[GRASS-SVN] r63924 - in grass/branches/releasebranch_7_0/general: g.list g.list/testsuite g.parser g.remove g.remove/testsuite g.setproj g.tempfile
svn_grass at osgeo.org
Thu Jan 1 14:49:11 PST 2015
Author: neteler
Date: 2015-01-01 14:49:11 -0800 (Thu, 01 Jan 2015)
New Revision: 63924
Added:
grass/branches/releasebranch_7_0/general/g.list/testsuite/
grass/branches/releasebranch_7_0/general/g.list/testsuite/test_g_list.py
grass/branches/releasebranch_7_0/general/g.remove/testsuite/
grass/branches/releasebranch_7_0/general/g.remove/testsuite/test_g_remove.py
grass/branches/releasebranch_7_0/general/g.parser/main.c
grass/branches/releasebranch_7_0/general/g.setproj/get_stp.c
grass/branches/releasebranch_7_0/general/g.tempfile/main.c
g.*: minor backports; testsuites backported
Added: grass/branches/releasebranch_7_0/general/g.list/testsuite/test_g_list.py
--- grass/branches/releasebranch_7_0/general/g.list/testsuite/test_g_list.py (rev 0)
+++ grass/branches/releasebranch_7_0/general/g.list/testsuite/test_g_list.py 2015-01-01 22:49:11 UTC (rev 63924)
@@ -0,0 +1,55 @@
+"""g.list tests"""
+import grass.gunittest
+from grass.gunittest.gmodules import SimpleModule
+class GMlistWrongParamertersTest(grass.gunittest.TestCase):
+ """Test wrong input of parameters for g.list module"""
+ @classmethod
+ def setUpClass(cls):
+ """Create maps in a small region."""
+ cls.use_temp_region()
+ cls.runModule("g.region", s=0, n=5, w=0, e=5, res=1)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove temporary region"""
+ cls.del_temp_region()
+ def test_pt_flags(self):
+ """Test that -p and -t flags are exclusive"""
+ module = SimpleModule('g.list', flags='pt', type='raster')
+ self.assertModuleFail(module)
+ stderr = module.outputs.stderr
+ self.assertIn('-p', stderr)
+ self.assertIn('-t', stderr)
+ def test_ft_flags(self):
+ """Test that -f and -t flags are exclusive"""
+ module = SimpleModule('g.list', flags='ft', type='raster')
+ self.assertIn('-f', stderr)
+ def test_pf_flags(self):
+ """Test that -p and -f flags are exclusive"""
+ module = SimpleModule('g.list', flags='pf', type='raster')
+ def test_re_flags(self):
+ """Test that -r and -e flags are exclusive"""
+ module = SimpleModule('g.list', flags='re', type='raster')
+ self.assertIn('-r', stderr)
+ self.assertIn('-e', stderr)
+if __name__ == '__main__':
+ grass.gunittest.test()
Property changes on: grass/branches/releasebranch_7_0/general/g.list/testsuite/test_g_list.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
Modified: grass/branches/releasebranch_7_0/general/g.parser/main.c
--- grass/branches/releasebranch_7_0/general/g.parser/main.c 2015-01-01 22:36:28 UTC (rev 63923)
+++ grass/branches/releasebranch_7_0/general/g.parser/main.c 2015-01-01 22:49:11 UTC (rev 63924)
@@ -29,11 +29,14 @@
int main(int argc, char *argv[])
+ char *progname;
struct context ctx;
const char *filename;
int standard_output;
int separator_nul;
+ progname = argv[0];
ctx.module = NULL;
ctx.option = NULL;
ctx.flag = NULL;
@@ -67,8 +70,8 @@
if ((argc < 2) || ((strcmp(argv[1], "help") == 0) ||
(strcmp(argv[1], "-help") == 0) ||
(strcmp(argv[1], "--help") == 0))) {
- fprintf(stderr, "%s: %s [-t] [-s] <filename> [<argument> ...]\n",
- _("Usage"), argv[0]);
+ fprintf(stderr, "%s: %s [-t] [-s] [-n] <filename> [<argument> ...]\n",
+ _("Usage"), progname);
exit(EXIT_FAILURE);
Added: grass/branches/releasebranch_7_0/general/g.remove/testsuite/test_g_remove.py
--- grass/branches/releasebranch_7_0/general/g.remove/testsuite/test_g_remove.py (rev 0)
+++ grass/branches/releasebranch_7_0/general/g.remove/testsuite/test_g_remove.py 2015-01-01 22:49:11 UTC (rev 63924)
@@ -0,0 +1,109 @@
+"""Test of g.remove module"""
+# TODO: rmapcalc probably fatals, replace or add raise on error?
+from grass.script.raster import mapcalc as rmapcalc
+from grass.gunittest.gutils import get_current_mapset
+# when used user1 must be replaced by current mapset
+REMOVE_RASTERS = """raster/test_map_0 at user1
+raster/test_map_1 at user1
+raster/test_map_2 at user1
+raster/test_map_3 at user1
+raster/test_map_4 at user1
+raster/test_map_5 at user1
+raster/test_map_6 at user1
+raster/test_map_7 at user1
+raster/test_map_8 at user1
+raster/test_map_9 at user1
+raster/test_two at user1
+REMOVING_RASTERS_LOG = """Removing raster <test_map_0>
+Removing raster <test_map_1>
+Removing raster <test_map_2>
+Removing raster <test_map_3>
+Removing raster <test_map_4>
+Removing raster <test_map_5>
+Removing raster <test_map_6>
+Removing raster <test_map_7>
+Removing raster <test_map_8>
+Removing raster <test_map_9>
+Removing raster <test_two>
+class GMRemoveTest(grass.gunittest.TestCase):
+ """Test removing with g.remove"""
+ @classmethod
+ """Set up small region for fast map creation."""
+ @classmethod
+ def test_remove_procedure(self):
+ """Test that maps are removed only with -f"""
+ for i in range(0, 10):
+ rmapcalc("test_map_%i = 100" % i)
+ rmapcalc("test_two = 2")
+ module = SimpleModule('g.remove',
+ type='raster', pattern='test_map_*,*two')
+ self.assertModule(module)
+ self.assertMultiLineEqual(module.outputs.stdout,
+ REMOVE_RASTERS.replace('user1',
+ get_current_mapset()))
+ module = SimpleModule('g.remove', type='raster',
+ pattern='test_map_*,*two', flags='f')
+ self.assertMultiLineEqual(module.outputs.stdout, '')
+ self.assertMultiLineEqual(module.outputs.stderr, REMOVING_RASTERS_LOG)
+ def test_remove_procedure_exclude(self):
+ """Test that exclude does not list excluded maps"""
+ rmapcalc("test_apples = 100")
+ rmapcalc("test_oranges = 200")
+ rmapcalc("test_apples_big = 300")
+ rmapcalc("test_apples_small = 300")
+ pattern='test_{apples,oranges}*',
+ exclude="*_small")
+ 'raster/test_apples at user1\n'
+ 'raster/test_apples_big at user1\n'
+ 'raster/test_oranges at user1\n'.replace(
+ 'user1', get_current_mapset()))
+ pattern='test_{apples,oranges}{_small,_big,*}',
+ flags='f')
+ self.assertRegexpMatches(module.outputs.stderr, "(.*<.+>[^\n]*\n){4}",
+ msg="4 maps should be removed")
+class GMRemoveWrongInputTest(grass.gunittest.TestCase):
+ """Test wrong input of parameters for g.remove module"""
+ module = SimpleModule('g.remove', flags='re',
+ type='raster', pattern='xxxyyyzzz')
Property changes on: grass/branches/releasebranch_7_0/general/g.remove/testsuite/test_g_remove.py
+ text/x-python
+ native
Modified: grass/branches/releasebranch_7_0/general/g.setproj/get_stp.c
--- grass/branches/releasebranch_7_0/general/g.setproj/get_stp.c 2015-01-01 22:36:28 UTC (rev 63923)
+++ grass/branches/releasebranch_7_0/general/g.setproj/get_stp.c 2015-01-01 22:49:11 UTC (rev 63924)
@@ -40,7 +40,7 @@
fprintf(stderr, "\nInvalid Co-ordinate System Specification\n");
if (get_stp_code(code, string, buff) == 0)
- G_fatal_error(_("This should not happen see your system admin"));
+ G_fatal_error(_("This should not happen. See your system admin."));
return;
@@ -122,7 +122,7 @@
if (icode != 0)
break;
else { /* no match */
- G_warning(_("No match of fips state %d county %d"), SFIPS, CFIPS);
+ G_warning(_("No match of FIPS state %d county %d"), SFIPS, CFIPS);
fclose(fipsfile);
Modified: grass/branches/releasebranch_7_0/general/g.tempfile/main.c
--- grass/branches/releasebranch_7_0/general/g.tempfile/main.c 2015-01-01 22:36:28 UTC (rev 63923)
+++ grass/branches/releasebranch_7_0/general/g.tempfile/main.c 2015-01-01 22:49:11 UTC (rev 63924)
@@ -29,7 +29,7 @@
struct GModule *module;
struct Option *pid;
struct Flag *dry_run;
- char *tempfile, *G__tempfile();
+ char *tempfile;
int p;
G_gisinit(argv[0]);
