88.7025069999999971 88.8489529999999945 89.0394440000000031 89.3270650000000046 89.8711399999999969 90.6649550000000062 91.809
203999999994 93.2837140000000034 95.0045389999999941 96.5076750000000061 97.5846020000000038 98.8322830000000039 99.7546839999999975 100.4750059999999934 101.0548320000000047 101.2091450000000066 100.9913939999999997 99.9932170000000013 99.2046279999999996 98.0447620000000057 95.8029020000000031 94.1645659999999936 93.9736630000000019 94.714256000000006 94.200255999999996 92.3666460000000029 90.8173369999999949 90.1752929999999964 90.1632919999999984 90.284599 90.2393419999999935 90.1320950000000067 90.1555180000000007 90.1545870000000065 90.5881729999999976 92.419280999999998 94.0597989999999982 95.1012039999999956 96.0083240000000018 97.0500109999999978 98.1636579999999981 98.8608169999999973 99.5743939999999981 100.3129200000000054 101.0192949999999996 101.8587950000000006 102.6248020000000025 103.2294459999999958 103.9191509999999994 104.5868150000000014 104.6625439999999969 104.2865910000000014 104.3342360000000042 104.8377080000000063 105.4787749999999988 105.869461000
0000011 105.6232380000000006 105.245789000000002 104.8758239999999944 104.1618959999999987 103.4158630000000016 103.0542449999999945 102.6617360000000048 102.4878389999999939 102.3397290000000055 102.7269210000000044 103.2698060000000027 103.853431999999998 104.5834729999999979 105.2233659999999986 105.8985820000000047 106.7361530000000016 107.3351590000000044 107.7646100000000047 108.2279589999999985 108.6127620000000036 108.8529130000000009 108.9827650000000006 109.0486300000000028 109.0397260000000017 108.8194119999999998 108.4939269999999993 108.2900700000000001 107.9212270000000018 107.3877030000000019 106.7631990000000002 105.933173999999994 104.8341829999999959 103.838325999999995 103.0574340000000007 102.348479999999995 101.3739699999999999 99.823882999999995 98.4124910000000028 97.3491439999999955 97.265113999999997 98.0473250000000007 98.5704120000000046 98.8031620000000004 99.0863039999999984 99.1775360000000035 98.8063740000000053 98.0385059999999982 97.403023000
0000046 97.248344000000003 96.9402620000000042 96.939384000000004 98.1255950000000041 99.5031280000000038 100.5949020000000047 101.7302169999999961 103.3579710000000063 105.3835909999999956 107.0482180000000056 108.165253000000007 109.1266779999999983 110.098243999999994 111.2935939999999988 112.4771879999999982 113.2620090000000062 113.7740249999999946 113.8974149999999952 113.4848400000000055 112.8600540000000052 112.2074970000000036 111.3656229999999994 110.9839709999999968 111.9623339999999985 113.3005600000000044
+91.7590100000000035 92.1645740000000018 92.7238540000000029 92.0581509999999952 89.5853039999999936 87.4050220000000024 86.5907899999999984 86.5044400000000024 86.413848999999999 86.433441000000002 86.5033260000000013 86.5652620000000042 86.4968570000000057 86.5069500000000033 86.4656140000000022 86.3182529999999986 86.2539830000000052 86.2308120000000002 86.2287900000000036 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289580000000058 86.2291639999999973 86.2291720000000055 86.2306370000000015 86.2182920000000053 86.3521420000000006 86.5846789999999942 86.6286089999999973 86.632782000000006 86.5922159999999934 86.6082839999999976 86.3771820000000048 86.1942520000000059 86.3104859999999974 86.3235240000000061 86.1966859999999997 86.4494169999999968 86.6258849999999967 86.5970920000000035 86.624046000000007 86.5364000000000004 86.2764130000000051 86.1495900000000034 86.2881849999999986 86.5274730000
000005 86.5021129999999943 86.4380649999999946 86.5584640000000007 86.596100000000007 86.277702000000005 86.1989290000000068 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1965869999999938 86.2083439999999968 86.2763980000000004 86.3578799999999944 86.4125439999999969 86.4137419999999992 86.4278950000000066 86.4484099999999955 86.4552989999999966 86.4428180000000026 86.3911740000000066 86.4963840000000062 86.7306899999999956 86.6663510000000059 86.4644389999999987 86.4303819999999945 86.44529 86.447661999999994 86.4479139999999973 86.4465710000000058 86.4375459999999975 86.4433439999999962 86.3786240000000021 86.2875599999999991 86.4347149999999971 86.632598999999999 86.8996429999999975 87.0965039999999959 87.455962999999997 87.9696349999999967 88.1957239999999985 88.1285859999999985 88.0711979999999954 88.0604249999999951 88.0668330000000026 88.4144739999999985 88.7559969999999936 89.1561049999999966 90.0081330000000008 91.0370939999999962 92.146918999999996
9 93.3318479999999937 94.8592529999999954 96.5734020000000015 97.6866839999999996 98.592101999999997 99.3939670000000035 100.2717289999999934 100.9956970000000069 101.1414180000000016 100.9856950000000069 99.6442030000000045 98.5545199999999966 97.8071750000000009 96.2269820000000067 94.2349399999999946 92.750953999999993 92.7501139999999964 92.4597550000000012 91.195533999999995 90.1874009999999942 89.9712909999999937 90.0514600000000058 90.1325839999999943 90.1367489999999947 90.1217649999999963 90.1096339999999998 89.9845430000000022 91.0220259999999968 93.2568590000000057 94.640106000000003 95.5717089999999985 96.4591139999999996 97.5796430000000043 98.5117570000000029 99.2996749999999935 99.9806289999999933 100.5829010000000068 101.316978000000006 102.143462999999997 102.777007999999995 103.4532470000000046 104.0326539999999937 104.1295929999999998 103.8857650000000064 103.9114150000000052 104.5160369999999972 105.2357250000000022 105.6711039999999997 105.64086199999999
85 105.2481379999999973 104.9421009999999939 104.4624249999999961 103.6383670000000023 102.9255679999999984 102.2881009999999975 101.6623610000000042 101.7802049999999952 102.0325160000000011 102.5848390000000023 103.4013599999999968 104.1744920000000008 104.7854229999999944 105.3752819999999986 105.9832310000000035 106.7092289999999934 107.2996519999999947 107.6545030000000054 108.0055849999999964 108.2571489999999983 108.4237439999999992 108.5164719999999932 108.5320210000000003 108.4534989999999937 108.2151180000000039 107.9733350000000058 107.8589319999999958 107.5989000000000004 107.2483900000000006 106.7710419999999942 106.0143049999999931 105.0037769999999995 104.0041499999999957 103.0804669999999987 101.9951400000000064 100.7754139999999978 99.3184590000000043 98.0426790000000068 97.2223280000000045 96.9442370000000011 97.3629530000000045 97.8587189999999936 97.9126660000000015 97.8272549999999939 97.7782440000000008 97.4204029999999932 96.8401029999999992 96.5256349
999999941 96.5498889999999932 96.8754729999999995 97.5157700000000034 98.5530320000000017 99.613617000000005 100.6581649999999968 102.0405039999999985 103.9200129999999973 106.0177989999999966 107.6896509999999978 108.8174819999999983 109.7940750000000065 110.694855000000004 111.6838300000000004 112.6911620000000056 113.5604399999999998 114.1004640000000023 114.0594789999999961 113.5371779999999973 113.0912249999999943 112.6928939999999955 112.0150299999999959 111.2799679999999967 111.8694229999999976 113.340644999999995
+92.0282590000000056 92.0940400000000068 92.4253460000000047 92.1258239999999944 89.8755419999999958 87.5415729999999996 86.6897890000000046 86.5952220000000068 86.4828339999999969 86.469688000000005 86.4412229999999937 86.470366999999996 86.4441829999999953 86.4137949999999933 86.3642269999999996 86.3560329999999965 86.3254850000000005 86.2514800000000008 86.2292860000000019 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2293090000000007 86.226768000000007 86.2279209999999949 86.2834849999999989 86.4576260000000048 86.6467439999999982 86.6725390000000004 86.7018049999999931 86.3724590000000063 86.1544109999999961 86.1893230000000017 86.211662000000004 86.2071300000000065 86.3129880000000043 86.3732760000000042 86.4548570000000041 86.5721209999999957 86.5689849999999979 86.3940960000000047 86.173088000000007 86.2864909999999981 86.54658499999
99932 86.5790020000000027 86.6192250000000001 86.6383359999999954 86.2850799999999936 86.1689530000000019 86.1979749999999996 86.1984939999999966 86.1984939999999966 86.1985549999999989 86.195098999999999 86.2145309999999938 86.2974470000000053 86.3699720000000042 86.384674000000004 86.3857189999999946 86.4096909999999951 86.4120180000000033 86.4116590000000002 86.412895000000006 86.4037550000000039 86.4098129999999998 86.4460299999999933 86.4478840000000019 86.4366150000000033 86.4438250000000039 86.4426650000000052 86.4424360000000007 86.4423900000000032 86.4427799999999991 86.4439540000000051 86.4472810000000038 86.4317630000000037 86.3810419999999937 86.3490599999999944 86.4608539999999977 86.6443560000000019 86.681358000000003 86.8921890000000019 87.1884610000000038 87.378296000000006 87.4597849999999966 87.5919489999999996 87.5566859999999991 87.6532519999999948 88.0878600000000063 88.4068680000000029 89.0634989999999931 90.2050250000000062 91.3107530000000054 92.42693
30000000053 93.4693680000000029 94.6145549999999957 96.2244799999999998 97.6744920000000008 98.5046540000000022 99.1590649999999982 99.9355010000000021 100.5863190000000031 100.7886120000000005 100.7632289999999955 99.660743999999994 98.5285949999999957 97.9198070000000058 96.7362289999999945 95.1235120000000052 93.3300629999999956 92.0612720000000024 90.9497680000000059 90.5896379999999937 90.4658359999999959 90.1522980000000018 90.0588910000000027 90.0835720000000038 90.1031190000000066 90.1023249999999933 90.0387340000000052 90.2537769999999995 91.8489529999999945 93.9815830000000005 95.1495589999999964 96.0019300000000015 97.0186769999999967 98.0392460000000057 98.8878399999999971 99.7121730000000071 100.3459699999999941 100.9538569999999993 101.6654429999999962 102.3805919999999929 102.998778999999999 103.4857329999999962 103.5076750000000061 103.2215649999999982 103.3553619999999995 104.1946329999999961 105.0137940000000043 105.3867719999999935 105.6155009999999947 105
.3968050000000005 104.938873000000001 104.5896149999999949 103.8872219999999942 103.0998689999999982 102.5530619999999971 101.6386030000000034 100.9143519999999938 101.1450119999999941 101.7671739999999971 102.6110610000000065 103.5254439999999931 104.2877809999999954 104.8781359999999978 105.4443590000000057 105.8857569999999981 106.3903660000000002 106.8867570000000029 107.2023470000000032 107.4761510000000015 107.6748659999999944 107.8697429999999997 107.9819260000000014 107.9300989999999985 107.8120799999999946 107.6223530000000039 107.4922710000000023 107.3758160000000004 107.1294400000000024 106.8530120000000068 106.5153430000000014 105.9352039999999988 104.9425350000000066 103.9007569999999987 102.9360960000000063 101.8733979999999946 100.5592649999999963 99.0548249999999939 97.8100809999999967 97.1157910000000015 96.7090610000000055 96.870079000000004 97.3355480000000028 97.3482740000000035 97.1142430000000019 96.8773879999999963 96.4780959999999936 96.07029 96.36012
99999999981 97.0238489999999985 97.7458189999999973 98.34375 99.1099700000000041 100.0147780000000068 101.0568770000000001 102.7425159999999948 104.7560579999999959 106.737922999999995 108.3115769999999998 109.3675769999999972 110.3408510000000007 111.2660290000000032 112.1200939999999946 113.0176699999999954 113.8098530000000039 114.2257539999999949 114.0668330000000026 113.524437000000006 113.1493150000000014 112.9247060000000005 112.4257199999999983 111.7059330000000017 111.6632390000000044 112.966155999999998
+92.0640790000000067 92.2465739999999954 92.5836029999999965 92.3628690000000034 90.2326809999999995 87.8379900000000049 86.7129359999999991 86.4974210000000028 86.4489360000000033 86.4409030000000058 86.4375229999999988 86.3856049999999982 86.4411010000000033 86.4253010000000046 86.2427749999999946 86.2629239999999982 86.2917939999999959 86.2589490000000012 86.2305450000000064 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2291639999999973 86.2191159999999996 86.165229999999994 86.2493740000000031 86.4907070000000004 86.5163419999999945 86.3450160000000011 86.2170409999999947 86.1839219999999955 86.1953960000000023 86.1904140000000041 86.1973109999999991 86.1842419999999976 86.1779939999999982 86.226532000000006 86.3056179999999955 86.4565350000000024 86.551201000000006 86.4439390000000003 86.2899170000000026 86.328093999
999993 86.4898910000000001 86.6240769999999998 86.6587980000000044 86.2766419999999954 86.1846239999999995 86.1985700000000037 86.1984939999999966 86.1984939999999966 86.198395000000005 86.194587999999996 86.2244419999999963 86.3106379999999973 86.3571469999999977 86.3524929999999955 86.3624650000000003 86.384490999999997 86.3816300000000012 86.3815380000000062 86.3791049999999956 86.3927989999999966 86.404601999999997 86.3916779999999989 86.3983000000000061 86.4222409999999996 86.4380419999999958 86.437256000000005 86.4367289999999997 86.4366990000000044 86.4366679999999974 86.4365389999999962 86.4367749999999972 86.4402769999999947 86.3680569999999932 86.1972729999999956 86.2887730000000062 86.4347149999999971 86.370705000000001 86.5200580000000059 86.7018589999999989 86.7440950000000015 86.8703160000000025 87.203117000000006 87.2782140000000055 87.3700180000000017 87.7590560000000011 88.091155999999998 88.937224999999998 90.2344970000000046 91.3863529999999997 92.52828999
99999984 93.6022260000000017 94.5629119999999972 95.9993670000000066 97.4342879999999951 98.3328319999999962 99.0135649999999998 99.5820539999999994 99.954338000000007 100.1687849999999997 100.2708590000000015 99.7036509999999936 98.7281949999999995 97.9588779999999986 96.8805470000000071 95.7127610000000004 94.4325180000000017 92.8329849999999936 91.069587999999996 90.2593839999999972 90.3522339999999957 90.2351529999999968 90.0919880000000006 90.0821080000000052 90.0936130000000048 90.0268630000000059 90.0923080000000027 91.2032849999999939 93.0105290000000053 94.5338059999999984 95.5044560000000047 96.4154589999999985 97.4870530000000031 98.3683620000000047 99.2530820000000062 99.9643630000000059 100.6113430000000051 101.3025209999999987 101.9464650000000034 102.5567779999999942 102.9326630000000051 102.8751529999999974 102.6621399999999937 102.7222370000000069 103.5171590000000066 104.6221850000000018 105.0880889999999965 105.1528239999999954 105.2610930000000025 105.095
2450000000056 104.6997070000000036 104.2042079999999942 103.3721239999999995 102.7184450000000027 102.1412349999999947 101.0598070000000064 100.432311999999996 100.5637660000000011 101.412871999999993 102.561797999999996 103.4844669999999951 104.2469710000000021 104.9143449999999973 105.3099899999999991 105.5893630000000059 105.9613879999999995 106.3327330000000046 106.6071929999999952 106.8205410000000057 106.9529880000000048 107.0839310000000069 107.1706700000000012 107.1400759999999934 107.0739360000000033 106.9253080000000011 106.9829639999999955 106.9729310000000027 106.7364879999999943 106.5549550000000067 106.2300950000000057 105.6655729999999949 104.7269210000000044 103.7089459999999974 102.7467500000000058 101.7965549999999979 100.5095440000000053 98.8738249999999965 97.5356670000000037 96.8069760000000059 96.4492649999999969 96.5760649999999998 96.9488599999999963 96.9336169999999981 96.6560360000000003 96.2806549999999959 95.7535780000000045 95.885185000000007 96.
9148409999999956 97.9520420000000058 98.5198440000000062 98.8767619999999994 99.4547879999999935 100.4792939999999959 101.9374310000000037 103.8694760000000059 105.7136459999999971 107.4524609999999996 108.909782000000007 110.0055689999999942 110.9612199999999973 111.7694240000000008 112.5770260000000036 113.3511120000000005 113.9054950000000019 114.1324079999999981 113.9401929999999936 113.5093150000000009 113.1184310000000011 112.9140239999999977 112.5534739999999942 112.0325389999999999 111.713752999999997 112.4725490000000008
+92.2428589999999957 92.5602489999999989 93.2919619999999981 93.1339040000000011 90.8427810000000022 88.2162479999999931 86.7195509999999956 86.3231509999999957 86.3847810000000038 86.4478679999999997 86.4957729999999998 86.3574600000000032 86.374046000000007 86.3958820000000003 86.2320019999999943 86.2167129999999986 86.2214129999999983 86.2351910000000004 86.2299270000000035 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289049999999975 86.2294310000000053 86.2281040000000019 86.2167660000000069 86.1850589999999954 86.2396700000000038 86.2385179999999991 86.147514000000001 86.1797640000000058 86.2036970000000053 86.1983570000000014 86.1984939999999966 86.1984020000000015 86.1958390000000065 86.1952969999999965 86.172118999999995 86.1533890000000042 86.2636260000000021 86.4950180000000017 86.6108250000000055 86.4392780000000016 86.197745999
9999951 86.271056999999999 86.4990010000000069 86.6294630000000012 86.2751010000000065 86.1797940000000011 86.1978679999999997 86.1995540000000062 86.1983340000000027 86.1974029999999942 86.1976010000000059 86.2479100000000045 86.3135759999999976 86.3223950000000002 86.3226240000000047 86.3460309999999964 86.3525389999999931 86.3503570000000025 86.3478850000000051 86.3536529999999942 86.3768390000000039 86.386382999999995 86.3998490000000032 86.4092409999999944 86.4050749999999965 86.4135670000000005 86.4191969999999969 86.4197690000000023 86.4197240000000022 86.4196929999999952 86.4198460000000068 86.4198379999999986 86.4156420000000054 86.3844600000000042 86.3590470000000039 86.4353789999999975 86.4288710000000009 86.2200930000000056 86.3214949999999988 86.4773409999999956 86.4684369999999944 86.4649280000000005 86.7851560000000006 87.0990450000000038 87.1751940000000047 87.4134829999999994 87.8826600000000013 88.7502669999999938 89.9863660000000039 91.2183299999999946 92.
3340529999999973 93.3803790000000049 94.3400649999999956 95.6559220000000039 96.8592830000000049 97.902985000000001 98.6827159999999992 99.1300430000000006 99.3867259999999959 99.5298310000000015 99.6564330000000069 99.4296039999999977 98.7318800000000039 97.8100280000000026 96.6158750000000026 95.5108489999999932 94.4966890000000035 93.303009000000003 91.5957259999999991 90.1367029999999971 90.0530619999999971 90.1158140000000003 90.0945889999999991 90.0984119999999962 90.0737840000000034 90.0454100000000039 90.4909210000000002 91.996467999999993 93.6340789999999998 94.8018950000000018 95.7579649999999987 96.7984160000000031 97.7235490000000055 98.5811389999999932 99.4856950000000069 100.1253509999999949 100.7714160000000021 101.4650800000000004 102.0665439999999933 102.3709259999999972 102.226341000000005 102.0134429999999952 102.2770689999999973 102.9164959999999951 103.8880000000000052 104.6026540000000011 104.8116839999999996 104.851776000000001 104.8138430000000056 104
.6407389999999964 104.2563099999999991 103.7194439999999958 103.0285109999999946 102.498786999999993 101.7721630000000062 100.6782379999999932 100.2090529999999973 100.3331680000000006 101.2316969999999969 102.4571300000000065 103.4789810000000045 104.1498569999999972 104.5405879999999996 104.7904589999999985 105.1172789999999964 105.5192789999999974 105.8006359999999972 106.0112299999999976 106.2189479999999975 106.3222889999999978 106.3959270000000004 106.3893589999999989 106.3676150000000007 106.3170929999999998 106.1099700000000041 106.3204269999999951 106.5029980000000052 106.3967899999999958 106.2635800000000046 105.8871539999999953 105.3216550000000069 104.4589079999999939 103.5358509999999939 102.5940020000000032 101.5377199999999931 100.2692260000000033 98.6301420000000064 97.1375730000000033 96.289268000000007 95.9696119999999979 96.2965319999999991 96.7306820000000016 96.6801300000000055 96.2552950000000038 95.8052140000000065 95.6094130000000035 96.39674399999999
82 97.6054149999999936 98.2984699999999947 98.6670680000000004 99.1593859999999978 99.8815230000000014 101.1164019999999937 102.9680019999999985 104.8959810000000061 106.435851999999997 108.0066829999999953 109.4231259999999963 110.5852430000000055 111.5539320000000032 112.2664259999999956 112.9339750000000038 113.4908369999999991 113.8368909999999943 113.9491649999999936 113.7709430000000026 113.3439410000000009 112.9626690000000053 112.8038939999999997 112.5594099999999997 112.1334839999999957 111.7852400000000017 111.955451999999994
+93.0361790000000042 93.3017729999999972 93.999329000000003 93.8588709999999935 91.676392000000007 88.7317500000000052 87.0283739999999995 86.4202120000000065 86.3628850000000057 86.5043720000000036 86.5474700000000041 86.4527659999999969 86.353943000000001 86.2560959999999994 86.2273249999999933 86.2292400000000043 86.2280729999999949 86.2270659999999936 86.2287670000000048 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289200000000022 86.2293399999999934 86.2294009999999957 86.2139209999999991 86.2071530000000052 86.2003780000000006 86.1798550000000034 86.1794969999999978 86.1997599999999977 86.2000349999999997 86.1982650000000064 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1982500000000016 86.2003710000000041 86.2004320000000064 86.1801909999999936 86.2412259999999975 86.3596040000000045 86.5481029999999976 86.366966000
000005 86.1502229999999969 86.3480679999999978 86.585448999999997 86.2891620000000046 86.1688769999999948 86.1776200000000046 86.1836619999999982 86.1885759999999976 86.1896509999999978 86.1983489999999932 86.2602159999999998 86.3008039999999994 86.2905959999999936 86.2985379999999935 86.3233180000000004 86.3207550000000055 86.3224330000000037 86.3259809999999987 86.3444669999999945 86.3632130000000018 86.3738330000000047 86.379210999999998 86.3889539999999982 86.387519999999995 86.3913500000000028 86.4055180000000007 86.4046170000000018 86.4047089999999969 86.4047319999999957 86.4036030000000039 86.4078290000000067 86.4093019999999967 86.418334999999999 86.4671100000000052 86.5486680000000064 86.4519420000000025 86.1261290000000059 86.2522349999999989 86.3828809999999976 86.3624650000000003 86.3356629999999967 86.5079879999999974 86.8743359999999996 87.1255799999999994 87.345673000000005 87.8309399999999982 88.535492000000005 89.699592999999993 90.88279 91.8875809999999973
92.9267119999999949 93.9384989999999931 95.093231000000003 96.2467579999999998 97.3621600000000029 98.0589370000000002 98.4653849999999977 98.8145140000000026 98.9438320000000004 99.0297699999999992 98.9497989999999987 98.4224700000000041 97.415229999999994 96.0983509999999939 94.9247890000000041 93.8004679999999951 92.5602650000000011 91.0566100000000063 90.0699769999999944 90.042580000000001 90.0498120000000029 90.0876540000000006 90.1452029999999951 90.1019289999999984 90.2062839999999966 91.0450519999999983 92.4187239999999974 93.8254780000000039 94.9364929999999987 96.033409000000006 97.0929639999999949 97.875434999999996 98.6837079999999958 99.522712999999996 100.2137220000000042 100.8383409999999998 101.4728929999999991 101.8122099999999932 101.6001969999999943 101.4295730000000049 101.7180859999999996 102.5073780000000028 103.3620760000000018 103.9276119999999963 104.2494959999999935 104.361510999999993 104.369811999999996 104.2595440000000053 104.0437929999999938 10
3.6685410000000047 103.1238859999999988 102.6124420000000015 102.2180560000000042 101.5488890000000026 100.5014720000000068 100.1525879999999944 100.4783099999999934 101.1812589999999972 102.2427830000000029 103.4063419999999951 103.8603590000000025 103.8684010000000058 104.208824000000007 104.5970080000000024 104.8455119999999994 104.9974140000000062 105.2212219999999974 105.4567030000000045 105.607048000000006 105.7276839999999964 105.7099759999999975 105.6905059999999992 105.7077179999999998 105.5762480000000068 105.6747280000000018 105.8380970000000048 105.8909380000000056 105.7191310000000044 105.3838269999999966 104.8453829999999982 104.0221939999999989 103.1894450000000063 102.1609040000000022 101.0350040000000007 99.8623809999999992 98.325774999999993 96.6418689999999998 95.6575550000000021 95.4651029999999992 95.8938749999999942 96.3375400000000042 96.2693100000000044 95.7948300000000046 95.5495379999999983 95.9244999999999948 97.0035550000000057 97.8797069999999962
98.2920230000000004 98.8323440000000062 99.5627369999999985 100.5903849999999977 102.0557400000000001 103.8944170000000042 105.5663449999999983 106.901329000000004 108.367676000000003 109.7253489999999942 110.7966229999999968 111.7031479999999988 112.4648590000000041 113.0855260000000015 113.4941859999999991 113.6474000000000046 113.6323009999999982 113.4239960000000025 113.0475009999999969 112.7481769999999983 112.6448060000000027 112.6114730000000037 112.4121399999999937 111.9385450000000048 111.5696410000000043
+93.9013139999999993 94.2212909999999937 94.7588200000000001 94.7543490000000048 92.6009750000000054 89.2627030000000019 87.3328170000000057 86.6362759999999952 86.4237059999999957 86.5558929999999975 86.563011000000003 86.5091709999999949 86.390381000000005 86.2348709999999983 86.228935000000007 86.2289889999999986 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.228943000000001 86.2292329999999936 86.2303390000000007 86.2194290000000052 86.1977619999999973 86.1958390000000065 86.1980209999999971 86.1985700000000037 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1985169999999954 86.1980290000000053 86.1692890000000062 86.1553569999999951 86.4208150000000046 86.5697940000
000017 86.3167799999999943 86.1921159999999986 86.343781000000007 86.4574130000000025 86.3811800000000005 86.280815000000004 86.1995390000000015 86.2132799999999975 86.2007519999999943 86.1877290000000045 86.2291720000000055 86.2618480000000005 86.2622910000000047 86.2842179999999956 86.2918399999999934 86.2896580000000029 86.3063279999999935 86.3234939999999966 86.3409879999999958 86.3489150000000052 86.3592000000000013 86.3568729999999931 86.3700709999999958 86.376655999999997 86.3760070000000013 86.3859020000000015 86.3895490000000024 86.3896330000000034 86.3884510000000034 86.3856739999999945 86.3973309999999941 86.4024579999999958 86.3821329999999961 86.3779600000000016 86.427582000000001 86.3987500000000068 86.2351840000000038 86.3097000000000065 86.3523560000000003 86.3341520000000031 86.3379819999999967 86.3694080000000071 86.5839229999999986 87.0497670000000028 87.5322570000000013 87.9018400000000071 88.3936920000000015 89.4328990000000061 90.5581509999999952 91.505
004999999997 92.4748079999999959 93.5330660000000051 94.546363999999997 95.6639179999999953 96.7443770000000001 97.3689349999999934 97.7574160000000063 98.1333470000000005 98.3005069999999961 98.3567050000000052 98.2692339999999973 97.7467120000000023 96.6988680000000045 95.4314269999999993 94.2449720000000042 92.6975560000000058 91.2048029999999983 90.2894129999999961 90.028923000000006 90.0621569999999991 90.0641710000000018 90.1028440000000046 90.1825259999999957 90.1920620000000071 90.3948819999999955 91.4567789999999974 92.8434369999999944 94.0957870000000014 95.1580199999999934 96.2630539999999968 97.167357999999993 97.891052000000002 98.6555249999999972 99.4444809999999961 100.1458509999999933 100.7671590000000066 101.1576770000000067 101.0282360000000068 100.8183209999999974 101.2282560000000018 102.0357589999999988 102.8836589999999944 103.4286349999999999 103.6369859999999932 103.8447800000000001 103.8327709999999939 103.7539220000000029 103.6250990000000058 103.43
64850000000047 103.0754239999999982 102.4988249999999965 102.0343929999999943 101.7713470000000058 101.4005279999999942 100.4883580000000052 99.7663569999999993 99.7829969999999946 100.5527110000000022 101.6954269999999951 102.9913559999999961 103.3983080000000001 103.4024809999999945 103.7545929999999998 104.0482640000000032 104.1039889999999986 104.1876139999999964 104.4849320000000006 104.7459340000000054 104.9235610000000065 104.9711379999999963 104.9624709999999936 104.9810640000000035 105.0427860000000067 105.1231310000000008 105.1528239999999954 105.2739640000000065 105.3607180000000056 105.1066969999999969 104.8123930000000001 104.2304919999999981 103.3978730000000041 102.6310349999999971 101.5936130000000048 100.4039539999999988 99.2415919999999971 97.7956920000000025 96.2238619999999969 95.3077090000000027 95.2136990000000054 95.442420999999996 95.7473219999999969 95.7388459999999952 95.2682109999999938 95.2401660000000021 96.0960390000000046 97.2652049999999946 97
.8810270000000031 98.5555109999999956 99.4739299999999957 100.3936080000000004 101.549201999999994 103.1110529999999983 104.6896289999999965 106.1417009999999976 107.3693999999999988 108.6711880000000008 109.8921590000000066 110.8317640000000068 111.6450040000000001 112.3961029999999965 113.0466229999999968 113.4009089999999986 113.4317020000000014 113.2869639999999976 113.031006000000005 112.7707369999999969 112.599189999999993 112.4841229999999968 112.5498809999999992 112.5391079999999988 112.0892410000000012 111.3188169999999957
+94.0102080000000058 94.821983000000003 95.9166340000000019 96.172820999999999 93.7039110000000051 89.890868999999995 87.4409559999999999 86.6239929999999987 86.4386750000000035 86.5059279999999973 86.4983670000000018 86.4685819999999978 86.3728179999999952 86.2412340000000057 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289580000000058 86.2291110000000032 86.2302700000000044 86.2234339999999975 86.2013019999999983 86.1976089999999999 86.198607999999993 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1995469999999955 86.1908339999999953 86.2406689999999969 86.5357439999
99994 86.6454930000000019 86.3629300000000057 86.2062530000000038 86.4338300000000004 86.6471860000000049 86.6021729999999934 86.4427869999999956 86.4342960000000033 86.3736799999999931 86.274360999999999 86.2331470000000024 86.214539000000002 86.2089310000000069 86.2509919999999966 86.2616199999999935 86.2704930000000019 86.2937090000000069 86.3149719999999974 86.3277590000000004 86.3341369999999984 86.3450160000000011 86.3447720000000061 86.3517609999999962 86.3599470000000053 86.3567120000000017 86.3620760000000018 86.375275000000002 86.3747709999999955 86.3796459999999939 86.3805009999999953 86.3825609999999955 86.3811039999999934 86.3593900000000048 86.3481450000000024 86.3481979999999965 86.3552779999999984 86.3578949999999992 86.3742069999999984 86.362671000000006 86.3574219999999997 86.3550869999999975 86.3369749999999954 86.3656009999999981 86.7963100000000054 87.4688950000000034 87.7849350000000044 88.1658249999999981 88.9110409999999973 90.0903019999999941 91.1540
990000000022 91.9389720000000068 92.9985580000000027 93.9611890000000045 94.9563289999999967 96.0252610000000004 96.7392810000000054 97.1463779999999986 97.4488369999999975 97.5968479999999943 97.6485140000000058 97.4914469999999937 96.8435130000000015 95.7675550000000015 94.637092999999993 93.3369749999999954 91.4889220000000023 90.348511000000002 90.0640870000000007 90.0367889999999989 90.0446319999999929 90.0752410000000054 90.1314849999999979 90.1892090000000053 90.2690120000000036 90.5301740000000024 91.7193299999999994 93.2510759999999976 94.4246059999999972 95.4410780000000045 96.3582380000000001 97.0629650000000055 97.784554 98.5692899999999952 99.3552090000000021 99.9955520000000035 100.3632970000000029 100.3585819999999984 100.2164080000000013 100.6026459999999929 101.4402690000000007 102.2549439999999947 102.8009490000000028 102.9820019999999943 103.1416090000000025 103.2981639999999999 103.2802810000000022 103.1741030000000023 103.0164950000000061 102.76590699999
99986 102.3257679999999965 101.8006060000000019 101.3528589999999951 101.1398999999999972 101.0586090000000041 100.483397999999994 99.2439349999999934 98.6175609999999949 99.4789049999999975 100.7626039999999961 102.1605299999999943 102.7942890000000062 103.0329279999999983 103.264403999999999 103.4513630000000006 103.5115590000000054 103.5720369999999946 103.8458480000000037 104.1173249999999939 104.3265300000000053 104.2910459999999944 104.2909470000000027 104.3323209999999932 104.3600540000000052 104.4620589999999964 104.5816039999999987 104.7718279999999993 104.7866360000000014 104.4670720000000017 104.1341709999999949 103.5689320000000038 102.7222440000000034 101.9511260000000021 100.9669269999999983 99.7227550000000065 98.4974210000000028 97.1078870000000052 95.8486630000000019 95.117165 94.9452129999999954 94.9761660000000063 95.0804140000000046 94.9352719999999977 94.7980119999999999 95.3558649999999943 96.3755419999999958 97.5016020000000054 98.3041000000000054 99.3
156890000000061 100.4318920000000048 101.5460970000000032 102.7490389999999962 104.1932829999999939 105.5032120000000049 106.7764739999999932 107.9009250000000009 109.0495760000000018 110.1017149999999987 110.9432979999999986 111.7056730000000044 112.3448099999999954 112.8863529999999997 113.1936259999999947 113.1801219999999972 112.9554600000000022 112.7130580000000037 112.5084460000000064 112.3674850000000021 112.2610629999999929 112.2774959999999993 112.2263640000000038 111.9420700000000011 111.0987240000000043
+94.1051180000000045 95.2409739999999942 96.5519029999999958 96.7708279999999945 94.6551900000000046 90.7837750000000057 87.7765050000000002 86.5407029999999935 86.3354259999999982 86.3037259999999975 86.3256910000000062 86.3982010000000002 86.3445210000000003 86.238617000000005 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2290119999999973 86.2297290000000061 86.2255710000000022 86.2049260000000004 86.1977689999999939 86.1985629999999929 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1986619999999988 86.1968609999999984 86.1593479999999943 86.3269499
999999965 86.6774139999999989 86.7223890000000068 86.4965820000000036 86.2504579999999947 86.4007260000000059 86.6440350000000024 86.732208 86.7753749999999968 86.670897999999994 86.5471119999999985 86.4232709999999997 86.2964020000000005 86.2582089999999937 86.2309110000000061 86.2331769999999977 86.2579730000000069 86.278137000000001 86.2973329999999947 86.3123470000000026 86.3169170000000037 86.326508000000004 86.329102000000006 86.327613999999997 86.3402559999999966 86.3443369999999959 86.3498689999999982 86.3604969999999952 86.3595119999999952 86.3732449999999972 86.380195999999998 86.3697049999999962 86.3560870000000023 86.3528749999999974 86.3506699999999938 86.3489229999999992 86.3481369999999941 86.3530499999999961 86.3728179999999952 86.3839949999999988 86.3922879999999935 86.3806689999999975 86.3756410000000017 86.3469920000000002 86.4770129999999995 87.0007549999999981 87.6082080000000047 87.9395600000000002 88.3588869999999957 89.2981489999999951 90.391930000000
0021 91.1898039999999952 92.2449419999999947 93.3311080000000004 94.3210980000000063 95.3151090000000067 96.0219500000000039 96.5376430000000028 96.8645400000000052 96.9655840000000069 96.9528660000000002 96.6486050000000034 95.8777160000000066 94.8128889999999984 93.6987380000000059 92.1698760000000021 90.838318000000001 90.374724999999998 90.1027370000000047 90.0319899999999933 90.0519100000000066 90.1012039999999956 90.1572489999999931 90.2055210000000045 90.2848890000000068 90.6134950000000003 91.9937520000000006 93.6069949999999977 94.7407149999999945 95.6620939999999962 96.3506239999999963 96.9881819999999948 97.741698999999997 98.5360569999999996 99.2579350000000034 99.6236109999999968 99.5650710000000032 99.5204240000000055 99.8972550000000012 100.7509079999999955 101.4654390000000035 101.8902740000000051 102.1861650000000026 102.3265760000000029 102.4444430000000068 102.5085140000000052 102.5384829999999994 102.5010220000000061 102.3682479999999941 102.0378489999999
942 101.5453949999999992 101.0762629999999973 100.6554950000000019 100.4636919999999947 100.4281229999999994 100.1602859999999993 99.2407070000000004 98.4259639999999933 98.743858000000003 99.7232589999999988 101.0443879999999979 101.9760509999999982 102.3260350000000045 102.5611499999999978 102.7895740000000018 102.8598400000000055 102.8621140000000054 103.0736239999999952 103.3059539999999998 103.5556639999999931 103.7119600000000048 103.7813110000000023 103.7884829999999994 103.8600689999999958 103.8887710000000055 103.963561999999996 104.1360930000000025 104.0936739999999929 103.731262000000001 103.3028489999999948 102.7912139999999965 101.9917070000000052 101.2571410000000043 100.3348620000000011 99.1677549999999997 97.9857789999999937 96.5715100000000035 95.4685669999999931 94.7010190000000023 94.4007029999999929 94.4214860000000016 94.4620290000000011 94.6477890000000031 95.3731690000000043 96.4647140000000007 97.3397060000000067 98.306365999999997 99.4456710000000044
100.5092850000000055 101.4784389999999945 102.6711039999999997 103.8943179999999984 105.1656420000000054 106.3455579999999969 107.441047999999995 108.4564510000000013 109.4967419999999976 110.4882350000000031 111.2855990000000048 112.0337600000000009 112.6011809999999969 112.8769910000000039 112.967133000000004 112.8971410000000049 112.6639559999999989 112.4302600000000041 112.1860350000000039 112.0176239999999979 111.947936999999996 111.9462889999999931 111.8410339999999934 111.574860000000001 110.8916779999999989
+94.5411150000000049 95.4645229999999998 96.727562000000006 96.8306579999999997 95.4424360000000007 91.9041210000000035 88.4033660000000054 86.6149829999999952 86.231026 86.2034450000000021 86.209259000000003 86.2556380000000047 86.2603990000000067 86.231812000000005 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.228935000000007 86.2291720000000055 86.2294619999999981 86.2265620000000013 86.2084430000000026 86.1973500000000001 86.1984180000000038 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984860000000026 86.1997070000000036 86.1862409999999954 86.1961749999999967 86.
3680569999999932 86.6104279999999989 86.7280120000000068 86.4561839999999933 86.2386630000000025 86.2994609999999938 86.5456470000000024 86.8152620000000042 86.7624509999999987 86.6714860000000016 86.5670240000000035 86.5210110000000014 86.5091089999999951 86.3251499999999936 86.2259750000000054 86.2410349999999966 86.2634050000000059 86.2824480000000023 86.298523000000003 86.2967150000000061 86.3028790000000043 86.316047999999995 86.3155210000000039 86.3269580000000047 86.3285139999999984 86.3335270000000037 86.3446579999999955 86.3492810000000048 86.3573460000000068 86.3623809999999992 86.3560870000000023 86.3500290000000064 86.3483810000000034 86.3457489999999979 86.3474960000000067 86.3502960000000002 86.3516460000000023 86.3703380000000038 86.3904270000000025 86.4127199999999931 86.4117810000000048 86.412659000000005 86.4116290000000049 86.3343509999999981 86.5797040000000067 87.7307210000000026 88.0990599999999944 87.977019999999996 88.4160689999999931 89.3250199999999
95 90.3572620000000057 91.4121860000000055 92.6638719999999978 93.8463820000000055 94.7209849999999989 95.3181529999999952 95.9268260000000055 96.3349000000000046 96.4130250000000046 96.172393999999997 95.5939099999999939 94.8908080000000069 93.9707949999999954 92.6280289999999979 91.0564959999999957 90.5599519999999956 90.4928819999999945 90.1454470000000043 90.0349879999999985 90.0741579999999971 90.1319119999999998 90.185364000000007 90.236266999999998 90.3064880000000016 90.9349899999999991 92.4814680000000067 93.9925309999999996 95.0701370000000026 95.8054730000000063 96.3316800000000057 97.0207900000000052 97.751891999999998 98.4463420000000013 98.8049239999999998 98.8171080000000046 98.8579249999999945 99.217528999999999 99.8472370000000069 100.5689540000000051 100.9867859999999951 101.2271649999999994 101.4318080000000037 101.6282120000000049 101.7068710000000067 101.7005999999999943 101.7294770000000028 101.8076020000000028 101.7291340000000019 101.3226319999999987
100.7807770000000005 100.3540270000000021 99.9999080000000049 99.9046859999999981 99.8805849999999964 99.719703999999993 99.2550959999999947 98.4334180000000032 98.0856019999999944 98.7833329999999989 99.9422760000000068 100.9386439999999965 101.3862529999999964 101.7280350000000055 101.9894409999999993 101.9245679999999936 101.9087140000000034 102.1289369999999934 102.3624949999999956 102.6522980000000018 103.0614620000000059 103.2074130000000025 103.1982189999999946 103.3118520000000018 103.3534999999999968 103.3540270000000021 103.4702000000000055 103.4215319999999991 102.9743579999999952 102.4057619999999957 101.8737260000000049 101.1406630000000035 100.4614870000000053 99.635863999999998 98.6327969999999965 97.5580290000000048 96.1699299999999937 94.9991909999999962 94.099457000000001 93.9207609999999988 94.1104349999999954 94.4313889999999958 95.469939999999994 96.8879320000000064 97.8814320000000038 98.6825560000000053 99.6539609999999954 100.7584300000000042 101.6589
199999999948 102.4556199999999961 103.4251560000000012 104.6639250000000061 105.9253010000000046 107.0252150000000029 108.0681380000000047 109.0292819999999949 110.0195389999999946 111.0237960000000044 111.8056789999999978 112.5049130000000019 112.9359440000000063 112.9714050000000043 112.8443070000000006 112.6756740000000008 112.3899689999999936 112.0727459999999951 111.8014830000000046 111.6309360000000055 111.5596850000000018 111.5228649999999959 111.3710860000000054 111.1057590000000062 110.6460419999999942
+95.0088039999999978 95.6491390000000052 97.0763699999999972 97.6313399999999945 96.7227630000000005 93.5323029999999989 89.6334920000000039 86.9973449999999957 86.2044369999999986 86.2319179999999932 86.229377999999997 86.223906999999997 86.2240910000000014 86.2285229999999956 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2291179999999997 86.227997000000002 86.2260210000000029 86.2126310000000018 86.1968690000000066 86.1981509999999957 86.1985020000000048 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1983869999999968 86.2018429999999967 86.184357000
0000057 86.1854399999999998 86.250953999999993 86.5026550000000043 86.684905999999998 86.6580890000000039 86.3219760000000065 86.2133479999999963 86.4843290000000025 86.6176990000000018 86.5116960000000006 86.4147719999999993 86.475594000000001 86.4983900000000006 86.3811259999999947 86.2383269999999982 86.2288130000000024 86.2470399999999984 86.2679370000000034 86.2840120000000042 86.2845379999999977 86.2881770000000046 86.2989120000000014 86.3001170000000002 86.3110199999999992 86.3160629999999998 86.3217769999999973 86.3292469999999952 86.3413309999999967 86.347099 86.3443680000000029 86.3456500000000062 86.3477330000000052 86.3353960000000029 86.3251110000000068 86.3324889999999954 86.3469539999999967 86.3602750000000015 86.380188000000004 86.3853759999999937 86.4041519999999963 86.4223790000000065 86.438170999999997 86.4395899999999955 86.3983309999999989 86.4147109999999969 87.4222259999999949 87.922820999999999 87.5418319999999994 87.7881770000000046 88.46573600000000
68 89.5458529999999939 90.587104999999994 92.0307619999999957 93.3907169999999951 94.1777340000000009 94.7963179999999994 95.3752900000000068 95.7230220000000003 95.7567209999999989 95.2920459999999991 94.5875020000000006 93.992401000000001 93.2181929999999994 91.5812990000000013 90.2563250000000039 90.2121199999999988 90.2657619999999952 90.1109469999999959 90.0266419999999954 90.0780489999999929 90.1357500000000016 90.1899489999999986 90.2205199999999934 90.375938000000005 91.5230789999999956 93.0055310000000048 94.3106690000000043 95.3780359999999945 95.920258000000004 96.4391399999999948 97.1618799999999965 97.6943049999999999 97.9544219999999939 97.9533919999999938 98.0936360000000036 98.6246569999999991 99.1835860000000054 99.6214750000000038 99.9438480000000027 100.1974409999999978 100.4584430000000026 100.5881959999999964 100.7628250000000065 100.8802570000000003 100.8836210000000051 100.909790000000001 101.0492710000000045 101.0161590000000018 100.6295470000000023 1
00.0297850000000039 99.6157910000000015 99.2623059999999953 99.2486499999999978 99.4378659999999996 99.4587479999999999 99.0836330000000061 98.0931630000000041 97.6516270000000048 98.2378999999999962 98.9914320000000032 99.847014999999999 100.4669650000000019 100.8933109999999971 101.158141999999998 101.0299610000000001 101.041167999999999 101.2452009999999945 101.5036470000000008 101.8032989999999955 102.2273710000000051 102.4061200000000014 102.4683299999999946 102.5690000000000026 102.6185530000000057 102.743110999999999 102.9059519999999992 102.6988450000000057 102.1749949999999956 101.6213529999999992 100.9592899999999958 100.1607970000000023 99.4777980000000071 98.6089630000000028 97.6635359999999935 96.7557979999999986 95.5888520000000028 94.4183730000000025 93.7221980000000059 93.8642119999999949 94.2156750000000045 94.8517300000000034 96.2574840000000052 97.7438740000000053 98.7422789999999964 99.9383930000000049 101.0333480000000037 101.854179000000002 102.59642800
00000031 103.2908330000000063 103.9918059999999969 105.1823349999999948 106.5214079999999939 107.6644059999999996 108.7842940000000027 109.7225949999999983 110.6845399999999984 111.6813510000000065 112.3656459999999981 112.8730319999999949 113.1294099999999929 113.1177059999999983 112.8310850000000016 112.4653780000000012 112.0366290000000049 111.6248089999999991 111.3664780000000007 111.1627809999999954 111.0490879999999976 110.994101999999998 110.8253780000000006 110.5382689999999997 110.174042
+95.4345780000000019 95.9885409999999979 97.3970570000000038 98.5490719999999953 98.2169949999999972 95.6809080000000023 91.7906720000000007 87.9776990000000012 86.2513500000000022 86.229218000000003 86.2300869999999975 86.2295529999999957 86.2288740000000047 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289580000000058 86.2290040000000033 86.2305300000000017 86.2207030000000003 86.2081529999999958 86.1995620000000002 86.1977159999999998 86.1985320000000002 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1983570000000014 86.1998829
999999998 86.1956100000000021 86.1756210000000067 86.2265550000000047 86.4184190000000001 86.7327959999999933 86.5637889999999999 86.2729190000000017 86.2319559999999967 86.3704910000000012 86.4615710000000064 86.3841780000000057 86.2574999999999932 86.2642749999999978 86.2978669999999966 86.214020000000005 86.2066120000000069 86.2309340000000049 86.2521129999999943 86.2667009999999976 86.2703170000000057 86.2654950000000014 86.2744519999999966 86.2875899999999945 86.2951809999999995 86.3043820000000039 86.3147739999999999 86.3173599999999936 86.3256839999999954 86.3315429999999964 86.3290860000000038 86.328827000000004 86.330528000000001 86.3215409999999963 86.3163679999999971 86.3244169999999968 86.3447489999999931 86.3664250000000067 86.3833850000000041 86.3850709999999964 86.4041600000000045 86.422393999999997 86.4427869999999956 86.4456559999999996 86.463318000000001 86.4248500000000064 86.6198200000000043 86.955016999999998 87.1492999999999967 87.4160920000000061 87.81
90380000000062 88.6741260000000011 89.7755279999999942 91.4435730000000007 92.7092899999999958 93.4723970000000008 94.2261280000000028 94.7724610000000069 95.0025789999999972 94.8991170000000039 94.4330520000000035 93.8316420000000022 93.2489240000000024 92.4686970000000059 90.8612750000000062 89.965209999999999 90.0413209999999964 90.0651170000000008 90.0348209999999938 90.0100099999999941 90.0424500000000023 90.0778959999999955 90.1127319999999941 90.1110079999999982 90.6464079999999939 92.057495000000003 93.3031459999999981 94.6386030000000034 95.6350779999999929 96.1026990000000012 96.7086939999999942 97.1283109999999965 97.1561659999999989 97.0724950000000035 97.353233000000003 97.9181209999999993 98.4567949999999996 98.7906650000000042 99.0788730000000015 99.2716980000000007 99.4420470000000023 99.5394820000000067 99.6148759999999953 99.7798080000000027 99.878304 99.9260029999999944 99.9584200000000038 100.0571900000000056 100.0081480000000056 99.7959440000000058 99.24
25609999999949 98.7839890000000054 98.4219889999999964 98.4287800000000033 98.8155820000000062 99.0980610000000013 99.0095599999999934 98.1102910000000037 97.743378000000007 97.8734819999999957 98.0864109999999982 98.8379439999999931 99.5795750000000055 100.0254359999999991 100.4896619999999956 100.6640699999999953 100.7151180000000039 100.8138890000000032 101.0285949999999957 101.2371059999999972 101.5588529999999992 101.8576429999999959 102.0181050000000056 102.1097340000000031 102.148926000000003 102.3358920000000012 102.4221119999999985 101.9825670000000031 101.3776320000000055 100.8576510000000042 100.0196689999999933 99.0448460000000068 98.2584300000000042 97.3070299999999975 96.3705599999999976 95.567931999999999 94.8112179999999967 94.090485000000001 93.7464829999999978 94.0252080000000063 94.3758770000000027 95.1563869999999952 96.4441910000000036 97.7751690000000053 99.300690000000003 101.0065230000000014 102.2271649999999994 102.9849700000000041 103.61959799999999
63 104.1536710000000028 104.7567829999999987 105.7932509999999979 107.120757999999995 108.4373860000000036 109.6669849999999968 110.6367570000000029 111.5125579999999985 112.353675999999993 112.8820189999999997 113.2276920000000047 113.4321819999999974 113.3495249999999999 112.8382110000000011 112.2221679999999964 111.6590499999999935 111.217811999999995 110.8866040000000055 110.604645000000005 110.4111939999999947 110.3685679999999962 110.2321239999999989 109.9288789999999949 109.6150669999999963
+95.9301070000000067 96.3375929999999983 97.6639250000000061 99.119324000000006 99.3637920000000037 97.4633330000000058 93.7747269999999986 89.3862840000000034 86.5572659999999985 86.2325969999999984 86.2151570000000049 86.2225490000000008 86.2295299999999969 86.2290650000000056 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2290270000000021 86.2288439999999952 86.2298200000000037 86.2140660000000025 86.1957170000000019 86.1982119999999981 86.1985700000000037 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939
999999966 86.1984329999999943 86.2002410000000054 86.2373659999999944 86.3551410000000033 86.3654709999999994 86.3836210000000051 86.5439300000000031 86.5951160000000044 86.4028090000000049 86.3767780000000016 86.4018169999999941 86.3171310000000034 86.3471530000000058 86.3923719999999946 86.2924270000000035 86.2347869999999972 86.2341380000000015 86.2337799999999959 86.2393110000000007 86.2509309999999942 86.2560730000000007 86.2629320000000064 86.2711259999999953 86.2813869999999952 86.2909470000000027 86.2972790000000032 86.3088460000000026 86.3171920000000057 86.3152469999999994 86.3185730000000007 86.3192829999999987 86.3170470000000023 86.3181000000000012 86.3196030000000007 86.326744000000005 86.3455809999999957 86.3640440000000069 86.3826449999999966 86.3851549999999975 86.4042210000000068 86.4216459999999955 86.4416429999999991 86.4446259999999995 86.466431 86.4802320000000009 86.3729859999999974 86.4060209999999955 86.8025049999999965 87.237480000000005 87.74375200
00000006 88.0661769999999962 89.0912929999999932 90.5917969999999997 91.6967010000000045 92.5719380000000029 93.4312440000000066 94.0317840000000018 94.2634120000000024 94.0382390000000044 93.6213460000000026 93.1471180000000061 92.6049730000000011 91.6405869999999965 90.4648669999999981 90.0968019999999967 90.0825580000000059 90.0172199999999947 89.9995119999999957 90.0078809999999976 90.0071719999999971 90.0180210000000045 89.9754180000000048 90.0403060000000011 91.2473909999999933 92.5010220000000061 93.6541979999999938 95.0695419999999984 95.8426740000000024 96.3007350000000031 96.5457380000000001 96.3648830000000061 96.1973189999999931 96.4610059999999976 97.173523000000003 97.7127299999999934 97.9270020000000017 98.0873789999999985 98.3199460000000016 98.5165860000000038 98.6546550000000053 98.656677000000002 98.6350020000000001 98.7467649999999963 98.8645250000000004 98.8976820000000032 98.9406809999999979 98.9696040000000039 98.8184660000000008 98.625945999999999 98.
1837919999999968 97.7673029999999983 97.5201339999999988 97.6512989999999945 98.1866610000000009 98.5502089999999953 98.5296780000000041 97.9568710000000067 97.4400710000000032 97.1872099999999932 97.3322830000000039 97.8590769999999992 98.3974610000000069 98.7674410000000051 99.3853759999999937 99.9674760000000049 100.187256000000005 100.3349910000000023 100.5806350000000009 100.7339549999999946 101.0038219999999995 101.3807299999999998 101.5912929999999932 101.6753690000000034 101.7228850000000051 101.7661209999999983 101.6421509999999984 101.2531890000000061 100.6336289999999991 99.946990999999997 98.9421690000000069 97.8149339999999938 96.8793110000000013 96.005439999999993 95.2474289999999968 94.4856800000000021 94.0519180000000006 93.8931350000000009 93.8489229999999992 94.0739750000000043 94.3669589999999943 95.3081049999999976 96.6371379999999931 98.0745540000000062 99.9603199999999958 101.7548900000000032 103.1270219999999966 103.9871140000000054 104.563300999999995
6 105.0226140000000044 105.6439510000000013 106.5549850000000021 107.8442990000000066 109.2446979999999996 110.6035229999999956 111.5899509999999992 112.3164830000000052 112.9740910000000014 113.3723750000000052 113.6345440000000053 113.7442630000000037 113.431792999999999 112.7551420000000064 111.9714050000000043 111.3269499999999965 110.8500209999999981 110.4139559999999989 110.0824970000000036 109.7720719999999943 109.5953599999999994 109.4303210000000064 109.2056960000000032 108.9808199999999943
+96.4818729999999931 96.7374949999999956 98.0753250000000065 99.6667400000000043 100.2896269999999959 98.7116469999999993 95.6369710000000026 91.508018000000007 88.0714040000000011 86.5172500000000042 86.1393659999999954 86.1744079999999997 86.2372510000000005 86.2276920000000047 86.2290189999999939 86.2289580000000058 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289659999999998 86.2289810000000045 86.2295299999999969 86.225403 86.2141490000000061 86.2056579999999997 86.1978759999999937 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966
86.1984939999999966 86.1955640000000045 86.2472000000000065 86.3529209999999949 86.1906429999999943 86.3626560000000012 86.7536620000000056 86.8730160000000069 86.6596600000000024 86.4668960000000055 86.4578400000000045 86.4286799999999999 86.3896639999999962 86.4409030000000058 86.4891889999999961 86.4548719999999946 86.2747729999999962 86.2157289999999961 86.2284930000000003 86.2357939999999985 86.2459790000000055 86.2582859999999982 86.2581019999999938 86.2691959999999938 86.2853620000000063 86.2863540000000029 86.2931289999999933 86.3015369999999962 86.3016740000000055 86.3151550000000043 86.3195189999999997 86.3079680000000025 86.3102650000000011 86.3210069999999945 86.3265760000000029 86.345366999999996 86.3647160000000014 86.3833159999999936 86.3854829999999936 86.404869000000005 86.422118999999995 86.4397890000000046 86.4399870000000021 86.4480510000000066 86.4551390000000026 86.4705660000000051 86.4851460000000003 86.507355000000004 87.1791079999999994 88.263762999
9999973 88.0128940000000028 88.390197999999998 89.6565860000000043 90.816558999999998 91.739531999999997 92.6484300000000047 93.276061999999996 93.5427779999999984 93.3732600000000019 92.9360810000000015 92.3491439999999955 91.7309419999999989 90.820250999999999 90.1874849999999952 90.1247180000000014 90.0392530000000022 89.9849849999999947 89.9942319999999967 90.0102839999999986 90.0070570000000032 90.0117259999999959 89.8935089999999946 90.3419339999999949 91.8365100000000041 92.8668140000000051 94.2011179999999939 95.292396999999994 95.7259219999999971 95.8265760000000029 95.5087050000000062 95.3757319999999993 95.8416749999999951 96.4506839999999954 96.8946609999999993 97.0651929999999936 97.2432170000000013 97.4104690000000062 97.5608749999999958 97.6563189999999963 97.7323229999999938 97.7872619999999984 97.6424789999999945 97.6060939999999988 97.7740170000000006 97.795921000000007 97.7897420000000039 97.7335659999999962 97.6177899999999994 97.3642650000000032 96.96355
4000000002 96.6663060000000058 96.6289139999999946 97.0350949999999983 97.6679309999999958 97.9213409999999982 97.6227190000000036 97.0913160000000062 96.5526349999999951 96.4637759999999957 96.7337189999999936 97.0384219999999971 97.2126540000000006 97.4851299999999981 98.0104829999999936 98.6582870000000014 99.1397170000000045 99.5582349999999963 99.9306789999999978 100.1357650000000064 100.355591000000004 100.5991060000000061 100.8410190000000028 100.9435959999999994 100.9809419999999989 100.9700320000000033 100.7114490000000018 100.3964770000000044 99.8398210000000006 99.0293120000000044 97.9043730000000068 96.6359479999999991 95.6094740000000058 94.9705890000000039 94.5640489999999971 93.9965440000000001 93.5026249999999948 93.3548279999999977 93.6446459999999945 93.9082640000000026 94.2729719999999958 95.6274109999999951 97.2881619999999998 98.9442520000000059 100.669983000000002 102.2555160000000001 103.5927580000000034 104.5276410000000027 105.2219699999999989 105.74
40639999999945 106.3869250000000051 107.3039090000000044 108.6096569999999986 109.9537729999999982 111.2841640000000041 112.1513139999999993 112.8007429999999971 113.4286419999999964 113.799980000000005 113.9569699999999983 113.8594439999999963 113.3556980000000038 112.6065899999999971 111.7423320000000047 111.0429230000000018 110.4799730000000011 109.976768000000007 109.6130220000000008 109.2377469999999988 108.8431470000000019 108.5100939999999952 108.2514720000000068 107.9986569999999944
+96.8746950000000027 97.1390150000000006 98.6101989999999944 100.2368160000000046 101.1925430000000006 100.4146420000000006 98.2657319999999999 94.6402590000000004 91.1161270000000059 88.535736 87.1321329999999961 86.5419310000000053 86.2889940000000024 86.2159809999999993 86.2283019999999993 86.2289889999999986 86.2288740000000047 86.2287830000000071 86.2288360000000011 86.228943000000001 86.2290880000000044 86.227965999999995 86.2116390000000052 86.1980510000000066 86.1980290000000053 86.1985320000000002 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.198493999999996
6 86.1984939999999966 86.1989290000000068 86.1900329999999997 86.147705000000002 86.2778550000000024 86.6406860000000023 86.6099169999999958 86.420226999999997 86.4088899999999995 86.4253920000000022 86.3706360000000046 86.413841000000005 86.5739209999999986 86.472014999999999 86.4153519999999986 86.4652329999999978 86.312927000000002 86.1899190000000033 86.2237930000000006 86.2278589999999951 86.2286299999999954 86.2505040000000065 86.258018000000007 86.2593920000000054 86.2662579999999934 86.2767489999999952 86.2867580000000061 86.2850799999999936 86.289283999999995 86.2985610000000065 86.3027189999999962 86.2911529999999942 86.3070069999999987 86.3219299999999947 86.3267819999999944 86.3460460000000012 86.3643189999999947 86.3795779999999951 86.3848950000000002 86.4052510000000069 86.4146580000000029 86.4205549999999931 86.4201970000000017 86.4336780000000005 86.439384000000004 86.455016999999998 86.4722139999999939 86.4536590000000018 86.7551040000000029 87.6975170000000
048 88.0267029999999977 87.8205489999999998 89.041450999999995 90.2950519999999983 91.0737759999999952 91.9427259999999933 92.6024479999999954 92.8368380000000002 92.7560349999999971 92.2789080000000013 91.2876739999999955 90.5045319999999975 90.1990049999999997 90.0276570000000049 89.9722370000000069 89.9635999999999996 89.9725569999999948 89.9900130000000047 90.0094220000000007 90.011375000000001 89.9862899999999968 89.9431840000000022 90.8883440000000036 92.1797870000000046 93.1928790000000049 94.3754959999999983 94.801879999999997 94.7844850000000037 94.5185929999999956 94.5627589999999998 95.122681 96.0034559999999999 96.4551469999999966 96.4116439999999955 96.4381939999999958 96.6589280000000031 96.8027569999999997 96.8759000000000015 96.9032440000000008 96.8586959999999948 96.7901839999999964 96.6520459999999986 96.5482250000000022 96.6004489999999976 96.6434859999999958 96.5444870000000037 96.3444750000000028 96.3487850000000066 96.1641539999999964 95.815978999999998
7 95.7807540000000017 96.1169890000000038 96.6815639999999945 97.0972749999999962 97.1337889999999931 96.7694170000000042 96.0941540000000032 95.7799150000000026 95.8007199999999983 96.0060040000000043 96.4909820000000025 96.6682279999999992 96.8915250000000015 97.3102650000000011 97.8240810000000067 98.466423000000006 99.0742869999999982 99.4686360000000036 99.6542359999999974 99.7967450000000014 99.9557109999999938 100.2483600000000052 100.3947979999999944 100.4125140000000016 100.4633939999999939 100.1608729999999952 99.7037430000000029 99.0778430000000014 98.168526 96.9508359999999954 95.5615389999999962 94.6560360000000003 94.3408969999999982 94.2135090000000019 93.8740310000000022 93.1804350000000028 92.8150559999999984 93.2744519999999966 93.8875730000000033 94.8438569999999999 96.6793519999999944 98.4083480000000037 99.9287110000000069 101.3379750000000001 102.6140139999999974 103.6905979999999943 104.6756290000000007 105.5635680000000036 106.2683179999999936 107.025
8029999999962 108.0165020000000027 109.2821119999999979 110.4985960000000063 111.5715639999999951 112.3031689999999969 112.997398000000004 113.6301040000000029 113.9971469999999982 114.0545730000000049 113.7774809999999945 113.2093959999999981 112.4114759999999933 111.5271220000000056 110.8044199999999933 110.1348270000000014 109.5977780000000052 109.2245099999999951 108.8057479999999941 108.2751690000000053 107.7877809999999954 107.3042679999999933 106.7656400000000048
+97.4565429999999964 97.3660509999999988 98.7466579999999965 100.5898210000000006 101.958281999999997 102.2068249999999949 101.1556549999999959 98.3748250000000013 95.518028000000001 92.9696500000000015 90.7916110000000032 88.9725569999999948 87.2166820000000058 86.3468400000000003 86.2143169999999941 86.2312009999999987 86.2297209999999978 86.2305759999999992 86.2301479999999998 86.2291409999999985 86.2281720000000007 86.2156300000000044 86.1983869999999968 86.1981959999999958 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984
939999999966 86.1984939999999966 86.1984790000000061 86.1985399999999942 86.1841809999999953 86.2757110000000011 86.4319839999999999 86.2822110000000038 86.1365590000000054 86.1536409999999933 86.1788410000000056 86.1461720000000071 86.2745900000000034 86.5015340000000066 86.4833299999999952 86.4682690000000065 86.4033510000000007 86.2491679999999974 86.1878130000000056 86.2088549999999998 86.2260059999999982 86.2271350000000041 86.2328640000000064 86.242912000000004 86.2536240000000021 86.2565989999999942 86.2608259999999945 86.2716219999999936 86.2707900000000052 86.2838670000000008 86.2876509999999968 86.2879410000000036 86.288848999999999 86.3088910000000027 86.3211289999999991 86.3274689999999936 86.3453219999999959 86.3548279999999977 86.362671000000006 86.3769000000000062 86.3924260000000004 86.3902360000000016 86.3845440000000053 86.3996580000000023 86.4190439999999995 86.4241030000000023 86.4377669999999938 86.4564129999999977 86.4787670000000048 86.4111330000000066
86.5994029999999952 87.2157669999999996 87.289268000000007 88.2870329999999939 89.5663530000000065 90.4444579999999974 91.270354999999995 91.9693299999999994 92.1797260000000023 92.0118329999999958 91.2318649999999991 90.2702409999999986 89.9334340000000054 90.0086749999999967 90.012512000000001 89.9603649999999959 89.9579470000000043 89.9514080000000007 89.947417999999999 89.9674610000000001 89.9813610000000068 89.9215849999999932 90.1090010000000063 91.1474610000000069 92.2529449999999969 93.0927429999999987 93.4779740000000032 93.4517670000000038 93.4456409999999948 93.7293930000000017 94.4442599999999999 95.1158520000000038 95.6623610000000042 95.9495620000000002 95.9417339999999967 95.9708940000000013 96.063713000000007 96.1513900000000064 96.1231310000000008 96.1596219999999988 96.0697480000000041 95.7869340000000022 95.5856859999999955 95.5479809999999929 95.5975880000000018 95.6072690000000023 95.4323579999999936 95.1100009999999969 95.0744550000000004 94.9331439999
999986 94.8129430000000042 95.2984390000000019 95.9851910000000004 96.3690339999999992 96.4705730000000017 96.3057400000000001 95.8958740000000063 95.2701799999999963 95.1399770000000018 95.0574340000000007 95.288848999999999 95.9406659999999931 96.234886000000003 96.3541110000000032 96.6563869999999952 97.1395799999999952 97.9130549999999999 98.647278 98.9771499999999946 99.0546800000000047 99.1373829999999998 99.3598250000000007 99.714500000000001 99.8933109999999971 99.9377520000000032 99.963042999999999 99.646088000000006 99.1610409999999973 98.4324040000000053 97.3331069999999983 95.9937129999999996 94.6558610000000016 94.0402150000000034 93.9336090000000041 93.9018549999999976 93.6613770000000017 93.0571589999999986 92.7035060000000044 93.0181730000000044 94.1644670000000019 96.0804059999999964 98.1908190000000047 99.6492690000000039 100.8093340000000069 101.8898999999999972 102.8446730000000002 103.75779 104.7413789999999949 105.7521440000000013 106.6902010000000018 1
07.6658330000000063 108.7218019999999967 109.8532639999999958 110.9227829999999955 111.8180009999999953 112.4979249999999951 113.1731189999999998 113.7337189999999936 114.0150220000000019 113.9987110000000001 113.6131740000000008 112.9940409999999957 112.1422500000000042 111.3135910000000024 110.611694 109.8868939999999981 109.3401489999999967 108.9982150000000019 108.5345609999999965 107.8719329999999985 107.2341080000000062 106.6020890000000065 105.7738879999999995
+98.515381000000005 97.8222430000000003 98.6298290000000009 100.7497330000000062 102.6050570000000022 103.2901150000000001 103.1541899999999998 101.7924270000000035 100.0416409999999985 97.9408260000000013 95.4304499999999933 92.5352479999999957 89.1304700000000025 86.9749450000000053 86.3113560000000035 86.2660450000000054 86.2954330000000027 86.3448939999999965 86.3015749999999997 86.238701000000006 86.2135999999999996 86.1995320000000049 86.1979450000000043 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.19
84939999999966 86.1984939999999966 86.1984939999999966 86.1985090000000014 86.2005769999999956 86.1883619999999979 86.1665270000000021 86.1780320000000017 86.2028580000000062 86.2000429999999938 86.1980209999999971 86.2011569999999949 86.1882630000000063 86.1502150000000029 86.2363129999999956 86.4536820000000006 86.5148930000000007 86.2732539999999943 86.1859970000000004 86.199073999999996 86.206421000000006 86.2173609999999968 86.2266769999999951 86.2279209999999949 86.2361530000000016 86.2458570000000009 86.2560270000000031 86.2556079999999952 86.2583920000000006 86.266295999999997 86.2757189999999952 86.2861860000000007 86.2889399999999966 86.2974090000000018 86.3164830000000052 86.3227459999999951 86.328400000000002 86.338286999999994 86.3492970000000071 86.3575359999999961 86.3587650000000053 86.3542939999999959 86.3644939999999934 86.3873140000000035 86.3907389999999964 86.4069369999999992 86.416718000000003 86.4312060000000031 86.4503559999999993 86.4979479999999938
86.4776760000000024 86.4820629999999966 86.6500850000000042 87.313721000000001 88.6177289999999971 89.7945710000000048 90.684235000000001 91.320526000000001 91.6011280000000028 91.1516649999999942 89.9450760000000002 89.8711239999999947 90.1075900000000019 90.0837549999999965 90.1158980000000014 90.0948029999999989 90.1441959999999938 90.1351549999999975 90.080451999999994 90.1030580000000043 90.0977709999999945 90.057060000000007 90.3872379999999964 91.0725249999999988 91.7464750000000038 92.1081389999999942 92.066283999999996 92.375434999999996 93.0120320000000049 93.9094470000000001 94.462097 94.7431639999999931 95.008735999999999 95.261330000000001 95.4538649999999933 95.431365999999997 95.3698270000000008 95.3316350000000057 95.2720790000000051 95.2834930000000071 95.2212679999999949 94.8654709999999994 94.4730610000000013 94.4445500000000067 94.6659999999999968 94.6291810000000027 94.3632659999999959 93.9983370000000065 93.8999179999999996 93.8434220000000039 94.106789
0000000062 95.0133739999999989 95.6940160000000049 95.7881619999999998 95.7739640000000065 95.495757999999995 95.0333399999999955 94.6067429999999945 94.5100400000000036 94.4886779999999931 94.7963790000000017 95.3064040000000006 95.5089650000000034 95.4129489999999976 95.5182499999999948 95.9815830000000005 96.8335270000000037 97.7962189999999936 98.2323229999999938 98.2344510000000071 98.2339249999999993 98.5376509999999968 98.9312819999999959 99.0792239999999964 99.2348180000000042 99.2613680000000045 98.9061430000000001 98.4340289999999953 97.6495129999999989 96.4422679999999986 95.116462999999996 94.0331649999999968 93.6179499999999933 93.5310900000000061 93.5169369999999986 93.3284840000000031 92.8983460000000036 92.6280979999999943 92.9660570000000064 94.2893750000000068 96.3810200000000066 98.4752960000000002 99.9512480000000068 101.1478270000000066 102.136573999999996 103.0064619999999991 103.9919430000000062 105.0107189999999946 106.0673680000000019 107.07871199999
99959 108.1818999999999988 109.2498089999999991 110.2738109999999949 111.259003000000007 112.1183929999999975 112.7927629999999937 113.3738400000000013 113.833045999999996 114.019172999999995 113.8929059999999964 113.4403609999999958 112.7911610000000024 111.9041210000000035 111.1077959999999933 110.422302000000002 109.734618999999995 109.1374739999999974 108.7742839999999944 108.3417280000000034 107.5750890000000055 106.7414930000000055 106.0126110000000068 105.2122569999999939
+99.611725000000007 98.4046479999999946 98.7577739999999977 101.204314999999994 103.3293610000000058 104.0950469999999939 104.3184130000000067 104.0683750000000032 102.965217999999993 100.8467559999999992 97.9614030000000042 94.4927220000000005 90.7137830000000065 87.9691540000000032 86.7155300000000011 86.3388439999999946 86.3720780000000019 86.5431980000000038 86.4467010000000045 86.2862089999999995 86.2065889999999939 86.1930310000000048 86.198875000000001 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.198
4939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984479999999991 86.1987079999999963 86.1991270000000043 86.1991040000000055 86.1983869999999968 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.198607999999993 86.2007059999999967 86.1782070000000004 86.186119000000005 86.3231959999999958 86.2720640000000003 86.187531000000007 86.1983409999999992 86.1966319999999939 86.2010350000000045 86.2110749999999939 86.2226869999999934 86.2273409999999956 86.2295459999999991 86.2409130000000062 86.2398830000000061 86.2526780000000031 86.2577289999999977 86.2598880000000037 86.2684780000000018 86.280272999999994 86.2896649999999994 86.2982099999999974 86.300139999999999 86.3012389999999954 86.3238450000000057 86.3333590000000015 86.3285829999999947 86.3259510000000034 86.3312609999999978 86.3540189999999939 86.3605579999999975 86.3734050000000053 86.3896330000000034 86.3927539999999965 86.4098890000000068 86.4287340000000057 86.4697720000000061
86.5168230000000023 86.5668950000000024 86.5239109999999982 86.7782749999999936 87.6735529999999983 88.8007199999999983 89.9041210000000035 90.7200009999999963 90.9780580000000043 90.2877349999999979 88.9952470000000062 89.3506320000000045 89.2972720000000066 89.236030999999997 89.4890209999999939 89.6807100000000048 90.110564999999994 90.2873759999999947 90.3184130000000067 90.4516449999999992 90.4369350000000054 90.3618469999999974 90.4739000000000004 90.6038279999999929 90.8883969999999977 91.327690000000004 91.7240749999999991 92.4671780000000041 93.4038620000000037 94.0609970000000004 94.1561509999999942 94.2215350000000029 94.5055770000000024 94.7885509999999982 94.9530259999999942 94.9145429999999948 94.7156520000000057 94.5171890000000019 94.443207000000001 94.3397449999999935 94.2363200000000063 93.9617920000000026 93.5697329999999994 93.3220210000000066 93.4443360000000069 93.4227520000000027 93.1328280000000035 92.8414989999999989 92.7653580000000062 92.9280009999
999947 93.6423570000000041 94.5991360000000014 95.054901000000001 95.1359860000000026 95.0965960000000052 94.7553939999999955 94.3821870000000018 94.0997239999999948 93.9468459999999936 93.9730909999999966 94.3392410000000012 94.7526170000000008 94.8420179999999959 94.5553589999999957 94.4715419999999995 94.7896420000000006 95.5286789999999968 96.6395260000000036 97.3647380000000027 97.4369659999999982 97.4573440000000062 97.8554149999999936 98.197181999999998 98.2733149999999966 98.4846339999999998 98.5477450000000061 98.1519779999999997 97.4753800000000012 96.5278550000000024 95.3452910000000031 94.2614669999999961 93.4693529999999981 93.1666490000000067 93.1151579999999939 93.0938029999999941 92.8730390000000057 92.5180359999999951 92.4305269999999979 93.0459519999999998 94.2920610000000039 96.025825999999995 97.6232530000000054 99.0475919999999945 100.5645829999999989 101.916443000000001 103.0049589999999995 104.1514049999999969 105.2783660000000054 106.3684080000000023
107.4214249999999993 108.5241390000000052 109.5130159999999933 110.5234379999999987 111.5046690000000069 112.2896800000000042 112.9871440000000007 113.5287859999999966 113.8398969999999935 113.9409559999999999 113.7041629999999941 113.2486499999999978 112.5820080000000019 111.6497039999999998 110.9002459999999957 110.2528989999999993 109.5825650000000024 108.924194 108.4688720000000046 108.1056669999999968 107.3659739999999942 106.4085919999999987 105.4970629999999971 104.8602680000000049
+100.5423660000000012 98.884003000000007 99.2036509999999936 101.8030930000000041 103.9335710000000006 104.8581089999999989 105.250511000000003 105.3354640000000018 104.4661329999999992 101.9975429999999932 98.6067280000000039 95.0184330000000017 91.4854579999999942 88.8175959999999947 87.3010940000000062 86.6155470000000065 86.4672999999999945 86.6158980000000014 86.5521009999999933 86.3945619999999934 86.3145370000000014 86.2174990000000037 86.1920700000000011 86.1985629999999929 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.
1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984479999999991 86.1992800000000017 86.1980899999999934 86.1903149999999982 86.1939390000000003 86.1991960000000006 86.1984939999999966 86.1985549999999989 86.1982119999999981 86.1975400000000036 86.2055890000000034 86.2157210000000021 86.2258609999999948 86.2267460000000057 86.2272640000000052 86.2355500000000035 86.2454910000000012 86.255675999999994 86.2562479999999994 86.2634120000000024 86.2736280000000022 86.2679289999999952 86.2693409999999972 86.2907869999999946 86.3015520000000009 86.2978820000000013 86.2997969999999981 86.3136599999999987 86.3231119999999947 86.3289180000000016 86.3389820000000014 86.360077000000004 86.361937999999995 86.3777539999999959 86.3972320000000025 86.4165799999999962 86.442688000000
004 86.4789729999999963 86.549712999999997 86.6110759999999971 86.6579669999999993 86.875243999999995 87.444145000000006 88.7641749999999945 90.0716019999999986 90.2565079999999966 89.5990450000000038 88.4717940000000027 88.2967529999999954 87.9249499999999955 87.6486210000000057 87.7862630000000053 88.0133440000000036 88.3811110000000042 88.8336939999999942 89.3356249999999932 89.7960209999999961 89.9455030000000022 89.8947139999999933 89.9617920000000026 90.129058999999998 90.6063160000000067 91.3932800000000043 92.0931700000000006 92.7131349999999941 93.4516830000000027 93.7479710000000068 93.684387000000001 93.8239750000000043 94.140900000000002 94.3721919999999983 94.4690860000000043 94.3970180000000028 94.1758119999999934 93.9382319999999993 93.7551119999999969 93.5125500000000045 93.2738570000000067 93.021088000000006 92.6540370000000024 92.0908050000000031 91.9761890000000051 92.038062999999994 91.8436659999999989 91.7689129999999977 91.8219990000000053 92.1216280000
000012 92.9808960000000013 93.8172529999999938 94.2487179999999967 94.5689469999999943 94.6183929999999975 94.301636000000002 93.9106670000000037 93.646491999999995 93.4445950000000067 93.4568859999999972 93.8800200000000018 94.2623059999999953 94.2377469999999988 93.8773730000000057 93.7297059999999931 93.9389950000000056 94.5371630000000067 95.5419389999999993 96.3806919999999963 96.6855160000000069 97.0455089999999956 97.5520020000000017 97.7421420000000012 97.8104249999999951 97.8561550000000011 97.7630079999999992 97.2427440000000018 96.2793429999999972 95.258269999999996 94.2558590000000009 93.4201050000000066 92.8294530000000009 92.6428149999999988 92.6792530000000028 92.6244279999999947 92.3276819999999958 92.1407779999999974 92.3604739999999964 93.4054569999999984 95.3120190000000065 97.1701740000000029 98.0360409999999973 98.7584839999999957 99.9626849999999934 101.5323719999999952 102.9240259999999978 104.2025679999999994 105.4237210000000005 106.6043470000000042
107.7438960000000066 108.8137360000000058 109.7991329999999977 110.8058240000000012 111.7040559999999942 112.3547360000000026 113.0624389999999977 113.5682599999999951 113.7476580000000013 113.7559889999999996 113.4651570000000049 113.0108259999999945 112.244056999999998 111.2560730000000007 110.5905460000000033 110.0081710000000044 109.3622670000000028 108.7654720000000026 108.2719730000000027 107.9420089999999988 107.2449569999999994 106.230316000000002 105.1729579999999942 104.4759449999999958
+101.1513209999999958 99.3706669999999974 99.6858139999999935 102.1032560000000018 104.3121799999999979 105.499046000000007 106.0592800000000011 106.1269609999999943 105.2546310000000034 102.6849979999999931 99.0654140000000041 95.3400340000000028 91.974891999999997 89.4676900000000046 87.9281849999999991 87.0934830000000062 86.7872849999999971 86.8211210000000051 86.7146220000000056 86.5265880000000038 86.416877999999997 86.2612230000000011 86.1962130000000002 86.1979060000000032 86.1984860000000026 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1
984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1985020000000048 86.1973420000000061 86.1990810000000067 86.211151000000001 86.2103350000000006 86.2206039999999945 86.228240999999997 86.229218000000003 86.2399599999999964 86.2430800000000062 86.2406620000000004 86.2382889999999946 86.2394639999999981 86.2577969999999965 86.2721250000000026 86.2696150000000017 86.2687760000000026 86.2840730000000065 86.3031309999999934 86.3031919999999957 86.2954859999999968 86.3184739999999948 86.3348239999999976 86.3450239999999951 86.3647310000000061 86.3821329999999961 86.4022980000000018 86.4178919999999
948 86.4485930000000025 86.5167919999999953 86.5833509999999933 86.6028979999999962 86.6173019999999951 86.6669239999999945 87.4579159999999973 88.9225009999999969 89.411170999999996 89.0552749999999946 88.320098999999999 87.7052690000000013 87.3266370000000052 86.9889220000000023 86.874572999999998 86.9654620000000023 87.142280999999997 87.5484090000000066 88.1035770000000014 88.5605549999999937 88.8529589999999985 89.0401609999999977 89.4930039999999991 90.1601869999999934 90.7371980000000065 91.3375240000000019 91.8647459999999967 92.2990949999999941 92.8031459999999981 93.1479340000000064 93.2546459999999939 93.5142670000000038 93.8092120000000023 93.9557949999999948 94.0279079999999965 93.9292980000000028 93.6915130000000005 93.4961090000000041 93.2161030000000039 92.7853240000000028 92.3129040000000032 91.8745799999999946 91.408844000000002 90.8378299999999967 90.6164320000000032 90.7186739999999929 90.7639309999999995 90.9413909999999959 91.0516590000000008 91.2570950
000000067 91.9361880000000014 92.7535100000000057 93.4100420000000042 93.8761520000000047 94.0710140000000052 93.8782879999999977 93.4625630000000029 93.1898039999999952 92.9502260000000007 93.0205990000000043 93.4651790000000062 93.8161850000000044 93.7755580000000037 93.4469220000000007 93.4004750000000001 93.6729739999999964 94.1423649999999981 94.905815000000004 95.669983000000002 96.1651150000000001 96.8567659999999933 97.438170999999997 97.5296940000000063 97.6168590000000052 97.4702529999999996 97.1753460000000047 96.4187320000000057 95.2597200000000015 94.2133330000000058 93.346855000000005 92.7359309999999937 92.281281000000007 92.1580809999999957 92.2120129999999989 92.1383589999999941 91.905815000000004 91.8765719999999959 92.3771129999999943 94.3983230000000049 97.4737850000000066 99.2546229999999952 99.7635120000000057 99.9361420000000038 100.3039169999999984 101.5291979999999938 103.0222169999999977 104.3930129999999963 105.6882399999999933 106.8926699999999954
107.9967730000000046 109.042357999999993 110.136330000000001 111.1188889999999958 111.8337709999999987 112.3710329999999971 113.0005649999999946 113.4334180000000032 113.6294479999999965 113.5293879999999973 113.1902769999999947 112.6488800000000055 111.7876890000000003 110.8156199999999956 110.1647030000000029 109.6351389999999952 109.1036150000000049 108.5778200000000027 108.129478000000006 107.8153460000000052 107.1329120000000046 106.1442949999999996 105.0686039999999934 104.1367649999999969
+101.636841000000004 99.8703380000000038 100.0202409999999986 102.2295230000000004 104.6578370000000007 105.9669420000000031 106.5992049999999978 106.6363599999999963 105.5800930000000051 102.9876170000000002 99.3728100000000012 95.7085189999999955 92.5482709999999997 90.1870119999999957 88.6447299999999956 87.6410979999999995 87.2834849999999989 87.2420269999999931 87.048523000000003 86.7519300000000015 86.5076519999999931 86.3205719999999985 86.1903080000000017 86.1909409999999951 86.1986009999999965 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86
.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1985169999999954 86.1983409999999992 86.188477000000006 86.1786649999999952 86.1835329999999971 86.1947940000000017 86.2045360000000045 86.2146220000000056 86.2251660000000015 86.2286830000000037 86.2282100000000042 86.2283479999999969 86.2277909999999963 86.2295299999999969 86.2409210000000002 86.2414250000000067 86.2378230000000059 86.2503360000000043 86.2718660000000028 86.2726519999999937 86.2676699999999954 86.2752530000000064 86.2957080000000047 86.3146969999999953 86.3333659999999981 86.3496860000000055 86.3674550000000067 86.3873829999999998 86.406318999
9999963 86.4360279999999932 86.4894180000000006 86.5496600000000029 86.5882950000000022 86.6471099999999979 86.6641919999999999 86.7516399999999948 87.3416370000000057 87.9078370000000007 88.0708999999999946 88.1617509999999953 87.8181459999999987 87.3727039999999988 87.1840519999999941 87.269172999999995 87.4971689999999995 87.7029950000000014 87.8351669999999984 87.8099820000000051 87.9151839999999964 88.2344590000000011 88.5049360000000007 89.2349090000000018 90.0911640000000062 90.4535290000000032 90.7413250000000033 91.2704319999999996 91.7338259999999934 92.1677779999999984 92.6338420000000013 92.926636000000002 93.1766970000000043 93.4180829999999958 93.4870990000000006 93.5851140000000044 93.4393689999999992 93.0190659999999951 92.8700709999999958 92.5002900000000068 91.7517699999999934 90.9568330000000032 90.2535859999999985 89.8029169999999937 89.5619509999999934 89.4408109999999965 89.5623779999999954 89.8037489999999963 90.1028900000000021 90.2041169999999966 90.
366187999999994 90.9710390000000046 91.7451400000000064 92.4820179999999965 92.9970469999999949 93.2651209999999935 93.2127610000000004 92.8897549999999939 92.6193770000000001 92.389411999999993 92.5920639999999935 93.1174769999999938 93.3673019999999951 93.3369519999999966 93.1486890000000045 93.1866299999999939 93.5503230000000059 93.9943389999999965 94.7015690000000063 95.4694750000000028 96.0284350000000018 96.6793440000000004 97.1301650000000052 97.276771999999994 97.3521649999999994 97.2015229999999946 96.8471370000000036 95.9086230000000057 94.7128749999999968 93.4818729999999931 92.5792239999999964 92.1766130000000032 91.8181529999999952 91.7041090000000025 91.7369920000000008 91.7149890000000028 91.6838840000000062 91.9694439999999958 93.0729900000000043 95.8646700000000038 99.0130539999999968 100.3416519999999963 100.8652569999999997 101.1883930000000049 101.3014909999999986 101.9967419999999976 103.2297059999999931 104.5956879999999956 105.8741069999999951 107.002
7690000000007 108.0850449999999938 109.0979540000000014 110.1750260000000026 111.1649170000000026 111.8188320000000004 112.3770520000000062 112.892082000000002 113.2512820000000033 113.4541629999999941 113.2576219999999978 112.8513109999999955 112.1742940000000033 111.3072970000000055 110.3708340000000021 109.7551119999999969 109.3022919999999942 108.826508000000004 108.2789609999999954 107.8632740000000041 107.5604710000000068 106.9338230000000038 106.0734099999999955 105.082603000000006 104.0046459999999939
+102.2464370000000002 100.4363479999999953 100.3696439999999939 102.6492230000000063 105.0241170000000039 106.1623380000000054 106.8131259999999969 106.9342730000000046 105.9134059999999948 103.1338580000000036 99.4655000000000058 96.1136400000000037 93.3104859999999974 91.029358000000002 89.309203999999994 88.1810300000000069 87.7939910000000054 87.7347259999999949 87.5201639999999941 87.1398539999999997 86.6601490000000041 86.362647999999993 86.191558999999998 86.1838609999999932 86.1987299999999976 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.
1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984860000000026 86.1985169999999954 86.1992489999999947 86.1929169999999942 86.1700670000000031 86.1665420000000069 86.1705469999999991 86.1803890000000052 86.1900559999999984 86.200019999999995 86.2086410000000001 86.2177659999999975 86.2273480000000063 86.2290339999999986 86.2196809999999942 86.2106699999999933 86.2098919999999964 86.2148739999999947 86.2266390000000058 86.237679 86.2443470000000048 86.2391889999999961 86.2426679999999948 86.2621230000000025 86.2825389999999999 86.3012920000000037 86.3183209999999974 86.3350680000000068 86.3527909999999963 86.372681 86.3920750000000055 86.4198149999
999998 86.4614409999999936 86.5202790000000022 86.5561139999999938 86.6333390000000065 86.7360610000000065 86.7359620000000007 86.6531300000000044 86.8000949999999989 86.8521580000000029 87.1679380000000066 87.7641449999999992 87.847297999999995 87.6477969999999971 87.6915659999999946 87.6739350000000002 87.3917919999999953 87.2538990000000041 87.1514509999999945 87.273415 87.6313320000000004 88.0800780000000003 88.8107449999999972 89.363861 89.5546420000000012 89.8103100000000012 90.4496309999999966 91.2042849999999987 91.7960130000000021 92.1490330000000029 92.4489290000000068 92.7911830000000037 92.9539719999999932 92.9180369999999982 92.7706909999999993 92.3642269999999996 91.8395770000000056 91.5645449999999954 91.1376719999999949 90.2118380000000002 89.2570039999999949 88.5991590000000002 88.3170010000000048 88.369324000000006 88.452171000000007 88.6790699999999958 88.9219209999999975 89.2143630000000059 89.3776090000000067 89.585716000000005 90.2311399999999963 90.951
8510000000049 91.5999529999999993 92.1575009999999963 92.504051000000004 92.5399699999999967 92.2997739999999993 92.0670319999999975 91.8754650000000055 92.2348479999999995 92.8259280000000047 92.9162979999999976 92.8301469999999966 92.8017810000000054 92.9503169999999983 93.3525159999999943 93.9356769999999983 94.722022999999993 95.5042880000000025 96.0579989999999952 96.5031199999999956 96.7643970000000024 96.9469150000000042 96.9393230000000017 96.8500599999999991 96.4292679999999933 95.2893830000000008 94.0060730000000007 92.8117830000000055 92.0897520000000043 91.7154620000000023 91.397034000000005 91.2207640000000026 91.2086489999999941 91.4130860000000069 91.9282989999999955 93.2568739999999963 95.3062900000000042 97.6973880000000037 99.6577759999999984 100.6436389999999932 101.233153999999999 101.8674699999999973 102.258972 102.6470410000000015 103.4532549999999986 104.6947250000000054 105.8897089999999963 106.9466400000000021 108.0251769999999993 108.983504999999993
9 109.9843290000000025 110.9733509999999939 111.6791460000000029 112.3128360000000043 112.8008039999999994 113.111023000000003 113.2180560000000042 113.0207599999999957 112.5044400000000024 111.7220760000000013 110.8631359999999972 109.9336469999999935 109.3573910000000069 108.9284130000000062 108.4410249999999962 107.924042 107.5170209999999997 107.199744999999993 106.6453630000000032 105.880898000000002 104.9547199999999947 103.8559800000000024
+102.4149249999999967 100.8027270000000044 101.0963289999999972 103.4408190000000047 105.3155440000000027 106.2938919999999996 107.03904 107.3157879999999977 106.4224169999999958 103.7366640000000046 100.1937559999999934 97.0593489999999974 94.4257580000000019 92.1541979999999938 90.2248230000000007 88.8999940000000066 88.3583760000000069 88.1777950000000033 87.9934769999999986 87.6305919999999929 86.9592059999999947 86.5084690000000052 86.2395170000000064 86.1842649999999963 86.1985930000000025 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.198493
9999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1985320000000002 86.1995160000000027 86.1963039999999978 86.1867289999999997 86.1752850000000024 86.1672439999999966 86.1679610000000054 86.1681140000000028 86.1673049999999989 86.1765209999999939 86.1878279999999961 86.1947020000000066 86.2030259999999942 86.2142410000000012 86.2153930000000059 86.2033839999999998 86.1944660000000056 86.1842879999999951 86.2004550000000052 86.2157590000000056 86.2136079999999936 86.2103039999999936 86.2117080000000016 86.2287520000000001 86.2477800000000059 86.2678910000000059 86.286681999999999 86.303764000000001 86.3204960000000057 86.3381729999999976 86.3580860000000001 86.3767239999999958
86.3904419999999931 86.4304280000000063 86.4889370000000071 86.5355679999999978 86.621025000000003 86.6823650000000043 86.7117389999999943 86.7621379999999931 86.7582780000000042 86.4367450000000019 86.4462740000000025 87.4948959999999971 88.0847849999999966 87.7821579999999955 87.3809360000000055 87.0891189999999966 86.6904449999999969 86.4540559999999942 86.6547999999999945 86.776732999999993 87.0547559999999976 87.8388819999999981 88.1863330000000047 88.2057800000000043 88.3691249999999968 88.6427149999999955 89.2930450000000064 90.3285450000000054 91.1395190000000071 91.4883729999999957 91.7769009999999952 92.1193849999999941 92.1674880000000059 92.0224079999999987 91.5297159999999934 90.8580549999999931 90.3627170000000035 89.8928530000000023 89.2864990000000063 88.4526670000000053 87.7006229999999931 87.3864360000000033 87.3233110000000039 87.4413219999999995 87.5865629999999982 87.8226169999999939 88.1476590000000044 88.4860149999999948 88.590485000000001 88.692299000
0000055 89.4555210000000045 90.3090210000000013 90.9219209999999975 91.4299390000000045 91.8394930000000045 91.9614409999999936 91.8389430000000004 91.6970830000000063 91.6501389999999958 92.0264049999999969 92.5243679999999955 92.519165000000001 92.4518510000000049 92.5159680000000009 92.7938690000000008 93.2693629999999985 93.949066000000002 94.7103199999999958 95.4529270000000025 95.9804230000000018 96.2966459999999955 96.5145799999999952 96.6232219999999984 96.4796220000000062 96.333129999999997 95.8547970000000049 94.5619429999999994 93.0365369999999956 92.0348510000000033 91.5239870000000053 91.2068790000000007 91.0307080000000042 90.868354999999994 90.8774570000000068 91.5837169999999929 93.1509020000000021 95.6671599999999955 97.9075160000000011 99.3930890000000034 100.3077470000000062 100.8777539999999959 101.5087130000000002 102.2685390000000041 102.7960209999999961 103.1799390000000045 103.758301000000003 104.8524479999999954 105.9876170000000002 106.9220810000000
057 107.8732830000000007 108.7703249999999997 109.7694699999999983 110.7582929999999948 111.4995190000000065 112.1382140000000049 112.6096799999999973 112.8857880000000051 112.9655300000000011 112.7613910000000033 112.1722180000000009 111.3838039999999978 110.4813390000000055 109.5565409999999957 108.9128269999999929 108.4300539999999984 107.9813230000000033 107.5197299999999956 107.1136779999999931 106.7560119999999984 106.2552869999999956 105.5242609999999956 104.5760499999999951 103.5287859999999966
+102.1527710000000013 101.0971530000000058 102.0412520000000001 104.1756290000000007 105.6339420000000047 106.5666659999999979 107.3554689999999994 107.7018659999999954 106.9683459999999968 104.781493999999995 101.739104999999995 98.8394849999999963 96.1837840000000028 93.829314999999994 91.7328720000000004 90.0336989999999986 89.059235000000001 88.6161960000000022 88.3908619999999985 88.0960239999999999 87.4662399999999991 86.9093019999999967 86.3809810000000056 86.1927570000000003 86.1979979999999983 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86
.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984479999999991 86.1989209999999986 86.1983869999999968 86.1898419999999987 86.1798249999999939 86.1700519999999983 86.168327000000005 86.1680149999999969 86.1690600000000018 86.1663819999999987 86.1548920000000038 86.153412000000003 86.1526640000000015 86.1796719999999965 86.1873930000000001 86.1873779999999954 86.1987150000000071 86.1985779999999977 86.1860499999999945 86.1700440000000043 86.183441000000002 86.1846769999999935 86.1823729999999983 86.193366999999995 86.2010350000000045 86.2143099999999976 86.2331999999999965 86.2533339999999953 86.2721559999999954 86.2892609999999962 86.3059839999999951 86.323639 86.3434979999999968 86.3629379999999998 86.37
60910000000024 86.4023130000000066 86.4569549999999936 86.5164570000000026 86.5845719999999943 86.6306529999999952 86.6658630000000016 86.7378769999999975 86.7281109999999984 86.8572539999999975 87.3688810000000018 87.7517469999999946 87.5535579999999953 87.1608200000000011 86.8926850000000002 86.7825160000000011 86.623351999999997 86.3886260000000021 86.4517900000000026 86.4246059999999972 87.1537929999999932 88.6310880000000054 88.5832599999999957 88.4703059999999937 88.829773000000003 88.4934999999999974 88.290740999999997 88.9702680000000043 90.035979999999995 90.707183999999998 91.0196300000000065 91.1547240000000016 91.0203400000000045 90.6784820000000025 89.9943080000000037 89.2808610000000016 88.7660680000000042 88.3012619999999941 87.5683060000000069 86.9317779999999942 86.6773450000000025 86.6912540000000007 86.7575449999999933 86.8224560000000025 86.9241030000000023 87.0605850000000032 87.4207150000000013 87.8241349999999983 87.8835830000000016 87.8996889999999951
88.6480260000000015 89.5137629999999973 90.1242519999999985 90.6255419999999958 91.0887989999999945 91.3308940000000007 91.3967509999999947 91.3254699999999957 91.5142359999999968 91.9008939999999939 92.1509319999999974 92.1239089999999976 92.2211460000000045 92.3254089999999934 92.5936659999999989 93.1969449999999995 93.975639000000001 94.6748199999999969 95.3087919999999968 95.8353809999999982 96.1016919999999999 96.2435609999999997 96.2808459999999968 96.1229780000000034 95.9014659999999992 95.372681 93.7792890000000057 91.9617690000000039 91.063689999999994 90.6066509999999994 90.5720210000000066 90.7585909999999956 90.9653550000000024 91.3821870000000018 92.5684660000000008 94.8023220000000038 97.2435150000000021 98.8786240000000021 99.892760999999993 100.6095729999999975 101.1440730000000059 101.8100890000000049 102.4899750000000012 103.0388949999999966 103.4927979999999934 104.1045680000000004 105.0418169999999947 106.0230480000000028 106.8059010000000058 107.5946430
000000049 108.4798360000000059 109.4819030000000026 110.4542309999999929 111.2316509999999994 111.8820419999999984 112.2789760000000001 112.5 112.5798649999999981 112.332183999999998 111.8217240000000032 111.0677950000000038 110.1065140000000042 109.1782989999999955 108.4737400000000065 107.9709469999999953 107.5604479999999938 107.0771639999999962 106.6328050000000047 106.2922740000000061 105.8157120000000049 105.0136260000000021 103.9886779999999931 103.1346209999999957
+102.1535489999999982 101.6833720000000056 102.9257130000000018 104.6773220000000038 106.0497210000000052 106.9342579999999998 107.6598819999999961 107.9786380000000037 107.5812909999999931 106.0013430000000056 103.4207310000000035 100.7603529999999949 98.154601999999997 95.7113420000000019 93.590880999999996 91.5527649999999937 90.0150299999999959 89.1374739999999974 88.7043299999999988 88.6352389999999986 88.3677899999999994 87.5303650000000033 86.4925989999999985 86.1787800000000033 86.1983259999999945 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966
86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984329999999943 86.1987380000000059 86.2002939999999995 86.1934739999999948 86.1830520000000035 86.1724090000000018 86.1681520000000063 86.1679380000000066 86.1684190000000001 86.1682210000000026 86.1598280000000045 86.1498789999999985 86.1398089999999996 86.1383819999999929 86.1391909999999967 86.1504589999999979 86.1562650000000048 86.1735379999999935 86.186829000000003 86.1844480000000033 86.1723250000000007 86.1655650000000009 86.154326999999995 86.1507419999999939 86.1618040000000036 86.1833419999999961 86.1869130000000041 86.1996079999999978 86.2186659999999989 86.2387240000000048 86.2576219999999978 86.2745440000000059 86.2922059999999931 86.3102039999999988 86.3299640000000039 86.3492970
000000071 86.3641590000000008 86.3872989999999987 86.430419999999998 86.4876560000000012 86.5562670000000054 86.6057359999999932 86.6511610000000019 86.6295319999999975 86.8816379999999953 87.645820999999998 87.9812770000000057 87.5082400000000007 86.9273610000000048 86.7790760000000034 86.8464510000000018 86.8518140000000045 86.7951809999999995 86.6127170000000035 86.4606399999999979 86.5458909999999975 87.4128340000000037 88.5806270000000069 88.6882630000000063 88.8907849999999939 89.4428099999999944 89.3828890000000058 89.0446089999999941 88.6296229999999952 88.8017119999999949 89.6491999999999933 90.0065079999999966 89.9178540000000055 89.6396100000000047 89.1010969999999958 88.4270549999999957 87.8695220000000035 87.2145919999999961 86.6644129999999961 86.2820590000000038 86.0421220000000062 86.08596 86.3279339999999991 86.3887789999999995 86.3773419999999987 86.4853059999999942 86.6198200000000043 86.8632280000000065 87.1908420000000035 87.3614730000000037 87.303100999
9999981 87.8656309999999934 88.7601319999999987 89.2970499999999987 89.7171479999999946 90.169556 90.5770490000000024 90.7618480000000005 90.6414639999999991 90.9998470000000026 91.6281280000000038 91.835731999999993 91.7910389999999978 91.819823999999997 91.9185559999999953 92.2665480000000002 93.0192640000000068 93.9450230000000062 94.6296839999999975 95.184196 95.6985240000000061 95.8822399999999959 95.8529280000000057 95.8544619999999981 95.7866290000000049 95.6338200000000001 94.7333220000000011 92.5433120000000002 90.5989229999999992 90.0183719999999994 90.0631180000000029 90.3929980000000057 90.824309999999997 91.4425200000000018 92.3663180000000068 93.7703630000000032 95.6807560000000024 97.4274599999999964 98.799469000000002 99.8087009999999992 100.5869139999999931 101.3064799999999934 102.0462950000000006 102.6747890000000041 103.1927259999999933 103.6269070000000028 104.2772219999999948 105.0514759999999939 105.8133320000000026 106.4269709999999947 107.10547599999
99959 108.1121289999999959 109.1351700000000022 110.0504609999999985 110.8191989999999976 111.4347609999999946 111.8495249999999999 112.0774770000000018 112.1284639999999939 111.8879699999999957 111.4141309999999976 110.6032260000000065 109.6525960000000026 108.7162320000000051 108.0013430000000056 107.4625929999999983 107.0663219999999995 106.5940930000000009 106.1601330000000019 105.8857419999999934 105.4442599999999999 104.4616319999999945 103.3053890000000052 102.6962050000000062
+102.4852599999999967 102.4503399999999971 103.8206710000000044 105.2870479999999986 106.5706480000000056 107.3647160000000014 107.9795069999999981 108.277946 108.0464779999999934 106.9866329999999977 104.8874590000000069 102.4169389999999993 100.0894169999999974 97.9954680000000025 95.9633409999999998 93.5625840000000011 91.2632600000000025 89.6562119999999965 89.1954350000000034 89.7433929999999975 89.949150000000003 88.6330569999999938 86.7905580000000043 86.1068649999999991 86.1893689999999992 86.2026209999999935 86.200958 86.1980360000000019 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.19849399999999
66 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1986160000000012 86.2002180000000067 86.1975860000000011 86.188873000000001 86.1769639999999981 86.1684340000000049 86.168059999999997 86.1680680000000052 86.169951999999995 86.1637039999999956 86.1532440000000008 86.1423800000000028 86.1377109999999959 86.1374440000000021 86.1378710000000041 86.1376190000000008 86.1280589999999933 86.1394810000000035 86.155036999999993 86.1611019999999996 86.1707150000000013 86.1688539999999961 86.1543810000000008 86.1390459999999933 86.1382289999999955 86.149597 86.1587520000000069 86.1684110000000061 86.1875459999999975 86.2049480000000017 86.2268600000000021 86.2454529999999977 86.2642139999999955 86.2735519999999951 86.2894210000000044 86.3096769999999935 86.3291399999999953 86.3464129999999983
86.3677519999999959 86.3887249999999938 86.4442439999999976 86.5262149999999934 86.5907820000000044 86.6419530000000009 86.924225000000007 87.6202770000000015 87.787871999999993 87.2740330000000029 86.8873370000000023 86.7963409999999982 86.8104859999999974 86.8089899999999943 86.8109970000000004 86.8237919999999974 86.804481999999993 86.7496029999999934 86.8845290000000006 87.2508009999999956 87.5037540000000007 87.846069 88.2808760000000063 88.754326000000006 89.2924270000000035 89.720673000000005 89.5025859999999938 88.8348160000000036 88.750953999999993 88.7547229999999985 88.4338300000000004 87.9529189999999943 87.4914859999999948 87.118187000000006 86.6796800000000047 86.1521529999999984 85.8069919999999939 85.7824779999999976 85.8020479999999992 85.8332599999999957 85.9551539999999932 85.9874729999999943 86.0352859999999993 86.1851879999999966 86.3396070000000009 86.4928670000000039 86.7262419999999992 86.9900130000000047 86.908653000000001 87.3822480000000041 88.1359
329999999943 88.4934159999999963 88.9300230000000056 89.3969189999999969 89.844268999999997 90.0043720000000036 89.905036999999993 90.3531569999999959 91.124992000000006 91.5106660000000005 91.4583740000000063 91.2387470000000036 91.3149109999999951 91.8406679999999938 92.7427749999999946 93.8411789999999968 94.5943759999999969 95.0857850000000013 95.5263439999999946 95.6229859999999974 95.4196699999999964 95.4059450000000027 95.4866489999999999 95.3875890000000055 93.8817290000000071 91.2141490000000061 89.6513599999999968 89.6703569999999957 90.2318269999999956 90.6736910000000051 91.1264879999999948 91.835999000000001 92.934227000000007 94.436042999999998 95.9027399999999943 97.4206920000000025 98.8335950000000025 99.8291550000000001 100.5152889999999957 101.2000890000000055 102.0140379999999993 102.6299669999999935 103.1148759999999953 103.6159059999999954 104.176117000000005 104.7525710000000032 105.3852920000000069 105.8567579999999992 106.5605549999999937 107.65535699
99999951 108.755195999999998 109.7155989999999974 110.4174799999999976 110.952849999999998 111.4982990000000029 111.8041000000000054 111.8389130000000051 111.5351490000000041 110.9597550000000012 110.1118929999999949 109.1601869999999934 108.152191000000002 107.4824600000000032 106.9096370000000036 106.4901279999999986 106.1227489999999989 105.7466660000000047 105.4646450000000044 105.0688549999999992 104.0196990000000028 102.8661579999999987 102.352965999999995
+102.9650419999999968 103.353240999999997 104.685608000000002 105.9951169999999934 107.0793079999999975 107.8101199999999977 108.4025270000000063 108.6244200000000006 108.3744279999999947 107.6049189999999953 106.0641940000000005 103.9643480000000011 102.0897599999999983 100.4868320000000068 98.3905790000000025 95.5487439999999992 92.4380649999999946 90.209266999999997 90.0720369999999946 91.3628620000000069 92.0227660000000043 90.4004589999999979 87.8237689999999986 86.3348390000000023 86.0750579999999985 86.1277769999999947 86.1704479999999933 86.2036820000000006 86.1985700000000037 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.198493999999996
6 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984099999999955 86.1993480000000005 86.1993640000000028 86.1917650000000037 86.1818700000000035 86.1713179999999994 86.1686399999999963 86.1677629999999937 86.1696620000000024 86.1674650000000071 86.1590190000000007 86.1473390000000023 86.1381910000000062 86.1375960000000021 86.1375270000000057 86.1395799999999952 86.1338959999999929 86.1231460000000055 86.1123580000000004 86.1195069999999987 86.1275020000000069 86.1479420000000005 86.1607819999999975 86.1548159999999967 86.1414110000000051 86.1355590000000007 86.1245119999999957 86.1261520000000047 86.1294170000000037 86.1526790000000062 86.1696699999999964 86.1887820000000033 86.1998750000000058 86.2198329999999942 86.2384030000000052 86.2489850000000047 86.2552110000000027 86.2747959999999949 86.2931
980000000038 86.303016999999997 86.3214490000000012 86.3316039999999987 86.3753279999999961 86.454741999999996 86.4898299999999978 86.9453579999999988 87.852287000000004 87.898467999999994 87.0901870000000002 86.7164149999999978 86.7443770000000001 86.7636719999999997 86.7519530000000003 86.751891999999998 86.7493900000000053 86.7536159999999938 86.7850490000000008 86.7794949999999972 86.8521800000000042 87.1471860000000049 87.4839939999999956 87.8031919999999957 88.1334149999999994 88.5150830000000042 88.8625339999999966 89.2351069999999993 89.6938549999999992 89.6465149999999937 89.2864229999999992 89.085883999999993 88.8682100000000048 87.9500050000000044 86.6247939999999943 86.1099700000000041 85.9289019999999937 85.7991260000000011 85.8133849999999967 85.8342289999999934 85.8323440000000062 85.8312909999999931 85.8131479999999982 85.8157120000000049 85.882598999999999 85.9348140000000029 86.0932159999999982 86.3200379999999967 86.4247819999999933 86.5797579999999982 86.
6636120000000005 86.9567030000000045 87.3413160000000062 87.6223219999999969 88.112480000000005 88.7494659999999982 89.2947999999999951 89.4322279999999949 89.3865890000000007 89.8022229999999979 90.4843520000000012 90.9382779999999968 91.0080949999999973 90.858672999999996 90.918610000000001 91.400351999999998 92.3508450000000067 93.6515809999999931 94.5217739999999935 94.9483570000000014 95.3135220000000061 95.35154 95.1076659999999947 95.0596850000000018 95.1382449999999977 94.9738540000000029 93.320801000000003 90.5567779999999942 89.3567120000000017 89.7560809999999947 90.3728710000000035 90.7614439999999973 91.2357329999999962 92.0053630000000027 93.1945719999999937 94.5516510000000068 95.9439619999999991 97.4305880000000002 98.737755000000007 99.6355130000000031 100.319344000000001 100.9834139999999962 101.6712189999999936 102.2542040000000014 102.8157120000000049 103.3643880000000053 103.84375 104.1925659999999993 104.7118990000000025 105.3334579999999931 106.2158660
000000054 107.2804339999999996 108.4113009999999946 109.4178849999999983 110.0788569999999993 110.6512069999999994 111.2247469999999936 111.5754320000000064 111.6506810000000058 111.1656569999999959 110.3997729999999962 109.6257480000000015 108.6969449999999995 107.6226120000000037 106.9843290000000025 106.4394839999999931 105.9336930000000052 105.6174929999999961 105.2711560000000048 105.0354229999999944 104.6463700000000046 103.6565549999999973 102.6370469999999955 102.1109849999999994
+103.5325160000000011 104.3796389999999974 105.5148389999999949 106.5830760000000055 107.5036539999999974 108.2260359999999935 108.7716599999999971 108.9127430000000061 108.7043759999999963 108.0227280000000007 106.8866730000000018 105.3103490000000022 103.8177409999999981 102.2927930000000032 99.8891220000000004 96.591148000000004 93.108397999999994 90.7808990000000051 90.9984280000000041 92.8090210000000013 94.1831049999999976 92.8993150000000014 90.1533359999999959 87.7964709999999968 86.5117340000000041 86.178719000000001 86.1654429999999962 86.1675029999999964 86.2039639999999991 86.1998140000000035 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.198493999999996
6 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.198395000000005 86.1988910000000033 86.200806 86.1946640000000031 86.1850280000000026 86.1738050000000015 86.1688230000000033 86.1676559999999938 86.1686710000000033 86.1691129999999958 86.1616590000000002 86.1518939999999986 86.1412200000000041 86.138274999999993 86.1372219999999942 86.1391299999999944 86.1372989999999987 86.1291279999999944 86.1176609999999982 86.1079639999999955 86.1072460000000035 86.1071089999999941 86.115273000000002 86.1302639999999968 86.127159000000006 86.136139 86.1400299999999959 86.1218029999999999 86.1101149999999933 86.1013339999999943 86.0937349999999952 86.1101989999999944 86.1251369999999952 86.1501849999999934 86.1459349999999944 86.1681209999999993 86.1863400000000013 86.2068019999999962 86.2062150000000003 86.2243579999999952 86.2414859999999948 86.23906700
00000057 86.2614820000000009 86.2749100000000055 86.3141940000000005 86.2988589999999931 86.5971830000000011 87.6688769999999948 88.0725560000000058 87.1767880000000019 86.6723790000000065 86.6724399999999946 86.6965940000000046 86.6898120000000034 86.6777270000000044 86.6776200000000046 86.6764069999999975 86.6936489999999935 86.7235340000000008 86.7042619999999999 86.8140790000000067 87.1375579999999985 87.474449000000007 87.7932890000000015 88.1302570000000003 88.5241010000000017 88.8859020000000015 89.2179639999999949 89.5011829999999975 89.7254259999999988 89.8930509999999998 89.9126890000000003 89.1407319999999999 87.492125999999999 86.1318279999999987 85.757087999999996 85.8401340000000062 85.8329619999999949 85.8342209999999994 85.8273539999999997 85.8152620000000042 85.8170700000000011 85.817229999999995 85.8144839999999931 85.8062970000000007 85.780738999999997 85.856269999999995 86.0881580000000071 86.2063830000000024 86.2823489999999964 86.4939880000000016 86.597
3740000000021 86.8202359999999942 87.2374039999999979 87.5796509999999984 87.9816059999999993 88.5183870000000042 88.7733230000000049 88.8814390000000003 89.1930080000000061 89.789032000000006 90.3665079999999961 90.5686189999999982 90.5795750000000055 90.684387000000001 91.0609440000000063 92.0411450000000002 93.3035430000000048 93.9881210000000067 94.2431950000000001 94.5241390000000052 94.7314379999999971 94.7400130000000047 94.6687469999999962 94.6309810000000056 94.4097289999999987 92.9240879999999976 90.395629999999997 89.2427519999999959 89.6333769999999959 90.2298360000000059 90.6402360000000016 91.069855000000004 91.9242629999999963 93.2883759999999995 94.5739059999999938 95.8602290000000039 97.3209460000000064 98.4708020000000062 99.2628169999999983 99.9790339999999986 100.6415250000000015 101.2585830000000016 101.9205699999999979 102.3644029999999958 102.7285609999999991 103.0789029999999968 103.3521960000000064 103.9227369999999979 104.8499300000000005 105.944282
9999999987 107.0243909999999943 108.0997310000000056 109.0361019999999996 109.7652510000000063 110.4169160000000005 110.8783870000000036 111.2314680000000067 111.3183819999999997 110.685364000000007 109.8755040000000065 109.1001969999999943 108.1991579999999971 107.0567700000000002 106.3118900000000053 105.8408050000000031 105.3376460000000066 105.042113999999998 104.7909850000000063 104.5817109999999985 104.1650850000000048 103.2611770000000035 102.321479999999994 101.7350540000000052
+104.1590039999999959 105.3273389999999949 106.3384020000000021 107.2006910000000062 108.0055619999999976 108.6670840000000027 109.1533129999999971 109.289000999999999 109.0614470000000011 108.4285959999999989 107.4406359999999978 106.2691039999999987 104.9814829999999972 103.2471850000000018 100.5460970000000032 96.731505999999996 93.2208789999999965 91.2878110000000049 91.7768630000000059 93.9960480000000018 96.1925509999999946 96.1108250000000055 93.9612730000000056 90.9958720000000056 88.4123079999999959 87.0495829999999984 86.2476429999999965 86.0395280000000042 86.1110840000000053 86.1976010000000059 86.2023769999999985 86.1979060000000032 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999
966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984860000000026 86.1986689999999953 86.2005999999999943 86.198395000000005 86.1905749999999955 86.1782680000000028 86.1691820000000064 86.1678619999999995 86.1679079999999971 86.1703949999999992 86.1647569999999945 86.1551440000000071 86.1437449999999956 86.1383670000000023 86.1371379999999931 86.1381149999999991 86.1388319999999936 86.1315539999999942 86.1219020000000057 86.1111219999999946 86.1078949999999992 86.1066890000000029 86.1085740000000044 86.1069870000000037 86.0971830000000011 86.0947800000000001 86.1041639999999973 86.1273039999999952 86.1257779999999968 86.1104890000000012 86.1064070000000044 86.0829240000000055 86.0762629999999973 86.0654909999999944 86.0687180000000041 86.0857620000000026 86.0937880000000035 86.1154329999999959 86.1253590000000031 86.1481399999999979 86.1456529999999958 86.1633219999999937 86.183
7459999999993 86.1906740000000013 86.2046739999999971 86.2255480000000034 86.2093809999999934 86.5203170000000057 87.5538789999999949 88.0840000000000032 87.2919770000000028 86.6376879999999971 86.6164169999999984 86.620514 86.6237179999999967 86.6188350000000042 86.6047059999999931 86.6045150000000064 86.6032710000000066 86.6288760000000053 86.6558760000000063 86.6385960000000068 86.7803729999999973 87.1188810000000018 87.4523389999999949 87.7710950000000025 88.1101380000000063 88.4903869999999984 88.8589779999999934 89.187927000000002 89.3814469999999943 89.4986569999999944 89.5916210000000035 88.8156740000000013 87.0504760000000033 85.8790970000000016 85.8049769999999938 85.8313140000000061 85.8328319999999962 85.8327259999999939 85.8337630000000047 85.8298489999999958 85.8071290000000033 85.8019180000000006 85.8022310000000061 85.8021999999999991 85.8021999999999991 85.8023989999999941 85.800255000000007 85.8223109999999991 85.9550780000000003 86.0918810000000008 86.3425
830000000047 86.4328689999999966 86.6326289999999943 87.0571060000000045 87.3005519999999962 87.4733350000000058 87.7929309999999958 88.1059879999999964 88.3734440000000063 88.5654909999999944 89.0737529999999964 89.8602070000000026 90.1826709999999991 90.223747000000003 90.4239120000000014 90.8311539999999979 91.7440869999999933 92.5497210000000052 92.7589650000000034 92.814659000000006 93.054901000000001 93.565612999999999 93.9636840000000007 93.9992680000000007 94.0586780000000005 93.7781140000000022 92.3225400000000036 90.0912019999999956 89.0958789999999965 89.4598309999999941 90.0069430000000068 90.4060439999999943 90.8116229999999973 91.7246549999999985 93.1669009999999957 94.6009059999999948 95.751884000000004 96.9985279999999932 98.0207520000000017 98.8040469999999971 99.5269930000000045 100.1891250000000042 100.8770449999999954 101.4318999999999988 101.5433120000000002 101.7307660000000027 102.0260999999999996 102.5081789999999984 103.5017699999999934 104.590614000
0000022 105.7689969999999988 106.8612370000000027 107.845673000000005 108.7527469999999994 109.5359499999999997 110.1923680000000019 110.624481000000003 110.8707959999999986 110.7669070000000033 110.1629259999999988 109.4736630000000019 108.6237260000000049 107.6653369999999938 106.4470900000000029 105.6580510000000004 105.2463379999999944 104.8550189999999986 104.6161349999999999 104.4005889999999965 104.0467909999999989 103.4896770000000004 102.7046430000000043 101.8212130000000002 101.1814190000000053
+104.986969000000002 106.207886000000002 107.1582259999999991 107.9341890000000035 108.6401749999999993 109.1882250000000028 109.6210329999999971 109.7659299999999973 109.5038219999999995 108.8455510000000004 107.7954790000000003 106.703834999999998 105.356102000000007 103.3077849999999955 100.3035129999999953 96.3665699999999958 93.1083069999999964 91.7634350000000012 92.701240999999996 95.2881320000000045 97.9890139999999974 99.0885470000000055 97.8834760000000017 95.0496669999999995 92.1716770000000025 90.1130519999999962 88.2654339999999991 86.9473270000000014 86.185333 86.0614850000000047 86.1425700000000063 86.2063059999999979 86.2000890000000055 86.1983180000000004 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.198493
9999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1985860000000059 86.1992489999999947 86.1937709999999981 86.1835399999999936 86.172386000000003 86.1687239999999974 86.1675110000000046 86.1705549999999931 86.1688160000000067 86.1607740000000035 86.1486129999999974 86.1389309999999995 86.137352000000007 86.1376269999999948 86.1404880000000048 86.1353759999999937 86.1252369999999985 86.1137080000000026 86.1079330000000027 86.1065219999999982 86.1082609999999988 86.1091229999999968 86.1017149999999987 86.0919489999999996 86.0803449999999941 86.0769810000000035 86.0905300000000011 86.1022719999999993 86.1079859999999968 86.1085889999999949 86.0906980000000033 86.078093999999993 86.0682220000000058 86.0487750000000062 86.0446319999999929 86.0320660000000004 86.0470959999999963 86.0595019999999948 86.0612560000000002 86.0869979999999941 86.093047999999996 86.1120910000000066 86.1238780000000048 86
.1450959999999952 86.1601490000000041 86.1157989999999955 86.1094889999999964 87.3135829999999942 88.2667390000000012 87.3718640000000022 86.5559310000000011 86.5179980000000057 86.5625 86.5464630000000028 86.5454790000000003 86.5330349999999981 86.5318680000000029 86.5312270000000012 86.542548999999994 86.5674900000000065 86.5841290000000043 86.5861739999999998 86.7441859999999991 87.0994950000000046 87.4293590000000052 87.7482830000000007 88.0866390000000052 88.4671780000000041 88.8332139999999981 89.0863879999999995 89.2490920000000045 89.3900220000000019 88.5855410000000063 86.8328929999999986 85.8274459999999948 85.7749400000000009 85.8329470000000043 85.8328699999999998 85.8327100000000058 85.8327259999999939 85.8327639999999974 85.8334119999999956 85.8279189999999943 85.8046039999999977 85.8010940000000062 85.8021700000000038 85.8022540000000049 85.8022540000000049 85.802299000000005 85.7985079999999982 85.7849879999999985 85.8730160000000069 86.0756910000000062 86.30
08190000000042 86.4047549999999944 86.5396120000000053 86.7541350000000051 87.1110000000000042 87.4775700000000001 87.732917999999998 87.9771190000000018 88.1159590000000037 88.4258269999999982 89.2104109999999935 89.7294239999999945 89.8558120000000002 90.117249000000001 90.5765530000000041 91.1300509999999946 91.2446290000000033 91.022469000000001 91.0173419999999993 91.3900299999999959 92.140632999999994 93.0103679999999997 93.3761599999999987 93.5365220000000051 93.0064160000000015 91.3378369999999933 89.4028629999999964 88.8382799999999975 89.2203290000000067 89.6616590000000002 90.1107939999999985 90.5984420000000057 91.5052259999999933 92.9974519999999956 94.5475160000000017 95.5422899999999942 96.6127319999999941 97.5331039999999945 98.1909639999999939 98.9156420000000054 99.5618060000000042 99.9547120000000007 100.2696380000000005 100.505463000000006 100.9172899999999942 101.4782179999999983 102.3376310000000018 103.6182479999999941 104.7580569999999938 105.84091200
0000003 106.8287509999999969 107.6818159999999978 108.6210860000000054 109.3633269999999982 109.8927539999999965 110.2952499999999958 110.482483000000002 110.1861109999999968 109.6613770000000017 109.0565950000000015 108.1954800000000034 107.1749570000000062 105.9771879999999982 105.2488940000000071 104.8419489999999996 104.4510729999999938 104.1596830000000011 103.9805829999999958 103.5978470000000016 102.911445999999998 102.1151200000000046 101.2297970000000049 100.5822370000000063
+105.8901520000000005 107.0807340000000067 107.9472350000000063 108.6501769999999993 109.2772140000000007 109.7712020000000024 110.102294999999998 110.1902160000000066 109.9046400000000006 109.1853179999999952 108.0882189999999952 106.7774119999999982 105.067656999999997 102.7573849999999993 99.5516819999999996 95.857024999999993 93.0845869999999991 92.3054889999999943 93.8842769999999973 96.7512439999999998 99.5020140000000026 100.9647060000000067 100.6941149999999965 98.9954610000000059 97.0025100000000009 95.2940980000000053 92.9389039999999937 89.6803589999999957 87.1598209999999938 86.280028999999999 86.1577450000000056 86.1250760000000071 86.1948699999999945 86.2010120000000057 86.1984559999999931 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.19849399999999
66 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1982119999999981 86.1881869999999992 86.1705170000000038 86.1672970000000049 86.1651760000000024 86.1655120000000068 86.1641539999999964 86.1551440000000071 86.1457139999999981 86.1373669999999976 86.1339260000000024 86.1340409999999963 86.1364899999999949 86.1317290000000071 86.1235810000000015 86.1116410000000059 86.1051479999999998 86.1030879999999996 86.1025159999999943 86.1044310000000053 86.093718999999993 86.087104999999994 86.0778660000000002 86.0741579999999971 86.0745009999999979 86.0745160000000027 86.066978000000006 86.0736770000000035 86.0961149999999975 86.0962679999999949 86.0752260000000007 86.0652690000000007 86.0552749999999946 86.0472180000000009 86.0315480000000008 86.0177379999999943 86.0120469999999955 86.0025250000000057 86.00779 86.0225980000000021 86.039978000000005 86.0642550000000028 86.0625380000000035 8
6.0876540000000006 86.0890119999999968 86.0163040000000052 86.7638469999999984 88.1510849999999948 87.4934999999999974 86.3163380000000018 86.2615509999999972 86.4407420000000002 86.4838330000000042 86.4747540000000043 86.4745029999999986 86.4601590000000044 86.4570310000000006 86.4535680000000042 86.4798739999999952 86.5149839999999983 86.5185850000000016 86.5228960000000029 86.7147219999999948 87.0888900000000064 87.4144670000000019 87.7335510000000056 88.0700379999999967 88.4580080000000066 88.7715989999999948 88.946479999999994 89.0330579999999969 88.370238999999998 86.7046969999999959 85.6786120000000011 85.7926559999999938 85.7965090000000004 85.8254320000000064 85.832618999999994 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327869999999962 85.8329619999999949 85.823127999999997 85.8144300000000015 85.8055039999999991 85.8017349999999936 85.8022459999999967 85.8022540000000049 85.8020549999999957 85.8010029999999944 85.7967299999999966 85.85497300000
00011 86.0344309999999979 86.0467450000000014 86.1273419999999987 86.357758000000004 86.7265239999999977 87.1681059999999945 87.4265290000000022 87.6040339999999986 87.7306439999999981 87.9148789999999991 88.5116579999999971 89.0556950000000001 89.4061580000000049 89.7399220000000071 90.1272660000000059 90.3057100000000048 89.9376979999999975 89.5350880000000018 89.516143999999997 89.8476179999999971 90.7709200000000038 92.1511380000000031 92.7771840000000054 92.9673389999999955 92.1924130000000019 90.2393040000000042 88.7476350000000025 88.7543869999999941 89.0288309999999967 89.3652569999999997 89.8479080000000039 90.4259950000000003 91.3240200000000044 92.8002089999999953 94.3154980000000052 95.2044750000000022 96.1811749999999961 97.0276640000000015 97.5653310000000005 98.0439379999999971 98.4661100000000005 98.8377610000000004 99.3902889999999957 100.0304260000000056 100.6737289999999945 101.4857030000000009 102.6154630000000054 103.8863979999999998 104.9696809999999942
105.7839359999999971 106.5607830000000007 107.432075999999995 108.3746029999999934 109.0389330000000001 109.4649050000000017 109.8057560000000024 110.0360790000000009 109.7292560000000066 109.124061999999995 108.521568000000002 107.7410660000000036 106.6866530000000068 105.5078890000000058 104.7855529999999931 104.4056020000000018 104.0247420000000034 103.6779329999999959 103.5448910000000069 103.2400279999999952 102.5742110000000054 101.6667709999999971 100.7122729999999962 100.013062000000005
+106.7502290000000045 107.8971630000000062 108.7373809999999992 109.3238910000000033 109.9041059999999987 110.4631810000000058 110.7157140000000055 110.6605150000000037 110.2307739999999967 109.4155429999999996 108.2558819999999997 106.7485960000000063 104.7465289999999953 102.3222350000000063 99.2100300000000033 95.6676410000000033 93.2209930000000071 93.0074769999999944 95.3745569999999958 98.4561539999999979 100.8032299999999992 102.0798110000000065 102.5096889999999945 102.2025990000000064 101.3631290000000007 100.2381129999999985 97.9480209999999971 93.8218839999999972 89.8959200000000038 87.890190000000004 87.0209119999999956 86.308952000000005 86.1624910000000028 86.1958240000000018 86.198646999999994 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.198493999
9999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1978909999999985 86.1833040000000068 86.1730419999999953 86.1759030000000052 86.1764450000000011 86.1765819999999962 86.1753769999999975 86.1592639999999932 86.1528090000000049 86.1539080000000013 86.1555939999999936 86.146064999999993 86.1422120000000007 86.1380840000000063 86.1220550000000031 86.1194310000000058 86.1201319999999981 86.1206439999999986 86.1208189999999973 86.1234209999999933 86.1118620000000021 86.0918350000000032 86.0897829999999971 86.0920559999999995 86.0819170000000042 86.0864789999999971 86.0645600000000002 86.064635999999993 86.0821530000000052 86.0803680000000071 86.0586169999999981 86.0489500000000049 86.0412670000000048 86.031959999999998 86.0201339999999988 86.0162660000000017 85.9928440000000052 85.9846799999999973 85.9839549999999946 85.9727859999999993 85.9828870000000052 86.0014800000000008 86.0
000380000000035 86.0288769999999943 85.9153369999999938 86.2254329999999953 87.9365010000000069 88.0691070000000025 86.3395610000000033 85.9492419999999981 86.1891329999999982 86.3436810000000037 86.4055100000000067 86.4003749999999968 86.3881449999999944 86.3827129999999954 86.3912119999999959 86.3975520000000046 86.4185329999999965 86.4481430000000017 86.4511410000000069 86.4526440000000065 86.6649089999999944 87.0411220000000014 87.3640749999999997 87.6834790000000055 88.0199049999999943 88.4028629999999964 88.6354450000000043 88.7424319999999938 88.3980410000000063 87.1395109999999988 86.2383650000000017 86.1750640000000061 86.2414090000000044 86.1530759999999987 85.914794999999998 85.8339689999999962 85.8327259999999939 85.8327259999999939 85.8326490000000035 85.8330380000000019 85.8338999999999999 85.8330380000000019 85.8236919999999941 85.8038559999999961 85.8017430000000019 85.8022459999999967 85.8022459999999967 85.8022610000000014 85.8022919999999942 85.80155200000
00009 85.8040770000000066 85.811829000000003 85.8018419999999935 85.9551390000000026 86.204741999999996 86.4625319999999959 86.787200999999996 87.0737079999999963 87.2162629999999979 87.3309330000000017 87.5544890000000038 87.9533310000000057 88.3945240000000041 88.919739000000007 89.2209009999999978 89.3463210000000032 89.1355819999999994 88.7231519999999989 88.6097180000000009 88.7518309999999957 88.8871840000000049 89.6208649999999949 91.1251139999999964 92.108429000000001 92.3696439999999939 91.6285170000000022 89.8894420000000025 88.5011669999999953 88.6133190000000042 88.9332959999999986 89.2863080000000053 89.7610240000000061 90.3167569999999955 91.2903210000000058 92.6479570000000052 93.9412159999999972 94.8474659999999972 95.6465840000000043 96.3353730000000041 96.8835980000000063 97.218781000000007 97.740074000000007 98.5766449999999992 99.357917999999998 100.0695500000000067 100.7327879999999993 101.5645370000000014 102.694396999999995 103.9330900000000071 104.905
6470000000019 105.597565000000003 106.190337999999997 107.0725709999999964 108.018897999999993 108.6091610000000003 109.035767000000007 109.404114000000007 109.5799329999999969 109.2901609999999977 108.5677259999999933 107.8065950000000015 107.1309200000000033 106.185149999999993 105.0488430000000051 104.347046000000006 103.9860149999999948 103.6677090000000021 103.3219299999999947 103.1381530000000026 102.8233869999999968 102.0970379999999977 101.0917210000000068 100.1384280000000047 99.5000229999999988
+107.6305239999999941 108.7264710000000036 109.5465930000000014 110.0860289999999964 110.6673049999999989 111.1690439999999995 111.282471000000001 111.1238019999999977 110.5124509999999987 109.4896619999999956 108.1904449999999969 106.6408229999999975 104.5932009999999934 102.0588070000000016 99.0394210000000044 95.7094500000000039 93.5551379999999995 93.8109659999999934 96.7200780000000009 100.005699000000007 102.0903399999999976 103.0971600000000024 103.7255480000000034 104.1050419999999974 104.0200499999999977 103.1642609999999962 101.1298680000000019 97.3210600000000028 92.8752520000000032 90.0631560000000064 88.477965999999995 86.9687650000000048 86.2048489999999958 86.1719819999999999 86.1987919999999974 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939
999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1983180000000004 86.1945269999999937 86.1937479999999994 86.1947250000000054 86.1946489999999983 86.1946870000000018 86.1946180000000055 86.1902769999999947 86.1895449999999954 86.1909940000000034 86.191551000000004 86.1807940000000059 86.1714860000000016 86.1734160000000031 86.1704330000000027 86.1714549999999946 86.1722409999999996 86.1722489999999937 86.1723400000000055 86.1726149999999933 86.1744159999999937 86.1511459999999971 86.1391909999999967 86.131896999999995 86.1165390000000031 86.1145099999999957 86.092796000000007 86.0770190000000071 86.0755690000000016 86.0624849999999952 86.0488969999999966 86.0428469999999948 86.0214160000000021 86.0187679999999943 86.018462999999997 85.9999849999999952 85.9855119999999999 85.9850619999999992 85.9802629999999937 85.9626769999999993 85.9587250000000012 85.9520109999999988 85.
951667999999998 85.9667429999999939 85.7957839999999976 86.3405989999999974 87.6727750000000015 86.8796389999999974 85.8519900000000007 85.9409710000000047 86.1071089999999941 86.2480010000000021 86.3317179999999951 86.3318330000000032 86.3137889999999999 86.3067700000000002 86.3143230000000017 86.3343890000000016 86.3590619999999944 86.3750150000000048 86.3907319999999999 86.3919910000000044 86.5687329999999946 86.9303969999999993 87.266563000000005 87.5784610000000043 87.9344559999999973 88.2706989999999934 88.4333419999999961 88.492217999999994 88.1611099999999936 87.6781229999999994 87.6749339999999933 87.7670970000000068 87.8647840000000002 87.4590149999999937 86.2390290000000022 85.8388750000000016 85.8327259999999939 85.8327259999999939 85.8335189999999955 85.8293610000000058 85.8199460000000016 85.8206789999999984 85.807502999999997 85.8015670000000057 85.8021999999999991 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022990000000
05 85.8019709999999947 85.8008650000000017 85.7946850000000012 85.816826000000006 85.930603000000005 86.1530230000000046 86.4891590000000008 86.756844000000001 86.8838959999999929 87.0323939999999965 87.2404559999999947 87.621452000000005 88.0942079999999947 88.3980559999999969 88.4632639999999952 88.3320619999999934 87.8966599999999971 87.7247849999999971 87.8504709999999989 88.0378269999999929 88.1692960000000028 88.7315439999999995 90.1296839999999975 91.4020160000000033 91.6562040000000025 90.9745329999999939 89.6456600000000066 88.4033660000000054 88.3699110000000019 88.8784409999999951 89.3512800000000027 89.8238220000000069 90.383269999999996 91.3499450000000053 92.560096999999999 93.6202090000000027 94.2934269999999941 94.8126830000000069 95.5660929999999951 96.231780999999998 96.795929000000001 97.7282490000000053 98.7340319999999991 99.4120640000000009 100.091399999999993 100.8023220000000038 101.6435850000000016 102.6630860000000069 103.7631379999999979 104.645401
0000000068 105.4130779999999987 106.0645289999999932 106.7851940000000042 107.5860289999999964 108.1783290000000051 108.6149439999999942 108.9231110000000058 109.0171430000000043 108.7179569999999984 107.9736249999999984 107.0777510000000063 106.3196949999999958 105.5861050000000034 104.6315160000000049 103.9676280000000048 103.6320500000000067 103.341431 102.9645540000000068 102.6877290000000045 102.1814799999999934 101.3272780000000068 100.3030779999999993 99.4767149999999987 98.9759750000000054
+108.3523789999999991 109.4693369999999959 110.241966000000005 110.8806529999999952 111.4693759999999969 111.7365719999999953 111.6665880000000044 111.3677979999999934 110.5984190000000069 109.4354320000000058 108.0525590000000022 106.4947590000000019 104.3220139999999958 101.6256939999999958 98.6819689999999952 95.705444 93.9978710000000035 94.5539019999999937 97.3616180000000071 100.8012310000000014 103.2231900000000024 104.1515579999999943 104.6474079999999987 104.9717100000000016 105.0998230000000007 104.2994079999999997 101.9720379999999977 98.0556260000000037 94.2864909999999981 91.7910159999999991 89.2649609999999996 87.2266309999999976 86.2481230000000068 86.1623230000000007 86.1986540000000048 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.198493999999996
6 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1985320000000002 86.1994930000000039 86.1999129999999951 86.1996989999999954 86.1997070000000036 86.1996919999999989 86.1997219999999942 86.2007519999999943 86.2010269999999963 86.2007899999999978 86.2006839999999954 86.1986770000000035 86.195769999999996 86.196983000000003 86.1985090000000014 86.1984939999999966 86.1983869999999968 86.1983869999999968 86.1983869999999968 86.1978840000000019 86.2015530000000041 86.1842960000000033 86.1637039999999956 86.146568000000002 86.1365129999999937 86.1219860000000068 86.1014940000000024 86.0823970000000003 86.0723500000000001 86.0522229999999979 86.044273000000004 86.0256499999999988 86.0148240000000044 86.018921000000006 86.0169070000000033 86.0011599999999987 85.9458620000000053 85.9056240000000031 85.9451980000000049 85.9323880000000031 85.8837429999999955 85.8809049999999985 85.914803000
0000063 85.9247819999999933 85.8392029999999977 86.0763019999999983 86.3898930000000007 85.9852520000000027 85.8628999999999962 85.9165189999999939 85.9975280000000026 86.1308590000000009 86.238585999999998 86.2430269999999979 86.2365489999999966 86.2395020000000017 86.2443310000000025 86.2650759999999934 86.3050080000000008 86.3154449999999969 86.3336720000000071 86.3269729999999953 86.4835209999999961 86.8309560000000005 87.1749650000000003 87.5032269999999954 87.8457259999999991 88.0898590000000041 88.2004009999999994 88.2759549999999962 88.3292079999999942 88.4252170000000035 88.5394820000000067 88.639679000000001 88.8030550000000005 88.2348630000000043 86.4263380000000012 85.841826999999995 85.8327259999999939 85.8327259999999939 85.834746999999993 85.8236009999999965 85.804908999999995 85.8040919999999971 85.8023830000000061 85.8021090000000015 85.8022540000000049 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.802
2459999999967 85.8022610000000014 85.8017580000000066 85.8045350000000013 85.7758869999999973 85.8679730000000063 86.1438749999999942 86.4658510000000007 86.630188000000004 86.6764600000000058 86.8992080000000016 87.395622000000003 87.8249509999999987 87.8644939999999934 87.7729340000000064 87.5466160000000002 87.1887969999999939 87.1009520000000066 87.2262190000000004 87.4262159999999966 87.5803379999999976 88.0998309999999947 89.3513030000000015 90.3720780000000019 90.1431659999999937 89.3771820000000048 88.6088100000000054 88.1338350000000048 88.2765959999999978 88.822258000000005 89.4007799999999975 89.9534759999999949 90.6026310000000024 91.4359050000000053 92.5335919999999987 93.4406280000000038 93.8352430000000055 94.2107699999999966 95.175658999999996 95.9821550000000059 96.6717680000000001 97.6341170000000034 98.6101299999999981 99.3287509999999969 100.007591000000005 100.7719040000000064 101.6248700000000014 102.5162279999999981 103.4789200000000022 104.34882399999
99934 105.1407470000000046 105.856537000000003 106.5305249999999972 107.2066350000000057 107.7185209999999955 108.1515349999999955 108.2869189999999975 108.2666930000000036 107.9864500000000049 107.286681999999999 106.3396840000000054 105.4755480000000034 104.8363339999999937 104.1612700000000018 103.5401839999999964 103.1869580000000042 102.9994429999999994 102.5893169999999941 102.092376999999999 101.3879009999999994 100.4704969999999946 99.4948579999999936 98.8206330000000008 98.4908750000000026
+108.8289410000000004 109.8587420000000066 110.8023610000000048 111.6158140000000003 112.1528780000000012 112.2873759999999947 112.117133999999993 111.5178760000000011 110.568199000000007 109.280272999999994 107.6157989999999955 105.9545209999999997 103.765381000000005 101.145103000000006 98.462883000000005 95.7655869999999965 94.4326169999999934 95.3377909999999957 98.1318590000000057 101.4569240000000008 103.9700469999999939 104.991966000000005 105.4131699999999938 105.6895980000000037 105.7018810000000002 104.8230439999999959 102.141563000000005 97.839271999999994 95.9336619999999982 94.2432100000000048 89.9920500000000061 86.8722309999999993 86.0717700000000008 86.1727369999999979 86.1995699999999943 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999
966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1990810000000067 86.1997530000000012 86.1995320000000049 86.1994090000000028 86.1993939999999981 86.1993789999999933 86.1993709999999993 86.1993559999999945 86.1998439999999988 86.1971510000000052 86.1781309999999934 86.1583020000000062 86.1432340000000067 86.1330109999999962 86.112755000000007 86.0910949999999957 86.0762179999999972 86.0653460000000052 86.050255000000007 86.0375370000000004 86.0166320000000013 86.0125730000000033 85.8896179999999987 85.7371980000000065 85.7066499999999962 85.9456179999999961 86.1973880000000037 86.0105590000000007 85.866966000000005 85.8438110000000023 85.7760999999999996 85.75082
39999999944 85.703636000000003 85.7249599999999958 85.8373339999999985 85.8875050000000044 85.8585970000000032 85.8952409999999986 85.8921430000000043 85.9144289999999984 86.0182649999999995 86.1483230000000049 86.1697690000000023 86.1584469999999953 86.168327000000005 86.1871950000000027 86.2041399999999953 86.2373429999999956 86.2534260000000046 86.2761760000000066 86.2630920000000003 86.4276660000000021 86.7815549999999973 87.1282350000000037 87.4697489999999931 87.7489400000000046 87.8930440000000033 87.9748230000000007 88.0691379999999953 88.1567540000000065 88.2618709999999993 88.3623280000000051 88.4418110000000013 88.613585999999998 88.116730000000004 86.3941269999999975 85.8414149999999978 85.8327259999999939 85.8327259999999939 85.8347849999999966 85.823631000000006 85.8030849999999958 85.8019100000000066 85.8021770000000004 85.8022610000000014 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85
.8022459999999967 85.8022459999999967 85.8023220000000038 85.8026049999999998 85.7961350000000067 85.8038640000000044 85.8296590000000066 86.080284000000006 86.4424290000000042 86.3608550000000008 86.4792020000000008 86.9391020000000054 87.3308719999999994 87.403648000000004 87.248351999999997 86.9336700000000064 86.658844000000002 86.494575999999995 86.6458740000000063 87.0103450000000009 87.222290000000001 87.5974039999999974 88.5210799999999978 89.0261229999999983 88.3845519999999993 87.7014309999999995 87.6555249999999972 87.9183809999999966 88.190337999999997 88.7334519999999998 89.3402559999999966 90.0325389999999999 90.8205109999999962 91.6101299999999981 92.6654280000000057 93.3786929999999984 93.6452639999999974 94.1311110000000042 95.1210630000000066 95.9320909999999998 96.6065219999999982 97.5143130000000014 98.5022349999999989 99.3097460000000041 100.0014189999999985 100.7430339999999944 101.4859009999999984 102.305603000000005 103.270118999999994 104.08174900000
00021 104.8236849999999976 105.472724999999997 106.1140369999999962 106.7337490000000031 107.1804280000000063 107.5211330000000061 107.5650409999999937 107.4998549999999966 107.2247469999999936 106.4810939999999988 105.506141999999997 104.5687479999999994 103.9093699999999956 103.5487370000000027 103.1572800000000001 102.8290860000000038 102.6765749999999997 102.1352080000000058 101.4397050000000036 100.7616649999999936 99.8483659999999986 98.9299850000000021 98.2429049999999933 98.1600490000000008
+109.3418429999999972 110.0950389999999999 111.2805249999999972 112.2231900000000024 112.7110210000000023 112.8222430000000003 112.5611799999999931 111.7561259999999947 110.6458590000000015 109.1031650000000042 106.9523619999999937 104.7984849999999994 102.6633680000000055 100.5176770000000062 98.3268049999999931 95.9550250000000062 94.9795610000000039 96.4708940000000013 99.7044139999999999 102.6497039999999998 104.5534360000000049 105.5030519999999967 106.016052000000002 106.5179370000000034 106.4288020000000046 105.5406490000000019 103.1948390000000018 99.1581189999999992 98.7220080000000024 97.5641329999999982 92.1171420000000012 87.5110629999999929 86.0096589999999992 86.1347889999999978 86.2035979999999995 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.19849
39999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.198363999999998 86.2009960000000035 86.1891940000000005 86.166679000000002 86.1472849999999966 86.1371309999999966 86.1232679999999959 86.1095049999999986 86.0904160000000047 86.0725020000000001 86.0558170000000047 86.0457459999999941 86.0299150000000026 86.0110320000000002 85.966148000000004 86.0028609999999958 86.2470930000000067 86.4646450000000044 87.0814969999999988 87.3391040000000061 86.6099779999999981 86.3598559999999935 86.6778110000000055 86.5483779999999996
86.2023700000000019 86.2091669999999937 86.4735490000000055 86.1291200000000003 85.8730999999999938 85.8955540000000042 85.893929 85.8916779999999989 85.8892819999999944 85.9428479999999979 86.0649339999999938 86.1009600000000006 86.0865629999999982 86.1012800000000027 86.1207279999999997 86.1466669999999937 86.1636429999999933 86.1885450000000048 86.2162399999999991 86.2078929999999986 86.382874000000001 86.750670999999997 87.0993959999999987 87.4085309999999964 87.5889659999999992 87.6838529999999992 87.7647170000000045 87.8525999999999954 87.9301070000000067 88.0009000000000015 88.1019519999999972 88.1868589999999983 88.3513640000000038 87.9201809999999995 86.3348309999999941 85.8402250000000038 85.8327259999999939 85.8327259999999939 85.8347320000000025 85.8239750000000043 85.8034519999999929 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 8
5.8022459999999967 85.8022459999999967 85.8022459999999967 85.8021849999999944 85.8029099999999971 85.8016130000000032 85.7963709999999935 85.8314969999999988 86.1224210000000028 86.1552580000000034 86.1286539999999974 86.3901440000000065 86.7063140000000061 86.7593770000000006 86.6620939999999962 86.3798830000000066 86.0952759999999984 85.9741060000000061 86.1544719999999984 86.662200999999996 86.8091890000000035 86.9702680000000043 87.644005000000007 87.8657610000000062 87.4694369999999992 87.1020050000000055 87.2865299999999991 87.8158949999999976 88.2092209999999994 88.6823959999999971 89.2094270000000051 89.8936769999999967 90.9274979999999999 91.9758219999999937 92.894835999999998 93.4135279999999995 93.6716380000000015 94.3337479999999999 95.1936950000000053 95.854613999999998 96.6220780000000019 97.6803210000000064 98.6834180000000032 99.3994600000000048 100.0696640000000031 100.7314219999999949 101.3509219999999971 102.1885599999999954 103.1568910000000017 103.80004
90000000013 104.4433290000000056 105.0479509999999976 105.5862659999999948 106.0914989999999989 106.5335010000000011 106.7983779999999996 106.8353270000000066 106.7933879999999931 106.5031510000000026 105.7162170000000003 104.6999050000000011 103.6463779999999986 103.0478590000000025 102.8508530000000007 102.6750789999999967 102.5041049999999956 102.3146059999999977 101.7805019999999985 101.1018219999999985 100.3466030000000018 99.4790500000000009 98.6208570000000009 97.8694760000000059 97.8795010000000048
+109.9985889999999955 110.5431750000000051 111.6674799999999976 112.5932240000000064 113.0842130000000054 113.1540150000000011 112.8158109999999965 111.9949340000000007 110.7732929999999953 109.1930160000000001 106.9669949999999972 104.2779620000000023 101.9489820000000009 100.0666200000000003 98.0756449999999944 96.1387100000000032 95.9403989999999993 98.2123339999999985 101.4486849999999976 103.8695139999999952 105.2396389999999968 105.9724810000000019 106.5759960000000035 107.238349999999997 107.3196640000000031 106.6049040000000048 104.8787229999999937 101.7002939999999995 101.4902270000000044 100.4746779999999973 95.0904620000000023 89.8106690000000043 86.8092120000000023 86.0787349999999947 86.1879200000000054 86.198607999999993 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.19
84939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1988450000000057 86.1991199999999935 86.1801909999999936 86.1659389999999945 86.1473540000000071 86.1324230000000028 86.1140290000000022 86.1059269999999941 86.0864559999999983 86.0666429999999991 86.050690000000003 86.0405200000000008 86.0221180000000061 85.9929810000000003 86.0293120000000044 87.1709979999999973 88.4118500000000012 88.8720550000000031 89.039283999999995 88.5424500000000023 87.6833270000000056 87.6446300000000065 88.2016299999999944 88.0708470000000
005 87.499968999999993 88.017273000000003 88.4678799999999939 86.8418879999999973 85.8611680000000064 85.8995060000000024 85.8936999999999955 85.8945080000000019 85.888465999999994 85.885468000000003 85.9698259999999976 86.0188449999999989 86.014435000000006 86.0338590000000067 86.0483250000000055 86.0889590000000027 86.1016390000000058 86.1291049999999956 86.1571430000000049 86.1560130000000015 86.340637000000001 86.7118909999999943 87.0568159999999978 87.2786100000000005 87.3715899999999976 87.4669190000000043 87.5603260000000034 87.6270679999999942 87.7134929999999997 87.7896580000000029 87.8787080000000032 87.978911999999994 88.1460040000000049 87.7613070000000022 86.2805180000000007 85.8388369999999981 85.8327259999999939 85.8327259999999939 85.8347320000000025 85.823882999999995 85.8034820000000025 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999
999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022310000000061 85.802299000000005 85.7927629999999937 85.8303219999999953 85.9251859999999965 85.9344480000000033 86.0048519999999996 86.2325359999999961 86.2776790000000062 86.1447679999999991 86.0025250000000057 85.8271560000000022 85.8072509999999937 85.9366530000000068 86.4657590000000056 86.5118870000000015 86.4863050000000015 86.9730069999999955 87.2611009999999965 87.189391999999998 87.0743329999999958 87.1965940000000046 87.6483989999999977 88.2278979999999962 88.6840820000000036 89.0991060000000061 89.6251220000000046 90.6598819999999961 92.0534439999999989 93.0181050000000056 93.6106639999999999 93.9731830000000059 94.628304 95.4291230000000041 96.085915 96.9322049999999962 98.0150450000000006 98.9642790000000048 99.5801009999999991 100.1063999999999936 100.7006609999999966 101.3012159999999966 102.0243300000000062 102.8221130000000016 103.438582999999994
2 104.0043869999999941 104.5269930000000045 104.9689560000000057 105.4695969999999932 105.8349910000000023 106.0634000000000015 106.1690750000000065 106.1019059999999996 105.7466739999999987 105.0046310000000034 103.969695999999999 103.0072629999999947 102.4574130000000025 102.1996460000000013 102.0790250000000015 102.0477139999999991 101.8770219999999966 101.5352550000000065 100.9549870000000027 99.988158999999996 99.1423340000000053 98.3486400000000032 97.5903239999999954 97.4945299999999975
+110.6898879999999963 111.1994710000000026 112.1130140000000068 112.9188769999999948 113.3772349999999989 113.4373549999999966 113.0935900000000061 112.2279050000000069 111.0015870000000007 109.6174850000000021 107.7471390000000042 105.3053210000000064 102.8798369999999949 100.5147170000000045 97.972565000000003 96.4051060000000035 97.432982999999993 100.3124080000000049 102.9073559999999929 104.6883389999999991 105.911949000000007 106.5893099999999976 107.185333 107.8377299999999934 108.1761630000000025 107.7654339999999991 106.6228789999999975 104.6087420000000066 104.2075269999999989 102.6727070000000026 97.5912170000000003 92.2084270000000004 88.1638789999999943 86.1969069999999959 86.0865019999999959 86.198127999999997 86.1984329999999943 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999
966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.2002329999999972 86.1911539999999974 86.1713869999999957 86.1634980000000041 86.1439969999999988 86.125031000000007 86.1109770000000054 86.0987010000000055 86.0765379999999993 86.0566639999999978 86.0457990000000024 86.0328599999999994 86.0195470000000029 85.9860610000000065 86.1056209999999993 88.1075519999999983 90.0979080000000039 90.7932890000000015 90.4181209999999993 89.4259490000000028 88.8597489999999937 89.1092299999999966 89.6188810000000018 89.3185650000000066 88.625
0689999999963 89.4377900000000068 89.2869799999999998 86.876189999999994 85.8511890000000051 85.9002150000000029 85.8936920000000015 85.8956450000000018 85.885200999999995 85.8630830000000032 85.8908540000000045 85.9398800000000023 85.9516909999999967 85.9726409999999959 85.9868320000000068 86.0294650000000019 86.0434879999999964 86.0673220000000043 86.0890430000000038 86.0956879999999956 86.2894519999999972 86.6685489999999987 86.9631040000000013 87.0819699999999983 87.1592559999999992 87.2484359999999981 87.3500669999999957 87.4148560000000003 87.4905399999999958 87.5838090000000022 87.6564330000000069 87.7628330000000005 87.9377819999999986 87.6070399999999978 86.237244000000004 85.837806999999998 85.8327259999999939 85.8326569999999975 85.8350369999999998 85.826240999999996 85.8037489999999963 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967
85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8008959999999945 85.7934190000000001 85.8118520000000018 85.8111719999999991 85.8142399999999981 85.9571689999999933 86.0197139999999933 85.8669129999999967 85.8068389999999965 85.7972340000000031 85.7999109999999945 85.8575670000000031 86.1172030000000035 86.3532560000000018 86.4113389999999981 86.5899430000000052 86.9005580000000037 86.913337999999996 86.9519499999999965 87.1904980000000052 87.6400299999999959 88.1442409999999938 88.5798719999999946 88.9527049999999946 89.3534619999999933 90.1407319999999999 91.5413819999999987 92.7850949999999983 93.6494220000000013 94.1659470000000027 94.8076250000000016 95.6542210000000068 96.4798360000000059 97.3323139999999967 98.2860260000000068 99.1642230000000069 99.7490010000000069 100.1665270000000021 100.5885470000000055 101.0784529999999961 101.6721730000000008 102.2939070000000044 102.9
030759999999987 103.3616640000000046 103.8148120000000034 104.2891690000000011 104.7626419999999996 104.9980089999999961 105.1765900000000045 105.3843990000000019 105.3333279999999945 104.8725050000000039 104.1470180000000028 103.2775189999999981 102.524840999999995 101.8752290000000045 101.5318299999999994 101.5102619999999973 101.5102839999999986 101.423255999999995 101.2446750000000009 100.5838619999999963 99.5494230000000044 98.7673869999999994 97.978935000000007 97.2931899999999956 97.1501769999999993
+111.4034189999999995 111.9671780000000041 112.7303919999999948 113.3824620000000039 113.7629089999999934 113.8422999999999945 113.4697720000000061 112.5779950000000014 111.5155330000000049 110.1629489999999976 108.5454710000000063 106.7581940000000031 104.3785019999999975 101.4316790000000026 98.3026499999999999 96.8957060000000041 98.7653119999999944 101.7630769999999956 103.9005049999999954 105.2906339999999972 106.4413679999999971 107.1902010000000018 107.817939999999993 108.4032969999999949 108.798255999999995 108.7068790000000007 108.0589980000000025 107.1130449999999996 106.6616970000000038 104.5421220000000062 99.8004609999999985 94.5512769999999989 90.1088409999999982 87.0731049999999982 86.1069410000000062 86.1705170000000038 86.2085720000000038 86.1973950000000002 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1
984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984250000000003 86.2010649999999998 86.1901859999999971 86.170417999999998 86.1544719999999984 86.1335830000000016 86.1150889999999976 86.1075060000000008 86.0898509999999959 86.0750809999999973 86.0561900000000009 86.041175999999993 86.0232769999999931 86.015625 85.9877319999999941 86.0089040000000011 87.588745000000003 89.9289169999999984 91.2078319999999962 91.1451260000000048 90.4379650000000055 90.1668399999999934 90.5403589999999951 90.9967730000000046 90.0771100000000047 89.267
6539999999932 89.9575499999999977 88.847999999999999 86.3264850000000052 85.8757169999999945 85.8953699999999998 85.8936230000000052 85.8961560000000048 85.8865890000000007 85.863701000000006 85.8628080000000011 85.8805470000000071 85.8941190000000034 85.9055019999999985 85.9212950000000006 85.9684979999999968 85.9855730000000023 86.0031809999999979 86.0157470000000046 86.0293350000000032 86.2385709999999932 86.6045759999999945 86.794312000000005 86.8597340000000031 86.9450530000000015 87.0292969999999997 87.1243589999999983 87.2093430000000041 87.2768779999999964 87.3692630000000037 87.4500429999999938 87.543526 87.7225040000000007 87.4428479999999979 86.1913909999999959 85.8367310000000003 85.8327259999999939 85.8329700000000031 85.8330990000000043 85.8186869999999971 85.8030930000000041 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.80224
59999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8024520000000024 85.8024750000000012 85.7994840000000067 85.797309999999996 85.795921000000007 85.814850000000007 85.8186800000000005 85.8016130000000032 85.7948760000000021 85.8019639999999981 85.8024900000000059 85.8003010000000046 85.8551180000000045 86.2336200000000019 86.4098589999999973 86.3768160000000051 86.5547710000000023 86.6140209999999939 86.8190610000000049 87.2664180000000016 87.7258000000000067 88.0872800000000069 88.4504929999999945 88.7187270000000012 88.9801709999999986 89.5581049999999976 90.6736369999999994 92.0654830000000004 93.3010560000000027 94.0768510000000049 94.749481000000003 95.6727829999999955 96.6320189999999997 97.5057680000000033 98.389922999999996 99.228424000000004 99.7766270000000048 100.0852430000000055 100.386107999999993 100.7205510000000004 101.1613849999999957 101.802550999999994 102.3647380000000027
102.6152500000000032 103.0268099999999976 103.5742029999999971 104.0178829999999977 104.1653060000000011 104.1802979999999934 104.4343570000000057 104.4894489999999934 104.0475160000000017 103.3728030000000047 102.6233139999999935 101.9200129999999973 101.161949000000007 100.7588959999999929 100.7827840000000066 100.814667 100.8845440000000053 100.8677220000000005 100.1931150000000059 99.139244000000005 98.3557279999999992 97.6264189999999985 97.0588609999999932 96.8788909999999959
+112.104179000000002 112.6933899999999937 113.338561999999996 113.8383939999999939 114.1369250000000051 114.1781079999999946 113.7559049999999985 112.9813769999999948 112.0443729999999931 110.6372989999999987 109.1519700000000057 107.6533969999999982 105.3047559999999976 102.3568649999999991 99.1149369999999976 97.4919199999999933 99.2420500000000061 102.0905230000000046 104.3115389999999962 105.8009109999999993 106.912391999999997 107.7280039999999985 108.4696270000000027 109.0105819999999994 109.3628690000000034 109.4430009999999953 109.1428300000000036 108.7437440000000066 108.4136660000000063 106.5540919999999971 102.7512279999999976 98.2626879999999971 93.6011349999999993 89.4598919999999964 87.001221000000001 86.2436370000000068 86.1667020000000008 86.2033389999999997 86.198639 86.1984790000000061 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.198493999999
9966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1986689999999953 86.1992259999999959 86.1873779999999954 86.1677090000000021 86.1456450000000018 86.1325149999999979 86.1145549999999957 86.1012949999999933 86.0810170000000028 86.0728909999999985 86.0533070000000038 86.0344240000000013 86.0192640000000068 86.0059590000000043 85.9855799999999988 85.941551000000004 86.6800690000000031 89.0203020000000009 90.7927629999999937 91.4637989999999945 91.546875 91.6233370000000065 91.9992749999999972 92.1540370000000024 90.6622469999999936 89.895813000000
004 90.1511079999999936 88.1315840000000037 85.9311600000000055 85.8841479999999962 85.8932420000000008 85.893889999999999 85.8942949999999996 85.8808750000000032 85.8642269999999996 85.8622510000000005 85.8613200000000063 85.8644180000000006 85.8654329999999959 85.8713460000000026 85.903899999999993 85.9167560000000066 85.9380950000000041 85.9487000000000023 85.9736099999999936 86.1974869999999953 86.4779889999999938 86.582854999999995 86.6395339999999976 86.7236860000000007 86.8218150000000009 86.8976969999999937 86.9879990000000021 87.0634689999999978 87.1411820000000006 87.2372890000000041 87.321503000000007 87.491219000000001 87.2789609999999954 86.1549449999999979 85.8360820000000047 85.8327259999999939 85.8337020000000024 85.8274770000000018 85.8074040000000053 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459
999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022079999999931 85.8024750000000012 85.8024900000000059 85.7970580000000069 85.7923049999999989 85.8007889999999946 85.8027799999999985 85.8022689999999955 85.8021849999999944 85.7886960000000016 85.8529819999999972 86.1784439999999989 86.3009109999999993 86.4357909999999947 86.5761030000000034 86.733947999999998 86.9709930000000071 87.3955540000000042 87.7131200000000035 87.9008639999999986 88.1473160000000036 88.3560489999999987 88.5874330000000043 89.1246340000000004 89.9557109999999938 91.1830980000000011 92.6283190000000047 93.7245709999999974 94.5730060000000066 95.5392070000000047 96.4878539999999987 97.3939900000000023 98.3105390000000057 99.1021269999999959 99.6249009999999942 99.871467999999993 100.1925580000000053 100.4802549999999997 100.7043840000000046 101.2558899999999937 101.7833179999999
942 101.9707870000000014 102.2813869999999952 102.7796940000000063 103.2001419999999996 103.3869320000000016 103.3445509999999956 103.5712740000000025 103.6138380000000012 103.2190089999999998 102.632591000000005 101.9700550000000021 101.2371899999999982 100.483001999999999 100.0921709999999933 100.1190639999999945 100.1697309999999987 100.2859119999999962 100.2734379999999987 99.7516940000000005 98.8438260000000071 97.9816739999999982 97.4312520000000006 96.9795069999999981 96.6365590000000054
+112.8187790000000064 113.266578999999993 113.7847519999999975 114.2484740000000016 114.4339290000000062 114.3928449999999941 114.0029219999999981 113.3105549999999937 112.2947460000000035 110.9366459999999961 109.6248470000000026 108.1832119999999975 106.0712740000000025 103.3696139999999986 100.1971889999999945 98.1278149999999982 99.2851030000000065 102.0282669999999996 104.5123980000000046 106.2411189999999976 107.3705669999999941 108.2429810000000003 109.031761000000003 109.5762629999999973 109.9690779999999961 110.1992029999999971 110.1918639999999954 109.937531000000007 109.7089229999999986 108.7089840000000009 106.2275089999999977 102.3875500000000045 97.5649489999999986 92.7667309999999929 88.8807369999999963 86.5640559999999937 86.0455860000000001 86.198395000000005 86.1963039999999978 86.197929000000002 86.1920620000000071 86.1894989999999979 86.1961519999999979 86.1998899999999963 86.1984180000000038 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1
984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984790000000061 86.199584999999999 86.1956559999999996 86.1772689999999955 86.1574099999999987 86.1381609999999966 86.1311489999999935 86.1124729999999943 86.0930249999999972 86.0787890000000004 86.0641099999999994 86.0429230000000018 86.0240710000000064 86.0179370000000034 86.0049439999999947 85.9842529999999954 85.9488680000000045 86.1529919999999976 87.9452129999999954 89.9988859999999988 91.4043120000000044 92.3007510000000053 92.7348559999999935 92.9489520000000056 92.700721999999999 91.363303999999
9994 90.5820080000000019 89.9657289999999961 87.1400600000000054 85.8214650000000034 85.8878250000000065 85.8936839999999933 85.8947830000000039 85.8907010000000071 85.8696439999999939 85.8632199999999983 85.8631740000000008 85.8626330000000024 85.8617320000000035 85.8609309999999937 85.8602599999999967 85.8660050000000012 85.8691479999999956 85.8829120000000046 85.8862610000000046 85.9202499999999958 86.1158070000000038 86.2820279999999968 86.3563079999999985 86.4320220000000035 86.505950999999996 86.6098559999999935 86.6876529999999974 86.7617950000000064 86.8541560000000032 86.9200359999999961 87.0175399999999968 87.1122589999999946 87.2560500000000019 87.1058500000000038 86.1214219999999955 85.8356480000000062 85.8327259999999939 85.8338470000000058 85.8262789999999995 85.8050379999999961 85.8020549999999957 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.80
22459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8023529999999965 85.8027950000000033 85.8022610000000014 85.8022380000000027 85.8022459999999967 85.8025049999999965 85.7823259999999976 85.8438799999999986 86.1762540000000001 86.4290160000000043 86.8153230000000065 87.0278019999999941 87.1437990000000013 87.243155999999999 87.4865800000000036 87.6566090000000031 87.602562000000006 87.7402110000000022 88.0003970000000066 88.2537990000000008 88.785499999999999 89.5536419999999964 90.5268400000000071 91.7870099999999951 93.1155320000000017 94.2605060000000066 95.3082430000000045 96.2207109999999943 97.143889999999999 98.1594309999999979 98.9083179999999942 99.3347090000000037 99.5958559999999977 99.847801000000004 100.0844349999999991 100.2219089999999966 100.4780959999999
936 100.857758000000004 101.1738509999999991 101.4347530000000006 101.9141460000000023 102.3340529999999973 102.5556409999999943 102.6118620000000021 102.7524259999999998 102.6368480000000005 102.242217999999994 101.8004990000000021 101.2427979999999934 100.5488430000000051 99.9085620000000034 99.5423129999999929 99.5366360000000014 99.6231460000000055 99.7055359999999951 99.6892930000000064 99.3082959999999986 98.5122379999999964 97.6313099999999991 97.0909039999999948 96.7698520000000002 96.3933789999999959
+113.5352019999999982 113.824744999999993 114.2330630000000014 114.6815260000000052 114.759726999999998 114.6459270000000004 114.2625349999999997 113.5266340000000014 112.4215010000000063 111.1060870000000023 109.819396999999995 108.3202210000000036 106.4174270000000035 103.7719120000000004 100.7547679999999986 98.7035290000000032 99.5022660000000059 102.2024839999999983 104.8381040000000013 106.6915280000000052 107.8226549999999975 108.7147219999999948 109.4678420000000045 110.0208590000000015 110.5273360000000054 110.9823149999999998 111.126648000000003 110.9451600000000013 110.7385330000000039 110.4665600000000012 108.9723659999999938 105.3252260000000007 100.4755860000000069 95.5908050000000031 91.0796509999999984 87.3802409999999981 86.1491240000000005 86.2150730000000038 86.1836700000000064 86.1851350000000025 86.2029189999999943 86.2142029999999977 86.1954879999999974 86.184151 86.1932220000000058 86.198646999999994 86.1984559999999931 86.1984939999999966 86.1984939999
999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1985240000000061 86.1990360000000067 86.188445999999999 86.1721650000000068 86.1552580000000034 86.1355669999999947 86.1214070000000049 86.1018370000000033 86.0831989999999934 86.076744000000005 86.0551379999999995 86.0399249999999967 86.0207060000000041 86.0169530000000009 86.001891999999998 85.9848250000000007 85.964775000000003 85.928252999999998 86.7054140000000046 88.6758650000000017 90.8605349999999987 92.3846360000000004 93.0730439999999959 93.2071909999999946 92.850403 91.9015349999999955 91.10235600000000
03 89.4464569999999952 86.263733000000002 85.7674789999999945 85.8954619999999949 85.8937990000000013 85.8955310000000054 85.8844299999999947 85.8644330000000053 85.8630289999999974 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632510000000053 85.8631290000000007 85.8610460000000018 85.8604890000000012 85.8618929999999949 85.859893999999997 85.8748250000000013 85.9636540000000053 86.0452350000000052 86.110320999999999 86.2062609999999978 86.2908330000000063 86.3825839999999943 86.4776379999999989 86.5478059999999942 86.6381679999999932 86.7129900000000049 86.7983700000000056 86.9021610000000067 87.0350569999999948 86.9187929999999938 86.0830310000000054 85.8352809999999948 85.8327259999999939 85.8337479999999999 85.8269810000000035 85.8058850000000035 85.8020939999999968 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.802245
9999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8017119999999949 85.7802049999999952 85.8777850000000029 86.266327000000004 86.7114720000000005 87.130675999999994 87.291411999999994 87.2997359999999958 87.3282999999999987 87.4142460000000057 87.5073469999999958 87.4311069999999972 87.5143199999999979 87.8369139999999931 88.0552979999999934 88.3937760000000026 89.1084440000000058 90.0352100000000064 91.1224590000000063 92.4207839999999976 93.7193529999999981 95.0093770000000006 96.1028440000000046 97.0638200000000069 97.9794080000000065 98.6655810000000031 99.0521999999999991 99.144165000000001 99.2386400000000037 99.3905560000000037 99.4508900000000011 99.648894999999996 99.8375319999999959 100
.0740279999999984 100.4412990000000008 101.0211939999999942 101.4513400000000019 101.6754909999999938 101.7730329999999981 101.8387069999999994 101.6820450000000022 101.296363999999997 100.9295269999999931 100.5006640000000004 99.9166639999999973 99.348267000000007 99.0047840000000008 98.9734270000000009 99.0544050000000027 99.2266919999999999 99.2099299999999999 98.707099999999997 97.9856340000000046 97.2600939999999952 96.7534409999999951 96.4932479999999941 96.1961060000000003
+114.1640170000000012 114.4324419999999947 114.7619399999999956 115.0668490000000048 115.1022260000000017 114.9011079999999936 114.3893049999999931 113.6062929999999938 112.4915919999999971 111.0782779999999974 109.4288710000000009 107.5633469999999932 105.4093929999999943 102.8160170000000022 100.4485240000000061 99.1940610000000049 99.9267040000000009 102.3646470000000051 104.9553149999999988 106.9377980000000008 108.2760700000000043 109.207451000000006 109.9413449999999983 110.5116809999999958 111.0628590000000031 111.5680689999999942 111.7164839999999941 111.7053149999999988 111.6281359999999978 111.5288769999999943 110.5219270000000051 107.5206759999999946 102.9505460000000028 97.9702300000000008 93.4641040000000061 88.8976899999999972 86.5480189999999965 86.3391340000000014 86.2570500000000067 86.2246860000000055 86.314148000000003 86.3489150000000052 86.2482990000000029 86.1870959999999968 86.1985470000000049 86.1845699999999937 86.1955109999999962 86.1989439999999973
86.1985169999999954 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1987380000000059 86.1969990000000053 86.1782230000000027 86.1684489999999954 86.1537399999999991 86.132323999999997 86.1130749999999949 86.1000669999999957 86.0818019999999962 86.0657810000000012 86.046356000000003 86.045897999999994 86.0262299999999982 86.0055919999999929 85.9894259999999946 85.985084999999998 85.9860079999999982 85.9256969999999995 85.927314999999993 86.9906390000000016 89.3753889999999984 91.4879459999999938 92.5627060000000057 92.919548000000006 92.5442050000000052 91.993340000000
0034 91.4975280000000026 88.858672999999996 85.9648509999999959 85.7967680000000001 85.8942490000000021 85.894683999999998 85.8891370000000052 85.8697659999999985 85.8630220000000008 85.8631819999999948 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8631440000000055 85.8624039999999979 85.8618089999999938 85.8607180000000056 85.8665620000000018 85.8808209999999974 85.9167630000000031 85.9795840000000027 86.0610350000000039 86.1449360000000013 86.2571789999999936 86.3417210000000068 86.4102100000000064 86.4984819999999957 86.579070999999999 86.6756519999999995 86.8139800000000008 86.7318190000000016 86.0463100000000054 85.8351590000000044 85.8327259999999939 85.8337479999999999 85.8268659999999954 85.8058240000000012 85.8020860000000027 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022
459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8019409999999993 85.8535310000000038 86.1352920000000069 86.4165799999999962 86.7549510000000055 87.0849759999999975 87.1103739999999931 87.1161270000000059 87.1942829999999987 87.2766419999999954 87.2693179999999984 87.2400049999999965 87.3612289999999945 87.7157360000000068 87.9767149999999987 88.1700670000000031 88.6625209999999981 89.6172940000000011 90.7186970000000059 92.0310589999999991 93.4547960000000018 94.8715059999999966 96.0921709999999933 97.1105579999999975 97.8357850000000013 98.4079360000000065 98.7331089999999989 98.6982569999999981 98.7086410000000001 98.739372000000003 98.6781229999999994 98.72503700000000
04 98.8773350000000022 99.0678180000000026 99.4851230000000015 100.1036220000000014 100.482726999999997 100.7015150000000006 100.8398360000000054 100.8763430000000056 100.779601999999997 100.4765550000000047 100.1170649999999966 99.7897719999999993 99.3145899999999955 98.8656540000000064 98.6561200000000014 98.5806050000000056 98.5528560000000056 98.7162550000000039 98.5808329999999984 97.9407420000000002 97.300171000000006 96.711143000000007 96.3758469999999932 96.2786329999999992 96.0231320000000039
+114.8161010000000033 114.9669880000000006 115.1686169999999976 115.3578720000000004 115.3471370000000036 115.0343859999999978 114.4185939999999988 113.5523529999999965 112.3954470000000043 110.6705249999999978 108.1525340000000028 105.7589339999999964 103.4776839999999964 101.6067120000000017 100.7606810000000053 100.1973650000000049 100.3177110000000027 101.9060130000000015 104.2761840000000007 106.3432999999999993 108.2310410000000047 109.525786999999994 110.2888109999999955 110.9662019999999956 111.527869999999993 111.9526670000000053 112.1957929999999948 112.3273240000000044 112.2186509999999942 111.9353559999999987 111.1504439999999931 109.2368850000000009 105.612639999999999 100.7890620000000013 96.2149809999999945 91.1481320000000039 87.3762509999999963 86.6302189999999968 86.5747530000000012 86.5264130000000051 86.624968999999993 86.5931700000000006 86.4310609999999997 86.3827210000000036 86.3271940000000058 86.2228159999999946 86.1976549999999975 86.1942140000000023
86.1987299999999976 86.1985320000000002 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1985020000000048 86.1916350000000051 86.1724169999999958 86.1625439999999969 86.1437070000000062 86.1224440000000016 86.1070330000000013 86.0988920000000064 86.0819019999999995 86.0648879999999963 86.0512159999999966 86.0397420000000039 86.0130159999999933 85.9887240000000048 85.9840090000000004 85.9851680000000016 85.9854430000000036 85.9608080000000001 85.8609009999999984 85.9360120000000052 87.2916409999999985 89.0888819999999981 90.0697710000000029 90.8632510000000053 91.464539000000002 91.945801
000000003 91.9000929999999983 88.3837429999999955 85.8646700000000038 85.8643650000000065 85.8937070000000062 85.8899459999999948 85.8719410000000067 85.8610000000000042 85.8628920000000022 85.8632130000000018 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8633420000000029 85.862922999999995 85.858161999999993 85.8509140000000031 85.8521350000000041 85.846855000000005 85.8737639999999942 85.9411999999999949 86.0313110000000023 86.1154480000000007 86.1839829999999978 86.272469000000001 86.3688960000000066 86.4489590000000021 86.5892489999999952 86.5428090000000054 85.9972379999999958 85.834259000000003 85.8327179999999998 85.8339390000000009 85.8288569999999993 85.8066100000000063 85.8020479999999992 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8
022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8070909999999998 85.9847560000000044 86.4091870000000029 86.5269849999999963 86.6061710000000033 86.7752909999999957 86.7815930000000009 86.8236619999999988 86.917823999999996 87.0531160000000028 87.0000529999999941 86.9937129999999996 87.2309719999999942 87.5829700000000031 87.8885960000000068 88.1207430000000045 88.5055160000000001 89.3540339999999986 90.5186690000000027 92.0378110000000049 93.5837709999999987 94.9756239999999963 96.2450330000000065 97.1675259999999952 97.7425539999999984 98.1715240000000051 98.2949600000000032 98.1660459999999944 98.0434489999999954 97.9899139999999989 97.9562150000000003 97.78390500000
00043 97.9580380000000019 98.1818080000000037 98.5957030000000003 99.0865940000000052 99.4715190000000007 99.7515410000000031 99.800926000000004 99.8212130000000002 99.8454210000000018 99.7282260000000065 99.421875 99.0257029999999929 98.6119840000000067 98.395629999999997 98.3481139999999954 98.2019269999999977 97.9897380000000027 97.815804 97.617249000000001 97.1145250000000004 96.4447859999999935 96.0059049999999985 95.8713300000000004 95.9418790000000001 95.7062609999999978
+115.3574600000000032 115.4198149999999998 115.5273509999999959 115.6213149999999956 115.4998020000000025 115.0987240000000043 114.4602200000000067 113.5320969999999932 112.2114329999999995 109.8782879999999977 106.6029510000000045 104.1599879999999985 102.6434480000000065 102.0777510000000063 102.5663760000000053 102.1745990000000006 101.2217940000000027 101.4391860000000065 103.4391779999999983 105.1751249999999942 107.3341599999999971 109.4384610000000038 110.471855000000005 111.2967150000000061 111.8128889999999984 112.2564239999999955 112.669708 112.8022380000000027 112.5079350000000034 112.0147780000000068 111.2323679999999939 110.1128690000000034 107.9434130000000067 104.1064530000000019 99.8154600000000016 94.7967909999999989 89.6316680000000048 87.292580000000001 87.0691070000000025 87.1758800000000065 87.1523130000000066 86.986534000000006 86.8050690000000031 86.7920150000000064 86.660767000000007 86.4596099999999979 86.2734449999999953 86.1904370000000029 86.194159
9999999966 86.1970519999999993 86.1977920000000069 86.1985169999999954 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1973270000000014 86.1804280000000063 86.1686629999999951 86.1553959999999961 86.1394499999999965 86.1195139999999952 86.101356999999993 86.0848540000000071 86.0762789999999995 86.081665000000001 86.0548550000000034 86.0051650000000052 85.9873889999999932 85.9841540000000037 85.984893999999997 85.9857099999999974 85.9809340000000049 85.9605789999999956 85.9664460000000048 85.8381349999999941 85.9523470000000032 86.4166490000000067 86.5648649999999975 87.5083159999999936 90.0691910000000036 92.1841809999999953 9
2.2094799999999992 88.0287249999999943 85.7153930000000059 85.8708189999999973 85.8950499999999977 85.8799510000000055 85.860320999999999 85.8627170000000035 85.8632510000000053 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632130000000018 85.8639679999999998 85.857758000000004 85.8304059999999964 85.8192140000000023 85.8395770000000056 85.8658290000000051 85.9088590000000067 85.9666670000000011 86.0443039999999968 86.1501999999999981 86.235596000000001 86.3628080000000011 86.3534619999999933 85.9514159999999947 85.8334959999999967 85.8327479999999952 85.8329700000000031 85.8233409999999992 85.8048629999999974 85.8021090000000015 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999
999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8057859999999977 85.9341739999999987 86.275299000000004 86.4318159999999978 86.4278410000000008 86.522246999999993 86.611725000000007 86.6265640000000019 86.6303020000000004 86.6694339999999954 86.6483690000000024 86.8067170000000061 87.0912479999999931 87.4101330000000019 87.7232209999999952 88.0760729999999938 88.5850520000000046 89.3841400000000021 90.5758670000000023 92.1020050000000055 93.7262570000000039 95.2040410000000037 96.5405499999999961 97.311119000000005 97.6859359999999981 97.9487459999999999 98.001884000000004 97.6272739999999999 97.2482990000000029 97.2428050000000042 97.1979749999999996 97.0031589999999966 97.0978
929999999991 97.3934480000000065 97.7645420000000058 98.0297319999999957 98.387084999999999 98.7420120000000026 98.7409669999999977 98.7802350000000047 98.9252170000000035 98.9551699999999954 98.6750339999999966 98.3153460000000052 98.0886380000000031 97.9338000000000051 97.785065000000003 97.5714949999999988 97.2250439999999969 96.7477800000000059 96.4947659999999985 96.1521840000000054 95.676368999999994 95.5216450000000066 95.5065840000000037 95.4160459999999944 95.1901170000000008
+115.7497410000000002 115.834023000000002 115.8991089999999957 115.8558730000000025 115.6469799999999992 115.1976089999999999 114.4770129999999995 113.5815120000000036 112.335448999999997 109.7061230000000052 106.2952959999999933 104.4190289999999948 103.8732380000000006 103.9702450000000056 104.7615810000000067 104.6688539999999961 103.4088820000000055 102.3069150000000036 103.4697189999999978 104.8208620000000053 106.6213529999999992 109.2288279999999929 110.6746289999999959 111.5182949999999948 112.0302120000000059 112.5717700000000008 112.9730830000000026 112.977965999999995 112.5805440000000033 111.9593579999999946 111.0673749999999984 110.144165000000001 108.9155729999999949 106.6878659999999996 103.7635729999999938 99.4359510000000029 93.4702680000000043 89.0609740000000016 87.8127369999999985 87.8953400000000045 87.8518830000000008 87.6542050000000046 87.4186329999999998 87.2226409999999959 87.058684999999997 86.8519519999999972 86.520622000000003 86.2669369999999986
86.1956859999999949 86.1996919999999989 86.2013929999999959 86.1983800000000002 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984559999999931 86.1973500000000001 86.1759030000000052 86.1632539999999949 86.1457599999999957 86.1376719999999949 86.1185229999999962 86.101508999999993 86.0854870000000005 86.079063000000005 86.0703280000000035 86.0191350000000057 85.9795759999999945 85.9823990000000009 85.9849399999999946 85.9857860000000045 85.9845889999999997 85.9667359999999974 85.9541090000000025 85.9584430000000026 85.9553219999999953 85.7791820000000058 85.6068649999999991 85.3923110000000065 85.8250050000000044 89.1296389999999974 92.70050799
99999992 92.422118999999995 87.7829899999999981 85.691040000000001 85.888733000000002 85.8946530000000052 85.8711090000000041 85.8609699999999947 85.8632970000000029 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8633039999999994 85.8635479999999944 85.8521420000000006 85.8337779999999952 85.8266979999999933 85.8216780000000057 85.8257059999999967 85.8357620000000026 85.8721010000000007 85.9396969999999953 86.0065230000000014 86.1073609999999974 86.1464310000000069 85.912895000000006 85.8335270000000037 85.8329389999999961 85.8313140000000061 85.8118819999999971 85.8016740000000055 85.8022229999999979 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8
022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8025130000000047 85.8121799999999979 85.9234770000000054 86.0859760000000023 86.1382449999999977 86.2413329999999974 86.4029239999999987 86.4739909999999981 86.4626010000000065 86.3936080000000004 86.4243929999999949 86.6485289999999964 86.8846589999999992 87.1576539999999937 87.4736630000000019 88.0372090000000043 88.7573469999999958 89.6573029999999989 90.8721689999999995 92.2709200000000038 93.8608629999999948 95.4115680000000026 96.6760100000000051 97.3813860000000062 97.6947329999999994 97.8601759999999956 97.8136599999999987 97.1733859999999936 96.6137700000000024 96.502319 96.3647380000000027 96.2396930000000026 96.
3535389999999978 96.6481169999999992 96.9090649999999982 97.152000000000001 97.3601610000000051 97.6157910000000015 97.7834239999999966 97.9046479999999946 98.073646999999994 98.2289810000000045 98.0232769999999931 97.807982999999993 97.7540889999999933 97.4463350000000048 97.0760800000000046 96.8019790000000029 96.4369429999999994 95.9075700000000069 95.5438539999999961 95.3139039999999937 95.1132810000000006 95.1009140000000031 95.0558089999999964 94.7292400000000043 94.5974120000000056
+115.9691470000000066 116.0540919999999971 116.1208189999999973 116.0658949999999976 115.8379970000000014 115.3410030000000006 114.5155330000000049 113.6366040000000055 112.6073070000000058 110.2982410000000044 107.1950149999999979 106.2426990000000018 106.3712539999999933 106.3057019999999966 106.8973309999999941 107.0642009999999971 105.9419560000000047 104.0553589999999957 103.8293299999999988 105.0362010000000055 106.7075580000000059 109.2989350000000002 110.8429490000000044 111.5895309999999938 112.2172470000000004 112.8333360000000027 113.1685329999999965 113.0153349999999932 112.5537259999999975 111.9570920000000029 110.8725199999999944 109.5922850000000039 108.3658829999999966 107.045219000000003 105.6471099999999979 102.9280320000000017 97.9422990000000055 92.9774089999999944 89.934937000000005 88.8715059999999966 88.702881000000005 88.5308380000000028 88.1477660000000043 87.6996379999999931 87.4257580000000019 87.2217030000000051 86.8634109999999993 86.4732280000000
06 86.2580949999999973 86.2252880000000062 86.2056350000000009 86.1985629999999929 86.1984630000000038 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.198607999999993 86.19529 86.1762159999999966 86.1571730000000002 86.1409450000000021 86.1278530000000018 86.1077650000000006 86.1090470000000039 86.1045840000000027 86.0686259999999947 86.0156630000000035 85.9834900000000033 85.9839020000000005 85.9853360000000038 85.9853739999999931 85.9851230000000015 85.9716640000000041 85.9527819999999991 85.9550399999999968 85.9567490000000021 85.9484860000000026 85.9146879999999982 85.9051359999999988 85.7741390000000052 85.8387299999999982 89.0457229999999953 93.206954999999993
6 92.8859250000000003 88.0392530000000022 85.5368349999999964 85.8106609999999961 85.8933719999999994 85.8633959999999945 85.8628309999999999 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8631740000000008 85.8649290000000036 85.8585280000000068 85.8360210000000023 85.8325880000000012 85.8320619999999934 85.829773000000003 85.8211210000000051 85.821312000000006 85.8333970000000051 85.8472440000000034 85.8900150000000053 85.9382630000000063 85.8637389999999954 85.8331529999999958 85.8326720000000023 85.8257059999999967 85.8049319999999938 85.8012080000000026 85.8022540000000049 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.802245
9999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8021320000000003 85.7912290000000013 85.7872540000000043 85.8271330000000034 85.844727000000006 85.8968809999999934 86.0186389999999932 86.1656190000000066 86.2643199999999979 86.3360600000000034 86.4657519999999948 86.5107270000000028 86.6266860000000065 86.8638380000000012 87.2006530000000026 87.9890209999999939 88.9567720000000008 90.0147630000000021 91.2811360000000036 92.6031880000000029 93.9794849999999968 95.3698349999999948 96.4468839999999972 97.2030869999999965 97.5678099999999944 97.6869740000000064 97.4705119999999994 96.6917720000000003 96.0164719999999932 95.5955199999999934 95.3879699999999957 95.4422990000000055
95.7300570000000022 95.8254469999999969 95.926201000000006 96.0795590000000033 96.189667 96.4529799999999966 96.7791210000000035 96.9866410000000059 97.1705400000000026 97.4647980000000018 97.4603270000000066 97.3295970000000068 97.2129439999999931 96.897469000000001 96.543571 96.1369169999999968 95.703559999999996 95.1983029999999957 94.758018000000007 94.5903849999999977 94.543526 94.5882569999999987 94.5348659999999938 94.2157360000000068 94.1838000000000051
+115.9514080000000007 116.0847320000000025 116.1632840000000044 116.1833500000000043 115.9941939999999931 115.5365979999999979 114.7848589999999973 113.9284289999999942 112.7581179999999961 110.5758969999999977 108.6111829999999969 108.7297970000000049 108.9072110000000038 108.6357419999999934 108.9204249999999945 108.9102780000000052 107.9694140000000004 106.0042720000000003 104.6530989999999974 105.1775209999999987 107.1019059999999996 109.7053070000000048 111.065369000000004 111.7207570000000061 112.2720570000000038 112.8653489999999948 113.2260969999999958 113.0034100000000024 112.5593570000000057 111.9395219999999966 110.6724779999999981 108.9098359999999985 107.0931700000000006 105.1760560000000027 104.1800000000000068 103.2554930000000013 100.6815799999999967 97.2055589999999938 93.6193999999999988 90.7643130000000014 89.4893339999999995 89.2492220000000032 88.7496799999999979 88.2127459999999957 87.8002929999999964 87.524872000000002 87.1867830000000055 86.78456900000
00047 86.433952000000005 86.2964099999999945 86.222099 86.1968609999999984 86.1972959999999944 86.1892699999999934 86.1880259999999936 86.1927189999999968 86.1610790000000009 86.1307910000000021 86.1531300000000044 86.1815030000000064 86.195342999999994 86.1996989999999954 86.1983409999999992 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984329999999943 86.1996230000000025 86.1862339999999989 86.1655039999999985 86.1462779999999952 86.1395569999999964 86.1256329999999934 86.1107410000000044 86.1053390000000007 86.084259000000003 86.0216669999999937 85.9806059999999945 85.9839020000000005 85.9853360000000038 85.985084999999998 85.9869000000000057 85.9796220000000062 85.9552079999999989 85.9541550000000001 85.9531939999999963 85.9471439999999944 85.9332729999999998 85.9098280000000045 85.8882370000000037 85.6844099999999997 86.4868469999999974 90.2577969999999965 93.89363099999999
92 93.7859190000000069 89.5689540000000051 85.8727949999999964 85.4926300000000055 85.7586060000000003 85.8810040000000043 85.8651579999999939 85.862679 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8647919999999942 85.855323999999996 85.8344040000000064 85.8326950000000011 85.8327259999999939 85.8326720000000023 85.8334880000000027 85.8318019999999962 85.8268360000000001 85.8212589999999977 85.8191680000000048 85.8317339999999973 85.8326870000000071 85.8327100000000058 85.8316269999999975 85.8139879999999948 85.8014299999999963 85.8020860000000027 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.80224599999999
67 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8021090000000015 85.8030009999999947 85.8034130000000062 85.8021549999999991 85.8030399999999958 85.7994460000000032 85.7892609999999962 85.775825999999995 85.7771680000000032 85.7983930000000043 85.8554610000000054 85.9553149999999988 86.1335679999999968 86.408576999999994 86.4777830000000023 86.4496460000000013 86.5995860000000022 86.9632950000000022 87.8207859999999982 89.060096999999999 90.2456049999999976 91.5142139999999955 92.7698209999999932 93.948120000000003 95.0994720000000058 95.9309460000000058 96.6708600000000047 97.1254430000000042 97.2593459999999936 97.0146560000000022 96.2237630000000053 95.4951549999999969 95.0294800000000066 94.8078990000000061 94.811522999999994 95.02521500
00000029 94.9724960000000067 94.8125529999999941 94.6836009999999959 94.9018630000000059 95.289268000000007 95.6840129999999931 95.9457400000000007 96.1701350000000019 96.5540009999999995 96.6743620000000021 96.5393519999999938 96.4392780000000016 96.2612459999999999 96.0147400000000033 95.6014250000000061 95.1242830000000055 94.5164110000000051 94.010895000000005 93.9154209999999949 94.0164570000000026 94.1407700000000034 94.0541309999999982 93.8100429999999932 93.9074779999999976
+115.9561460000000039 116.1381679999999932 116.2290799999999962 116.2567209999999989 116.1153110000000055 115.7393569999999983 115.1210480000000018 114.341148000000004 113.1364590000000021 111.5113070000000022 110.8091129999999964 110.9535750000000007 110.7780079999999998 110.4849619999999959 110.4562070000000062 110.1961749999999967 109.6324390000000051 108.2773669999999981 106.660743999999994 105.9597629999999953 107.3150789999999972 109.8246610000000061 111.3156809999999979 111.968742000000006 112.3699490000000054 112.9234770000000054 113.2184680000000014 112.8107830000000007 112.2987439999999992 111.5494000000000057 110.1802899999999994 108.4313740000000053 106.4009630000000044 103.4373020000000025 101.3190230000000014 100.5950700000000069 99.3460010000000011 97.3753509999999949 94.8060530000000057 91.964264 90.1329190000000011 89.6559599999999932 89.1294479999999965 88.565804 88.1390690000000063 87.8942109999999985 87.6782460000000015 87.3432080000000042 86.8245390000000
015 86.4855799999999988 86.3030619999999971 86.1771930000000026 86.1928020000000004 86.2034299999999973 86.1818470000000048 86.0986630000000019 86.1482390000000038 86.2688670000000002 86.2184519999999992 86.1779400000000066 86.1826860000000039 86.1840590000000049 86.2015530000000041 86.1982730000000004 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1986770000000035 86.198607999999993 86.1772840000000002 86.1614529999999945 86.1428829999999977 86.1373439999999988 86.1377719999999982 86.1154630000000054 86.0708920000000006 86.0204999999999984 85.9848790000000065 85.9840549999999979 85.9851299999999981 85.9851149999999933 85.9854129999999941 85.9877699999999976 85.9711300000000023 85.9541320000000013 85.9520190000000071 85.9365159999999975 85.927818000000002 85.9250490000000013 85.9137269999999944 85.8384400000000056 86.0949549999999988 88.635161999999994 92.6112519999999932 94.9113239999999934 94.81812
99999999965 92.3935469999999981 88.569344000000001 86.4440380000000062 85.7199860000000058 85.7132799999999975 85.8721539999999948 85.8769609999999943 85.8620530000000031 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8644180000000006 85.8577729999999946 85.8377689999999944 85.8327639999999974 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8328020000000009 85.8311230000000052 85.8271029999999939 85.8311159999999944 85.8326490000000035 85.8320920000000029 85.810149999999993 85.7997359999999958 85.802306999999999 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967
85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.802338000000006 85.8036799999999999 85.804893000000007 85.8014679999999998 85.8000339999999966 85.8044510000000002 85.8044969999999978 85.802306999999999 85.7993009999999998 85.8048320000000047 85.8032759999999968 85.7929079999999971 85.7788160000000062 85.7981340000000046 85.8263699999999972 86.0583570000000009 86.2766189999999966 86.2942120000000017 86.4678499999999985 86.8183439999999962 87.516052000000002 88.8484569999999962 90.1223600000000005 91.3301320000000061 92.5118640000000028 93.6026229999999941 94.6078799999999944 95.2079540000000009 95.8134689999999978 96.4257350000000031 96.8031689999999969 96.510863999999998 95.6641309999999976 94.949744999999993 94.7647400000000033 94.708320999999998 94.3571089999999941 94.1545179999999
959 93.995506000000006 93.7830579999999969 93.5360029999999938 93.7354129999999941 94.0890430000000038 94.4224399999999946 94.8193739999999963 95.2126849999999934 95.6332929999999948 95.7813720000000046 95.723906999999997 95.669548000000006 95.5182879999999983 95.4021529999999984 95.2013319999999936 94.681358000000003 93.92971 93.4333879999999937 93.4081800000000015 93.527434999999997 93.5497890000000041 93.4411390000000068 93.4669569999999936 93.8724670000000003
+115.9369350000000054 116.1933899999999937 116.3108370000000065 116.3347550000000012 116.2368009999999998 115.9152370000000047 115.3895949999999999 114.7322999999999951 113.8697200000000009 113.1328960000000023 112.6701130000000006 112.2185589999999991 111.9065089999999998 111.6961289999999991 111.5327840000000066 111.2197110000000038 110.9057849999999945 110.241455000000002 108.8294139999999999 107.2052460000000025 107.3002780000000058 109.639435000000006 111.5243679999999955 112.2417449999999945 112.6683120000000002 113.0775380000000041 113.1637570000000039 112.5573200000000043 111.8154449999999969 110.9187770000000057 109.5813519999999954 108.0732730000000004 106.2417219999999958 103.1674419999999941 99.7984540000000067 97.7546690000000069 96.0842059999999947 94.3402329999999978 92.9484479999999991 92.0134350000000012 91.2190169999999938 90.2316820000000064 89.3146210000000025 88.7753220000000027 88.4991299999999939 88.3498539999999934 88.2588729999999941 88.02924299999999
39 87.5147780000000068 86.9125140000000016 86.4614409999999936 86.2234650000000045 86.2555389999999989 86.5401690000000059 86.6527860000000061 86.7647019999999998 87.8279189999999943 88.5276790000000062 87.8285829999999947 86.8607250000000022 86.3161390000000068 86.1869659999999982 86.1936039999999934 86.1995009999999979 86.1984939999999966 86.1984939999999966 86.1984939999999966 86.1985779999999977 86.1990509999999972 86.1990049999999997 86.2002939999999995 86.1898350000000022 86.1697769999999963 86.167548999999994 86.1595310000000012 86.1426850000000002 86.1247479999999968 86.073639 86.0202179999999998 85.9850229999999982 85.9827729999999946 85.9851529999999968 85.9851299999999981 85.9851840000000038 85.9856189999999998 85.9794160000000005 85.9613339999999937 85.9542239999999964 85.9380419999999958 85.9213409999999982 85.922393999999997 85.9276890000000009 85.9045260000000042 85.8123549999999966 87.4587549999999965 91.7019420000000025 94.8463059999999984 95.752037000000001
4 95.7012859999999961 94.9043049999999937 92.8169560000000047 90.130188000000004 87.3907549999999986 85.8328779999999938 85.6377640000000042 85.7791749999999951 85.8769680000000051 85.8649290000000036 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8634490000000028 85.8639679999999998 85.8494340000000022 85.8331069999999983 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.832886000000002 85.8292919999999953 85.809394999999995 85.8005449999999996 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459
999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8021320000000003 85.8029480000000007 85.8039399999999972 85.7988509999999991 85.797302000000002 85.7890699999999953 85.7844240000000013 85.7978360000000038 85.7970959999999963 85.7915650000000056 85.7827759999999984 85.7954029999999932 85.7961119999999937 85.7969819999999999 85.8034360000000049 85.7996059999999972 85.7635120000000057 85.7928849999999983 85.8857730000000004 85.9976580000000013 86.2269440000000031 86.4885940000000062 87.0439910000000054 88.3105699999999985 89.5939869999999985 90.6672899999999942 91.7003629999999958 92.6846239999999995 93.5526729999999986 94.1345290000000006 94.7501450000000034 95.5639800000000008 96.3314589999999953 96.0781479999999988 95.1347119999999933 94.3847729999999956 94.3037489999999963 94.3169249999999977 93.8760220000000061
93.4503100000000018 93.2036209999999983 93.0051040000000029 92.7224960000000067 92.6490859999999969 92.8681490000000025 93.1802830000000029 93.8036040000000071 94.4095080000000024 94.9014590000000027 95.0989150000000052 95.071280999999999 94.9034879999999958 94.7571870000000018 94.7729190000000017 94.6724700000000041 94.1409529999999961 93.4328919999999954 92.9794849999999968 92.9482119999999981 92.9137340000000052 92.8011549999999943 92.9156880000000029 93.3469850000000037 93.9727859999999993
+115.8265530000000041 116.1113890000000026 116.276061999999996 116.3726429999999965 116.3102489999999989 116.0310360000000003 115.6712880000000041 115.203125 114.6509929999999997 114.139411999999993 113.5843119999999971 113.1635509999999982 112.854896999999994 112.6370090000000062 112.4786299999999954 112.2268980000000056 111.9981769999999983 111.5391460000000023 110.3566280000000006 108.6256790000000052 107.904633000000004 109.9264679999999998 111.8238220000000069 112.5268709999999999 112.9757769999999937 113.1660229999999956 112.9552230000000037 112.2322769999999963 111.3679730000000063 110.3579029999999932 109.0947570000000013 107.4553300000000036 105.3691790000000026 102.3944170000000042 98.8229220000000055 95.8973770000000059 94.1002809999999954 93.5183719999999994 94.4163889999999952 94.845123000000001 93.8125150000000048 91.4645689999999973 89.594184999999996 88.9785459999999944 88.9421159999999986 88.862755000000007 88.7511599999999987 88.5168529999999976 88.158835999
9999938 87.5564729999999969 86.958122000000003 86.6711959999999948 86.7096630000000062 87.6072769999999963 88.5275649999999956 90.3192290000000071 93.5735700000000037 94.5585169999999948 92.5541230000000041 89.5097430000000003 87.2927090000000021 86.4640270000000015 86.1000290000000064 86.205719000000002 86.2000730000000033 86.1969679999999983 86.1953280000000035 86.1933750000000032 86.1888050000000021 86.1881790000000052 86.1961670000000026 86.1852800000000059 86.1671300000000002 86.1691509999999994 86.1672970000000049 86.1365129999999937 86.0809100000000029 86.0116419999999948 85.9864039999999932 85.9845580000000069 85.9849169999999958 85.9851380000000063 85.9851299999999981 85.9855730000000023 85.9834589999999963 85.9632110000000011 85.9536290000000065 85.9435119999999984 85.9226149999999933 85.9235759999999971 85.9259569999999968 85.9214709999999968 85.8497919999999937 86.3448719999999952 89.8757779999999968 94.6244350000000054 96.3963619999999963 96.3337169999999929 96.
4990389999999962 96.1342700000000008 95.5353700000000003 93.9872819999999933 91.1522449999999935 87.8582459999999941 85.9793169999999947 85.7112500000000068 85.734650000000002 85.8078380000000038 85.8400649999999956 85.8636089999999967 85.8648680000000013 85.8630749999999949 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8631129999999985 85.8657680000000028 85.8556669999999968 85.8333659999999981 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8326339999999988 85.8342059999999947 85.8201140000000038 85.8015369999999962 85.8019100000000066 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999
999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8021849999999944 85.8025279999999952 85.8042140000000018 85.8016130000000032 85.7954409999999967 85.782630999999995 85.7772060000000067 85.7743150000000014 85.7718660000000028 85.7786640000000062 85.7780079999999998 85.775574000000006 85.7711259999999953 85.7774200000000064 85.7773669999999981 85.7787320000000051 85.7919459999999958 85.8000030000000038 85.8090969999999942 85.7650529999999947 85.7268370000000033 85.7440869999999933 85.8343200000000053 85.9476779999999962 86.3179700000000025 87.3040239999999983 88.5429529999999971 89.5176320000000061 90.3985600000000034 91.3020779999999945 92.1452940000000069 92.8232189999999946 93.5074690000000004 94.4535450000000054 95.4264299999999963 95.5865100000000041 94.7909010000000052 94.0333399999999955 93.7398220000000038 93.4587329999999952 93.2346569999999986 92.9
919280000000015 92.7738109999999949 92.4464490000000012 92.1148220000000038 91.9144900000000007 92.0219730000000027 92.3995359999999977 93.1256029999999981 93.8067779999999942 94.3103789999999975 94.3857500000000016 94.1739960000000025 93.961669999999998 93.9887999999999977 94.0674439999999947 93.8894420000000025 93.421363999999997 92.9221880000000056 92.4899290000000036 92.298088000000007 92.2463000000000051 92.3800350000000066 92.8370510000000024 93.292823999999996 93.7955469999999991
+115.606780999999998 115.8944850000000031 116.1445850000000064 116.355559999999997 116.3625949999999989 116.1416399999999953 115.9459760000000017 115.6526719999999955 115.2815779999999961 114.7879709999999989 114.3669890000000038 114.0278469999999942 113.7412869999999998 113.5361630000000019 113.3964689999999962 113.2521820000000048 113.0852809999999948 112.6144029999999958 111.5045850000000058 109.9022829999999971 109.0886150000000043 110.7404400000000066 112.2979739999999964 112.8599240000000066 113.1568979999999982 113.1432800000000043 112.5918730000000068 111.5971909999999951 110.537895000000006 109.4213869999999957 108.0559999999999974 106.0107880000000051 103.5333940000000013 100.3995740000000012 97.084937999999994 94.8618850000000009 95.3227159999999998 97.2973630000000043 99.2632449999999977 99.2602080000000058 96.4170680000000004 92.4733509999999939 90.1469879999999932 89.3788760000000053 89.5173949999999934 89.4928050000000042 89.2410739999999976 88.8900380000000041
88.5678630000000027 88.2135700000000043 87.8706279999999964 87.6864240000000024 87.9794160000000005 89.3433840000000004 91.6167980000000028 95.3576659999999947 99.998778999999999 101.2501680000000022 98.0552899999999994 93.6753920000000022 90.0125730000000033 87.5690000000000026 86.1510999999999996 86.1633759999999995 86.1779250000000019 86.1972200000000015 86.204346000000001 86.2072909999999979 86.2083509999999933 86.2125319999999959 86.1982880000000051 86.1856230000000068 86.1763080000000059 86.1635279999999995 86.1336440000000039 86.0885470000000055 86.0306470000000019 85.9849169999999958 85.9825519999999983 85.9850160000000017 85.9851840000000038 85.9851299999999981 85.9851380000000063 85.9859160000000031 85.978431999999998 85.9586790000000036 85.9493789999999933 85.9257350000000031 85.9233399999999961 85.9252469999999988 85.9210510000000056 85.9037479999999931 85.7736210000000057 87.7243880000000047 92.6462250000000012 96.7752610000000004 97.4119720000000058 96.9264759
999999939 97.2785489999999982 96.9991380000000021 96.701667999999998 95.8958439999999968 94.2260670000000005 91.3032149999999945 88.5682299999999998 86.9746020000000044 86.0273820000000029 85.9249269999999967 85.9004060000000038 85.8291169999999966 85.8518830000000008 85.8660050000000012 85.863158999999996 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.863190000000003 85.8633350000000064 85.8663250000000033 85.8546750000000003 85.8333590000000015 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8329700000000031 85.8327560000000034 85.8112720000000024 85.7997510000000005 85.8023759999999953 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85
.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022160000000014 85.8031849999999991 85.8042679999999933 85.8028869999999984 85.799469000000002 85.7891309999999976 85.7767029999999977 85.7713700000000046 85.7691039999999987 85.770545999999996 85.7711489999999941 85.7694850000000031 85.7696300000000065 85.7702409999999986 85.7713389999999976 85.7697979999999944 85.7697679999999991 85.7704700000000031 85.7743150000000014 85.784546000000006 85.792381000000006 85.7756650000000036 85.7447659999999985 85.6928939999999955 85.6758580000000052 85.6902919999999995 85.7278979999999962 86.1248549999999966 86.9912340000000057 87.769867000000005 88.6246189999999956 89.7494429999999994 90.7915119999999973 91.5542070000000052 92.2219769999999954 93.0525279999999952 93.901732999999993 94.5408630000000016 94.3829570000000047 93.6712270000000018 93.0128100000000018 92.6225660000000062 92.52934299999999
72 92.5074999999999932 92.4937589999999972 92.2477949999999964 91.9649050000000017 91.7937469999999962 91.8074419999999947 92.0498500000000064 92.6098180000000042 93.2199860000000058 93.5907820000000044 93.3992159999999956 93.0338820000000055 92.9644470000000069 93.1427230000000037 93.1695330000000013 92.9693369999999959 92.6491999999999933 92.4090190000000007 91.9509740000000022 91.6680300000000017 91.9556120000000021 92.3289869999999979 92.8523030000000063 93.2003629999999958 93.4946520000000021
+115.3144680000000051 115.5725170000000048 115.8132399999999933 116.0397260000000017 116.1543499999999938 116.1472239999999942 116.1229399999999998 115.9516529999999932 115.7997589999999946 115.6000750000000039 115.2349090000000018 114.8595279999999974 114.6308590000000009 114.4573520000000002 114.3304820000000035 114.1508479999999963 113.9402469999999994 113.5486300000000028 112.6057820000000049 111.0512920000000037 110.2480010000000021 111.6833570000000009 112.9426500000000004 113.3171159999999986 113.3931199999999961 113.0855329999999981 111.9566879999999998 110.0855179999999933 108.4247060000000005 107.1056439999999981 105.5719600000000042 103.5843959999999981 101.2367480000000057 98.3197710000000029 95.6605529999999931 95.5978389999999933 98.9641040000000061 101.8195340000000044 102.5559010000000058 101.1518169999999941 97.0905759999999987 92.6215669999999989 90.5231930000000062 89.9540860000000038 90.1355819999999994 90.0152889999999957 89.6573640000000012 89.3491130000
000027 89.0386730000000028 88.7980579999999975 88.8019330000000053 89.1807560000000024 90.1389080000000007 92.2360000000000042 95.8167880000000025 100.4168619999999947 104.9821400000000011 106.1222309999999993 102.2175519999999977 97.801085999999998 94.215209999999999 90.4750520000000051 87.3701549999999969 86.2535780000000045 86.1943049999999999 86.2825700000000069 86.3382490000000047 86.3971559999999954 86.4493709999999993 86.4809649999999976 86.3631670000000042 86.2087939999999975 86.1702959999999933 86.1249619999999965 86.0753480000000053 86.0254819999999967 85.9914399999999972 85.9838179999999994 85.9852980000000002 85.9851299999999981 85.9851299999999981 85.9851069999999993 85.9853439999999978 85.9830319999999944 85.967292999999998 85.9570159999999959 85.9415889999999933 85.9237439999999992 85.9249499999999955 85.9213869999999957 85.902000000000001 85.9066470000000066 85.7389370000000071 88.6905670000000015 94.2403410000000008 97.5191420000000022 97.6147459999999967 97
.4564510000000013 97.9985279999999932 97.8832019999999972 97.6189420000000041 97.0114590000000021 95.7272799999999933 93.7421190000000024 91.7204669999999993 89.9027940000000001 88.1667709999999971 87.0601580000000013 86.4539340000000038 85.9491960000000006 85.8227920000000069 85.8531799999999947 85.8642040000000009 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8633039999999994 85.863433999999998 85.8623199999999969 85.8516620000000046 85.8333360000000027 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8343660000000028 85.8242189999999994 85.8039399999999972 85.8018040000000042 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.802245999
9999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8021549999999991 85.8026200000000046 85.8037949999999938 85.8003230000000059 85.7974470000000053 85.7942350000000005 85.7814029999999974 85.7738339999999937 85.7694170000000042 85.7712860000000035 85.7718729999999994 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7715910000000008 85.7697749999999957 85.7720259999999968 85.7777559999999966 85.7555160000000001 85.7191619999999972 85.7091599999999971 85.7091520000000031 85.7067490000000021 85.640106000000003 85.6326980000000049 85.8115839999999963 86.1193619999999953 86.739570999999998 87.9984050000000053 89.3073499999999996 90.1884919999999966 90.7866360000000014 91.4188460000000021 92.0485149999999948 92.8716050000000024 93.4606780000000015 93.0483090000000033 92.292113999999998 92.1272809999999964 92.022925999
9999982 92.0249709999999936 92.2534710000000047 92.2257840000000044 91.9618839999999977 91.7692109999999985 91.767548000000005 91.8210749999999933 92.0932999999999993 92.5236969999999985 92.6912690000000055 92.3344879999999932 91.9928440000000052 92.0087740000000025 92.121619999999993 92.145545999999996 92.1460419999999942 92.0712889999999931 91.9749369999999971 91.5254290000000026 91.317261000000002 91.7766040000000061 92.2396549999999991 92.8528670000000034 93.3958740000000063 93.7676160000000039
+115.3526920000000047 115.6001210000000015 115.7647929999999974 115.9072950000000048 116.0541690000000017 116.1933590000000009 116.2179789999999997 116.1306150000000059 116.1155930000000041 116.1394959999999941 115.9547960000000018 115.7125630000000029 115.5661850000000044 115.3670199999999966 115.1924360000000007 114.9285739999999976 114.6280519999999967 114.3345259999999968 113.6775970000000058 112.524597 111.7077869999999962 112.7052539999999965 113.6851120000000037 113.899353000000005 113.8059839999999951 113.2284549999999967 111.620514 108.9603419999999971 106.4648669999999981 104.6853710000000035 103.049980000000005 101.2807849999999945 99.4736180000000019 97.1199649999999934 95.8523940000000039 98.3286970000000053 102.2384109999999993 104.1804730000000063 103.9432749999999999 101.3805770000000024 97.0037460000000067 92.9195019999999943 90.919951999999995 90.5014950000000056 90.6246029999999934 90.5195619999999934 90.2825320000000033 90.0619959999999935 89.7995760000000
018 89.549476999999996 89.8500750000000039 91.1627960000000002 93.2318879999999979 96.5248109999999997 100.8008119999999934 105.0633009999999956 108.1586609999999951 108.438689999999994 105.1502150000000029 101.4189910000000054 98.4514470000000017 94.4679260000000056 90.0429380000000066 87.5412830000000071 86.7555849999999964 86.6760940000000062 86.7644650000000013 86.8885649999999998 86.8778230000000065 86.9338840000000062 86.8319319999999948 86.487244000000004 86.1709819999999951 86.0715710000000058 86.022948999999997 85.9848400000000055 85.9830400000000026 85.9851910000000004 85.9851299999999981 85.9851299999999981 85.9851299999999981 85.9852369999999979 85.9839860000000016 85.9705280000000016 85.9531630000000035 85.9501570000000044 85.9321589999999986 85.9239199999999954 85.9208679999999987 85.908173000000005 85.8972849999999966 85.8726580000000013 85.8429030000000068 88.9456330000000008 94.2081759999999946 97.0090940000000046 97.5867999999999967 97.9858399999999961 98.7
067640000000068 98.6671599999999955 98.4019779999999997 97.8454129999999935 96.6671300000000002 94.7931820000000016 93.2738039999999984 92.1242289999999997 90.6116329999999977 88.7950440000000043 87.3843229999999949 86.612647999999993 86.0170439999999985 85.8021389999999968 85.854377999999997 85.863892000000007 85.8631210000000067 85.8632049999999936 85.8632049999999936 85.8632049999999936 85.8631969999999995 85.8637240000000048 85.8590389999999957 85.8447340000000025 85.8380970000000048 85.8329159999999973 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8326720000000023 85.8355260000000015 85.8196030000000007 85.8003230000000059 85.8023910000000001 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999
967 85.8022459999999967 85.8022459999999967 85.8022310000000061 85.8023910000000001 85.8036270000000059 85.8023299999999978 85.7984469999999959 85.7862240000000043 85.7775960000000026 85.7770610000000033 85.7700650000000024 85.7705919999999935 85.7718430000000041 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717439999999982 85.7719270000000051 85.7743150000000014 85.7634199999999964 85.7260509999999982 85.7069850000000031 85.7106780000000015 85.7108609999999942 85.7098689999999976 85.7179110000000009 85.6921770000000009 85.6001210000000015 85.5679020000000037 85.6934200000000033 86.3860930000000025 87.4582060000000041 88.2305450000000064 88.6505889999999965 89.2575839999999943 89.9901200000000046 90.9158400000000029 91.7556380000000047 92.0629650000000055 91.8631670000000042 91.7276150000000001 91.5650859999999938 91.538054999999
9999 91.8327940000000069 91.9132309999999961 91.605994999999993 91.2815480000000008 91.3195649999999972 91.3836440000000039 91.6101069999999993 91.8239820000000009 91.7052379999999943 91.4047699999999992 91.207603000000006 91.1651690000000059 91.2157140000000055 91.3106460000000055 91.5128480000000053 91.6549069999999944 91.5952759999999984 91.2857060000000047 91.0814589999999953 91.5198819999999955 92.4216080000000062 93.3458020000000062 93.9566499999999962 94.4997939999999943
+115.6241380000000021 115.9997709999999955 116.0966719999999981 116.2265469999999965 116.393929 116.5180359999999951 116.4567339999999973 116.321044999999998 116.3069080000000071 116.2778469999999942 116.2493900000000053 116.1879809999999935 116.1079029999999932 116.0187909999999931 115.8956909999999993 115.6274949999999961 115.293059999999997 114.9549030000000016 114.6284940000000034 114.059227000000007 113.4249499999999955 113.8857270000000028 114.4280550000000005 114.4158330000000063 114.2051699999999954 113.5291600000000045 112.0824970000000036 109.4278790000000043 106.3793110000000013 104.7698139999999967 103.3240890000000007 100.9542239999999964 98.8987960000000044 97.2808529999999934 98.0281520000000057 101.6487879999999961 104.5149459999999948 105.8032460000000015 105.0168989999999951 101.8607329999999962 97.4943470000000048 93.8358149999999966 91.6989209999999986 91.0081100000000021 91.1080249999999978 91.1762470000000036 91.1420970000000068 90.9778060000000011 90.71
58359999999959 90.5085980000000063 91.2553790000000049 93.3898319999999984 96.3972019999999929 100.5250240000000019 104.9791720000000055 108.0891879999999929 109.3447879999999941 109.1471250000000026 107.3703770000000048 104.6156849999999991 101.5008090000000038 97.4555969999999974 92.9447399999999959 89.762077000000005 87.9442980000000034 87.4351580000000013 87.5094760000000065 87.5232699999999966 87.3866419999999948 87.336853000000005 87.2496639999999957 86.9257350000000031 86.4900360000000035 86.2550200000000018 86.0548249999999939 85.9825440000000043 85.9855119999999999 85.986266999999998 85.9849619999999959 85.9851299999999981 85.9850689999999958 85.9865039999999965 85.9763719999999978 85.9543000000000035 85.9526290000000017 85.9340899999999976 85.9252850000000024 85.9125750000000039 85.8942030000000045 85.8725740000000002 85.8682249999999954 85.7526170000000008 86.2946400000000011 89.5091019999999986 94.1703870000000052 97.1553190000000058 98.1062849999999997 98.557464
9999999934 99.3814469999999943 99.4290390000000031 98.9352109999999954 98.1106259999999963 96.8140410000000031 95.1928479999999979 93.859618999999995 92.6291049999999956 91.0382539999999949 89.2832259999999991 87.9520109999999988 87.5344999999999942 86.7970959999999963 86.0010070000000013 85.8521729999999934 85.8552399999999949 85.8652189999999962 85.8630519999999962 85.8632049999999936 85.8631740000000008 85.8634720000000016 85.8612750000000062 85.8443599999999947 85.8301089999999931 85.8310620000000029 85.8326720000000023 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8328929999999986 85.8339840000000009 85.8194809999999961 85.8013229999999965 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967
85.8022459999999967 85.8021849999999944 85.8027110000000022 85.8035959999999989 85.802825999999996 85.8005600000000044 85.7926099999999963 85.7802120000000059 85.7724149999999952 85.768889999999999 85.7699360000000013 85.7715610000000055 85.771766999999997 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7718200000000053 85.7740710000000064 85.7696459999999945 85.734886000000003 85.7088700000000046 85.7105870000000039 85.710875999999999 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.712128000000007 85.7192000000000007 85.6847690000000028 85.6202090000000027 85.6459049999999991 85.9415740000000028 86.2664180000000016 86.4455949999999973 86.9081950000000063 87.6548839999999956 88.7068940000000055 89.6537019999999956 90.5644450000000063 91.0643689999999992 90.9420389999999941 90.8606570000000033 90.96
20510000000024 91.1293179999999978 91.1772610000000014 90.9071349999999967 90.5324169999999953 90.6139600000000058 90.7922899999999942 91.1581570000000028 91.1769029999999958 90.8687359999999984 90.6657869999999946 90.604186999999996 90.6210630000000066 90.6878970000000066 90.7943729999999931 91.0446089999999941 91.3016590000000008 91.2465669999999989 90.9959790000000055 91.0057299999999998 91.9048920000000038 93.1956710000000044 94.0532759999999968 94.5721889999999945 95.1906809999999979
+115.6845090000000056 116.1299510000000055 116.1805339999999944 116.3191910000000036 116.5369799999999998 116.6012879999999967 116.5917429999999939 116.4965440000000001 116.4428249999999991 116.4179380000000066 116.3006210000000067 116.286438000000004 116.3505779999999987 116.3590700000000027 116.2706909999999993 116.0616909999999962 115.9060439999999943 115.771332000000001 115.7004170000000016 115.2537540000000007 114.6940769999999929 114.7795639999999935 114.9317089999999979 114.8557509999999979 114.6160430000000048 113.896064999999993 112.5948029999999989 110.1951830000000001 108.025550999999993 107.4835429999999974 106.0114360000000033 102.8966599999999971 99.8184360000000055 98.2255099999999999 100.0515900000000045 103.7327800000000053 106.2281490000000019 107.2877730000000014 106.4314040000000006 103.569344000000001 99.5545879999999954 96.0557019999999966 93.6229479999999938 91.9843520000000012 91.6566009999999949 91.736298000000005 91.9513319999999936 91.96763599999999
88 91.5936130000000048 91.4876019999999954 92.8317409999999938 95.8048480000000069 99.0024870000000021 102.4691930000000042 106.4418639999999954 109.3072360000000032 110.0687410000000028 109.5889430000000004 108.5398100000000028 106.4948880000000031 103.3261719999999997 99.3226549999999975 95.4306720000000013 92.4210659999999962 89.8488689999999934 88.624488999999997 88.5067520000000059 88.3647079999999931 88.133979999999994 87.845207000000002 87.5979229999999944 87.3718259999999987 87.1395949999999999 86.7635879999999986 86.3209690000000052 86.0415270000000021 85.9712679999999949 85.9719620000000049 85.9849470000000053 85.9835589999999996 85.9843060000000037 85.9850689999999958 85.967528999999999 85.9539410000000004 85.9489590000000021 85.9309690000000046 85.9070820000000026 85.8627780000000058 85.8955919999999935 85.8669589999999943 85.8057249999999954 85.9998860000000036 87.5796890000000019 90.817229999999995 95.0467299999999966 98.2244029999999952 98.9622119999999938 99.
4935990000000032 99.9790569999999974 99.6612400000000065 98.7136760000000066 97.5485989999999958 96.3106460000000055 94.935608000000002 93.522521999999995 92.0276489999999967 90.4063490000000058 89.214500000000001 88.6160129999999953 88.4269330000000053 87.8701319999999981 86.8322679999999991 86.0892180000000025 85.8616410000000059 85.8557820000000049 85.8646849999999944 85.8631359999999972 85.8634569999999968 85.8629530000000045 85.8484729999999985 85.8306579999999997 85.8321380000000005 85.8327639999999974 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8339840000000009 85.8281479999999988 85.8079610000000059 85.8020250000000004 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.802245999999
9967 85.8021849999999944 85.8027500000000032 85.8015369999999962 85.7980579999999975 85.7964709999999968 85.7840350000000029 85.7754209999999944 85.7696689999999933 85.7710340000000002 85.7719040000000064 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717739999999935 85.7727739999999983 85.7689129999999977 85.7397160000000014 85.7112659999999948 85.7103120000000018 85.7108690000000024 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7103350000000006 85.7147060000000067 85.7229839999999967 85.6487960000000044 85.5611499999999978 85.5673749999999984 85.5742489999999947 85.6585539999999952 85.8921509999999984 86.6460270000000037 87.6862179999999967 88.7516099999999994 89.5662690000000055 89.7857819999999975 89.94435900000000
57 90.2424390000000045 90.3478700000000003 90.2380289999999974 90.0491789999999952 89.8896179999999987 90.043327000000005 90.3726649999999978 90.7047649999999948 90.621887000000001 90.3882059999999967 90.1644359999999949 90.1451950000000011 90.2690280000000058 90.3185730000000007 90.4555359999999951 90.6694109999999966 90.8286669999999958 90.7027439999999956 90.6343770000000006 91.3973309999999941 92.8345719999999943 93.8789060000000006 94.4488369999999975 95.140349999999998 95.8021549999999991
+115.5783310000000057 115.9856189999999998 116.0311739999999929 116.173766999999998 116.4131619999999998 116.4096530000000058 116.4464190000000059 116.5167469999999952 116.4634170000000069 116.4498980000000046 116.3795470000000023 116.3753659999999996 116.4572069999999968 116.4641189999999966 116.3982539999999943 116.2913970000000035 116.246025000000003 116.2967989999999929 116.324860000000001 115.9462429999999955 115.5406339999999972 115.3847959999999944 115.2555239999999941 115.2053379999999976 115.0672990000000055 114.3873980000000046 113.1094439999999963 111.382750999999999 110.5022809999999964 110.2205730000000017 108.4130710000000022 104.9073559999999929 101.2425539999999984 99.4741130000000027 101.4768140000000045 105.1487120000000033 107.7017969999999991 108.6109309999999937 108.1409840000000031 106.1519169999999974 102.9159700000000015 99.9213259999999934 97.4444199999999938 94.5629729999999995 92.8112110000000001 92.4022829999999971 92.7586139999999943 93.0274509999
999992 92.9748079999999959 93.4968489999999974 95.8101120000000037 99.7478179999999952 102.8133090000000038 104.7483220000000017 107.3327100000000058 109.6759870000000063 110.4406970000000001 109.9511260000000021 108.9400250000000057 107.3342360000000042 104.8820719999999937 101.5085219999999993 98.2461469999999935 95.5924380000000014 92.7891620000000046 90.5761719999999997 89.7267230000000069 89.3983379999999954 88.9840010000000063 88.5116579999999971 88.1837620000000015 88.0125500000000045 87.7451480000000004 87.2638929999999959 86.722046000000006 86.2476580000000013 85.9947509999999937 85.9326930000000004 85.9904329999999959 85.9827650000000006 85.9836119999999937 85.9519880000000001 85.9284519999999929 85.9318619999999953 85.9110340000000008 85.9195629999999966 85.8797990000000055 85.9665530000000047 86.3285900000000055 86.4749300000000005 86.5099639999999965 87.7881090000000057 90.7368620000000021 94.0334550000000036 97.0071109999999948 99.0702739999999977 99.8941959999
999938 100.3624039999999979 99.9336169999999981 98.9380869999999959 97.6076199999999972 96.1518480000000011 94.9842150000000061 93.7936169999999976 92.3694839999999999 90.9738849999999957 90.125031000000007 89.6427539999999965 89.429633999999993 89.1269450000000063 88.4891429999999986 87.6708909999999975 86.7098160000000036 86.0254819999999967 85.8244710000000026 85.8636860000000013 85.8636630000000025 85.8641199999999998 85.8540040000000033 85.8319699999999983 85.8319019999999995 85.8328020000000009 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327100000000058 85.834937999999994 85.8235860000000059 85.802825999999996 85.802299000000005 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.802
2459999999967 85.8024369999999976 85.8026729999999986 85.7905120000000068 85.7787699999999944 85.7793199999999985 85.770545999999996 85.770103000000006 85.7717059999999947 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717130000000054 85.7721789999999942 85.7699580000000026 85.7490839999999963 85.7145919999999961 85.708045999999996 85.7100980000000021 85.7108989999999977 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7098849999999999 85.7168429999999972 85.7155230000000046 85.7012560000000008 85.6716540000000037 85.6041110000000032 85.5283510000000007 85.6529309999999953 86.1994859999999932 87.156920999999997 88.0820310000000006 88.5593800000000044 88.8737339999
999989 89.2407070000000004 89.5054779999999965 89.4624100000000055 89.3708189999999973 89.3926539999999932 89.5988080000000053 90.0658569999999941 90.3262179999999972 90.1898649999999975 90.0184330000000017 89.8647689999999955 89.8694080000000071 89.8986969999999985 89.9603419999999971 90.1667400000000043 90.2368320000000068 90.1388850000000019 90.2258000000000067 90.7889789999999977 92.123810000000006 93.4445649999999972 94.1827009999999945 94.8339770000000044 95.6432340000000067 96.2517239999999958
+115.4471209999999957 115.7811279999999954 115.8333659999999981 116.0105590000000007 116.2646100000000047 116.2426379999999995 116.221100000000007 116.304466000000005 116.3289719999999932 116.3481979999999965 116.3789979999999957 116.4352039999999988 116.4426500000000004 116.4582209999999947 116.4632029999999929 116.4484250000000003 116.3785859999999985 116.3311539999999979 116.3175959999999947 116.1819919999999939 116.1049040000000048 116.0170209999999997 115.8631290000000007 115.7015379999999993 115.5173649999999981 114.8958740000000063 113.9724580000000032 113.0605390000000057 112.3399730000000005 111.6319660000000056 109.7940600000000018 106.3286820000000006 102.763306 101.1150209999999987 103.3189930000000061 106.8311539999999979 108.9219669999999951 109.5992279999999965 109.4616850000000028 108.3436130000000048 106.1663510000000059 103.8045960000000036 101.1920850000000058 97.6362000000000023 94.4641189999999966 93.4005580000000037 93.718040000000002 94.3085329999999971
95.656281000000007 97.7768939999999986 100.9040150000000011 104.4915919999999971 106.7801209999999941 107.9825289999999995 109.2795559999999995 110.4329070000000002 110.8415370000000024 110.327690000000004 109.4072189999999978 108.0354159999999979 106.2030790000000025 103.8511809999999969 101.063477000000006 98.139679000000001 95.0309299999999979 92.548332000000002 91.2122729999999962 90.2977980000000002 89.6934279999999973 89.2951659999999947 88.9754939999999976 88.736725000000007 88.2391889999999961 87.6583710000000025 87.3917689999999965 87.2821200000000061 87.1031420000000054 86.6052549999999997 86.2318190000000016 86.2271879999999982 86.1934360000000055 86.0385210000000029 85.9444960000000009 85.9467089999999985 85.8862610000000046 85.8990019999999959 86.313721000000001 87.1671910000000025 87.9100949999999983 88.0612409999999954 88.6377640000000042 91.0610499999999945 94.9774550000000062 98.255675999999994 99.4287410000000023 99.983704000000003 100.5647510000000011 100
.2091219999999936 98.8406679999999938 97.2562410000000028 95.694855000000004 94.3194270000000046 93.280974999999998 92.3701860000000039 91.4399870000000021 90.7499389999999977 90.5682450000000046 90.2534100000000024 89.9044719999999984 89.3648220000000038 88.6066280000000006 87.9800189999999986 87.1859890000000064 86.3626170000000002 85.8944170000000042 85.839423999999994 85.8674319999999938 85.8587189999999936 85.8355710000000016 85.8318560000000019 85.8328249999999997 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327940000000069 85.8339610000000022 85.823830000000001 85.8039250000000067 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.802222999999
9979 85.8037489999999963 85.7977829999999955 85.774162000000004 85.7692490000000021 85.7697979999999944 85.7714840000000009 85.7718050000000005 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717059999999947 85.7721559999999954 85.7710110000000014 85.7546839999999975 85.7378460000000047 85.726341000000005 85.7164539999999988 85.7137599999999935 85.7104420000000005 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7103649999999959 85.713752999999997 85.7197189999999978 85.7242509999999953 85.6276170000000008 85.6286470000000008 86.1429289999999952 86.9462510000000037 87.4166560000000032 87.8145370000000014 8
8.2505869999999959 88.6247939999999943 88.7987750000000062 88.8049699999999973 88.9491730000000018 89.310096999999999 89.8190989999999942 90.0720290000000006 89.8750459999999975 89.6495589999999964 89.6197970000000055 89.6194919999999939 89.5438000000000045 89.6142040000000009 89.7579649999999987 89.8241119999999995 89.9028239999999954 90.5617369999999937 91.6178440000000052 92.821479999999994 93.8612059999999957 94.6727219999999932 95.4300989999999985 96.078093999999993 96.6468430000000041
+115.2668299999999988 115.5963590000000067 115.6609339999999975 115.7587970000000013 115.9619600000000048 116.0285719999999969 115.9983749999999958 115.994324000000006 116.0681459999999987 116.0274959999999993 115.9966050000000024 116.2031779999999941 116.3127209999999963 116.4026340000000062 116.4543840000000046 116.4713749999999948 116.4616390000000052 116.4762039999999956 116.4723970000000008 116.3110659999999967 116.1831590000000034 116.2664410000000004 116.3759160000000037 116.2764049999999969 115.9903489999999948 115.4916690000000017 114.8499910000000028 114.2121889999999951 113.5343780000000038 112.723228000000006 111.0200650000000024 107.9585110000000014 104.6778489999999948 102.7752839999999992 104.6378559999999993 108.0498350000000016 109.9256440000000055 110.4005889999999965 110.2821660000000037 109.5422290000000061 108.0154799999999966 105.5498659999999944 102.3220519999999993 98.5621409999999969 95.2307820000000049 94.2282029999999935 94.5500870000000049 95.42964
89999999977 97.8794019999999989 101.2364960000000025 104.4693299999999994 107.0073009999999982 108.5109790000000061 109.5941619999999972 110.4267040000000009 111.1045000000000016 111.2009120000000024 110.701240999999996 109.9272689999999955 108.634681999999998 107.0116040000000055 105.112647999999993 102.3005449999999996 98.8726199999999977 95.5403819999999939 93.6996989999999954 92.7264480000000049 91.5477680000000049 90.5461810000000042 90.0127329999999972 89.8301390000000026 89.9425659999999993 89.5424419999999941 89.6988979999999998 90.4633409999999998 91.3596419999999938 91.4003749999999968 89.8228150000000056 88.433967999999993 88.1499179999999996 88.0147400000000033 87.6672059999999931 87.4615859999999969 87.3718340000000069 87.0320509999999956 86.8035349999999966 87.4677120000000059 88.8619840000000067 89.8440089999999998 90.2180100000000067 91.7390670000000057 94.7747119999999938 98.1748659999999944 100.3354420000000005 100.6376570000000044 100.8237230000000011 100.
5263750000000016 99.2985919999999993 97.3807299999999998 95.5531849999999991 94.5060880000000054 93.9548419999999993 93.267944 92.4413449999999983 91.8885800000000046 91.6686329999999998 91.3398739999999947 90.8466870000000029 90.4985659999999967 89.6881790000000052 88.7243270000000024 88.0852280000000007 87.4357150000000019 86.7639620000000065 86.1338580000000036 85.8211210000000051 85.8379520000000014 85.8352359999999948 85.8322529999999944 85.834937999999994 85.8347629999999953 85.8323900000000037 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8333049999999957 85.8306960000000032 85.8121409999999969 85.8025439999999975 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022380000000027 85.
8023910000000001 85.8045500000000061 85.7899170000000026 85.7714079999999939 85.7718430000000041 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717289999999934 85.7720719999999943 85.7727579999999961 85.7594449999999995 85.7394029999999958 85.7413559999999961 85.7418440000000004 85.7357640000000032 85.721100000000007 85.7095640000000003 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.710212999999996 85.7176440000000071 85.6868130000000008 85.7025600000000054 86.0625380000000035 86.5320130000000063 87.0548629
999999974 87.6182330000000036 87.9061279999999954 87.9969099999999997 88.0730590000000007 88.4784999999999968 89.1633149999999972 89.7311550000000011 89.8455960000000005 89.5936580000000049 89.3508829999999961 89.3173519999999996 89.2640379999999993 89.2720110000000062 89.2718579999999946 89.3194199999999938 89.7787249999999943 90.4109119999999962 91.2865910000000014 92.3644029999999958 93.5071109999999948 94.6427989999999966 95.4832690000000071 96.0714490000000012 96.6096419999999938 97.2583769999999959
+115.0611109999999968 115.3688889999999958 115.4569850000000031 115.4959340000000054 115.5844649999999945 115.7017670000000038 115.7088090000000022 115.6590419999999995 115.7300639999999987 115.6827619999999968 115.5860749999999939 115.7238389999999981 115.8964459999999974 116.097533999999996 116.3112409999999954 116.4267810000000054 116.4486009999999965 116.529792999999998 116.6552580000000034 116.6326370000000026 116.4579090000000008 116.3372959999999949 116.3280639999999977 116.4044800000000066 116.3617320000000035 116.1790919999999971 115.6643370000000033 114.949341000000004 114.3067319999999967 113.7209629999999976 112.3258440000000036 109.3811950000000053 106.2514039999999937 104.6418299999999988 105.7261809999999969 108.755004999999997 110.7238389999999981 111.0487140000000039 110.8222889999999978 110.0290370000000024 108.2462840000000028 105.0734939999999966 101.3231889999999993 97.7537609999999972 95.220405999999997 94.7346730000000008 95.3497310000000056 96.16342899
99999936 98.0659100000000024 101.410728000000006 104.7647709999999961 107.3853840000000019 108.9261319999999955 109.9951779999999957 110.9216080000000062 111.5538559999999961 111.5194929999999971 111.0889360000000039 110.5146330000000034 109.3309330000000017 107.5220719999999943 105.4152830000000023 102.4377900000000068 98.7953720000000004 96.0932690000000065 95.098906999999997 94.5010149999999953 93.5106660000000005 92.1535949999999957 91.0167689999999965 90.6620249999999999 91.3944850000000031 91.8676909999999936 93.3581159999999954 95.4721909999999951 97.0751110000000068 97.1943509999999975 94.6380000000000052 92.1776200000000046 91.3478929999999991 91.1011120000000005 90.7233889999999974 90.4208370000000059 90.3774339999999938 90.1272349999999989 89.7525250000000057 89.7867970000000071 90.6590649999999982 91.5574340000000007 92.5094990000000053 94.8028489999999948 97.7696459999999945 99.8787229999999937 100.8220979999999969 101.0873490000000032 100.9842150000000061 100.0
327759999999984 98.3767169999999993 96.3789519999999982 95.2199779999999976 95.3458399999999955 95.432982999999993 94.8999400000000009 94.0598600000000005 93.4040069999999929 92.8047640000000058 91.9050519999999977 91.4672159999999934 91.4224470000000053 90.5081250000000068 89.1709139999999962 88.2752760000000052 87.7706380000000053 87.2430420000000026 86.5915600000000012 85.941283999999996 85.7557369999999963 85.8135759999999976 85.8094789999999961 85.7989270000000062 85.8043820000000039 85.8275600000000054 85.8324130000000025 85.8340989999999948 85.8325959999999952 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327330000000046 85.8334499999999991 85.8255159999999933 85.8047260000000023 85.8019330000000053 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.802291999999
9942 85.8030470000000065 85.7985460000000018 85.7798389999999955 85.7718959999999981 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717439999999982 85.7719500000000039 85.7731480000000062 85.7646409999999975 85.7421190000000024 85.7404099999999971 85.7413020000000046 85.7429280000000063 85.7388459999999952 85.716431 85.7101590000000044 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108460000000036 85.7130279999999942 85.6558909999999969 85.652977000000007 86.0096439999999944 86.54350999
99999977 87.1145020000000017 87.364806999999999 87.3484420000000057 87.5529630000000054 88.1287460000000067 88.9348909999999933 89.5285570000000064 89.4636459999999971 89.1059039999999953 88.8325580000000059 88.748383000000004 88.7274089999999944 88.8539659999999998 88.9731599999999929 89.3736949999999979 90.2482530000000054 91.0249100000000055 91.7245329999999939 92.8885350000000045 94.3120349999999945 95.5483550000000008 96.2329029999999932 96.7638850000000019 97.406959999999998 98.017005999999995
+114.778648000000004 114.9499359999999939 115.023926000000003 115.1254650000000055 115.1831889999999987 115.2498779999999954 115.2809299999999979 115.2170100000000019 115.2074740000000048 115.2485499999999945 115.2945330000000013 115.3161089999999973 115.3611910000000051 115.5500720000000001 115.860328999999993 116.1463700000000046 116.3444980000000015 116.5226360000000057 116.7270890000000065 116.9009549999999962 116.9163209999999964 116.7397160000000014 116.4776609999999977 116.3321530000000052 116.3776780000000031 116.5015719999999959 116.3499070000000017 115.8261410000000069 115.0201339999999988 114.3564680000000067 113.4379809999999935 110.8257830000000013 108.3885120000000057 107.858665000000002 108.3064959999999957 109.9537119999999959 111.2617489999999947 111.3644029999999958 111.0706330000000008 110.1073149999999998 107.8121260000000063 104.0552830000000029 100.2280580000000043 97.1143950000000018 95.4716719999999981 95.8586580000000055 97.4154209999999949 97.6381839
999999954 97.7316820000000064 100.1753769999999975 103.9217830000000049 107.1087490000000031 108.9739229999999992 110.1405259999999942 111.0671770000000009 111.6850809999999967 111.6876220000000046 111.3777769999999947 110.9944689999999952 110.0339280000000031 107.8398590000000041 104.9361040000000003 102.083122000000003 99.3339390000000009 97.7328030000000041 97.2301559999999938 96.612244000000004 95.6345830000000063 94.3409269999999935 92.9379579999999947 92.1387789999999995 92.6425780000000003 93.5929639999999949 96.063011000000003 98.8804169999999942 100.4208909999999975 100.7256160000000023 98.6757350000000031 95.8122099999999932 94.5714870000000047 94.276923999999994 93.8322220000000016 93.5780259999999942 94.0095290000000006 94.4006810000000058 94.6868589999999983 94.362724 94.1650700000000001 93.8220670000000041 94.5542140000000018 97.1227650000000011 99.6114199999999954 100.945335 101.6028979999999962 101.3661500000000046 100.4390790000000067 99.2716219999999936 97.
6158140000000003 96.1377789999999948 96.0898279999999971 96.8786319999999961 96.8503879999999953 96.2853999999999957 95.5206529999999958 94.6290659999999946 93.5247339999999951 92.3983149999999966 92.2012249999999938 92.4318389999999965 91.6034700000000015 90.0594789999999961 88.8231119999999947 88.2240450000000038 87.8973390000000023 87.4250109999999978 86.7250599999999991 86.3209839999999957 86.1468279999999993 85.9738689999999934 85.8220139999999958 85.7928090000000054 85.8723300000000052 85.8098070000000064 85.8129040000000032 85.8354719999999958 85.8325650000000024 85.8327259999999939 85.8327259999999939 85.8327259999999939 85.8327869999999962 85.8312909999999931 85.8155749999999955 85.8026430000000033 85.8021700000000038 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8025439999999975 85.800040999
9999931 85.7816159999999996 85.7707750000000004 85.7717209999999994 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7718430000000041 85.7727890000000031 85.7676009999999991 85.7460399999999936 85.740509000000003 85.7413860000000057 85.7412869999999998 85.7438350000000042 85.7290799999999962 85.7099230000000034 85.7109379999999987 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7106550000000027 85.7148899999999969 85.6802749999999946 85.7685170000000028 86.057854000000006
1 86.5548550000000034 86.9456330000000008 87.0462799999999959 87.2834550000000036 87.9276049999999998 88.6044459999999958 88.8948819999999955 88.6710209999999961 88.3976059999999961 88.1801909999999936 88.1105579999999975 88.2837980000000044 88.5728069999999974 89.1370540000000062 90.0416110000000032 90.9195019999999943 91.5433809999999966 92.3127819999999986 93.7121580000000023 95.1211399999999969 96.047577000000004 96.541175999999993 97.2190319999999986 98.0688169999999957 98.532905999999997
+114.427825999999996 114.5192870000000056 114.5346760000000046 114.6163329999999974 114.7247160000000008 114.7986219999999946 114.8054499999999933 114.7184450000000027 114.624329000000003 114.6054230000000018 114.7481920000000031 114.8327409999999986 114.8653869999999984 115.0505449999999996 115.3013229999999965 115.6154860000000042 116.0331570000000028 116.4023669999999981 116.6897349999999989 116.8419190000000043 116.9115299999999991 117.0030900000000003 117.0713499999999954 116.8233869999999968 116.4585799999999978 116.3402940000000001 116.4751969999999943 116.4040150000000011 115.8615489999999966 114.9995119999999957 114.2930149999999969 112.7941440000000028 111.4762499999999932 111.2603000000000009 111.3410719999999969 111.6727680000000049 111.893730000000005 111.7513660000000044 111.2589040000000011 110.0176160000000039 107.3827359999999942 103.5378649999999965 99.9745560000000069 97.164519999999996 96.1098790000000065 97.6821209999999951 100.552063000000004 100.6433410
000000066 98.6863330000000047 99.1326899999999966 102.1710510000000056 105.2456209999999999 107.3999859999999984 109.089698999999996 110.463042999999999 111.5215910000000008 111.7593080000000043 111.5645370000000014 111.2895359999999982 110.4753800000000012 108.1902469999999994 104.8287119999999959 101.8310089999999946 100.3654559999999947 99.7784350000000018 99.3106989999999996 98.5818859999999972 97.5334780000000023 96.2861860000000007 94.9983139999999935 94.1755370000000056 94.0634160000000037 94.846069 97.5244979999999941 100.1179049999999933 101.4724039999999974 102.1477430000000055 101.3712770000000063 99.1831509999999952 97.8544239999999945 97.5509799999999956 97.1461720000000071 97.3523249999999933 98.2012179999999972 99.0461350000000067 99.9545209999999997 99.5241390000000052 98.0140909999999934 96.0961989999999986 96.5118259999999992 99.0988689999999934 101.2966160000000002 102.0720060000000018 102.1837390000000028 101.2390369999999962 99.726073999999997 98.3958820
000000003 97.3496860000000055 97.0569380000000024 97.6409450000000021 98.1803359999999969 97.891846000000001 97.2801440000000071 96.4277799999999985 95.3661960000000022 94.0094760000000065 92.9883580000000052 93.0734180000000038 93.4499969999999962 92.7786100000000005 91.3012159999999966 89.8499300000000005 89.0046999999999997 88.6946410000000043 88.4531779999999941 88.3389130000000051 88.3408660000000054 88.303016999999997 88.0752489999999995 87.6194080000000071 87.1907199999999989 86.6487879999999961 86.0389559999999989 85.7994230000000044 85.8190610000000049 85.8344270000000051 85.8334880000000027 85.8326639999999941 85.8327259999999939 85.8328400000000045 85.8287810000000064 85.806800999999993 85.8010179999999991 85.8022540000000049 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022540000000049 85.8004760000000033 85
.7855069999999955 85.7704470000000043 85.7714840000000009 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771766999999997 85.7722169999999977 85.7690809999999999 85.7496029999999934 85.7404559999999947 85.7412949999999938 85.7412869999999998 85.7412869999999998 85.7434539999999998 85.7313999999999936 85.7110820000000047 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.710999000000001 85.7118150000000014 85.6950149999999979 85.722237
0000000069 86.0583950000000044 86.5497739999999993 86.8310550000000063 87.0378340000000037 87.5430530000000005 87.9113310000000041 87.8804549999999978 87.7036669999999958 87.7144090000000034 87.7830050000000028 88.1375270000000057 88.6076199999999972 89.222290000000001 90.1165239999999983 90.8532100000000042 91.5140839999999969 92.2086560000000048 93.2074279999999931 94.5564650000000029 95.6835559999999958 96.1559220000000039 96.4712750000000057 97.1349950000000035 97.9253539999999987 98.3488389999999981
+114.0579610000000059 114.1329879999999974 114.1312259999999981 114.1796949999999953 114.2318729999999931 114.2449419999999947 114.2482300000000066 114.207335999999998 114.1697010000000034 114.1056669999999968 114.1141510000000068 114.1955489999999998 114.3311460000000039 114.5933529999999934 114.856505999999996 115.0929569999999984 115.5175930000000051 115.9680180000000007 116.2984540000000067 116.4989779999999939 116.6955870000000033 116.9459080000000029 117.3631670000000042 117.4619900000000001 116.8959349999999944 116.3753279999999961 116.2772449999999935 116.3301539999999932 116.2579730000000069 115.8065950000000015 115.1356119999999947 114.3609699999999947 113.6939160000000015 113.3084110000000067 113.1542050000000046 113.0512920000000037 112.7339020000000005 112.3157879999999977 111.5152049999999946 110.1491010000000017 107.5133589999999941 103.7166059999999987 100.1543429999999972 97.5407710000000066 96.9432220000000058 99.2877119999999991 103.133301000000003 104.0086
440000000039 101.4728389999999933 99.7098160000000036 100.5133510000000001 102.8276369999999957 105.2404400000000066 107.4164279999999962 109.638489000000007 111.3878710000000041 111.8047030000000035 111.6867600000000067 111.5063930000000028 110.742241000000007 108.6554869999999937 105.5540699999999958 102.844963000000007 102.0969539999999967 101.7924119999999988 101.1382600000000025 100.3135379999999941 99.1708830000000034 97.7370300000000043 96.3645549999999957 95.5474399999999946 95.2360460000000018 96.055176000000003 98.3495860000000022 100.5565720000000027 102.0516659999999973 102.9558490000000006 103.0613479999999953 102.2881849999999986 101.5154040000000037 101.1494979999999941 100.7695470000000029 100.908600000000007 101.7109449999999953 102.913062999999994 103.7661820000000006 102.7652819999999991 99.8668210000000016 98.0107730000000004 99.2194060000000064 101.2149280000000005 102.6147229999999979 102.9091489999999993 102.4579619999999949 101.0374070000000017 99.293
9760000000007 98.2763209999999958 98.3789830000000052 98.951751999999999 99.3576659999999947 99.4077529999999996 98.9638060000000053 98.2364879999999943 97.2692870000000056 96.0244600000000048 94.398643000000007 93.6338650000000001 94.1985779999999977 94.6386179999999939 94.0430450000000064 92.7956240000000037 91.3716890000000035 90.2904889999999938 89.6603779999999944 89.7479479999999938 90.5299219999999991 91.3264920000000018 91.9513929999999959 92.0564499999999981 91.668762000000001 91.1997989999999987 90.2500380000000035 88.8443529999999981 86.9759829999999994 85.7171550000000053 85.8390500000000003 85.8248439999999988 85.8336869999999976 85.8327790000000022 85.8328170000000057 85.8293840000000046 85.8083649999999949 85.801085999999998 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022380000000027 85.8024369999999976
85.7899550000000062 85.7707139999999981 85.7711489999999941 85.7717820000000017 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717439999999982 85.7718809999999934 85.7699130000000025 85.753272999999993 85.7399369999999976 85.7410959999999989 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7434690000000046 85.7313309999999973 85.7111280000000022 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7111739999999998 85.7
122039999999998 85.6766510000000068 85.7564619999999991 86.0714420000000047 86.5515749999999997 86.9686049999999966 87.080444 86.8567280000000039 86.9261779999999931 87.162148000000002 87.2442170000000061 87.6799390000000045 88.7299730000000011 89.423759000000004 90.2085720000000038 91.0614170000000058 91.5152659999999969 92.1176530000000042 92.9793010000000066 93.929230000000004 94.8819730000000021 95.696503000000007 96.1257630000000063 96.488624999999999 96.9377900000000068 97.3851389999999952 97.7455369999999988
+113.6431809999999984 113.7441560000000038 113.7363739999999979 113.694121999999993 113.5984499999999997 113.5826799999999963 113.5899809999999945 113.581940000000003 113.6413500000000028 113.6231230000000068 113.5338820000000055 113.6281659999999931 113.8811189999999982 114.1657490000000053 114.3965610000000055 114.6320039999999949 115.011382999999995 115.4803699999999935 115.8572240000000022 116.1350860000000011 116.4457780000000042 116.8334200000000038 117.284522999999993 117.5616229999999973 117.3901520000000005 117.1815950000000015 116.7070159999999959 116.2118990000000025 116.1787869999999998 116.2165530000000047 115.8721850000000018 115.2374650000000003 114.655547999999996 114.2748109999999997 114.0981900000000024 114.0892869999999988 113.697417999999999 112.8895420000000058 111.9101560000000006 110.5823060000000027 107.9841229999999968 104.047852000000006 100.2988359999999943 98.050224 97.8765559999999937 100.5341109999999958 104.7417910000000063 106.5413819999999987
105.0332410000000039 102.6436460000000039 102.1258389999999991 104.1178359999999969 106.4204330000000027 108.127601999999996 109.9623179999999962 111.5533599999999979 111.987639999999999 111.8585209999999961 111.6961060000000003 111.0850910000000056 109.2979349999999954 106.6989590000000021 104.8921279999999996 104.3076549999999969 103.7166749999999951 102.8758930000000049 101.8562090000000069 100.5123750000000058 98.8469539999999967 97.2859729999999985 96.1648859999999956 96.1059340000000049 97.4741209999999967 99.2211300000000023 101.1000669999999957 102.782471000000001 103.8624339999999933 104.4543989999999951 104.7361219999999946 104.7923279999999977 104.4828870000000052 104.1893539999999945 104.0584180000000032 104.5671619999999962 105.7170559999999995 105.7247919999999937 103.266570999999999 100.6000140000000016 100.7384720000000016 102.347808999999998 103.0646739999999966 103.4655910000000034 103.5507659999999959 102.4576799999999963 100.7303619999999995 99.3519670000
000019 99.2520140000000026 100.0882189999999952 100.6006770000000046 100.638489000000007 100.4405820000000062 99.9594500000000039 99.1555630000000008 98.0723569999999967 96.6374969999999962 94.8992159999999956 94.449584999999999 95.5287929999999932 96.1461410000000001 95.571228000000005 94.5348129999999998 93.1932829999999939 91.7943340000000063 90.8469539999999967 91.2693179999999984 92.617249000000001 93.9575420000000037 95.1047360000000026 95.5915600000000012 95.4335559999999958 95.1872479999999968 94.2246779999999973 92.6485210000000023 89.8708340000000021 87.0637660000000011 85.8273159999999962 85.7264710000000036 85.8353419999999971 85.8315809999999999 85.8329319999999996 85.8293840000000046 85.8083649999999949 85.8010790000000014 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022380000000027 85.8023220000000038 85.8022229999999979 85
.781257999999994 85.7693940000000055 85.7718050000000005 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717509999999947 85.7717899999999958 85.7719799999999992 85.7720790000000051 85.7709430000000026 85.7574840000000052 85.7397689999999955 85.740784000000005 85.7413020000000046 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7434619999999938 85.7313769999999948 85.7111819999999938 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.710
4570000000052 85.7134929999999997 85.6838529999999992 85.7580640000000045 86.1974029999999942 86.6078949999999992 86.6637190000000004 86.3894269999999977 86.6058199999999943 87.0514139999999941 87.1477890000000031 87.9349749999999943 89.3168330000000026 90.047309999999996 90.7758560000000045 91.4475170000000048 91.8977280000000007 92.4482730000000004 93.2881160000000023 94.0737150000000071 94.692695999999998 95.2652049999999946 95.9034039999999948 96.423096000000001 96.7235029999999938 96.9781569999999959 97.1928939999999955
+113.2103039999999936 113.2778469999999942 113.252350000000007 113.168602000000007 113.0677570000000003 113.083122000000003 113.0520479999999992 113.0083999999999946 113.045921000000007 113.0767900000000026 113.0602489999999989 113.1623230000000007 113.3802570000000003 113.646088000000006 113.8294369999999986 114.1313710000000015 114.651061999999996 115.2643589999999989 115.617912000000004 115.894172999999995 116.264679000000001 116.7344360000000023 117.1548460000000063 117.4373700000000014 117.6331859999999949 117.8491209999999967 117.4976960000000048 116.6738430000000051 116.2511750000000035 116.1654589999999985 116.1099090000000018 115.8086169999999981 115.2421190000000024 114.7575300000000027 114.5810390000000041 114.616973999999999 114.2643659999999954 113.2837070000000068 112.0779270000000025 110.1771700000000038 107.362679 103.8006670000000042 100.5848160000000036 98.6782230000000027 98.6911319999999961 101.7337569999999971 105.9885790000000014 108.2183909999999969 107
.894683999999998 106.482056 106.3424299999999931 107.8311080000000004 109.1218029999999999 109.9040990000000022 110.7607500000000016 111.7836910000000046 112.2571180000000055 112.1539839999999941 111.9506300000000039 111.4937589999999972 110.1620790000000056 108.2453540000000061 106.8454669999999993 106.0537489999999963 105.3096010000000007 104.427031999999997 103.2264559999999989 101.552773000000002 99.7172850000000039 97.9883350000000064 96.5859530000000035 96.5229029999999995 98.3071439999999939 100.153923000000006 102.0007779999999968 103.7573390000000018 104.9617080000000016 105.8361819999999938 106.4400859999999938 106.8187410000000028 106.9122700000000066 107.0265430000000038 106.967376999999999 107.1775360000000035 107.6503369999999933 106.6078490000000016 103.6318049999999999 102.3258969999999977 103.3642349999999936 104.095917 104.1166230000000041 104.1471710000000002 103.6127010000000013 102.0542760000000015 100.7476580000000013 100.2411419999999964 100.6596370000
000036 101.4561230000000052 101.7354430000000036 101.6114039999999932 101.3336259999999953 100.8573609999999974 100.0790329999999955 98.8262480000000068 97.0721049999999934 95.4610980000000069 95.3912810000000064 96.7778469999999942 97.5590519999999941 97.016059999999996 96.0847019999999929 94.6828380000000038 93.2014920000000018 92.4045030000000054 92.8416600000000045 94.1828459999999978 95.6665339999999986 96.9798360000000059 97.7847670000000022 97.8837199999999967 97.4962840000000028 96.3583830000000034 94.6785050000000012 92.5348819999999961 89.9617999999999967 87.4744189999999975 86.0851289999999949 85.7390819999999962 85.8242029999999971 85.8316879999999998 85.829582000000002 85.8084029999999984 85.8010639999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022919999999942 85.8029480000000007 85.7958299999999952 85.774405999999999
85.7709270000000004 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771766999999997 85.7718959999999981 85.7717289999999934 85.7704010000000068 85.7710270000000037 85.7626419999999996 85.7408520000000038 85.7405009999999947 85.7413329999999974 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412800000000033 85.7434920000000034 85.7317890000000062 85.7112350000000021 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85
.7108309999999989 85.7086029999999965 85.710716000000005 85.8086169999999981 85.8597110000000043 86.1184920000000034 86.4066239999999937 86.5823060000000027 87.0071640000000031 87.3571089999999941 88.2246399999999937 89.4571229999999957 90.1741789999999952 90.783173000000005 91.2930980000000005 91.7327879999999993 92.2226330000000019 92.9319919999999939 93.6613849999999957 94.2817990000000066 94.8113630000000001 95.395386000000002 95.9502180000000067 96.2323149999999998 96.4357760000000042 96.5401080000000036
+112.7070470000000029 112.7639389999999935 112.739531999999997 112.7368320000000068 112.7424850000000021 112.676169999999999 112.5802230000000037 112.5745090000000062 112.5196150000000017 112.4771269999999959 112.5246889999999951 112.6385729999999938 112.7760999999999996 113.0125730000000033 113.2516629999999935 113.6222759999999994 114.3857500000000016 115.1783070000000038 115.4630200000000002 115.760193000000001 116.247840999999994 116.7001800000000031 117.0905840000000069 117.3866730000000018 117.6135940000000062 117.8301699999999954 117.8211210000000051 117.3057479999999941 116.6254200000000054 116.211662000000004 116.0677720000000051 115.9948270000000008 115.6641539999999964 115.3110889999999955 115.0720139999999958 114.7806240000000031 114.367157000000006 113.5075609999999955 112.115082000000001 109.8787540000000007 107.0767359999999968 103.8309399999999982 100.9005970000000048 99.1878659999999996 99.633018000000007 102.9720310000000012 107.1345210000000066 109.23654899
99999966 109.4731369999999941 109.0011599999999987 109.1966319999999939 109.7326809999999995 110.1273960000000045 110.6035770000000014 111.2445909999999998 112.0153580000000062 112.3557430000000039 112.3159179999999964 112.1446689999999933 111.811286999999993 110.971587999999997 109.6644670000000019 108.4427259999999933 107.501655999999997 106.7091290000000043 105.8572010000000034 104.534797999999995 102.5354159999999979 100.3391649999999942 98.4965669999999989 97.1898570000000035 96.966858000000002 98.8448029999999989 101.0105740000000054 103.156677000000002 105.1247330000000062 106.1599269999999962 106.7619550000000004 107.3785550000000057 107.9712140000000034 108.3942949999999996 108.7512660000000011 108.824150000000003 108.8484040000000022 108.6418610000000058 107.6596530000000058 105.9769969999999972 104.904326999999995 104.6354220000000055 104.6445389999999946 104.882355000000004 104.5200810000000047 103.2234270000000009 102.1071319999999929 101.7695010000000053 101.89
04189999999943 102.132842999999994 102.4943700000000035 102.7031630000000035 102.6568599999999947 102.3149870000000021 101.662391999999997 100.9643549999999976 99.6727369999999979 97.3633420000000029 95.9560699999999969 96.5024109999999951 98.0590519999999941 98.6791690000000017 97.8677440000000018 97.027191000000002 95.8665009999999995 94.9405440000000027 94.7436450000000008 95.0948329999999942 95.8808520000000044 97.0547789999999964 98.3287810000000064 99.223754999999997 99.5516970000000043 98.9420089999999988 97.6850050000000039 96.1797329999999988 94.5233460000000036 92.4726100000000031 90.2746889999999951 88.296165000000002 87.1553650000000033 86.2185130000000015 85.7635499999999951 85.8369289999999978 85.8084340000000054 85.8010409999999979 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022610000000014 85.8029939999999982 85.8000109999999978 85.777161000
0000067 85.7710270000000037 85.7717899999999958 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717289999999934 85.7713549999999998 85.7683559999999972 85.7557749999999999 85.7556299999999965 85.7454220000000049 85.7402950000000033 85.7413480000000021 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7413480000000021 85.7429580000000016 85.7314989999999995 85.7112879999999961 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.71080800000
00001 85.7108080000000001 85.7108080000000001 85.7112120000000033 85.7086330000000061 85.6911089999999973 85.6313549999999992 85.7437209999999936 86.1091610000000003 86.3928989999999999 86.8884429999999952 87.4901959999999974 88.1120829999999984 88.8999100000000055 89.6483609999999942 90.1475599999999986 90.4717250000000064 91.1404799999999966 91.9490509999999972 92.5226360000000057 93.0694660000000056 93.770111 94.3044430000000062 94.8208470000000005 95.4074329999999975 95.6902850000000029 95.841423000000006 95.8329389999999961
+112.1688999999999936 112.3375240000000019 112.4056089999999983 112.4033660000000054 112.3892290000000003 112.2761229999999983 112.1125640000000061 112.0905759999999987 112.0403589999999951 111.899405999999999 111.9280779999999993 112.0919339999999949 112.229857999999993 112.4409789999999987 112.7360460000000018 113.2371370000000042 114.224648000000002 115.0973740000000021 115.3736339999999956 115.6828380000000038 116.2487490000000037 116.6790390000000031 117.0496059999999972 117.3619999999999948 117.5896529999999984 117.7682570000000055 117.8621669999999995 117.5060419999999937 116.9333879999999937 116.6077350000000052 116.2739490000000018 115.953093999999993 115.8473280000000045 115.7371899999999982 115.449821 114.9655910000000034 114.5357130000000012 113.8355099999999993 112.5992739999999941 110.7610399999999942 107.9709849999999989 104.2938230000000033 101.1797030000000035 99.7668299999999988 100.7239150000000052 103.8989179999999948 107.5189589999999953 109.6098939999999
97 110.341858000000002 110.1214750000000038 110.0706330000000008 110.2058870000000042 110.5283199999999937 111.0428390000000007 111.6774979999999999 112.3343729999999994 112.5561370000000068 112.6468660000000028 112.5915760000000034 112.3492889999999989 111.740784000000005 110.7634350000000012 109.8476720000000029 108.9249570000000062 108.0422899999999942 107.2667390000000012 105.7741319999999945 103.2804720000000032 100.6230929999999972 98.8286669999999958 97.6314930000000061 97.3299559999999957 99.4947810000000032 102.0361939999999947 104.448646999999994 106.4356539999999995 107.1610260000000068 107.3970719999999943 107.9041600000000045 108.5062709999999981 108.8855130000000031 109.2822879999999941 109.5309139999999957 109.4306639999999931 109.0948410000000024 108.7604979999999983 107.596100000000007 105.9447329999999994 105.2394790000000029 105.397948999999997 105.6958690000000018 105.0157240000000058 103.6702350000000052 103.2290420000000069 103.4263229999999965 103.6356
959999999958 103.6757810000000006 103.6487500000000068 103.5196609999999993 103.4364850000000047 103.1895289999999932 102.4977800000000059 101.8171159999999986 100.3106920000000031 97.7384189999999933 96.5846250000000026 97.7290119999999973 99.4470369999999946 99.5850300000000033 98.3515699999999953 97.6692350000000005 97.0316159999999996 96.7173460000000063 96.9206159999999954 97.1274949999999961 97.349884000000003 98.2286450000000002 99.4480360000000019 100.2097320000000025 100.4197920000000011 99.7908479999999969 98.6162259999999975 97.5698390000000018 96.3277360000000016 94.3333889999999968 92.5161970000000053 91.1967999999999961 89.9154359999999997 87.7754970000000014 85.9173360000000059 85.8072810000000032 85.8088680000000039 85.800926000000004 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8028489999999948 85.8010330000000039 85.781920999999997 85.771889
0000000016 85.771766999999997 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7712779999999952 85.7605060000000066 85.7508700000000061 85.7420960000000036 85.7402569999999997 85.7409519999999929 85.7413410000000056 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7420120000000026 85.7390900000000045 85.7204899999999981 85.7109760000000023 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000
000001 85.7108080000000001 85.7108080000000001 85.7108309999999989 85.7111359999999962 85.7102509999999995 85.7178420000000045 85.6632079999999974 85.7436139999999938 86.0999759999999981 86.6987840000000034 87.2815930000000009 87.6812520000000006 88.0767670000000038 88.8050159999999948 89.3608250000000055 89.7196349999999967 90.5286100000000005 91.535979999999995 92.1045299999999969 92.5284269999999935 93.1586839999999938 93.7599330000000037 94.360352000000006 94.889251999999999 95.1783829999999966 95.3107600000000019 95.2955319999999944
+111.7064969999999988 111.9415359999999993 112.0801770000000062 112.0405429999999996 111.9789200000000022 111.8817370000000011 111.6888119999999986 111.5694890000000044 111.586860999999999 111.5476299999999981 111.6397319999999951 111.7987519999999932 112.0289460000000048 112.3450849999999974 112.6852489999999989 113.2757720000000035 114.1492839999999944 114.9416810000000027 115.3499369999999971 115.7042079999999942 116.2725980000000021 116.6726000000000028 117.0070950000000067 117.3239590000000021 117.6087880000000041 117.7995760000000018 117.7752689999999944 117.4380490000000066 117.1716919999999931 117.1000370000000004 116.7636260000000021 116.1091689999999943 115.8174740000000043 115.7551270000000017 115.5607219999999984 115.2060699999999969 114.7645260000000036 114.1444699999999983 113.2182999999999993 111.6697240000000022 108.6573099999999954 104.6357189999999946 101.5936659999999989 100.4642410000000012 101.6380920000000003 104.7320100000000025 107.8280639999999977 109
.9701770000000067 111.0346449999999976 110.8793179999999978 110.6210099999999983 110.7590560000000011 111.1233059999999995 111.5110169999999954 112.0854719999999958 112.8685679999999962 113.3544689999999946 113.681358000000003 113.6029130000000009 113.165740999999997 112.4857180000000056 111.5749890000000022 110.6923599999999936 109.898658999999995 109.0331039999999945 108.0436710000000033 106.4162900000000036 103.6805880000000002 100.676361 98.6819529999999929 97.8165970000000016 97.6884840000000025 99.4804610000000054 102.6214750000000038 105.526245000000003 107.3123470000000026 107.7437670000000054 107.9661789999999968 108.4075930000000056 108.7743839999999977 109.0323489999999964 109.3318859999999972 109.4870300000000043 109.4573209999999932 109.197449000000006 108.4582060000000041 107.0415270000000021 105.8437729999999988 105.7792429999999939 106.0666729999999944 106.2161329999999992 105.7877579999999966 104.9095310000000012 104.8240129999999937 105.1308819999999997 105
.3191149999999965 105.3140180000000043 104.9485320000000002 104.4367369999999937 104.1630099999999999 103.9464339999999964 103.3557050000000004 102.4227219999999932 100.5509189999999933 98.1482850000000013 97.3827440000000024 98.6863780000000048 100.199577000000005 100.0394059999999996 99.157439999999994 98.7583470000000005 98.0576630000000051 97.620514 97.7879870000000011 97.8294450000000069 97.8919599999999974 98.624992000000006 99.8089370000000002 100.5704350000000034 100.6943279999999987 100.2096630000000062 99.4838490000000064 98.8528819999999939 97.7889100000000013 96.0974429999999984 94.5677189999999968 93.2703020000000009 91.7768939999999986 89.1404339999999991 86.2292249999999996 85.6447220000000016 85.8200070000000039 85.8015139999999974 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022380000000027 85.8036730000000034 85.7959589999999963 85.774840999999995 85.771743999
9999982 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717739999999935 85.7707369999999969 85.7501749999999987 85.7388760000000048 85.7412410000000023 85.7412949999999938 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7427899999999994 85.7336350000000067 85.7129670000000061 85.7107699999999966 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.710808000000
0001 85.7108080000000001 85.7108080000000001 85.7108000000000061 85.7104190000000017 85.7055820000000068 85.6942899999999952 85.6876529999999974 85.6616130000000027 85.8216319999999939 86.4096600000000024 86.8311389999999932 87.0964510000000018 87.2149430000000052 87.8165740000000028 88.3884120000000024 88.8952100000000058 89.7711720000000071 90.6389010000000042 91.3748860000000036 92.0720060000000018 92.6373439999999988 93.3379209999999944 93.9846419999999938 94.3742369999999937 94.6813429999999983 94.7595900000000029 94.7800900000000013
+111.3524019999999979 111.4914399999999972 111.5360639999999961 111.5185929999999956 111.5093770000000006 111.3950880000000012 111.224616999999995 111.0904919999999976 111.088325999999995 111.1994090000000028 111.4367680000000007 111.6750949999999989 112.1354829999999936 112.650115999999997 113.0633540000000039 113.5682139999999976 114.1687550000000044 114.8337020000000024 115.3523030000000063 115.7591400000000021 116.2969889999999964 116.7235029999999938 117.0930249999999972 117.405540000000002 117.628296000000006 117.7221600000000024 117.5549160000000057 117.3280560000000037 117.2385940000000062 117.230164000000002 117.0203170000000057 116.4618679999999955 115.9844889999999964 115.8131180000000029 115.6173480000000069 115.2694929999999971 114.7697679999999991 114.2863080000000053 113.5970839999999953 112.1857300000000066 109.3753509999999949 105.6185990000000032 102.503112999999999 101.2519759999999991 102.4180070000000029 105.4412920000000042 108.4441300000000012 110.54282
3999999996 111.6370009999999979 111.6188429999999983 111.2845839999999953 111.3622890000000041 111.6484379999999987 111.9387590000000046 112.5784380000000056 113.5350190000000055 114.2471390000000042 114.6501619999999946 114.4140550000000047 113.725837999999996 112.9491730000000018 112.1087420000000066 111.032707000000002 110.2638630000000006 109.4494399999999956 108.1943049999999999 106.3654169999999937 103.3282470000000046 100.2803959999999961 98.6654359999999997 98.9305729999999954 99.231773000000004 99.8873439999999988 102.561797999999996 105.9366839999999996 107.8310699999999969 108.1029889999999938 108.2861479999999972 108.6802140000000065 108.912627999999998 109.1297069999999962 109.3867340000000041 109.465369999999993 109.2001340000000056 108.3819660000000056 107.2590330000000023 106.5085749999999933 106.5604100000000045 106.6693729999999931 106.5635759999999976 106.5882339999999999 106.5571589999999986 106.1944050000000033 106.2519910000000039 106.5867690000000039 1
06.793059999999997 106.6723329999999947 106.1482850000000013 105.5924219999999991 105.1677399999999949 104.7012789999999995 104.0206069999999983 102.7557139999999976 100.7794039999999995 98.6521450000000044 98.1504060000000038 99.4239199999999954 100.600639000000001 100.5178829999999977 100.2483900000000006 100.0626979999999975 99.2445450000000022 98.3172229999999985 97.9956669999999974 98.0119320000000016 98.0416409999999985 98.6550749999999965 99.8248669999999976 100.6889270000000067 100.9327849999999955 100.6708299999999952 100.3909610000000043 100.101532000000006 99.2123490000000032 97.7606810000000053 96.2218859999999978 94.4681470000000019 92.2890469999999965 89.4642110000000059 86.5302580000000034 85.6151890000000009 85.8142320000000041 85.8018950000000018 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8024290000000036 85.8025209999999987 85.7876049999999992 85.772651999999
9937 85.7717509999999947 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7724230000000034 85.7638699999999972 85.7438889999999958 85.7403719999999936 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7426379999999995 85.7347340000000031 85.7137599999999935 85.7107850000000013 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.710808000000000
1 85.7108000000000061 85.7108460000000036 85.7109300000000047 85.7088700000000046 85.6977159999999998 85.6879200000000054 85.6798399999999987 85.679665 85.6763229999999965 85.7159189999999995 85.9221040000000045 86.1848829999999992 86.5496899999999982 86.6034549999999967 86.9314349999999934 87.3715519999999941 87.9258039999999994 88.9339370000000002 89.8973239999999976 90.8371730000000071 91.6862720000000024 92.299987999999999 92.9773859999999956 93.5098720000000014 93.926353000000006 94.1815950000000015 94.228699000000006 94.334259000000003
+111.0763089999999949 111.024840999999995 110.9401929999999936 110.9464260000000024 110.9831240000000037 110.8649669999999929 110.7363589999999931 110.6089630000000028 110.577606000000003 110.7547760000000068 111.0684360000000055 111.5419160000000005 112.1625209999999981 112.7991870000000034 113.3167190000000062 113.7670669999999973 114.3013990000000035 114.8439029999999974 115.3361890000000045 115.8179700000000025 116.2633440000000036 116.6999440000000021 117.1650539999999978 117.4666979999999938 117.6081999999999965 117.6450040000000001 117.4158400000000029 117.2307050000000004 117.1059419999999989 117.0085980000000063 116.8732449999999972 116.5540309999999948 116.2113650000000007 115.9535979999999995 115.664124000000001 115.3505329999999987 114.8173139999999961 114.2381519999999995 113.5604710000000068 112.4766539999999964 110.3067700000000002 106.7971270000000032 103.5724560000000025 102.3086780000000005 103.4507600000000025 106.0807420000000008 108.847565000000003 110.98
31240000000037 112.1495290000000011 112.2919080000000065 111.9521179999999987 111.9044269999999983 112.0976560000000006 112.3521729999999934 113.079780999999997 113.9724269999999962 114.6102520000000027 114.9148330000000016 114.6650700000000001 113.9883269999999982 113.2111210000000057 112.3772739999999999 111.2260590000000064 110.3136290000000059 109.3730469999999997 108.0402150000000034 105.6029359999999997 102.110564999999994 99.7954639999999955 99.6318049999999999 101.0701750000000061 101.4279099999999971 101.4454419999999999 103.4598390000000023 106.3637619999999941 108.1874540000000025 108.5487750000000062 108.7483900000000006 108.9277649999999937 109.0658719999999988 109.1568220000000053 109.3526080000000036 109.0108489999999932 108.2014240000000029 107.373542999999998 107.0637439999999998 107.4088820000000055 107.8412249999999943 107.8029480000000007 107.4021379999999937 107.0485840000000053 107.0760879999999986 107.1401599999999945 107.1466219999999936 107.503258000
0000024 107.7754060000000038 107.557502999999997 107.0759510000000034 106.5826799999999963 105.9908369999999991 105.3322979999999944 104.5114209999999986 103.1695330000000013 101.2067339999999973 99.1819610000000011 98.8096079999999972 100.1346130000000016 101.2844769999999954 101.3710329999999971 101.1647109999999969 100.9405979999999943 100.3101879999999966 99.2140119999999968 98.3412399999999991 98.2781980000000033 98.5382919999999984 99.2190319999999986 100.287384000000003 101.076911999999993 101.4709780000000023 101.4344020000000057 101.3196329999999961 101.1514279999999957 100.3158870000000036 98.6623539999999934 96.6923599999999936 94.4712980000000044 91.9053269999999998 89.3333279999999945 87.0143130000000014 85.7721939999999989 85.7376940000000047 85.8066639999999978 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022380000000027 85.8025590000000022 85.7912599999999941 85.773231999999993 85.
7715840000000043 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7734219999999965 85.7541499999999957 85.7394330000000053 85.741264000000001 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7426219999999972 85.7347560000000044 85.7137830000000065 85.7107769999999931 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.71080
80000000001 85.710875999999999 85.7105870000000039 85.7097090000000037 85.6988910000000033 85.679481999999993 85.6791079999999994 85.6802440000000018 85.6803210000000064 85.6809460000000058 85.6703409999999934 85.632598999999999 85.7065659999999951 85.928719000000001 86.0543440000000004 86.2958299999999952 86.7277980000000071 87.263062000000005 88.2666700000000048 89.4912410000000023 90.6174319999999938 91.3770980000000037 91.997649999999993 92.6734239999999971 93.1158750000000026 93.5013280000000009 93.6803050000000042 93.7740100000000041 93.9417190000000062
+110.7463230000000038 110.5599749999999943 110.4638520000000028 110.4201809999999995 110.4273989999999941 110.3899839999999983 110.289551000000003 110.1776499999999999 110.2017749999999978 110.396568000000002 110.7742999999999967 111.4487150000000071 112.099174000000005 112.7169949999999972 113.281218999999993 113.8216319999999939 114.3891909999999967 114.860328999999993 115.3307340000000067 115.8869250000000051 116.2684169999999995 116.6140290000000022 117.0533070000000038 117.3130649999999946 117.4559560000000005 117.4932479999999941 117.3032070000000004 117.1820299999999975 117.034087999999997 116.8455660000000051 116.6942750000000046 116.4771580000000029 116.2058870000000042 115.8694080000000071 115.5355529999999931 115.3606800000000021 115.0958629999999943 114.5835270000000037 113.5177230000000037 111.9272079999999931 109.6698379999999986 106.6940989999999942 104.2343139999999977 103.5038449999999983 104.6899109999999951 107.0301819999999964 109.4891889999999961 111.5836
330000000061 112.6556470000000019 112.8276749999999993 112.580994000000004 112.4717559999999992 112.6080549999999931 112.7560730000000007 113.4786150000000049 114.2616349999999983 114.705475000000007 114.9031520000000057 114.7300419999999974 114.1980590000000007 113.4269100000000066 112.3561329999999998 111.1518400000000071 110.1850199999999944 108.9861219999999946 107.157866999999996 104.1244200000000006 101.2987289999999945 100.6302869999999956 101.8733670000000018 103.5778049999999979 103.7075040000000001 104.1783140000000003 105.9377589999999998 107.4801790000000068 108.6362840000000034 109.1037900000000036 109.3028950000000066 109.2448499999999996 109.219025000000002 108.9963230000000038 108.8128279999999961 108.2670209999999997 107.836860999999999 107.8811110000000042 108.2313000000000045 108.7366870000000034 108.8681789999999978 108.6194760000000059 108.2977450000000061 107.7684480000000065 107.4999239999999929 107.6297449999999998 107.6818470000000048 107.98818199999
99948 108.2567370000000011 108.0834200000000038 107.7049559999999957 107.2610930000000025 106.5760420000000011 105.850127999999998 104.8970640000000003 103.3528749999999974 101.3434139999999957 99.6947169999999971 99.6115949999999941 100.9506300000000039 102.0488359999999943 102.1377260000000007 101.8934169999999995 101.5782849999999939 101.0803070000000048 100.0158080000000069 98.7136150000000043 98.6595080000000024 99.5557100000000048 100.4503019999999935 101.2826919999999973 101.945533999999995 102.3536220000000014 102.3425519999999977 102.0646129999999943 101.6008219999999937 100.5398249999999933 98.4932940000000059 96.1027830000000023 93.6091380000000015 91.2956769999999977 89.5731739999999945 87.9662019999999956 86.1391220000000004 85.6461939999999942 85.8235779999999977 85.803496999999993 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.802299000000005 85.7937469999999962 85.7744979999999941 85.771064999999993 85.7
717209999999994 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717130000000054 85.7735059999999976 85.7564469999999943 85.7389600000000058 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7426070000000067 85.7347950000000054 85.7138209999999958 85.7107699999999966 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108
379999999954 85.7117690000000039 85.7056730000000044 85.6940689999999989 85.6835099999999983 85.6793590000000052 85.6803440000000052 85.6803210000000064 85.6803210000000064 85.6803050000000042 85.6806490000000025 85.6816479999999956 85.681800999999993 85.6174469999999985 85.6495440000000059 85.8132630000000063 86.2550659999999993 86.784790000000001 87.8118900000000053 89.2463609999999932 90.379294999999999 91.1429600000000022 91.6433410000000066 92.3173979999999972 92.8301469999999966 93.0793299999999988 93.2589569999999952 93.4039920000000023 93.3977660000000043
+110.2997969999999981 110.0366060000000061 110.0259929999999997 109.943398000000002 109.870941000000002 109.9223559999999935 109.8816680000000048 109.8780289999999979 109.9725799999999936 110.1272129999999976 110.611701999999994 111.3703919999999954 112.0261310000000066 112.5981450000000024 113.1405029999999954 113.7546770000000009 114.3510129999999947 114.8321300000000065 115.262084999999999 115.7694549999999936 116.185615999999996 116.5175399999999968 116.8763430000000056 117.1064989999999995 117.264671000000007 117.2719960000000015 117.1658549999999934 117.1009829999999994 116.9708329999999989 116.8522339999999957 116.6824869999999947 116.5144200000000012 116.1667479999999983 115.7018810000000002 115.2907560000000018 115.0252839999999992 114.9691930000000042 114.9524380000000008 114.2892149999999987 112.4333270000000056 109.6462250000000012 106.7016909999999967 104.9523539999999997 104.755866999999995 105.7688220000000001 107.8812099999999958 110.4201510000000042 112.38137
10000000015 113.1944199999999938 113.3384250000000009 113.2203449999999947 113.0826569999999975 113.1475910000000056 113.2128979999999956 113.8090899999999976 114.5262369999999947 114.8065950000000015 114.9305569999999932 114.7728120000000018 114.338325999999995 113.5717319999999972 112.2991180000000071 110.717772999999994 109.3539959999999951 107.833045999999996 105.514167999999998 102.9239960000000025 102.1750260000000026 103.2533109999999965 104.9181059999999945 105.9117889999999989 105.9054110000000009 106.9349979999999931 108.1777880000000067 108.7607189999999946 109.2976460000000003 109.5538939999999997 109.5350109999999972 109.3242029999999971 109.1108169999999973 108.8526609999999977 108.6100229999999982 108.4518589999999989 108.718993999999995 109.1766889999999961 109.4544219999999939 109.5897669999999948 109.4811710000000033 109.187775000000002 108.9481430000000017 108.5450359999999961 108.1178210000000064 108.0887069999999994 108.1698229999999938 108.2380600000000
044 108.4257580000000019 108.3357699999999966 108.1086200000000019 107.7054289999999952 107.0054930000000013 106.0480730000000023 104.7607880000000051 103.0731580000000065 101.4376220000000046 100.5242389999999943 100.7110519999999951 101.8993069999999932 102.7501220000000046 102.6960679999999968 102.5787890000000004 102.3650360000000035 101.9101639999999946 100.9733580000000046 99.4762269999999944 99.4210970000000032 100.910736 101.9508670000000023 102.5781779999999941 103.1150590000000022 103.3207089999999937 103.0417329999999936 102.3439639999999997 101.3690720000000027 99.8481220000000036 97.2633969999999977 94.8611219999999946 92.9347460000000041 91.7183760000000063 91.0360950000000031 89.8193509999999975 87.5161740000000066 85.5798869999999994 85.5041200000000003 85.8047559999999976 85.8019409999999993 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8024599999999964 85.7826919999999973 85.7698139999999967 85.7716669999999937 85.771759
000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717130000000054 85.7726289999999949 85.7706759999999946 85.7479399999999998 85.7402040000000056 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7425989999999985 85.734809999999996 85.7138439999999946 85.7107699999999966 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108000000000061 85.7113109999
999949 85.7099000000000046 85.6896440000000013 85.6800309999999996 85.6802440000000018 85.6803440000000052 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6800839999999937 85.682068000000001 85.6747280000000018 85.6437229999999943 85.9101940000000042 86.5368880000000047 87.5339890000000054 88.9698029999999989 90.1087109999999996 90.9449230000000028 91.4185030000000012 91.9526369999999957 92.4605260000000015 92.7200930000000056 92.8225249999999988 92.9744029999999952 92.8992839999999944
+109.876221000000001 109.5943299999999994 109.5857469999999978 109.5754780000000039 109.4745099999999951 109.4836350000000067 109.5332949999999954 109.6605610000000013 109.764954000000003 109.9244840000000067 110.5365829999999931 111.3330610000000007 111.9795459999999991 112.532707000000002 113.0910949999999957 113.7186580000000049 114.3150020000000069 114.7745589999999964 115.1516950000000037 115.5666959999999932 115.9416279999999944 116.278931 116.6260300000000001 116.9012830000000065 117.0849299999999999 117.1113430000000051 117.0253909999999991 116.9181899999999956 116.8222499999999968 116.829102000000006 116.6889189999999985 116.4800639999999987 116.0422360000000026 115.5086139999999943 115.1099930000000029 114.7911830000000037 114.5590440000000001 114.5465930000000014 114.7923279999999977 114.4539489999999944 112.6766130000000032 109.8032299999999992 107.4867940000000033 106.2901839999999964 106.8737030000000061 108.9458690000000018 111.389922999999996 113.0578079999999
943 113.6411130000000043 113.8958279999999945 113.904083 113.728950999999995 113.643897999999993 113.6753159999999951 114.1811519999999973 114.7112350000000021 114.8901369999999957 114.968079000000003 114.7476580000000013 114.344184999999996 113.6395490000000024 112.3306120000000021 110.1856839999999949 107.9821239999999989 106.2329409999999967 104.390625 103.4786069999999967 104.6817089999999979 106.2032389999999964 107.2967000000000013 107.6279750000000064 107.804893000000007 108.735045999999997 109.4328459999999978 109.7782519999999948 109.944389000000001 109.7293399999999934 109.4531400000000048 109.3277659999999969 109.1217120000000023 108.9371340000000004 108.849700999999996 108.8871460000000013 109.2793879999999973 109.6901469999999961 109.7759860000000032 109.7679140000000046 109.7059780000000018 109.4984440000000063 109.2946469999999977 108.999756000000005 108.6709139999999962 108.6672590000000014 108.7658310000000057 108.6793210000000016 108.5380329999999987 108.33
83869999999973 108.173798000000005 107.8459399999999988 107.2863080000000053 106.2290880000000044 104.8062129999999996 103.433014 102.2094960000000015 101.4343800000000044 101.7032010000000071 102.8354870000000005 103.4570850000000064 103.3450239999999951 103.4434739999999948 103.4343719999999962 102.9228899999999953 102.1504359999999991 101.0763780000000054 101.1463549999999998 102.4720690000000047 103.4457780000000042 103.9837720000000019 104.285979999999995 104.1971439999999944 103.4638819999999981 102.4077609999999936 100.8260570000000058 98.7470930000000067 96.1380769999999956 94.4610980000000069 94.0533070000000038 93.933014 93.5223919999999964 92.455260999999993 90.5000229999999988 87.7597959999999944 85.922302000000002 85.5070570000000032 85.7956010000000049 85.8083799999999997 85.8015139999999974 85.8022459999999967 85.8022459999999967 85.802550999999994 85.7800450000000012 85.7691800000000057 85.7718509999999981 85.771759000000003 85.771759000000003 85.771759000000
003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717289999999934 85.7724000000000046 85.7727969999999971 85.7530059999999992 85.7415850000000006 85.7412029999999987 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412800000000033 85.7426300000000055 85.7362439999999992 85.7143480000000011 85.7107620000000026 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108230000000049 85.7098620000000011 85.7010729999999938 85.690796000000006 85.6814119999999
946 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6802289999999971 85.6629870000000011 85.7698900000000037 86.3235090000000014 87.2391889999999961 88.4785920000000061 89.6795730000000049 90.7010039999999975 91.2104340000000064 91.6004259999999988 92.0736540000000048 92.335991000000007 92.3832469999999972 92.473236 92.3866199999999935
+109.4580610000000007 109.2415390000000031 109.1796190000000024 109.2162859999999966 109.1454240000000055 109.0685579999999959 109.228431999999998 109.4935990000000032 109.5874790000000019 109.8479459999999932 110.6015780000000035 111.3767550000000028 112.0005799999999994 112.5353620000000063 113.1019900000000007 113.678496999999993 114.2304460000000006 114.657905999999997 115.0136799999999937 115.4136660000000063 115.7158430000000067 115.9919050000000027 116.3606340000000046 116.6947250000000054 116.9279480000000007 116.9664539999999988 116.8507230000000021 116.7798389999999955 116.7625429999999938 116.7349470000000053 116.6190720000000027 116.3165659999999946 115.7615969999999948 115.2809680000000014 115.0734020000000015 114.8712539999999933 114.4386369999999999 114.0285640000000029 114.106110000000001 114.654326999999995 114.8230899999999934 113.9319990000000047 111.8498380000000054 109.5125349999999997 109.0661999999999949 110.6408619999999985 112.3481599999999929 113.524
1850000000028 114.1436839999999933 114.4990920000000045 114.5651629999999983 114.4006650000000036 114.1777950000000033 114.1883540000000039 114.6481780000000015 114.8855510000000066 114.9337230000000005 114.9222340000000031 114.6649019999999979 114.2917400000000043 113.6457520000000017 112.2868270000000024 109.8932800000000043 107.3697130000000044 105.9127199999999931 105.3125529999999941 105.8844299999999947 107.4560089999999946 108.3696209999999951 108.8249590000000069 109.0759809999999987 109.4844510000000071 109.9599840000000057 110.115752999999998 110.2168499999999938 110.1261219999999952 109.789008999999993 109.5088200000000001 109.317420999999996 109.0253979999999956 108.7136310000000066 108.6293790000000001 108.691993999999994 109.0550000000000068 109.4579319999999996 109.581908999999996 109.5704350000000034 109.4774929999999955 109.2578510000000023 109.1475750000000033 109.0840989999999948 108.9759829999999994 109.0384449999999958 109.280296000000007 109.32674400000
0005 109.0123439999999988 108.6847920000000016 108.3451160000000044 107.946228000000005 107.4443360000000069 106.6754909999999938 105.8347629999999953 105.0431750000000051 103.9427490000000063 102.7302169999999961 102.744133000000005 103.8440319999999986 104.3994979999999941 104.3318560000000019 104.5953449999999947 104.7445909999999998 104.2798460000000063 103.6558689999999956 103.197174000000004 103.4378509999999949 104.0890579999999943 104.7502669999999938 105.1186370000000068 105.1473309999999941 104.7933809999999966 103.833991999999995 102.3739400000000046 100.3165970000000016 98.6017609999999962 97.1234740000000016 96.4165500000000009 96.772705000000002 96.8118209999999948 96.2536929999999984 95.3105319999999949 93.9786830000000037 91.9758070000000032 89.0372770000000031 86.5694890000000044 85.7266850000000034 85.7548290000000009 85.8110199999999992 85.8022459999999967 85.8022459999999967 85.8024369999999976 85.7889789999999977 85.7720259999999968 85.7712860000000035 8
5.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7720790000000051 85.7731320000000039 85.757606999999993 85.7426679999999948 85.7411649999999952 85.7413020000000046 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7414019999999937 85.7408369999999991 85.7271499999999946 85.7120510000000024 85.7107769999999931 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7107620000000026 85.7110210000000023 85.7113489999999985 85.7014010000000042 85.6
817400000000049 85.6801990000000018 85.6803440000000052 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6804810000000003 85.6702420000000018 85.6659549999999967 85.9352719999999977 86.714539000000002 87.8624109999999945 89.1088259999999934 90.2586670000000026 90.884925999999993 91.2700040000000001 91.6615829999999931 91.860564999999994 91.8736719999999991 91.877135999999993 91.8034669999999977
+108.9734270000000009 108.7822800000000001 108.7745510000000024 108.7578199999999953 108.6384960000000035 108.5851059999999961 108.9279020000000031 109.3585819999999984 109.5223459999999989 109.8878559999999993 110.6689530000000019 111.3668370000000039 111.9576950000000011 112.5024870000000021 113.025383000000005 113.5187990000000013 114.0104829999999936 114.4480209999999971 114.7434839999999951 115.1452479999999952 115.5257490000000047 115.832367000000005 116.2489779999999939 116.5951840000000033 116.8603439999999978 116.921204000000003 116.7349700000000041 116.6670529999999957 116.7388380000000012 116.6010670000000005 116.3978579999999994 116.0434190000000001 115.5217130000000054 115.1881560000000064 115.0351639999999946 114.7940980000000053 114.351592999999994 113.845673000000005 113.3885960000000068 113.3392939999999953 114.1551359999999988 115.2820049999999981 114.9201809999999995 113.6261290000000059 112.543578999999994 112.6679610000000054 113.2046279999999996 113.8799
290000000042 114.6678619999999995 115.0521999999999991 115.1626430000000028 115.0212329999999952 114.7184830000000062 114.732215999999994 115.0552899999999994 114.9927140000000065 114.9534840000000031 114.8270949999999999 114.5523299999999978 114.1923900000000032 113.6100689999999958 112.163139000000001 109.6335299999999933 107.6941759999999988 107.0918810000000008 107.5789029999999968 108.4903560000000056 109.4869309999999984 110.0916979999999938 110.3267139999999955 110.4441599999999966 110.6271289999999965 110.5887989999999945 110.3337779999999952 110.277191000000002 110.234375 110.0116040000000055 109.6963959999999929 109.1391370000000052 108.5794530000000009 108.1834029999999984 108.1364750000000043 108.244324000000006 108.4981690000000043 108.876380999999995 109.1629329999999953 109.2045590000000033 109.0310900000000061 108.8273319999999984 108.813880999999995 108.8537139999999965 108.9569019999999995 109.1802440000000018 109.5044249999999977 109.6702420000000018 109.5
986630000000019 109.394835999999998 108.9309389999999951 108.3883739999999989 107.8675080000000008 107.2796859999999981 106.815094000000002 106.3895650000000046 105.6724549999999994 104.7718809999999934 104.5258029999999962 105.1831590000000034 105.6943360000000069 105.7365190000000013 105.9130169999999964 105.9980010000000021 105.6905589999999933 105.268889999999999 105.0796890000000019 105.1688610000000068 105.3128049999999973 105.5792079999999942 105.709502999999998 105.5512080000000026 105.0921479999999946 104.1666950000000043 102.499565000000004 100.7651670000000053 100.0463029999999947 99.5845719999999943 99.3255390000000062 99.3653719999999936 99.1874159999999989 98.6872790000000037 97.722099 96.2758330000000058 94.3410109999999946 91.6928630000000027 88.6831889999999987 86.4433209999999974 85.7736660000000057 85.8024750000000012 85.801085999999998 85.8022459999999967 85.8022770000000037 85.7984699999999947 85.7768860000000046 85.7699810000000014 85.7717970000000065 8
5.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7718119999999971 85.772712999999996 85.7615129999999937 85.7434159999999963 85.7410579999999953 85.7412949999999938 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7416309999999982 85.7369840000000067 85.7163699999999977 85.7102809999999948 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7107539999999943 85.7118679999999955 85.7077940000000069 85.6971970000000027 85.6855999999999938 85.6793519999999944 85
.6802370000000053 85.6803129999999982 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803280000000029 85.6813740000000053 85.6622849999999971 85.6399609999999996 86.084266999999997 87.3210830000000016 88.5633320000000026 89.6933439999999962 90.5164790000000039 90.9231029999999976 91.2590480000000071 91.5064009999999968 91.3998030000000057 91.1895679999999942 91.0973970000000008
+108.602485999999999 108.3803560000000061 108.3774410000000046 108.3286059999999935 108.1374279999999999 108.1829070000000002 108.6829759999999965 109.200287000000003 109.4887999999999977 109.9338910000000027 110.6123960000000039 111.2667009999999976 111.8277659999999969 112.3383029999999962 112.8329540000000009 113.322181999999998 113.7615890000000007 114.2201840000000033 114.5191800000000057 114.8704450000000037 115.3301539999999932 115.6957929999999948 116.1431429999999949 116.5008700000000061 116.7282710000000066 116.8740080000000034 116.6315309999999954 116.4372479999999968 116.517784000000006 116.3631129999999985 116.0297699999999992 115.6950149999999979 115.386330000000001 115.099700999999996 114.7597200000000015 114.4235989999999958 114.0445940000000036 113.6849590000000063 113.309898000000004 112.8687129999999996 113.3382720000000035 114.9439540000000051 115.5569839999999999 115.3361739999999998 114.6838070000000016 114.246459999999999 114.0753399999999971 114.175055
9999999979 114.654326999999995 115.0630869999999959 115.3320159999999959 115.2844240000000013 114.9919969999999978 115.0132289999999955 115.1179580000000016 114.8425830000000047 114.8956380000000053 114.7792969999999997 114.4684220000000039 114.0765459999999933 113.5631099999999947 112.2735669999999999 109.9437259999999981 108.6720580000000069 108.7568360000000069 109.6281280000000038 110.3230819999999994 110.8356629999999967 111.189384000000004 111.2452239999999932 111.0980529999999931 110.9498829999999998 110.8070069999999987 110.732048000000006 110.7079930000000019 110.612480000000005 110.2797470000000004 109.7888870000000026 109.0574569999999994 108.3244629999999944 107.8387830000000065 107.7349090000000018 107.7702259999999939 107.7976910000000004 107.9666059999999987 108.434235000000001 108.6874619999999965 108.6762470000000036 108.6882860000000051 108.6240080000000034 108.5015790000000067 108.6395490000000024 109.1028519999999986 109.5439070000000044 109.7571180000000
055 109.853675999999993 109.815764999999999 109.5218809999999934 109.0496830000000017 108.650299000000004 107.9653629999999964 107.0690309999999954 106.6797260000000023 106.4148480000000063 106.0469889999999964 105.9198609999999974 106.1834110000000067 106.6127319999999941 106.9020540000000068 106.9851529999999968 106.8946229999999957 106.6828380000000038 106.4289700000000067 106.250427000000002 106.1600109999999972 106.1211469999999935 106.2064510000000013 106.1844940000000008 105.9310069999999939 105.4430310000000048 104.553252999999998 103.2672649999999948 102.3134919999999966 102.0253979999999956 101.5768199999999979 101.2201459999999997 101.0765609999999981 100.8193279999999987 100.3601840000000038 99.0418470000000042 96.9561460000000039 94.7946929999999952 92.6174160000000057 90.7226330000000019 88.0690000000000026 85.8972090000000037 85.6950379999999967 85.8082279999999997 85.8022459999999967 85.8022380000000027 85.8014600000000058 85.7847670000000022 85.7696530000000
052 85.7714079999999939 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7716900000000066 85.7724149999999952 85.7651440000000065 85.7444310000000058 85.7405619999999971 85.7412489999999963 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7416920000000005 85.7383420000000029 85.7167589999999961 85.7099230000000034 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7113650000000007 85.7100910000000056 85.6918869999999941 85.681549000000004 85.6805650000000
014 85.6802140000000065 85.6803280000000029 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6804280000000063 85.6793980000000062 85.6663130000000024 85.7029569999999978 86.6879959999999983 87.9988330000000047 89.0971600000000024 89.9260479999999944 90.4101409999999959 90.824852000000007 91.2261280000000028 90.9846650000000068 90.559905999999998 90.3591919999999931
+108.2663189999999958 108.0801620000000014 108.0125579999999985 107.9794770000000028 107.8277130000000028 107.976624000000001 108.5301819999999964 109.0392460000000057 109.4012989999999945 109.8832629999999995 110.4775769999999966 111.1034700000000015 111.6474000000000046 112.0815659999999951 112.5597460000000041 113.0820010000000053 113.5307690000000065 114.0246889999999951 114.3906479999999988 114.7239759999999933 115.167816000000002 115.5183179999999936 115.9286419999999964 116.306358000000003 116.4593959999999981 116.6001129999999932 116.4614789999999971 116.2263719999999978 116.1826400000000064 116.0723339999999979 115.7641979999999933 115.4800340000000034 115.2102509999999995 114.8000260000000026 114.4035640000000029 114.1850740000000002 113.9681700000000006 113.7361070000000041 113.4373700000000014 112.9427189999999968 113.3277889999999957 114.8813629999999932 115.1766889999999961 114.2885359999999935 113.9853669999999966 114.3321990000000028 114.4961169999999981 114.4
082109999999943 114.3987730000000056 114.5286409999999933 114.7082139999999981 114.7444839999999999 114.5912929999999932 114.5892489999999952 114.4943159999999978 114.2135090000000019 114.3758930000000049 114.3805689999999942 114.1254880000000043 113.7883000000000067 113.3557890000000015 112.5611040000000003 111.2549669999999935 110.4339750000000038 110.5443729999999931 111.0929409999999962 111.4648210000000006 111.585907000000006 111.5285800000000052 111.5292050000000046 111.5185620000000029 111.3952790000000022 111.3847659999999991 111.4428560000000061 111.2490010000000069 110.8402480000000025 110.4006880000000024 109.816032000000007 109.0811609999999945 108.2548519999999996 107.6236799999999931 107.4044880000000006 107.3222889999999978 107.2137149999999934 107.1558459999999968 107.536713000000006 108.0224989999999963 108.2263260000000002 108.2838289999999972 108.3115159999999975 108.2559969999999936 108.3696520000000021 108.8619999999999948 109.3316120000000069 109.759415
0000000042 110.059905999999998 110.0905460000000033 109.9104229999999944 109.6064680000000067 109.3009409999999946 108.236976999999996 106.993378000000007 106.8924559999999957 106.9961320000000029 106.6651540000000011 106.7309190000000001 106.9406199999999956 107.0791169999999966 107.2459949999999935 107.375938000000005 107.4686810000000037 107.4137570000000039 107.2605060000000066 107.1256410000000017 107.0147089999999963 106.9883880000000005 106.9992600000000067 106.9324799999999982 106.6317290000000071 106.0102080000000058 105.2587130000000002 104.5124279999999999 103.843079000000003 103.4305949999999967 102.789985999999999 102.2176130000000001 102.0342250000000064 101.7772829999999971 101.2554860000000048 99.6019670000000019 97.3874590000000069 95.7856670000000037 94.4636540000000053 93.0494230000000044 89.6295240000000035 86.0645679999999942 85.5969010000000026 85.8136369999999999 85.8022459999999967 85.8022459999999967 85.8022540000000049 85.7984699999999947 85.7817459
999999983 85.7719040000000064 85.7717439999999982 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7716450000000066 85.7726360000000057 85.7689589999999953 85.7465820000000036 85.7400669999999963 85.7411579999999987 85.7412949999999938 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.741264000000001 85.7419890000000038 85.7327039999999982 85.7128139999999945 85.7103419999999971 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7107769999999931 85.7126389999999958 85.7050780000000003 85.6833649999999949 85.6800839999999937 85.68026
70000000006 85.6803359999999969 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803129999999982 85.680419999999998 85.6837459999999993 85.6325379999999967 86.0452729999999946 87.186522999999994 88.3422779999999932 89.3189699999999931 90.0277399999999943 90.4457400000000007 90.8060679999999962 90.4185329999999965 89.9439390000000003 89.779876999999999
+107.7477569999999929 107.6370620000000002 107.645820999999998 107.6401819999999958 107.5766600000000039 107.8367539999999991 108.4246440000000007 108.9072800000000001 109.2798389999999955 109.7330549999999931 110.2646560000000022 110.8440020000000032 111.4023439999999994 111.8431929999999994 112.3271330000000034 112.8943019999999962 113.4261549999999943 113.8977739999999983 114.2061389999999932 114.5957570000000061 115.035743999999994 115.3786999999999949 115.7359390000000019 116.0623700000000014 116.1951830000000001 116.3004459999999938 116.2892530000000022 116.0763630000000006 115.9302220000000005 115.852019999999996 115.6356739999999945 115.3374479999999949 114.9327770000000015 114.5036089999999973 114.2182999999999993 114.1296540000000022 114.1383210000000048 113.871696 113.3751979999999975 112.8848569999999967 113.432075999999995 114.8111569999999944 114.2477420000000023 112.611298000000005 112.6457209999999947 113.5098420000000061 114.1684269999999941 114.5974120000000
056 114.6762999999999977 114.4356379999999973 114.2729109999999935 114.1662900000000036 114.0219349999999991 113.9143300000000067 113.7413939999999997 113.5499039999999979 113.5796890000000019 113.590637000000001 113.4263080000000059 113.2010649999999998 112.9270250000000004 112.6162410000000023 112.3027189999999962 112.075774999999993 112.0202259999999939 112.0209049999999991 112.0365680000000026 112.0548100000000034 112.118622000000002 112.217369000000005 112.367401000000001 112.324309999999997 112.114570999999998 111.794524999999993 111.3884120000000024 110.8756790000000052 110.4182660000000027 109.8047789999999964 109.0336230000000057 108.210723999999999 107.4590989999999948 107.1149750000000012 106.934394999999995 106.7414320000000032 106.613585999999998 106.7765050000000002 107.2786329999999992 107.5148470000000032 107.4578400000000045 107.7616270000000043 108.0259630000000044 108.2709959999999967 108.6812589999999972 109.1376499999999936 109.742676000000003 110.283691
0000000046 110.3845670000000041 110.1950839999999943 109.9704279999999983 109.3775100000000009 107.9599460000000022 107.1589359999999971 107.683021999999994 108.025810000000007 107.721312999999995 107.7621919999999989 107.9174579999999963 107.8321689999999933 107.6803819999999945 107.662627999999998 107.7875520000000051 107.875511000000003 107.924987999999999 107.986542 107.9993900000000053 107.9510499999999951 107.8006670000000042 107.677070999999998 107.3595959999999963 106.7400590000000022 106.1692579999999992 105.6358180000000004 104.8590930000000014 104.0697629999999947 103.4905550000000005 103.1087339999999983 102.8034439999999989 102.4755169999999964 101.8864439999999973 100.2979579999999942 98.4482500000000016 97.3082200000000057 96.3516999999999939 94.4176790000000068 90.3772129999999976 86.2571949999999958 85.5370249999999999 85.8158339999999953 85.8022459999999967 85.8022459999999967 85.8023299999999978 85.8038640000000044 85.7934570000000036 85.773216000000005 85
.7716450000000066 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7716669999999937 85.7725829999999974 85.7725910000000056 85.750709999999998 85.7400590000000022 85.7410509999999988 85.7413099999999986 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7411649999999952 85.742217999999994 85.7365570000000048 85.7150500000000051 85.7102509999999995 85.7107539999999943 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7110140000000058 85.7106550000000027 85.6961359999999956 85.6812589999999972 85.6803210000000064 85.6803210000000064 85.6803210000000064
85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6808850000000035 85.6743089999999938 85.7511669999999953 86.5829319999999996 87.7072679999999991 88.8893429999999967 89.758728000000005 90.0015029999999996 90.0742950000000064 89.7545010000000048 89.3587880000000041 89.1930160000000001
+107.2847289999999987 107.1444469999999995 107.2704159999999973 107.2718729999999994 107.3176270000000017 107.7342220000000026 108.3199079999999981 108.7655259999999942 109.1230010000000021 109.5284960000000041 110.019408999999996 110.5868990000000025 111.1821819999999974 111.6592789999999979 112.1758269999999982 112.8081360000000046 113.429749000000001 113.8464199999999948 114.1304779999999965 114.5426709999999986 114.9639659999999992 115.3174130000000019 115.6388699999999972 115.8844150000000042 116.0497210000000052 116.1791309999999982 116.0955349999999981 115.8438639999999964 115.7343599999999952 115.7205579999999969 115.4957200000000057 115.1584930000000071 114.7059399999999982 114.3585970000000032 114.0860749999999939 113.8939440000000047 113.8596419999999938 113.5691599999999966 113.0890349999999955 112.7313230000000033 113.3714980000000025 114.444312999999994 113.1372829999999965 111.5515060000000034 112.1327969999999965 113.024353000000005 113.7719879999999932 114.60
43399999999934 114.9752809999999954 114.8316039999999987 114.7558290000000056 114.6157680000000028 114.3858409999999992 114.1252290000000045 113.8911970000000053 113.7091900000000066 113.555144999999996 113.4727019999999982 113.3132779999999968 113.1172940000000011 113.0250699999999995 112.9656520000000057 112.8724820000000051 112.9520109999999988 112.9378659999999996 112.6788939999999997 112.3979029999999995 112.6898730000000057 113.0624540000000025 113.0310360000000003 112.9368130000000008 112.816283999999996 112.4409330000000011 111.8451459999999997 111.3569640000000049 110.9020610000000033 110.3961869999999976 109.755898000000002 108.9829029999999932 108.2318190000000016 107.3846280000000064 106.743622000000002 106.4064479999999975 106.1551670000000058 106.1032560000000018 106.361969000000002 106.6844179999999938 106.7859270000000009 106.8729859999999974 107.2826919999999973 107.7519070000000028 108.1651690000000059 108.670921000000007 109.2261280000000028 109.6590499999
999935 110.1840669999999989 110.4271849999999944 110.365509000000003 109.9787749999999988 108.973479999999995 107.9313960000000066 107.8965610000000055 108.6495819999999952 108.9758070000000032 108.7532879999999977 108.6783520000000038 108.7096789999999942 108.6705929999999967 108.6070789999999988 108.4283140000000003 108.288094000000001 108.2968060000000037 108.3364409999999936 108.4294969999999978 108.6030499999999961 108.6138380000000012 108.4034269999999935 108.1888280000000009 107.8624729999999943 107.3886569999999949 106.9118349999999964 106.3412249999999943 105.6893230000000017 104.9676970000000011 104.4860919999999993 104.330284000000006 103.9509809999999987 103.2546389999999974 102.5988770000000017 101.203795999999997 99.452186999999995 98.1056820000000016 96.7673489999999958 94.3780289999999979 90.4402769999999947 86.3507390000000044 85.4897540000000049 85.8201830000000001 85.8022459999999967 85.8022459999999967 85.8022380000000027 85.8031849999999991 85.7998730000
000052 85.7777329999999978 85.770781999999997 85.7718509999999981 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717130000000054 85.7723540000000071 85.7740249999999946 85.7563860000000062 85.7411189999999976 85.7409519999999929 85.7413250000000033 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7418059999999969 85.7383190000000042 85.7182999999999993 85.7094799999999992 85.7105940000000004 85.7108230000000049 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7116240000000005 85.707618999999994 85.6864779999999939 85.6800690000000031 85.6803210000000064 85.680321
0000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6802600000000041 85.6786349999999999 85.7394259999999946 86.4746549999999985 87.575989000000007 88.6914979999999957 89.4139480000000049 89.445335 89.2267379999999974 88.9993900000000053 88.7606660000000005 88.630463000000006
+106.9311370000000068 106.8007810000000006 106.8954090000000008 106.8162159999999972 107.018897999999993 107.5686869999999971 108.1107410000000044 108.5080489999999998 108.8420720000000017 109.2578890000000058 109.8034289999999942 110.4098740000000021 111.0219120000000004 111.5252610000000004 112.0326689999999985 112.6493229999999954 113.2379379999999998 113.6783599999999979 114.1161799999999999 114.5559619999999938 114.913848999999999 115.2385790000000014 115.5801929999999942 115.8481450000000024 116.0169139999999999 116.1287920000000042 115.8912810000000064 115.5621260000000063 115.5280149999999963 115.5920100000000019 115.3591540000000037 115.0006640000000004 114.5516970000000043 114.1735529999999983 113.873076999999995 113.5621029999999934 113.3086239999999947 113.0646210000000025 112.800415000000001 112.5778269999999992 113.067497000000003 113.7729570000000052 112.3911590000000018 111.0838619999999963 111.7558439999999962 112.6762619999999941 113.4850689999999958 114.278
0000000000058 114.6143880000000053 114.748542999999998 115.0313029999999941 115.1736829999999969 115.1495510000000024 114.9122540000000043 114.6374210000000033 114.4722519999999975 114.3605419999999953 114.2763669999999934 113.991730000000004 113.7951889999999935 113.8297579999999982 113.8186800000000005 113.5909580000000005 113.4773480000000063 113.4740979999999979 113.1675950000000057 112.6626969999999943 113.075255999999996 113.4502939999999995 113.2679820000000035 113.017548000000005 112.8025209999999987 112.4129489999999976 111.8363800000000055 111.3313830000000024 110.8913500000000028 110.3510359999999935 109.688202000000004 108.9171599999999955 108.135627999999997 107.3744509999999934 106.4401629999999983 105.8041149999999959 105.5372310000000056 105.6370390000000015 106.0206450000000018 106.2027130000000028 106.188209999999998 106.4668810000000008 107.0185929999999956 107.561119000000005 108.0632169999999945 108.665924000000004 109.2274319999999932 109.47073399999999
31 109.8834760000000017 110.1597370000000069 110.1341089999999951 109.646049000000005 108.8804860000000048 108.7083439999999968 109.0535050000000012 109.3818279999999987 109.5094679999999983 109.426201000000006 109.3499450000000053 109.2656860000000023 109.1821209999999951 109.218757999999994 109.0945739999999944 108.9622800000000069 108.8830410000000057 108.7181240000000031 108.5945590000000038 108.6026150000000001 108.7318039999999968 108.6874770000000012 108.432982999999993 108.1461259999999953 107.7273560000000003 107.2609329999999943 106.817688000000004 106.473044999999999 106.1663060000000058 105.7105789999999956 105.3980640000000051 105.0735779999999977 104.2517550000000028 103.3486630000000019 101.7866970000000038 99.9235690000000005 98.2309570000000036 96.3343660000000028 93.7329710000000063 90.3840869999999938 86.6989590000000021 85.5241780000000063 85.8156589999999966 85.8017650000000032 85.8022459999999967 85.8022459999999967 85.8023680000000013 85.80287199999999
36 85.7946469999999977 85.7758709999999951 85.771491999999995 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717509999999947 85.7720790000000051 85.7739559999999983 85.7608180000000004 85.7430949999999967 85.7409059999999954 85.7413410000000056 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7411349999999999 85.7439349999999934 85.7307969999999955 85.7092360000000042 85.7105099999999993 85.7108379999999954 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108149999999966 85.7105940000000004 85.6996460000000013 85.6820139999999952 85.6800309999999996 85.6803210000000064 85.68032100
00000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6728439999999978 85.8068540000000013 86.6684190000000001 87.8318479999999937 88.6788099999999986 88.9925839999999937 88.8363719999999972 88.502167 88.2667390000000012 88.1816639999999978 88.2233659999999986
+106.4880909999999972 106.4816820000000064 106.5235440000000011 106.3785100000000057 106.6287609999999972 107.1978450000000009 107.7078249999999997 108.0579299999999989 108.3879239999999982 108.8563690000000008 109.5302580000000034 110.2372210000000052 110.8558500000000038 111.3746950000000027 111.8697590000000019 112.4577479999999952 113.0231399999999979 113.4983979999999946 113.9399259999999998 114.4219889999999964 114.7485499999999945 115.0195080000000019 115.420653999999999 115.7176359999999988 115.8332139999999981 115.9063419999999951 115.6142040000000009 115.2804260000000056 115.2988129999999956 115.3205640000000045 115.1165079999999961 114.7651599999999945 114.3346710000000002 113.9104770000000002 113.6251749999999987 113.3303149999999988 113.0133819999999929 112.7273100000000028 112.5147780000000068 112.2789989999999989 112.4591669999999937 112.9264830000000046 111.8184969999999936 110.6681439999999981 111.2060550000000063 112.2256320000000045 113.1264270000000067 113
.8399809999999945 114.1045909999999992 114.2771000000000043 114.5668720000000036 114.8453750000000042 115.0660170000000022 115.0528560000000056 115.0017169999999993 114.9440610000000049 114.9258039999999994 114.8864750000000043 114.4618380000000002 114.2514270000000067 114.2972110000000043 114.2028660000000002 113.8955080000000066 113.6323780000000028 113.5293960000000055 113.2389450000000011 112.6828840000000014 112.910743999999994 113.2784580000000005 113.132866000000007 112.9642410000000012 112.7530519999999967 112.3051219999999972 111.8023450000000025 111.2896350000000041 110.8079989999999952 110.2559130000000067 109.5686720000000065 108.698395000000005 107.9393539999999945 107.4493709999999993 106.4506229999999931 105.4465480000000071 105.0151209999999935 105.1382059999999967 105.412895000000006 105.6279449999999969 105.745002999999997 106.1218340000000069 106.9036329999999992 107.5021210000000025 107.9950939999999946 108.5206830000000053 109.0292660000000069 109.333420
0000000038 109.6290819999999968 109.7617419999999981 109.641136000000003 109.4595259999999968 109.4122919999999937 109.705687999999995 110.0057529999999986 109.9057920000000053 109.7454450000000037 109.812927000000002 109.8328319999999962 109.652434999999997 109.444312999999994 109.3653110000000055 109.2845379999999977 109.2335659999999962 109.1464459999999974 108.9999619999999965 108.8354719999999958 108.5512849999999929 108.4754559999999941 108.548248000000001 108.4550250000000062 108.2189330000000069 107.7382130000000018 107.3452450000000056 107.1478270000000066 106.926872000000003 106.6831669999999974 106.2428440000000052 105.7311329999999998 105.3867259999999959 104.9197769999999963 103.8066560000000038 101.8184969999999936 99.8974299999999999 97.9173129999999929 95.6006699999999938 93.1016769999999951 90.5365520000000004 87.7019729999999953 85.7745209999999929 85.7084270000000004 85.8056260000000037 85.8022459999999967 85.8022459999999967 85.8021999999999991 85.8026810
000000069 85.8045350000000013 85.7873759999999947 85.770545999999996 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7718349999999958 85.773223999999999 85.7642290000000003 85.7445830000000058 85.7407230000000027 85.7413020000000046 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7420429999999953 85.7395250000000004 85.7200619999999986 85.7096410000000049 85.7108539999999977 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108690000000024 85.7093509999999981 85.6895520000000062 85.6792829999999981 85.6802899999999994 85.6803210000000064 85.68
03210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6752010000000013 85.7730789999999956 86.5857539999999943 87.6679759999999959 88.2784189999999995 88.3252789999999948 88.0714870000000047 87.8393860000000046 87.630004999999997 87.6445920000000029 87.8011549999999943
+106.0694270000000046 106.1034389999999945 106.158385999999993 106.0464939999999956 106.193641999999997 106.6619110000000035 107.116187999999994 107.4819260000000014 107.890900000000002 108.4202420000000018 109.2198719999999952 110.0456240000000037 110.656952000000004 111.1863859999999988 111.7341080000000062 112.3663860000000057 113.0257490000000047 113.4799119999999988 113.7584920000000039 114.182068000000001 114.5154799999999966 114.7959519999999998 115.1887820000000033 115.4254909999999938 115.528923000000006 115.5500179999999943 115.2131499999999988 114.9825819999999936 115.0299380000000014 114.9158400000000029 114.7188720000000046 114.4130250000000046 113.9937359999999984 113.6217960000000033 113.4080349999999981 113.1253279999999961 112.7225569999999948 112.4800189999999986 112.2550430000000006 111.9490509999999972 111.9327550000000002 112.1258930000000049 111.2516099999999994 110.3041690000000017 110.7150730000000038 111.7491610000000009 112.7309269999999941 113.50206
00000000002 113.8436200000000014 113.9112319999999983 114.0158770000000032 114.2013929999999959 114.4143370000000033 114.5467299999999966 114.7793350000000032 114.8405460000000033 114.8444750000000028 114.8509059999999948 114.5296249999999958 114.2995990000000006 114.1892090000000053 113.9944229999999976 113.6766889999999961 113.3434599999999932 113.1298900000000032 112.950019999999995 112.5162279999999981 112.5610279999999932 112.9491119999999995 112.8786769999999962 112.7326050000000066 112.5817949999999996 112.2262340000000052 111.7985000000000042 111.2240910000000014 110.6834560000000067 110.1479190000000017 109.2843699999999956 108.2484280000000041 107.7937469999999962 107.5440669999999983 106.6596530000000058 105.3842700000000008 104.6200489999999945 104.5642320000000041 104.7335280000000068 105.0531160000000028 105.4419630000000012 105.9875409999999931 106.8170850000000058 107.4769129999999961 107.8975300000000033 108.3210909999999956 108.7415009999999995 109.09411599
99999996 109.359886000000003 109.4312740000000019 109.4117049999999978 109.5717089999999985 109.8089980000000025 110.0433730000000025 110.1918950000000024 110.090209999999999 109.8633959999999945 109.8916090000000025 109.9134140000000031 109.7280499999999961 109.5481950000000069 109.3348309999999941 109.199584999999999 109.1037369999999953 109.0058290000000056 108.923096000000001 108.8417510000000021 108.5883409999999998 108.2993390000000034 108.1504589999999979 108.1911850000000044 108.0716170000000034 107.6261520000000047 107.3813399999999945 107.2503200000000021 106.976508999999993 106.6639179999999953 106.2131810000000058 105.7030259999999942 105.2363890000000026 104.9225919999999945 103.9198460000000068 101.4745860000000022 99.0261760000000066 96.9259639999999933 94.8529740000000032 92.9078520000000054 90.852294999999998 88.4985810000000015 86.2209239999999966 85.6787259999999975 85.8022079999999931 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.80217700
00000004 85.804717999999994 85.7906569999999959 85.7702940000000069 85.771759000000003 85.771759000000003 85.771759000000003 85.7716900000000066 85.7726059999999961 85.7671050000000008 85.7462689999999981 85.740050999999994 85.7412029999999987 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7425769999999972 85.7370070000000055 85.7134170000000069 85.7083279999999945 85.7102200000000067 85.7109379999999987 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7107010000000002 85.7117310000000003 85.7049939999999992 85.6827239999999932 85.6793140000000051 85.6803280000000029 85.6803210000000064 85.68
03210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6811749999999961 85.6824110000000019 86.0075379999999967 86.5823589999999967 87.0216750000000019 87.1423340000000053 87.0596919999999983 87.1347200000000015 87.1041409999999985 87.1514209999999991 87.410033999999996
+105.6758959999999945 105.7372670000000028 105.7965319999999991 105.7046050000000008 105.7608720000000062 106.0758289999999988 106.4788970000000035 106.924980000000005 107.4451899999999966 108.0518650000000065 108.9224240000000066 109.7726750000000067 110.3719480000000033 110.9852139999999991 111.6119999999999948 112.2439799999999934 112.8959810000000061 113.3348390000000023 113.6363680000000045 114.0057529999999986 114.3144910000000039 114.5876920000000041 114.9672850000000039 115.2148969999999935 115.3354949999999945 115.2811970000000059 114.8868939999999981 114.6707459999999941 114.6882319999999993 114.5432279999999992 114.3375699999999995 114.0183490000000006 113.6248630000000048 113.3551709999999986 113.2146220000000056 112.9358220000000017 112.5066989999999976 112.3653489999999948 112.0483470000000068 111.7322309999999987 111.544524999999993 111.3975369999999998 110.769867000000005 110.0000529999999941 110.2846760000000046 111.1850129999999979 112.1729050000000001 113.0
220180000000028 113.414787000000004 113.4690480000000008 113.5227280000000007 113.679665 113.8617480000000057 114.0230179999999933 114.3365330000000029 114.496216000000004 114.5352100000000064 114.565772999999993 114.4397809999999964 114.2454299999999989 113.9297559999999976 113.6653519999999986 113.3487089999999995 112.930603000000005 112.5989229999999992 112.3791279999999944 112.0530399999999958 112.0964429999999936 112.4344250000000045 112.4953610000000026 112.4123380000000054 112.2817079999999947 112.070282000000006 111.6717220000000026 111.0961460000000045 110.602485999999999 110.1054529999999971 108.999290000000002 107.8239750000000043 107.6036220000000014 107.4682920000000053 106.6685559999999953 105.3215100000000035 104.3554840000000041 104.0450739999999996 104.2018740000000037 104.6151349999999951 105.1541059999999987 105.8098750000000052 106.6033860000000004 107.2668529999999976 107.6272280000000023 107.9765550000000047 108.3086009999999959 108.6511990000000054 109
.0406270000000006 109.1791529999999995 109.3061900000000009 109.4872969999999981 109.5915990000000022 109.7070310000000006 109.8379520000000014 109.8877410000000054 109.8306270000000069 109.7844769999999954 109.7131650000000036 109.5717389999999938 109.4006959999999964 109.1332170000000019 108.9814070000000044 108.8690030000000064 108.7330249999999978 108.6514130000000051 108.5739899999999949 108.4371569999999991 108.3146059999999977 107.9467539999999985 107.7119600000000048 107.6800379999999961 107.5004729999999995 107.3218990000000019 107.1022260000000017 106.8068999999999988 106.4787520000000001 106.005004999999997 105.6245880000000028 105.2224960000000067 104.9268880000000053 104.1150130000000047 101.6306840000000022 98.8754729999999995 97.0038380000000018 95.2434230000000071 93.3586430000000007 91.1480260000000015 88.6805039999999991 86.5762100000000032 85.7716060000000056 85.7988969999999966 85.8021930000000026 85.8022459999999967 85.8022459999999967 85.802245999999996
7 85.804473999999999 85.789268000000007 85.7704540000000009 85.771759000000003 85.771759000000003 85.7716450000000066 85.7725680000000068 85.7700420000000037 85.7489620000000059 85.7393880000000053 85.7410430000000048 85.7412949999999938 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7416529999999995 85.7409360000000049 85.7280650000000009 85.7170720000000017 85.7127299999999934 85.7103579999999994 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7111739999999998 85.7068560000000019 85.6877369999999985 85.679665 85.6801909999999936 85.6803210000000064 85.6803210000000064 85.6803210000000064 8
5.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6809159999999963 85.6747060000000005 85.6860279999999932 85.7140050000000002 85.8749540000000025 86.0233149999999966 86.088561999999996 86.2432330000000036 86.4531860000000023 86.7375640000000061 87.1391979999999933
+105.259917999999999 105.3779069999999933 105.4801790000000068 105.3158109999999965 105.2380679999999984 105.5480270000000047 105.907898000000003 106.3957900000000052 106.9954149999999942 107.7069019999999995 108.6243130000000008 109.4210280000000068 110.031281000000007 110.7226490000000041 111.3732219999999984 111.9421770000000009 112.5224149999999952 112.9193499999999943 113.3469699999999989 113.8076709999999991 114.1041029999999949 114.3423839999999956 114.6660689999999931 114.9483029999999957 115.0637509999999963 114.9650800000000004 114.6156160000000028 114.3068310000000025 114.2917790000000053 114.2211460000000045 113.9922870000000046 113.6341709999999949 113.3395919999999961 113.1944660000000056 113.0541609999999935 112.7624129999999951 112.4750520000000051 112.2716900000000066 111.8190919999999977 111.4796829999999943 111.1058960000000013 110.741698999999997 110.3021009999999933 109.698798999999994 109.8532029999999935 110.6708370000000059 111.579338000000007 112.2979
579999999942 112.6690439999999995 112.8439029999999974 112.9502180000000067 113.1432499999999948 113.3265150000000006 113.5208509999999933 113.9115680000000026 114.2047960000000018 114.2846069999999941 114.2737120000000033 114.2359469999999959 114.0723720000000014 113.6319430000000068 113.3245540000000062 112.936829000000003 112.4822460000000035 112.1063690000000008 111.7279819999999972 111.5004200000000054 111.5393519999999938 111.7614590000000021 111.935851999999997 112.0334469999999953 111.9880979999999937 111.8292079999999942 111.4792249999999996 111.0259400000000056 110.5471799999999973 109.9743270000000024 109.0015180000000043 107.8854829999999936 107.4274139999999989 107.1090240000000051 106.2684480000000065 105.1275480000000044 104.2353439999999978 103.7246779999999973 103.7906650000000042 104.2419890000000038 104.8604200000000048 105.5155110000000036 106.1904219999999981 106.7458879999999937 107.085014000000001 107.4444579999999974 107.9290699999999958 108.329520999
9999997 108.6897579999999977 108.8392259999999965 108.978699000000006 109.040976999999998 109.0717539999999985 109.1849440000000016 109.3876949999999937 109.5160979999999995 109.5635989999999964 109.5709920000000039 109.479881000000006 109.314155999999997 109.0059969999999936 108.7854540000000014 108.6960299999999933 108.6004709999999989 108.4532319999999999 108.3690030000000064 108.318909000000005 108.190804 108.1419680000000056 107.900299000000004 107.3921509999999984 107.1437990000000013 107.1645129999999995 106.9804380000000066 106.6943360000000069 106.4701689999999985 106.112480000000005 105.7435380000000009 105.5119779999999992 105.3573070000000058 105.2286830000000037 104.5820619999999934 102.7858049999999963 100.666443000000001 98.9725269999999995 96.8701480000000004 94.2853240000000028 91.6660920000000061 89.665733000000003 87.3123700000000014 85.6215969999999942 85.7698520000000002 85.8053129999999982 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8
044430000000062 85.7896039999999971 85.7704619999999949 85.771759000000003 85.7716669999999937 85.7724460000000022 85.7730099999999993 85.7533569999999941 85.7393569999999983 85.7408680000000061 85.7413329999999974 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7411960000000022 85.7419969999999978 85.7408070000000038 85.735077000000004 85.7181779999999947 85.7091599999999971 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7106629999999967 85.7130580000000037 85.698204000000004 85.6780320000000017 85.6799239999999998 85.6803670000000039 85.6803210000000064 85.6803210000000064 85.6803210000000
064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6801829999999995 85.6809230000000071 85.683014 85.6608049999999963 85.6104430000000036 85.6243819999999971 85.6307979999999986 85.6537479999999931 85.667145000000005 85.8655849999999958 86.4424740000000043 86.9104690000000062
+104.8142169999999993 105.090912000000003 105.2061609999999945 104.9215090000000004 104.745941000000002 105.1140369999999962 105.3734050000000053 105.8134160000000037 106.5213779999999986 107.347130000000007 108.308959999999999 109.0629200000000054 109.6754609999999985 110.3458789999999965 111.0046310000000034 111.6021580000000029 112.1457369999999969 112.5373539999999934 112.9648210000000006 113.4183960000000013 113.7649609999999996 114.0405350000000055 114.2314070000000044 114.4169389999999993 114.4995880000000028 114.3974529999999987 114.122437000000005 113.9262389999999954 113.9461139999999943 113.8360289999999964 113.6000750000000039 113.3127980000000008 113.1113890000000026 112.9986799999999931 112.8080980000000011 112.5183789999999959 112.3190380000000062 111.993103000000005 111.5354080000000039 111.1974029999999942 110.8135300000000001 110.2950589999999949 109.8680269999999979 109.4116060000000061 109.3949429999999978 110.1418989999999951 111.011107999999993 111.59568
79999999956 111.9136349999999993 112.1264110000000045 112.252326999999994 112.4590380000000067 112.7052460000000025 112.9443279999999987 113.4500890000000055 113.8920669999999973 113.9821780000000047 114.0002819999999986 114.0307690000000065 113.8786089999999973 113.4314729999999969 112.9094539999999967 112.1437530000000038 111.7186279999999954 111.3934330000000017 111.1433640000000054 111.2472230000000053 111.1046829999999943 111.0804289999999952 111.3596799999999973 111.6237260000000049 111.7194369999999992 111.5771029999999939 111.3030470000000065 110.9535680000000042 110.420219000000003 109.7572940000000017 109.1402740000000051 108.2807920000000053 107.4835589999999996 106.8065030000000064 105.9463269999999966 105.0091400000000021 104.1600109999999972 103.5970920000000035 103.5342179999999956 103.8755869999999959 104.4945220000000035 105.1402510000000063 105.6442949999999996 106.127326999999994 106.5839689999999962 107.0696870000000018 107.6487580000000008 108.0600809999
999967 108.301879999999997 108.4069669999999945 108.5079730000000069 108.619843000000003 108.660576000000006 108.7551119999999969 108.8936389999999932 109.0492100000000022 109.1577989999999971 109.205009000000004 109.1393280000000061 108.9427409999999981 108.5793230000000023 108.3646999999999991 108.2804339999999996 108.2299799999999976 108.1444780000000065 108.0405200000000008 108.017280999999997 107.8739779999999939 107.661438000000004 107.553687999999994 107.2065730000000059 106.694823999999997 106.5939639999999997 106.540465999999995 106.2019269999999977 105.972808999999998 105.7351759999999956 105.5836639999999989 105.4800029999999964 105.4560010000000005 105.424225000000007 105.0097499999999968 103.998076999999995 102.5138170000000031 100.7770459999999986 98.4724499999999949 95.4542309999999929 93.0569839999999999 92.3234559999999931 89.8482889999999941 86.1192089999999979 85.2243349999999964 85.7474820000000051 85.8305129999999963 85.7983250000000055 85.80224599999999
67 85.8047329999999988 85.7878110000000049 85.7697979999999944 85.7718430000000041 85.772246999999993 85.7741089999999957 85.7591249999999974 85.7406620000000004 85.7407070000000004 85.7413710000000009 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7411960000000022 85.7417760000000015 85.7423019999999951 85.7211839999999938 85.7085720000000038 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7112269999999938 85.7104340000000064 85.6894989999999979 85.6785660000000036 85.6803819999999945 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803
210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6802220000000005 85.6812819999999959 85.6793820000000039 85.6707530000000048 85.6586609999999951 85.6507490000000047 85.6476590000000044 85.6331559999999996 85.6301729999999992 85.6161120000000011 85.672584999999998 86.170921000000007 86.7028660000000002
+104.472022999999993 104.7557139999999976 104.8604430000000036 104.7639620000000065 104.6567459999999983 104.8066100000000063 104.936286999999993 105.2771450000000044 106.008544999999998 106.9043879999999973 107.8900150000000053 108.6827470000000062 109.287659000000005 109.9390489999999971 110.6072850000000045 111.266838000000007 111.8231119999999947 112.2632449999999977 112.6214899999999943 112.9687880000000035 113.3313749999999942 113.6584399999999988 113.8450700000000069 113.9341280000000012 113.9551160000000039 113.7874149999999958 113.5521009999999933 113.5833889999999968 113.6574099999999987 113.4930109999999956 113.2454759999999965 113.0312729999999988 112.8433689999999956 112.6027150000000034 112.3999249999999961 112.1984329999999943 111.9116439999999955 111.5545120000000026 111.2313079999999985 110.9390949999999947 110.6217579999999998 110.0917890000000057 109.6051410000000033 109.1792370000000005 108.9692309999999935 109.4396059999999977 110.282623000000001 110.8607
709999999997 111.0823139999999967 111.2641830000000027 111.4570690000000042 111.7141419999999954 112.1451720000000023 112.5220949999999931 113.0170439999999985 113.515656000000007 113.6179429999999968 113.6521840000000054 113.6866530000000068 113.5314410000000009 113.1749570000000062 112.1508330000000058 110.9195019999999943 110.6896129999999943 110.4907070000000004 110.563202000000004 111.0737919999999974 110.8105089999999961 110.4811940000000021 110.929473999999999 111.2780000000000058 111.4118419999999929 111.373383000000004 111.1425250000000062 110.6685099999999977 110.1213529999999992 109.7544630000000012 109.3836589999999944 108.6489409999999936 107.6636890000000051 106.8218150000000009 105.9951779999999957 104.9715960000000052 103.9104540000000014 103.2241360000000014 103.1570660000000004 103.492125999999999 104.0399929999999955 104.6380000000000052 105.1681059999999945 105.7005920000000003 106.2478490000000022 106.8153530000000018 107.2206500000000062 107.52605400000
0002 107.7915569999999974 107.8887859999999961 107.957854999999995 108.2581100000000021 108.3709340000000054 108.4363479999999953 108.4630279999999942 108.551636000000002 108.6650389999999931 108.6566930000000042 108.6041029999999949 108.4466089999999951 108.1491850000000028 107.9395829999999989 107.7615509999999972 107.7094879999999932 107.665976999999998 107.6071929999999952 107.5525279999999952 107.3632970000000029 107.0984569999999962 106.9754939999999976 106.8674850000000021 106.4093400000000003 106.0029750000000064 106.1111680000000064 105.778899999999993 105.4572529999999944 105.3594439999999963 105.3267359999999968 105.3203579999999988 105.3049239999999998 105.2529069999999933 105.041679000000002 104.5183940000000007 103.3564379999999971 101.760704000000004 99.7507630000000063 97.1180420000000026 95.7173229999999933 95.8658140000000003 94.0595019999999948 89.5149920000000066 86.1893160000000051 85.504326000000006 85.5899430000000052 85.8518370000000033 85.80738800000
00031 85.8034519999999929 85.7922059999999931 85.7722930000000048 85.7717289999999934 85.7738800000000055 85.763298000000006 85.7433319999999952 85.7406160000000028 85.7413789999999949 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7414320000000032 85.7366710000000012 85.7163390000000049 85.7093890000000016 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7127530000000064 85.7015909999999934 85.6816639999999978 85.6800839999999937 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6
803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803129999999982 85.6805190000000039 85.6824260000000066 85.683021999999994 85.6647640000000052 85.6530079999999998 85.6499560000000031 85.6495359999999977 85.649628000000007 85.6511760000000066 85.6511380000000031 85.6514820000000014 85.6327289999999977 85.860352000000006 86.4657669999999996
+104.2661970000000053 104.2970430000000022 104.3733139999999935 104.5344010000000026 104.552314999999993 104.5868909999999943 104.6735690000000005 104.9242940000000033 105.5672529999999938 106.4994279999999947 107.4759520000000066 108.3042530000000028 108.9120640000000009 109.5807340000000067 110.2506410000000017 110.9113239999999934 111.5067439999999976 111.8983230000000049 112.2467800000000011 112.6201400000000064 112.9680019999999985 113.3382490000000047 113.6000669999999957 113.6511990000000054 113.5971370000000036 113.3687589999999972 113.1299360000000007 113.1944119999999998 113.3057019999999966 113.2592010000000045 113.0263439999999946 112.7598650000000049 112.4627839999999992 112.1487350000000021 112.0242920000000026 111.8583830000000034 111.4793399999999934 111.1689379999999971 110.9992139999999949 110.8380580000000037 110.5983429999999998 109.9791409999999985 109.3734970000000004 108.9813539999999961 108.6773910000000001 108.7272030000000029 109.2959900000000033 109
.8703000000000003 110.0722889999999978 110.3150559999999984 110.6587070000000068 111.0965960000000052 111.7644959999999941 112.2568660000000023 112.6711200000000019 113.1024170000000026 113.3276819999999958 113.3204570000000047 113.2668989999999951 113.1277850000000029 112.8046489999999977 111.4219279999999941 110.1239240000000024 110.0765690000000063 109.9885940000000062 110.1481169999999992 110.8498689999999982 110.6023480000000063 109.9738540000000029 110.5216829999999959 110.9686200000000014 111.1104349999999954 111.2097629999999953 111.0687640000000016 110.4698029999999989 109.8670429999999953 109.8846280000000064 109.7663119999999992 109.0780259999999942 107.8060609999999997 106.8379139999999978 106.0350190000000055 104.9061279999999954 103.6531750000000045 102.6805729999999954 102.4220580000000069 103.0567630000000037 103.6635820000000052 104.1567079999999947 104.8459550000000036 105.3869930000000039 105.7569890000000044 106.266136000000003 106.6118699999999961 106.83
29010000000068 107.0538789999999949 107.1534580000000005 107.320533999999995 107.6887049999999988 107.9042510000000021 108.0452650000000006 108.1089630000000028 108.1110149999999948 108.1255490000000066 108.1137619999999941 108.0799870000000027 107.9176029999999997 107.6557159999999982 107.5203020000000009 107.3148649999999975 107.2258609999999948 107.1737519999999932 107.0948259999999976 106.9985049999999944 106.845917 106.6337199999999967 106.4701459999999997 106.381844000000001 106.1393130000000014 105.5363459999999947 105.4506530000000026 105.3027500000000032 105.0439449999999937 104.8985210000000023 104.8289410000000004 104.8626019999999954 104.8959499999999991 104.846153000000001 104.703400000000002 104.4029620000000023 103.6378940000000028 102.5613170000000025 101.0876999999999981 99.3477479999999957 98.8145899999999955 98.9255830000000032 97.6856230000000068 94.7593990000000019 90.8671489999999977 87.3290559999999942 85.5879139999999978 85.5792919999999953 85.7929079
999999971 85.8159639999999939 85.8015670000000057 85.7829739999999958 85.7712099999999964 85.7660979999999995 85.7456209999999999 85.7404250000000019 85.7413250000000033 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7420730000000049 85.7253189999999989 85.7098009999999988 85.7105710000000016 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.713554000000002 85.6969069999999959 85.6784590000000037 85.6805339999999944 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064
85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6804049999999933 85.6809460000000058 85.6766130000000032 85.6677700000000044 85.6521840000000054 85.648658999999995 85.6495670000000047 85.6499100000000055 85.649840999999995 85.649840999999995 85.6498339999999985 85.650825999999995 85.6123350000000016 85.6940000000000026 86.2777329999999978
+104.0305249999999972 103.873619000000005 103.9201659999999947 104.0536579999999987 104.1280359999999945 104.2202759999999984 104.4113540000000029 104.7066120000000069 105.2709810000000061 106.1840519999999941 107.112724 107.9300080000000008 108.5750500000000045 109.2426150000000007 109.933289000000002 110.5942309999999935 111.1688999999999936 111.5379410000000036 111.9539790000000039 112.3568420000000003 112.682036999999994 113.0137179999999972 113.2574460000000016 113.277434999999997 113.1690600000000018 113.0450210000000055 112.8078770000000048 112.7802350000000047 112.9442290000000071 112.9465480000000071 112.7765270000000015 112.4507449999999977 112.0044170000000037 111.7735370000000046 111.6709979999999973 111.4613879999999995 111.1428530000000023 110.932304000000002 110.8931350000000009 110.9057690000000065 110.7275389999999931 109.9363330000000047 109.1914060000000006 108.8553540000000055 108.4256060000000019 108.0610279999999932 108.2683179999999936 108.8375240000000
019 109.1820299999999975 109.6591719999999981 110.2195590000000038 110.8306050000000056 111.5362700000000018 111.989136000000002 112.4033579999999972 112.7448499999999996 113.0649410000000046 113.1260680000000036 113.0265050000000002 112.9298550000000034 112.5001299999999986 111.0688099999999991 109.9746250000000032 109.9240949999999941 109.8171459999999939 109.8217620000000068 110.5814510000000013 110.4516529999999932 109.5108259999999945 109.9771960000000064 110.588745000000003 110.8409809999999993 111.0110779999999977 110.9545750000000055 110.447929000000002 109.8596950000000021 109.9166259999999937 109.9320139999999952 109.1847690000000028 107.8227229999999963 106.8907779999999974 106.0600589999999954 104.8579330000000027 103.5047150000000045 102.4021379999999937 102.0060959999999994 102.767280999999997 103.1595760000000013 103.693634000000003 104.486778000000001 104.9541169999999966 105.2093660000000028 105.5123980000000046 105.879051000000004 106.1370469999999955 106.2
395860000000027 106.339020000000005 106.6288830000000019 107.008018000000007 107.314667 107.5429989999999947 107.684630999999996 107.7006530000000026 107.6523279999999971 107.6589359999999971 107.5799410000000051 107.3489150000000052 107.1717150000000061 107.0558699999999988 106.9085390000000046 106.8542249999999996 106.7820210000000003 106.6476899999999972 106.5526119999999963 106.4630810000000025 106.2853999999999957 105.9982830000000007 105.845917 105.7203219999999959 105.2668689999999998 104.7891309999999976 104.7293169999999947 104.6904530000000051 104.4707640000000026 104.3105620000000044 104.3394389999999987 104.4118500000000012 104.395820999999998 104.2024689999999936 103.8834690000000052 103.5301280000000048 103.0391390000000058 102.1346589999999992 101.1839449999999943 100.822174000000004 100.5232390000000038 99.3798749999999984 97.8620829999999984 95.7650600000000054 92.1043319999999994 87.596153000000001 85.6031190000000066 85.5085909999999956 85.7334979999999973
85.8172150000000045 85.7854839999999967 85.7651819999999958 85.7481539999999995 85.7396619999999956 85.7411730000000034 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7423629999999974 85.721100000000007 85.7081450000000018 85.710907000000006 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7125549999999947 85.7029569999999978 85.6823810000000066 85.6800000000000068 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210
000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.680176000000003 85.6810530000000057 85.682495000000003 85.6748730000000052 85.6567540000000065 85.6514209999999991 85.6494450000000001 85.6498639999999938 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6500240000000019 85.6312640000000016 85.6648560000000003 86.151955000000001
+103.8694459999999964 103.7093579999999946 103.6431050000000056 103.5794070000000033 103.5870510000000024 103.7525559999999984 104.0825650000000024 104.4868550000000056 105.0203400000000045 105.8397829999999971 106.7360989999999958 107.5491410000000059 108.2270970000000005 108.8558579999999978 109.5583419999999961 110.2742460000000051 110.7713090000000022 111.170929000000001 111.6417009999999976 112.0282140000000055 112.379294999999999 112.5767060000000015 112.6775590000000022 112.6069490000000002 112.5034789999999987 112.4915309999999948 112.3317720000000008 112.2915119999999973 112.4838100000000054 112.3975910000000056 112.2253189999999989 111.9944760000000059 111.6025539999999978 111.4002689999999944 111.2497180000000014 111.0470729999999975 110.8762739999999951 110.8229749999999996 110.8352359999999948 110.8548509999999965 110.7548599999999936 109.9568409999999972 109.1431500000000057 108.8067470000000014 108.0853419999999971 107.4178770000000043 107.4301379999999995 108.
033385999999993 108.7281799999999947 109.4537349999999947 110.1748050000000063 110.7608720000000062 111.2313999999999936 111.6438059999999979 112.089020000000005 112.4054110000000009 112.6895899999999955 112.8459849999999989 112.825523000000004 112.7382970000000029 112.2151790000000062 110.8066409999999991 109.8854220000000055 109.8172150000000045 109.6215669999999989 109.4433439999999962 110.270386000000002 110.3797909999999973 109.1284639999999939 109.3816070000000025 110.1882480000000015 110.5725249999999988 110.7710270000000037 110.7690960000000047 110.4568859999999972 109.9954910000000012 109.8346630000000062 109.6124039999999979 108.7450709999999958 107.7645949999999999 107.038330000000002 106.1042790000000053 104.8546829999999943 103.444145000000006 102.3342820000000017 102.1382519999999943 102.5662080000000032 102.4315110000000004 103.1724399999999946 103.9916690000000017 104.436561999999995 104.8001249999999942 104.9637680000000017 105.1734699999999947 105.392989999
9999975 105.4738009999999946 105.6282420000000002 105.9398960000000045 106.3677140000000065 106.7781750000000045 107.054741000000007 107.2196579999999955 107.2245249999999999 107.2078929999999986 107.1562880000000035 106.9820399999999978 106.7634280000000047 106.6711269999999985 106.573646999999994 106.4699099999999987 106.4397960000000012 106.3696819999999974 106.2884899999999959 106.2022400000000033 106.0741270000000043 105.8091890000000035 105.4223479999999995 105.3151629999999983 105.2356800000000021 104.9959869999999995 104.3475190000000055 104.1977689999999939 104.3123319999999978 104.1271969999999953 103.8947069999999968 103.8854060000000032 103.9214709999999968 103.8378680000000003 103.6472090000000037 103.4543529999999976 103.4196550000000059 103.1282039999999967 102.4299850000000021 101.8829649999999987 101.4262619999999941 100.7724910000000023 99.6984099999999955 98.4180530000000005 97.4895099999999957 95.7460099999999983 91.4122310000000056 88.010185000000007 86.
131141999999997 85.5780869999999965 85.6753690000000034 85.7815779999999961 85.7506029999999981 85.7389299999999963 85.7409519999999929 85.7413020000000046 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7422789999999964 85.7231599999999929 85.7085270000000037 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7111050000000034 85.7110519999999951 85.6926270000000017 85.6786500000000046 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000
000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6802220000000005 85.6811749999999961 85.6798169999999999 85.6724009999999936 85.6591719999999981 85.6474910000000023 85.6487050000000067 85.6497650000000021 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6505810000000025 85.6199040000000053 85.6755679999999984 86.2264629999999954
+103.5901180000000039 103.4877699999999976 103.2787090000000063 103.0788189999999958 103.1158140000000003 103.3203510000000023 103.6002040000000051 104.0488509999999991 104.6831509999999952 105.4559169999999995 106.3253169999999983 107.1252209999999963 107.8033680000000061 108.447181999999998 109.1862639999999942 109.9162520000000001 110.3232419999999934 110.691978000000006 111.1369250000000051 111.507782000000006 111.8295750000000055 111.9921719999999965 111.9846799999999973 111.8618160000000046 111.6993559999999945 111.668342999999993 111.5741960000000006 111.5445859999999954 111.6698990000000009 111.6131210000000067 111.4858779999999996 111.4019169999999974 111.1953280000000035 110.9868770000000069 110.8445739999999944 110.6868819999999971 110.6282199999999989 110.6680369999999982 110.6394200000000012 110.5381239999999963 110.5344850000000037 109.9445649999999972 109.1753309999999999 108.744811999999996 107.8545909999999992 107.0719150000000042 106.9061970000000059 107.416
6720000000055 108.5095979999999969 109.4580150000000032 110.1262660000000011 110.5427470000000056 110.787193000000002 111.2118300000000062 111.6654589999999985 111.9698939999999965 112.275383000000005 112.4226759999999956 112.4010849999999948 112.325012000000001 111.847099 110.5636750000000035 109.7288360000000011 109.6026540000000011 109.4090120000000042 109.1316989999999976 110.018028000000001 110.4199679999999972 108.9120180000000033 108.8329769999999996 109.7630079999999992 110.2654339999999991 110.542145000000005 110.6419070000000033 110.5021289999999965 110.130675999999994 109.7339099999999945 109.2068629999999985 108.4428099999999944 107.7996440000000007 107.0801320000000061 106.0854420000000005 104.9055709999999948 103.5668409999999966 102.4707109999999943 102.2494959999999935 102.1316680000000048 101.7276080000000036 102.5668330000000026 103.4108580000000046 103.8324279999999931 104.2239990000000063 104.4955599999999976 104.5793989999999951 104.638465999999994 104.7
673340000000053 104.9429549999999978 105.2571789999999936 105.7071689999999933 106.1566540000000032 106.5023120000000034 106.6954649999999987 106.6703949999999992 106.6545409999999947 106.5633700000000061 106.3612899999999968 106.2365489999999966 106.1277850000000029 106.0775679999999994 105.9946369999999973 105.9168169999999947 105.853699000000006 105.8073729999999983 105.7370149999999995 105.5776670000000053 105.198639 104.8516460000000023 104.8324130000000025 104.8445279999999968 104.5040819999999968 103.8464199999999948 103.6786419999999964 103.8256910000000062 103.7126240000000053 103.4722600000000057 103.4454120000000046 103.4084550000000036 103.2356639999999999 103.1575619999999986 103.1554110000000009 103.1262739999999951 102.7743990000000025 102.2117539999999991 101.8537369999999953 101.3519359999999949 100.4608309999999989 99.4500050000000044 98.3858489999999932 97.4792860000000019 96.4797059999999931 94.3304820000000035 91.7607419999999934 88.9627150000000029 86.7
919919999999934 85.7987059999999957 85.6878509999999949 85.7567439999999976 85.7396009999999933 85.7413480000000021 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7424469999999985 85.7212980000000044 85.7082599999999957 85.7108920000000012 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7106859999999955 85.7132260000000059 85.6968690000000066 85.6781229999999994 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000
000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803129999999982 85.6805190000000039 85.6822810000000032 85.6830369999999988 85.6661610000000024 85.6539539999999988 85.6497190000000046 85.6493300000000062 85.6498870000000068 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6517869999999988 85.592772999999994 85.6910929999999951 86.4309310000000011
+103.1583789999999965 103.0162579999999934 102.8289029999999968 102.7029720000000026 102.7864229999999992 102.9161830000000037 103.1230549999999937 103.5886990000000054 104.2563020000000051 104.9758829999999961 105.842133000000004 106.7081450000000018 107.4210360000000009 108.1230929999999972 108.8388599999999968 109.4868620000000021 109.8872149999999976 110.1918110000000013 110.6134490000000028 110.9544070000000033 111.1734770000000054 111.2881239999999963 111.2347110000000043 111.1288299999999936 110.9428560000000061 110.8549730000000011 110.7167890000000057 110.6154250000000019 110.691749999999999 110.7254329999999953 110.7210539999999952 110.7383580000000052 110.7193829999999934 110.6481629999999967 110.4758609999999948 110.3203050000000047 110.3526080000000036 110.4857789999999937 110.5415729999999996 110.4569929999999971 110.3466339999999946 109.8448099999999954 109.1535190000000028 108.6331250000000068 107.7654419999999931 106.9605559999999969 106.6310419999999937 106.
885468000000003 107.9801709999999986 109.2480999999999938 109.8835140000000052 110.1006160000000023 110.2499389999999977 110.6662450000000035 111.1521450000000044 111.4614559999999983 111.8114850000000047 112.0544969999999978 112.034599 111.9761429999999933 111.4891970000000043 110.3040239999999983 109.5757519999999943 109.3767009999999971 109.1657490000000053 108.929665 109.774405999999999 110.5084149999999994 108.8447419999999966 108.2913589999999999 109.2197189999999978 109.9170069999999981 110.3344649999999945 110.5434649999999976 110.4459379999999982 110.0855789999999956 109.6397170000000045 109.1242519999999985 108.5004200000000054 107.8653489999999948 107.1015699999999953 106.1331100000000021 105.054665 103.8229450000000043 102.7865450000000038 102.3091579999999965 101.5963749999999948 101.0217439999999982 101.7148439999999994 102.675147999999993 103.0642239999999958 103.2750240000000019 103.7363430000000051 103.8689799999999934 103.8985140000000058 104.05127000000000
24 104.1994320000000016 104.5940700000000021 105.0476840000000038 105.4826809999999995 105.8333659999999981 106.0186769999999967 106.0827869999999962 106.0495760000000018 105.9909210000000002 105.8969120000000004 105.7857060000000047 105.6161500000000046 105.4892880000000019 105.3901520000000005 105.3179700000000025 105.2434690000000046 105.1766740000000055 105.1677700000000044 105.0029530000000051 104.733940000000004 104.617241000000007 104.5818479999999937 104.4421159999999986 103.9358600000000052 103.3084790000000055 103.0373989999999935 103.1891779999999983 103.1883619999999979 103.0096589999999992 102.9851380000000063 102.8924789999999945 102.7538830000000019 102.7102809999999948 102.6884919999999966 102.5116270000000043 102.2042009999999976 101.9236219999999946 101.6157759999999968 101.0306170000000066 100.120521999999994 99.098511000000002 98.1390300000000053 97.3290480000000002 96.3680880000000002 95.1328280000000035 93.6149520000000024 91.7055589999999938 89.4619450
000000001 87.0090789999999998 85.6483989999999977 85.6916350000000051 85.7576980000000049 85.7403950000000066 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7422030000000035 85.7254489999999976 85.7082900000000052 85.7103809999999982 85.7108460000000036 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7126769999999993 85.6952670000000012 85.6783599999999979 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064
85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6802600000000041 85.6814040000000006 85.6818310000000025 85.6773450000000025 85.6698070000000058 85.6522290000000055 85.6480480000000028 85.649437000000006 85.6499400000000009 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6517790000000048 85.6002730000000014 85.6453249999999997 86.4670030000000054
+102.8048480000000069 102.7154079999999965 102.6516720000000049 102.4795989999999932 102.370705000000001 102.5909419999999983 102.854896999999994 103.3156510000000026 103.8501890000000003 104.4097139999999939 105.1779480000000007 106.0772170000000045 106.8802950000000038 107.6385879999999986 108.378783999999996 109.0036010000000033 109.4213179999999994 109.7092820000000017 110.076935000000006 110.3749849999999952 110.5206450000000018 110.5858609999999942 110.5697329999999994 110.3786929999999984 110.1792370000000005 109.9963989999999967 109.809196 109.6607819999999975 109.7300950000000057 109.7903060000000011 109.8841089999999951 110.1347049999999967 110.2119450000000001 110.1769489999999934 110.0704570000000047 110.029601999999997 110.1190799999999967 110.3590619999999944 110.6013180000000062 110.5818249999999949 110.3081970000000069 109.589271999999994 109.0092089999999985 108.5214840000000009 107.5912550000000039 106.8281860000000023 106.4507370000000037 106.49294299999999
68 107.348938000000004 108.7165990000000022 109.3988339999999937 109.5459819999999951 109.6831279999999964 110.1168749999999932 110.6447139999999933 111.0280529999999999 111.2999039999999979 111.6273350000000022 111.776329000000004 111.7425989999999985 111.162871999999993 110.0154880000000048 109.4705280000000016 109.3183290000000056 109.0595169999999996 108.8658910000000049 109.6104349999999954 110.5872880000000009 108.9176099999999963 107.8439709999999963 108.6030039999999985 109.5150830000000042 110.0046459999999939 110.2959060000000022 110.2677539999999965 109.9587250000000012 109.4825819999999936 109.0587620000000015 108.5733570000000014 107.8939129999999977 107.1347499999999968 106.2544170000000037 105.2484050000000053 104.111937999999995 103.0851439999999997 102.3425060000000002 101.2941210000000041 100.4602280000000007 100.7659680000000009 101.7280429999999996 102.3115999999999985 102.4205170000000038 102.7740780000000029 102.9692079999999947 103.0759809999999987 103
.2118150000000014 103.3763579999999962 103.8729929999999939 104.3779370000000029 104.7824329999999975 105.1216739999999987 105.354179000000002 105.4985810000000015 105.5067980000000034 105.503540000000001 105.416679000000002 105.2319030000000026 105.0688860000000062 104.8966599999999971 104.7775120000000015 104.7437970000000007 104.707374999999999 104.653923000000006 104.5785060000000044 104.4247359999999958 104.3385770000000008 104.5074919999999992 104.4355699999999985 103.9514850000000052 103.3755950000000041 102.842376999999999 102.4903790000000043 102.594971000000001 102.5859449999999953 102.5290679999999952 102.5253979999999956 102.4472499999999968 102.3777999999999935 102.3121799999999979 102.2459340000000054 102.0562520000000006 101.8346710000000002 101.634215999999995 101.2383269999999982 100.5936049999999966 99.7861330000000066 98.803009000000003 97.9672470000000004 97.4329379999999929 96.3259120000000024 95.0382079999999974 94.0234449999999953 92.7787170000000003 9
1.1308819999999997 88.8962549999999965 86.4370569999999958 85.4911799999999999 85.6923680000000019 85.7503049999999973 85.741219000000001 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7414700000000067 85.7372819999999933 85.7186659999999989 85.7088090000000022 85.7105260000000015 85.7108149999999966 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7128909999999991 85.6937939999999969 85.6778719999999936 85.6804350000000028 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.68032100
00000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6802220000000005 85.6810839999999985 85.6788020000000046 85.6716160000000002 85.6596679999999964 85.6518630000000059 85.6492389999999943 85.6498789999999985 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6525570000000016 85.596862999999999 85.6162570000000045 86.4829029999999932
+102.6317599999999999 102.6346510000000052 102.5871350000000035 102.3277659999999969 102.123108000000002 102.3245699999999943 102.5629430000000042 102.9781420000000054 103.4203190000000063 103.9195179999999965 104.7017139999999955 105.4659649999999971 106.1980740000000054 106.9897380000000027 107.8187029999999993 108.4685360000000003 108.8969649999999945 109.2215649999999982 109.5265959999999978 109.7327120000000065 109.829741999999996 109.8649520000000024 109.827697999999998 109.5862730000000056 109.3569410000000062 109.0314560000000057 108.7550810000000041 108.6542280000000034 108.7379300000000057 108.8603590000000025 109.0342639999999932 109.4470749999999981 109.5563510000000065 109.5105209999999971 109.6206439999999986 109.7909089999999992 109.9401399999999995 110.2352980000000002 110.5032199999999989 110.4810099999999977 110.0622939999999943 109.2969279999999941 108.8889999999999958 108.3405079999999998 107.4473040000000026 106.7137599999999935 106.2626419999999996 106.2
942500000000052 107.009215999999995 108.1569369999999992 108.8235020000000048 109.0499269999999967 109.1787800000000033 109.5616760000000056 110.1028749999999974 110.5969240000000013 110.9077000000000055 111.164978000000005 111.4070279999999968 111.4169389999999993 110.9198990000000009 109.8326260000000048 109.3384929999999997 109.2976529999999968 109.1050720000000069 108.8458399999999955 109.4590989999999948 110.6049349999999976 109.100403 107.5936580000000049 107.9826280000000054 108.9867550000000023 109.5691989999999976 109.9222950000000054 109.9789889999999986 109.8125 109.366730000000004 108.9436570000000017 108.5509639999999933 107.9155039999999985 107.1865389999999962 106.3621370000000042 105.4204330000000027 104.4089199999999948 103.3340910000000008 102.4225689999999958 101.4295269999999931 100.3016199999999998 100.1083220000000011 100.5981519999999989 101.2364039999999932 101.5551300000000055 101.7652510000000063 102.0138929999999959 102.1664580000000058 102.3279500
000000013 102.6285929999999951 103.1190339999999992 103.6036220000000014 103.9391099999999994 104.2437440000000066 104.5396269999999959 104.7376170000000002 104.8143689999999992 104.8865969999999948 104.7184830000000062 104.5383450000000067 104.4262540000000001 104.2865450000000038 104.2395250000000004 104.2520520000000062 104.2419129999999967 104.2361149999999981 104.0856480000000062 103.9363330000000047 103.8923570000000041 103.9967419999999976 103.8829350000000034 103.3675460000000044 102.8255079999999992 102.3721079999999972 102.0737529999999964 102.1563799999999986 101.969177000000002 102.0038380000000018 102.1105579999999975 102.1006320000000045 102.0762100000000032 102.050255000000007 101.9469150000000042 101.7369230000000044 101.5266799999999989 101.2215350000000029 100.7661059999999935 100.1680369999999982 99.402198999999996 98.533134000000004 97.880004999999997 97.5457380000000001 96.4674839999999989 95.1992800000000017 94.6570889999999991 93.8210980000000063 92.30
51990000000018 90.9582209999999947 88.5098189999999931 86.0225300000000033 85.5365749999999991 85.7277909999999963 85.7427899999999994 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.741219000000001 85.7423249999999939 85.7363589999999931 85.716614000000007 85.7105640000000051 85.7107850000000013 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7124400000000009 85.6977229999999963 85.6798399999999987 85.6800460000000044 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000
064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6802670000000006 85.6805880000000002 85.6821900000000056 85.6812520000000006 85.6628340000000037 85.6533050000000031 85.6487879999999961 85.6482850000000013 85.6497499999999974 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6498490000000032 85.645781999999997 85.5839459999999974 85.6738890000000026 86.6545179999999959
+102.5295639999999935 102.5801009999999991 102.3918610000000058 102.1067579999999992 102.0303729999999973 102.1645280000000042 102.3094410000000067 102.5981519999999989 102.9380869999999959 103.4051900000000046 104.2774890000000028 105.0276109999999932 105.7072450000000003 106.4808199999999943 107.3005679999999984 107.9219819999999999 108.367919999999998 108.7034680000000009 108.9491960000000006 109.0745620000000002 109.166877999999997 109.1293720000000036 108.9646000000000043 108.7110749999999939 108.4464949999999988 107.9578630000000032 107.4501649999999984 107.4249729999999943 107.6805039999999991 107.9156720000000007 108.143974 108.5793230000000023 108.8455119999999994 108.9614490000000018 109.1700819999999936 109.5103529999999949 109.833129999999997 110.1184769999999986 110.2873230000000007 110.2839579999999984 109.7346270000000032 109.0856320000000039 108.7288819999999987 108.0702670000000012 107.3583299999999952 106.6523969999999935 106.1297990000000055 106.29454800000
0006 106.9118880000000047 107.8138200000000069 108.3687819999999959 108.5841450000000066 108.778931 109.0763239999999996 109.5142060000000015 110.1053849999999983 110.5987400000000065 110.9340289999999953 111.1845550000000031 111.2021940000000058 110.7569660000000056 109.6867139999999949 109.165733000000003 109.2008510000000001 109.0081789999999984 108.6632000000000033 109.3360669999999999 110.5044630000000012 109.2705689999999947 107.4889759999999939 107.4116669999999942 108.3817750000000046 109.1374509999999987 109.5677189999999968 109.702422999999996 109.6091080000000062 109.2813189999999963 108.8385700000000043 108.4168619999999947 107.8641510000000068 107.2021260000000069 106.4304049999999933 105.5273969999999935 104.6262820000000033 103.617249000000001 102.6441879999999998 101.8398360000000054 100.6244740000000064 99.9009549999999962 99.7249910000000028 99.9814219999999949 100.392273000000003 100.7264629999999954 101.0455780000000061 101.2474979999999931 101.5454330000
000027 102.0927049999999952 102.538139000000001 102.8637310000000014 103.063438000000005 103.2489850000000047 103.5076370000000026 103.7731169999999992 104.0041429999999991 104.1265870000000007 104.0399019999999979 103.8966450000000066 103.7922970000000049 103.6687770000000057 103.7355579999999975 103.7977139999999991 103.7557450000000046 103.7874759999999981 103.7295069999999981 103.5678479999999979 103.453132999999994 103.327147999999994 103.1351319999999987 102.7988129999999956 102.3980480000000028 101.7833329999999989 101.4921109999999942 101.6696239999999989 101.4452969999999965 101.4629589999999979 101.6697309999999987 101.7200780000000009 101.7633739999999989 101.7581330000000008 101.6147310000000061 101.3507390000000044 101.0754469999999969 100.7642819999999944 100.3633420000000029 99.7731480000000062 99.02346 98.2554779999999965 97.6551510000000036 97.4819789999999955 96.8323290000000014 95.7335360000000009 95.2583159999999936 94.8814390000000003 94.0991590000000002
93.1811979999999949 91.2322240000000022 88.2298279999999977 86.0531229999999994 85.6671220000000062 85.737671000000006 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7413789999999949 85.7429659999999956 85.732048000000006 85.7122269999999986 85.7105940000000004 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7111359999999962 85.7082369999999969 85.6876979999999975 85.6786189999999976 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210
000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803129999999982 85.6806179999999955 85.6807709999999929 85.6776349999999951 85.6686329999999998 85.6489490000000018 85.6476669999999984 85.6495209999999929 85.6499019999999973 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6497269999999986 85.6503450000000015 85.6518250000000023 85.633728000000005 85.5910640000000029 85.6478350000000006 86.6587070000000068
+102.3230899999999934 102.3561329999999998 102.1677930000000032 101.8381729999999976 101.8083419999999961 102.0236280000000022 102.2035829999999947 102.3532790000000006 102.517951999999994 102.8137820000000033 103.5232929999999953 104.4318080000000037 105.2862240000000043 106.0533449999999931 106.7778469999999942 107.389403999999999 107.8244629999999944 108.1524050000000017 108.3714290000000062 108.4680630000000008 108.5616299999999939 108.4028550000000024 108.0385440000000017 107.7125699999999995 107.3144759999999991 106.6508869999999973 106.1223909999999933 106.2210160000000059 106.5964510000000018 106.9534069999999986 107.3712230000000005 107.915740999999997 108.4092480000000052 108.7212600000000009 109.0117340000000041 109.394919999999999 109.7641979999999933 109.9599149999999952 110.0656890000000061 110.0536500000000046 109.4281229999999994 108.9191440000000028 108.4814149999999984 107.8689650000000029 107.2258530000000007 106.4746399999999937 106.0732880000000051 106.35
20579999999995 106.7972180000000009 107.3834300000000042 107.8519900000000007 107.9805450000000064 108.0604100000000045 108.3664930000000055 108.8954470000000043 109.6617810000000048 110.2935030000000012 110.7376629999999977 111.0078120000000013 111.0508350000000064 110.5847930000000048 109.5028760000000005 109.008018000000007 109.0547870000000046 108.808021999999994 108.4775389999999931 109.2830730000000017 110.2566910000000036 109.2469640000000055 107.4002229999999969 106.9843369999999965 107.8333970000000051 108.7309419999999989 109.2003399999999971 109.4106290000000001 109.3562770000000057 109.1250229999999988 108.7462770000000063 108.2688670000000002 107.7326970000000017 107.1070330000000013 106.398926000000003 105.5095519999999993 104.6364590000000021 103.814423000000005 102.9236910000000051 102.2577129999999954 101.1791920000000005 100.0786970000000053 99.4720080000000024 99.3089750000000038 99.4494250000000051 99.7658770000000032 100.1154789999999934 100.425811999999
9934 100.9577179999999998 101.6303790000000049 102.0386280000000028 102.2134549999999962 102.2692789999999974 102.3673399999999987 102.6708220000000011 103.0192339999999973 103.3421249999999958 103.4801479999999998 103.4478529999999949 103.2964630000000028 103.1863249999999965 103.1232909999999947 103.1938099999999991 103.2943190000000016 103.2734829999999988 103.2938079999999985 103.2919849999999968 103.1528849999999977 102.9714280000000031 102.7683179999999936 102.566032000000007 102.3446430000000049 101.9375229999999988 101.1334149999999994 100.9153289999999998 101.1388550000000066 100.9404069999999933 100.9141690000000011 101.1778790000000043 101.2765809999999931 101.3522719999999993 101.3697130000000044 101.269165000000001 101.0046619999999962 100.6718369999999965 100.3798369999999949 99.9841080000000062 99.367125999999999 98.6377489999999995 97.9571459999999945 97.5085600000000028 97.4520490000000024 97.2179869999999937 96.3786089999999973 95.7626269999999948 95.607551
9999999983 95.3891140000000064 94.7972180000000009 93.3809889999999996 90.8770750000000049 87.602287000000004 85.803687999999994 85.7198180000000036 85.7412489999999963 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412800000000033 85.7422559999999976 85.7385179999999991 85.7165069999999929 85.7101669999999984 85.7108309999999989 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7106859999999955 85.711853000000005 85.692688000000004 85.6777799999999985 85.6803210000000064 85.6803210000000064 85.6803210000000064 85
.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6802749999999946 85.6812670000000054 85.6822740000000067 85.6736149999999981 85.6592179999999956 85.6516950000000037 85.6489789999999971 85.6499560000000031 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6497800000000069 85.6504439999999931 85.6498179999999962 85.6446150000000017 85.6267780000000016 85.6073760000000021 85.5495679999999936 86.3396299999999997
+102.1007539999999949 102.1002960000000002 101.8950880000000012 101.6375349999999997 101.6860659999999967 101.9300080000000008 102.1806789999999978 102.2037890000000004 102.1357270000000028 102.2484129999999993 102.8786539999999974 103.9572830000000039 104.8796690000000069 105.582611 106.2546540000000022 106.8976519999999937 107.3232349999999968 107.6276629999999983 107.8454360000000065 107.9415659999999946 107.9161299999999954 107.5569610000000011 107.0437469999999962 106.5743939999999981 106.0451889999999935 105.4283070000000038 105.1348420000000061 105.4364929999999987 105.8622060000000005 106.235313000000005 106.799744000000004 107.5548550000000034 108.2781070000000057 108.7607500000000016 109.0958250000000049 109.4004819999999967 109.6582259999999991 109.7749179999999996 109.851616000000007 109.7036130000000043 109.089698999999996 108.7418590000000052 108.344727000000006 107.7002030000000019 106.9417880000000025 106.0283969999999982 105.6987000000000023 106.0882260000000
059 106.4822240000000022 106.7652740000000051 107.0619279999999947 107.1765290000000022 107.1359410000000025 107.4875490000000013 108.375945999999999 109.3334430000000026 109.981026 110.4934619999999938 110.7445830000000058 110.7816470000000066 110.3796839999999975 109.3696139999999986 108.8546910000000025 108.9003680000000003 108.6500170000000054 108.3609009999999984 109.1650539999999978 109.8926770000000062 109.0342639999999932 107.2466809999999953 106.6734469999999959 107.3695979999999963 108.3320920000000029 108.8103490000000022 109.084075999999996 109.1001820000000038 108.869133000000005 108.5344999999999942 108.1270829999999989 107.5994110000000035 106.9498899999999963 106.2699360000000013 105.4257199999999983 104.5711589999999944 103.8928530000000023 103.1400830000000042 102.5602260000000001 101.7520980000000037 100.5708159999999936 99.6359479999999991 99.0846939999999989 98.9220279999999974 99.0531229999999994 99.3582150000000013 99.8423839999999956 100.6219410000000
067 101.1934889999999996 101.4887240000000048 101.5728990000000067 101.5245510000000024 101.6025389999999931 102.0074769999999944 102.4632490000000047 102.7794650000000019 102.8812559999999934 102.7664950000000061 102.6267469999999946 102.5254750000000001 102.5278550000000024 102.575806 102.6732640000000032 102.6994020000000063 102.7020190000000071 102.6967319999999972 102.595130999999995 102.4499129999999951 102.2540659999999946 102.077415000000002 101.8206179999999961 101.3051379999999995 100.5782169999999951 100.4277040000000056 100.4850689999999958 100.3490680000000026 100.3680339999999944 100.7179260000000056 100.8935469999999981 100.9572299999999956 100.964539000000002 100.8779830000000004 100.6291279999999944 100.3094480000000033 99.954582000000002 99.5031510000000026 98.9446870000000018 98.3219150000000042 97.7389370000000071 97.3978120000000018 97.3209839999999957 97.1637419999999992 96.6083220000000011 96.2093200000000053 96.2286380000000037 96.1567229999999995 95.
4962459999999993 94.2992550000000023 92.1985700000000037 88.7993160000000046 86.0831450000000018 85.7074279999999931 85.740784000000005 85.7405700000000053 85.7411649999999952 85.7413180000000068 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7414780000000007 85.7415620000000018 85.7294849999999968 85.7126540000000006 85.7103270000000066 85.710875999999999 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7109379999999987 85.6894989999999979 85.6778719999999936 85.6803819999999945 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.68032100000
00064 85.6803210000000064 85.6803210000000064 85.6804580000000016 85.6778110000000055 85.674034000000006 85.6582259999999991 85.647278 85.648643000000007 85.6499100000000055 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6498179999999962 85.6501690000000053 85.6520459999999986 85.6391449999999992 85.6258700000000061 85.621619999999993 85.6181339999999977 85.5567700000000002 85.9262619999999941
+101.9823149999999998 101.9918820000000039 101.7117539999999991 101.4908980000000014 101.6564639999999997 101.9813610000000068 102.1715549999999979 101.981110000000001 101.8268659999999954 101.9844819999999999 102.6670610000000039 103.7785259999999994 104.5546190000000024 105.0956800000000015 105.7594679999999983 106.3817899999999952 106.8443450000000041 107.1957929999999948 107.3568499999999943 107.3690720000000027 107.2018970000000024 106.7916720000000055 106.3155059999999992 105.6149750000000012 104.8914029999999968 104.4761809999999969 104.4669039999999995 104.9071200000000061 105.4604340000000064 105.8169479999999965 106.3329010000000068 107.3010330000000039 108.230591000000004 108.7117539999999991 108.9109339999999975 109.2275850000000048 109.4744720000000058 109.561310000000006 109.6323469999999958 109.4671100000000052 108.9307019999999966 108.4977650000000011 108.165222 107.5203319999999962 106.4997479999999968 105.4241180000000071 105.0665209999999945 105.53659799999
99979 106.0276570000000049 106.2959519999999998 106.3729399999999998 106.4293590000000052 106.3883289999999988 106.8260039999999975 108.0340039999999959 109.079338000000007 109.6967700000000008 110.2628330000000005 110.529601999999997 110.5223849999999999 110.1583399999999955 109.2134860000000032 108.7235790000000009 108.7998050000000063 108.5339579999999984 108.2267300000000034 108.9944919999999939 109.558952000000005 108.7129060000000038 106.976624000000001 106.3320240000000041 106.8946609999999993 107.9142230000000069 108.4438020000000051 108.6828610000000026 108.742408999999995 108.5049510000000055 108.1186519999999973 107.7499310000000037 107.347022999999993 106.7597810000000038 106.0547710000000023 105.2370609999999971 104.4344559999999973 103.8627699999999976 103.1896289999999965 102.6254650000000055 102.1659619999999933 101.1968690000000066 100.1566470000000066 99.2581100000000021 98.7807009999999934 98.6994090000000028 98.8924480000000017 99.5094150000000042 100.375
2060000000057 100.7636799999999937 100.9187239999999974 100.982917999999998 100.9868550000000056 101.1274410000000046 101.5228960000000029 101.9389879999999948 102.1782910000000015 102.2660680000000042 102.1878509999999949 102.0625990000000058 101.9660719999999969 102.017548000000005 102.0549769999999938 102.0609819999999957 102.1133650000000017 102.1956629999999961 102.1939239999999955 102.0803149999999988 101.8830109999999962 101.7402040000000056 101.6047899999999942 101.2747119999999938 100.5798649999999981 100.1228490000000022 100.1854859999999974 99.9215159999999969 99.7141040000000061 99.8873899999999963 100.3262480000000068 100.558173999999994 100.6220780000000019 100.5978700000000003 100.4958950000000044 100.2465440000000001 99.9293059999999969 99.5200959999999952 99.0565189999999944 98.5705640000000045 98.1316680000000048 97.6637190000000004 97.2386860000000013 97.0659639999999939 96.8409649999999971 96.5596010000000007 96.4233629999999948 96.4506229999999931 96.480
2860000000067 96.0561069999999972 94.7739490000000018 92.4038010000000014 88.9020540000000068 86.108429000000001 85.6964569999999952 85.7443540000000013 85.7440869999999933 85.7412340000000057 85.7404400000000066 85.7408829999999966 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412340000000057 85.741981999999993 85.743622000000002 85.7259289999999936 85.7116319999999945 85.7106090000000052 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.71096 85.6926040000000029 85.6790239999999983 85.6801609999999982 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.680321
0000000064 85.6803210000000064 85.6803210000000064 85.6811139999999938 85.6660839999999979 85.6541059999999987 85.6492999999999967 85.6494450000000001 85.6498490000000032 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6498490000000032 85.6508029999999962 85.6519320000000022 85.6435929999999956 85.6233289999999982 85.617241000000007 85.6185990000000032 85.6193849999999941 85.6141510000000068 85.6429140000000046
+101.921882999999994 101.8735350000000039 101.5160139999999984 101.2566989999999976 101.5490190000000013 101.9816359999999946 102.0454560000000015 101.6994020000000063 101.6307910000000021 102.023499000000001 102.7012789999999995 103.6104430000000036 104.1941149999999965 104.6295549999999963 105.2193599999999947 105.7667689999999965 106.3250349999999997 106.8193509999999975 106.9332200000000057 106.7815319999999986 106.5326079999999962 106.238892000000007 105.6367719999999935 104.7062070000000062 103.9245300000000043 103.6930080000000061 103.9970550000000031 104.5409010000000052 105.1137540000000001 105.5197220000000016 106.0772709999999961 107.0545500000000061 107.951744000000005 108.462608000000003 108.7008440000000036 108.9580229999999972 109.2189869999999985 109.3069150000000036 109.2783739999999995 109.1934200000000033 108.8187099999999958 108.2965700000000027 107.9663010000000014 107.430610999999999 106.2307590000000062 105.0349879999999985 104.6210630000000066 104.9026
410000000027 105.409797999999995 105.8080669999999941 105.8968279999999993 105.8609620000000007 105.7875059999999934 106.4179989999999947 107.717376999999999 108.7538600000000031 109.4269869999999969 110.0011520000000047 110.2787629999999979 110.2898940000000039 109.965637000000001 109.073882999999995 108.5758359999999954 108.5988389999999981 108.2839740000000006 107.9013060000000053 108.4064709999999963 108.7858889999999974 108.0876920000000041 106.6484300000000047 105.9648130000000066 106.4190219999999982 107.4523240000000044 108.0526499999999999 108.2298200000000037 108.348076000000006 108.1810760000000045 107.8473050000000057 107.4838409999999982 107.111298000000005 106.5535739999999976 105.8190539999999942 105.0357510000000048 104.2562559999999934 103.7655639999999977 103.1535949999999957 102.5220719999999943 102.2684019999999947 101.6281280000000038 100.703636000000003 99.6929090000000002 98.9042969999999997 98.6068190000000016 98.6075289999999995 99.0227809999999948 9
9.8410109999999946 100.269157000000007 100.337340999999995 100.4784470000000027 100.727530999999999 100.9600910000000056 101.2341380000000015 101.4738619999999969 101.6242069999999984 101.7778780000000012 101.7888789999999943 101.609809999999996 101.5364990000000063 101.5655670000000015 101.5776440000000065 101.6073229999999938 101.7585299999999933 101.9569850000000031 101.971587999999997 101.7452550000000002 101.4216380000000015 101.2960740000000044 101.1608889999999974 100.7553630000000027 100.0534289999999942 99.8972399999999965 100.038848999999999 99.798759000000004 99.4902569999999997 99.4995569999999958 99.8598709999999983 100.1575700000000069 100.2546690000000069 100.2569500000000033 100.1698679999999939 99.9003600000000063 99.5529860000000042 99.1449360000000013 98.7113039999999984 98.3142009999999971 97.9865190000000013 97.5025250000000057 97.0306089999999983 96.8812259999999981 96.6936489999999935 96.5098500000000001 96.4377669999999938 96.446235999999999 96.519195
9999999938 96.4839170000000053 95.1855390000000057 92.3927690000000013 88.8629379999999998 86.0980069999999955 85.6727070000000026 85.7612000000000023 85.7613369999999975 85.7465519999999941 85.7435300000000069 85.7427370000000053 85.740752999999998 85.7411270000000059 85.7413250000000033 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7411960000000022 85.742125999999999 85.7423550000000034 85.718757999999994 85.7092209999999994 85.7108539999999977 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108539999999977 85.704498000000001 85.6846239999999995 85.6791690000000017 85.6803210000000064 85.6803210000000064 85.6803210000000064 85
.6803210000000064 85.6803210000000064 85.6802519999999959 85.6819080000000071 85.6608889999999974 85.6454470000000043 85.6495209999999929 85.6499019999999973 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6497800000000069 85.6503220000000027 85.6483690000000024 85.6432109999999938 85.6262439999999998 85.618110999999999 85.6193470000000048 85.6193619999999953 85.6194919999999939 85.6255869999999959 85.5850449999999938
+101.8378139999999945 101.6898879999999963 101.1969069999999959 101.0396879999999982 101.3854060000000032 101.7746659999999963 101.7764509999999945 101.4803540000000055 101.4328309999999931 102.0297319999999957 102.6504359999999991 103.2688059999999979 103.776061999999996 104.1967240000000032 104.6819990000000047 105.0962750000000057 105.6230929999999972 106.2354200000000048 106.4739150000000052 106.3012080000000026 105.9439540000000051 105.579741999999996 104.8331069999999983 103.9370040000000017 103.2899400000000014 103.1808319999999952 103.5409010000000052 104.1570739999999944 104.7610629999999929 105.2742310000000003 105.9741669999999942 106.7639010000000042 107.4184190000000001 108.0595320000000044 108.5302279999999939 108.7106019999999944 108.8006440000000055 108.8634109999999993 108.8056639999999931 108.7432019999999966 108.590453999999994 108.1896820000000048 107.818450999999996 107.3516850000000034 106.2399369999999976 105.0196080000000052 104.3882140000000049 104.31
08670000000018 104.7201770000000067 105.2312770000000057 105.4140550000000047 105.2347029999999961 105.2073900000000037 106.1267009999999971 107.4680859999999996 108.4161450000000002 109.1560970000000026 109.7269129999999961 110.0120239999999967 110.0627290000000045 109.812492000000006 108.9496690000000001 108.3487400000000065 108.1890719999999959 107.8612289999999945 107.4603500000000054 107.3658290000000051 107.2900850000000048 106.9072879999999941 106.1863780000000048 105.7072220000000016 105.9873280000000051 106.8866809999999958 107.5930019999999985 107.803496999999993 108.002326999999994 107.912871999999993 107.7193299999999994 107.4690020000000032 106.9571530000000052 106.3163530000000065 105.5882950000000022 104.8525999999999954 104.097724999999997 103.6001049999999992 103.012519999999995 102.3045039999999943 102.1404720000000026 101.5879290000000026 100.9148030000000063 100.1311259999999947 99.1795500000000061 98.5372919999999937 98.1541979999999938 98.22718799999999
82 98.9140550000000047 99.6351470000000035 99.7684780000000018 99.9671859999999981 100.3931120000000021 100.6604159999999979 100.8708649999999949 101.0625150000000048 101.1824720000000042 101.3088300000000004 101.291199000000006 101.0885240000000067 101.0456920000000025 101.0314790000000045 101.0574569999999994 101.2155609999999939 101.3836139999999943 101.5678329999999931 101.5731349999999935 101.3506009999999975 101.0927120000000059 100.952849999999998 100.6490249999999946 100.0217059999999947 99.8093109999999939 99.8297649999999948 99.5765690000000063 99.4036100000000005 99.3635249999999957 99.2768250000000023 99.2752839999999992 99.5589370000000002 99.8206859999999949 99.8843540000000019 99.8023910000000001 99.5268860000000046 99.1559979999999968 98.7498630000000048 98.3794249999999977 97.9990080000000034 97.5599670000000003 97.1466139999999996 96.8413539999999955 96.6730040000000059 96.4900439999999975 96.283600000000007 96.1823200000000043 96.2700119999999941 96.387862
9999999958 96.3756259999999969 95.3140790000000067 92.6271969999999953 89.4928440000000052 86.8584819999999951 85.765632999999994 85.7449799999999982 85.7729420000000005 85.7656020000000012 85.7614520000000056 85.7544709999999952 85.7438279999999935 85.7416309999999982 85.7406540000000064 85.7408980000000014 85.7411419999999964 85.7419359999999955 85.7424160000000057 85.7414780000000007 85.7412340000000057 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7411730000000034 85.7433319999999952 85.7276690000000059 85.7086259999999953 85.7098849999999999 85.7102280000000007 85.7107539999999943 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7107929999999953 85.7097169999999977 85.688453999999993 85.6783599999999979 85.6803359999999969 85.6803210000000064 85.6803210000000064
85.6803210000000064 85.6803210000000064 85.6805190000000039 85.6801070000000067 85.6611249999999984 85.6477739999999983 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6497880000000009 85.6500549999999947 85.6511150000000043 85.6492159999999956 85.6329800000000034 85.6234440000000063 85.6187900000000042 85.619101999999998 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6188429999999983 85.6220399999999984
+101.7373580000000004 101.5654679999999956 101.204780999999997 101.0781630000000035 101.1304930000000013 101.4038699999999977 101.499297999999996 101.380439999999993 101.369804000000002 101.921165000000002 102.4964140000000015 102.9643169999999941 103.4219279999999941 103.8151929999999936 104.1797260000000023 104.4747389999999996 104.9303589999999957 105.4949799999999982 105.8491970000000038 105.826744000000005 105.4803469999999948 104.914032000000006 104.1913760000000053 103.4767989999999998 102.9742049999999978 102.936790000000002 103.1726299999999981 103.767944 104.4242629999999963 105.0351940000000042 105.7871319999999997 106.4104080000000039 106.8497619999999984 107.470641999999998 107.9985279999999932 108.1891399999999948 108.202613999999997 108.3270190000000071 108.4515150000000006 108.4003979999999956 108.2821579999999955 107.9640500000000003 107.5152279999999934 107.0611339999999956 106.2968139999999977 105.2331920000000025 104.2955089999999956 103.819823999999997 10
4.073204000000004 104.5252459999999957 104.716826999999995 104.5862809999999996 104.6719669999999951 105.8431700000000006 107.2907940000000053 108.1213460000000026 108.7580719999999985 109.3673629999999974 109.6885829999999942 109.7609250000000003 109.5107189999999946 108.7656939999999963 108.1967620000000068 107.8714370000000002 107.5597309999999993 107.2205730000000017 106.8149870000000021 106.4468150000000009 106.0805969999999974 105.7859270000000009 105.6116640000000046 105.6361689999999953 106.3113709999999941 107.1138839999999988 107.334778 107.5359270000000009 107.5100479999999976 107.3167880000000025 107.0865859999999969 106.6038209999999964 105.960448999999997 105.237671000000006 104.5576860000000039 103.8803479999999979 103.3455199999999934 102.7750089999999972 102.0834880000000027 101.9598919999999964 101.3476100000000031 100.784514999999999 100.3175430000000006 99.4774089999999944 98.6440809999999999 97.8893810000000002 97.6190030000000064 98.0210270000000037 98.
7983250000000055 99.1787949999999938 99.3842700000000008 99.8214569999999952 100.1790620000000018 100.4665150000000011 100.6835399999999936 100.7446369999999973 100.7904209999999949 100.7430800000000062 100.6114730000000037 100.5562589999999972 100.5607830000000007 100.6005169999999964 100.7281880000000029 100.802818000000002 100.8821109999999948 100.8758320000000026 100.7562559999999934 100.616730000000004 100.3493880000000047 99.9234239999999971 99.5490719999999953 99.6418989999999951 99.5083850000000041 99.0423049999999989 98.6731340000000046 98.5782470000000046 98.7382350000000031 98.8656919999999957 98.9587169999999929 99.0463940000000065 99.0912399999999991 99.1510009999999937 99.0277940000000001 98.6832349999999963 98.3246379999999931 98.0317759999999936 97.6085970000000032 97.1620410000000021 96.8954849999999936 96.6846539999999948 96.4688419999999951 96.1890410000000031 95.9313199999999995 95.7489779999999939 95.7779919999999976 95.9647140000000007 96.14555400000000
42 95.3684159999999963 93.1454849999999936 90.8627929999999964 88.9135210000000029 86.937927000000002 85.8238139999999987 85.7418059999999969 85.7852780000000052 85.7759479999999996 85.7708049999999957 85.7610240000000061 85.7487409999999954 85.7422870000000046 85.7430339999999944 85.7443920000000048 85.7337650000000053 85.7243650000000059 85.7390060000000034 85.7425159999999948 85.7412410000000023 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7417219999999958 85.7364429999999942 85.7169269999999983 85.7126690000000053 85.7130810000000025 85.7110140000000058 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7087020000000024 85.6886059999999929 85.6786270000000059 85.6802059999999983 85.6803210000000064 85.6803210000000064 85.6803210000000064 85.6803
210000000064 85.6818159999999978 85.672118999999995 85.6515050000000002 85.6493449999999967 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6498260000000045 85.6501240000000053 85.6499400000000009 85.6475680000000068 85.6378629999999958 85.6175000000000068 85.6170429999999953 85.6190869999999933 85.6193999999999988 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953
+101.7332690000000071 101.5409930000000003 101.3057479999999941 101.0287929999999932 100.822449000000006 101.0115430000000032 101.1459579999999931 101.2255099999999999 101.3884429999999952 101.7730179999999933 102.3225400000000036 102.762092999999993 103.1340560000000011 103.4919890000000038 103.755156999999997 104.0340419999999995 104.355842999999993 104.7407149999999945 105.1710130000000021 105.2843320000000062 105.040253000000007 104.5091089999999951 103.7277370000000047 103.0311889999999977 102.6543879999999973 102.7078400000000045 102.9076160000000044 103.4355620000000044 104.1062550000000044 104.7742769999999979 105.4650500000000051 106.0277480000000025 106.3944240000000008 106.8874820000000057 107.2802810000000022 107.4978559999999987 107.6975709999999964 107.9154889999999938 108.0800780000000003 108.039551000000003 107.8201830000000001 107.6010509999999982 107.2330319999999944 106.7634120000000024 106.2442250000000001 105.2780759999999987 104.071044999999998 103.26901
20000000036 103.398894999999996 103.8228840000000019 103.9579240000000055 103.9902040000000056 104.3098909999999933 105.6034619999999933 107.0068820000000045 107.8150559999999984 108.4257580000000019 108.973754999999997 109.3145679999999942 109.4325099999999935 109.1538850000000025 108.5793000000000035 108.0737380000000059 107.6653369999999938 107.3447879999999941 107.0042650000000037 106.6612630000000053 106.3309710000000052 105.9253460000000047 105.633269999999996 105.4086070000000035 105.3035349999999966 105.775306999999998 106.6257710000000003 106.8852839999999986 107.0077739999999977 106.9937520000000006 106.7583470000000005 106.4161220000000014 106.0158310000000057 105.4049610000000001 104.765593999999993 104.1479949999999945 103.5551219999999972 103.0781779999999941 102.5874179999999996 101.9414670000000029 101.6684719999999942 101.3120569999999958 100.7842100000000016 100.3358539999999977 99.6322940000000017 98.7905200000000008 97.9463810000000024 97.3760379999999941
97.3552860000000067 97.8839420000000047 98.5386349999999993 98.8717189999999988 99.2954409999999967 99.7774890000000028 100.1021729999999934 100.347808999999998 100.4114299999999957 100.3954470000000043 100.311829000000003 100.1731869999999986 100.1231609999999961 100.1957170000000019 100.2270579999999995 100.2464980000000025 100.2660290000000032 100.2668529999999976 100.2191470000000066 100.0256200000000035 99.8079910000000012 99.5989299999999957 99.5068049999999999 99.5309220000000039 99.4325869999999981 99.0722729999999956 98.5713580000000036 98.085731999999993 97.7709349999999944 98.0105510000000066 98.5037769999999995 98.6253130000000056 98.4989620000000059 98.3494639999999976 98.2484359999999981 98.1339339999999964 97.9326709999999991 97.7392650000000032 97.5318680000000029 97.2033389999999997 96.9921420000000012 96.7231830000000059 96.4717789999999979 96.2585530000000063 95.9289019999999937 95.5535739999999976 95.2815630000000056 95.2187349999999952 95.43328099999999
38 95.8438260000000071 95.4961780000000005 93.9325560000000053 92.2652970000000039 91.0663299999999936 89.4098510000000033 86.9362639999999942 85.7198790000000059 85.7373429999999956 85.7975160000000017 85.7864759999999933 85.7738190000000031 85.7654650000000061 85.7594760000000065 85.7595369999999946 85.7278440000000046 85.7244419999999963 85.7481539999999995 85.7349169999999958 85.7378309999999999 85.7416609999999935 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7411960000000022 85.7419969999999978 85.7357329999999962 85.7307359999999932 85.7269210000000044 85.7124400000000009 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7105559999999969 85.7014010000000042 85.6840129999999931 85.6801609999999982 85.6803129999999982 85.6803210000000064 85.680
3210000000064 85.6803210000000064 85.6828540000000061 85.6656270000000006 85.6478500000000054 85.6499790000000019 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6498569999999972 85.6504359999999991 85.6514209999999991 85.6432039999999972 85.6302029999999945 85.6212840000000028 85.6183620000000047 85.6194839999999999 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953
+101.863861 101.5188289999999967 101.0399249999999967 100.6028139999999951 100.4338300000000004 100.725562999999994 100.8442079999999947 100.937531000000007 101.319580000000002 101.6936039999999934 102.0967409999999944 102.4362490000000037 102.7496409999999969 103.1003419999999977 103.3272089999999963 103.6197429999999997 103.8319929999999971 104.0977550000000065 104.5164790000000039 104.6173100000000034 104.4211880000000008 104.0562209999999936 103.2285689999999931 102.5002369999999985 102.1994169999999968 102.2733149999999966 102.5772780000000068 102.9245449999999948 103.5651249999999948 104.2995530000000031 104.9709550000000036 105.5881040000000013 105.9658359999999959 106.2952959999999933 106.5731349999999935 106.919951999999995 107.2540130000000005 107.5203400000000045 107.6504819999999967 107.6344529999999935 107.4155580000000043 107.2447810000000032 107.0422740000000061 106.6487879999999961 106.1429140000000046 105.1457290000000029 103.7353820000000013 102.723534000000
0008 102.7599110000000024 103.245789000000002 103.3712079999999958 103.378112999999999 103.8999629999999996 105.2288130000000024 106.5634160000000037 107.5233609999999942 108.2484280000000041 108.7089540000000056 109.0111689999999953 109.0601429999999965 108.7748030000000057 108.3057790000000011 107.7976759999999956 107.3439639999999997 107.0161970000000053 106.6718979999999988 106.356812000000005 106.0539320000000032 105.7641370000000052 105.5157240000000058 105.1410139999999984 104.9592059999999947 105.2219699999999989 105.9655910000000034 106.3781809999999979 106.4991530000000068 106.4477389999999986 106.2633670000000023 105.8800130000000053 105.3866040000000055 104.8090820000000036 104.3398210000000006 103.7869720000000058 103.1847920000000016 102.7055589999999938 102.3606410000000011 101.7399900000000059 101.2142110000000059 101.2999729999999943 100.9933240000000012 100.4022980000000018 99.7415469999999971 98.8565980000000053 97.8806689999999975 97.17971 96.891609000000
0025 97.0454100000000039 97.7788539999999955 98.4083250000000049 98.8823849999999993 99.3673480000000069 99.5266570000000002 99.7621149999999943 99.8079529999999977 99.728667999999999 99.7024770000000018 99.5839610000000022 99.5148319999999984 99.5246199999999988 99.4986339999999956 99.484343999999993 99.4846650000000068 99.4399640000000034 99.4321439999999939 99.3723600000000005 99.2849810000000019 99.3263239999999996 99.3957900000000052 99.2848429999999951 99.0600199999999944 98.6624910000000028 98.0978999999999957 97.5649489999999986 97.380195999999998 97.6114350000000002 97.947685000000007 98.2902679999999975 98.5645070000000061 98.4598540000000071 97.9834900000000033 97.4944459999999964 97.3067700000000002 97.1596679999999964 96.9416729999999944 96.6567990000000066 96.4352870000000024 96.2123030000000057 96.0986019999999996 95.9305949999999967 95.5962829999999997 95.2143250000000023 94.894005000000007 94.7769169999999974 94.9588470000000058 95.4304049999999933 95.496223
0000000005 94.6705860000000001 93.4049380000000014 92.3962169999999929 91.5113680000000045 89.1603929999999991 86.3679730000000063 85.6214370000000002 85.7989649999999955 85.7876820000000038 85.7696530000000052 85.7723620000000011 85.7721860000000049 85.7517550000000028 85.6543879999999973 85.9978260000000034 86.280974999999998 85.8279270000000025 85.7020339999999976 85.7428050000000042 85.7412800000000033 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7413180000000068 85.7424239999999998 85.7448729999999983 85.7357939999999985 85.7133639999999986 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7110140000000058 85.7123490000000032 85.6988979999999998 85.6814650000000029 85.6802749999999946 85.6803210000000064 85.6803210000000064 85.6803210000000064
85.6826169999999934 85.6672820000000002 85.648415 85.6498789999999985 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6498109999999997 85.6500779999999935 85.6486739999999998 85.6449659999999966 85.6277390000000054 85.6171879999999987 85.6184230000000071 85.6194760000000059 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953
+101.9644849999999963 101.4378200000000021 100.699860000000001 100.1670150000000064 100.1538089999999954 100.5157169999999951 100.6503749999999968 100.7527690000000007 101.1999660000000034 101.6263050000000021 101.8570179999999965 102.0259170000000069 102.2716750000000019 102.6075670000000031 102.8452680000000043 103.061797999999996 103.3264010000000042 103.5529480000000007 103.8640290000000022 103.9528269999999992 103.7181630000000041 103.3362730000000056 102.6044389999999993 101.9557570000000055 101.675690000000003 101.8050159999999948 102.3361210000000057 102.5073170000000005 102.9393769999999932 103.6621549999999985 104.3529359999999997 105.0314869999999985 105.3917919999999953 105.6750789999999967 105.9826280000000054 106.3572240000000022 106.7020109999999988 106.976585 107.1743320000000068 107.225594000000001 107.1568070000000006 107.0456769999999977 106.8040239999999983 106.4300000000000068 105.8943179999999984 105.0125500000000045 103.6319199999999938 102.438828000000
0009 102.2805330000000055 102.6573869999999999 102.7756880000000024 102.7534789999999987 103.3748250000000013 104.7235490000000055 106.0473329999999947 107.1134409999999946 107.922309999999996 108.4034500000000065 108.5791930000000036 108.5030820000000062 108.2711110000000048 107.9139330000000001 107.395354999999995 106.9172130000000038 106.6118699999999961 106.2997210000000052 105.9757230000000021 105.693641999999997 105.4152600000000035 105.1940919999999977 104.8698349999999948 104.6255259999999936 104.6911159999999938 105.3477550000000065 105.9067840000000018 105.9867550000000023 105.9669339999999949 105.7583470000000005 105.3338849999999951 104.8520740000000018 104.4022290000000055 104.0515900000000045 103.5244670000000013 102.784546000000006 102.2938000000000045 102.054901000000001 101.4800570000000022 100.7833940000000013 101.0745009999999979 101.0662460000000067 100.5079960000000057 99.9179610000000054 99.0797040000000067 97.960999000000001 97.220130999999995 97.20207
20000000011 97.2747880000000009 97.7208250000000049 98.2740019999999959 98.5400089999999977 98.7623439999999988 98.7481310000000008 98.8411409999999933 98.8165659999999946 98.7726439999999997 98.8556059999999945 98.8950729999999965 98.8975369999999998 98.9269489999999934 98.9761960000000016 99.0078960000000023 99.0215840000000043 99.007866000000007 99.0739590000000021 99.125945999999999 99.0987400000000065 99.0437320000000057 98.9245300000000043 98.7867049999999978 98.5995939999999962 98.1413880000000063 97.6244429999999994 97.1605380000000025 96.9901200000000046 97.2393339999999995 97.5153269999999992 97.9930880000000002 98.4833909999999975 98.5705719999999985 98.1825410000000005 97.5869450000000001 97.220366999999996 96.9679179999999974 96.6974790000000013 96.352753000000007 95.9475860000000011 95.6315610000000049 95.4596410000000049 95.2669750000000022 94.9917449999999945 94.7641449999999992 94.5426029999999997 94.4363859999999988 94.5740279999999984 94.9103779999999944 9
5.0718990000000019 94.7587130000000002 94.1097720000000066 93.304657000000006 92.5515290000000022 91.0723799999999954 88.2563710000000015 86.2901920000000047 85.7588650000000001 85.7479859999999974 85.7481690000000043 85.7665329999999955 85.7952959999999933 85.7155759999999987 86.044990999999996 87.0436779999999999 87.2379300000000057 86.2425989999999985 85.7025759999999934 85.7333220000000011 85.7413250000000033 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7428510000000017 85.7340849999999932 85.7137369999999947 85.7107010000000002 85.7108230000000049 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7107929999999953 85.7121429999999975 85.7064670000000035 85.6846769999999935 85.6801379999999995 85.6803359999999969 85.6803210000000064 85.680321000
0000064 85.6824869999999947 85.6681820000000016 85.6496510000000058 85.6496889999999951 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.649840999999995 85.6498109999999997 85.6501010000000065 85.6490550000000042 85.6351319999999987 85.625031000000007 85.619101999999998 85.6191100000000063 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953
+101.9797059999999931 101.3194430000000068 100.4173129999999929 99.7910229999999956 99.8813549999999992 100.1562650000000048 100.3294910000000044 100.6871110000000016 101.0949779999999976 101.5025250000000057 101.700798000000006 101.723236 101.9072340000000025 102.1739879999999943 102.3474199999999996 102.4895549999999957 102.7953949999999992 103.0123829999999998 103.3168869999999941 103.5043409999999966 103.1590039999999959 102.4694140000000004 101.7773739999999947 101.3840560000000011 101.1713409999999982 101.2001269999999948 101.8884740000000022 102.2978360000000038 102.4946209999999951 103.1790309999999948 103.8613430000000051 104.4242859999999951 104.7966160000000002 105.1340480000000071 105.5053560000000061 105.8054580000000016 106.0715409999999963 106.3255920000000003 106.6433260000000018 106.8389739999999932 106.8998870000000068 106.8615800000000036 106.5421680000000038 106.1553190000000058 105.6991880000000066 104.8653410000000008 103.5162579999999934 102.30447399999
9999 101.9669800000000066 102.0593489999999974 102.0810929999999956 102.1831590000000034 102.8914259999999956 104.1868670000000066 105.4750520000000051 106.5154569999999978 107.3808750000000032 107.9615859999999969 108.0864030000000042 107.9652559999999966 107.7624509999999987 107.4518889999999942 106.9826510000000042 106.4904400000000066 106.1746370000000042 105.8789670000000029 105.5886079999999936 105.3470379999999977 105.0119250000000051 104.7290339999999986 104.4208760000000069 104.2329710000000063 104.2855150000000037 104.7734530000000035 105.5113979999999998 105.5736160000000012 105.4323880000000031 105.1635279999999995 104.747437000000005 104.4785770000000014 104.1705469999999991 103.7142939999999953 103.0906679999999938 102.338318000000001 101.9253850000000057 101.7425690000000031 101.2762680000000017 100.4483570000000014 100.5961460000000045 100.7873000000000019 100.3329769999999996 99.7750779999999935 99.2254329999999953 98.5327840000000066 98.1090470000000039 98.
2214890000000054 98.3879170000000016 98.3970570000000038 98.3184739999999948 98.2712329999999952 98.3991549999999933 98.5088879999999989 98.6146930000000026 98.5768049999999931 98.5415040000000033 98.6193849999999941 98.7215350000000029 98.7160109999999946 98.6472629999999953 98.6757889999999946 98.7058559999999972 98.766846000000001 98.8578799999999944 98.8966900000000066 98.7899170000000026 98.6100390000000004 98.4666519999999963 98.3630519999999962 98.3180849999999964 98.1478579999999994 97.6771619999999956 97.2415620000000018 96.8728490000000022 96.6156160000000028 96.8702770000000015 97.1993030000000005 97.6473620000000011 98.0658420000000035 98.200562000000005 97.9896849999999944 97.5172270000000054 97.1148680000000013 96.8159260000000046 96.5446239999999989 96.2758330000000058 95.9074250000000035 95.4916529999999995 95.0562589999999972 94.6766740000000055 94.3301539999999932 94.1131129999999985 94.0916670000000011 94.059119999999993 94.0468900000000048 94.265656000000
007 94.3714829999999978 94.2143549999999976 93.9019619999999975 93.4192050000000052 92.8553310000000067 91.8858800000000002 90.1529160000000047 88.2967989999999929 86.693877999999998 85.9760440000000017 85.8981780000000015 85.9023439999999994 86.2153930000000059 86.5580980000000011 87.4578089999999975 88.1585010000000011 87.8635409999999979 86.7650909999999982 85.7630840000000063 85.702849999999998 85.7416690000000017 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7417829999999981 85.7408219999999943 85.7234650000000045 85.7112809999999996 85.7105260000000015 85.7107620000000026 85.7108149999999966 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7111819999999938 85.7105559999999969 85.6947629999999947 85.6813279999999935 85.680144999999996 85.6803440000000052 85.68032
10000000064 85.6809690000000046 85.677773000000002 85.6564330000000069 85.6484300000000047 85.6498639999999938 85.649840999999995 85.649840999999995 85.649840999999995 85.6498339999999985 85.6499179999999996 85.650383000000005 85.6505659999999978 85.6392589999999956 85.6180800000000062 85.6171949999999953 85.619133000000005 85.6193920000000048 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.619324000000006
+101.8243480000000005 101.1584320000000048 100.1720959999999963 99.4501800000000031 99.4601519999999937 99.704063000000005 100.0471270000000032 100.5950090000000046 100.9933400000000034 101.2536620000000056 101.4650189999999981 101.5208509999999933 101.6437760000000026 101.8112720000000024 101.8647689999999955 101.972014999999999 102.2461469999999935 102.5014039999999937 102.9013520000000028 103.1292339999999967 102.6185380000000009 101.5273279999999971 100.7031020000000012 100.4040300000000059 100.2892530000000022 100.3476100000000031 101.2554090000000002 102.0592189999999988 102.2034840000000031 102.7653880000000015 103.3875050000000044 103.8450780000000009 104.2582400000000007 104.5882569999999987 104.9926070000000067 105.3538060000000058 105.5740049999999997 105.8140410000000031 106.2019959999999941 106.4996639999999957 106.5624849999999952 106.4871140000000054 106.2429499999999933 105.9400710000000032 105.5355830000000026 104.726776000000001 103.498619000000005 102.23361
19999999937 101.642548000000005 101.4941249999999968 101.4006729999999976 101.6115649999999988 102.4030759999999987 103.541175999999993 104.727530999999999 105.7984009999999984 106.6747969999999981 107.2739409999999936 107.4800950000000057 107.4887920000000037 107.3151629999999983 106.999488999999997 106.6057359999999932 106.0840989999999948 105.6534879999999958 105.2635800000000046 104.8966520000000031 104.6078409999999934 104.3375779999999935 104.1239240000000024 103.9271389999999968 103.8897400000000033 104.0197749999999957 104.1376190000000008 104.8138349999999974 105.0211110000000048 104.8489610000000027 104.596344000000002 104.1711119999999937 103.9336619999999982 103.7181700000000006 103.1692500000000052 102.537391999999997 101.9781190000000066 101.5647050000000036 101.2490080000000034 100.8586039999999997 100.1548229999999933 100.0384750000000054 100.0685650000000066 99.7813569999999999 99.4413990000000041 99.2107469999999978 98.9792249999999996 98.8397980000000018 9
8.5164259999999956 97.8917309999999929 97.7096180000000061 97.8871000000000038 98.2214280000000031 98.5335620000000034 98.8155440000000027 99.117912000000004 99.1201169999999934 98.9253389999999939 98.8375400000000042 98.8135300000000001 98.6285780000000045 98.2298739999999952 98.0752719999999982 98.0444410000000062 98.1064910000000054 98.257866000000007 98.298332000000002 98.189384000000004 98.0911329999999992 98.0209579999999931 97.9271320000000003 97.8631519999999995 97.678496999999993 97.3036649999999952 96.9537890000000004 96.5932619999999957 96.2872540000000043 96.5518339999999995 96.9072879999999941 97.2018659999999954 97.5948719999999952 97.7195889999999991 97.5272599999999983 97.0510709999999932 96.5633239999999944 96.2794489999999996 96.039032000000006 95.8054350000000028 95.5725779999999929 95.2717439999999982 94.8627319999999941 94.4532470000000046 94.0394440000000031 93.6932529999999986 93.6107180000000056 93.5154040000000037 93.3508829999999961 93.5316009999999
949 93.6798710000000057 93.4491960000000006 93.1034159999999957 92.7492369999999937 92.3719099999999997 91.7351840000000038 90.8390500000000003 90.0507580000000019 88.8611300000000028 87.7577440000000024 87.5727920000000069 87.6014859999999942 87.8732300000000066 88.1475599999999986 88.618155999999999 88.605994999999993 87.9767460000000057 86.789985999999999 85.7880710000000022 85.7022400000000033 85.7415919999999971 85.741271999999995 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412410000000023 85.7421719999999965 85.7411270000000059 85.718757999999994 85.7112809999999996 85.7109379999999987 85.7106169999999992 85.7107929999999953 85.7108080000000001 85.7108080000000001 85.7107620000000026 85.7116319999999945 85.7115940000000052 85.6905749999999955 85.6802370000000053 85.6802140000000065 85.6803210
000000064 85.6802220000000005 85.6821209999999951 85.6646499999999946 85.6480410000000063 85.6497339999999951 85.649840999999995 85.649840999999995 85.649840999999995 85.6498870000000068 85.6494900000000001 85.6490019999999959 85.6440350000000024 85.6211320000000029 85.6184619999999938 85.6194610000000011 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193470000000048 85.6194459999999964 85.6199869999999947
+101.4781720000000007 100.8873059999999953 100.0132899999999978 99.3423460000000063 99.1212620000000015 99.3753430000000009 99.929717999999994 100.4483720000000062 100.7963259999999934 100.9164200000000022 101.1069559999999967 101.2876430000000028 101.3318249999999949 101.3987809999999996 101.443634000000003 101.4980010000000021 101.6999969999999962 102.0286640000000062 102.4738920000000064 102.6089549999999946 102.0022280000000023 100.7958449999999999 99.8062900000000042 99.4123759999999947 99.4555509999999998 99.9393390000000039 100.9394300000000015 101.753783999999996 101.9895779999999945 102.3182599999999951 102.8145600000000002 103.2900389999999931 103.7117310000000003 103.9832459999999941 104.3967130000000054 104.8546070000000014 105.1468660000000028 105.4285430000000048 105.7935559999999953 106.0817339999999973 106.1092220000000026 106.0360639999999961 105.9105529999999931 105.7188799999999986 105.3292540000000059 104.6597600000000057 103.7823939999999965 102.656136000
0000036 101.5904079999999965 101.0466689999999943 100.9632339999999999 101.1412890000000004 101.8071369999999973 102.7745359999999977 103.9074549999999988 105.0501170000000002 105.9073029999999989 106.4359510000000029 106.7538760000000053 106.9456330000000008 106.8536069999999967 106.5992360000000048 106.2624279999999999 105.7138369999999981 105.0744930000000039 104.4485320000000002 103.7364039999999932 103.0122680000000059 102.6513520000000028 102.6748730000000052 102.9904789999999934 103.5212020000000024 103.8090590000000049 103.6272430000000071 104.0540699999999958 104.2666470000000061 104.2508009999999956 104.0627520000000032 103.6446080000000052 103.3521879999999982 103.0085299999999933 102.4301909999999936 101.8041690000000017 101.319587999999996 100.8921660000000031 100.5590820000000036 100.2988359999999943 99.9781650000000042 99.812743999999995 99.6340639999999951 99.5493390000000034 99.4416279999999944 99.2265170000000012 98.9681929999999994 98.7706909999999993 98.1
048660000000012 96.3731460000000055 96.2746120000000047 97.6070629999999966 98.3962630000000047 98.6757350000000031 98.9614030000000042 99.2913819999999987 99.2671809999999937 98.9559560000000005 98.7727200000000067 98.6901859999999971 98.3957900000000052 97.846619000000004 97.6617889999999989 97.5737529999999964 97.5220259999999968 97.6488269999999972 97.7144090000000034 97.6823729999999983 97.5311509999999942 97.4526209999999935 97.4215769999999992 97.3376849999999934 97.1721650000000068 96.8797840000000008 96.5621340000000004 96.1950149999999979 95.8319240000000008 96.1132510000000053 96.5618359999999996 96.8484119999999962 97.1975709999999964 97.317931999999999 97.0625760000000071 96.4589160000000021 95.9128269999999929 95.6201930000000004 95.3679730000000063 95.1239010000000036 94.8916090000000025 94.660576000000006 94.3974079999999987 94.0936810000000037 93.8072970000000055 93.4728929999999991 93.2504200000000054 93.1598359999999985 92.9963300000000004 93.0405039999999
985 93.1883619999999979 92.8124080000000049 92.292357999999993 91.9504239999999982 91.672828999999993 91.2745359999999977 90.7637940000000043 90.4387360000000058 90.1807249999999954 89.6936869999999971 89.4827420000000018 89.4019930000000045 89.208281999999997 88.9609530000000035 88.8423839999999956 88.6141889999999961 87.807579000000004 86.3794330000000059 85.6905289999999979 85.7237700000000018 85.741973999999999 85.7414320000000032 85.7412410000000023 85.741264000000001 85.741264000000001 85.741264000000001 85.7412570000000045 85.7412800000000033 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412410000000023 85.742241000000007 85.7364809999999977 85.7257079999999974 85.7151949999999943 85.7108309999999989 85.7108460000000036 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7107539999999943 85.7116999999999933 85.7088849999999951 85.6855390000000057 85.6790919999999971 85.68032800000
00029 85.6803210000000064 85.6807709999999929 85.6734620000000007 85.6532590000000056 85.6486969999999985 85.6498490000000032 85.649840999999995 85.649840999999995 85.6502760000000052 85.6466290000000043 85.6347049999999967 85.6246869999999944 85.6187209999999936 85.6194380000000024 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6194760000000059 85.619300999999993 85.6184010000000058
+101.0968170000000015 100.5809169999999995 99.8915410000000037 99.2694699999999983 98.8397599999999983 99.1837689999999981 99.8124009999999942 100.2343369999999965 100.4811169999999976 100.5502780000000058 100.7303770000000043 100.9767910000000057 101.0248490000000032 100.9937209999999936 101.0856249999999932 101.0890959999999978 101.2347029999999961 101.6190260000000052 102.0075230000000062 102.0607150000000019 101.4988249999999965 100.4414600000000064 99.4939880000000016 99.1731570000000033 99.3909230000000008 100.0063480000000027 100.738433999999998 101.3817370000000011 101.7105030000000028 101.9039460000000048 102.2442860000000024 102.7038040000000052 103.0908969999999982 103.3889920000000018 103.801361 104.2461009999999959 104.5516199999999998 104.8069689999999952 105.1740719999999953 105.4379200000000054 105.4862059999999957 105.5243150000000014 105.460205000000002 105.2993239999999986 105.0398100000000028 104.5914539999999988 104.028648000000004 103.3214109999999977 10
2.0879750000000001 101.0055619999999976 100.7842859999999945 100.9165339999999986 101.2972639999999984 102.005439999999993 103.0235600000000034 104.2079090000000008 105.0902789999999953 105.611030999999997 105.9951549999999969 106.2888339999999943 106.3423389999999955 106.1949010000000015 105.8793490000000048 105.3372729999999962 104.6172789999999964 103.8568340000000063 102.8694689999999952 101.6578290000000067 100.9700930000000056 101.2043689999999998 102.0770870000000059 103.1715470000000039 103.5626299999999986 103.1731719999999939 103.4749369999999971 103.7439880000000016 103.6551900000000046 103.334969000000001 102.8258900000000011 102.3735960000000063 101.9037399999999991 101.437072999999998 100.9977650000000011 100.6366960000000006 100.312065000000004 100.0966719999999981 99.9766850000000034 99.8716430000000059 99.716431 99.5461580000000055 99.4671249999999958 99.3249050000000011 99.0669709999999952 98.8283540000000045 98.5610889999999955 97.8241809999999958 95.77680
99999999976 95.480827000000005 97.287871999999993 98.5063930000000028 98.8289489999999944 98.927031999999997 99.062775000000002 98.9526290000000017 98.682311999999996 98.6026150000000001 98.590453999999994 98.2512509999999963 97.557075999999995 97.3926620000000014 97.3640979999999985 97.1440659999999951 97.0858379999999954 97.0561979999999949 97.0100479999999976 96.8375020000000006 96.7961880000000008 96.751648000000003 96.6381910000000062 96.4732740000000035 96.1554179999999974 95.8111949999999979 95.3981169999999992 95.0442500000000052 95.3017580000000066 95.9140780000000035 96.4079739999999958 96.7866130000000027 96.9639430000000004 96.6295700000000011 95.8735580000000027 95.3422549999999944 95.0154270000000025 94.7675320000000028 94.5580669999999941 94.3176119999999969 94.0657269999999954 93.8307420000000008 93.597297999999995 93.3682560000000024 93.0605929999999972 92.8936309999999992 92.9157029999999935 92.8907849999999939 92.889647999999994 92.8253019999999935 92.3604
809999999929 91.7321319999999929 91.361298000000005 91.1502299999999934 90.8504939999999976 90.4728620000000063 90.1701050000000066 90.1647799999999933 90.0961379999999963 89.9179380000000066 89.574852000000007 89.2158739999999995 89.1374820000000057 88.8979640000000018 88.328125 87.4086460000000045 86.0124969999999962 85.6464390000000009 85.7570649999999972 85.7583999999999946 85.7467579999999998 85.7404099999999971 85.7414399999999972 85.7414780000000007 85.7415160000000043 85.7415699999999958 85.7413559999999961 85.7412570000000045 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412570000000045 85.7415539999999936 85.7410959999999989 85.7325519999999983 85.7227100000000064 85.7125400000000042 85.7107850000000013 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7107539999999943 85.7121120000000047 85.693641999999997 85.6782989999999955 85.6802600000000041 85.6803210000000064 85.680274
9999999946 85.6797940000000011 85.6600420000000042 85.6480099999999993 85.6497959999999949 85.649840999999995 85.649840999999995 85.6505810000000025 85.6441350000000057 85.6220019999999948 85.618155999999999 85.6193700000000035 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193849999999941 85.6200099999999935 85.6149979999999999 85.6031339999999972
+100.7548900000000032 100.3318249999999949 99.732239000000007 99.0178219999999953 98.5649109999999951 99.006134000000003 99.622596999999999 99.9599460000000022 100.1233670000000018 100.1666490000000067 100.322181999999998 100.5277789999999953 100.5783389999999997 100.5691300000000012 100.7021639999999962 100.7242049999999978 100.8615190000000013 101.2190549999999973 101.5767589999999956 101.6415559999999942 101.1541289999999975 100.2742230000000063 99.4479979999999983 99.0961910000000046 99.2747499999999974 99.8189160000000015 100.3867419999999981 100.9338759999999979 101.2608570000000014 101.4400789999999972 101.7427979999999934 102.155579000000003 102.4512179999999972 102.8264539999999982 103.2529830000000004 103.5983729999999952 103.8724670000000003 104.0909649999999971 104.3899080000000055 104.6253430000000009 104.7566989999999976 104.9099659999999972 104.8601460000000003 104.7125170000000054 104.5992970000000071 104.4099580000000032 104.0619279999999947 103.5966800000000
063 102.6483149999999966 101.2895359999999982 100.604896999999994 100.6830750000000023 100.9049990000000037 101.3307039999999972 102.0848540000000071 103.2062070000000062 104.1262049999999988 104.6625669999999957 105.1121980000000065 105.5536960000000022 105.7798080000000027 105.7140880000000038 105.4087300000000056 104.9061509999999942 104.265900000000002 103.5125730000000033 102.4733729999999952 101.1505200000000002 100.3093570000000057 100.6539539999999988 101.7684560000000005 102.9402469999999994 103.2768860000000046 102.7325440000000043 102.7985379999999935 103.0189359999999965 102.7263109999999955 102.2150649999999956 101.7131580000000071 101.262084999999999 101.0080030000000022 100.7935030000000012 100.5506129999999985 100.3020020000000017 99.9874650000000003 99.682495000000003 99.5485460000000018 99.4987560000000002 99.2639010000000042 99.1241610000000009 99.050933999999998 98.8850170000000048 98.7033310000000057 98.5359040000000022 98.2530589999999933 97.45607800000
00051 95.4398570000000035 94.8897929999999974 96.4742580000000061 98.0799099999999981 98.7574160000000063 98.7848209999999938 98.7158510000000007 98.5816879999999998 98.3249509999999987 98.2594600000000042 98.2554090000000002 97.820282000000006 97.2494429999999994 97.1921540000000022 97.1591420000000028 96.9733889999999974 96.6915659999999946 96.4206920000000025 96.3303760000000011 96.3267290000000003 96.3128360000000043 96.0860600000000034 95.8233029999999957 95.5939560000000057 95.160224999999997 94.7155379999999951 94.2877119999999991 93.9653019999999941 94.249968999999993 95.0927279999999939 95.804633999999993 96.2570419999999984 96.4413299999999936 96.0997090000000043 95.3627850000000024 94.8239970000000056 94.4997330000000062 94.2679820000000035 94.0344620000000049 93.8290410000000037 93.5857390000000038 93.3180689999999942 93.1198579999999936 92.913841000000005 92.5739520000000056 92.427306999999999 92.5274809999999945 92.6499940000000066 92.6818310000000025 92.494185
9999999991 92.0803300000000036 91.5602339999999941 91.1889340000000033 90.8661040000000071 90.5035019999999975 90.1141130000000032 89.8437119999999965 89.8162460000000067 89.8402329999999978 89.7811049999999966 89.4089969999999994 88.9606629999999967 88.8164289999999994 88.5275800000000004 87.8252939999999995 86.7272190000000052 85.7998809999999992 85.7414399999999972 85.7713779999999986 85.7720110000000062 85.7632449999999977 85.7537310000000019 85.7561489999999935 85.7560880000000054 85.7560579999999959 85.7569050000000033 85.7448650000000043 85.7403340000000043 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7413099999999986 85.7420120000000026 85.7413789999999949 85.7223280000000045 85.7112429999999961 85.7107850000000013 85.7108080000000001 85.7108080000000001 85.7108080000000001 85.7112269999999938 85.7025150000000053 85.6829450000000037 85.679374999999993
2 85.6803210000000064 85.6803210000000064 85.6799699999999973 85.6695330000000013 85.6516270000000048 85.6492389999999943 85.649840999999995 85.649840999999995 85.6504970000000014 85.6448440000000062 85.6236719999999991 85.6189349999999934 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193470000000048 85.6194380000000024 85.6196209999999951 85.6175539999999984 85.6006009999999975 85.5874330000000043
+100.5181120000000021 100.1214219999999955 99.4976429999999965 98.6874619999999965 98.4013209999999958 98.7795720000000017 99.3378450000000015 99.6421050000000008 99.766334999999998 99.8132480000000015 99.9286189999999976 100.0880970000000048 100.0981450000000024 100.1760479999999944 100.3217700000000008 100.4126969999999943 100.5731959999999958 100.8493119999999976 101.197417999999999 101.2490920000000045 100.7889179999999953 100.1024400000000014 99.3551029999999997 98.674744000000004 98.5595019999999948 99.2514950000000056 99.9162979999999976 100.3929059999999964 100.7023010000000056 100.9232789999999937 101.2557529999999986 101.6635359999999935 101.9445189999999997 102.2449260000000066 102.6059879999999964 102.9189910000000054 103.2446819999999974 103.4959869999999995 103.6144790000000029 103.807068000000001 104.0557249999999954 104.2817000000000007 104.306365999999997 104.2658459999999963 104.2288819999999987 104.1869279999999947 103.9355089999999961 103.5603100000000012
102.9453050000000047 101.6525039999999933 100.4428479999999979 100.254997000000003 100.4032749999999936 100.686119000000005 101.2407610000000062 102.1420289999999937 102.999061999999995 103.5960539999999952 104.3040079999999961 104.9687270000000012 105.1638870000000026 105.1251910000000009 104.8835909999999956 104.4765239999999977 103.9838029999999947 103.2558899999999937 102.1713330000000042 100.8414379999999966 100.0074460000000016 100.370238999999998 101.4996110000000016 102.5230710000000016 102.9046249999999958 102.368155999999999 102.056792999999999 101.9843599999999952 101.6899109999999951 101.3611369999999994 101.0674510000000055 100.8240279999999984 100.7299270000000035 100.6015469999999965 100.2828219999999959 99.9394070000000028 99.5810550000000063 99.1795039999999943 98.9151080000000036 98.8615259999999978 98.718781000000007 98.5718310000000031 98.568877999999998 98.4793549999999982 98.3549040000000048 98.1831889999999987 97.872130999999996 96.8347169999999977 95.
1470259999999968 95.0181500000000057 96.0906070000000057 97.3768769999999932 98.3377080000000063 98.5606989999999996 98.3633580000000052 98.0767060000000015 97.7290799999999962 97.6033170000000041 97.5108340000000027 97.0626139999999964 96.8276520000000005 96.7790760000000034 96.3449169999999953 96.495948999999996 96.5111619999999988 96.0853199999999958 95.9895400000000052 96.058250000000001 95.9515150000000006 95.5647129999999976 95.0858920000000012 94.6960749999999933 94.2251820000000038 93.7730099999999993 93.3426819999999964 92.9908980000000014 93.3904650000000061 94.3869550000000004 95.1335679999999968 95.5852660000000043 95.775810000000007 95.511330000000001 94.8125150000000048 94.2797390000000064 93.9972080000000005 93.7493439999999936 93.5294880000000006 93.3403090000000049 93.1165770000000066 92.914124000000001 92.7428740000000005 92.4885940000000062 92.146049000000005 92.0413360000000011 92.1410369999999972 92.2636109999999974 92.3401870000000002 92.175849999999997
91.9065169999999938 91.5573499999999996 91.1711430000000007 90.7693710000000067 90.3350829999999974 89.9196929999999952 89.6566159999999996 89.507750999999999 89.4355319999999949 89.4308319999999952 89.1539149999999978 88.6042400000000043 88.2300639999999987 87.8758389999999991 87.0874859999999984 86.0667190000000062 85.7170179999999959 85.7709200000000038 85.7718200000000053 85.7718279999999993 85.7714079999999939 85.7709880000000027 85.7711330000000061 85.7711639999999989 85.7712020000000024 85.7709729999999979 85.7616349999999983 85.7513660000000044 85.7426379999999995 85.7411040000000071 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7420429999999953 85.7399750000000012 85.7177350000000047 85.7102660000000043 85.7108000000000061 85.7108080000000001 85.7108080000000001 85.7108000000000061 85.709534000000005 85.6891399999999948 85.6784210000000002 85.6803050
000000042 85.6803210000000064 85.680412000000004 85.6774669999999929 85.6566159999999996 85.6487120000000033 85.6498339999999985 85.649840999999995 85.6504970000000014 85.6445769999999982 85.6238019999999977 85.6190339999999992 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193540000000013 85.6194610000000011 85.6189650000000029 85.6173480000000069 85.6045230000000004 85.587851999999998 85.5885389999999973
+100.3973540000000071 99.9608609999999942 99.3192520000000059 98.5409470000000027 98.2980119999999999 98.5947570000000013 99.068877999999998 99.3148419999999987 99.4310459999999949 99.4572749999999957 99.5664979999999957 99.831505000000007 99.9802930000000032 100.0624239999999929 100.0943680000000029 100.1455990000000043 100.2772369999999995 100.487922999999995 100.7923279999999977 100.8125990000000058 100.393929 99.8930820000000068 99.2277150000000034 98.3830870000000033 97.9613719999999972 98.595909000000006 99.3540339999999986 99.8524089999999944 100.2236939999999947 100.4720310000000012 100.7736969999999985 101.1139139999999941 101.459259000000003 101.6282350000000037 101.8941959999999938 102.2295610000000039 102.5294569999999936 102.7133409999999998 102.7499159999999989 102.9687650000000048 103.3191829999999953 103.6643679999999961 103.8400800000000004 103.8717120000000023 103.8708110000000033 103.8409500000000065 103.6886140000000012 103.440804 103.0145569999999964 102.
0485460000000018 100.620079000000004 99.8719940000000008 99.7447360000000032 99.9113080000000053 100.3071209999999951 100.9657140000000055 101.7429659999999956 102.5314180000000022 103.6200489999999945 104.4825440000000043 104.5471339999999998 104.4808500000000038 104.3140340000000066 103.9326549999999969 103.5174939999999992 103.0155110000000036 102.0506359999999972 100.5367889999999989 99.593742000000006 99.9849849999999947 101.0603179999999952 101.8899310000000042 102.3222049999999967 102.0137789999999995 101.5036470000000008 101.3804779999999965 101.3160709999999938 101.1572419999999966 100.8515699999999953 100.5577159999999992 100.3112950000000012 100.1854479999999938 100.0100939999999952 99.6257779999999968 99.1671220000000062 98.7790990000000022 98.4071809999999942 98.1766740000000055 98.1743009999999998 98.1255340000000018 98.1081700000000012 98.0341260000000005 97.8784100000000024 97.6649479999999954 97.3010560000000027 96.1977229999999963 95.089934999999997 95.4978
490000000022 96.0043560000000014 96.910224999999997 97.945091000000005 98.2417530000000028 97.9586720000000071 97.4045789999999982 96.9259639999999933 96.818450999999996 96.6865159999999975 96.3844529999999935 96.1877900000000068 95.9486849999999976 95.2193450000000041 95.4584880000000027 95.9661640000000062 95.7509000000000015 95.687531000000007 95.6683809999999966 95.4522479999999973 94.9970469999999949 94.4356839999999949 93.9445950000000067 93.4815750000000065 93.1109239999999971 92.6750109999999978 92.2840190000000007 92.7176209999999941 93.7106320000000039 94.4496379999999931 94.8935390000000041 95.095207000000002 94.8768230000000017 94.1603929999999991 93.5896000000000043 93.3414690000000036 93.1453779999999938 92.9771039999999971 92.8174060000000054 92.6290130000000005 92.4804919999999981 92.3156429999999943 92.0187990000000013 91.7761990000000054 91.7504880000000043 91.7462689999999981 91.7792819999999949 91.8991850000000028 91.8368069999999932 91.6380460000000028 9
1.3214260000000024 90.9441759999999988 90.6841579999999965 90.3177639999999968 89.8888019999999983 89.5955809999999957 89.3430630000000008 89.1008219999999937 89.0439149999999984 88.7504809999999935 88.1754990000000021 87.767273000000003 87.2182009999999934 86.316474999999997 85.7838289999999972 85.7728270000000066 85.7730480000000028 85.770622000000003 85.7717059999999947 85.7717970000000065 85.7718430000000041 85.7718279999999993 85.7718200000000053 85.7718200000000053 85.7717899999999958 85.7715069999999997 85.7702940000000069 85.7531589999999966 85.7409739999999942 85.7410129999999953 85.7413180000000068 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7413099999999986 85.7420350000000013 85.7366329999999977 85.7131650000000036 85.7099910000000023 85.7108149999999966 85.7108080000000001 85.7108080000000001 85.7103039999999936 85.698204000000004 85.6808929999999975 85.6799469999999985 85.68032100000
00064 85.6803510000000017 85.6794969999999978 85.6659930000000003 85.6509089999999986 85.6496960000000058 85.649840999999995 85.6501010000000065 85.6489940000000018 85.6336289999999991 85.620238999999998 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6194150000000036 85.620270000000005 85.6121749999999935 85.6002040000000051 85.5908359999999959 85.5880970000000048 85.5889130000000051
+100.2195279999999968 99.8046039999999977 99.2628629999999958 98.5709300000000042 98.1088179999999994 98.3658290000000051 98.8533549999999934 99.0934139999999957 99.1769259999999946 99.0860669999999999 99.1591420000000028 99.5818710000000067 99.923798000000005 99.9833909999999975 99.9248580000000004 99.8965610000000055 99.9353100000000012 100.0605240000000009 100.3102800000000059 100.3700489999999945 100.0236660000000057 99.5941700000000054 98.9606320000000039 98.1551589999999976 97.6829379999999929 98.081665000000001 98.8485490000000055 99.4812009999999987 99.916877999999997 100.1509700000000009 100.3662410000000023 100.5604859999999974 100.880943000000002 101.0317229999999995 101.255675999999994 101.4871669999999995 101.5812760000000026 101.722808999999998 101.839775000000003 102.1043849999999935 102.5127939999999995 102.9580610000000007 103.2849960000000067 103.3625030000000038 103.4442829999999987 103.4447329999999994 103.3588709999999935 103.2347489999999937 102.91411600
0000007 102.2848589999999973 101.0573270000000008 99.818207000000001 99.1940380000000062 99.1573410000000024 99.3807220000000058 99.8490749999999991 100.6688460000000021 101.7502900000000068 102.9854739999999964 103.7996600000000029 103.8765559999999937 103.819312999999994 103.6804499999999933 103.3049239999999998 103.0100170000000048 102.8056339999999977 102.105316000000002 100.3970410000000015 99.1672820000000002 99.4834519999999998 100.4287340000000057 101.1731259999999963 101.614806999999999 101.5447010000000034 101.0655979999999943 100.9975199999999944 101.1958620000000053 100.9756009999999975 100.5675659999999993 100.145622000000003 99.7701490000000035 99.6864089999999976 99.7672349999999994 99.2077330000000046 98.4622339999999951 98.1351319999999987 97.9191890000000029 97.6380920000000003 97.6471939999999989 97.6589890000000054 97.6157230000000027 97.5153049999999979 97.2772290000000055 97.0984270000000009 96.674201999999994 95.453559999999996 94.2417530000000028 94.4
007950000000022 95.1045230000000004 96.2315830000000005 97.2308199999999943 97.5485690000000005 97.2988820000000061 96.6453400000000045 96.1153410000000008 96.038841000000005 95.9331279999999964 95.6968690000000066 95.3059010000000058 94.8909450000000021 94.3809360000000055 94.4807210000000026 94.992912000000004 95.1589969999999994 95.2683490000000006 95.1668470000000042 94.8614120000000014 94.4328229999999991 93.9663699999999977 93.4493870000000015 92.8859020000000015 92.4909360000000049 92.0806730000000044 91.7417219999999958 92.1174550000000067 92.9113540000000029 93.5808719999999994 94.0233920000000012 94.2269129999999961 94.0487140000000039 93.440612999999999 92.8928530000000023 92.6118089999999938 92.4467240000000032 92.3589709999999968 92.2679289999999952 92.1231920000000031 91.9527439999999956 91.7934570000000036 91.5555039999999991 91.4209519999999998 91.3980480000000028 91.2717059999999947 91.223747000000003 91.3318249999999949 91.3922879999999935 91.29144300000000
1 91.0274579999999958 90.763062000000005 90.5405729999999949 90.2202149999999961 89.7628780000000006 89.3821259999999995 89.0873789999999985 88.728508000000005 88.5558240000000012 88.3923029999999983 87.9371340000000004 87.2141649999999942 86.4196089999999941 85.8643040000000042 85.7956310000000002 85.7991099999999989 85.7884520000000066 85.780060000000006 85.7724230000000034 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7718430000000041 85.772521999999995 85.7676770000000062 85.7568210000000022 85.7460779999999971 85.7403489999999948 85.7413329999999974 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7413329999999974 85.7414250000000067 85.7315899999999971 85.710875999999999 85.7101439999999997 85.7108149999999966 85.7108080000000001 85.7108460000000036 85.7099299999999999 85.6957859999999982 85.6810530000000057 85.680228999999997
1 85.6803210000000064 85.6810679999999962 85.6749949999999956 85.6539149999999978 85.6495129999999989 85.649840999999995 85.649840999999995 85.6513060000000053 85.6435929999999956 85.6221010000000007 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193770000000001 85.6201099999999968 85.6172870000000046 85.5951000000000022 85.587799000000004 85.588752999999997 85.5889279999999957 85.5888900000000064
+99.9215389999999957 99.6098180000000042 99.2022019999999998 98.4991909999999962 97.7904209999999949 97.9130860000000069 98.5041279999999944 98.8887100000000032 98.9603199999999958 98.7437290000000019 98.7655029999999954 99.2314609999999959 99.5615310000000022 99.5886310000000066 99.5971600000000024 99.6859280000000041 99.7065120000000036 99.6748580000000004 99.8261799999999937 99.9046249999999958 99.6119159999999937 99.1166840000000064 98.3698650000000043 97.5590059999999966 97.3237610000000046 97.8209920000000039 98.5701370000000026 99.2740399999999994 99.7293240000000054 99.9934839999999951 100.138976999999997 100.176201000000006 100.3814770000000038 100.5302350000000047 100.6839449999999943 100.7304989999999947 100.6558990000000051 100.863624999999999 101.0746230000000025 101.3128509999999949 101.7408599999999979 102.2669829999999962 102.7963490000000064 103.0447690000000023 103.1209110000000067 103.0936360000000036 103.0310970000000026 102.9994659999999982 102.7415539999
999936 102.3190919999999977 101.459937999999994 100.1674119999999988 99.1628570000000025 98.8007130000000018 98.8224869999999953 99.1222989999999982 100.0400999999999954 101.3890379999999993 102.4194949999999977 102.953132999999994 103.1338879999999989 103.1697460000000035 103.0553359999999969 102.8466800000000063 102.8035050000000012 102.7078319999999962 102.1444019999999995 100.477753000000007 98.9242399999999975 98.8827210000000036 99.6253360000000043 100.4339829999999978 100.9097370000000069 101.0533449999999931 100.6702729999999946 100.4959949999999935 100.8701169999999934 100.6626210000000015 100.2277449999999988 99.823875000000001 99.4278340000000043 99.3081669999999974 99.2177510000000069 98.3916930000000036 97.6632689999999997 97.421843999999993 97.3311769999999967 97.1357959999999991 97.0683060000000069 97.2167740000000009 97.2516250000000042 97.1139679999999998 96.8885879999999986 96.7891919999999999 96.2231900000000024 94.8306500000000057 93.2439499999999981 92.6
735759999999971 93.5415189999999939 94.8426670000000058 95.9371569999999991 96.4586180000000013 96.3896100000000047 95.8792880000000025 95.4359819999999957 95.2876430000000028 95.1262820000000033 94.7976910000000004 94.3010479999999944 93.8673249999999939 93.6368870000000015 93.8479389999999967 94.2601010000000059 94.5589750000000038 94.8285220000000066 94.764008000000004 94.4825739999999996 94.1437609999999978 93.7617419999999981 93.133301000000003 92.3768160000000051 91.9247589999999946 91.5233690000000024 91.2264330000000001 91.5411150000000049 92.0963590000000067 92.6735379999999935 93.1277240000000006 93.3230439999999959 93.206474 92.7073060000000027 92.2655330000000049 91.9819260000000014 91.7861939999999947 91.8100199999999944 91.8038480000000021 91.6777040000000056 91.5032269999999954 91.2656020000000012 91.0037920000000042 90.9424360000000007 90.8689959999999957 90.625953999999993 90.5923540000000003 90.7595979999999969 90.8806229999999999 90.8670500000000061 90.724
4799999999998 90.5735549999999989 90.2988359999999943 89.9117810000000048 89.4427869999999956 89.0958559999999977 88.8049390000000045 88.4044719999999984 88.1700589999999949 87.9839860000000016 87.4683069999999958 86.5825040000000001 85.9191440000000028 85.7965930000000014 85.8028110000000055 85.8023910000000001 85.8027569999999997 85.7922590000000014 85.7718200000000053 85.7712169999999929 85.7718509999999981 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7718430000000041 85.7716060000000056 85.771300999999994 85.7638239999999996 85.7414469999999937 85.7404630000000054 85.7413329999999974 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412800000000033 85.7413329999999974 85.7403560000000056 85.7272190000000052 85.7101750000000067 85.7104420000000005 85.7108080000000001 85.7108149999999966 85.7116929999999968 85.7046739999999971 85.6836469999999935 85.6800690000000031 8
5.6803210000000064 85.6806789999999978 85.6790009999999995 85.6624369999999971 85.6504750000000001 85.649840999999995 85.649840999999995 85.6515050000000002 85.6418689999999998 85.6215210000000013 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6197970000000055 85.6188510000000065 85.599648000000002 85.5890809999999931 85.5888980000000004 85.5888900000000064 85.5888900000000064 85.5888900000000064
+99.6534960000000041 99.4876249999999942 99.1580510000000004 98.4414369999999934 97.5828089999999975 97.4338609999999932 98.0570909999999998 98.5819240000000008 98.6933209999999974 98.4192120000000017 98.4482799999999969 98.8507160000000056 99.0586550000000017 99.0988619999999969 99.1592100000000016 99.3683620000000047 99.4839939999999956 99.4081570000000028 99.4549030000000016 99.4434130000000067 99.0718379999999996 98.3622819999999933 97.4648820000000029 96.7753220000000027 96.9217909999999989 97.6648639999999943 98.5270919999999961 99.2362899999999968 99.636107999999993 99.9322810000000032 100.0954590000000053 100.0101549999999975 99.9697800000000001 100.019676000000004 100.1769100000000066 100.1596150000000023 100.1004099999999966 100.3200680000000062 100.4885709999999932 100.6695940000000036 101.1634980000000041 101.813477000000006 102.4956820000000022 102.8432459999999935 102.8154600000000016 102.7360460000000018 102.8057330000000036 102.7862630000000053 102.52027099999
99939 102.2344360000000023 101.7582859999999982 100.7342380000000048 99.5194850000000031 98.7659989999999937 98.5091400000000021 98.6805109999999956 99.630675999999994 101.0753559999999993 101.8866270000000043 102.198607999999993 102.4560089999999946 102.6376039999999961 102.5589070000000049 102.4473040000000026 102.521300999999994 102.4996260000000063 102.0584110000000067 100.6902469999999994 98.9248050000000063 98.2977910000000037 98.7466579999999965 99.6348270000000014 100.3060380000000009 100.5293429999999972 100.1434710000000052 99.9642180000000025 100.3630220000000008 100.3371350000000035 99.9322970000000055 99.5475229999999982 99.1366960000000006 98.8862689999999986 98.3936080000000004 97.5886459999999971 97.2338490000000064 97.0751719999999949 96.8497700000000066 96.4897160000000014 96.3497919999999937 96.6512680000000017 96.8112409999999954 96.7339860000000016 96.6042329999999936 96.4287570000000045 95.7632370000000037 94.5819469999999995 93.1714099999999945 92.1745
910000000066 92.3541560000000032 93.3178630000000027 94.5544510000000002 95.3273769999999985 95.459778 95.084075999999996 94.6263500000000022 94.3751830000000069 94.1751629999999977 93.8469159999999931 93.4216770000000025 93.0081859999999949 92.8527449999999988 93.2999729999999943 93.8828960000000023 94.1709749999999985 94.4351199999999977 94.4372180000000014 94.238624999999999 93.9492259999999959 93.5344769999999954 92.8330839999999995 92.0019379999999956 91.4965210000000013 91.0939330000000069 90.7391199999999998 90.9180829999999958 91.3674319999999938 91.8769149999999968 92.3620760000000018 92.5834049999999991 92.4547199999999947 92.0113070000000022 91.6562880000000035 91.4314040000000006 91.2261349999999993 91.2761079999999936 91.3249969999999962 91.2599330000000037 91.0888980000000004 90.727997000000002 90.4056929999999994 90.3595049999999986 90.2937239999999974 90.0431439999999981 90.0554659999999956 90.211937000000006 90.3012389999999954 90.3891749999999945 90.3491669
999999942 90.2101899999999972 89.936554000000001 89.5126419999999996 89.0259630000000044 88.6538699999999977 88.3385849999999948 88.0086979999999954 87.757758999999993 87.3608090000000033 86.7819980000000015 86.1673049999999989 85.820250999999999 85.8003539999999987 85.8022459999999967 85.8022770000000037 85.803719000000001 85.7973180000000042 85.7848429999999951 85.7745290000000011 85.7707290000000029 85.7718349999999958 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717509999999947 85.7718050000000005 85.7720489999999955 85.7713090000000022 85.7588810000000024 85.7398610000000048 85.7397919999999942 85.741187999999994 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7412869999999998 85.7413860000000057 85.7396999999999991 85.7243729999999999 85.7113039999999984 85.7107539999999943 85.7108080000000001 85.7112730000000056 85.7091829999999959 85.6917799999999943 85.6808010000000024 85.68032
10000000064 85.6803440000000052 85.6817250000000001 85.6731570000000033 85.6521680000000032 85.649840999999995 85.649840999999995 85.6505889999999965 85.6478419999999971 85.6293330000000026 85.6193999999999988 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6194760000000059 85.6192400000000049 85.603935000000007 85.5894849999999963 85.5888599999999968 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064
+99.2972409999999996 99.2518160000000051 99.0247119999999938 98.4939799999999934 97.7954330000000027 97.5108720000000062 97.9347690000000028 98.3599090000000018 98.3995510000000024 98.157630999999995 98.1571040000000039 98.3751139999999964 98.4338840000000062 98.5143130000000014 98.5538250000000033 98.6512910000000005 98.7527240000000006 98.8034820000000025 98.8253330000000005 98.7300110000000046 98.3048249999999939 97.579102000000006 96.8153080000000017 96.3946300000000065 96.7855220000000003 97.5783919999999938 98.550690000000003 99.233429000000001 99.4577259999999939 99.7135310000000032 99.9229200000000048 99.8420720000000017 99.582611 99.4820710000000048 99.6898649999999975 99.7551650000000052 99.7538909999999959 99.9216919999999931 100.0577320000000014 100.2815549999999973 100.8576280000000054 101.5458220000000011 102.1784059999999954 102.4389189999999985 102.395386000000002 102.3879699999999957 102.5457920000000058 102.4662550000000039 102.2334519999999998 102.093536000
0000003 101.9523010000000056 101.1497650000000021 99.7674329999999969 98.6576840000000033 98.1549610000000001 98.2609479999999991 99.0956950000000063 100.456230000000005 101.3166120000000063 101.6449659999999966 101.9483180000000004 102.202147999999994 102.1404650000000061 101.9836269999999985 102.0164340000000038 102.0586239999999947 101.8221589999999992 100.9329149999999942 99.1743850000000009 98.0045620000000071 98.0715789999999998 98.8475490000000008 99.5597000000000065 99.7020720000000011 99.4216770000000025 99.3683319999999952 99.6812060000000031 99.889008000000004 99.5566409999999991 99.0872650000000021 98.6711119999999937 98.3765029999999996 97.7932210000000026 97.1629640000000023 96.9376749999999987 96.6873779999999954 96.3297500000000042 95.8403849999999977 95.6993329999999958 95.9471889999999945 96.1975939999999952 96.2566149999999965 96.1625439999999969 95.914124000000001 95.2989120000000014 94.4008939999999939 93.3239209999999986 92.3082660000000033 91.805069000
0000031 92.2793810000000008 93.5215380000000067 94.405296000000007 94.5229029999999995 94.1126249999999942 93.5646969999999953 93.2870410000000021 93.1699299999999937 92.9836580000000055 92.6417919999999953 92.2120900000000034 92.1032490000000053 92.6659850000000063 93.4051209999999941 93.7860029999999938 94.0188600000000037 94.0765690000000063 93.9059220000000039 93.5578079999999943 93.009215999999995 92.3181380000000047 91.6200259999999957 91.1097340000000031 90.6970139999999958 90.3069380000000024 90.3429869999999937 90.7291110000000032 91.1208799999999997 91.5181350000000009 91.7413710000000009 91.6618270000000024 91.3452450000000056 91.0934910000000002 90.9167790000000053 90.7264940000000024 90.7331700000000012 90.763458 90.7141879999999929 90.582183999999998 90.2509230000000002 89.9840470000000039 89.9289700000000067 89.8760680000000036 89.8016130000000032 89.6869279999999947 89.6156689999999969 89.8509140000000031 90.0653149999999982 89.9626849999999934 89.78956599999
99936 89.427741999999995 88.9377589999999998 88.3637700000000024 87.8219220000000007 87.4017029999999977 87.1298680000000019 87.019157000000007 86.6305389999999989 86.1708299999999952 85.9168930000000017 85.8090289999999953 85.8020939999999968 85.8022459999999967 85.8022459999999967 85.8023910000000001 85.801604999999995 85.8007130000000018 85.7912290000000013 85.7704619999999949 85.7710110000000014 85.7718119999999971 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717439999999982 85.7718729999999994 85.7697069999999968 85.7576600000000013 85.7478490000000022 85.7412949999999938 85.741264000000001 85.7412869999999998 85.7412570000000045 85.7436979999999949 85.7303849999999983 85.721862999999999 85.7408520000000038 85.742676000000003 85.7341770000000025 85.7133029999999962 85.7106090000000052 85.7108080000000001 85.7108460000000036 85.7122339999999951 85.7028200000000027 85.6822130000000044 85.6803210000000064 85.68032100000
00064 85.6821819999999974 85.6717680000000001 85.6513369999999981 85.6498490000000032 85.649840999999995 85.6498870000000068 85.6516490000000061 85.6400450000000006 85.6195220000000035 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193619999999953 85.6193540000000013 85.6193159999999978 85.6080780000000061 85.5897980000000018 85.5885999999999996 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064
+98.8333659999999981 98.8253100000000018 98.7422870000000046 98.5066989999999976 98.1945419999999984 98.0313799999999986 98.1289670000000029 98.1964569999999952 98.1166840000000064 98.0456240000000037 97.9974140000000062 97.9431229999999999 97.8935390000000041 97.9034879999999958 97.9051589999999976 97.8711169999999981 97.8393549999999976 97.8680190000000039 97.8658449999999931 97.7880710000000022 97.5477750000000015 97.2753749999999968 97.0059969999999936 96.8567350000000005 97.1584550000000036 97.7424550000000067 98.4292760000000015 98.9193949999999944 99.0371700000000033 99.2716750000000019 99.5055009999999953 99.5390469999999965 99.3731920000000031 99.1899190000000033 99.2121580000000023 99.3065339999999992 99.3034739999999942 99.4248960000000039 99.7349090000000018 100.1586149999999975 100.7212449999999961 101.3099820000000051 101.8468019999999967 102.0888439999999946 102.0872499999999974 102.0791399999999953 102.1204299999999989 102.0702440000000024 101.9683459999999968
101.945335 101.9004970000000014 101.2121429999999975 99.8440169999999938 98.5242609999999956 97.8350520000000046 97.8331600000000066 98.4393079999999969 99.6712650000000053 100.6547620000000052 101.113861 101.4915620000000018 101.7358250000000055 101.7622219999999942 101.634490999999997 101.609343999999993 101.6799620000000033 101.5767290000000003 100.9458240000000018 99.4321139999999986 98.314148000000003 98.2043689999999998 98.5268860000000046 98.8068920000000048 98.9265819999999962 98.9749759999999981 98.8171389999999974 98.9339070000000049 99.2739640000000065 99.0182039999999972 98.4469150000000042 97.9679260000000056 97.6556400000000053 97.2112500000000068 96.723479999999995 96.3986890000000045 96.0270610000000033 95.6860279999999932 95.3181529999999952 95.1963200000000001 95.4072110000000038 95.6646729999999934 95.7406770000000051 95.6321180000000055 95.3848950000000002 94.8408430000000067 94.119300999999993 93.2188110000000023 92.3023299999999978 91.5920639999999935
91.6281659999999931 92.7560419999999937 93.5776599999999945 93.5196459999999945 93.0444789999999955 92.4878999999999962 92.1842960000000033 92.0871659999999963 92.0046310000000034 91.7806700000000006 91.405579000000003 91.362671000000006 91.9227139999999991 92.5669170000000037 93.0036089999999973 93.3032460000000015 93.4297710000000023 93.2782440000000008 92.8553619999999995 92.2223429999999951 91.6019129999999961 91.095130999999995 90.6385649999999998 90.2276920000000047 89.9049150000000026 89.8562469999999962 90.1251139999999964 90.4209900000000033 90.7013400000000019 90.8833920000000006 90.9346079999999972 90.7520219999999966 90.5729599999999948 90.4667359999999974 90.3447720000000061 90.3164519999999982 90.2598880000000037 90.2239689999999968 90.167357999999993 89.9003450000000015 89.6157230000000027 89.4267040000000009 89.3434450000000027 89.3151699999999948 89.0726169999999939 89.0193560000000019 89.4091339999999946 89.7313309999999973 89.6614299999999957 89.4227139999
999991 88.8708879999999937 88.1203380000000038 87.3463289999999972 86.7361680000000064 86.3298489999999958 86.1783910000000049 86.2254099999999966 86.0483169999999973 85.841826999999995 85.8036349999999999 85.8029630000000054 85.8022919999999942 85.8022459999999967 85.8022459999999967 85.8022160000000014 85.8023910000000001 85.8028560000000056 85.8011470000000003 85.7862930000000006 85.7698290000000014 85.7712860000000035 85.7717739999999935 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7718119999999971 85.7709810000000061 85.7679899999999975 85.7480929999999972 85.7407230000000027 85.7413559999999961 85.7416000000000054 85.7272490000000005 85.8045730000000049 85.8239520000000056 85.7190860000000043 85.7482069999999936 85.738669999999999 85.7208789999999965 85.7111359999999962 85.7108080000000001 85.7108000000000061 85.7126240000000053 85.7032470000000046 85.6822590000000019 85.6803210000000064 85.6803210
000000064 85.6812359999999984 85.6775209999999987 85.6582949999999954 85.6497499999999974 85.649840999999995 85.6498339999999985 85.6520540000000068 85.639922999999996 85.619575999999995 85.6193619999999953 85.6193619999999953 85.6192860000000024 85.6196900000000056 85.6205599999999976 85.6121519999999947 85.5909269999999935 85.5882189999999952 85.5888669999999934 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064
+98.7520600000000002 98.7121730000000071 98.6232380000000006 98.4892880000000019 98.183205000000001 97.7750470000000007 97.6517869999999988 97.7506560000000064 97.8792040000000014 98.0343699999999956 98.0685119999999984 97.9634779999999949 97.9427259999999933 97.8953630000000032 97.8145829999999989 97.7218320000000062 97.6937180000000041 97.6034010000000052 97.5275960000000026 97.4179689999999994 97.1848219999999969 97.0308069999999958 97.0929490000000044 97.2375179999999943 97.4989319999999964 97.9265589999999975 98.2384490000000028 98.4696200000000061 98.6448900000000037 98.8734359999999981 99.1484760000000023 99.2825469999999939 99.2488479999999953 99.0232539999999943 98.7875140000000016 98.7826689999999985 98.8540500000000009 99.0680080000000061 99.5349199999999996 100.1345139999999958 100.6677779999999984 101.1059879999999964 101.5718920000000054 101.8886719999999997 101.9141620000000046 101.8719559999999973 101.7987899999999968 101.7878340000000037 101.7721559999999954
101.7523730000000057 101.6308899999999937 101.1033549999999934 99.9130099999999999 98.5660019999999975 97.6859819999999957 97.4813230000000033 97.8182680000000033 98.7804639999999949 99.8286209999999983 100.564819 100.9944610000000011 101.2266769999999951 101.4344860000000068 101.4914320000000032 101.359406000000007 101.2474749999999943 100.913605000000004 100.3030239999999935 99.3413699999999977 98.7188029999999941 98.4804149999999936 98.2201000000000022 98.2327650000000006 98.4681020000000018 98.6226429999999965 98.2759549999999962 98.1906199999999956 98.5686950000000053 98.3829269999999951 97.7417760000000015 97.1904069999999933 96.7905650000000009 96.3937990000000013 96.0236359999999962 95.6908109999999965 95.4027559999999966 95.1926040000000029 94.8801270000000017 94.6977459999999951 95.0025329999999997 95.2460399999999936 95.2273789999999991 95.075721999999999 94.7795720000000017 94.2552029999999945 93.6418989999999951 92.8888019999999983 92.0637049999999988 91.3747180
000000014 91.2700650000000024 92.1407389999999964 92.6902079999999984 92.4922559999999976 91.9859309999999937 91.4992369999999937 91.234382999999994 91.0810089999999946 90.9747469999999936 90.8015979999999985 90.5240170000000006 90.5761949999999985 91.0689849999999979 91.5585020000000043 91.9636459999999971 92.2909010000000052 92.422393999999997 92.3001629999999977 91.9078059999999937 91.3398899999999969 90.8015979999999985 90.4334640000000007 90.0990520000000004 89.7425080000000008 89.5531459999999981 89.481780999999998 89.5802379999999943 89.8223569999999967 90.1068039999999968 90.2998580000000004 90.3520659999999936 90.2134089999999986 90.1315919999999977 90.0629040000000032 90.0521320000000003 89.9702910000000031 89.7607730000000004 89.7631990000000002 89.721587999999997 89.5046009999999939 89.1182100000000048 88.7280200000000008 88.6163020000000046 88.5541000000000054 88.4391710000000018 88.591614000000007 88.9376979999999975 89.298530999999997 89.2913889999999952 88.93
82630000000063 88.2507480000000015 87.1865839999999963 86.348479999999995 85.9959719999999948 85.818450999999996 85.8108139999999935 85.8334499999999991 85.8400270000000063 85.8116380000000021 85.7988660000000039 85.8012240000000048 85.8022540000000049 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022229999999979 85.8024829999999952 85.8000179999999943 85.7827609999999936 85.769408999999996 85.7704619999999949 85.7717820000000017 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717899999999958 85.7722019999999929 85.7730030000000028 85.7666700000000048 85.7441560000000038 85.7404099999999971 85.7417140000000018 85.6739730000000037 86.0529099999999971 86.5333020000000062 85.8961939999999942 85.6639330000000001 85.7488940000000071 85.7323609999999974 85.7123030000000057 85.7108080000000001 85.7108080000000001 85.7128220000000027 85.7014539999999982 85.6812290000000019 85.6803510000000017 85
.6803210000000064 85.6804049999999933 85.6819689999999952 85.6694339999999954 85.649604999999994 85.649840999999995 85.649840999999995 85.6520160000000033 85.6398850000000067 85.6196209999999951 85.6193619999999953 85.6193619999999953 85.6201779999999957 85.6157070000000004 85.6078339999999969 85.5956039999999945 85.5878600000000063 85.5888209999999958 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064
+98.8219380000000029 98.7462309999999945 98.563170999999997 98.3440169999999938 97.8627170000000035 96.8656079999999946 96.4954149999999942 97.0869519999999966 97.6469879999999932 97.9531479999999988 98.1331629999999961 98.2845609999999965 98.3243870000000015 98.2315140000000042 98.0867389999999943 97.9427029999999945 97.8832239999999985 97.785492000000005 97.6966479999999962 97.4958879999999937 96.9259569999999968 96.2489549999999952 96.1002199999999931 96.3896100000000047 96.9416200000000003 97.6534580000000005 98.1442789999999974 98.3347399999999965 98.5240780000000029 98.7082520000000017 98.9469760000000065 99.039092999999994 98.894172999999995 98.6038889999999952 98.3676300000000055 98.3443979999999982 98.5876240000000053 99.0358580000000046 99.5259170000000069 100.1344760000000065 100.649162000000004 100.9651109999999932 101.3268049999999931 101.6384350000000012 101.6733779999999996 101.7077100000000058 101.6342319999999972 101.4572679999999991 101.3806919999999963 101.
3777469999999994 101.3139950000000056 101.0439760000000007 100.0523830000000061 98.7117539999999991 97.6151049999999998 97.180603000000005 97.3013080000000059 97.8000949999999989 98.8665239999999983 100.042357999999993 100.5338749999999948 100.7868189999999942 101.0987089999999995 101.1466369999999984 100.7930759999999992 100.4041979999999938 99.880431999999999 99.5350569999999948 99.158134000000004 98.6060329999999965 97.8954470000000043 97.3501739999999955 97.4747239999999948 97.8145899999999955 97.8706669999999974 97.6424260000000004 97.5011829999999975 97.8265609999999981 97.7660680000000042 97.1123350000000016 96.5651929999999936 96.110352000000006 95.7107769999999931 95.3851470000000035 95.0807340000000067 94.9103549999999956 94.8156589999999966 94.3815309999999954 94.003105000000005 94.3630979999999937 94.6739120000000014 94.594420999999997 94.3857569999999981 94.0525889999999976 93.5300519999999977 92.9198070000000058 92.2938840000000056 91.6293639999999954 91.039565
9999999936 91.0962600000000009 91.6558760000000063 91.7676469999999966 91.4328229999999991 90.9924699999999973 90.6983180000000004 90.5543980000000062 90.3600540000000052 90.0973970000000008 89.847046000000006 89.6735690000000005 89.7839359999999971 90.1163099999999986 90.5225369999999998 90.960907000000006 91.3011400000000037 91.3878710000000041 91.2704319999999996 90.9162139999999965 90.3693999999999988 89.8585819999999984 89.5828630000000032 89.4381410000000017 89.2503739999999937 89.2224269999999962 89.2586900000000014 89.253304 89.3283080000000069 89.576233000000002 89.7868880000000047 89.7217639999999932 89.642760999999993 89.7083439999999968 89.6585460000000012 89.6722869999999972 89.5306319999999971 89.3374400000000009 89.237915000000001 89.152702000000005 88.971619000000004 88.502159000000006 88.1426929999999942 88.0828779999999938 88.0469209999999975 88.0871889999999951 88.3290860000000038 88.703117000000006 88.9779050000000069 88.7658310000000057 88.25560799999999
52 87.4309690000000046 86.3834609999999969 85.8452529999999996 85.8229450000000043 85.8033680000000061 85.8135680000000036 85.8107150000000019 85.826744000000005 85.8317109999999985 85.8123860000000036 85.8006819999999948 85.8021389999999968 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022610000000014 85.8029020000000031 85.7976840000000038 85.7844620000000049 85.7758409999999998 85.7695619999999934 85.7711869999999976 85.7718890000000016 85.771759000000003 85.771759000000003 85.771759000000003 85.771759000000003 85.7717360000000042 85.7719799999999992 85.7728350000000006 85.7627030000000019 85.7406849999999991 85.7379530000000045 85.6363070000000022 86.3082660000000033 87.3531190000000066 86.3590769999999992 85.6502909999999957 85.7396930000000026 85.7335659999999962 85.7124479999999949 85.7108080000000001 85.7108080000000001 85.7118839999999977 85.7071990000000028 85.6875459999999975 85.6801379999999995 85.68032100
00000064 85.6803050000000042 85.6826020000000028 85.6701740000000029 85.6496510000000058 85.649840999999995 85.649840999999995 85.6523059999999958 85.6381530000000026 85.6190409999999957 85.6194310000000058 85.6193619999999953 85.621727000000007 85.608161999999993 85.5906599999999997 85.5893169999999941 85.588745000000003 85.5888980000000004 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064
+98.5864640000000065 98.5135570000000058 98.3845369999999946 98.1826250000000016 97.7287220000000048 96.5611719999999991 95.9329610000000059 96.6171949999999953 97.3622210000000052 97.7999650000000003 98.036247000000003 98.2881090000000057 98.3349759999999975 98.1770860000000027 98.0828400000000045 97.9943080000000037 97.6984860000000026 97.4408650000000023 97.376380999999995 97.1769259999999946 96.3975980000000021 95.5141449999999992 95.1255869999999959 95.3288189999999958 96.0648649999999975 96.9976350000000025 97.931358000000003 98.3666230000000041 98.534514999999999 98.6818770000000001 98.739570999999998 98.6358869999999968 98.3525159999999943 98.0623860000000036 97.973228000000006 98.1082080000000047 98.4787670000000048 99.0375750000000039 99.576233000000002 100.1103059999999942 100.4750669999999957 100.7232510000000048 101.0257110000000011 101.2822950000000048 101.3420179999999959 101.4106979999999965 101.3089219999999955 100.9551850000000002 100.7681659999999937 100.76
76929999999942 100.7917400000000043 100.7381670000000042 100.0872880000000009 98.9159470000000027 97.6491999999999933 96.8798599999999936 96.8320470000000029 97.0034870000000069 97.7979739999999964 99.1306689999999975 99.9752270000000038 100.3425139999999942 100.4670789999999982 100.2776719999999955 99.9468920000000054 99.7538530000000065 99.569855000000004 99.4232709999999997 99.0772249999999985 98.2818910000000017 97.1605299999999943 96.4375689999999963 96.5111770000000035 96.8866809999999958 97.069145000000006 97.0991360000000014 96.9006650000000036 97.0299530000000061 97.180144999999996 96.6125179999999943 96.0801239999999979 95.6543049999999937 95.3021930000000026 94.9655230000000046 94.6538309999999967 94.4720310000000012 94.308525000000003 93.7146759999999972 93.0567400000000049 93.3028560000000056 93.5902629999999931 93.4856110000000058 93.3319019999999995 93.1053540000000055 92.6925959999999947 92.1204299999999989 91.5921100000000052 91.1570360000000051 90.705284000
000006 90.7621919999999989 91.0798489999999958 90.9044719999999984 90.5313799999999986 90.244056999999998 90.1356739999999945 90.0327910000000031 89.7772449999999935 89.3937229999999943 89.1462250000000012 89.0640410000000031 89.0801089999999931 89.2039719999999932 89.4955669999999941 89.9170989999999932 90.2967989999999929 90.3650279999999952 90.2200389999999999 89.8582310000000035 89.3665469999999971 89.0253220000000027 88.902869999999993 88.9033739999999995 88.9084849999999989 88.9551620000000014 89.0081559999999996 88.9423749999999984 88.8192059999999941 88.8082809999999938 88.8794709999999952 88.8212889999999931 88.8085779999999971 88.9361499999999978 88.9909519999999929 88.9705050000000028 88.8008350000000064 88.6397929999999974 88.5065380000000062 88.2393569999999983 87.8207629999999995 87.4343719999999962 87.2944179999999932 87.3131099999999947 87.3310010000000005 87.6098180000000042 88.0333710000000025 88.4000470000000007 88.5924610000000001 88.2505720000000053 87.5
612639999999942 86.5938569999999999 85.9446259999999995 85.8231889999999993 85.8525159999999943 85.8455050000000028 85.834502999999998 85.8343890000000016 85.8325959999999952 85.8329999999999984 85.8281020000000012 85.8081130000000059 85.801368999999994 85.802299000000005 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8023759999999953 85.8023989999999941 85.8009799999999956 85.7928619999999995 85.7803729999999973 85.7723689999999976 85.7690429999999964 85.7692720000000008 85.770386000000002 85.7717439999999982 85.771759000000003 85.771759000000003 85.7717209999999994 85.7720489999999955 85.7718509999999981 85.7576980000000049 85.7394180000000006 85.6167910000000063 86.434905999999998 87.6897430000000071 86.6449360000000013 85.7155910000000034 85.7235409999999973 85.7318269999999956 85.7102509999999995 85.7100680000000068 85.7109300000000047 85.7109300000000047 85.7125850000000042 85.6972200000000015 85.6779099999999971
85.6784669999999977 85.6800230000000056 85.6828990000000061 85.6682129999999944 85.647948999999997 85.6480179999999933 85.649437000000006 85.6512369999999947 85.6452790000000022 85.6222379999999958 85.6183620000000047 85.6194760000000059 85.6206509999999952 85.6147610000000014 85.5942840000000018 85.588325999999995 85.5889049999999969 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064
+98.3045500000000061 98.2534409999999951 98.1616669999999942 98.0164719999999932 97.5758739999999989 96.4316560000000038 95.6968839999999972 96.2935640000000035 97.0846180000000061 97.6186749999999961 97.8376849999999934 97.9656679999999938 97.9619600000000048 97.8034899999999965 97.7940219999999982 97.8159940000000034 97.4343719999999962 96.9704440000000005 96.8210530000000063 96.576240999999996 95.8483509999999939 95.1264649999999961 94.8135529999999989 94.927063000000004 95.5831529999999958 96.4162220000000048 97.4170299999999969 98.135429000000002 98.3727260000000001 98.4601820000000032 98.3966750000000019 98.1495510000000024 97.793578999999994 97.5432820000000049 97.5947720000000061 97.9590149999999937 98.4437709999999981 98.9742889999999989 99.5037609999999972 99.9282299999999992 100.0890349999999955 100.2595440000000053 100.5016329999999982 100.728950999999995 100.8835830000000016 101.0065160000000049 100.9430239999999941 100.6731189999999998 100.5066910000000036 100.4
089969999999994 100.2574919999999992 100.1005169999999964 99.7775570000000016 99.0231629999999967 97.936522999999994 96.9739990000000063 96.5873870000000068 96.5767900000000026 96.9650120000000015 98.0804210000000012 99.2134170000000069 99.6424329999999969 99.5999529999999993 99.5632250000000028 99.6031490000000019 99.6838070000000016 99.6785129999999953 99.3921430000000043 98.8827289999999977 98.0132449999999977 96.8835219999999993 95.8042760000000015 95.5673069999999996 96.0558170000000047 96.4729310000000027 96.5973589999999973 96.2882160000000056 96.2255399999999952 96.5254359999999991 96.1869350000000054 95.6666639999999973 95.2886960000000016 94.9435579999999959 94.6019739999999985 94.2717360000000042 93.9918059999999969 93.6009140000000031 92.9126129999999932 92.0642699999999934 91.9393309999999957 91.9660570000000064 91.8337169999999929 91.8654020000000031 91.9046940000000063 91.7688449999999989 91.391563000000005 90.9784470000000027 90.7024459999999948 90.3854979999
999983 90.2825930000000056 90.4581529999999958 90.2947460000000035 90.0014800000000008 89.7229770000000002 89.5469970000000046 89.4455640000000045 89.1966089999999951 88.8510820000000052 88.7047270000000054 88.6599350000000044 88.6171719999999965 88.6193310000000025 88.7398220000000038 88.9668960000000055 89.1810839999999985 89.2345889999999997 89.1076809999999995 88.7889179999999953 88.5055689999999942 88.4831310000000002 88.5349269999999962 88.5548320000000047 88.6244509999999934 88.6260759999999976 88.5643460000000005 88.4209670000000045 88.1970599999999934 88.0672760000000068 88.0350799999999936 88.0291440000000023 88.0964050000000043 88.1174620000000033 88.1195830000000058 88.0383759999999995 87.9005200000000002 87.5279919999999976 87.2349470000000053 86.8318859999999972 86.3980710000000016 86.2681429999999949 86.2723079999999953 86.2920459999999991 86.3436659999999989 86.7190700000000021 87.2521509999999978 87.5599519999999956 87.7190700000000021 87.4053569999999951 86
.7461550000000017 86.0677570000000003 85.8422620000000052 85.8672710000000023 85.8651430000000033 85.853943000000001 85.8340450000000033 85.8325729999999965 85.8327179999999998 85.8329389999999961 85.8343509999999981 85.8265150000000006 85.8050000000000068 85.801392000000007 85.8023610000000048 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022310000000061 85.8023759999999953 85.8033449999999931 85.8020099999999957 85.7984849999999994 85.7865599999999944 85.7781070000000057 85.7819899999999933 85.7761540000000053 85.7697830000000039 85.7694630000000018 85.7697979999999944 85.7714840000000009 85.771759000000003 85.7720949999999931 85.7702940000000069 85.7695310000000006 85.6422579999999982 86.4712300000000056 87.7884600000000006 86.6816709999999944 85.6916499999999957 85.724693000000002 85.7328339999999969 85.7219159999999931 85.7126849999999934 85.7081529999999958 85.7084660000000014 85.710907000000006 85.7036209999999983 85.6888280000000
009 85.6895750000000049 85.6802370000000053 85.6812129999999996 85.6731410000000011 85.6588899999999995 85.6599269999999962 85.651955000000001 85.6494900000000001 85.6502689999999944 85.6405560000000037 85.6208189999999973 85.6187589999999972 85.6194919999999939 85.6207200000000057 85.605559999999997 85.5873950000000008 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064
+98.0192260000000033 98.0231859999999955 97.8673480000000069 97.677338000000006 97.1667790000000053 95.955048000000005 95.297584999999998 95.9880069999999961 96.8334270000000004 97.3180470000000071 97.4619830000000036 97.4995499999999993 97.4197240000000022 97.230827000000005 97.1738589999999931 97.2124249999999961 97.0114059999999938 96.599700999999996 96.3625559999999979 96.089500000000001 95.5209049999999991 94.8700099999999935 94.5824429999999978 94.6381149999999991 95.2039869999999979 95.9892200000000031 96.840217999999993 97.6006619999999998 97.8690720000000027 97.894683999999998 97.8960720000000038 97.643889999999999 97.2120209999999929 97.0070110000000057 97.2129750000000001 97.7130130000000037 98.3161850000000044 98.8675309999999996 99.3035959999999989 99.5815280000000058 99.685364000000007 99.8408359999999959 99.9843220000000059 100.1759189999999933 100.3905409999999989 100.5187909999999931 100.6105189999999965 100.5836259999999953 100.4855500000000035 100.400024000
0000019 100.2079240000000055 99.8853840000000019 99.4799730000000011 98.9072950000000048 98.2260509999999982 97.5874629999999996 97.0221020000000038 96.8908619999999985 97.1866380000000021 97.9283980000000014 98.6349029999999942 98.9127579999999966 99.0450440000000043 99.2368390000000034 99.3012769999999989 99.203795999999997 99.014403999999999 98.799278000000001 98.3794170000000037 97.4319080000000071 96.5909809999999993 95.4607769999999931 94.823363999999998 95.3808140000000009 95.9423900000000032 96.0485690000000005 95.7253189999999989 95.5145870000000059 95.7895579999999995 95.7913360000000011 95.308021999999994 94.9249039999999979 94.5655900000000003 94.1955410000000057 93.752869000000004 93.3046420000000012 92.7469250000000045 92.0546719999999965 91.2440799999999967 90.7393950000000018 90.4452670000000012 90.1869200000000006 90.2999420000000015 90.6309130000000067 90.8102569999999929 90.6915659999999946 90.4217830000000049 90.2195969999999932 90.0149380000000008 89.962
9290000000026 90.0799939999999992 89.9367139999999949 89.6092380000000048 89.2136760000000066 88.8745880000000028 88.7900010000000037 88.6568599999999947 88.4363560000000035 88.3913960000000003 88.3386990000000054 88.3149870000000021 88.3012470000000036 88.2629850000000005 88.209075999999996 88.0299219999999991 87.9782639999999958 87.9415740000000028 87.8310010000000005 87.8570019999999943 88.0004119999999972 88.0444559999999967 87.994101999999998 88.0269470000000069 88.0724409999999978 88.0529860000000042 87.8846130000000016 87.6104430000000036 87.4753110000000049 87.4494250000000051 87.3857270000000028 87.3848109999999991 87.2311940000000021 87.0826569999999975 86.9231719999999939 86.838829000000004 86.4963070000000016 86.1087109999999996 85.9225540000000052 85.8411250000000052 85.8430859999999996 85.8595049999999986 85.8604430000000036 85.8650279999999952 85.9746020000000044 86.2595060000000018 86.4570240000000041 86.535308999999998 86.3571010000000001 86.0560069999999939
85.8862610000000046 85.8569490000000002 85.8638459999999952 85.8642119999999949 85.8604890000000012 85.8403090000000049 85.8328630000000032 85.8327259999999939 85.8326950000000011 85.8330540000000042 85.834502999999998 85.8229220000000055 85.8016740000000055 85.8014450000000011 85.8023529999999965 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8021770000000004 85.8025669999999963 85.8033290000000051 85.8003539999999987 85.7976460000000003 85.8000559999999979 85.7930759999999992 85.7793199999999985 85.7804490000000044 85.7788850000000025 85.7704930000000019 85.770118999999994 85.7715380000000067 85.7757569999999987 85.6441800000000057 85.6416239999999931 87.1193849999999941 88.0917429999999939 86.6679759999999959 85.6464610000000022 85.7308040000000062 85.7470469999999949 85.7383959999999945 85.7283170000000041 85.7175670000000025 85.7210079999999977 85.7180330000000055 85.7102739999999983 85.7073520000000002 85.7069240
000000008 85.6924669999999935 85.6804350000000028 85.6792599999999993 85.677063000000004 85.6755679999999984 85.6568680000000029 85.6483149999999966 85.6501460000000066 85.6498179999999962 85.6299290000000042 85.6171879999999987 85.6193310000000025 85.6219640000000055 85.6045069999999981 85.5867159999999956 85.589020000000005 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5887910000000005
+97.6446380000000005 97.7663880000000063 97.6225199999999944 97.3478240000000028 96.6836399999999969 95.4705510000000004 95.0424579999999963 95.786011000000002 96.6104509999999976 96.9587939999999975 96.864372000000003 96.7427220000000005 96.683959999999999 96.5226750000000067 96.3756869999999992 96.3253399999999971 96.2309190000000001 95.9842450000000014 95.9235000000000042 95.8099140000000062 95.3687060000000031 94.7874529999999993 94.4016340000000014 94.3310170000000028 94.7068710000000067 95.4650500000000051 96.3385240000000067 97.0516889999999961 97.2387999999999977 97.1939320000000038 97.218047999999996 97.0674669999999935 96.6850589999999954 96.5419080000000065 96.8930050000000023 97.3883359999999954 98.0033949999999976 98.5682599999999951 98.9343489999999974 99.0815580000000011 99.186981000000003 99.4023820000000029 99.5212169999999929 99.5845949999999931 99.7042619999999999 99.7179490000000044 99.8464969999999994 100.0648570000000035 100.0512849999999929 100.04536400
00000064 100.1983720000000062 100.0309680000000014 99.4006499999999988 98.8042370000000005 98.2284470000000027 97.8496399999999937 97.4734650000000045 97.295921000000007 97.5105439999999959 97.8095320000000044 98.1281589999999966 98.3701860000000039 98.4707259999999991 98.4319839999999999 98.3137049999999988 98.0876769999999993 97.9107819999999975 97.882782000000006 97.3837429999999955 96.5559839999999951 96.1572720000000061 95.2855990000000048 94.3901670000000053 94.8283080000000069 95.5318829999999934 95.682304000000002 95.3470310000000012 94.8903269999999992 95.0607760000000042 95.338561999999996 94.9479900000000043 94.518889999999999 94.1743620000000021 93.7101590000000044 93.0186690000000027 92.3303910000000059 91.7595670000000041 91.158385999999993 90.5683899999999937 90.0980069999999955 89.5842439999999982 88.9989010000000036 89.0642009999999971 89.5693279999999987 89.8889999999999958 89.945098999999999 89.8249279999999999 89.6968920000000054 89.5718920000000054 89.69
60069999999945 89.8054659999999956 89.5853419999999971 89.1364669999999961 88.7077869999999962 88.4149479999999954 88.3256070000000051 88.2336499999999972 88.1033479999999969 88.1190869999999933 87.9953459999999978 87.823882999999995 87.8114010000000036 87.6644129999999961 87.4062119999999965 87.0264430000000004 86.8717960000000033 86.905060000000006 87.0692370000000011 87.3549799999999976 87.5033870000000036 87.4233930000000043 87.3025439999999975 87.3870009999999979 87.5408330000000063 87.5792770000000047 87.4108659999999986 87.1450499999999977 86.8255079999999992 86.6374050000000011 86.5133739999999989 86.3719710000000021 86.225594000000001 86.134917999999999 86.0065460000000002 86.0259319999999974 85.9681779999999947 85.8437880000000035 85.8530959999999936 85.894440000000003 85.8814930000000061 85.8803860000000014 85.8805009999999953 85.8654329999999959 85.8318330000000032 85.8583909999999975 85.8995209999999929 85.9061509999999942 85.8795929999999998 85.8553090000000054
85.866966000000005 85.8645170000000064 85.8630979999999937 85.8633420000000029 85.8645099999999957 85.8504870000000011 85.832642000000007 85.8328089999999975 85.8327259999999939 85.8326639999999941 85.8331909999999993 85.8337099999999964 85.8174900000000065 85.7999949999999956 85.801636000000002 85.802306999999999 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8022459999999967 85.8030009999999947 85.8036189999999976 85.8036730000000034 85.8022079999999931 85.7978739999999931 85.7985989999999958 85.7962270000000018 85.7838289999999972 85.7752689999999944 85.7707750000000004 85.759949000000006 85.8038939999999997 86.6942980000000034 88.4906309999999934 88.4210889999999949 86.5058590000000009 85.6369710000000026 85.7630079999999992 85.7662660000000017 85.7476580000000013 85.7399369999999976 85.7370379999999983 85.7394560000000041 85.7317890000000062 85.7131349999999941 85.7117389999999943 85.7118909999
999943 85.7048800000000028 85.6843029999999999 85.6801609999999982 85.6811600000000055 85.6786120000000011 85.6575090000000046 85.6481930000000062 85.6498030000000057 85.6506420000000048 85.6289060000000006 85.6165850000000006 85.6194689999999952 85.620789000000002 85.6110690000000005 85.5905910000000034 85.588325999999995 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888900000000064 85.5888060000000053 85.5897449999999935
Added: grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/data/lake_viewshed.ascii
--- grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/data/lake_viewshed.ascii (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/data/lake_viewshed.ascii 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,153 @@
+north: 216990
+south: 215520
+east: 635950
+west: 633730
+rows: 147
+cols: 222
+89.32888 89.314835 89.306641 89.307411 89.305687 89.303696 89.299942 89.294083 * 89.296921 89.29599 89.290314 89.285027 89.276215 * 89.268959 89.275551 89.269928 89.269279 89.261124 89.25618 89.252548 89.232727 * 89.220886 89.225548 89.215584 89.20591 89.198158 89.19696 89.198517 89.194931 89.19239 89.184212 89.173378 89.158463 * * * * 89.187103 89.191025 89.197937 89.201515 89.207253 89.214546 89.220634 89.223053 89.233406 89.24128 89.248314 89.245956 89.258476 89.289192 89.311043 89.327423 89.343132 89.363144 89.383827 89.400887 89.422112 89.450729 89.482475 89.491211 89.464485 89.422508 89.393143 89.367439 89.351463 89.35347 89.363754 89.377869 89.37944 89.389229 89.41243 89.426384 89.43882 89.428665 89.387917 89.315269 89.230904 89.16864 89.122169 89.096901 * * * * * * * * 89.606064 89.665054 89.713432 89.741669 89.740829 89.718811 89.691315 * * * * * * * * * * * * 90.164436 90.212624 90.243134 90.287544 90.329819 90.369751 90.413559 90.424805 * * * * * * * * * * * * * *
* 89.458595 89.423325 89.406334 89.414703 89.408318 89.421448 89.526764 89.682655 89.836418 89.947296 89.995285 90.026031 90.072578 90.113083 90.147469 90.182014 90.199188 90.19944 90.205315 90.215202 90.227905 90.240334 90.261719 90.290726 90.323059 90.360229 90.377823 90.385216 90.403244 90.415894 90.415962 90.429329 90.452187 90.478699 90.499886 90.522072 90.553001 90.57695 90.589569 90.605186 90.626945 90.646851 90.658768 90.662399 90.663254 90.662697 90.658119 90.652908 * * * * * * * * * * * * * * 90.58831 90.6175 90.646973 90.659302 90.654793 * * * * * * * * * * * * * * * * * 90.526939 90.529434 * *
+89.32 89.316292 89.307884 89.302635 89.302689 89.301094 89.295586 * 89.2929 89.292557 89.289383 89.282532 89.275215 89.270248 89.261299 89.262939 89.265366 89.25544 89.258575 89.257149 89.244667 89.243134 89.236313 * 89.217552 89.215263 89.205444 89.197845 * * 89.197464 89.188622 89.186432 89.178719 89.162354 89.147881 89.142754 * 89.164238 89.173065 89.175491 89.175415 89.178802 89.181793 89.189476 89.192436 89.196877 89.199211 89.198692 89.200691 89.212456 89.221718 89.239792 89.268219 89.286713 89.30233 89.319901 89.340202 89.362495 89.382446 89.401833 89.428314 89.453087 89.454842 89.428024 89.382042 89.342979 89.323502 89.320274 89.324821 89.333725 89.344635 89.343231 89.339821 89.355637 89.373703 89.380676 89.363304 89.325768 89.264229 89.193947 89.128761 89.097359 89.08564 89.113571 * * * * * * * 89.579201 89.626884 89.668816 89.692062 89.686325 89.671188 * * * * * * * * * * * * * 90.161163 90.21347 90.247406 90.290497 90.329445 90.361542 90.400253 90.412086 90.41748
90.427048 90.406357 90.361 * * * * * * * * * * * * 89.39534 89.387772 89.397408 89.393524 89.403679 89.542252 89.731468 89.860741 89.942596 89.992546 90.032761 90.067932 90.095245 90.12439 90.148399 90.153717 90.152206 90.157219 90.169197 90.192314 90.209175 90.228798 90.258362 90.2929 90.337822 90.351402 90.353104 90.372047 * * * 90.427139 90.464912 90.495453 90.516487 90.542664 90.564392 90.588188 90.613869 90.633781 90.646088 90.654488 90.65863 90.650703 * * * * * * * * * * * * * * * * * 90.585327 90.611877 90.637863 90.65242 90.645653 * * * * * * * * * * * * * * * * 90.50193 90.5168 90.517937 * *
+89.312096 89.308205 89.3022 89.298157 89.299599 * 89.299965 89.295609 89.289497 89.290298 89.286079 89.278313 89.272881 89.264893 89.258041 89.257233 89.257744 89.248238 * 89.252426 89.242027 89.227379 89.224983 89.227531 89.223206 89.212669 89.202362 89.191422 * 89.191177 89.191032 89.177567 89.175331 89.171463 89.153221 89.13871 89.133492 89.139534 89.152573 89.160133 89.162399 89.158661 89.156975 89.159615 89.168121 89.173714 89.180359 89.17836 89.16951 89.172546 89.184677 89.191589 89.205185 89.230125 89.251663 89.273033 89.296692 89.32016 89.344414 89.366173 89.384903 89.408882 89.425362 89.416718 89.381332 89.32991 89.295761 89.287285 89.294907 89.302414 89.311073 89.315933 89.309349 89.307701 89.318649 89.327293 89.321472 89.298454 89.265938 89.214073 89.146957 89.099762 89.097206 89.077438 89.078651 * * * * * * * * * * * * * * * * * * * * * * * * * * * 90.2071 90.249588 90.289635 90.326363 90.354988 90.382698 90.398277 90.416344 90.416794 90.385162 90.343735 90.31563
6 90.268509 90.20649 * * * * * * * * * 89.3787 89.370964 89.372482 89.371933 * 89.548309 89.738235 89.850052 89.918076 89.960938 89.998154 90.038399 90.065216 90.084709 90.090858 90.08474 90.084099 90.096886 90.119972 90.153572 90.177681 90.192757 * * * * * * * * * 90.41658 90.447853 90.488068 90.52195 90.5448 90.569939 90.602455 90.622452 90.634041 90.644447 90.651268 90.649712 * * * * * * * * * * * * * * * * * * 90.585419 90.610634 90.628685 90.640663 90.63237 * * * * * * * * * * * * * * * * 90.482086 90.498352 90.49865 * *
+89.31144 89.301392 89.295486 89.298264 89.294014 89.297302 89.303101 89.298874 89.287552 89.283836 89.279099 89.270233 89.269867 89.260956 89.251541 89.250618 89.250114 89.242348 * 89.247566 89.244225 * * 89.216835 89.214432 89.204994 89.196526 89.190636 89.191055 89.190987 89.182007 89.171127 89.169563 89.166824 89.150101 89.128998 89.122574 89.12606 89.132057 89.143982 89.1493 89.144714 89.140778 89.145096 89.152031 89.158257 89.16024 89.152336 89.146835 89.150597 89.156082 89.159218 89.165749 89.189026 89.217346 89.242233 89.274704 * 89.330765 89.349602 89.369461 89.393517 89.403976 89.383041 89.330986 89.277832 89.258728 89.260902 89.272514 89.280159 89.286041 89.285278 89.278992 89.281151 89.292793 89.2929 89.271248 89.249626 89.212158 89.160881 89.107513 89.081284 89.065521 89.043274 89.023865 * * * * * * * * * * * * * * * * * * * * * * * * * * * 90.200859 90.244591 90.283997 90.318573 90.34726 90.363762 90.377411 90.393097 90.386124 90.361198 90.323624 90.28476 90.234
108 90.185989 90.130013 * * * * * * * * 89.370476 89.353493 * * * 89.596436 89.750771 89.836227 89.879868 89.900749 89.927834 89.989395 90.019287 90.023872 90.018036 90.010872 90.01947 * * * * * * * * * * * * * * * * 90.488312 90.528824 90.556404 90.589516 90.615005 90.62365 90.634972 90.641953 * * * * * * * * * * * * * * * * * * * * 90.584877 90.608948 90.622391 90.624359 * * * * * * * * * * * * * * * * * 90.454521 90.473167 90.476685 90.460472 *
+89.313438 89.301529 * 89.294449 * * 89.294846 89.295532 89.288338 89.276604 89.270203 89.265182 89.263733 89.257988 89.250237 89.247704 89.244446 89.238228 89.237885 89.23848 89.236328 89.233337 89.227127 * 89.206955 89.196953 89.185982 89.185539 89.191216 89.18177 89.164757 89.158165 89.155945 89.1549 89.14666 89.127594 89.117447 89.117096 89.114464 89.120491 89.128731 89.130997 89.129913 89.134071 89.139702 89.146072 89.139832 89.130547 89.129036 89.128113 89.129211 89.130753 89.129112 89.140968 89.17057 89.205879 89.249229 89.292931 89.317787 89.325935 89.343094 89.370453 89.379829 89.348122 89.282967 89.23877 89.230972 89.237976 89.249756 89.25573 89.259911 89.257919 89.252876 89.254112 89.274582 89.277946 89.235107 89.209351 89.15963 89.098267 89.085732 89.064201 89.008041 88.997551 * * * * * * * * * * * * * * * * * * * * * * * * * 90.135674 90.145866 90.162628 90.196907 90.234535 90.272705 90.306854 90.329811 90.348145 90.36013 90.360062 90.350937 90.331207 90.290184 9
0.236092 90.186859 90.147057 90.09507 90.009811 * * * * 89.480293 * * * * * 89.417656 89.533386 89.643639 89.748802 89.816154 89.848549 89.864944 89.883492 89.931282 89.95356 89.947289 * * * * * * * * * * * * * * * * * * * 90.51088 90.541328 90.576286 90.608322 90.620178 * 90.636047 * * * * * * * * * * * * * * * * * * * * * 90.576424 90.598991 90.611183 90.606651 * * * * * * * * * * * * * * * * * 90.431267 90.444931 90.449074 90.434212 *
+89.312866 89.302216 89.29155 89.288536 * * 89.285919 89.288528 89.283257 89.274826 89.26783 89.26519 89.262207 89.256454 89.252594 89.244705 89.232513 89.227036 89.227142 89.22686 89.221436 89.21891 89.220772 89.218452 89.215553 89.20475 89.186317 89.174126 89.174431 * * 89.162994 89.148369 89.139343 89.14315 89.136459 89.118538 89.109818 89.104416 89.098511 89.10582 89.116913 89.121506 89.124702 89.127747 89.129555 89.118805 89.110062 89.110001 89.109001 89.105713 89.096542 89.089211 89.09568 89.116333 89.151978 89.203209 89.259575 89.290321 89.295952 89.307739 89.335548 89.341805 89.29837 89.233131 89.204712 89.204689 89.214508 89.224762 89.22699 89.230949 89.226303 89.220184 89.226654 89.260643 89.269341 89.20665 89.165176 89.10968 89.035202 89.041794 89.035423 88.982025 88.971268 * * * * * * * * * * * * * * * * * * * * * * * * 90.126663 90.135078 90.143051 90.15937 90.190094 90.225883 90.259933 90.290054 90.309959 90.334846 90.343239 90.334015 90.322479 90.296165 90.2385
71 90.177757 90.122971 90.078835 90.031113 89.973389 89.893509 89.799881 89.700096 89.553825 89.427765 89.380249 * * * * 89.445427 89.547417 89.633102 89.717583 89.791344 89.838043 89.854332 89.863693 89.879677 89.881271 * * * * * * * * * * * * * * * * * * * 90.507965 90.533974 90.558243 90.591042 90.618217 90.627426 * * * * * * * * * * * * * * * * * * * * * * * 90.565857 90.586464 90.597534 * * * * * * * * * * * * * * * * * * 90.411476 90.419403 90.419983 90.4076 *
+89.312546 89.306099 89.293945 89.2883 89.28434 89.277512 89.274727 89.276306 89.272385 89.267921 89.261726 89.261055 89.259636 89.251892 89.243446 89.233688 89.220207 89.216064 89.21553 89.215248 89.210365 89.201004 89.194275 89.196609 89.201042 89.197281 89.187897 89.171272 * * * 89.176071 89.155121 89.130829 89.134605 89.139435 89.121078 89.103386 89.095383 89.088287 89.088814 89.099762 89.107002 89.110428 89.112045 89.109894 89.101532 89.093094 89.089081 89.089279 89.083809 89.070427 89.062172 89.066902 89.078392 89.09864 89.143112 89.196938 89.231247 89.247391 89.262733 89.285645 89.287468 89.242622 89.190323 89.176071 89.178993 89.188263 89.195396 89.197716 89.201332 89.193924 89.193001 * 89.247238 89.238937 89.169167 89.121475 89.059448 88.996948 89.000534 88.991005 88.963562 * * 89.03936 * * * * * * * * * * * * * * * * * * * * * 90.115944 90.127556 90.131531 90.138878 90.150398 90.177505 90.211632 90.246048 90.272408 90.288078 90.312698 90.315674 90.30645 90.291229 90
.254501 90.181549 90.110481 90.041405 89.988243 89.957092 89.914917 89.841812 89.75724 89.641525 89.472229 89.351746 89.360245 89.354446 * * * 89.462326 89.521362 89.592232 89.671371 89.746445 89.804878 89.816765 89.817574 * * * * * * * * * * * * * * * * * * * * 90.49736 90.522499 90.547768 90.567802 90.595284 90.625031 90.636108 * * * * * * * * * * * * * * * * * * * * * * * 90.561432 90.580208 90.589691 * * * * * * * * * * * * * * * * * * 90.37632 90.386215 90.386757 90.379982 *
+89.313362 89.310822 89.296707 89.289024 89.28299 89.276382 89.264816 * 89.261459 89.26162 89.256218 89.251366 89.247932 89.241348 89.230049 89.224213 89.218742 89.212349 89.20842 89.208519 89.204262 89.196678 * * 89.180748 89.179642 89.180618 89.173325 * 89.166954 89.169884 89.166306 89.155479 89.131523 * 89.132637 89.122261 89.098381 89.084419 89.078697 89.078064 89.082878 89.090904 89.090675 89.091118 89.093933 89.08802 89.077194 89.069763 89.066605 89.056961 89.048409 89.045616 89.047096 89.050957 89.057625 89.084625 89.121094 89.153183 89.177925 89.20192 89.221901 89.220543 89.192314 89.161125 89.155045 89.155479 89.1586 89.162704 89.168633 89.171074 89.16732 89.176872 89.203232 89.225372 89.190819 89.115364 89.0737 89.02607 88.990646 88.973145 88.955681 88.940842 * 88.985146 89.027786 * * * * * * * * * * * * * * * * * * * * 90.091484 90.116753 90.125099 90.128677 90.134674 90.142159 90.161545 90.191887 90.227501 90.255005 90.270638 90.290337 90.290009 90.273201 90.24580
4 90.196793 90.122795 90.043938 89.961784 89.891418 89.867516 89.836136 89.767654 89.693237 89.56179 * * 89.305908 89.347763 89.357887 * 89.411118 89.461884 89.499634 89.54734 89.608223 89.664032 89.71579 89.743584 * * * * * * * * * * * * * * * * * * * * 90.493973 90.515289 * 90.553642 90.572876 90.601677 90.633247 90.638695 * * * * * * * * * * * * * * * * * * * * * * * 90.558945 90.575638 90.581947 * * * * * * * * * * * * * * * * * * 90.329391 90.341904 90.347748 90.352989 *
+89.306442 89.307755 89.299751 89.288422 89.278503 89.270576 * * 89.261581 89.25927 89.255951 89.244926 89.239372 * * 89.223297 89.219589 89.212547 89.203697 89.202957 89.205276 89.199821 89.195168 89.192413 89.180145 89.172104 89.169647 89.168037 89.167679 89.161949 89.154686 89.1492 89.144424 89.136803 89.119644 89.115715 89.11628 89.095963 89.077431 89.06694 89.067886 89.071419 89.077103 89.072014 89.068428 89.074112 89.069931 89.059669 89.050728 89.043793 89.032799 89.0271 89.027863 89.025948 89.020317 89.023834 89.039452 89.057571 89.083366 89.108383 89.131065 89.150299 89.152695 89.144302 89.135254 89.136269 89.132446 89.130272 89.133148 89.137451 89.139725 89.141464 89.157433 89.182388 89.188164 89.130623 89.057251 89.023743 89.00045 88.997871 88.956146 88.925957 88.925476 88.947319 88.973389 89.009117 * * * * * * * * * * * * * * * * * 89.966812 * * 90.087776 90.114143 90.120354 90.116478 90.121262 90.128601 90.144127 90.179436 90.211662 90.244606 90.270073 90.274536 9
0.265007 90.23983 90.200478 90.138535 90.063438 89.990227 89.906136 89.815536 89.766731 89.736961 89.682701 89.599518 89.477592 * * 89.250557 89.306641 89.370384 89.386513 * 89.438385 * * * * * * * * * * * * * * * * * * * * * * * 90.435699 90.464958 90.489731 * * 90.547142 * 90.583618 90.609505 90.637161 90.638474 * * * * * * * * * * * * * * * * * * * * * * 90.523994 90.554337 90.570213 90.572609 * * * * * * * * * * * * * * * * * 90.281319 90.299568 90.310547 90.318871 90.329437 *
+89.295097 89.298416 89.299194 89.286095 89.276108 * 89.266968 89.269218 89.264648 89.258865 89.257042 89.24498 89.232506 * 89.232376 89.227249 89.219948 89.215324 89.203201 89.191055 89.187973 89.19207 89.190514 89.191216 89.17997 89.165749 89.157433 89.156731 89.157646 89.147629 89.139557 89.133064 89.127731 89.134354 89.12793 89.10199 89.106834 89.095139 89.072296 89.060066 89.053459 89.055138 89.057899 89.051109 89.043541 89.043373 89.045647 89.042404 89.031334 89.021431 89.014679 89.009224 89.007469 89.000023 88.992867 89.001472 89.011314 89.01915 89.037598 89.056267 89.070633 89.087601 89.102882 89.108253 89.109665 89.114922 89.107735 89.102051 89.104248 89.107147 89.110992 89.117836 89.134987 89.150093 89.134911 89.069901 89.011978 88.988831 88.96315 88.978287 88.957207 88.894638 88.913864 88.941872 88.959358 88.996223 * * * * * * * * * * * * * * * * 89.915756 89.966331 90.023064 90.066261 90.082573 90.102547 90.105217 90.096657 90.098419 90.1064 90.127541 90.165779 90
.189499 90.21962 90.253799 90.258888 90.239235 90.209351 90.175652 90.111687 90.023834 89.94709 89.872627 * * 89.637032 89.589851 89.497803 89.397682 89.308899 89.243462 89.229286 89.259003 89.340515 89.393761 * * * * * * * * * * * * * * * * * * * * * * * * * 90.453461 90.484467 90.510536 * * 90.560661 90.57991 90.595787 90.611771 90.63546 90.638596 * * * * * * * * * * * * * * * * * * * * * * 90.521416 90.552673 90.565742 90.5662 * * * * * * * * * * * * * * * * 90.245125 90.2743 90.291672 90.299217 90.303764 90.307945 *
+89.293655 89.29071 89.291664 89.283737 89.27301 89.272095 89.26799 89.255768 89.252449 89.255241 89.25174 89.237907 * * 89.234917 89.226631 89.217743 89.211563 89.202896 89.184677 * 89.177635 89.175995 89.172676 89.1651 89.156006 89.148293 89.143974 89.140808 89.136986 89.130157 89.120972 89.115257 89.12133 89.123779 89.096664 89.092896 89.092323 89.074661 89.060432 89.046059 89.041 89.040901 * 89.033981 89.026039 89.020691 89.015854 89.010323 89.001572 88.993057 88.993286 88.986397 88.9785 88.976982 88.982132 88.98542 88.991402 89.007858 89.019814 89.029991 89.044998 89.065048 89.077377 89.077766 89.081711 89.077156 89.073402 89.072975 89.072922 89.076096 89.090057 89.108521 89.10807 89.08017 89.028549 88.978531 88.956329 88.942268 88.942238 88.915108 * * 88.92749 88.946373 88.97583 * * * * * * * * * * * * * * 89.761978 89.834862 89.916115 89.952721 89.996521 90.051575 90.080696 90.087372 90.085976 90.078743 90.076126 90.087036 90.115463 90.148315 90.159233 90.177666 90.220
07 90.240219 90.217888 90.184593 90.152496 90.087227 * 89.913185 89.842781 89.751854 * * 89.492088 89.40789 89.32328 89.246674 89.201363 89.212784 * 89.326866 89.396233 89.43998 * * * * * * * * * * * * * * * * * * * * * * 90.424759 * * 90.499275 90.53022 90.542633 90.557518 90.575943 90.590424 90.602303 90.613121 90.633553 90.636024 * * * * * * * * * * * * * * * * * * * * * * 90.524666 90.55439 90.558624 90.550354 * * * * * * * * * * * * * * * * 90.245979 90.273079 90.287239 90.291878 90.293945 90.290627 *
+89.291054 * 89.282913 89.277237 89.265671 89.265419 89.264839 89.251686 * 89.246582 89.245865 89.233833 89.222725 89.221725 89.224487 89.221153 89.212486 89.204529 89.201294 89.193344 89.178352 89.173119 89.170639 89.160042 89.153915 89.148102 89.14167 89.135666 89.129227 89.125694 89.123985 89.122002 89.111366 89.105721 89.111488 89.097092 89.079826 89.080605 89.072586 89.059113 89.047493 89.041573 89.039116 89.03511 89.039017 89.028908 89.010574 88.998024 88.995087 88.989563 88.980873 88.981552 88.974915 88.964996 88.960823 88.962135 88.961586 88.967339 88.979759 88.988701 89.000084 89.012856 89.026672 89.042755 89.047432 89.043747 89.043053 89.044456 89.03714 89.033371 89.035782 89.050972 89.069817 89.064651 89.040466 88.99617 88.941216 88.908401 88.914833 88.908546 88.879868 88.886269 88.89872 88.914459 88.933083 88.957062 * * * * * * * * * * * * * 89.715996 89.758385 89.827744 89.903931 89.93576 89.956566 90.010185 90.065742 90.077972 90.071068 90.059509 90.060638 90.07
3524 90.100182 90.119804 90.12632 90.155998 90.198135 90.215263 90.199989 90.163223 90.118927 90.045113 * * 89.800369 89.718361 89.63163 89.53315 * 89.339951 89.260704 * 89.177002 89.215714 89.282471 89.344124 89.403526 89.462967 * * * * * * * * * * * * * * * * * * * * * 90.414154 90.448761 90.469803 90.490089 90.519844 90.540581 90.553719 90.570381 90.579185 90.586288 90.599007 90.611343 90.630707 90.634033 * * * * * * * * * * * * * * * * * * * * * 90.483971 90.532974 90.553246 * * * * * * * * * * * * * * * * 90.214912 90.218956 90.246925 90.267899 90.277168 90.280296 90.285561 90.277573 *
+* 89.288773 89.283897 89.271873 89.26059 * 89.261192 89.25531 89.243546 89.243103 89.24221 89.234154 89.225769 89.217926 89.213562 89.211555 89.206673 89.201622 89.202293 89.201874 89.185226 89.172585 89.168678 89.159157 89.148521 89.140152 89.136047 89.129471 89.122978 89.116966 89.114494 89.120796 89.113876 89.100143 89.098869 89.097252 89.076828 89.06675 89.066872 89.055267 89.045013 89.042831 89.037231 89.027725 89.033493 89.023247 89.008011 88.998848 88.992783 88.986046 88.976852 88.970703 88.965408 88.954811 88.943687 88.942459 88.94323 88.947556 88.954742 88.962044 88.974892 88.98835 88.997498 89.008659 89.016373 89.013336 89.008331 89.01252 89.008194 89.001564 89.001175 89.011078 89.027977 89.027832 89.001747 88.955109 88.904106 88.876015 88.887024 88.873375 88.870247 88.874435 88.887337 88.900146 88.915833 88.939438 * * * * * * * * * * * * 89.683731 89.714027 89.744164 89.8032 89.873604 89.917435 89.955704 90.004761 90.041847 90.055435 90.054863 * 90.050079 90.06253
8 90.078659 90.076439 90.095253 90.145241 90.178856 90.188148 90.174812 90.136322 90.089622 * * 89.845909 89.749458 89.658844 89.571747 89.491783 89.397217 89.286057 89.215904 89.175758 * 89.223595 89.297798 89.363838 89.424843 89.489067 * * * * * * * * * * * * * * * * * * * * * 90.438713 90.463951 90.482582 90.512543 90.533241 90.546059 90.558304 90.566673 90.570992 90.577713 90.589905 90.60125 90.622978 90.632996 * * * * * * * * * * * * * * * * * * * * * 90.495468 90.54277 90.550552 * * * * * * * * * * * * * * * * 90.210785 90.213051 90.233627 90.250313 90.257805 90.264771 90.273758 * *
+89.294777 89.295341 89.282745 89.267685 89.260986 * 89.255089 89.248444 89.243782 89.241676 89.235786 89.229233 89.221703 89.213646 89.207237 89.202576 89.201012 89.196808 89.194473 89.192978 89.182304 89.169792 89.163673 89.159103 89.153183 89.138649 89.128456 89.123482 89.116974 89.110268 89.104492 89.104645 89.104477 89.095001 89.088608 89.093208 89.078056 89.057945 89.059341 89.048248 89.035614 89.035416 89.031792 89.024567 89.026062 89.014931 89.001373 89.000328 88.991005 88.975311 88.965492 88.957535 88.950699 88.942764 88.934189 88.929855 88.926781 88.930763 88.937241 88.9422 88.951675 88.967171 88.974113 88.973007 88.976013 88.986069 88.978615 88.980499 88.985931 88.979935 88.973869 88.978539 88.994003 88.994179 88.962112 88.912163 88.874023 88.85331 88.851173 88.842789 88.847389 88.844719 88.858627 88.87484 88.887253 88.913116 * * * * * * * * 89.607552 * * * 89.679871 89.702812 89.730026 89.779945 89.837067 89.88855 89.948517 90.001175 90.021378 90.027298 90.041206
90.055359 90.049728 90.050896 90.050835 90.04467 90.079399 90.125244 90.156281 90.166809 90.146965 90.110352 90.067802 89.998398 * 89.809593 89.700363 89.596542 89.499046 89.409584 89.317162 89.23156 89.182007 89.159386 89.177475 89.227966 89.294304 89.379051 89.450951 89.519867 89.597137 * * 89.798607 89.877968 89.939484 90.000916 90.056664 * * * * * * * * * * * * * 90.450569 90.477257 90.499001 90.516174 90.533699 90.547562 90.549004 90.554482 90.562477 90.568642 90.58007 90.591499 90.612488 90.628052 * * * * * * * * * * * * * * * * * * * * 90.450981 90.50634 90.54557 90.542747 * * * * * * * * * * * * * * * * 90.1968 90.213188 * 90.22126 90.232391 * * * *
+89.295036 89.288445 89.269417 * 89.263023 89.253342 89.247459 89.241302 89.23996 89.236984 89.229584 89.22287 89.215172 89.208626 89.20269 89.197281 89.196861 89.19313 89.186813 89.181313 89.170074 89.161354 89.158646 89.156067 89.158966 89.14518 89.125465 89.117287 89.110992 89.104965 89.09774 89.091103 89.086975 89.080482 89.078362 89.084816 89.071098 89.051163 89.055038 89.040665 89.026321 89.02626 89.027275 89.024178 89.021988 89.01329 88.997925 88.991295 88.977516 88.960846 88.952484 88.944908 88.937424 88.92952 88.925179 88.924118 88.913841 88.913155 88.919464 88.92495 88.935638 88.949326 88.952797 88.944359 88.938072 88.947845 88.945045 88.945679 88.949455 88.944206 88.941132 88.946907 88.961304 88.957306 88.929108 88.883789 88.848404 88.819771 88.802719 88.814697 88.822845 88.824051 88.82827 88.848602 88.863121 88.886269 * * * * * * * 89.574318 89.600525 89.632057 89.659691 89.670143 89.677444 89.691055 89.71534 89.757324 89.80703 * * * 90.002052 * 90.030266 90.05171
2 90.045296 90.035301 90.016731 90.022484 90.065636 90.103241 90.129677 90.141312 90.121201 90.087074 90.045052 89.975845 89.881493 89.768082 89.655159 89.547882 89.440048 89.324905 89.224602 89.17511 89.145973 89.142838 89.178894 89.237762 89.306709 89.389015 * * 89.650681 * * 89.799141 89.901978 89.97126 90.030037 90.085365 90.133774 * * * * * * * * * * * 90.444359 90.46405 90.489731 90.501167 90.510986 90.528587 90.536171 90.534119 90.540947 90.551849 90.559517 90.571457 90.584373 90.603386 90.619843 * * * * * * * * * * * * * * * * * * * * 90.459549 90.512352 90.536835 90.527863 * * * * * * * * * * * * * * * * 90.166618 90.217506 * * * * * * *
+89.291878 89.279617 * * 89.264412 89.257607 89.249634 89.241302 89.232727 89.228767 89.223999 89.216919 89.209862 89.204018 89.198181 89.192345 89.191223 89.193481 89.187843 89.175667 89.165131 89.157509 89.149483 89.149933 89.15461 89.143883 89.120529 89.109718 89.104477 89.099113 89.090973 89.083321 89.076912 89.068581 89.063995 89.068283 89.065292 89.047134 89.049599 89.035522 89.01857 89.015289 89.013329 89.012978 89.010139 89.004456 88.996681 88.981819 88.961479 88.949409 88.941765 88.934113 88.926422 88.918457 88.912102 88.911453 88.90181 88.896873 88.902794 88.907082 88.91835 88.928368 88.927238 88.918579 88.909042 88.906647 88.90493 88.906784 88.906303 88.900307 88.905518 88.914742 88.920326 88.916428 88.894363 88.855667 88.814941 88.786316 88.782555 88.792328 88.791153 88.799255 88.807236 88.832481 88.850891 * * * * * * 89.449692 89.534576 89.5718 89.595276 89.623558 89.652679 89.664497 89.67556 89.685959 89.702835 * * * * * * * 90.023857 90.022797 90.024261 90.0083
01 89.978592 89.996712 90.036911 90.075111 90.096283 90.103287 90.083435 90.053436 90.012268 89.938934 89.837547 89.71624 89.599243 89.487007 89.36853 89.230385 89.136154 89.120506 89.120285 89.138916 89.178146 89.23912 89.323135 * * * * * * * 89.886528 89.97644 90.038643 90.103149 90.159798 90.205681 90.266495 90.309227 * * * * * * 90.42215 90.437698 90.452774 90.477623 90.488472 90.492096 90.503098 90.512932 90.514023 90.515434 90.523132 90.534485 90.544754 90.562958 90.577515 90.593025 90.61116 * * * * * * * * * * * * * * * * * * * 90.404968 90.46006 90.50782 90.52169 90.507362 * * * * * * * * * * * * * * * * * * * * * * * * *
+89.289513 * 89.275642 89.270981 89.266769 89.260918 89.254768 89.241829 89.226044 89.223587 89.21962 89.211288 89.205406 89.19957 89.193619 89.18737 89.183212 89.186256 89.185677 89.171875 89.165207 89.157585 * 89.145729 89.146873 89.135773 89.114685 89.105347 89.097763 89.090523 89.082878 89.07415 89.06929 89.061646 89.05291 * 89.067505 89.046249 89.035622 89.033569 89.016182 89.004646 88.996895 89.000565 89.000282 88.995125 88.992409 88.976028 88.950096 88.939262 88.931442 88.923538 88.915627 88.907677 88.899826 88.892776 88.888451 88.885834 88.888763 88.891197 88.894669 88.898788 88.889366 88.883179 88.881531 88.871452 88.868423 88.87291 88.873039 88.869629 88.869102 88.878517 88.880913 88.875534 88.855644 88.81601 88.789902 88.768456 88.761368 88.76944 88.763855 88.771904 * 88.818993 88.832458 * * * * * 89.334579 89.432648 89.492462 89.536903 89.57206 89.597275 89.610611 89.617332 89.638367 89.661629 89.693886 89.739571 * * * * * * 90.022034 90.007271 89.990952 * 89.9415
97 89.964439 89.997528 90.038834 90.062378 90.063927 90.038788 90.004677 89.962105 89.889832 89.783302 89.653259 89.529327 89.406334 89.276611 * * 89.099762 89.108025 89.137108 89.187927 * * * * * * * * * * * 90.03743 90.116325 90.17733 90.226379 90.297768 90.341721 * * * * * * 90.433167 90.446678 90.460281 90.474365 90.479393 90.479347 90.482307 90.489182 90.493469 90.498886 90.506363 90.516838 90.527649 90.547562 90.567787 90.584862 90.604218 * * * * * * * * * * * * * * * * * * * 90.394112 90.451683 90.496201 90.50061 90.475113 90.449051 * * * * * * * * * * * * * * * * * * * * * * * *
+* 89.286713 89.282974 89.276711 89.270294 89.260628 89.252617 89.239029 89.227249 89.223312 89.214859 89.206123 89.200638 89.195084 89.189041 89.182846 89.176483 89.173553 89.174088 89.167778 89.161133 89.154289 89.14695 89.142365 89.13649 89.12693 89.117805 89.109268 89.099808 89.088264 89.076202 89.066917 89.063423 89.055656 * 89.050117 89.060188 89.040756 89.020706 89.029716 89.024536 89.004654 88.988541 88.98584 88.988029 88.983788 88.974663 88.963776 88.942345 88.926384 88.920799 88.912773 88.904587 88.896431 88.888245 88.879677 88.878548 88.878792 88.874847 88.871864 88.869392 88.869278 88.857033 88.850456 88.848351 88.836029 88.834045 88.843544 88.845856 88.844032 88.832016 88.829483 88.838684 88.83699 88.814697 88.781281 88.780502 88.749397 88.723007 88.74144 88.745293 88.757774 88.792 88.803337 * * * * * 89.219597 89.31221 89.39447 89.44117 89.47744 89.509964 89.534698 89.543488 89.550774 89.568398 89.604759 89.661697 89.731041 89.812378 89.882385 89.940353 89.98418
4 90.013161 90.029388 90.015465 90.00161 * * 89.905907 89.927238 89.955505 89.99604 90.019905 90.014938 89.985825 89.943024 89.899178 89.830872 89.720276 89.586555 89.459221 89.331421 89.201607 * 89.092857 89.094162 89.095993 89.138832 89.208282 * 89.431801 * * * * * * * * * * 90.118538 90.186523 90.244247 90.317894 90.365341 90.383636 90.402397 90.409126 90.40889 90.41317 * 90.440247 90.453743 90.459663 90.46212 90.458466 90.454994 90.45858 90.467819 90.478271 90.48481 90.492149 90.502663 90.515724 90.53421 90.556831 90.579147 90.598724 * * * * * * * * * * * * * * * * * * * 90.365807 90.42897 90.468124 90.462372 90.43441 90.409714 * * * * * * * * * * 90.10186 90.158478 * * * * * * * * * * * *
+* * * 89.283012 89.276917 89.263191 89.244049 89.234047 89.232506 89.222023 89.211281 89.206718 89.198059 89.190674 89.184456 89.178345 89.171997 89.164001 89.158211 89.155495 89.150124 89.146698 89.144974 89.134216 89.122131 89.11515 89.112877 89.109009 89.101898 89.086639 89.069664 89.062729 89.057762 89.051994 89.044434 89.043236 89.044212 89.036919 89.014565 89.010651 89.023216 89.012016 88.99028 88.973061 88.969254 88.964745 88.950493 88.948204 88.94413 88.926758 88.909363 88.901558 88.89344 88.884964 88.876534 88.868126 88.867302 88.871864 88.86422 88.846672 88.844841 88.848694 88.838615 88.829475 88.821434 88.813576 88.809456 88.811256 88.814949 88.813591 88.80471 88.792137 88.788208 88.790985 88.770828 88.753815 88.751701 88.711037 88.685745 88.708336 88.721512 88.734558 88.770325 88.794144 * 88.834625 * 89.005676 89.129082 89.205574 89.258987 89.317734 89.371468 89.404701 89.429649 89.450272 89.451958 89.460999 89.492065 89.539604 89.604614 89.688103 89.788986 89.87
1056 89.924622 89.974976 90.013657 90.024704 90.006561 * * * * 89.880737 89.912285 89.94548 89.965775 89.954559 89.922234 89.879135 89.836113 89.765076 89.655548 89.530289 89.398392 89.265686 89.149063 * 89.079659 89.08007 89.085831 89.13147 89.231728 89.374199 89.49691 89.581413 * * * * * * * * * * 90.189209 90.258141 90.331894 90.374657 90.395142 90.408218 90.403603 * * 90.438141 90.451271 90.450264 90.446465 90.440018 90.432716 90.43264 90.437561 90.442261 90.453781 90.465523 90.477364 90.491096 90.506157 90.531067 90.554619 90.572395 90.591743 * * * * * * * * * * * * * * * * * * * * 90.396118 90.423119 90.409386 90.385521 90.367607 90.33712 * * * * * * * * 90.097939 90.163361 90.227287 90.292328 90.332504 90.358582 90.38578 * * * * * * * *
+* * * 89.292221 89.285744 89.269577 89.242203 89.232475 89.229965 89.216751 89.209724 89.205971 89.195152 89.186241 89.179909 89.173416 89.166321 89.157097 89.148575 89.142982 89.136879 89.135483 89.141975 89.130013 89.111275 89.104095 89.099739 89.098381 89.094078 89.082504 89.066917 89.056786 89.049126 89.046066 89.046837 89.036797 89.029457 89.035324 89.020393 * 88.996613 88.998459 88.988579 88.971039 88.961723 88.959282 88.945778 88.933243 88.934296 88.92868 88.906708 88.890213 88.881973 88.873329 88.864639 88.855927 88.850967 88.854492 88.852119 88.832405 88.820702 88.822556 88.815956 88.806808 88.800613 88.797798 88.791801 88.783501 88.78566 88.783844 88.780975 88.771484 88.75206 88.746841 88.729172 88.722549 88.708595 88.67704 88.668663 88.683693 88.691978 88.701065 88.738426 88.780815 88.795914 88.813385 * 88.981033 89.082108 89.159348 89.198792 89.232422 89.282028 89.319717 89.339546 89.345573 89.336021 89.349106 89.400711 89.464081 89.539772 89.628487 89.746841 89.
852913 89.906075 89.948311 89.998985 90.014297 89.997406 * * * * 89.828949 89.863991 89.892883 89.910561 89.893646 89.84726 89.802917 89.760208 89.689796 89.586868 89.47142 89.334259 89.18895 89.095322 89.063629 89.064209 89.066795 89.071907 89.115349 89.251968 89.42939 89.540184 89.625359 89.700043 * * * * * * * * * * 90.263466 90.344093 90.394012 90.402412 90.395615 90.395401 90.416031 90.436676 90.450241 90.450111 90.434311 90.418633 90.415222 90.414864 90.409401 90.404358 90.404907 90.423256 90.445251 90.459183 90.48143 90.502258 90.52932 90.556198 90.571411 90.584045 * * * * * * * * * * * * * * * * * * * * 90.351753 90.368256 90.352783 90.327682 90.310051 90.27935 * * * * * * * * 90.132866 90.198631 90.262085 90.323906 90.363892 90.395714 90.425873 * * * * * * * *
+89.435982 89.387001 89.315521 89.30162 89.291618 89.275902 89.250633 89.234085 89.221405 89.207336 89.204094 89.19902 89.188446 89.181526 89.17511 89.16758 89.159546 89.151772 89.143875 89.136696 89.129272 89.125374 89.130272 89.123756 89.111702 89.102814 89.09301 89.086151 89.08387 89.080734 89.063896 89.047951 89.041183 89.035332 89.037788 89.030563 89.016991 89.01828 89.0186 88.999527 88.984879 88.974037 88.968651 88.95974 88.951492 88.951263 88.945183 88.928535 88.915764 88.910538 88.905472 88.884254 88.869171 88.861557 88.852554 88.843567 88.834862 88.829933 88.827972 88.818871 88.805992 88.792015 88.781792 88.777512 88.773491 88.774002 88.770691 88.763161 88.763596 88.764046 88.758324 88.747581 88.732399 88.715225 88.696663 88.685219 88.685875 88.671234 88.664925 88.669487 88.666885 88.669296 88.701714 88.744301 88.766144 88.782677 88.853752 88.946495 89.024376 89.097389 89.133942 89.155197 89.197098 89.229675 89.24601 89.241768 89.226578 89.244194 89.304077 89.369225
89.455391 89.5597 89.691261 89.824059 89.893639 89.931793 89.981506 90.001335 89.987778 * * * * 89.77697 89.817955 89.847519 89.851944 89.822876 89.770851 89.71698 89.656723 89.5896 89.503357 89.390297 89.248611 89.105324 89.050217 89.047531 89.049065 89.052498 * * * 89.478584 89.580765 89.662575 89.736931 * * * * * * * * * * 90.280006 90.360077 90.394295 90.383598 90.377106 90.3918 90.421227 90.44072 90.438927 90.428665 90.407967 90.395241 90.392349 90.384888 90.373146 90.365128 90.369751 90.393616 90.42411 90.440575 90.468307 90.503189 90.529762 90.555061 90.572464 90.579063 * * * * * * * * * * * * * * * * * * * * 90.302704 90.306984 90.288933 90.270966 90.248322 90.209099 * * * * * * * 90.081047 90.160126 90.221199 90.282959 90.338921 90.383461 90.416664 90.449341 90.468048 * * * * * * *
+89.45462 89.418297 89.338921 89.313095 89.296455 89.282684 89.258003 89.23278 89.212502 * 89.203506 89.198219 89.186226 89.177475 89.16983 89.162231 89.154388 89.146667 89.138908 89.131905 89.124847 89.118134 89.112694 89.108383 89.108955 89.10614 89.093132 * 89.081268 89.075592 89.056412 89.039795 89.033852 89.026207 89.02211 89.021393 89.008873 88.99865 89.005104 89.001289 88.98896 88.967789 88.954231 88.94854 88.939491 88.927864 88.922798 88.923271 88.914146 88.894302 88.888748 88.874001 88.857002 88.849617 88.840286 88.831001 88.821503 88.812202 88.802979 88.79538 88.793083 88.774673 88.761108 88.760841 88.749443 88.748283 88.745659 88.741997 88.748627 88.751289 88.733604 88.718071 88.711578 88.688828 88.669868 88.64978 88.657944 88.659843 88.65239 88.654251 88.648132 88.640282 88.660347 88.701813 88.729172 88.75708 88.831139 88.907066 88.976135 89.04245 89.062622 89.080505 89.115318 89.12674 89.12104 89.118515 89.116394 89.135376 89.187775 89.251633 89.355988 89.488029
89.628601 89.770927 89.8685 89.924446 89.969582 89.983078 * * * * * * 89.768806 89.80117 89.788391 89.755325 89.702377 89.632874 89.549614 89.478004 89.401299 89.282394 89.135971 89.035736 89.022766 89.030258 89.034767 * * * * 89.523643 89.625557 89.696434 89.760086 * * * * * * * * * * 90.303017 90.358467 90.365273 90.362808 90.3741 90.385551 90.394737 90.406754 90.407944 90.397552 90.386452 90.373589 90.355591 90.340965 90.33416 90.334465 90.343483 90.364922 90.398323 90.427788 90.458466 90.500153 90.529678 90.553154 90.572121 90.57914 * * * * * * * * * * * * * * * * * * * * * 90.244095 * 90.211571 * * * * * * * * * 90.115135 90.189537 90.249313 90.303543 90.357101 90.40593 90.440681 90.473068 90.490837 * * * * * * *
+89.443443 89.408447 89.344109 89.321381 89.304192 89.285965 89.257996 89.228592 89.204338 * 89.206581 89.198166 89.185646 89.173531 89.165176 89.157425 89.149193 89.140869 89.133728 89.126694 89.119606 89.112259 89.103935 89.096275 89.093666 89.097412 89.095131 89.091599 89.085159 89.07032 89.051521 89.039368 89.02906 89.019516 89.010956 89.006866 89.001534 88.993874 88.991135 88.980766 88.972916 88.962662 88.953484 88.945503 88.929382 * 88.906311 88.904106 88.910927 88.898285 88.874931 88.858551 88.846123 88.837257 88.827827 88.81823 88.80864 88.798981 88.788177 88.778397 88.772484 88.762558 88.755875 88.754364 88.739807 88.731171 88.726128 88.723381 88.730209 88.730026 88.709198 88.695869 88.691307 88.666885 88.646233 88.635384 88.633553 88.633003 88.625259 88.625397 88.620186 88.613159 88.636269 88.67186 88.694458 88.720825 88.783218 88.863312 88.936005 88.986992 88.997414 89.006851 89.025055 89.013763 88.985321 88.986671 89.010841 89.041161 89.080315 89.149498 89.275452
89.4254 89.561111 89.696617 89.834869 89.922844 89.960808 89.974052 * * * * * * 89.708969 89.750237 89.742821 89.715546 89.646065 89.543892 89.451515 89.376007 89.271294 89.127983 89.025688 88.999878 89.008415 89.015327 89.019386 * * * * 89.544121 89.654976 89.726044 89.790085 89.846863 * * * * * * * * * 90.315819 90.336281 90.342644 90.35923 90.37252 90.370552 90.353477 90.34848 90.366379 90.365356 90.350784 90.331749 90.313278 90.306564 90.30423 90.306892 90.314537 90.336037 90.370644 90.410011 90.448143 90.491783 90.526482 90.551521 90.569336 90.574677 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 90.071083 90.156418 90.220192 90.273567 90.324089 90.377129 90.42733 90.466675 90.496437 * * * * * * * *
+89.453438 89.417168 * 89.321907 89.302208 89.282143 89.253044 89.223419 89.202774 89.198357 89.198486 89.190041 89.178864 89.168694 89.160355 89.151466 89.142982 89.135582 89.128624 89.121475 89.114235 89.106903 89.09967 89.091255 89.082817 89.080223 89.087662 89.089699 89.081703 89.066612 89.050545 89.038193 89.021896 89.010567 89.003365 88.994637 88.990005 88.988716 88.976822 88.95919 88.950844 88.94416 88.938278 88.923691 * 88.916664 88.915443 88.887932 88.886681 88.893234 88.87117 88.853371 88.838478 88.824669 88.815163 88.805267 88.795341 88.785378 88.775597 88.765656 88.754738 88.747627 88.744888 88.741936 88.734688 88.724861 88.712196 88.707405 88.708672 88.703468 88.692581 88.684204 88.675346 88.6548 88.63401 88.633965 88.629333 88.619667 88.606552 88.598473 88.589951 88.588097 88.609268 88.634468 88.655708 88.670273 88.72657 88.819893 88.899246 88.936905 88.938629 88.936272 88.928459 88.907875 88.891533 88.897713 88.926247 88.969437 89.012001 89.090302 89.22715 89.3
75854 89.525429 89.674812 89.819298 89.910629 89.943329 89.974571 * * * * * * 89.633682 89.703506 89.704536 89.667435 89.564667 89.434006 89.336983 89.250229 89.112671 88.994362 88.973183 88.985748 88.994148 88.997757 * * * * * 89.546959 89.680824 89.75795 89.821266 89.882957 89.949524 * * * * * 90.257973 90.293365 90.308838 90.31234 90.318657 90.347511 90.366226 90.353722 * * 90.293839 90.302597 90.311096 90.289024 90.269821 90.265968 90.264389 90.261597 90.262077 90.278099 90.313324 90.356468 90.401688 90.441788 90.485092 90.519264 90.542786 90.558372 90.560715 90.550491 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 90.024948 90.108307 90.186623 90.249878 90.293877 90.341545 90.397972 90.449165 90.491394 90.51828 * * * * * * * *
+* * * 89.359276 89.303726 89.271576 89.245331 89.219131 89.2024 89.194298 89.188606 89.182152 89.173019 89.163368 89.153969 89.145348 89.137611 89.130722 89.123543 89.116257 89.108887 89.101425 89.093849 89.086357 89.07859 89.06974 89.069466 89.071091 89.063271 89.057274 89.051636 89.033737 89.014679 89.003197 88.994362 88.987091 88.978668 88.975204 88.968079 88.954559 88.943939 88.932289 88.921112 * * 88.914505 88.911491 88.878166 88.865829 88.868492 88.858673 88.85051 88.834465 88.810287 88.800758 88.792076 88.78183 88.771553 88.761253 88.750938 88.7407 88.733253 88.729141 88.725204 88.722328 88.716324 88.69912 88.686409 88.684929 88.687439 88.68367 88.667717 88.649872 88.638878 88.628548 88.622643 88.614616 88.605118 88.594864 88.586487 88.571609 88.568436 88.578827 88.585541 88.608116 88.628334 88.690781 88.784943 88.858681 88.883377 88.877197 88.86631 88.841492 88.831085 88.822525 88.8265 88.857025 88.896286 88.947876 89.043472 89.19178 89.336388 89.501106 89.674866 89.
801361 89.879936 89.921021 89.972488 89.989838 * 89.92244 * * * * 89.614929 89.634911 89.562843 89.4319 89.295204 89.185768 89.095634 88.999687 * 88.964096 88.972054 88.976913 88.979294 * * * * * * 89.71846 89.78614 89.850151 89.917374 89.987419 90.050735 90.100082 90.145599 90.202003 90.249847 90.282906 90.298615 90.29377 90.293953 90.321251 90.363586 90.356865 * * * * 90.229668 90.224243 90.20945 90.19989 90.199333 90.202393 90.210121 90.230865 90.266296 90.314278 90.36763 90.40757 90.441757 90.479118 90.505798 90.524147 90.535133 90.536758 90.528877 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.98362 90.061493 90.137871 90.214279 90.272972 90.316406 90.365067 90.420082 90.471359 90.512436 90.535713 * * * * * * * *
+* * 89.509521 89.443939 89.335007 89.261528 89.233696 89.214394 89.19416 89.189285 89.185829 89.178993 89.172432 89.160637 89.149063 89.139839 89.132912 89.125771 89.118446 89.111038 89.103539 89.09594 89.088242 89.080452 89.072556 89.064468 89.056007 89.050735 89.041656 89.042938 89.049751 89.03698 89.019661 89.006706 88.990967 88.977203 88.967461 88.964294 88.969315 88.957642 88.937729 88.929581 88.921806 88.911354 88.911026 88.902306 88.880707 88.865295 88.860458 88.852158 88.842278 88.837143 88.83255 88.81736 88.793945 88.778763 88.768105 88.757469 88.746811 88.736023 88.726158 88.719543 88.714546 88.710007 88.705109 88.697861 88.685303 88.668777 88.659599 88.66703 88.674561 88.662483 88.634781 88.615166 88.610107 88.600883 88.589851 88.581566 88.573677 88.569092 88.553276 88.546379 88.54792 88.534698 88.557884 88.594582 88.644867 88.734634 88.8013 88.806625 88.804787 88.794617 88.764877 88.769325 88.762306 88.764755 88.799377 88.834442 * * 89.167099 * * 89.62812 89.7699
05 89.857689 89.912193 89.966507 89.98494 * 89.902489 89.861534 * * * 89.460014 89.517654 89.426003 89.278358 89.134964 89.021019 88.975281 88.961449 88.956268 88.951942 88.95845 88.964661 * 89.102844 89.269272 89.381721 89.472992 89.562866 89.676903 89.749649 89.810966 89.88131 89.945419 90.016899 90.084862 90.130585 90.179367 90.240311 90.277596 90.277405 90.269524 90.269691 90.298004 90.344986 90.354774 * * * * * * * 90.125153 90.135643 90.146309 90.164925 90.198654 90.240906 90.28627 90.339485 90.38623 90.416351 90.447067 90.477013 90.496117 90.506126 90.509048 90.507393 90.496735 90.473549 * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.949532 90.007713 90.077179 90.166786 90.243004 90.293045 90.338234 90.386261 90.439751 90.492821 90.527328 90.547142 * * * * * * * *
+* * 89.560844 89.501671 89.367607 89.260391 89.219566 89.205498 89.188103 89.184464 89.1847 89.180077 89.172432 89.163132 89.150574 89.135773 89.127594 89.120705 89.113358 89.10582 89.098183 89.090446 89.082611 89.074669 89.066628 89.058502 89.049911 89.040665 89.03112 89.028023 89.036934 89.039452 89.025414 89.011971 88.994728 88.974716 88.961624 88.95504 88.96212 88.950058 88.923836 88.927292 88.929329 88.91713 88.910332 88.891037 88.860489 88.851433 88.849876 88.846481 88.834015 88.820251 88.824959 88.831856 88.789474 88.765266 88.754158 88.743156 88.732124 88.72094 88.710754 88.704636 88.700035 88.695518 88.686867 88.677055 88.668663 88.656372 88.642059 88.635025 88.647697 88.659042 88.632103 88.595085 88.583199 88.576408 88.566673 88.557533 88.548134 88.540298 88.52919 88.516365 88.502884 88.496521 88.519447 88.555679 88.584099 88.651726 88.716125 88.719528 88.714516 88.70388 88.686127 88.687225 88.700043 88.717903 88.74633 88.80191 * * 89.156647 89.336182 89.493065 89.
605537 89.735558 89.831558 89.906349 89.966354 89.982307 * * * * * * * 89.336479 89.28907 89.112457 88.965881 88.909554 88.915092 88.93364 88.936295 88.933289 88.942871 88.950272 88.998116 89.174217 89.330452 89.430099 89.51622 89.613106 89.71489 89.778488 89.842514 89.907661 89.968979 90.040581 90.104767 90.154366 90.210121 90.263077 90.266922 90.234245 90.23597 90.273735 90.321602 90.349098 * * * * * * * * * 90.095589 90.132942 90.172455 90.221375 90.263229 90.306709 90.360329 90.397064 90.421921 90.448532 90.469551 90.480873 90.484932 90.484856 90.480072 90.462212 * 90.421944 * * * * * * * * * * * * * * * * * * * * * * * * * * 89.961418 90.016998 90.095551 90.192024 90.269882 90.320709 90.36348 90.406105 90.45845 90.509499 90.541634 90.560959 * * * * * * * *
+* * 89.553207 89.515038 89.381531 89.26136 89.212044 89.201027 89.189621 89.184059 89.181198 89.177864 89.167206 89.16082 89.151421 89.135811 89.124763 89.115952 89.108269 89.100609 89.092834 89.084953 89.076973 89.068886 89.060692 89.052391 89.043999 89.035477 89.026947 89.01741 89.017311 89.023766 89.01783 89.009171 88.997375 88.989296 88.964066 88.941788 88.940201 88.931335 88.912361 88.920547 88.923401 88.911278 88.90316 88.886383 88.856354 88.836029 88.835907 88.843727 88.831024 88.81514 88.813843 88.805969 88.769089 88.751373 88.739998 88.728607 88.717186 88.705574 88.695114 88.689552 88.685265 88.678749 88.66758 88.657616 88.648293 88.637817 88.625656 88.609932 88.608887 88.620277 88.603806 88.574257 88.560753 88.552139 88.542534 88.532951 88.523453 88.513466 88.505226 88.490211 88.472786 88.47982 88.492561 88.512962 88.526764 88.557968 88.605896 88.624626 88.613251 88.603287 88.598625 88.596222 88.630302 88.664322 88.705093 * * * 89.146141 89.308502 89.490669 89.6090
7 89.70533 89.790436 89.883255 89.959534 89.974899 89.958733 * * * * * * * * 88.980637 * * 88.886856 88.902069 88.909882 88.916008 88.922569 * 89.024323 89.240608 89.374779 89.465431 89.55072 89.655823 89.742355 89.814667 89.87635 89.930122 89.994423 90.065559 90.119003 90.175095 90.222061 90.228119 90.206009 90.206238 90.253197 90.308487 90.340195 * * * * * * * * * 90.047089 90.08622 90.143387 90.196449 90.237221 90.275787 90.31488 90.361244 90.397644 90.417679 90.437088 90.449623 90.456406 90.458298 90.455223 90.446251 90.427414 90.408684 90.398087 * * * * * * * * * * * * * * * * * * * * * * * * * 89.912247 89.964378 90.032234 90.123199 90.223312 90.301567 90.352852 90.396255 90.435471 90.478203 90.521156 90.557167 90.577705 * * * * * * * *
+* * 89.535782 89.516426 89.394028 89.265221 89.213669 89.202141 89.189476 89.182053 89.173691 89.168411 89.159958 89.151146 89.141113 89.133316 89.124107 89.112221 89.103218 89.095398 89.087486 89.079468 89.071342 89.063103 89.054756 89.046295 89.03772 89.029037 89.020256 89.011169 89.002213 88.99675 88.999191 89.002747 88.995262 88.987946 88.955597 88.930519 88.922974 88.914452 88.903908 88.901291 88.895348 88.890961 88.889252 88.878494 88.854507 88.826607 88.824318 88.833633 88.82518 88.817314 88.807724 88.767693 88.74659 88.737305 88.725609 88.713829 88.702003 88.689842 88.679634 88.675026 88.669617 88.659157 88.647507 88.63797 88.626534 88.614906 88.6035 88.591209 88.580452 88.572701 88.561829 88.54985 88.539825 88.52919 88.518852 88.508766 88.498978 88.48954 88.480621 88.470093 88.456261 88.444672 88.448364 88.460068 88.456985 88.472687 88.498047 88.512787 88.516586 88.526329 88.518692 88.525681 88.569565 88.601654 88.670753 88.792831 88.911652 89.032082 89.144897 89.26
9043 89.443436 89.600426 89.690407 89.761299 89.845055 89.915024 89.936836 89.934349 * * * * * * * * * 88.896118 88.871597 88.869667 88.879753 88.889481 88.897354 88.899277 * * 89.298279 89.41375 89.498039 89.596275 89.693306 89.773125 89.849434 89.907417 89.962112 90.024971 90.087013 90.139572 90.179947 90.180168 90.154495 90.1642 90.231842 90.29657 90.323975 90.339279 90.318748 * * * * * * * * 90.028145 90.088844 90.153458 90.206085 90.245636 90.282768 90.310585 90.342201 90.372658 90.390411 90.405045 90.414444 90.423409 90.426842 90.419685 90.40844 90.392853 90.381256 90.370682 * * * * * * * * * * * * * * * * * * * * * * * * 89.88591 89.931892 89.983955 90.066818 90.164398 90.258972 90.332542 90.380348 90.423538 90.463829 90.500206 90.538063 90.570526 90.585365 * * * * * * * *
+* * * 89.526733 89.41021 89.277695 89.211288 89.1931 89.183754 89.176506 89.169411 89.159492 89.155502 89.1474 89.129601 89.123268 89.117355 89.107735 89.098228 89.090195 89.082146 89.073982 89.065712 89.05732 89.04882 89.040192 89.031456 89.022591 89.013611 89.004524 88.994637 88.981682 88.977852 88.984718 88.976936 88.955376 88.936516 88.924072 88.914642 88.903915 88.893929 88.882355 88.871155 88.863922 88.858963 88.859482 88.855774 88.836365 88.813019 88.804588 88.806023 88.805382 88.796722 88.753647 88.734055 88.723152 88.711006 88.698807 88.686546 88.67392 88.664207 88.659538 88.651428 88.638763 88.627434 88.617256 88.604836 88.59272 88.580452 88.569801 88.55909 88.546112 88.535164 88.526093 88.516418 88.505302 88.494431 88.483841 88.473511 88.463455 88.453743 88.444695 88.42807 88.401367 88.402611 88.410164 88.395874 88.404877 88.417984 88.416641 88.424942 88.456337 88.460335 88.466728 88.506279 88.540276 88.631401 88.772903 88.899063 89.024635 89.143097 89.249329 89.4
08005 89.566399 89.665657 89.740837 89.803528 89.844604 89.868362 89.879852 89.81916 * 89.634171 89.521156 * * * * * 88.865929 88.861382 88.854561 88.861565 88.870903 88.872612 * 89.004814 89.187981 89.341095 89.43914 89.530037 89.634575 89.719711 89.803741 89.870483 89.930252 89.992935 90.050285 90.103622 90.13549 90.129257 90.109795 90.113869 90.179657 90.270027 90.305916 90.308296 90.314125 90.297829 90.263565 * * * * * * * 90.002327 90.086006 90.151772 90.204842 90.25016 90.275558 90.292381 90.315254 90.337639 90.353043 90.364052 90.369484 90.374695 90.376915 90.371506 90.363914 90.351212 90.351677 90.347908 * * * * * * * * * * * * * * * * * * * * * * * 89.872688 89.90284 89.954865 90.027618 90.122612 90.211853 90.294624 90.362579 90.412231 90.454491 90.489174 90.523308 90.555382 90.576866 90.583054 * * * * * * * *
+* * * 89.565315 89.440025 89.294716 89.208038 89.179863 89.176376 89.172935 89.16861 89.15374 89.14743 89.141335 89.124428 89.115913 89.108444 89.10141 89.09314 89.085007 89.07682 89.068512 89.060089 89.051544 89.042885 89.034096 89.025185 89.016151 89.006989 88.997734 88.988228 88.977921 88.96608 88.959999 88.949989 88.933556 88.925575 88.916916 88.906052 88.895439 88.884682 88.873611 88.862556 88.849663 88.836945 88.834007 88.840561 88.838249 88.813187 88.782127 88.776077 88.782677 88.781494 88.73999 88.719643 88.708679 88.696266 88.683533 88.670761 88.658028 88.649727 88.642853 88.630898 88.618156 88.607567 88.595451 88.582558 88.569679 88.55764 88.547379 88.535919 88.524971 88.513779 88.501396 88.490463 88.479439 88.468132 88.457001 88.446136 88.435577 88.425316 88.414948 88.402061 88.390144 88.389565 88.380539 88.34996 88.353546 88.363708 88.356384 88.350189 88.380447 88.410782 88.415359 88.438667 88.488503 88.583717 88.721039 88.85862 88.983704 89.101395 89.209618 89.3
57925 89.493553 89.611107 89.698914 89.749443 89.778633 89.795166 89.809845 89.785675 89.710274 89.611229 89.483749 89.367317 89.262062 89.139091 88.96344 * 88.815353 88.82988 88.835876 88.844658 88.850731 88.856628 * 89.068275 89.237114 89.357491 89.45549 89.560051 89.651924 89.735893 89.822815 89.883667 89.944031 90.007622 90.061737 90.088318 90.074707 90.055351 90.07769 90.131866 90.213234 90.27137 90.286179 90.286713 90.280815 90.264061 90.230644 90.185745 * * * * * * 89.988907 90.079041 90.152634 90.199509 90.225479 90.24099 90.261574 90.286964 90.303581 90.315048 90.326088 90.329941 90.331741 90.328239 90.323799 90.317574 90.301468 90.312019 90.320625 90.311142 90.300163 * * * * * * * * * * * * * * * * * * * * 89.860359 89.886597 89.924057 89.986694 90.079102 90.173859 90.2481 90.322708 90.388718 90.441528 90.484322 90.514366 90.541855 90.563774 90.575623 90.576569 * * * * * * * *
+* * * 89.601822 89.482063 89.319313 89.221214 89.181404 * 89.17215 89.167488 89.154968 89.142021 89.128922 89.119621 89.111984 89.104057 89.096016 89.088028 89.079826 89.071503 89.063049 89.054474 89.045776 89.036949 89.028 89.018921 89.009705 89.000389 88.990913 88.980263 88.970047 88.959686 88.948227 88.938011 88.929108 88.918671 88.907944 88.897217 88.886337 88.875313 88.864159 88.852837 88.84156 88.829987 88.816696 88.809639 88.807091 88.810226 88.7836 88.753647 88.757477 88.764824 88.72747 88.704506 88.692329 88.67984 88.667183 88.654121 88.641678 88.633987 88.62442 88.610222 88.597664 88.586693 88.573181 88.560089 88.547218 88.535866 88.524635 88.512718 88.500412 88.488686 88.475983 88.463997 88.453278 88.441238 88.429543 88.418114 88.406853 88.396492 88.386185 88.377075 88.372711 88.372429 88.353043 88.308632 88.314697 88.321938 88.312881 88.303673 88.317543 88.354141 88.378494 88.40004 88.452568 88.530952 88.662697 88.797386 88.912239 89.031471 89.147865 89.280777 89
.413528 89.54174 89.622009 89.669098 89.709572 89.725113 89.735779 89.72789 89.670319 89.560158 89.417068 89.291382 89.172691 89.043083 88.886963 88.788536 88.793793 88.802994 88.815613 88.830429 88.83493 88.85479 88.949265 89.09639 89.244606 89.361191 89.474525 89.582367 89.661636 89.742012 89.823891 89.890396 89.949516 90.008446 90.039322 90.019783 90.004326 90.029846 90.098808 90.172096 90.219055 90.244301 90.251328 90.249527 90.23793 90.217911 90.185333 90.139801 90.097786 90.065804 * * * * 89.985039 90.063828 90.14856 90.180092 90.178917 90.201424 90.22686 90.242043 90.250229 90.263176 90.276649 90.284142 90.28949 90.285606 90.281662 90.280159 90.269127 90.272911 90.280693 90.281433 90.268257 * * * * * * * * * * * * * * * * * * * 89.839119 89.868324 89.906807 89.959793 90.034019 90.125763 90.207794 90.271957 90.341537 90.404785 90.45327 90.493149 90.525551 90.550827 90.565819 90.568741 90.563858 * * * * * * * *
+* * * 89.647728 89.529373 89.345016 89.234329 89.18956 89.17086 89.171135 89.164383 89.154068 89.139862 89.123299 89.115204 89.107338 89.09935 89.09124 89.083015 89.074669 89.0662 89.057602 89.048874 89.040016 89.031029 89.021912 89.012657 89.003288 88.993828 88.983429 88.972153 88.962044 88.95208 88.941856 88.931442 88.920891 88.910187 88.899338 88.888344 88.87719 88.865891 88.854446 88.84285 88.831108 88.819214 88.807137 88.792671 88.779205 88.7882 88.787971 88.754631 88.731461 88.731255 88.727943 88.708374 88.68647 88.665955 88.653633 88.638901 88.624016 88.614021 88.603233 88.589462 88.577675 88.564545 88.550484 88.538261 88.526138 88.51413 88.501259 88.488724 88.475029 88.463043 88.450554 88.437485 88.425728 88.413544 88.40123 88.389061 88.377022 88.366882 88.3564 88.343506 88.332787 88.328529 88.315987 88.288696 88.288773 88.285858 88.276596 88.270454 88.268127 88.287643 88.337112 88.389427 88.429474 88.484558 88.604317 88.734924 88.845329 88.9589 89.083153 89.202339 8
9.333717 89.460625 89.534332 89.580528 89.625191 89.645699 89.653488 89.644951 89.587219 89.47081 89.331085 89.202156 89.034859 88.875946 88.782761 88.76255 88.774788 88.783875 88.797089 88.814789 88.82518 88.85585 88.975014 89.125694 89.260391 89.373802 89.489609 89.583611 89.65831 89.735641 89.813942 89.882454 89.942131 89.979141 89.967384 89.948502 89.986145 90.058693 90.133385 90.179939 90.196251 90.212166 90.208992 90.200218 90.187431 90.16993 90.138657 90.090538 90.052376 90.030968 90.001518 * * * 89.937477 90.023476 90.119087 90.147705 90.146545 90.17038 90.189583 90.19165 90.19561 90.214233 90.230011 90.239822 90.240723 90.237854 90.236824 90.238617 90.241562 90.241211 90.246651 90.249817 90.231728 90.211472 * * * * * * * * * * * * * * * * * 89.81546 89.852234 89.90107 89.949188 90.008575 90.087585 90.166191 90.237251 90.296097 90.357666 90.414352 90.456558 90.492065 90.524071 90.550842 90.563316 90.560555 * * * * * * * * *
+* * * 89.721962 89.586731 89.376266 89.236862 89.185234 89.167908 89.164474 89.156769 89.147675 89.134636 89.119301 89.11071 89.102722 89.094612 89.086372 89.078018 89.069527 89.060913 89.05217 89.043289 89.034271 89.025124 89.015831 89.006416 88.996918 88.986748 88.975388 88.965111 88.954994 88.944656 88.934174 88.923538 88.912743 88.901794 88.890694 88.879433 88.868011 88.85643 88.844688 88.832787 88.820732 88.808517 88.796143 88.783699 88.770317 88.761551 88.772987 88.76931 88.73259 88.705971 88.712036 88.71714 88.699791 88.672089 88.657532 88.63813 88.614975 88.596931 88.580864 88.565918 88.555473 88.542046 88.52845 88.516281 88.503975 88.490898 88.477257 88.464157 88.450027 88.436768 88.423798 88.409798 88.396904 88.385094 88.372063 88.359901 88.34761 88.3358 88.323975 88.310265 88.298141 88.287758 88.278671 88.269608 88.262688 88.253128 88.244911 88.237663 88.229218 88.226967 88.273018 88.348732 88.383095 88.425995 88.513107 88.652786 88.779411 88.873299 89.000359 89.1
16089 89.235779 89.364143 89.450203 89.499802 89.537003 89.556015 89.563812 89.547432 89.474533 89.353241 89.227226 89.083572 88.879929 * 88.735329 88.741112 88.751083 88.763786 88.779457 88.795395 88.813782 88.851379 88.986015 89.154228 89.282768 89.393135 89.49157 89.567001 89.642784 89.723412 89.80265 89.866356 89.902794 89.90332 89.890984 89.927872 90.005409 90.0793 90.127533 90.142319 90.1549 90.166931 90.163658 90.152908 90.138023 90.115662 90.078079 90.034309 89.997704 89.980659 89.974411 * * * 89.855225 89.9534 90.058113 90.104301 90.120697 90.13623 90.148262 90.151054 90.153809 90.171333 90.188339 90.200768 90.196426 90.194527 90.195396 90.195351 90.200127 90.205925 90.216118 90.215034 90.193047 90.170631 * * * * * * * * * * * * * * * * 89.7929 89.837097 89.891548 89.950562 90.008514 90.070084 90.142921 90.207832 90.269875 90.323555 90.377579 90.426048 90.463554 90.496666 90.523384 90.545067 90.555412 * * * * * * * * * *
+* * * 89.752869 89.636414 89.422264 89.251984 89.177002 89.158371 89.149231 89.142998 89.139572 89.128799 89.114799 89.106247 89.098137 89.089897 89.081528 89.073036 89.064407 89.055649 89.046753 89.03772 89.028549 89.019234 89.009773 89.000214 88.990181 88.978889 88.968323 88.958145 88.947754 88.937202 88.926491 88.915619 88.904587 88.893387 88.882027 88.870491 88.858795 88.846924 88.834885 88.822678 88.810303 88.79776 88.785042 88.772179 88.75898 88.742668 88.743248 88.759392 88.749969 88.717148 88.682007 88.681145 88.688705 88.682655 88.672569 88.648895 88.623123 88.597015 88.57029 88.551735 88.534096 88.519249 88.506599 88.493523 88.480392 88.466896 88.452408 88.438515 88.423996 88.409164 88.395973 88.38205 88.368484 88.355713 88.341927 88.330063 88.31778 88.303886 88.290001 88.277702 88.265968 88.254768 88.244186 88.234833 88.227821 88.220421 88.213341 88.204559 88.197258 88.187836 88.198311 88.257309 88.327507 88.36515 88.414337 88.527657 88.660583 88.75808 88.887375 8
9.020729 89.142494 89.264694 89.351959 89.416 89.457214 89.471329 89.471992 89.438263 89.349968 89.228302 89.102501 88.930367 88.783508 88.738449 88.71624 88.717522 88.72937 88.74472 88.760963 88.776466 88.795448 88.841255 88.998718 89.178276 89.304573 89.406677 89.483086 89.552956 89.633255 89.716141 89.790283 89.828148 89.824234 89.821762 89.859322 89.940865 90.00782 90.046761 90.073166 90.08503 90.09462 90.099258 90.100822 90.096527 90.084183 90.055412 90.013702 89.974808 89.940674 89.925789 89.923721 89.903305 * * * 89.874062 89.974678 90.044258 90.06958 90.086006 90.101624 90.105614 90.104721 90.118484 90.133408 90.149231 90.158386 90.161499 90.160408 90.163582 90.163887 90.16716 90.176636 90.172272 90.147858 * * * * * * * * * * * * * * * * 89.781525 89.835175 89.89711 89.954033 90.005081 90.066887 90.12925 90.193069 90.251228 90.304222 90.352379 90.401009 90.446472 90.481789 90.514168 90.537399 90.546402 * * * * * * * * * * *
+* * * 89.755074 89.677628 89.481155 89.283371 89.177528 89.14875 89.139687 89.132378 89.127304 89.119736 89.110085 89.101807 89.093575 89.085213 89.076714 89.068085 89.059319 89.050415 89.041367 89.032173 89.022842 89.013374 89.003761 88.993782 88.982628 88.971764 88.961555 88.951118 88.940521 88.929749 88.918808 88.9077 88.896423 88.884964 88.873337 88.861534 88.849548 88.837387 88.825043 88.812523 88.79982 88.786934 88.773872 88.760628 88.747307 88.732582 88.719635 88.720329 88.727249 88.723587 88.685715 88.652 88.642754 88.650337 88.660423 88.640961 88.617691 88.592842 88.573296 88.556877 88.523499 88.498077 88.483833 88.470337 88.456543 88.44249 88.426636 88.411674 88.397545 88.382088 88.36805 88.353111 88.338753 88.32531 88.311401 88.298187 88.284958 88.270798 88.257042 88.244217 88.231743 88.220291 88.209503 88.199127 88.191452 88.184608 88.178749 88.170776 88.163773 88.157303 88.142212 88.167801 88.306633 88.349586 88.332474 88.385918 88.498665 88.627487 88.759659 88.
916634 89.065102 89.175339 89.25119 89.328384 89.380768 89.392715 89.366043 89.298958 89.217804 89.111847 88.957085 88.777534 88.727165 88.728088 88.69696 88.694016 88.708649 88.725578 88.742165 88.758575 88.777206 88.856934 89.035057 89.20636 89.32856 89.412529 89.473198 89.549614 89.628906 89.702972 89.741943 89.745834 89.752495 89.790001 89.852692 89.922829 89.962921 89.985672 90.004654 90.022469 90.029312 90.028435 90.03067 90.037148 90.029984 89.995003 89.949364 89.914307 89.886002 89.879448 89.878792 89.867226 * * * 89.801041 89.890953 89.966805 90.000374 90.025475 90.044212 90.039093 90.037567 90.052711 90.068481 90.087822 90.114929 90.12368 90.121849 90.128197 90.129692 90.128471 90.134727 90.130333 * * * * * * * * * * * * * * * * 89.808388 89.853508 89.907036 89.966759 90.014694 90.056389 90.106392 90.169472 90.232681 90.286667 90.336906 90.382256 90.428322 90.474342 90.508789 90.538689 90.555237 * * * * * * * * * * * *
+* * * 89.797356 89.746086 89.568489 89.348526 89.195358 89.143501 89.137451 89.129578 89.121407 89.113441 89.105606 89.097404 89.089043 89.080551 89.071922 89.063156 89.054253 89.045197 89.036003 89.026657 89.017174 89.007446 88.997505 88.986649 88.975441 88.965218 88.954765 88.944115 88.933296 88.922302 88.911133 88.89978 88.888252 88.876534 88.864639 88.852554 88.840279 88.82782 88.81517 88.802322 88.789284 88.776054 88.762634 88.749016 88.735207 88.721497 88.705818 88.691528 88.682655 88.690117 88.691711 88.67469 88.629303 88.604012 88.613655 88.610764 88.585258 88.560272 88.550301 88.536613 88.508972 88.478439 88.461075 88.44648 88.432182 88.417427 88.40107 88.385094 88.369965 88.353905 88.339043 88.323708 88.30864 88.294006 88.280167 88.265907 88.250999 88.236923 88.223351 88.208504 88.194366 88.182869 88.172806 88.163239 88.155136 88.14592 88.139122 88.133026 88.127426 88.12085 88.109734 88.10675 88.230225 88.290726 88.240204 88.270233 88.355995 88.49379 88.627266 88.8
12263 88.986717 89.088509 89.168991 89.244431 89.290733 89.297806 89.243202 89.159798 89.091064 89.001579 88.808731 88.656464 88.660324 88.676292 88.667892 88.668381 88.685104 88.702728 88.720085 88.734871 88.763802 88.902908 89.076698 89.228088 89.351051 89.415558 89.476448 89.557602 89.617439 89.648155 89.651779 89.669586 89.725937 89.783867 89.828812 89.861694 89.887344 89.913147 89.926186 89.943069 89.954391 89.9552 89.958023 89.970772 89.968208 89.935265 89.884888 89.85128 89.823456 89.824257 89.841591 89.844994 * * * 89.757286 89.817436 89.884033 89.931625 89.96389 89.983658 89.974541 89.975609 89.990341 90.008598 90.029358 90.058258 90.069855 90.073357 90.079361 90.081856 90.089211 90.098907 90.084648 * * * * * * * * * * * * * * * 89.798279 89.854919 89.921356 89.981201 90.025345 90.064568 90.100609 90.136398 90.19696 90.264168 90.320274 90.374306 90.418358 90.462875 90.5084 90.537895 90.558334 90.566353 * * * * * * * * * * * *
+* * * * 89.826836 89.685318 89.465919 89.246994 89.142441 89.133476 89.125694 89.117706 89.109589 89.101379 89.093033 89.084549 89.075928 89.067169 89.058266 89.049217 89.040016 89.03067 89.021172 89.011612 89.001144 88.990318 88.979584 88.969116 88.958664 88.947983 88.937126 88.926086 88.914864 88.903458 88.891861 88.880081 88.868103 88.855934 88.843567 88.831001 88.81823 88.805267 88.792091 88.778717 88.765129 88.751343 88.737343 88.723145 88.708725 88.694244 88.679054 88.662277 88.651573 88.65345 88.666687 88.635902 88.593246 88.573326 88.570251 88.562744 88.538879 88.509865 88.493736 88.480209 88.454704 88.436806 88.422127 88.407135 88.391472 88.374664 88.356972 88.340836 88.325272 88.309227 88.293526 88.27816 88.262131 88.247025 88.231934 88.216209 88.201103 88.186653 88.171364 88.157028 88.144859 88.134811 88.125603 88.116508 88.106232 88.098915 88.092316 88.086838 88.079994 88.075958 88.065605 88.086411 88.126472 88.149307 88.182571 88.23452 88.346199 88.490639 88.709
152 88.875542 88.976822 89.076904 89.150169 89.182838 89.173096 89.11779 89.046349 88.978455 88.887131 88.694824 * 88.612518 88.625732 88.632759 88.640846 88.656082 88.671883 88.687782 88.699615 88.77301 88.944496 89.09446 89.251694 89.368752 89.426102 89.497299 89.547279 89.555061 89.551147 89.584961 89.647079 89.705269 89.741814 89.773102 89.794434 89.813156 89.824539 89.833618 89.850861 89.86161 89.867516 89.871933 89.882164 89.879181 89.862076 89.816017 89.779076 89.751091 89.754425 89.788963 89.81427 89.809196 * * 89.726936 89.746277 89.806259 89.86422 89.898911 89.934227 89.947647 89.951881 89.959442 89.975052 89.989906 90.012306 90.032677 90.043243 90.048973 90.051086 90.062904 90.067909 * * * * * * * * * * * * * * * 89.722626 89.799179 89.885147 89.979492 90.045898 90.086266 90.119385 90.146622 90.177025 90.229454 90.296028 90.360954 90.420395 90.465797 90.505768 90.543381 90.565025 90.577415 * * * * * * * * * * * * *
+* * * * 89.889153 89.782837 89.574646 89.32328 89.156174 89.12989 89.120949 89.113312 89.105522 89.097168 89.088692 89.080086 89.071342 89.062447 89.053406 89.04422 89.034874 89.025375 89.015701 89.005943 88.994904 88.983513 88.973328 88.962822 88.95211 88.941223 88.930153 88.918892 88.90744 88.895798 88.883957 88.871918 88.859673 88.847229 88.834572 88.821709 88.808632 88.795341 88.78183 88.768105 88.754158 88.739998 88.725609 88.711006 88.696182 88.681129 88.665855 88.650536 88.638176 88.633011 88.618004 * 88.602318 88.590858 88.555862 88.536469 88.521889 88.496269 88.48188 88.468994 88.441101 88.41729 88.399284 88.381256 88.363815 88.347038 88.32959 88.312378 88.29541 88.278786 88.262253 88.245529 88.229645 88.213654 88.196739 88.180786 88.164902 88.149078 88.134132 88.119759 88.106667 88.095688 88.08535 88.075775 88.064903 88.056984 88.049721 88.043701 88.036385 88.032501 88.028564 88.009605 88.010254 88.06028 88.116585 * 88.226868 88.364624 88.566132 88.71534 88.834213
88.950974 89.033531 89.067657 89.042412 88.993004 88.937187 88.873779 88.757828 88.617165 88.580582 88.589294 88.592125 88.601334 88.614105 88.626083 88.639732 88.64727 88.667747 88.821091 88.97718 89.119011 89.287796 89.381592 89.438774 89.471596 89.457817 89.445885 89.479919 89.560219 89.620903 89.647095 89.66732 89.694351 89.71727 89.733994 89.737259 89.738228 89.751785 89.765617 89.771378 89.777931 89.783089 89.772148 89.757843 89.722206 89.689606 89.672142 89.686874 89.73484 89.767662 89.768593 89.725212 89.687248 89.670853 89.68573 89.729607 89.773422 89.803658 89.851685 89.896065 89.913155 89.924706 89.942986 89.954384 89.973679 89.999962 90.014351 90.01989 90.022873 90.025505 90.01712 89.991684 * * * * * * * * * * * * * * 89.732338 89.815086 89.921242 90.020531 90.095093 90.140717 90.170364 90.193298 90.224373 90.270042 90.334526 90.403648 90.469513 90.515495 90.547707 90.575974 90.591003 90.599136 * * * * * * * * * * * * *
+* * * * 89.939789 89.851433 89.677475 89.440666 89.239159 * * 89.106529 89.101913 89.092903 89.084396 89.075668 89.066788 89.05777 89.048592 89.039253 89.029762 89.020142 89.010056 88.999321 88.988586 88.977707 88.967209 88.956497 88.945587 88.934494 88.92321 88.911728 88.900047 88.888161 88.876068 88.86377 88.851257 88.838524 88.825577 88.812408 88.799019 88.7854 88.771553 88.757469 88.743156 88.728607 88.713829 88.698807 88.683548 88.668053 88.652321 88.636093 88.62458 88.61792 * * 88.605957 88.600777 88.563217 88.527 88.508492 88.487762 88.46579 88.452904 88.439705 88.417747 88.379982 88.35482 88.337318 88.319214 88.301437 88.283951 88.265114 88.247673 88.230972 88.212677 88.195274 88.178322 88.160675 88.145004 88.128616 88.110672 88.09494 88.080818 88.066643 88.054832 88.043823 88.033501 88.021835 88.013298 88.005402 87.99852 87.990295 87.984146 87.97892 87.975914 87.973907 87.974068 88.06385 88.211113 88.177444 88.230347 88.405014 88.565575 88.694138 88.820824 88.909477
88.949692 88.931938 88.879395 88.808228 88.734383 88.62397 88.551636 88.554169 88.554413 88.559219 88.572495 88.586967 88.599358 88.613007 88.612053 88.679359 88.869629 89.002007 89.167221 89.301323 89.358109 89.376465 89.348129 89.340874 89.398918 89.471123 89.5243 89.547691 89.571404 89.593544 89.613541 89.62764 89.639542 89.64917 89.639351 89.640152 89.660225 89.666283 89.669647 89.668434 89.661926 89.643379 89.612381 89.591118 89.592651 89.631767 89.689003 89.713539 89.692368 89.652847 89.613663 89.61097 89.636429 89.664032 89.681061 89.705177 89.747711 89.798401 89.835831 89.867912 89.896011 89.911659 89.928017 89.945679 89.962868 89.97023 89.973045 89.972588 89.955803 89.935669 * * * * * * * * * * * * * * 89.768112 89.863167 89.960419 90.048225 90.120926 90.170547 90.20639 90.232445 90.264427 90.310226 90.37545 90.441559 90.505867 90.545647 90.57383 90.600479 90.614014 * * * * * * * * * * * * * *
+* * * * 89.989548 89.945999 89.824371 89.616547 89.410751 * * * * 89.088066 89.080101 89.071289 89.062279 89.053116 89.0438 89.034332 89.024704 89.014816 89.003769 88.992699 88.982346 88.97184 88.961121 88.950203 88.939102 88.927795 88.916298 88.904587 88.89267 88.880547 88.868202 88.855637 88.84285 88.829834 88.816597 88.803116 88.789406 88.775452 88.761253 88.746811 88.732124 88.717186 88.701996 88.686554 88.67086 88.654907 88.638695 88.622276 88.604744 88.583832 88.578796 88.59597 88.575821 88.539856 88.520836 88.504341 88.480476 88.466301 88.464165 88.434761 88.409752 88.395897 88.360054 88.326942 88.310898 88.291519 88.271751 88.254417 88.235504 88.21595 88.197159 88.17897 88.160942 88.141731 88.123535 88.106316 88.08886 88.069839 88.054825 88.040283 88.025055 88.012421 88.000412 87.988815 87.976746 87.967621 87.957985 87.948883 87.939964 87.934052 87.9282 87.924889 87.922989 87.917328 87.957535 88.088463 88.134972 88.107887 88.280678 88.458443 88.570465 88.695137 88.79
0878 88.828217 88.822861 88.764404 88.637901 88.541542 88.51075 88.498848 88.503044 88.513939 88.527588 88.542725 88.558441 88.57225 88.582985 88.59182 88.721359 88.890419 89.023102 89.173264 89.232155 89.238762 89.217087 89.231064 89.302399 89.407585 89.463745 89.465431 89.47464 89.50412 89.525009 89.538239 89.546593 89.54763 89.546341 89.538361 89.533936 89.544548 89.5541 89.550278 89.537308 89.543251 89.53215 89.506874 89.509644 89.544525 89.598152 89.637985 89.645256 89.619286 89.568573 89.548172 89.554977 89.57621 89.618782 89.636711 89.657776 89.693123 89.734795 89.785057 89.831726 89.861992 89.876717 89.888092 89.900383 89.921661 89.932495 89.934395 89.938477 * * * * * * * * * * * * * * * 89.730087 89.830887 89.918114 89.997581 90.068268 90.126755 90.179237 90.225571 90.261314 90.299232 90.348763 90.411781 90.471199 90.52227 90.555145 90.585587 90.61245 90.625694 * * * * * * * * * * * * * *
+* * * * * 90.046303 89.987236 89.828293 89.662048 89.510666 89.378204 89.264542 89.152512 89.091873 89.075035 89.067093 89.057869 89.04863 89.039154 89.029472 89.019615 89.008835 88.997551 88.987198 88.976692 88.965973 88.955063 88.943962 88.932655 88.921143 88.909416 88.897484 88.88533 88.872963 88.860359 88.847534 88.834465 88.821167 88.807625 88.793831 88.779793 88.765503 88.750954 88.736145 88.721077 88.705742 88.690132 88.674255 88.658112 88.641685 88.624992 88.608017 88.590782 88.571915 88.562813 88.559891 88.527252 88.494385 88.47718 88.460587 88.437889 88.431587 88.43576 88.414238 88.392822 88.365761 88.328514 88.301094 88.282715 88.26387 88.243156 88.222961 88.203308 88.183807 88.16349 88.143456 88.124428 88.104202 88.086006 88.066986 88.047913 88.029366 88.01384 87.997902 87.981834 87.968033 87.953888 87.940361 87.928619 87.91803 87.906006 87.894547 87.887131 87.8815 87.875069 87.871109 87.869148 87.869026 87.857361 87.883621 87.972427 87.984825 88.13031 88.316528
88.4459 88.568047 88.672264 88.707794 88.690895 88.589897 88.465805 88.429771 88.451141 88.463341 88.468605 88.481117 88.493576 88.506813 88.523552 88.539795 88.546951 88.585526 88.729424 88.878944 88.993324 89.050919 89.05867 89.068871 89.112701 89.205132 89.29068 89.360359 89.399872 89.406357 89.416794 89.433868 89.450089 89.453972 89.464493 89.462036 89.44043 89.427498 89.430923 89.442741 89.450546 89.44088 89.417824 89.421692 89.415947 89.412285 89.462303 89.528748 89.567513 89.581322 89.572403 89.54332 89.497192 89.492462 89.491707 89.515938 89.57267 89.600372 89.614037 89.641312 89.681572 89.742516 89.799255 89.825401 89.832863 89.840538 89.85788 89.884056 89.897583 89.90168 89.904404 89.884239 * * * * * * * * * * * * * 89.691628 89.816109 89.901085 89.967636 90.028526 90.081345 90.130928 90.183487 90.236595 90.284874 90.33432 90.387154 90.443031 90.494759 90.536644 90.566849 90.596313 90.619545 90.628494 * * * * * * * * * * * * * *
+* * * * * * 90.100731 90.023575 89.922478 89.799034 89.649117 89.473457 89.263824 89.125961 89.076813 89.064957 89.057556 89.0513 89.039017 89.025261 89.013695 89.002647 88.992218 88.98175 88.971046 88.960152 88.949059 88.937759 88.926247 88.914528 88.902588 88.890419 88.878029 88.86541 88.852554 88.839455 88.826111 88.812523 88.798676 88.784569 88.770203 88.755562 88.740654 88.725479 88.710014 88.694267 88.678246 88.661926 88.645317 88.628418 88.611221 88.593727 88.575935 88.558052 88.538498 88.517685 88.499817 88.483025 88.463211 88.443199 88.423454 88.401764 88.377121 88.365524 88.368286 88.354179 88.306122 88.274734 88.254494 88.233513 88.212883 88.192047 88.17025 88.14933 88.128685 88.108238 88.086632 88.065651 88.045609 88.026108 88.007164 87.987663 87.969452 87.953293 87.936073 87.91951 87.90435 87.890236 87.876686 87.863167 87.849899 87.839882 87.832893 87.824364 87.819008 87.814064 87.811188 87.810417 87.815239 87.811546 87.812912 87.839676 87.940285 88.13533 88.312
08 88.447136 88.545517 88.592773 88.535957 88.372971 88.372955 88.417404 88.425827 88.442688 88.452782 88.473038 88.485802 88.492928 * * * 88.593521 88.695709 88.794685 88.853233 88.861504 88.912315 89.00132 89.119209 89.194344 89.236626 89.276291 89.313683 89.343643 89.34948 89.351089 89.355263 89.357201 89.366577 89.368263 89.340279 89.309448 89.315399 89.345642 89.350365 89.333282 89.307411 89.306953 89.31041 89.342743 89.43174 89.498695 89.513008 89.5177 89.499878 89.467049 89.438011 89.436737 89.441635 89.472794 89.519272 89.540657 89.538498 89.551788 89.591873 89.660118 89.735046 89.769844 89.772522 89.774963 89.798874 89.828575 89.840637 89.852982 89.856316 89.833984 * * * * * * * * * * * * * 89.707924 89.831825 89.918007 89.98674 90.042526 90.090675 90.144356 90.198906 90.254555 90.306786 90.363014 90.416397 90.46656 90.513855 90.553848 90.58371 90.608337 90.626427 90.630585 * * * * * * * * * * * * * *
+* * * * * * * 90.154671 90.092026 89.968651 89.797523 89.588249 89.356232 89.182732 89.097588 89.065262 * 89.059402 89.043701 89.02356 89.008308 88.997131 88.987038 88.976334 88.965462 88.954384 88.9431 88.931602 88.919891 88.907959 88.895798 88.883408 88.870781 88.85791 88.844788 88.831421 88.817795 88.803909 88.789757 88.77533 88.760628 88.745644 88.73037 88.714813 88.698952 88.682793 88.666336 88.649567 88.632484 88.615097 88.597389 88.579361 88.561012 88.542343 88.523384 88.50412 88.484489 88.464485 88.444244 88.423691 88.40284 88.381714 88.360519 88.336372 88.315285 88.308472 88.280449 88.248222 88.226707 88.20359 88.181091 88.159203 88.137497 88.114952 88.092155 88.070618 88.047661 88.026688 88.004997 87.983246 87.962746 87.943161 87.923805 87.904953 87.88588 87.867439 87.852905 87.837448 87.820938 87.805801 87.792969 87.783928 87.773804 87.765968 87.760048 87.753632 87.750801 87.749756 87.753601 87.759911 87.768219 87.764069 87.806091 87.945412 88.120018 88.291183 88.
419518 88.465439 88.372803 88.19455 88.258118 88.263107 88.267876 88.317947 88.359482 88.434189 88.47348 88.492882 88.52636 88.540054 88.546112 88.577019 88.610085 88.662598 88.733833 88.798454 88.904495 89.031761 89.12265 89.14502 89.163567 89.207069 89.249512 89.277725 89.282852 89.270439 89.25853 89.26033 89.259117 89.258049 89.239594 89.209846 89.195381 89.21785 89.225853 89.20797 89.190506 89.193703 89.218964 89.293991 89.389046 89.437218 89.451332 89.454689 89.432137 89.407463 89.391022 89.385719 89.395195 89.431908 89.471558 89.484779 89.468445 89.468117 89.498413 89.5597 89.647293 89.704575 89.713112 89.717735 89.749146 89.775917 89.78363 89.800491 89.806908 89.782249 * * * * * * * * * * * * * 89.685913 89.781662 89.865669 89.953423 90.030243 90.090927 90.153725 90.214333 90.271851 90.326355 90.382561 90.431747 90.481216 90.528313 90.564453 90.595482 90.618065 90.628639 90.628517 * * * * * * * * * * * * * *
+* * * * * * * 90.228477 90.179924 90.036285 89.835068 89.618111 89.400299 89.231163 89.129837 89.078377 * 89.059685 89.045967 89.025902 89.010521 88.993721 88.981384 88.970978 88.95993 88.948677 88.937202 88.925514 88.913597 88.901451 88.889069 88.876442 88.863571 88.850449 88.837074 88.823433 88.809525 88.795341 88.780876 88.766121 88.751083 88.735748 88.720108 88.704163 88.687897 88.671326 88.654419 88.637192 88.619637 88.601738 88.583511 88.564934 88.546013 88.526749 88.507141 88.487183 88.466881 88.446228 88.42524 88.403915 88.382263 88.360283 88.337982 88.315475 88.292458 88.268417 88.245407 88.222366 88.198425 88.174393 88.150162 88.125771 88.102386 88.079254 88.05616 88.03196 88.007828 87.984909 87.962471 87.940399 87.917412 87.895798 87.875153 87.852898 87.832344 87.815475 87.797974 87.779335 87.762558 87.748711 87.735443 87.722939 87.712471 87.705139 87.696404 87.691368 87.688522 87.687302 87.688812 87.693581 87.705353 87.717331 87.728699 87.767838 87.862228 88.0721
28 88.279709 88.316689 88.227745 88.0709 88.058578 88.018677 87.994507 88.031784 88.082306 88.152885 88.23497 88.323128 88.404518 88.442543 88.453438 88.4804 88.5205 88.600441 88.718658 88.823372 88.91584 89.020943 89.069748 89.07428 89.103035 89.152031 89.190041 89.211906 89.214348 89.20034 89.185059 89.176216 89.161415 89.147552 89.132729 89.106728 89.061729 89.062744 89.081192 89.074402 89.079353 89.096352 89.136002 89.226265 89.31221 89.359688 89.396172 89.408081 89.388092 89.362305 89.347885 89.339043 89.348076 89.39032 89.428307 89.433144 89.41156 89.40699 89.429901 89.48175 89.562881 89.629906 89.656372 89.686249 89.725967 89.742432 89.750015 89.755882 89.752113 * * * * * * * * * * * * * 89.639221 89.752052 89.804893 89.848457 89.918793 90.008575 90.0867 90.15712 90.223099 90.285683 90.344925 90.399384 90.448387 90.497658 90.540398 90.569565 90.601158 90.621918 90.625809 * * * * * * * * * * * * * * *
+* * * * * * * 90.27523 90.226776 90.077065 89.861794 89.635956 89.427612 89.267883 89.165039 89.104317 * 89.068542 89.052055 89.029915 89.012497 88.991669 88.976532 88.965637 88.95446 88.943024 88.931366 88.919479 88.907356 88.894997 88.882393 88.869537 88.85643 88.843056 88.829414 88.815498 88.8013 88.786819 88.772041 88.756966 88.741577 88.725883 88.709869 88.693535 88.676865 88.659859 88.642517 88.624817 88.606773 88.588364 88.569595 88.550461 88.53096 88.511086 88.490829 88.4702 88.449196 88.427818 88.406059 88.383934 88.361443 88.338593 88.315392 88.291847 88.267975 88.24379 88.219307 88.19455 88.16954 88.14431 88.118889 88.093307 88.067459 88.041908 88.017677 87.991814 87.967522 87.943047 87.9179 87.894394 87.870224 87.845718 87.821739 87.798897 87.779297 87.759956 87.739059 87.719406 87.703323 87.689049 87.673187 87.657509 87.648079 87.639206 87.631012 87.626022 87.622429 87.621063 87.620796 87.624756 87.636505 87.649788 87.657387 87.665909 87.681679 87.815247 88.0543
29 88.140923 88.097534 87.99791 87.919319 87.878899 87.846573 87.84919 * * 88.01004 88.110573 88.19603 88.257523 88.303909 88.385956 88.495384 88.590744 88.687263 88.772339 88.843781 88.92247 88.979652 89.006493 89.051308 89.09935 89.128899 89.149223 89.149696 89.134666 89.124916 89.106331 89.072136 89.034592 89.001801 88.967201 88.922935 88.915222 88.94001 88.958679 88.989754 89.013695 89.046074 89.121727 89.208183 89.277908 89.32888 89.35466 89.346054 89.31852 89.303864 89.292404 89.306953 89.351822 89.388077 89.392197 89.373505 89.377304 89.405632 89.448334 89.512215 89.574707 89.615997 89.67067 89.716202 89.725861 89.735016 89.727699 * * * * * * * * * * * * * 89.579208 89.766808 89.874298 89.905289 * * 90.008423 90.092545 90.168304 90.23851 90.30246 90.359818 90.412994 90.467819 90.515785 90.548866 90.572121 90.599739 90.616821 90.621597 * * * * * * * * * * * * * * *
+* * * * * * * 90.305885 90.24675 90.095314 89.879669 89.656807 89.460335 89.309258 89.206192 89.134956 * 89.091438 89.069412 89.040192 89.013832 88.990761 88.971069 88.95993 88.949066 88.937439 88.925591 88.913513 88.901184 88.888611 88.875786 88.862701 88.84935 88.835724 88.821815 88.807625 88.793137 88.778351 88.76326 88.747856 88.732124 88.716072 88.699677 88.682945 88.665863 88.64843 88.630623 88.612457 88.59391 88.574982 88.555664 88.535957 88.515854 88.495354 88.474442 88.453125 88.431396 88.409264 88.386719 88.363762 88.340408 88.31665 88.292503 88.267975 88.243073 88.217812 88.192215 88.16629 88.140076 88.113586 88.086868 88.059914 88.03154 88.003021 87.976357 87.950554 87.924629 87.898903 87.873466 87.847328 87.820984 87.795158 87.76976 87.745331 87.723091 87.700081 87.677383 87.658234 87.641685 87.623215 87.605225 87.590706 87.579865 87.570496 87.562859 87.556694 87.552681 87.550964 87.551064 87.554924 87.564636 87.577438 87.588631 87.604988 87.616379 87.640869 87.
747475 87.850838 87.890671 87.92012 87.882805 * * 87.856056 87.911842 87.964401 88.006126 88.025101 88.06337 88.132065 88.193108 88.317047 88.455811 88.524979 88.582947 88.67157 88.749733 88.822411 88.897491 88.94928 88.994675 89.03801 89.05983 89.084656 89.080765 89.045853 89.042618 89.01516 88.94725 88.876404 88.817459 88.786781 88.77877 88.783348 88.812332 88.852531 88.897408 88.922104 88.952034 89.022812 89.107483 89.1866 89.243706 89.277405 89.282127 89.263306 89.249504 89.239525 89.265961 89.318398 89.347137 89.352661 89.345535 89.356369 89.392258 89.433479 89.493713 89.557114 89.603607 89.655777 89.692307 89.706245 89.714851 89.707451 * * * * * * * * * * * * * 89.666252 89.858116 89.938316 89.969681 89.988777 * 90.035156 90.104607 90.180244 90.249626 90.309509 90.365791 90.417305 90.471352 90.519806 90.549721 90.57412 90.595863 90.60923 90.614418 * * * * * * * * * * * * * * *
+* * * * * * * 90.324387 90.267303 90.104378 89.884789 89.680084 89.504959 89.358658 89.244507 89.165459 89.132126 89.119263 89.096016 89.061378 89.019402 88.9888 88.966156 88.954285 88.943741 88.931931 88.919891 88.907616 88.895088 88.882301 88.869255 88.855934 88.842339 88.828461 88.814285 88.79982 88.785042 88.769951 88.754547 88.738808 88.722733 88.706314 88.689537 88.672409 88.654907 88.637024 88.618767 88.600113 88.581062 88.5616 88.541733 88.521439 88.500725 88.479576 88.457993 88.435966 88.413498 88.390587 88.367226 88.343422 88.319168 88.294472 88.269348 88.24379 88.217812 88.191429 88.164658 88.13752 88.110031 88.082222 88.054214 88.025032 87.993439 87.964172 87.935799 87.90818 87.880585 87.853142 87.825691 87.798584 87.771896 87.744499 87.715965 87.688087 87.662193 87.638054 87.61599 87.594948 87.574486 87.553482 87.535355 87.521446 87.509453 87.499031 87.490257 87.483452 87.478882 87.476799 87.476791 87.48037 87.488457 87.501579 87.512947 87.533279 87.559776 87.57
103 87.570503 87.609535 87.634468 87.703377 87.817764 87.850334 87.839333 87.867805 87.887573 87.867912 87.87162 87.881676 87.92556 88.003624 88.093666 88.222076 88.323097 88.372238 88.429459 88.53698 88.657219 88.753319 88.816475 88.871452 88.930435 88.965965 88.9767 88.974083 88.941338 88.896095 88.880814 88.849121 88.763313 88.677002 88.62529 88.615059 88.640244 88.668037 88.709831 88.752213 88.798439 88.83094 88.866974 88.94355 89.025192 89.098038 89.160774 89.202988 89.216621 89.205818 89.195976 89.189949 89.230469 89.289253 89.305534 89.307152 89.313385 89.333473 89.372925 89.425423 89.492188 89.557106 89.6035 89.640846 89.663971 89.680916 89.683968 89.681206 * * * * * * * * * * * * 89.627373 89.776268 89.896355 89.95607 89.991264 90.028404 90.050789 90.072556 90.117661 90.186409 90.251312 90.307404 90.363663 90.412384 90.462524 90.511147 90.543953 90.572411 90.592812 90.603706 90.60405 * * * * * * * * * * * * * * *
+* * * * * * * 90.347885 90.298386 90.140785 89.928322 89.736526 89.571716 89.426086 89.298996 89.207664 89.16468 89.144211 89.12307 89.089676 89.034935 88.99395 88.964516 88.949219 88.938477 88.926491 88.914268 88.901794 88.889069 88.876068 88.862801 88.849243 88.835411 88.821274 88.806839 88.792091 88.777023 88.761635 88.745903 88.729828 88.713402 88.696617 88.679459 88.661926 88.643997 88.625679 88.606949 88.587807 88.568245 88.548248 88.527809 88.50692 88.48558 88.463776 88.441498 88.418755 88.395523 88.371811 88.34761 88.322922 88.297745 88.272079 88.245934 88.219307 88.192215 88.164658 88.136665 88.108246 88.079544 88.049927 88.019119 87.987717 87.956451 87.926125 87.895538 87.864716 87.835266 87.806175 87.776596 87.747459 87.719086 87.689621 87.658646 87.628738 87.599358 87.575035 87.551643 87.526627 87.502724 87.481026 87.463531 87.448128 87.434799 87.423241 87.41349 87.405876 87.400681 87.398193 87.39785 87.399033 87.40715 87.420822 87.434746 87.457573 87.478355 87.4
95705 87.518578 87.534103 87.498299 * 87.713943 87.831451 87.804268 87.763405 87.742142 87.7061 87.697273 87.756493 87.803596 87.873741 88.017113 88.094521 88.123955 88.173515 88.237617 88.351868 88.515099 88.644356 88.709991 88.766312 88.828117 88.851707 88.851166 88.808884 88.746803 88.707504 88.672569 88.623367 88.550362 88.488762 88.476837 88.492378 88.526802 88.563255 88.608147 88.660919 88.713669 88.742065 88.769539 88.859581 88.955772 89.027046 89.086845 89.136192 89.1586 89.158936 89.157616 89.164536 89.207184 89.258965 89.267914 89.271606 89.285828 89.316734 89.36245 89.422935 89.488251 89.550621 89.595428 89.623558 89.64386 89.655807 89.649445 89.643036 * * * * * * * * * * * 89.644585 89.786102 89.878799 89.935204 89.96991 90.007545 90.052017 90.082146 90.103447 90.135422 90.195923 90.257591 90.307007 90.356438 90.402031 90.452309 90.501144 90.535995 90.56485 90.584496 90.593719 90.592735 * * * * * * * * * * * * * * *
+* * * * * * * 90.37178 90.331856 90.203957 90.021683 89.844475 89.678757 89.528465 89.391365 89.276741 89.20639 89.169159 89.145454 89.116638 89.064705 89.016594 88.969406 88.944801 88.933258 88.921143 88.90873 88.896065 88.883133 88.869919 88.85643 88.842644 88.828568 88.814178 88.799477 88.784447 88.769096 88.753395 88.737343 88.72094 88.704163 88.687004 88.669456 88.651512 88.633163 88.614395 88.595192 88.575554 88.555466 88.53492 88.513908 88.492416 88.470436 88.44796 88.424988 88.401497 88.377487 88.352951 88.327888 88.302292 88.276154 88.249489 88.222282 88.19455 88.16629 88.137512 88.108299 88.078468 88.047134 88.015137 87.982719 87.950958 87.919052 87.887032 87.854263 87.820038 87.787117 87.754265 87.725616 87.694313 87.662109 87.632042 87.6007 87.568001 87.535454 87.508568 87.480766 87.453598 87.430046 87.407486 87.387611 87.370583 87.355804 87.342972 87.332115 87.323578 87.31768 87.314713 87.314262 87.315308 87.321297 87.334946 87.351974 87.372971 87.39238 87.41210
9 87.440384 87.456375 * * 87.693436 87.683067 87.642403 87.624695 87.634575 87.637917 87.630699 87.671471 87.69857 87.84082 88.092087 88.112419 88.123543 88.202721 * * 88.302109 88.471611 88.584129 88.646782 88.685097 88.688469 88.666199 88.602943 88.538383 88.499718 88.468369 88.407333 88.359367 88.355804 88.382126 88.413567 88.44413 88.477852 88.514374 88.572853 88.634148 88.659676 88.680359 88.771217 88.870804 88.943771 89.004715 89.060593 89.095116 89.113113 89.118675 89.146622 89.190773 89.222313 89.230049 89.247818 89.265747 89.296387 89.352791 89.421532 89.482506 89.537056 89.582237 89.606987 89.622025 89.629112 89.622017 * * * * * * * * * * * 89.584984 89.741638 89.845314 89.90892 89.953255 89.985771 90.025475 90.065216 90.096565 90.121841 90.155655 90.20726 90.260376 90.301483 90.342163 90.387367 90.438065 90.486267 90.523262 90.55291 90.56881 90.575333 90.574493 * * * * * * * * * * * * * * *
+* * * * * * * 90.389359 90.369514 90.278091 90.123993 89.961868 89.799828 89.644638 89.506676 89.371094 * * * * 89.121475 89.054588 88.972404 88.938904 88.928192 88.915878 88.903282 88.890419 88.877289 88.863861 88.850151 88.836136 88.821815 88.807175 88.792206 88.776901 88.761253 88.745255 88.728882 88.712135 88.695007 88.677475 88.659546 88.64119 88.622406 88.603188 88.583511 88.56337 88.542755 88.521652 88.500053 88.477951 88.455322 88.432167 88.408463 88.384216 88.359406 88.33403 88.308075 88.281548 88.254425 88.226723 88.198425 88.169533 88.140106 88.110252 88.078781 88.046265 88.013138 87.980301 87.947502 87.914345 87.880676 87.84549 87.809731 87.773651 87.73864 87.703857 87.67067 87.63678 87.604935 87.572861 87.538773 87.503677 87.470184 87.436829 87.405815 87.378578 87.354645 87.329262 87.307304 87.288506 87.272079 87.257797 87.245651 87.236244 87.229607 87.226089 87.225334 87.226631 87.232338 87.244576 87.262177 87.284538 87.305946 87.329056 87.342384 * 87.563484 87
.644279 87.584969 87.510269 87.512703 87.553185 87.584145 87.605789 87.608047 87.616547 87.663513 87.831635 88.042007 88.087547 88.146652 88.255791 88.274315 * * * 88.416901 88.489609 88.502182 88.490372 88.446388 88.387283 88.344658 88.291969 88.253677 88.236473 88.236458 88.268814 88.322495 88.354897 88.378723 88.414719 88.452606 88.500778 88.556236 88.59449 88.609138 88.683922 88.788544 88.856476 88.911697 88.96843 89.0196 89.049507 89.05172 89.095627 89.161613 89.190231 89.197014 89.20974 89.227875 89.265663 89.334732 89.41571 89.476021 89.524902 89.569572 89.588463 89.591156 89.596054 89.595833 89.589561 * * * * * * * * * 89.512985 89.639015 89.752197 89.839836 89.903427 89.951706 89.995499 90.039635 90.07634 90.105873 90.12999 90.166046 90.20845 90.249367 90.281258 90.316147 90.368355 90.420502 90.465919 90.502716 90.530777 90.547829 90.554901 90.552742 * * * * * * * * * * * * * * *
+* * * * * * * 90.40834 90.398552 90.338531 90.213898 90.063828 89.919571 89.787018 89.655624 89.49778 * * * * 89.22493 89.126053 88.98848 88.929031 88.922562 88.910995 88.898109 88.884842 88.871536 88.85791 88.843971 88.829727 88.81517 88.800278 88.785042 88.769463 88.753525 88.737213 88.72052 88.703438 88.685959 88.668053 88.649727 88.630966 88.611748 88.592072 88.571915 88.55127 88.530121 88.508461 88.486267 88.463531 88.440247 88.416397 88.39196 88.366943 88.341316 88.315071 88.288216 88.260719 88.23259 88.203812 88.1744 88.144524 88.113472 88.081001 88.047447 88.013649 87.980286 87.946381 87.912163 87.876282 87.839279 87.801712 87.76461 87.727806 87.690849 87.65361 87.614838 87.579376 87.544777 87.50898 87.474228 87.438164 87.400688 87.363922 87.330742 87.301033 87.272484 87.245781 87.222771 87.201637 87.183708 87.167725 87.154488 87.142326 87.134369 87.130318 87.129257 87.130959 87.136612 87.145348 87.163719 87.190041 87.215858 87.241798 * 87.46225 87.514908 87.445679 8
7.402847 87.415474 87.448303 87.47963 87.512634 87.548317 87.579338 87.605186 87.662277 87.755684 87.829742 87.916344 88.015205 88.117561 88.226906 88.317558 88.314209 * * * * * * 88.198311 88.173332 88.138649 88.127342 88.154625 88.18647 88.21891 88.260796 88.291672 88.323494 88.365509 88.406898 88.447083 88.494438 88.543602 88.557037 88.624702 88.717621 88.770172 88.828758 88.88858 88.945015 88.97406 88.979286 89.032448 89.112251 89.156998 89.163704 89.156349 89.1735 89.226677 89.308662 89.404129 89.470306 89.514694 89.554153 89.566795 89.556854 89.561089 89.572083 89.569939 * * * * * * * * 89.45163 89.553879 89.651772 89.750862 89.841385 89.90435 89.947174 89.989059 90.037842 90.073936 90.101646 90.129761 90.160736 90.192055 90.225952 90.250198 90.286865 90.344315 90.400993 90.449127 90.48259 90.506645 90.530807 90.542076 * * * * * * * * * * * * * * * *
+* * * * * * * 90.430214 90.41951 90.377113 90.286644 90.159729 90.044266 89.943535 89.809212 * * * * * 89.362862 89.244003 89.056007 88.940315 88.909515 88.900536 88.890625 88.879814 88.865898 88.852058 88.837906 88.823433 88.808632 88.793488 88.777992 88.762131 88.745903 88.729286 88.71228 88.694862 88.677017 88.658745 88.64003 88.62085 88.601196 88.581062 88.560425 88.539268 88.517586 88.495354 88.472565 88.449196 88.42524 88.400681 88.375504 88.349693 88.323235 88.296112 88.268318 88.239838 88.210655 88.180885 88.150299 88.118057 88.08477 88.050636 88.016769 87.982414 87.947731 87.911819 87.874367 87.835785 87.796921 87.758713 87.720093 87.681366 87.64109 87.599724 87.558128 87.519333 87.480774 87.444557 87.407524 87.367844 87.327553 87.289459 87.251534 87.217232 87.184814 87.157959 87.132072 87.10894 87.086845 87.069221 87.054306 87.04097 87.030052 87.025146 87.023483 87.023651 87.029045 87.036308 87.053596 87.081131 87.103127 * 87.403465 87.433823 87.305359 87.263 87.29
8149 87.333351 87.364403 87.398888 87.434021 87.471222 87.513718 87.550377 87.600319 87.68618 87.777252 87.863754 87.95015 88.042427 88.127335 88.213814 88.310478 88.332573 * * * * * 88.042778 88.052917 88.069443 88.10331 88.137169 88.167542 88.197296 88.224396 88.253181 88.288368 88.321045 88.364243 88.413483 88.4487 88.488121 88.519333 88.570457 88.62912 88.676201 88.741837 88.819397 88.886383 88.914513 88.925522 88.977028 89.050392 89.102219 89.120125 89.119247 89.135712 89.186172 89.273102 89.385689 89.461685 89.501434 89.535522 89.544052 89.531334 89.533386 89.544632 89.538109 * * * * * * * * 89.466507 89.559669 89.65313 89.750595 89.834839 89.892052 89.935005 89.975891 90.017395 90.051849 90.084366 90.115509 90.142044 90.160622 90.188492 90.221565 90.268517 90.324623 90.383308 90.434219 90.465706 90.49192 90.517738 90.531479 90.530739 * * * * * * * * * * * * * * *
+* * * * * * * 90.448715 90.440681 90.403717 90.338081 90.243774 90.152748 90.057747 89.904472 * * * * * 89.50795 89.413612 89.214882 89.039093 88.935921 88.899231 88.885101 88.871796 88.860771 88.846413 88.831947 88.817253 88.802208 88.786819 88.771057 88.754929 88.738411 88.721489 88.704163 88.686401 88.668213 88.649567 88.630455 88.610863 88.590775 88.570175 88.549049 88.527382 88.505157 88.482353 88.458961 88.434959 88.410324 88.385048 88.359116 88.332497 88.305191 88.277168 88.248413 88.218979 88.188965 88.157211 88.124222 88.09021 88.056145 88.021751 87.986847 87.951065 87.913414 87.874634 87.834915 87.795525 87.755699 87.71566 87.674446 87.631706 87.587929 87.543999 87.501198 87.458336 87.416847 87.376709 87.333786 87.293465 87.252968 87.209358 87.167999 87.128525 87.090881 87.059753 87.030594 87.005951 86.978317 86.958931 86.942024 86.929039 86.915421 86.909363 86.906967 86.904503 86.911041 86.919655 86.937332 86.947632 * 87.258446 87.359856 87.20742 87.136932 87.1678
24 87.205414 87.238937 87.273102 87.310852 87.349503 87.392303 87.437881 87.475311 87.534943 87.629601 87.724625 87.81472 87.90567 88.003258 88.093422 88.176735 88.25061 88.313965 88.367584 88.399162 88.321579 88.129128 * 87.968407 88.014175 88.04744 88.080956 88.112671 88.143005 88.174217 88.204468 88.23362 88.261436 88.286644 88.322151 88.373322 88.411148 88.443596 88.488937 88.522209 88.566345 88.628113 88.680992 88.738045 88.806038 88.846375 88.872398 88.91584 88.983086 89.046936 89.077072 89.09034 89.111084 89.153603 89.243912 89.354477 89.416679 89.443878 89.472404 89.494652 89.50145 89.502167 89.505341 89.495163 * * * * * * * 89.374687 89.470665 89.559509 89.646538 89.742783 89.817543 89.868568 89.913887 89.955032 89.992622 90.032135 90.057999 90.078705 90.098213 90.11293 90.144234 90.194992 90.254112 90.311348 90.367271 90.414642 90.450035 90.480667 90.500725 90.514763 90.514763 * * * * * * * * * * * * * * *
+* * * * * * * 90.472542 90.463577 90.429718 90.373283 90.304245 90.226448 90.118607 * * * * * * * 89.634155 89.478996 89.262268 89.067894 88.95768 * * 88.848351 88.84063 88.826416 88.811142 88.795914 88.780273 88.764259 88.747856 88.731049 88.713829 88.696182 88.678093 88.659546 88.640526 88.621025 88.601021 88.580498 88.559433 88.537827 88.51564 88.492867 88.46949 88.445488 88.420837 88.395523 88.369522 88.342819 88.315392 88.287216 88.258301 88.228806 88.198029 88.165741 88.132042 88.097832 88.063713 88.028877 87.993484 87.956116 87.91729 87.877274 87.837166 87.796768 87.755836 87.71405 87.670265 87.625343 87.579521 87.534256 87.488792 87.443436 87.397224 87.349434 87.302917 87.258698 87.217438 87.172379 87.125595 87.082001 87.036049 86.99498 86.955093 86.920303 86.890984 * 86.840843 86.819992 86.805649 86.790047 86.782867 86.780594 86.779854 86.785019 86.79599 86.803444 * * 87.247551 87.108307 87.002968 87.030258 87.065239 87.10228 87.139702 87.177032 87.218437 87.26075 8
7.3088 87.357552 87.398727 87.467758 87.569443 87.668114 87.762131 87.857178 87.956314 88.050926 88.136826 88.199989 88.250237 88.295708 88.216782 88.003487 * 87.907837 87.948792 87.985497 88.021088 88.055923 * 88.119476 88.151009 88.182358 88.212852 88.242538 88.271469 88.299377 88.329147 88.369812 88.409752 88.460236 88.493111 88.53595 88.599548 88.643913 88.680351 88.729515 88.776726 88.818504 88.852409 88.91333 88.996826 89.038246 89.054741 89.084129 89.129845 89.215546 89.290436 89.316132 89.32917 89.356171 89.40316 89.440521 89.449982 89.460976 89.446991 * * * * * * * 89.359138 89.460785 89.559715 89.638351 89.72142 89.788635 89.839584 89.885773 89.927307 89.969566 90.003029 90.00959 90.020477 90.037407 90.064751 90.120667 90.180893 90.244987 90.303123 90.354271 90.400284 90.438789 90.469833 90.48848 90.497055 * * * * * * * * * * * * * * * *
+* * * * * * * 90.502487 90.49173 90.456512 90.396355 90.332344 90.250809 * * * * * * * * 89.840233 89.75341 89.548378 89.335281 89.176926 89.030342 88.919792 88.848648 88.824692 88.816063 88.805878 88.789879 88.773857 88.757599 88.740921 88.723831 88.706314 88.688347 88.669922 88.651031 88.631645 88.611748 88.591331 88.570374 88.548851 88.526749 88.504051 88.480736 88.456779 88.432167 88.40686 88.380859 88.354126 88.326645 88.298393 88.269356 88.239563 88.208214 88.1754 88.141548 88.107666 88.073151 88.038231 88.001732 87.963402 87.923485 87.882851 87.842308 87.801033 87.75914 87.715096 87.669304 87.622314 87.575302 87.528137 87.480743 87.432549 87.382401 87.33136 87.279655 87.229256 87.18203 87.134857 87.087158 87.039314 86.988953 86.940971 86.895233 86.849602 * * * * * 86.672569 86.656967 86.648903 86.644089 86.646271 86.652046 86.649712 * * 87.164299 86.994598 86.848488 86.872559 86.917046 86.951668 86.991821 87.031746 87.075676 87.121109 87.169899 87.221954 87.272858 87.
321304 87.397514 87.506996 87.609566 87.707802 87.806732 87.90979 88.007561 88.084877 88.146164 88.202507 88.118355 87.901237 * * * * * * * 88.065987 88.099487 88.129936 88.161919 88.19355 88.224205 88.254013 88.283005 88.310791 88.336784 88.372726 88.419487 88.467178 88.501366 88.537651 88.580643 88.636032 88.690765 88.73365 88.774323 88.804405 88.848869 88.933716 88.993317 89.017876 89.053146 89.103912 89.161072 89.18132 89.174217 89.184395 89.223694 89.291008 89.365707 89.400864 89.419998 * * * * * * * * 89.342239 89.447739 89.554726 89.623634 89.695908 89.757187 89.800797 89.847641 89.888725 89.913635 89.93338 89.948036 89.972748 90.005638 90.055092 90.127632 90.190826 90.249634 90.302071 90.34613 90.394073 90.430504 90.45491 90.472145 90.477776 * * * * * * * * * * * * * * * *
+* * * * * * * 90.529396 90.517464 90.478683 90.41568 90.337959 * * * * * * * * * * 89.95137 89.829147 89.682655 89.553497 89.373154 89.120461 88.917633 * 88.811661 88.793671 88.783447 88.767815 88.751083 88.734138 88.716766 88.698952 88.680679 88.661926 88.642677 88.622925 88.602646 88.581818 88.560425 88.538445 88.515854 88.492645 88.468781 88.444244 88.419014 88.393059 88.366364 88.338898 88.310631 88.281548 88.251579 88.219589 88.185745 88.152649 88.118721 88.084099 88.048256 88.010368 87.971321 87.931305 87.890816 87.849701 87.8078 87.763733 87.71801 87.67054 87.622742 87.574532 87.525513 87.475922 87.423302 87.370476 87.316429 87.262695 87.209236 87.155441 87.100159 87.047729 86.998871 86.946457 86.890808 86.838722 * * * * * * * 86.528519 86.513397 86.505127 86.496391 86.499329 86.502434 86.494209 * 87.008675 86.882057 86.646545 86.666924 86.74231 86.790947 86.831268 86.876045 86.920067 86.968216 87.017708 87.074089 87.132698 87.185532 87.23864 87.32579 87.443909 87.550
514 87.653214 87.756042 87.864395 87.957382 88.025536 88.078003 88.014801 * * * * * * * * * 88.042236 88.077675 88.110893 88.143303 88.174774 88.205948 88.236725 88.266571 88.295547 88.323616 88.350563 88.383263 88.427444 88.453484 88.48558 88.531418 88.589249 88.652321 88.69648 88.731956 88.761848 88.796074 88.86573 88.928894 88.973755 89.016022 89.06163 89.088875 89.07106 89.050972 89.061752 89.099632 89.182182 89.297462 89.353218 89.375259 * * * * * * * 89.259583 89.32785 89.432831 89.538086 89.600571 89.667328 89.724442 89.761009 89.793159 89.82119 89.845581 89.880348 89.919632 89.958321 90.006096 90.071281 90.143288 90.203285 90.247047 90.287903 90.333199 90.381538 90.413948 90.433006 90.447197 90.455315 * * * * * * * * * * * * * * * *
+* * * * * * * 90.559166 90.53875 90.494194 90.427299 * * * * * * * * * * * * 90.059044 89.99868 89.91581 89.744019 89.429337 89.122032 88.955551 88.873886 88.802605 88.774971 88.761292 88.744743 88.727524 88.709869 88.691765 88.67318 88.654099 88.634514 88.614395 88.593727 88.572487 88.550667 88.528229 88.505157 88.48143 88.457024 88.431908 88.406059 88.379456 88.352066 88.323853 88.2948 88.264877 88.233978 88.200478 88.166473 88.133041 88.098289 88.062424 88.025299 87.985062 87.944893 87.904541 87.863075 87.818779 87.774002 87.727905 87.678703 87.630203 87.580948 87.530418 87.47863 87.426071 87.369987 87.31131 87.254768 87.198212 87.138695 87.081444 87.018829 86.960403 86.905792 86.847961 86.786919 * * * * * * * * * 86.357216 86.346001 86.336197 86.339882 86.316071 86.399063 86.818367 86.868324 86.488945 86.430504 86.522499 86.598274 86.656242 86.702339 86.749641 86.800713 86.856522 86.91317 86.973694 87.036377 87.093941 87.151199 87.247559 87.37188 87.483231 87.590851 87.6
9825 87.810196 87.893692 87.9543 87.941681 * * * * * * * * * * 88.018684 88.055481 88.090973 88.12439 88.155586 88.187927 88.21962 88.250328 88.280136 88.309082 88.337112 88.364677 88.391991 88.416733 88.4571 88.505775 88.55381 88.606842 88.654747 88.687958 88.717705 88.756424 88.809616 88.865036 88.926178 88.966637 88.99128 88.987503 88.9674 88.971916 88.996635 89.020203 89.089508 89.215981 89.299995 89.328117 * * * * * * 89.202911 89.249634 89.323341 89.420876 89.512062 89.576157 89.632004 89.679665 89.717484 89.74128 89.776024 89.829254 89.878075 89.921753 89.9617 90.010719 90.076035 90.146317 90.200142 90.237144 90.267929 90.31411 90.362938 90.391571 90.410896 90.426773 90.432213 * * * * * * * * * * * * * * * *
+* * * * * * * 90.588608 90.557381 90.500114 90.424408 * * * * * * * * * * * * * 90.192734 90.131836 89.981186 89.692223 89.347015 89.119965 88.983635 88.8498 88.772675 88.753395 88.738564 88.721077 88.703156 88.684753 88.665863 88.646461 88.626534 88.606056 88.585007 88.56337 88.541115 88.518227 88.494675 88.470436 88.445488 88.419792 88.393333 88.366074 88.33799 88.309036 88.279198 88.248421 88.216667 88.183487 88.14962 88.114891 88.078926 88.041832 88.00354 87.963455 87.922585 87.880714 87.837402 87.791092 87.743546 87.696228 87.646736 87.59642 87.544632 87.49128 87.436531 87.38044 87.323288 87.260384 87.198219 87.135796 87.070877 87.007744 86.940178 86.873436 86.809639 86.743813 86.678635 * * * * * * * * * * 86.176529 86.165672 * * 86.272545 86.617676 86.445465 86.225243 86.283417 86.364769 86.443939 86.513069 86.566032 86.61779 86.674408 86.736008 86.801491 86.868607 86.934196 86.999695 87.062035 87.157501 87.285545 87.405159 87.516792 87.632713 87.741409 87.817223 87.87
3573 87.865395 * * * * * * * * * 87.956116 87.994766 88.03157 88.068497 88.102592 88.136513 88.170174 88.202736 88.234314 88.264931 88.29464 88.323463 88.351395 88.378433 88.404167 88.432007 88.468132 88.513794 88.569038 88.61618 88.648865 88.682587 88.720764 88.773277 88.832397 88.875244 88.896545 88.900749 88.879593 88.88063 88.905724 88.935097 88.959328 89.016441 89.136276 89.243584 89.272026 * * * * 89.119164 89.162354 89.204536 89.251678 89.325157 89.4132 89.489433 89.538826 89.577248 89.629753 89.675621 89.714203 89.774689 89.838409 89.881027 89.922859 89.965721 90.015381 90.074402 90.136894 90.185791 90.227287 90.261505 90.298904 90.339996 90.369011 90.389114 90.402 90.403351 * * * * * * * * * * * * * * * *
+* * * * * * 90.616623 90.604866 90.564064 90.49807 * * * * * * * * * * * * * * 90.272591 90.216576 90.044395 89.74691 89.453133 89.251183 89.041527 88.86541 88.770653 88.746819 88.732544 88.714813 88.696617 88.67794 88.658745 88.63903 88.618767 88.597931 88.576508 88.554474 88.531799 88.508461 88.484428 88.459686 88.434196 88.407928 88.380859 88.352951 88.324165 88.294472 88.26384 88.232224 88.199593 88.166008 88.131256 88.095284 88.058151 88.019783 87.980148 87.939316 87.897026 87.853249 87.808029 87.76104 87.712372 87.662743 87.611565 87.558533 87.503853 87.447533 87.389587 87.329926 87.26944 87.203621 87.135597 87.066742 86.997963 86.927208 86.854332 86.781097 86.709473 86.635788 86.565331 86.493561 * * * * * * * * * * * * * 86.036758 86.13739 86.061234 86.065178 86.120293 86.187775 86.272652 86.354866 86.415543 86.476639 86.542274 86.610031 86.682396 86.759377 86.830025 86.902039 86.968407 87.066177 87.198303 87.325661 87.445976 87.564819 87.662247 87.733406 87.796432 87
.853813 87.91626 87.9795 88.038414 88.104828 * * * * * 87.931625 87.970772 88.007698 88.045692 88.082359 88.118034 88.152626 88.186119 88.218559 88.249992 88.280457 88.30999 88.338623 88.366402 88.393303 88.419739 88.442268 88.476006 88.52652 88.579918 88.616966 88.642052 88.682487 88.746307 88.802383 88.82296 88.831741 88.828896 88.815178 88.824081 88.850082 88.881409 88.908295 88.963028 89.072784 89.162216 89.155533 * * * 89.062485 89.112175 89.16301 89.210892 89.264267 89.328857 89.409645 89.476067 89.507584 89.537193 89.603798 89.658974 89.705681 89.768272 89.830414 89.875679 89.917648 89.963837 90.014313 90.066025 90.120834 90.169289 90.212395 90.250427 90.285416 90.31987 90.344742 90.364906 90.368813 90.364403 * * * * * * * * * * * * * * * *
+* * * * * * 90.645149 90.615433 90.563599 * * * * * * * * * * * * * * * 90.317848 90.256363 90.05735 89.729416 89.578453 89.440399 89.095322 88.832085 88.750916 88.742073 88.726791 88.708733 88.690285 88.671326 88.65184 88.631813 88.611221 88.590034 88.568245 88.545815 88.52272 88.49894 88.474442 88.449196 88.423172 88.396339 88.36866 88.340103 88.310631 88.280205 88.248779 88.216316 88.18277 88.148102 88.112259 88.075188 88.03685 87.997185 87.956146 87.913681 87.869728 87.824234 87.777153 87.728516 87.6782 87.625999 87.572037 87.516258 87.458618 87.399101 87.3377 87.274498 87.208862 87.138306 87.065681 86.992165 86.917976 86.840286 86.761009 86.682167 86.6036 86.523918 86.445076 86.365181 * * * * * * * * * * * * * 85.785767 85.822639 85.846939 85.896774 85.94339 86.003128 86.089096 86.185585 86.258232 86.325882 86.40097 86.47966 86.558731 86.641655 86.720497 86.800133 86.871338 86.977425 87.11795 87.25235 87.381073 87.493721 87.578094 87.648674 87.719063 87.785927 87.853333
87.91761 87.976318 88.04705 88.015182 * * * * 87.907227 87.947777 87.985764 88.024948 88.063019 88.099808 88.135376 88.169792 88.203102 88.235344 88.266571 88.296814 88.326111 88.354507 88.38205 88.408783 88.434036 88.459946 88.486847 88.534492 88.59124 88.60511 88.636887 88.698524 88.752357 88.776756 88.780815 88.77124 88.765297 88.768684 88.797745 88.843201 88.875359 88.919487 89.004929 89.056221 * * 88.990372 89.021797 89.053139 89.102959 89.156082 89.21389 89.276924 89.338638 89.41674 89.470467 89.493774 89.530769 89.599236 89.654907 89.700836 89.760262 89.823372 89.874229 89.917076 89.962036 90.006165 90.053894 90.109047 90.154381 90.194893 90.229416 90.262863 90.294487 90.316086 90.331566 90.330879 90.324417 * * * * * * * * * * * * * * * *
+* * * * * 90.68206 90.673355 90.631355 * * * * * * * * * * * * * * * * 90.372581 90.31089 90.137283 * 89.793442 89.699593 89.261185 88.878952 * 88.733513 88.721504 88.702866 88.684151 88.664925 88.645149 88.624817 88.603905 88.582382 88.560226 88.537407 88.513908 88.489693 88.464729 88.438995 88.412445 88.385048 88.356773 88.327576 88.297417 88.266258 88.234047 88.200737 88.16629 88.130653 88.093765 88.055573 88.016029 87.97506 87.932617 87.888634 87.843048 87.795784 87.746788 87.695992 87.643326 87.588737 87.53215 87.473518 87.412796 87.34993 87.284874 87.21814 87.146538 87.07061 86.992966 86.91497 86.83419 86.751549 86.666092 86.579468 86.492058 86.405594 86.317741 86.229706 * * * * * * * * * * * * * * 85.614983 85.658157 85.703751 85.757484 85.818481 85.900566 86.005157 86.090744 86.166504 86.251778 86.33947 86.429192 86.516678 86.605331 86.693466 86.772438 86.887947 87.03891 87.180588 87.309349 87.409081 87.489517 87.564629 87.638298 87.707535 87.773125 87.841232 87.9042
21 87.977196 87.957024 * * * 87.837814 87.883133 87.925156 87.964447 88.004868 88.044052 88.081902 88.118469 88.153816 88.187988 88.221039 88.253014 88.283951 88.313911 88.342926 88.371033 88.39827 88.424751 88.450233 88.474571 88.502075 88.553017 88.578346 88.597488 88.642174 88.690453 88.714226 88.724319 88.718353 88.712387 88.720169 88.752464 88.810364 88.837975 88.865982 88.933075 88.963821 * * 88.959717 89.011093 89.05143 89.096497 89.144287 89.201881 89.282143 89.361557 89.430496 89.471321 89.494148 89.542686 89.602867 89.649117 89.701073 89.770004 89.834099 89.879395 89.921005 89.961258 89.998207 90.047173 90.102722 90.138557 90.173706 90.206009 90.234001 90.259644 90.281349 90.293068 90.292358 90.287468 * * * * * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * 90.439758 90.391739 90.265656 * 90.008499 89.928391 89.496391 89.061127 88.801308 88.723618 88.71476 88.697212 88.678246 88.658745 88.638695 88.618073 88.59684 88.574982 88.552475 88.529282 88.505379 88.480736 88.455322 88.4291 88.402031 88.374084 88.345222 88.315392 88.284554 88.25267 88.219681 88.185539 88.150192 88.113586 88.075661 88.036346 87.99559 87.953323 87.90947 87.863953 87.816711 87.767662 87.716721 87.663811 87.608856 87.551773 87.492485 87.430908 87.366982 87.300629 87.231873 87.160583 87.083069 87.003746 86.920868 86.836082 86.748024 86.659782 86.566879 86.471939 86.376305 86.280968 86.183121 86.08268 * * * * * * * * * * * * * 85.648041 85.387085 85.44117 85.492722 85.55558 85.624634 85.701416 85.807457 85.907471 85.996178 86.093056 86.189621 86.292679 86.388313 86.48629 86.58271 86.670708 86.796196 86.956085 87.10437 87.222504 87.31134 87.397346 87.479767 87.554298 87.629402 87.699844 87.769684 87.838577 87.9152
83 87.90406 * * * 87.812546 87.859428 87.90287 87.943489 87.985146 88.025475 88.064392 88.101952 88.138222 88.173248 88.207092 88.239815 88.271454 88.302055 88.331673 88.360352 88.388123 88.415031 88.441101 88.466393 88.489998 88.517387 88.549339 88.572449 88.600449 88.641747 88.665741 88.673569 88.680389 88.68425 88.700981 88.729553 88.789787 88.809769 88.82357 88.876945 88.913681 88.922157 88.927193 88.949677 88.995705 89.04985 89.093887 89.133987 89.18087 89.261703 89.365089 89.437256 89.483047 89.512688 89.560699 89.617043 89.662994 89.719894 89.790321 89.851036 89.890144 89.92305 89.959335 89.99527 90.037651 90.083519 90.11808 90.149094 90.177071 90.20002 90.225769 90.243637 90.253746 90.25708 90.25116 * * * * * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * 90.504745 90.480293 90.399429 * 90.221085 90.102379 89.69548 89.252892 88.908539 88.728477 88.700928 88.691734 88.672554 88.652809 88.632484 88.611572 88.590034 88.567856 88.544998 88.521439 88.497147 88.472092 88.446228 88.419533 88.39196 88.363472 88.33403 88.303581 88.272079 88.239479 88.205727 88.170761 88.134521 88.096962 88.057999 88.01757 87.975609 87.932037 87.886765 87.839722 87.790817 87.73996 87.68705 87.632004 87.574722 87.515091 87.453033 87.388428 87.32119 87.251221 87.178764 87.101379 87.018867 86.935547 86.846741 86.754845 86.660881 86.564346 86.462753 86.35907 86.255325 86.149391 86.042267 85.929451 * 86.311661 86.790939 86.923187 * * * * * * 85.952583 86.20385 86.161957 85.420914 85.135612 85.200836 85.260849 85.334076 85.412674 85.495453 85.598488 85.711426 85.816658 85.925919 86.033859 86.148544 86.254768 86.361595 86.465637 86.563667 86.699821 86.870224 87.015938 87.120186 87.212173 87.302826 87.392143 87.4
71138 87.548866 87.626427 87.697327 87.770851 87.852272 87.851479 * * * 87.78772 87.836227 87.881378 87.923019 87.965881 88.007355 88.047333 88.085876 88.123055 88.158928 88.193558 88.227013 88.259331 88.290573 88.320786 88.350021 88.378311 88.405701 88.432236 88.457947 88.482742 88.506195 88.531403 88.554085 88.576447 88.610764 88.636955 88.643578 88.658028 88.676369 88.695244 88.718155 88.756889 88.792702 88.813469 88.843132 88.88221 88.897614 88.914574 88.945961 88.99205 89.040977 89.083817 89.121201 89.159645 89.223877 89.328484 89.420097 89.484337 89.5242 89.571342 89.630661 89.687355 89.744514 89.806778 89.863068 89.900238 89.926529 89.952545 89.982056 90.017067 90.053001 90.087509 90.11277 90.13723 90.162399 90.18705 90.198189 90.206032 90.215302 90.210602 * * * * * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * 90.55278 90.510445 * 90.414406 90.251411 89.872551 89.441719 89.06572 88.797325 88.697647 88.684135 88.667999 88.647018 88.626534 88.605339 88.583511 88.561012 88.537827 88.513908 88.489235 88.463776 88.437485 88.410324 88.382263 88.353241 88.323235 88.292175 88.260025 88.226723 88.192215 88.156433 88.119331 88.080818 88.04084 87.999306 87.956146 87.911278 87.864601 87.816025 87.76545 87.712776 87.657898 87.600685 87.541039 87.478836 87.41394 87.346237 87.275597 87.201881 87.125504 87.043236 86.955681 86.865219 86.769989 86.671463 86.571594 86.465828 86.35717 86.244186 86.129143 86.010826 85.89328 85.769165 85.658516 85.999779 86.592758 86.900597 86.813225 * * * * 86.221703 85.931206 86.155609 85.790749 84.973724 84.867401 84.932732 85.004944 85.090584 85.18251 85.278572 85.387566 85.506271 85.626221 85.746651 85.868156 85.996643 86.115158 86.231239 86.343086 86.451874 86.600945 86.777954 86.909676 87.010147 87.110451 87.2062
91 87.300072 87.387924 87.468842 87.550613 87.626862 87.701927 87.787605 87.797127 * * 87.711678 87.763496 87.813255 87.85907 87.902969 87.947136 87.989746 88.030769 88.070282 88.10836 88.145065 88.180473 88.214645 88.247635 88.279495 88.310287 88.340065 88.368858 88.396729 88.423698 88.449829 88.475166 88.499702 88.523216 88.546097 88.568375 88.591843 88.613289 88.632286 88.651649 88.671654 88.690559 88.708725 88.731056 88.778885 88.809364 88.822617 88.851875 88.871307 88.90126 88.948502 88.995461 89.034149 89.072021 89.102257 89.131302 89.181572 89.267448 89.370026 89.459824 89.517204 89.566566 89.631042 89.696404 89.754936 89.812874 89.86676 89.901733 89.921455 89.940315 89.960777 89.987076 90.024513 90.056656 90.070389 90.092949 90.122681 90.146088 90.152802 90.152184 90.164459 90.165886 * * * * * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * 90.553604 90.41275 90.110817 89.744225 89.352898 88.994324 88.769371 88.685501 88.659126 88.64212 88.620865 88.599388 88.577271 88.554474 88.53096 88.506699 88.481667 88.455811 88.4291 88.401497 88.372948 88.343422 88.312859 88.281212 88.248421 88.214439 88.179192 88.142624 88.104652 88.065216 88.024231 87.981613 87.937271 87.891121 87.843048 87.792946 87.740715 87.686234 87.629372 87.569992 87.507965 87.443146 87.375381 87.30452 87.230408 87.152901 87.071899 86.984718 86.891922 86.794373 86.694344 86.588844 86.479904 86.364845 86.248268 86.124672 85.997223 85.86718 85.734718 85.598152 85.453499 85.544739 86.147842 86.612534 86.749832 * * * 86.755814 86.196777 85.902092 85.985092 85.275291 84.526779 84.561951 84.635101 84.721443 84.821404 84.928009 85.042419 85.167854 85.297699 85.430878 85.563934 85.69751 85.83625 85.966637 86.095634 86.217926 86.339394 86.502007 86.669861 86.791763 86.898087 87.005295 87.110405 87.206
39 87.300697 87.387962 87.471657 87.554733 87.632042 87.719917 87.742737 * * 87.686348 87.739975 87.79039 87.836845 87.883492 87.928986 87.97271 88.014763 88.055229 88.094185 88.131706 88.16787 88.202736 88.236382 88.268852 88.300209 88.330513 88.359795 88.388123 88.415527 88.442055 88.467743 88.492638 88.516762 88.540176 88.562874 88.584404 88.605362 88.626884 88.64724 88.666801 88.68586 88.703278 88.726601 88.770416 88.796867 88.823601 88.850052 88.877174 88.909592 88.9552 88.991776 89.017998 89.047806 89.074211 89.101578 89.149521 89.216492 89.308769 89.413536 89.492805 89.554077 89.621613 89.686539 89.74736 89.807533 89.858673 89.892235 89.908333 89.928574 89.946419 89.960152 89.992691 90.023201 90.033684 90.050926 90.078354 90.100937 90.110245 90.106903 90.118141 90.119324 * * * * * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * 90.657486 90.586449 90.393227 90.082802 89.681534 89.270798 88.92646 88.70871 88.643471 88.636513 88.61525 88.593674 88.570732 88.547386 88.524193 88.499969 88.474434 88.448212 88.421097 88.393059 88.364052 88.33403 88.302933 88.270714 88.237312 88.20266 88.166702 88.129356 88.090553 88.050209 88.00824 87.964561 87.91906 87.871643 87.822189 87.770592 87.716721 87.660439 87.601601 87.540062 87.475647 87.408203 87.337547 87.263489 87.185837 87.104591 87.018379 86.924995 86.82666 86.723587 86.618156 86.504997 86.386284 86.263359 86.134918 85.999435 85.859329 85.717903 85.57045 * * * 85.607811 86.169479 86.550797 86.782974 86.869926 86.890915 86.752159 86.212524 85.89119 85.647987 84.58847 84.129372 84.216599 84.302788 84.406013 84.522995 84.646507 84.784355 84.930511 85.080009 85.230667 85.380791 85.528938 85.675713 85.817703 85.95784 86.090179 86.224762 86.391655 86.543716 86.667976 86.786621 86.89917 87.012321 87.114815
87.211647 87.307182 87.393356 87.480988 87.563995 87.651283 87.686905 * * 87.661774 87.71711 87.768852 87.816536 87.864769 87.911484 87.956306 87.999367 88.040756 88.080574 88.118889 88.155785 88.191338 88.225609 88.258667 88.290573 88.321381 88.351143 88.379913 88.40773 88.434647 88.460701 88.485931 88.510376 88.534065 88.557037 88.579338 88.601006 88.621956 88.642349 88.662163 88.681442 88.698486 88.721794 88.766426 88.803482 88.850098 88.881943 88.90554 88.927277 88.959251 88.985001 88.993752 89.016106 89.046661 89.075996 89.124001 89.187119 89.262695 89.355804 89.451332 89.532661 89.605873 89.668785 89.731003 89.797684 89.846375 89.874207 89.891411 89.9077 89.922745 89.931641 89.947281 89.969749 89.988136 90.003029 90.0299 90.052956 90.064644 90.067101 90.074074 90.0672 * * * * * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * 90.729164 90.617737 90.325485 89.924187 89.508278 89.112373 88.775703 88.647942 88.633133 88.608978 88.587128 88.566132 88.543854 88.517937 88.491898 88.467064 88.441017 88.413498 88.385048 88.355598 88.325096 88.293488 88.260719 88.226723 88.191429 88.154778 88.116684 88.077072 88.035851 87.992928 87.948204 87.901573 87.852921 87.802124 87.749054 87.693565 87.635506 87.574722 87.511032 87.444252 87.374191 87.300629 87.223358 87.142143 87.056816 86.964836 86.866829 86.763489 86.654037 86.540016 86.418709 86.291283 86.16037 86.019073 85.872719 85.718674 85.56266 85.397659 * * * * 85.494667 86.154686 86.61972 86.801239 86.786812 86.590233 86.165108 85.811478 85.127403 83.852501 83.699722 83.827034 83.928383 84.053055 84.190628 84.338577 84.502792 84.67321 84.846054 85.018806 85.18943 85.356316 85.517815 85.674187 85.824989 85.968529 86.109871 86.262383 86.405472 86.537506 86.669518 86.792252 86.910095 87.022507 87.12431
3 87.224762 87.317314 87.407135 87.495728 87.5849 87.628975 * 87.57901 87.638062 87.695038 87.748398 87.797455 87.84684 87.894707 87.94059 87.984627 88.026924 88.067574 88.106659 88.144264 88.180473 88.215355 88.248978 88.28141 88.312706 88.342926 88.372116 88.400337 88.42762 88.454018 88.479576 88.504318 88.528297 88.551537 88.574081 88.595947 88.617165 88.637772 88.657784 88.677185 88.69429 88.720749 88.770149 88.822746 88.871872 88.899513 88.914688 88.931015 88.951233 88.971474 88.978821 88.997513 89.032845 89.059975 89.094826 89.154755 89.22773 89.309807 89.404053 89.496185 89.585701 89.660599 89.725433 89.786011 89.831001 89.856606 89.863716 89.870827 89.881226 89.885994 89.898727 89.910652 89.925095 89.946663 89.979767 90.003899 90.01622 90.021393 90.024742 * * * * * * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * 90.816574 90.74585 90.508087 90.131744 89.709473 89.315712 88.904915 88.679054 88.639763 88.610893 88.585762 88.571381 88.551277 88.517265 88.486046 88.461136 88.432762 88.406013 88.377533 88.34761 88.31665 88.284554 88.251259 88.21669 88.180786 88.143471 88.104652 88.064262 88.022194 87.978348 87.932617 87.884895 87.835045 87.782936 87.728424 87.671356 87.611565 87.548866 87.483055 87.41394 87.341286 87.264847 87.184364 87.099609 87.00985 86.91169 86.809898 86.701294 86.585007 86.462532 86.334526 86.197914 86.054138 85.901466 85.745758 85.576553 85.398766 * * * * * * 85.351288 86.047272 86.377243 86.440125 86.210472 85.917442 85.665009 84.497818 * * * 83.504311 83.653259 83.816872 84.000092 84.195129 84.394676 84.595039 84.793297 84.987236 85.17527 85.356339 85.529762 85.695038 85.85231 86.001472 86.144585 86.282082 86.417168 86.55088 86.681259 86.804977 86.927696 87.0383 87.139938 87.239906 87.333305 87.424728 87.51
8639 87.571365 * 87.554474 87.615326 87.673912 87.728729 87.779106 87.82972 87.878716 87.925629 87.970612 88.013779 88.055229 88.095047 88.133339 88.170181 88.20565 88.239815 88.272743 88.304512 88.335159 88.364761 88.393349 88.42099 88.447723 88.473579 88.498619 88.522865 88.546364 88.569138 88.591232 88.612663 88.633469 88.653671 88.673264 88.696671 88.738457 88.779045 88.823112 88.865334 88.882576 88.89785 88.918243 88.938438 88.951462 88.962547 88.984261 89.022141 89.05249 89.077385 89.122337 89.197754 89.281311 89.377007 89.477859 89.576004 89.659332 89.727951 89.776611 89.814674 89.8367 89.836296 89.838631 89.84214 89.840126 89.844498 89.854881 89.867249 89.892265 89.928116 89.949936 89.962486 89.970406 89.972656 89.96772 * * * * * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * 90.862267 90.851379 90.799164 90.651802 90.356178 89.949425 89.552185 89.099648 88.749001 88.661903 88.635674 88.609291 88.596031 88.56974 88.529785 88.499847 88.46817 88.430336 88.399513 88.369926 88.340134 88.308723 88.276154 88.242355 88.207245 88.170761 88.132805 88.093307 88.052162 88.009285 87.964561 87.91787 87.869087 87.818085 87.764717 87.708817 87.650215 87.588737 87.52417 87.456299 87.384888 87.309685 87.230408 87.146751 87.058395 86.963623 86.860794 86.753845 86.638519 86.51561 86.386505 86.251198 86.105247 85.950226 85.786552 85.613571 * * * * * * * * * * 85.027145 85.246674 85.416298 85.565086 85.498009 * * * * * 83.19664 83.401299 83.626282 83.858704 84.093559 84.326622 84.554649 84.775352 84.987236 85.189415 85.38147 85.563301 85.735107 85.897003 86.04847 86.190544 86.32637 86.452835 86.579102 86.706741 86.831726 86.948425 87.055588 87.160629 87.261444 87.354004 87.452103 87.513908 * 87.53096 87.593674 8
7.653862 87.71035 87.761826 87.813499 87.863579 87.911484 87.957375 88.001373 88.043579 88.084114 88.123055 88.160492 88.19651 88.231194 88.264603 88.296814 88.327873 88.357857 88.386803 88.41478 88.441818 88.467972 88.493279 88.517784 88.541519 88.564522 88.586823 88.608452 88.629448 88.649826 88.670029 88.704201 88.757866 88.784966 88.808205 88.837967 88.854156 88.872688 88.894722 88.919289 88.929207 88.942314 88.972771 89.010712 89.044441 89.07222 89.109886 89.178352 89.266556 89.376396 89.485504 89.582108 89.668655 89.731171 89.770386 89.799644 89.80941 * * * 89.797165 * 89.801346 89.816177 89.841537 89.870735 89.893463 89.90995 89.913513 89.915421 89.917511 * * * * * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * 90.898354 90.887245 90.859749 90.807755 90.726234 90.553741 90.23336 89.863914 89.419067 88.947472 88.718262 * 88.66597 88.641869 88.603188 88.561668 88.535629 88.496635 88.449005 88.40126 88.3629 88.332634 88.301155 88.268234 88.234047 88.198425 88.161385 88.122833 88.082687 88.04084 87.997185 87.951622 87.904015 87.854233 87.802124 87.747543 87.690315 87.630249 87.567146 87.500778 87.430908 87.357277 87.279594 87.19754 87.110779 87.018707 86.917938 86.81208 86.699295 86.578743 86.449478 86.312141 86.166077 86.012238 85.851776 85.67144 85.472153 * * * * * * * * * * * * * 85.297379 85.253204 * * * * * * * 83.212723 83.491219 83.768867 84.040726 84.303375 84.554649 84.793297 85.018806 85.231117 85.430519 85.617523 85.792755 85.956902 86.110878 86.253517 86.382393 86.507042 86.630989 86.748749 86.862984 86.973503 87.08149 87.188644 87.286232 87.385841 87.4571 87.460159 87.508728 87.573227 87.634773 87.691948 87.745201 87.79
8264 87.849358 87.898209 87.944962 87.989746 88.032684 88.073875 88.113434 88.151443 88.187988 88.223152 88.257011 88.289635 88.321083 88.351425 88.380714 88.408997 88.436333 88.462753 88.488319 88.513062 88.537025 88.560234 88.582733 88.604546 88.625717 88.646255 88.666504 88.696701 88.743729 88.774307 88.791061 88.815208 88.838318 88.855026 88.870445 88.888138 88.900887 88.926537 88.960709 88.996513 89.031029 89.067497 89.113899 89.179062 89.269249 89.379715 89.494133 89.596405 89.687263 89.73996 89.766487 89.785446 89.791031 * * * * * * * 89.794022 89.810989 89.832779 89.854019 89.855347 89.858841 89.867958 89.870773 * * * * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * 90.913986 90.894859 90.857063 90.795944 90.730453 90.637222 90.455467 90.20755 89.827934 89.289467 88.876122 * 88.729919 88.704842 88.663925 88.617874 88.574234 88.532349 88.48452 88.421745 88.365051 88.32634 88.294609 88.261398 88.226341 88.190262 88.152702 88.113586 88.07283 88.030319 87.985947 87.93959 87.891121 87.840385 87.787247 87.731522 87.673027 87.611565 87.546913 87.478836 87.407059 87.331291 87.251221 87.166496 87.076714 86.981255 86.875671 86.76519 86.646416 86.521835 86.386139 86.241486 86.0868 85.923462 85.74752 85.54628 85.333366 85.11779 * * * * * * * * * * * * 85.134621 84.905746 * * * * * * * * 83.090843 83.420319 83.738037 84.040726 84.326622 84.595039 84.846054 85.080185 85.298264 85.501259 85.690208 85.86615 86.030136 86.183121 86.323235 86.452675 86.576355 86.692741 86.803856 86.909508 87.013992 87.118279 87.216522 87.3153 87.398178 87.431473 87.488022 87.554131 87.616814 87.67382 87.729469 87.78408
1 87.836128 87.885864 87.933426 87.978958 88.022575 88.064392 88.104523 88.143059 88.180092 88.215714 88.249992 88.283005 88.314812 88.34549 88.375084 88.403664 88.431267 88.457947 88.483749 88.508713 88.532875 88.556282 88.578964 88.600952 88.622284 88.642975 88.663086 88.683411 88.711632 88.743256 88.765076 88.790359 88.819565 88.84095 88.855453 88.865219 88.882195 88.912994 88.943901 88.976692 89.011734 89.063301 89.124489 89.196548 89.288246 89.390129 89.502335 89.609428 89.69561 89.74411 89.766747 89.779633 89.779121 * * * * * * * * * 89.775208 89.791519 89.802696 89.81115 89.822006 89.83194 * * * * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * 90.918587 90.894371 90.858513 90.781464 90.685837 90.591965 90.487183 90.372467 90.137123 89.690392 89.231483 88.936516 88.818794 88.783051 88.745773 88.686295 88.618187 88.565582 88.518394 88.453072 88.381866 88.327324 88.291229 88.255249 88.219315 88.18277 88.144737 88.105103 88.063782 88.020653 87.975609 87.92852 87.879242 87.827629 87.773514 87.716721 87.657043 87.594276 87.528168 87.458473 87.384888 87.307106 87.22477 87.137497 87.044868 86.945709 86.836845 86.720734 86.597313 86.46595 86.323456 86.175774 86.015465 85.834236 85.633812 85.423286 85.205559 84.970215 84.714905 * * * * * * * * * * * 84.933258 84.64048 * * * * * * * * * 83.048737 83.420319 83.768867 84.093559 84.394676 84.67321 84.930519 85.168152 85.387688 85.59066 85.778549 85.952705 86.114838 86.263634 86.398514 86.528633 86.650864 86.764923 86.870598 86.971573 87.068779 87.160675 87.25248 87.340134 87.402512 87.468765 87.536377 87.599586 87.6576 87.71
5317 87.770996 87.823944 87.874504 87.922821 87.96904 88.01329 88.055687 88.096352 88.135376 88.172867 88.2089 88.243568 88.276932 88.309082 88.340065 88.369949 88.398788 88.426643 88.453552 88.479576 88.504738 88.529099 88.552681 88.575531 88.597679 88.619156 88.639984 88.660194 88.678902 88.697655 88.71949 88.738907 88.760551 88.787102 88.814911 88.838264 88.858971 88.883476 88.9011 88.923454 88.953987 88.99086 89.058571 89.137115 89.219978 89.315033 89.411606 89.50956 89.606216 89.680397 89.732391 89.758438 89.768532 * * * * * * * * * * * * 89.747406 89.761078 89.773216 89.791023 89.792709 * * * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * 90.924057 90.919128 90.896309 90.858551 90.766342 90.629974 90.485008 90.327034 90.244858 90.166496 89.936874 89.617294 89.277176 88.995155 88.855782 88.812935 88.742813 88.666466 88.600227 88.545982 88.483047 88.410789 88.341499 88.293617 88.251144 88.212738 88.17585 88.136391 88.096107 88.054832 88.006989 87.957169 87.912247 87.866066 87.815567 87.761192 87.703209 87.642464 87.578484 87.511032 87.439827 87.364563 87.284897 87.200447 87.110771 87.015648 86.911369 86.798546 86.678246 86.552208 86.41526 86.267754 86.111198 85.937988 85.739059 85.529434 85.31498 85.080917 84.825089 84.54641 * * * * * * * * * * * * 84.618141 * * * * * * * * * * 83.090843 83.491219 83.858704 84.195137 84.502853 84.784348 85.042091 85.278419 85.495491 85.695259 85.879494 86.050148 86.205505 86.347008 86.482964 86.610039 86.728668 86.839813 86.943481 87.040184 87.131004 87.217171 87.300995 87.378227 87.451141 87.520042 87.582832 87.643234 87.7026
21 87.759079 87.812874 87.864189 87.913193 87.960045 88.004868 88.047798 88.088943 88.128426 88.166321 88.202736 88.237755 88.271454 88.303894 88.335159 88.365311 88.394394 88.42247 88.449593 88.475807 88.50116 88.525688 88.549438 88.572441 88.594711 88.616402 88.637398 88.657623 88.677444 88.69632 88.714111 88.731148 88.748894 88.767731 88.788857 88.812714 88.841888 88.877571 88.897102 88.909035 88.933517 88.972626 89.045525 89.143219 89.234886 89.33004 89.422104 89.506927 89.588043 89.646599 89.697983 89.730133 89.741478 * * * * * * * * * * * * * * 89.719124 89.742233 89.750977 * * * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * 90.924751 90.90519 90.876701 90.828087 90.726883 90.590889 90.426933 90.177498 89.994545 89.930038 89.81604 89.632149 89.386459 * * * * * * * * * * * * * * 88.131691 88.088463 * * 87.967293 87.912209 87.855888 87.803345 87.747673 87.691597 87.629333 87.564285 87.495605 87.423035 87.346237 87.264847 87.178444 87.086617 86.988747 86.879959 86.764809 86.640823 86.510674 86.372047 86.216911 86.043434 85.853775 85.651756 85.441818 85.213005 84.961945 84.686234 * * * * * * * * * * * * 84.921402 84.697205 * * * * * * * * * * 82.754929 83.212708 83.626411 84.00016 84.338135 84.644295 84.922264 85.17527 85.406189 85.617523 85.81147 85.99025 86.153244 86.300842 86.441139 86.572617 86.695084 86.809402 86.916321 87.016518 87.110596 87.198769 87.281418 87.360764 87.435341 87.505577 87.568802 87.630554 87.691154 87.748413 87.802956 87.854958 87.904587 87.952003 87.997353 88.040756 88.082344 88.122223 88.160492 88.19725 88.232582 88.26657
1 88.299286 88.330803 88.361183 88.39048 88.418762 88.446075 88.472466 88.497978 88.522667 88.546562 88.569824 88.592346 88.613762 88.634712 88.65554 88.675385 88.694466 88.712944 88.73159 88.749153 88.765533 88.781181 88.798988 88.817009 88.849846 88.880821 88.896339 88.922737 88.96109 89.022972 89.127541 89.225586 89.316818 89.404182 89.48349 89.555374 89.599335 89.64267 89.685478 89.712608 * * * * * * * * * * * * * * * 89.692871 89.703545 89.703239 89.703094 * * * * * * * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * 90.921593 90.886223 90.838974 90.777756 90.678322 90.561661 90.413986 90.154427 * * * * * * * * * * * * * * * * * * * * * * * 88.264687 88.126701 87.943985 87.813553 87.738243 87.679741 87.617996 87.551773 87.482002 87.408203 87.330048 87.2472 87.159042 87.065453 86.963264 86.852066 86.736771 86.611725 86.475136 86.327538 86.159592 85.976822 85.782959 85.580811 85.360924 85.118652 84.851631 84.556351 84.225998 * * * * * * * * * * * 84.913765 84.665314 * * * * * * * * * * 82.420403 82.940018 83.402222 83.814278 84.182724 84.513329 84.811066 85.080185 85.324341 85.546631 85.74971 85.935905 86.107155 86.261452 86.403709 86.539154 86.665115 86.782463 86.892021 86.994522 87.090622 87.180885 87.265808 87.345856 87.421448 87.492317 87.55687 87.619759 87.681038 87.739044 87.79425 87.846863 87.897041 87.944962 87.990768 88.034592 88.076561 88.116798 88.155396 88.192451 88.228058 88.262306 88.295258 88.326996 88.357574 88.38707 88.41
5527 88.443001 88.469551 88.495201 88.520096 88.544205 88.566986 88.589378 88.610481 88.631264 88.652977 88.672852 88.69175 88.709831 88.729149 88.746971 88.76432 88.781631 88.797691 88.810867 88.828613 88.850616 88.873459 88.904205 88.936501 88.988724 89.089226 89.188484 89.271103 89.349091 89.422028 89.485664 89.529282 89.574081 89.630486 89.682747 * * * * * * * * * * * * * * * 89.653572 89.667229 89.668823 * * 89.66243 * * * * * * * * * 89.652496
+* * * * * * * * * * * * * * * * * * * * * * * * * 90.910301 90.906212 90.861359 90.803871 90.732841 90.638809 * * * * * * * * * * * * * * * * * * * * * * * * * * 89.075859 88.775703 88.313148 87.947906 87.771156 87.656273 87.609093 87.541298 87.470062 87.39492 87.315193 87.230042 87.140198 87.046104 86.941811 86.828682 86.71167 86.584984 86.441673 86.280731 86.102776 85.920845 85.728798 85.519157 85.288704 85.034309 84.75251 84.437843 * * * * * * * * * * * 85.11367 84.645302 84.530724 84.009338 * * * * * * * * * 82.098175 82.682442 83.192787 83.642723 84.040726 84.394676 84.711044 84.995186 85.251564 85.483887 85.695259 85.88829 86.065903 86.226135 86.371101 86.510063 86.639114 86.759125 86.871002 86.975533 87.073402 87.165222 87.251534 87.332787 87.409706 87.479836 87.545494 87.610603 87.672379 87.731026 87.786804 87.839935 87.890594 87.938942 87.985146 88.029327 88.071632 88.112167 88.151047 88.188362 88.224205 88.258667 88.291824 88.323753 88.354507 88.384163 88.412773 88
.440384 88.467094 88.493042 88.517723 88.541275 88.563461 88.585617 88.607315 88.628387 88.649635 88.669609 88.688858 88.70739 88.726265 88.744102 88.761566 88.77948 88.796516 88.813179 88.825409 88.837761 88.853859 88.874832 88.896942 88.936638 89.018303 89.115433 89.192276 89.261009 89.329659 89.392769 89.44371 89.493919 89.559654 89.625641 89.639648 * * * * * * * * * * * * * 89.591042 89.621788 89.62928 * * * 89.626228 * * * * * * * * 89.617332 89.644051
+* * * * * * * * * * * * * * * * * * * * * * * * * 90.909294 90.87851 90.811653 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.982201 89.537422 88.901833 88.338982 87.929756 87.656532 87.594231 87.528816 87.460426 87.385895 87.306084 87.220909 87.130806 87.031075 86.924759 86.811546 86.689186 86.553558 86.403542 86.237946 86.06115 85.879982 85.683144 85.466293 85.227036 84.961952 84.667015 84.333763 * * * * * * * * * * 85.345078 85.461075 84.31144 84.317497 83.748032 83.524849 * * * * * * * * * 82.442352 83.007103 83.491196 83.916481 84.291649 84.624756 84.922264 85.189415 85.430519 85.649117 85.848198 86.030907 86.194946 86.343689 86.48571 86.617378 86.739647 86.853485 86.959724 87.05909 87.152222 87.239685 87.322021 87.399551 87.469292 87.536812 87.602936 87.665222 87.724396 87.780655 87.834221 87.885269 87.933983 87.980507 88.024994 88.067574 88.10836 88.147461 88.18499 88.221039 88.255684 88.289009 88.321083 88.35199 88.381775 88.410606 88.438446 88.465096 8
8.490646 88.514694 88.537766 88.560745 88.583282 88.605453 88.626869 88.647446 88.667572 88.687141 88.706184 88.72448 88.742378 88.759842 88.777077 88.794334 88.810959 88.825302 88.838211 88.849258 88.862556 88.877762 88.894234 88.935379 89.007896 89.072708 89.141129 89.225937 89.30336 89.360863 89.410965 89.470314 89.529533 89.574402 * * * * * * * * * * * * * 89.559189 89.583138 * * * 89.575027 89.580193 * * * * * * * 89.593002 89.612839 89.629822
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 90.645088 90.116562 89.488632 88.950439 88.36113 87.838455 87.602074 87.52449 87.467117 87.400696 87.330757 87.25515 87.170685 87.051208 86.915947 86.795227 86.663933 86.521416 86.367264 86.203979 86.033089 85.848915 85.646538 85.423767 85.177361 84.903503 84.596443 * * * * * * * * * * * 85.58313 84.926743 83.787582 83.894241 83.349266 83.215164 83.089684 * * * * * * * * 82.229607 82.844696 83.366013 83.814278 84.207474 84.554649 84.863281 85.139359 85.387688 85.612221 85.81617 86.001884 86.169609 86.321938 86.466415 86.600182 86.724258 86.839661 86.94725 87.047806 87.141983 87.230362 87.313751 87.390327 87.460938 87.530548 87.59684 87.659615 87.7192 87.775841 87.829742 87.881104 87.930099 87.976883 88.021599 88.064392 88.105377 88.144661 88.182358 88.218559 88.253342 88.286804 88.318993 88.35006 88.380074 88.408546 88.436089 88.462646 88.487381 88.511795 88.5357
06 88.559433 88.582291 88.604378 88.625793 88.646561 88.666718 88.686279 88.705276 88.723732 88.741669 88.759094 88.775917 88.792603 88.809105 88.823074 88.835625 88.849792 88.864326 88.878326 88.887444 88.900475 88.926041 88.959778 89.013763 89.109009 89.205368 89.271713 89.318367 89.36615 89.412727 89.470337 89.512291 * * * * * * * * * * * 89.493401 89.521431 89.534866 * * * * 89.52771 89.531914 89.532257 * * * 89.533798 89.560005 89.592934 89.622002 89.642548
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 90.961586 90.526054 90.005402 89.570152 88.959175 88.24733 87.801773 87.611031 87.527748 87.468483 87.411911 87.326904 87.248985 87.134674 86.962868 86.784485 86.64003 86.495728 86.342056 86.184196 86.013237 85.825691 85.619781 85.392662 85.140953 84.859978 * * * * * * * * * * * * 84.416267 83.992371 83.154655 83.179466 82.271942 82.410797 82.874397 82.551064 * * * * * * 81.759827 82.175331 82.702454 83.267471 83.738312 84.144974 84.502853 84.819878 85.102631 85.356339 85.585381 85.791626 85.976982 86.148384 86.306061 86.452431 86.58773 86.713127 86.829666 86.938248 87.039665 87.134598 87.223633 87.307823 87.383942 87.4552 87.525902 87.592476 87.655579 87.715469 87.772377 87.82653 87.878113 87.927307 87.974274 88.019165 88.062111 88.103241 88.142654 88.180473 88.216782 88.251671 88.28524 88.317657 88.348618 88.378181 88.405838 88.432892 88.459816 88.485199 88.510
452 88.534958 88.55854 88.58139 88.603523 88.624977 88.64579 88.66597 88.68557 88.704597 88.723076 88.741043 88.758507 88.775513 88.792229 88.80748 88.820343 88.834229 88.849434 88.863998 88.878113 88.892525 88.904221 88.911057 88.921814 88.942947 89.00135 89.083389 89.144058 89.180695 89.228424 89.282997 89.348419 89.407143 89.432167 * * * * 89.447517 89.457649 * * * * 89.466927 89.483513 * * * * * 89.484917 89.499725 89.511246 89.512527 * * 89.521255 89.56868 89.616394 89.648483 89.676865
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.05899 90.836647 90.463142 90.017563 89.408325 88.694283 88.152107 87.802315 87.652176 87.594055 87.5215 87.416542 87.321159 87.211861 87.046509 86.845345 86.672867 86.494629 86.332039 86.174057 86.001244 85.811554 85.603493 85.37368 * * * * * * * * * * * * * * * 84.087341 82.802612 81.951355 78.953636 80.18718 81.678566 81.781738 * 81.608749 81.812233 * * 81.564461 82.155167 82.478256 82.72126 83.207924 83.687706 84.107307 84.471008 84.793297 85.080177 85.337303 85.56826 85.773445 85.960815 86.135788 86.29644 86.443962 86.5802 86.706398 86.823624 86.932816 87.034752 87.130142 87.21962 87.303864 87.380539 87.452255 87.523026 87.589844 87.653152 87.713219 87.770294 87.824593 87.876312 87.925629 87.97271 88.0177 88.060738 88.101952 88.141449 88.179329 88.215767 88.250816 88.284332 88.316429 88.346741 88.375481 88.403671 88.431297 88.458427 88.484695 88.509949 88.
534355 88.557983 88.580856 88.603012 88.624489 88.645325 88.665527 88.685143 88.704185 88.722687 88.740669 88.758156 88.775337 88.791534 88.804985 88.818741 88.834206 88.849167 88.863724 88.877922 88.891769 88.905365 88.919037 88.929558 88.937798 88.951851 88.98336 89.016052 89.038635 89.078751 89.135872 89.210762 89.277565 89.340752 89.377838 89.377014 89.378632 89.3909 89.406723 89.415405 * * * 89.416679 89.442192 89.448471 * * * * 89.448074 89.458443 89.475922 89.493439 89.495102 * * 89.539894 89.605904 89.650131 89.677589 89.709282
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.157417 91.119537 91.000275 90.732437 90.285728 89.689613 89.078613 88.574242 88.112808 87.85128 87.765816 87.670685 87.553062 87.416557 87.278854 87.135674 86.980629 86.78212 86.552605 86.342888 86.166916 85.993423 85.806824 85.597572 * * * * * * * * * * * * * * * 85.487518 85.389969 84.608276 82.01812 180 75.063782 79.15181 80.406548 80.846001 81.06765 81.139297 * 81.352478 81.927254 82.618835 82.997536 83.08712 83.291077 83.674347 84.090752 84.460861 84.784325 85.072716 85.330719 85.559105 85.764954 85.957184 86.132568 86.293243 86.441124 86.577675 86.70414 86.821609 86.930992 87.033104 87.128647 87.21846 87.301613 87.377472 87.451332 87.522072 87.588966 87.652336 87.712471 87.7696 87.823944 87.87571 87.925072 87.972183 88.017212 88.06028 88.101524 88.141037 88.179016 88.215279 88.249855 88.283318 88.314346 88.344635 88.374115 88.403275 88.431358 88.458374 88.
484497 88.509743 88.534157 88.557793 88.580673 88.602844 88.624329 88.645164 88.665382 88.684998 88.704048 88.722557 88.740547 88.75811 88.774818 88.789108 88.803078 88.818748 88.834129 88.849068 88.863632 88.877831 88.891685 88.905197 88.91835 88.931519 88.944649 88.951973 88.958244 88.97049 88.982498 88.999161 89.024864 89.082397 89.156334 89.230232 89.28746 89.307983 89.324478 89.348801 89.361473 89.361565 * * 89.369331 89.393539 89.417435 89.418449 * * * 89.421219 89.428986 89.441093 89.456879 89.46965 * * 89.511093 89.585014 89.638786 89.669006 89.704483 89.737984
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.206635 91.168594 91.055878 90.852371 90.51413 90.019188 89.514709 89.079117 88.594315 88.180565 87.978271 87.856514 87.71109 87.54496 87.395897 87.268211 87.110764 86.894325 86.646881 86.39502 86.176346 85.987373 85.813042 * * * * * * * * * * * * * * * * * 87.307678 87.39119 84.155418 76.270714 75.059563 76.837059 78.563866 79.572701 79.977325 80.290939 80.955154 81.716057 82.481361 83.047966 83.342583 83.504372 83.579819 83.756371 84.091942 84.47123 84.793449 85.080475 85.334465 85.559929 85.770065 85.961517 86.1362 86.296448 86.443962 86.5802 86.706398 86.823624 86.932816 87.034752 87.130135 87.219986 87.302063 87.377739 87.452415 87.523026 87.589844 87.653152 87.713219 87.770294 87.824593 87.876312 87.925629 87.97271 88.0177 88.060738 88.101952 88.141472 88.17939 88.214371 88.248032 88.281746 88.313187 88.344353 88.374596 88.403603 88.431587 88.458603 88.4847
11 88.509949 88.534355 88.557983 88.580856 88.603012 88.624489 88.645325 88.665527 88.685143 88.704185 88.722687 88.7407 88.758011 88.773376 88.787277 88.80294 88.818832 88.834229 88.849159 88.863724 88.877922 88.891769 88.905273 88.918457 88.931328 88.94384 88.956573 88.968475 88.979271 88.988831 88.995758 89.002022 89.020622 89.064812 89.133102 89.198006 89.23484 89.261292 89.290276 89.312767 89.317169 89.318733 89.326637 89.344635 89.376663 89.396805 * * * * 89.401955 89.410522 89.426346 89.434975 * 89.444244 89.476852 89.546684 89.614647 89.653419 89.687408 89.72831 89.759109
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.25898 91.218895 91.120125 90.951866 90.70742 90.371895 89.950867 89.484894 88.96225 88.514404 88.23822 88.020172 87.845299 87.698082 87.556267 87.420898 87.22097 86.987602 86.807365 86.649536 86.461029 86.173317 * * * * * * * * * * * * * * * * 87.923538 88.210098 88.702736 87.626984 83.517975 78.346161 75.731956 75.9814 77.338112 78.607819 79.540695 80.458038 81.551743 82.314659 82.904152 83.279785 83.481674 83.713791 83.840225 83.938042 84.1567 84.494484 84.821281 85.101219 85.348106 85.576347 85.784546 85.973885 86.147057 86.306015 86.452431 86.58773 86.713127 86.829666 86.938248 87.039665 87.134613 87.223869 87.305801 87.38131 87.455513 87.525879 87.592476 87.655579 87.715469 87.772377 87.82653 87.878113 87.927307 87.974274 88.019165 88.062111 88.103233 88.142838 88.179955 88.21357 88.247971 88.281654 88.314194 88.345383 88.375404 88.404366 88.432304 88.45929
88.485367 88.510567 88.53495 88.55854 88.58139 88.603523 88.624977 88.64579 88.66597 88.68557 88.70459 88.723114 88.740982 88.757156 88.772842 88.788513 88.803894 88.81942 88.834488 88.849442 88.863991 88.878181 88.892021 88.905518 88.918694 88.931557 88.944115 88.956383 88.968376 88.980057 88.99173 89.003304 89.014534 89.019226 89.029823 89.071472 89.129669 89.166786 89.198868 89.232521 89.261917 89.279259 89.286743 89.301834 89.328674 89.363159 89.383018 * * * * * 89.392731 89.405502 89.414116 89.42321 89.461044 89.517838 89.580894 89.634918 89.677048 89.715897 89.748924 89.777687
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.305031 91.267982 91.190918 91.035957 90.824677 90.560852 90.141891 89.602127 89.047417 88.710754 88.503838 88.247559 88.007523 87.840576 87.731133 87.673927 87.504677 * * 87.62735 87.536049 87.020073 86.507339 86.256775 * * * * * * * * * * * * * 89.106842 89.269386 89.36116 88.84568 86.694138 82.78997 79.006172 77.734123 78.361481 79.173904 79.862755 80.753494 81.761566 82.488899 82.971039 83.456009 83.60955 83.665619 83.864723 84.032761 84.170784 84.307831 84.53997 84.854973 85.130638 85.378525 85.604233 85.808472 85.994202 86.164948 86.321793 86.466415 86.600182 86.724258 86.839661 86.94725 87.047806 87.14209 87.230003 87.309914 87.386696 87.460663 87.530624 87.59684 87.659615 87.7192 87.775841 87.829742 87.881104 87.930099 87.976883 88.021599 88.064392 88.105392 88.144936 88.180923 88.215034 88.249939 88.283447 88.315712 88.346794 88.376747 88.405632 88.43351
88.460434 88.48645 88.511597 88.535927 88.559479 88.582283 88.604378 88.625793 88.646561 88.666718 88.686272 88.705299 88.723808 88.740677 88.756538 88.773689 88.790268 88.805901 88.82048 88.834915 88.849915 88.864449 88.878616 88.892441 88.90593 88.91909 88.931938 88.944481 88.956741 88.968712 88.980415 88.991859 89.003044 89.013947 89.025116 89.033684 89.044914 89.076645 89.114258 89.154236 89.195778 89.220543 89.233528 89.245422 89.275574 89.320671 89.358467 89.370811 * * * * * 89.375191 89.383202 89.411934 89.448845 89.497246 89.554787 89.614532 89.67292 89.716118 89.746559 89.774124 89.806435
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.344826 91.318115 91.270111 91.132912 90.897385 90.604881 90.162659 89.590973 89.140007 88.948692 88.814278 88.601936 88.309013 88.038666 * * * * * 88.986084 88.972527 88.272675 87.534782 87.183746 86.969284 86.691963 * * * * * * * * * * * 89.55574 89.737022 89.597878 88.455147 86.156464 83.082497 81.243462 81.672188 82.423721 82.614159 82.625488 82.898483 83.217422 83.296349 83.675034 84.226089 84.235275 * 84.084595 84.285599 84.45388 84.55793 84.651642 84.887283 85.174103 85.414772 85.631172 85.832481 86.021019 86.189507 86.343864 86.48568 86.617378 86.739647 86.853485 86.959724 87.05909 87.152351 87.238403 87.317162 87.394402 87.467827 87.537209 87.602913 87.665222 87.724396 87.780655 87.834221 87.885269 87.933983 87.980507 88.024994 88.067574 88.108452 88.147026 88.182381 88.217575 88.252266 88.28566 88.317802 88.348763 88.378609 88.407402 88.435188 88.462029
88.487961 88.513039 88.5373 88.560783 88.583527 88.60556 88.626923 88.647644 88.667747 88.687286 88.706337 88.72406 88.74015 88.757454 88.77449 88.791122 88.806877 88.820839 88.83564 88.850578 88.865082 88.879234 88.893028 88.906494 88.919632 88.932465 88.944992 88.95723 88.969193 88.980873 88.992302 89.003471 89.014404 89.025093 89.03569 89.04245 89.05233 89.08345 89.124382 89.166649 89.189522 89.196678 89.216209 89.256187 89.308205 89.347519 89.350189 * * * * * 89.359962 89.386147 89.435883 89.479828 89.51918 89.58078 89.654022 89.716942 89.752258 89.779663 89.811913 89.842087
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.363838 91.353897 91.33329 91.229645 90.941063 90.531403 90.107712 89.677261 89.408768 89.307945 89.181389 88.983505 * * * * * * * 89.775551 89.840401 89.312943 88.522209 88.108086 87.929085 87.685997 87.478546 87.481987 87.472092 87.421638 * * * * * * 89.709671 90.162605 89.98777 89.157005 87.927963 86.000259 84.128754 83.958977 84.953674 85.190697 85.00544 84.770462 84.545357 84.255814 84.038528 84.442162 85.032089 85.001915 * 84.482292 84.603676 84.817307 84.95575 85.00325 85.142113 85.337959 85.515961 85.683876 85.869728 86.067558 86.215019 86.366333 86.510681 86.639076 86.759125 86.871002 86.975533 87.073418 87.164963 87.248505 87.327652 87.404373 87.476952 87.545601 87.610657 87.672379 87.731026 87.786804 87.839935 87.890594 87.938942 87.985146 88.029327 88.071671 88.1119 88.148598 88.1847 88.220734 88.255264 88.28849 88.320473 88.351295 88.381004 88.409668
88.43734 88.464073 88.489906 88.514885 88.539055 88.562454 88.585121 88.607086 88.62838 88.649033 88.669083 88.688622 88.707092 88.723701 88.741142 88.758606 88.77552 88.792183 88.807083 88.821266 88.836578 88.851425 88.865898 88.880013 88.893784 88.907227 88.920341 88.933144 88.945648 88.957863 88.969803 88.981468 88.992874 89.004028 89.014938 89.025612 89.036041 89.046524 89.054451 89.069527 89.096153 89.134369 89.165672 89.179749 89.201286 89.245232 89.290138 89.312927 * * * * * 89.333565 89.368645 89.420494 89.470078 89.506042 89.548622 89.621559 89.693718 89.741257 89.767166 89.801445 89.843285 89.866341
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.374962 91.369789 91.28801 90.988594 90.513428 90.068748 89.84053 89.741394 89.656395 89.52182 * * * * * * * * * 90.184761 89.997498 89.42337 89.032341 88.898712 88.721329 88.719742 88.933868 89.171906 89.463333 89.256882 * * * * 89.951515 90.429276 90.541862 89.895676 88.68512 87.451843 86.352646 85.933624 86.432899 86.987732 86.842072 86.501549 86.070404 85.596069 85.034775 84.798492 85.250877 85.806328 85.781105 85.400612 85.08754 85.059547 85.238731 85.424789 85.635391 85.862717 86.056938 86.179413 86.229248 86.282494 86.303482 86.306938 86.395943 86.536118 86.665482 86.782616 86.892006 86.994522 87.090645 87.180168 87.261261 87.340454 87.416374 87.487961 87.555748 87.620018 87.681038 87.739044 87.79425 87.846863 87.897041 87.944962 87.990768 88.034592 88.076347 88.114777 88.151627 88.188881 88.224594 88.258904 88.291924 88.323723 88.354362 88.383911 88.412
43 88.439957 88.466553 88.492264 88.517136 88.541199 88.564499 88.587067 88.60894 88.63015 88.650726 88.670738 88.689865 88.707092 88.72467 88.742569 88.759903 88.776772 88.793358 88.808418 88.822472 88.837646 88.852455 88.86689 88.880974 88.894707 88.908112 88.921196 88.933968 88.946449 88.958633 88.970543 88.982185 88.993568 89.0047 89.015587 89.026237 89.036667 89.046883 89.056923 89.065704 89.076904 89.105896 89.143272 89.167892 89.187805 89.224068 89.252022 89.257492 * * 89.273033 89.298515 89.329597 89.367645 89.419411 89.462204 89.500412 89.539635 89.593323 89.663361 89.721352 89.746613 89.763901 89.797508 89.836555 89.857758
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.394493 91.320557 91.05175 90.618736 90.22271 90.111816 90.066002 89.959892 89.818657 * * * * * * * * * 90.375252 90.416954 90.234749 90.036278 89.934425 89.818535 89.852699 90.10817 90.530205 90.87294 90.537071 89.375443 * * * 90.66481 90.884247 90.669106 89.770988 88.516983 87.665367 87.638504 88.032196 88.344139 88.401329 88.098137 87.635452 87.080299 86.436714 85.668861 85.525139 86.134468 86.615654 86.5597 86.23259 85.878944 85.704231 85.717575 85.979904 86.444527 86.869576 87.204704 87.363289 87.375626 87.366531 87.239647 87.014923 * * 86.696426 86.807785 86.916512 87.016525 87.110603 87.198456 87.278145 87.355675 87.430328 87.500793 87.567574 87.630936 87.691147 87.748413 87.802956 87.854958 87.904587 87.952003 87.997353 88.040779 88.080833 88.118423 88.156822 88.193726 88.229126 88.263176 88.295959 88.327538 88.357971 88.387337 88.415672 88.443031 88.
469475 88.495041 88.519775 88.543716 88.566895 88.589355 88.611122 88.632233 88.652733 88.672447 88.690361 88.708038 88.726402 88.744171 88.761444 88.778252 88.794777 88.809776 88.823784 88.838905 88.853668 88.868065 88.882103 88.895798 88.909164 88.922211 88.934944 88.947388 88.959541 88.97142 88.983032 88.994392 89.005493 89.016357 89.026985 89.037384 89.047569 89.057556 89.067383 89.074852 89.088898 89.116226 89.152458 89.184402 89.198631 * 89.20549 89.225868 89.237564 89.267937 89.330269 89.372772 89.419243 89.468384 89.496284 89.531204 89.578522 89.629417 89.679565 89.722115 89.745262 89.764839 89.7882 89.811096 89.829536
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.41449 91.362724 91.139183 90.784546 90.53138 90.454651 90.372696 90.245178 90.080147 * * * * * * * * * * 90.752129 90.855309 90.907234 90.861961 90.816757 90.81636 91.020317 91.460999 91.543037 90.707634 89.689644 * 90.432442 90.800949 91.05545 91.169197 90.61673 89.604706 88.700294 88.572441 89.101662 89.445297 89.468056 89.331535 89.012215 88.507805 87.88134 87.121384 86.29126 86.269165 87.038795 87.510628 87.402351 87.118393 86.750618 86.406204 86.262131 86.595947 87.195198 87.737282 88.174934 88.391327 88.418381 88.421158 88.24894 87.946198 * * * * 86.944176 87.041084 87.133156 87.218994 87.296944 87.37291 87.446159 87.515358 87.581009 87.643356 87.702644 87.759079 87.812874 87.864189 87.913193 87.960045 88.004875 88.047798 88.086372 88.124481 88.162743 88.199226 88.234306 88.268074 88.300583 88.331909 88.362114 88.391251 88.419388 88.446564 88.472832 88
.49823 88.522804 88.5466 88.569649 88.59198 88.613647 88.634659 88.654938 88.673576 88.69133 88.710121 88.72834 88.746017 88.763214 88.779953 88.79641 88.811356 88.825302 88.840363 88.855072 88.869408 88.8834 88.897049 88.91037 88.92337 88.936066 88.948471 88.960594 88.972435 88.984016 88.995331 89.006409 89.017242 89.02784 89.038216 89.04837 89.058311 89.068031 89.077751 89.085373 89.098831 89.132866 89.164604 89.175873 * 89.188446 89.220367 89.232872 89.282028 89.36174 89.405853 89.449066 89.488586 89.516098 89.548203 89.594246 89.636803 89.670418 89.701195 89.734634 89.761818 89.778107 89.791962 89.803719
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.436676 91.442375 91.412895 91.256775 91.006996 90.822121 90.721413 90.622795 90.496162 90.309082 * * * * * * * * * * * 91.268433 91.420235 91.507011 91.606827 91.663452 91.808479 92.05249 91.798706 90.815483 90.360825 90.799355 91.15596 91.231163 91.315842 91.121201 90.356499 89.647415 89.336777 89.564194 90.046539 90.224113 90.14653 89.969872 89.674431 89.213577 88.513962 87.60334 86.867226 86.992706 87.810699 88.27993 88.141624 87.865784 87.4431 87.038544 86.912689 87.205177 87.754463 88.298279 88.747101 89.019958 89.086365 89.025833 * * * * * * * * 87.157829 87.241776 87.317795 87.392036 87.463745 87.531563 87.59597 87.657196 87.715469 87.770988 87.823944 87.874504 87.922821 87.969048 88.013374 88.054886 88.092949 88.13163 88.169289 88.205399 88.240128 88.273567 88.305771 88.336815 88.36676 88.39566 88.423569 88.450531 88.476601 88.501816 88.526222 88.54985
88.572762 88.594933 88.616333 88.63726 88.656799 88.674637 88.693756 88.712425 88.730515 88.7481 88.765213 88.781868 88.798256 88.813156 88.827011 88.842003 88.856651 88.870934 88.884865 88.89846 88.911728 88.924683 88.93734 88.949699 88.961769 88.973579 88.985115 88.996399 89.007439 89.018242 89.028809 89.039146 89.049278 89.059189 89.068909 89.078423 89.087616 89.096878 89.11142 89.123032 89.146034 89.170227 89.187782 89.218559 89.24472 89.298012 89.369614 89.412918 89.449837 89.480988 89.508011 89.537094 89.576668 89.616554 89.650391 89.679222 89.710197 89.739258 89.754845 89.766472 89.773262
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.460991 91.449081 91.364532 91.207634 91.055504 90.938477 90.83857 90.723587 90.523987 * * * * * * * * * * * * * 91.870789 92.049858 92.161148 92.26635 92.30632 92.089943 91.605057 91.292046 91.254005 91.321869 91.490707 91.404053 90.864632 90.356628 90.198967 90.270866 90.412468 90.625366 90.753601 90.730835 90.532326 90.157959 89.771217 89.091187 * 87.336494 87.711166 88.513969 88.849403 88.576828 88.322372 87.978043 87.751175 87.790611 88.002861 88.330185 88.743362 89.150703 89.424286 89.531219 89.399155 * * * * * * * * * * 87.340538 87.412926 87.482971 87.549309 87.612366 87.672379 87.729553 87.784081 87.836128 87.885864 87.933426 87.97905 88.022285 88.061279 88.100723 88.139435 88.176537 88.212227 88.246567 88.279648 88.311516 88.342255 88.37191 88.400543 88.4282 88.454933 88.480782 88.505791 88.530006 88.553459 88.576149 88.597916 88.618172 88.638916 88
.658188 88.677338 88.696457 88.714943 88.732925 88.75042 88.767433 88.784004 88.800262 88.815102 88.828911 88.843826 88.858406 88.872627 88.886497 88.900032 88.913246 88.926147 88.938744 88.951057 88.963089 88.974846 88.986343 88.997589 89.008591 89.019348 89.029884 89.040192 89.050285 89.060173 89.069855 89.079338 89.088661 89.097626 89.105553 89.110954 89.125862 89.154495 89.178108 89.212776 89.252518 89.292587 89.340691 89.385864 89.417297 89.439163 89.478203 89.523621 89.55648 89.587448 89.625458 89.654709 89.682594 89.713387 89.729218 89.738571 *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.512733 91.514465 91.464478 91.358589 91.256493 91.148064 91.040146 90.943565 90.723534 * * * * * * * * * * * * * * * 92.304817 92.373932 92.374611 92.373322 92.09008 91.605766 91.420738 91.547714 91.738831 91.530647 91.005768 90.844887 90.96965 91.103447 91.152893 91.161873 91.109131 91.070389 90.937935 90.572174 90.219032 89.475967 * 87.807724 88.395493 89.18528 89.275932 * 88.633087 88.469444 88.431213 88.56485 88.689972 88.810562 89.108002 89.474937 89.694267 89.758659 * * * * * * * * * * * * * 87.503731 87.568474 87.630104 87.68882 87.744827 87.798279 87.849358 87.898209 87.945038 87.989594 88.030121 88.070129 88.109749 88.147827 88.184441 88.219681 88.253601 88.286293 88.317802 88.348206 88.377548 88.405884 88.433273 88.459747 88.485367 88.510155 88.534157 88.557373 88.578934 88.599953 88.620407 88.640869 88.660957 88.680443 88.699333 88.717712 88.73558
88.75296 88.769875 88.7864 88.802216 88.816437 88.830978 88.84584 88.860336 88.874489 88.88829 88.901764 88.914909 88.927757 88.9403 88.95256 88.964539 88.97625 88.987701 88.998901 89.009857 89.020576 89.031075 89.041344 89.051399 89.061249 89.0709 89.080353 89.089622 89.098724 89.107574 89.11673 89.122238 89.135109 89.162849 89.203232 89.241989 89.270287 89.297844 89.3423 89.377022 89.401009 89.447487 89.503166 89.535927 89.560944 89.595688 89.628426 89.660568 89.688759 89.705078 89.713737 *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.612976 91.638718 91.616386 91.558861 91.465332 91.371269 91.285812 91.184746 91.058609 90.821518 * * * * * * * * * * * * * * * * * 92.330055 92.197945 91.832489 91.506287 * 91.718094 91.846153 91.750053 91.454842 91.46994 91.652145 91.783134 91.821083 91.679604 91.453537 91.327957 91.220375 90.929832 90.482414 * * 88.292915 88.88871 89.530563 89.487473 * 89.076912 88.878044 88.782257 88.883606 88.940727 89.000496 89.241119 89.58358 89.793274 89.831261 * * * * * * * * * * * * * * * 87.649086 87.706436 87.7612 87.81353 87.863579 87.911484 87.957558 88.000565 88.040146 88.08036 88.119377 88.156891 88.192986 88.227737 88.261208 88.29348 88.324608 88.354645 88.383652 88.411674 88.438774 88.464973 88.490334 88.514885 88.538666 88.561623 88.5821 88.602798 88.624084 88.644547 88.664413 88.683716 88.702477 88.720718 88.738464 88.75573 88.772537 88.789017 88.804253 88.8
1823 88.833237 88.848022 88.862442 88.876511 88.890244 88.903648 88.916733 88.929512 88.941994 88.954193 88.966118 88.977776 88.989174 89.000328 89.011238 89.021912 89.032364 89.042595 89.05262 89.062431 89.072044 89.081467 89.090698 89.099724 89.108322 89.116386 89.124557 89.131508 89.148499 89.188377 89.218567 89.239899 89.25309 89.29129 89.327263 89.359261 89.409462 89.458382 89.499863 89.538704 89.570412 89.608177 89.6427 89.664337 89.681694 89.687988 89.691475
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.728661 91.735573 91.681168 91.611832 91.530029 91.409775 91.329437 91.237946 91.072273 * * * * * * * * * * * * * * * * * * * * 91.597511 91.676819 91.778633 * 91.886177 91.942078 91.867119 91.94838 92.14035 92.278511 92.271072 92.075668 91.849915 91.668381 91.458641 91.149582 * * * 88.707336 89.240494 89.707001 89.687149 89.604256 89.556381 89.308052 89.045197 88.984772 89.027534 89.071922 89.270172 89.598389 89.827698 89.892281 * * * * * * * * * * * * * * * * * * 87.829742 87.878716 87.925652 87.97065 88.011917 88.051537 88.091324 88.129692 88.166603 88.202141 88.236374 88.269371 88.301193 88.331909 88.361557 88.390213 88.4179 88.444687 88.470596 88.495682 88.519981 88.543579 88.56562 88.585953 88.607155 88.62812 88.648399 88.668106 88.687248 88.705864 88.723961 88.741577 88.758713 88.775406 88.791756 88.806984 88.820847 88.835693 88.850388 88.864723 88.87870
8 88.892357 88.905685 88.918694 88.931404 88.943825 88.955963 88.967827 88.979431 88.990776 89.001877 89.012733 89.023361 89.033768 89.043953 89.053932 89.063705 89.07328 89.082672 89.091743 89.100121 89.108414 89.116638 89.125153 89.133324 89.143692 89.162888 89.184761 89.211655 89.22168 89.245834 89.27536 89.310211 89.367508 89.421555 89.473488 89.520042 89.554253 89.590981 89.620102 89.643188 89.658249 89.663254 89.670914
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.750946 91.756218 91.703949 91.635307 91.555359 91.425552 91.32473 91.214523 * * * * * * * * * * * * * * * * * * * * 91.64399 91.807091 92.006493 92.065643 92.004288 91.950272 92.022728 92.107101 92.167702 92.35817 92.514549 92.470032 92.305923 92.122337 91.885818 91.612457 91.26796 90.715584 * * 89.03273 89.543686 89.965614 89.996483 89.927887 89.8582 89.667198 89.350075 89.120331 89.133568 89.233879 89.437485 89.725159 89.926117 90.021057 90.01207 89.986465 89.951096 * * * * * * * * * * * * * * * * * 87.940628 87.983208 88.023254 88.063766 88.102951 88.140633 88.176918 88.211868 88.24556 88.278053 88.30941 88.339684 88.368935 88.397202 88.424545 88.450996 88.476601 88.501396 88.525421 88.548859 88.569679 88.590286 88.611755 88.632439 88.652534 88.672058 88.691032 88.709488 88.72744 88.744911 88.761917 88.778481 88.794716 88.80983 88.823586 88.838326 88.852921
88.867165 88.881058 88.894623 88.907867 88.920807 88.933441 88.945793 88.957863 88.969666 88.981201 88.992493 89.003532 89.014343 89.024918 89.035278 89.045418 89.055344 89.065079 89.0746 89.083885 89.092422 89.100296 89.109093 89.117813 89.126305 89.134666 89.142258 89.148239 89.160095 89.179604 89.19368 89.213547 89.242897 89.277016 89.334312 89.401726 89.463066 89.505234 89.539864 89.576599 89.601471 89.623207 89.634789 89.642174 89.652893
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.751328 91.718468 91.651245 91.538826 91.401886 91.293167 * * * * * * * * * * * * * * * * * * * * 91.755035 91.912117 92.122192 92.232002 92.228424 92.197121 92.091125 * 92.161812 * * 92.535912 92.508728 92.392899 92.239822 91.983475 91.702705 91.330925 * * * 89.372414 89.850952 90.224998 90.24778 90.162781 90.060692 89.91024 * * 89.264915 89.523094 89.764732 89.975899 90.13356 90.222855 90.213425 90.147049 * * * * * * * * * * * * * * * * * * * * 88.036835 88.076813 88.115211 88.152176 88.187798 88.222137 88.255264 88.287231 88.3181 88.347923 88.376747 88.404617 88.431587 88.457687 88.482971 88.507462 88.531197 88.554375 88.57515 88.595276 88.616562 88.637039 88.656929 88.67627 88.695068 88.713356 88.731148 88.748466 88.765335 88.781754 88.797859 88.812866 88.826508 88.841133 88.855629 88.869766 88.883575 88.897049 88.91021 88.923058 88.935623 88.947891 88.95
9892 88.971626 88.983101 88.994324 89.00531 89.01606 89.026581 89.036888 89.046974 89.056862 89.066597 89.075729 89.084358 89.092873 89.101593 89.110428 89.119041 89.127495 89.135788 89.143944 89.151985 89.159836 89.164124 89.173401 89.189362 89.219398 89.253395 89.312012 89.390083 89.45179 89.494202 89.523003 89.559746 89.58812 89.603424 89.615189 89.625137 89.627876
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.742828 91.722702 91.656456 91.516823 91.326797 * * * * * * * * * * * * * * * * * * * * 91.857368 92.035675 92.174652 92.280151 92.319191 92.302376 92.296585 92.234756 92.156662 92.199471 * * * * 92.389076 92.259102 92.013206 * * * * * 89.775291 90.169968 90.438438 90.410362 90.363647 90.290306 90.151527 89.886642 * 89.48793 89.880859 90.139801 90.28476 90.399925 90.433853 90.360359 * * * * * * * * * * * * * * * * * * * * * * * 88.128052 88.164284 88.199226 88.232933 88.265465 88.29689 88.327248 88.35659 88.384972 88.41243 88.439011 88.464752 88.489685 88.513855 88.537384 88.559937 88.579941 88.6007 88.621643 88.641899 88.661583 88.680717 88.699333 88.717445 88.735069 88.752235 88.768951 88.785233 88.801201 88.816078 88.829605 88.844116 88.858498 88.872536 88.886238 88.89962 88.912689 88.925453 88.937927 88.950127 88.962051 88.973709 88.985115 88.996277 89.00
7195 89.017883 89.028351 89.038597 89.048637 89.058502 89.068047 89.076302 89.085007 89.094109 89.103027 89.111771 89.120346 89.128761 89.137024 89.145126 89.153084 89.160881 89.168648 89.175797 89.181587 89.202599 89.241646 89.298775 89.37693 89.438965 89.485008 89.512535 89.542542 89.570786 89.586708 89.59494 89.605362 *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.724937 91.708366 91.650414 91.506653 * * * * * * * * * * * * * * * * * * * * * * * * * * * 92.297623 92.268112 92.221909 92.269485 * * * * * * * * * * * * 90.102325 90.453201 90.633011 90.584923 90.59906 90.58094 90.424477 90.205933 89.920685 89.940636 90.267715 90.492004 90.602242 90.652763 90.614632 * * * * * * * * * * * * * * * * * * * * * * * * * * 88.211151 88.244202 88.276131 88.306984 88.336815 88.365669 88.393593 88.420616 88.446793 88.47216 88.496742 88.520645 88.543808 88.564438 88.58522 88.606384 88.626991 88.647018 88.666481 88.685417 88.703835 88.721756 88.739212 88.75621 88.772766 88.788895 88.804726 88.81958 88.832909 88.84726 88.861534 88.875458 88.889053 88.902336 88.915306 88.927986 88.940376 88.952484 88.964333 88.975914 88.987251 88.998337 89.009193 89.019821 89.03022 89.040413 89.050339 89.059586 89.068565 89.077423 89.086578 89.095627 8
9.1045 89.113197 89.121735 89.130112 89.138329 89.146393 89.15432 89.162094 89.169731 89.177223 89.183693 89.196442 89.231758 89.284767 89.353088 89.418335 89.473618 89.502953 89.526016 89.552689 89.568878 89.574631 89.582298 *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.699242 91.685921 91.635521 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.149612 90.795883 90.413719 90.411552 90.730591 90.877869 90.839996 90.894264 90.913437 90.767647 90.586945 90.456261 90.502892 90.64418 90.779594 90.841148 90.824402 90.726532 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.317505 88.346794 88.375137 88.40258 88.429169 88.454933 88.479904 88.50415 88.527748 88.54911 88.569908 88.591309 88.612259 88.632599 88.652382 88.671623 88.690338 88.708549 88.726288 88.743553 88.760376 88.776772 88.792763 88.808296 88.822464 88.836174 88.850571 88.864723 88.878532 88.892021 88.905197 88.918068 88.930649 88.942947 88.954971 88.966736 88.978241 88.989494 89.000511 89.011299 89.021851 89.032211 89.042358 89.051682 89.060226 89.069687 89.079048 89.088226 89.097221 89.106049 89.1147 89.123192 89.131531
89.139709 89.147736 89.155624 89.163361 89.170959 89.178436 89.185242 89.192238 89.213043 89.259247 89.323105 89.390762 89.45253 89.487701 89.510612 89.533463 89.546768 89.551079 * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.657104 91.614662 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.775688 91.629173 91.491478 91.266083 90.988708 90.904175 91.075676 91.198547 91.186768 91.209137 91.204681 91.098579 90.967453 90.897797 90.896408 90.906792 90.943336 90.947441 90.889099 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.357147 88.384972 88.411926 88.438057 88.463394 88.487968 88.511894 88.533989 88.554802 88.576447 88.597717 88.61837 88.638451 88.657982 88.676987 88.69548 88.713486 88.731018 88.7481 88.764748 88.780968 88.796814 88.811882 88.825386 88.839645 88.854042 88.868065 88.881752 88.895126 88.908195 88.920959 88.933441 88.945648 88.957581 88.969254 88.980682 88.991859 89.0028 89.013504 89.024063 89.034088 89.043503 89.052673 89.061981 89.071518 89.080833 89.089951 89.0989 89.107674 89.116287 89.124733 89.133026 89.141159
89.149147 89.15699 89.164696 89.172264 89.179695 89.18705 89.193245 89.199173 89.228523 89.296997 89.364571 89.425491 89.470428 89.494492 89.514771 89.53051 * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.643288 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 92.081512 91.883179 * * 91.413734 91.296509 91.245186 91.298264 91.391243 91.441986 91.435616 91.383682 91.302132 91.212265 91.142609 91.095078 91.060211 91.053123 91.02269 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.4216 88.447266 88.472153 88.496384 88.51915 88.540001 88.561813 88.58342 88.60437 88.624733 88.644539 88.663818 88.682579 88.700836 88.718628 88.735954 88.752838 88.769295 88.785339 88.801025 88.816032 88.829323 88.843384 88.857666 88.871559 88.885124 88.898376 88.911331 88.923988 88.936371 88.948471 88.960312 88.971893 88.983231 88.994324 89.005188 89.015862 89.026192 89.035278 89.044655 89.054413 89.064011 89.073448 89.082695 89.091766 89.100655 89.109383 89.117943 89.126343 89.13459 89.142685 89.150627 89.158432 89.1661 89.173622
89.181023 89.188293 89.195381 89.201736 89.210487 89.266434 89.337555 89.397049 89.442436 89.470436 89.494644 89.51783 * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 92.240463 92.159767 * * * 91.504547 91.402161 91.403152 91.438667 91.452438 91.470421 91.476372 91.47094 91.428741 91.36364 91.303833 91.250526 91.216698 91.191193 91.149803 91.062149 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.481308 88.504692 88.525642 88.547485 88.569405 88.59063 88.611259 88.631325 88.650856 88.669868 88.688377 88.706398 88.723961 88.741081 88.757759 88.774025 88.789894 88.80542 88.819824 88.833092 88.847328 88.861443 88.875191 88.888626 88.901764 88.914597 88.927139 88.939415 88.951416 88.963158 88.974648 88.985893 88.996902 89.007683 89.018356 89.028221 89.037025 89.046768 89.056534 89.066093 89.075455 89.084648 89.093658 89.102493 89.111168 89.119675 89.128029 89.136223 89.144272 89.152176 89.159943 89.167564 89.175049 89.182411 8
9.189636 89.196747 89.203903 89.208191 89.235535 89.298424 89.360962 89.413757 89.452774 89.477249 89.498589 * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.625717 91.702065 91.609695 91.602852 91.621696 91.578499 91.518021 91.48893 91.491951 91.484482 91.466888 91.451004 91.42379 91.383484 91.32267 91.268814 91.178192 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.533546 88.55571 88.577194 88.598061 88.61837 88.638138 88.657379 88.676125 88.694374 88.712158 88.729492 88.746384 88.762863 88.778923 88.794678 88.809547 88.822868 88.83712 88.851418 88.865356 88.878967 88.892273 88.905273 88.917992 88.93042 88.942581 88.954475 88.966118 88.977509 88.988663 88.99958 89.010292 89.020744 89.030106 89.039261 89.04908 89.058754 89.068245 89.077553 89.086678 89.095627 89.104408 89.113029 89.121483 89.129784 89.137932 89.145935 89.153793 89.161507 89.16909 89.176537 89.183861 89.191048 89.19812 89.205093 89
.211601 89.222145 89.26976 89.330894 89.393814 89.440659 89.456825 89.464684 * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.794838 91.863266 91.793968 91.758385 91.745964 91.714569 91.675797 91.609505 91.551811 91.527 91.508011 91.499466 91.506546 91.478722 91.406471 91.335251 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.58519 88.605721 88.625702 88.645164 88.664116 88.682579 88.700569 88.718102 88.735199 88.751869 88.768135 88.784042 88.799255 88.812859 88.826981 88.841507 88.855629 88.869408 88.882881 88.896049 88.90892 88.921509 88.933823 88.945869 88.957657 88.969193 88.980484 88.991539 89.002365 89.013023 89.023163 89.032043 89.041649 89.05146 89.061066 89.070488 89.079727 89.088783 89.097679 89.1064 89.11496 89.12336 89.131607 89.139709 89.147659 89.155472 89.163147 89.170685 89.178085 89.185364 89.19252 89.199547 89.206459 89.213173 89.222878 89.265
64 89.325577 89.385208 89.42498 89.431168 * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.824677 91.894562 91.913361 91.879547 91.844948 91.806381 91.766197 91.751389 91.69928 91.644814 91.601433 91.539757 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.63324 88.652382 88.671036 88.689217 88.70694 88.72422 88.741081 88.757523 88.77356 88.789436 88.803719 88.817032 88.831734 88.846031 88.85997 88.873604 88.886925 88.899948 88.912689 88.925148 88.93734 88.949265 88.960938 88.972366 88.983559 88.994514 89.005249 89.015747 89.025375 89.034393 89.044189 89.053925 89.063461 89.072807 89.081978 89.090973 89.0998 89.108467 89.116966 89.125313 89.133507 89.141548 89.149452 89.157219 89.164841 89.172333 89.179695 89.186928 89.194038 89.201035 89.207909 89.214294 89.227592 89.276443 89.339203 89.385628 89.405716 * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 91.969521 91.939026 * 91.89418 91.882797 91.824799 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.678139 88.696037 88.713486 88.730515 88.747124 88.763336 88.779221 88.794472 88.808083 88.82206 88.836578 88.85067 88.864449 88.877922 88.89109 88.903969 88.916573 88.928902 88.940964 88.952774 88.964333 88.975647 88.986732 88.997589 89.008232 89.018555 89.027542 89.036942 89.046837 89.05648 89.065941 89.075211 89.084312 89.093239 89.102005 89.110603 89.119041 89.127327 89.135468 89.143463 89.151314 89.159019 89.166595 89.174042 89.181358 89.188553 89.195625 89.202576 89.209412 89.215874 89.227333 89.273689 89.332397 89.367363 89.374779 * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.7202 88.736961 88.753319 88.769295 88.784996 88.799805 88.812904 88.827095 88.841476 88.855453 88.869049 88.882362 88.895378 88.908112 88.92057 88.93277 88.944702 88.956383 88.967827 88.979034 88.990005 89.000755 89.01136 89.021263 89.030014 89.039742 89.049553 89.05912 89.068497 89.077698 89.086723 89.095581 89.104279 89.112808 89.121193 89.129417 89.137497 89.145432 89.153229 89.160889 89.168419 89.175812 89.183083 89.190231 89.197258 89.204163 89.21096 89.217682 89.224319 89.246712 89.280876 89.307945 * * * * * *
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.759666 88.775406 88.790802 88.805763 88.819473 88.833015 88.846741 88.860306 88.873779 88.886925 88.89978 88.912369 88.924683 88.936737 88.948547 88.960106 88.97142 88.982513 88.993378 89.004051 89.014214 89.023254 89.032799 89.042686 89.052353 89.061836 89.071129 89.080254 89.089211 89.097992 89.106621 89.115089 89.123405 89.131569 89.139587 89.147469 89.155212 89.162819 89.170296 89.177643 89.18486 89.191963 89.198944 89.205811 89.212563 89.219238 89.225464 89.232445 89.240128 89.254082 89.267212 * * 89.304657 89.323273 89.34697
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.796776 88.811638 88.826012 88.839737 88.852341 88.865234 88.878616 88.891594 88.904297 88.916733 88.928902 88.940819 88.952484 88.963921 88.975113 88.986092 88.996834 89.007523 89.016922 89.025803 89.035873 89.045662 89.055237 89.064629 89.073845 89.082886 89.091766 89.100479 89.109032 89.117432 89.125687 89.133789 89.141747 89.149567 89.157249 89.164803 89.172226 89.179527 89.186699 89.193748 89.200684 89.207512 89.214211 89.220848 89.227448 89.23275 89.23661 89.243492 89.249916 89.257011 89.263557 89.278603 89.310867 89.337646
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.831787 88.845772 88.857872 88.870323 88.883575 88.896378 88.90892 88.921196 88.93322 88.944992 88.956528 88.967827 88.978897 88.989754 89.00042 89.010796 89.019714 89.029076 89.039047 89.048706 89.058189 89.067497 89.07663 89.085594 89.094391 89.103027 89.111511 89.119843 89.128029 89.13607 89.143967 89.151726 89.159355 89.166847 89.174217 89.181465 89.188583 89.195587 89.202477 89.209251 89.215973 89.222435 89.228462 89.23423 89.240105 89.246117 89.251495 89.257339 89.262566 89.270996 89.299629 89.329369
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.862938 88.875618 88.888626 88.901268 88.913643 88.925758 88.937637 88.949265 88.960663 88.971832 88.982773 88.993507 89.00415 89.013763 89.022644 89.032486 89.042259 89.051826 89.061218 89.070435 89.079483 89.088364 89.097084 89.105652 89.114059 89.122322 89.130432 89.138405 89.14624 89.153938 89.161507 89.168953 89.176262 89.183456 89.190529 89.197479 89.20433 89.211159 89.217804 89.223419 89.229263 89.235435 89.241631 89.247765 89.253868 89.259804 89.265663 89.270554 89.28669 89.319809
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.893784 88.90625 88.918457 88.93042 88.942139 88.953629 88.964882 88.975914 88.986732 88.997337 89.007919 89.017075 89.025948 89.035912 89.045555 89.055023 89.064323 89.073448 89.082413 89.091209 89.099846 89.10833 89.116669 89.124855 89.132904 89.140808 89.148575 89.156212 89.163719 89.171104 89.17836 89.185501 89.19252 89.199425 89.206245 89.212708 89.218849 89.224556 89.230759 89.237083 89.243286 89.249367 89.255356 89.261261 89.26712 89.271065 89.280457 89.312561
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.92337 88.935173 88.946739 88.958076 88.969193 88.980087 88.990776 89.001259 89.01165 89.021133 89.029762 89.039352 89.04892 89.058296 89.067497 89.07653 89.085403 89.094116 89.102676 89.111076 89.119339 89.127457 89.135429 89.143265 89.15097 89.158546 89.165993 89.173309 89.180511 89.187584 89.194595 89.201523 89.207878 89.213608 89.219879 89.226219 89.232582 89.238815 89.244957 89.250999 89.256958 89.262817 89.2686 89.273422 89.280571 89.308212
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.951416 88.962608 88.973579 88.984337 88.994896 89.005249 89.015427 89.025391 89.034042 89.042809 89.052353 89.06163 89.070732 89.079674 89.088455 89.097084 89.10556 89.113884 89.12207 89.130112 89.138016 89.145782 89.153419 89.160927 89.168312 89.175568 89.182709 89.189781 89.196625 89.203049 89.209076 89.215088 89.221642 89.228081 89.234383 89.24057 89.246674 89.252678 89.258591 89.26442 89.270187 89.274429 89.282547 89.312996
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 88.978043 88.988663 88.999084 89.009315 89.019341 89.02935 89.038017 89.046387 89.055855 89.065033 89.074036 89.082886 89.091576 89.100121 89.108505 89.116753 89.124855 89.13282 89.140648 89.148346 89.155922 89.163361 89.170677 89.177895 89.185066 89.19207 89.198067 89.204201 89.21064 89.217163 89.223633 89.22998 89.236221 89.242371 89.248428 89.254395 89.260269 89.266052 89.271843 89.274742 89.284782 89.323685
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.003349 89.013451 89.023361 89.033211 89.041702 89.050072 89.059425 89.068497 89.077408 89.086159 89.094757 89.10321 89.111511 89.119675 89.127701 89.13559 89.143341 89.15097 89.15847 89.16584 89.173157 89.180321 89.187111 89.193634 89.199539 89.206032 89.2127 89.219223 89.225616 89.231911 89.238106 89.244209 89.250221 89.256149 89.261978 89.267723 89.273476 89.276695 89.284256 89.326759
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.027443 89.037178 89.045456 89.05378 89.063065 89.072021 89.080833 89.089485 89.097992 89.106354 89.114571 89.12265 89.1306 89.138405 89.146088 89.153641 89.161064 89.168419 89.175491 89.18219 89.188538 89.195 89.201622 89.208305 89.214844 89.221291 89.227631 89.233879 89.240036 89.246094 89.25206 89.257935 89.263725 89.269432 89.275185 89.278175 89.284531 89.328957
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.041168 89.049599 89.057693 89.066727 89.075607 89.084312 89.092873 89.101288 89.109558 89.117691 89.125687 89.133545 89.141281 89.14888 89.15638 89.163826 89.171013 89.17717 89.183693 89.190376 89.197151 89.203926 89.210518 89.21701 89.223404 89.229698 89.235893 89.241997 89.248009 89.253929 89.259766 89.265518 89.271179 89.276573 89.279259 89.288773 89.338173
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.062019 89.070389 89.079247 89.087852 89.096313 89.10463 89.112808 89.120857 89.128761 89.136543 89.144196 89.151741 89.159157 89.166275 89.172974 89.179008 89.185905 89.192848 89.199615 89.206245 89.212784 89.219215 89.225555 89.231796 89.237946 89.244003 89.249962 89.255844 89.261627 89.267365 89.273048 89.277763 89.281288 89.289253 89.339882
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.082932 89.091438 89.0998 89.108025 89.116112 89.124069 89.131897 89.139587 89.147217 89.154716 89.161591 89.168045 89.174759 89.181625 89.188568 89.195343 89.202026 89.208603 89.215088 89.221466 89.227745 89.23394 89.240036 89.24604 89.251953 89.257782 89.263557 89.269196 89.274536 89.279221 89.283768 89.286522 89.327164
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.10334 89.111473 89.119469 89.127327 89.135071 89.142693 89.15004 89.157211 89.163628 89.170204 89.177322 89.184319 89.191147 89.197868 89.204491 89.211006 89.217422 89.223747 89.22998 89.236115 89.242157 89.248116 89.253983 89.259781 89.265572 89.270592 89.27552 89.280792 89.286026 89.288582 89.310333
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.11496 89.122864 89.130638 89.13829 89.145859 89.152466 89.159126 89.166061 89.173149 89.180145 89.187012 89.193771 89.200432 89.206985 89.21344 89.219803 89.226067 89.232246 89.238327 89.244316 89.250221 89.256088 89.261879 89.267143 89.271782 89.277008 89.282494 89.28788 89.292923 89.299408
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.133987 89.141548 89.149086 89.155281 89.161682 89.169022 89.176048 89.182945 89.189743 89.196434 89.203026 89.209518 89.215919 89.222221 89.228424 89.234543 89.24057 89.246513 89.252388 89.258072 89.263519 89.268341 89.273499 89.279015 89.284401 89.289719 89.295227 89.298592
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.152206 89.158432 89.164871 89.17202 89.178955 89.185783 89.192513 89.199135 89.205666 89.21209 89.21843 89.22467 89.23082 89.236877 89.242867 89.248802 89.254517 89.259476 89.264671 89.270027 89.275536 89.280968 89.286308 89.291573 89.296745 89.30201
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.168053 89.175041 89.1819 89.18866 89.195312 89.201874 89.208328 89.214699 89.22097 89.22715 89.233246 89.239265 89.245171 89.250893 89.256187 89.26091 89.266487 89.27211 89.277565 89.282936 89.288239 89.293465 89.298615 89.303703
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.178101 89.184883 89.191566 89.198151 89.204643 89.211037 89.217339 89.223549 89.229668 89.235733 89.241722 89.247192 89.252357 89.257645 89.263138 89.268745 89.274216 89.279617 89.284943 89.290199 89.29538 89.300491 89.305534
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.194511 89.201027 89.207443 89.213776 89.220009 89.226151 89.232224 89.238136 89.243843 89.248833 89.254066 89.259789 89.265411 89.270912 89.276337 89.281693 89.286972 89.292183 89.297325 89.302391 89.307396
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.210281 89.216537 89.22271 89.228806 89.234756 89.239998 89.245354 89.250832 89.256516 89.262131 89.267662 89.273109 89.278488 89.283798 89.289032 89.294197 89.299294 89.304321 89.30928
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.225471 89.231499 89.236885 89.24173 89.247467 89.253265 89.258911 89.264458 89.269936 89.275337 89.28067 89.285927 89.291115 89.296234 89.301285 89.306274 89.311195
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.233879 89.238647 89.244324 89.250099 89.255745 89.261314 89.266815 89.27224 89.277588 89.282867 89.288078 89.293221 89.298302 89.303307 89.30825 89.313156
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.246979 89.25264 89.258232 89.263748 89.269196 89.274567 89.279869 89.285095 89.29026 89.295357 89.300385 89.305359 89.310249 89.315048
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.26075 89.266212 89.271599 89.276917 89.282166 89.287354 89.292465 89.297516 89.302498 89.307442 89.31208 89.316368
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.274025 89.279297 89.284492 89.289627 89.294693 89.299698 89.304642 89.309425 89.313499 89.317688
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.286842 89.291924 89.296944 89.301872 89.306694 89.310966 89.315018 89.319763
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.299248 89.303795 89.308121 89.3125 89.317116 89.321831
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.309776 89.314568 89.319267 89.323898
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.316742 89.321388 89.325981
+* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 89.328087
Added: grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/test_r_viewshed.py
--- grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/test_r_viewshed.py (rev 0)
+++ grass/branches/releasebranch_7_0/raster/r.viewshed/testsuite/test_r_viewshed.py 2015-01-01 22:16:37 UTC (rev 63919)
@@ -0,0 +1,123 @@
+import grass.gunittest
+from grass.gunittest.gmodules import call_module
+class TestViewshed(grass.gunittest.TestCase):
+ viewshed = 'test_viewshed_from_elevation'
+ @classmethod
+ def setUpClass(cls):
+ cls.use_temp_region()
+ cls.runModule('g.region', raster='elevation')
+ @classmethod
+ def tearDownClass(cls):
+ cls.del_temp_region()
+ def tearDown(cls):
+ """Remove viewshed map after each test method"""
+ # TODO: eventually, removing maps should be handled through testing framework fucntions
+ cls.runModule('g.remove', flags='f', type='raster',
+ name=cls.viewshed)
+ def test_limits(self):
+ """Test if results is in expected limits"""
+ obs_elev = '1.72'
+ self.assertModule('r.viewshed', input='elevation',
+ coordinates=(634720,216180), output=self.viewshed,
+ observer_elevation=obs_elev)
+ self.assertRasterMinMax(map=self.viewshed, refmin=0, refmax=180,
+ msg="Viewing angle above the ground must be between 0 and 180 deg")
+ def test_limits_flags(self):
+ obs_elev = '1.72'
+ # test e flag
+ self.assertModule('r.viewshed', input='elevation', flags='e',
+ coordinates=(634720, 216180), output=self.viewshed,
+ minmax = 'null_cells=1963758\nmin=-24.98421\nmax=43.15356'
+ self.assertRasterFitsUnivar(raster=self.viewshed, reference=minmax, precision=1e-5)
+ # test b flag (#1788)
+ self.assertModule('r.viewshed', input='elevation', flags='b',
+ observer_elevation=obs_elev, overwrite=True)
+ minmax = 'min=0\nmax=1\ndatatype=CELL'
+ self.assertRasterFitsInfo(raster=self.viewshed, reference=minmax,
+ msg="Values of binary output must be 0 or 1")
+ def test_limits_extreme_value(self):
+ """Test extremely high observer elevation
+ Unfortunatelly, this takes very long time to compute
+ (something like ten times more).
+ obs_elev = '500000'
+class TestViewshedAgainstReference(grass.gunittest.TestCase):
+ Data created using NC data set::
+ g.region n=216990 s=215520 w=633730 e=635950 res=10 -p
+ r.out.ascii elevation out=data/elevation.ascii
+ r.viewshed input=elevation output=lake_viewshed coordinates=634720,216180 observer_elevation=1.72
+ r.out.ascii lake_viewshed out=data/lake_viewshed.ascii
+ # precision for comparisons
+ precision = 0.0001
+ # list to hold rasters to be removed
+ # here we accumulate all rasters created during tests
+ # then we remove them at the end in class tear down
+ to_remove = []
+ @classmethod
+ cls.runModule('g.region', n=216990, s=215520, e=635950, w=633730, res=10)
+ cls.elevation = 'ref_elevation'
+ cls.runModule('r.in.ascii', input='data/elevation.ascii',
+ output=cls.elevation)
+ @classmethod
+ name=cls.elevation)
+ if cls.to_remove:
+ name=','.join(cls.to_remove))
+ def test_viewshed(self):
+ ref_viewshed = 'reference_viewshed'
+ viewshed = 'actual_viewshed'
+ obs_elev = '1.72'
+ self.runModule('r.in.ascii',
+ input='data/lake_viewshed.ascii', output=ref_viewshed)
+ self.to_remove.append(ref_viewshed)
+ self.assertModule('r.viewshed', input=self.elevation,
+ coordinates=(634720,216180), output=viewshed, observer_elevation=obs_elev)
+ self.to_remove.append(viewshed)
+ # check we have expected values
+ self.assertRasterMinMax(map=viewshed, refmin=0, refmax=180,
+ msg="Viewshed in degrees must be between 0 and 180")
+ # check against reference data
+ self.assertRastersNoDifference(actual=viewshed, reference=ref_viewshed,
+ precision=self.precision)
+ # TODO: add self.assertRasterFitsUnivar()
+if __name__ == '__main__':
+ grass.gunittest.test()
